W83L786NG
W83L786NG
    NUVOTON(新唐)
    SSOP20_208MIL
    IC H/W MONITOR 20-SSOP
W83L786NG 数据手册
W83L786NR W83L786NG Nuvoton H/W Monitoring IC W83L786NR/ W83L786NG W83L786NR Data Sheet Revision History PAGES DATES VERSION VERSION ON WEB MAIN CONTENTS Pin 10: from Vram_SEN to VTIN1 Pin 11: from Vcore_SEN to D1 P.13 10/15/04 0.6 N/A Pin 13: from Vref to Vcore_SEN Pin 14: from D- to Vram_SEN Pin 15: from D1+ to Vref 2 P.14, P.18, P.51, P.55 11/15/04 0.7 N/A Add pin function description, functional description, electrical characteristics and top marking explanation 3 P.1, P.3, P.5, P.9 07/04/05 0.8 N/A Correct temp. sensor measurement method 4 N.A. 03/31/06 0.9 N/A Add Pb-free package version; remove application circuit 5 Please note that all data and specifications are subject to change without notice. All the trademarks of products and companies mentioned in this data sheet belong to their respective owners. LIFE SUPPORT APPLICATIONS These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. -I- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG Table of Contents1. GENERAL DESCRIPTION ......................................................................................................... 1 2. FEATURES ................................................................................................................................. 2 2.1 Monitoring Items .............................................................................................................. 2 2.1.1 Temperature.....................................................................................................................2 2.1.2 Voltage .............................................................................................................................2 2.1.3 Fan ...................................................................................................................................2 2.2 Actions Enabling .............................................................................................................. 2 2.3 General ............................................................................................................................ 2 2.4 Package ........................................................................................................................... 2 3. KEY SPECIFICATIONS .............................................................................................................. 3 4. BLOCK DIAGRAM ...................................................................................................................... 3 5. PIN CONFIGURATION ............................................................................................................... 4 6. PIN DESCRIPTION..................................................................................................................... 5 7. FUNCTIONAL DESCRIPTION.................................................................................................... 8 7.1 General Description ......................................................................................................... 8 7.2 Access Interface .............................................................................................................. 8 7.3 The First Serial Bus Access Timing................................................................................. 8 7.4 Analog Inputs ................................................................................................................... 9 7.5 7.6 7.7 8. 7.4.1 Voltage Input can not be over 2.048V ............................................................................10 7.4.2 Voltage Fault (VOLTAGE_FAULT #)..............................................................................10 Temperature Measurement Machine............................................................................. 10 7.5.1 Monitor Temperature from Thermistor............................................................................11 7.5.2 Monitor Temperature from Thermal Diode .....................................................................11 7.5.3 Temperature Fault (TEMP_FAULT #) ............................................................................12 FAN Speed Count and FAN Speed Control .................................................................. 12 7.6.1 Fan Speed Count ...........................................................................................................12 7.6.2 Fan Speed Control .........................................................................................................14 7.6.3 SMART FANTM I Control ...............................................................................................16 7.6.4 SMART FANTM II Control ..............................................................................................17 7.6.5 Fan Fault (FAN_FAULT #) .............................................................................................19 Fault Signal—INT#......................................................................................................... 19 7.7.1 Temperature...................................................................................................................19 7.7.2 Voltage ...........................................................................................................................21 7.7.3 Fan .................................................................................................................................21 CONTROL AND STATUS REGISTER ..................................................................................... 22 - II - W83L786NR/ W83L786NG 8.1 Configuration Register - Index 40h ................................................................................ 22 8.2 INT# Status Register 1 - Index 41h ............................................................................... 22 8.3 INT# Status Register 2 - Index 42h ............................................................................... 22 8.4 INT# Mask Register 1 - Index 43h ................................................................................. 23 8.5 INT# Mask Register 2 - Index 44h ................................................................................. 23 8.6 Register - Index 45h....................................................................................................... 23 8.7 Register - Index 46h....................................................................................................... 24 8.8 GPIO/GPO Function Enable Control Register - Index 47h............................................ 24 8.9 Register - Index 48h....................................................................................................... 24 8.10 GPIO1-2 & 5-7 I/O Mode Control Register - Index 49h ................................................. 24 8.11 GPO3-4 Output Data Register - Index 4Ah ................................................................... 25 8.12 GPIO1-2 & 5-7 Data Register - Index 4Bh..................................................................... 26 8.13 Nuvoton Vendor ID (Low Byte) - Index 4Ch .................................................................. 26 8.14 Nuvoton Vendor ID (High Byte) - Index 4Dh.................................................................. 26 8.15 Chip ID - Index 4Eh........................................................................................................ 26 8.16 Register - Index 4Fh ...................................................................................................... 27 8.17 Register - Index 50h....................................................................................................... 27 8.18 GPIO1-2 & 5-7 Output Mode Control Register - Index 51h ........................................... 27 8.19 INT# Property Select - Index 52h .................................................................................. 28 8.20 Thermal Sensor 1/2 Type Register - Index 53h............................................................. 28 8.21 Fan Divisor Register - Index 54h ................................................................................... 28 8.22 Reserved - Index 55h ~ 5Fh .......................................................................................... 29 8.23 FAN Configuration Register - Index 80h........................................................................ 30 8.24 DC FAN1 Output Voltage Level Control Register (Manual Mode) / FAN1 Output Voltage Table (SMART FANTM II Mode) – Index 81h ................................................................. 30 8.25 FAN1 Output Voltage Table (SMART FANTM II Mode) - Index 82h............................. 31 8.26 TEMP0 (D+_D-) Target Temperature Register (Thermal Cruise Mode) / TEMP_POINT1 for FAN1 (SMART FANTM II Mode) - Index 83h............................................................. 31 8.27 TEMP_POINT2 for FAN1 (SMART FANTM II Mode) - Index 84h................................. 31 8.28 FAN 1 Speed Low Limit Rate Control Register (Thermal Cruise Mode) / TEMP_POINT3 for FAN1 (SMART FANTM II Mode) - Index 85h................................... 32 8.29 TEMP_POINT4 for FAN1 (SMART FANTM II Mode) - Index 86h................................. 32 8.30 DC FAN2 Output Voltage Level Control Register (Manual Mode)/ FAN2 Output Voltage Table (SMART FANTM II Mode) - 87h ............................................................................ 32 8.31 FAN2 Output Voltage Table (SMART FANTM II Mode) - Index 88h............................. 33 8.32 TEMP1 (VTIN1) Target Temperature Register (Thermal Cruise Mode) / TEMP_POINT1 for FAN2 (SMART FANTM II Mode) - Index 89h................................... 33 - III - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 9. 8.33 TEMP_POINT2 for FAN2 (SMART FANTM II Mode) - Index 8Ah ................................ 33 8.34 FAN 2 Speed Low Limit Rate Control Register/ TEMP_POINT3 for FAN2 SMART FANTM II Mode) - Index 8Bh........................................................................................... 34 8.35 TEMP_POINT4 for FAN2 (SMART FANTM II Mode) - Index 8Ch ................................ 34 8.36 Tolerance of Temperature Register - Index 8Dh ........................................................... 34 8.37 FAN 2D/3D state Control Register - Index 8Eh ............................................................. 35 8.38 FAN Pre-Scale Register - Index 8Fh ............................................................................. 35 8.39 FAN Initial Output Value – Index90h ............................................................................. 36 8.40 Fan Step down Time Register - Index 91h .................................................................... 36 8.41 Fan Step up Time Register - Index 92h......................................................................... 36 8.42 Temperature Sensor 0 (D+_D-) Offset Register - Index 93h......................................... 37 8.43 Temperature Sensor 1 (VTIN1) Offset Register – Index 94h ........................................ 37 8.44 Register - Index 95h....................................................................................................... 37 8.45 Register - Index 96h....................................................................................................... 38 8.46 Register - Index 97h....................................................................................................... 38 8.47 Value RAM - Index 20h- 3Fh or 60h - 7Fh..................................................................... 38 ELECTRICAL CHARACTERISTICS......................................................................................... 40 9.1 Absolute Maximum Ratings ........................................................................................... 40 9.2 DC Characteristics ......................................................................................................... 40 9.3 AC Characteristics ......................................................................................................... 42 9.3.1 Serial Bus Timing Diagram.............................................................................................42 9.3.2 VID Input Skew...............................................................................................................42 10. THE TOP MARKING................................................................................................................. 43 11. PACKAGE SPECIFICATION .................................................................................................... 44 - IV - W83L786NR/ W83L786NG 1. GENERAL DESCRIPTION W83L786NR/NG is an evolving product of W83L785R -- Nuvoton's most popular hardware monitoring IC, and intelligent fan controlling IC. Specifically designed for the graphic cards and barebone /mini systems, W83L786NR/NG can be used to monitor several critical hardware parameters of the system, including voltages, fan speeds, and temperatures, which are very important for the system to work stably and properly. W83L786NR/NG can monitor up to 3 analog voltage inputs, 2 fan tachometer inputs, and 2 remote temperature sensors. One of the temperature inputs is connected to CPU/GPU thermal diode sensor, and the other remote temperature sensor could be performed by either thermal diode or thermistor. Power-on fan_set configuration offers the function to choose one of the four duty cycles, 100%, 81%, 62%, 43%, as initial fan speed. 2 sets of PWM (Pulse Width Modulation) / DC (Direct Current) fan TM TM TM output for SMART FAN control – “Thermal Cruise ” mode and “SMART FAN II “mode. Under TM “Thermal Cruise “mode, temperatures of GPU and the system can be maintained within specific programmable ranges under the hardware control. Under “SMART FANTM II” mode, the fan could be operated at the lowest possible speed for minimum acoustic noise, and the dynamic intelligent fan management could create the most quiet system environment and stable working performance. An 8bit analog-to-digital converter (ADC) is built inside W83L786NR/NG. As for warning mechanism, W83L786NR/NG provides four pure hardware event pins for independent warning signals: VOLTAGE_FAULT#, FAN_FAULT#, TEMP_FAULT#, and INT#. All threshold values could be set for system protection without any timing delay. One bit power-on address selection is used to decide the address of the W83L786NR/NG over I2C serial bus interface. W83L786NR/NG also provides up to 7 optional multifunctional GPIO. W83L786NR/NG is powered by 3.3V. Through the application software or BIOS, the users can read all the monitored parameters of system from time to time. A pop-up warning can also be activated when the monitored item is out of the proper / preset range. The application software could be Nuvoton's Hardware DoctorTM, IntelTM LDCM (LanDesk Client Management), or other management application software. Also the users can set up the upper and lower limits (alarm thresholds) of these monitored parameters and activate one programmable interrupts. For the spacing saving consideration of the Graphic cards and Notebook system, W83L786NR/NG is 20-pin SSOP package. -1- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 2. FEATURES 2.1 2.1.1 2.1.2 2.1.3 2.2 Monitoring Items Temperature „ Measure the temperature with high accuracy. „ One thermal diode sensor (current mode) connected to CPU/GPU and one remote sensor either by thermal diode (current mode) or thermistor. „ Programmable hysteresis and setting points (alarm thresholds) for all monitored items. Voltage „ 3 voltage sensor inputs. --- Typically for Vcore, RAM, etc. Fan „ 3D/2D application being used and transferring fan set to the most appropriate fan speed control. „ Fan set: power on configuration for fan speed at four rotation rate levels at 43%, 62%, 81%, and 100% duty cycle. „ Two DC/PWM fan output control. „ SMART FANTM function compliant. Actions Enabling „ „ „ 2.3 General „ „ „ „ „ 2.4 Total up to 2 sets of fan speed monitoring and controlling. Issue FAN_FAULT#, VOLTAGE_FAULT#, TEMP_FAULT#, and INT# signals to activate system protection. Warning signal pop-up in application software. Interface: I²C / SMBus control. 1 bit I2C address selection. Up to 7 GPIOs. Nuvoton hardware monitoring application software (Hardware DoctorTM) support Windows 95 / 98 / 2000 / XP and Windows NT 4.0 / 5.0. 3.3V VCC operation. Package „ 20-pin SSOP (209mil). -2- W83L786NR/ W83L786NG 3. KEY SPECIFICATIONS „ „ „ „ „ „ ±3% (typ.) 0°C to +160°C; ± 3°C (max.) 3.3V±10% 2 mA (typ.) 10 uA (typ.) 8 Bits Voltage monitoring accuracy Monitoring temperature range and accuracy Supply voltage Operating supply current Power down supply current ADC resolution 4. BLOCK DIAGRAM V c o re DDR RAM OR O T H E R D E V IC E POW ER PW M GPU D - R e m o te T h e r m is t o r D + V T IN 1 G P U D IO D E SENSOR VREF THERM AL SENSOR G P IO G P IO C O N T R O L L O G IC & R E G IS T E R IN T # FAN _FAU LT# F a u lt D e t e c t o r VO LTAG E_FAU LT# TEM P_FAU LT# I2 C FAN CONTROL FAN _SET ( IN IO U T _ G P O ) VO LTAG E SENSOR V CC F A N IN 1 GND F A N IN 2 SDA V c o re _ S E N SCL ADDR V RAM _S E N FANOUT1 FAN 1 FANOUT2 FAN 2 -3- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 5. PIN CONFIGURATION 1 20 VOLTAGE_FAULT#/GPIO7 TEMP_FAULT#/GPIO2 2 19 INT# SCL 3 18 PWM/DC_OUT2/GPIO6 SDA 4 17 PWM/DC_OUT1 Vcc 5 16 GND ADDR/GPO3 6 15 VREF FAN_SET/GPO4 7 14 VRAM_SEN FANIN1 8 13 VCORE_SEN FANIN2/GPIO5 9 12 D+ VTIN1 10 11 D- W83L786NR FAN_FAULT/GPIO1 -4- W83L786NR/ W83L786NG 6. PIN DESCRIPTION PIN TYPE PIN ATTRIBUTE I/O12t TTL level bi-directional pin with 12 mA source-sink capability I/O12ts TTL level and schmitt trigger with 12 mA source-sink capability I/O8ts TTL level and schmitt trigger with 8 mA source-sink capability I/O6ts TTL level and schmitt trigger with 6 mA source-sink capability I/OD12ts TTL level and schmitt trigger open drain output with 12 mA sink capability OUT12 Output pin with 12 mA source-sink capability OD12 Open-drain output pin with 12 mA sink capability AOUT Output pin (Analog) INt TTL level input pin INts TTL level input pin and schmitt trigger AIN Input pin(Analog) PIN NAME NO FAN_FAULT# PIN TYPE OD12 DESCRIPTION Active-Low output. This pin will be a logic LOW when the fan1 or fan2 is abnormally stopped. (Default) 1 General purpose I/O function. GPIO1 I/OD12TS This multi-functional pin is programmable. Active-Low output. This pin will be a logic LOW when the TEMP_FAULT# OD12 2 GPIO2 temperature of the system or CPU exceeds its limit. (Default) I/OD12TS SCL 3 INt s SDA 4 I/OD12 Vcc 5 POWER General purpose I/O function. This multi-functional pin is programmable. Digital Input. SMBus serial clock input. Requires SMBus pull-up. Digital I/O (Open drain). SMBus bidirectional serial data. Requires SMBus pull-up. Power supply input. -5- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG Continued PIN NAME NO PIN TYPE 6 INTS/OUT12 ADDR DESCRIPTION Determines the SMBus device address. GPO3 General purpose Output function. This multi-functional pin is programmable. Determines the FAN initial speed. Power on configuration FAN_SET AIN 7 GPO4 FANIN1 OUT12 8 FANIN2 for fan speed at four rotation rate levels at 43%, 62%, 81%, and 100%. General purpose Output function. This multi-functional pin is programmable. INTS 0V to +3.3V amplitude fan tachometer input. (Default) INTS 0V to +3.3V amplitude fan tachometer input. (Default) 9 GPIO5 OUT12TS General purpose I/O function. This multi-functional pin is programmable. Analog Input. Connect to either diode sensor (current VTIN1 10 AIN mode) or thermistor. Anode to VTIN1 if VTIN1 is connected to diode sensor (current mode). D- 11 AIN Thermistor 2 terminal input (Default) / Cathode to CPU Thermal Diode. Also cathode to VTIN1 if VTIN1 is connected to diode sensor (current mode). Please connect this pin to the ground, see page 15, figure 5. D+ 12 AIN Thermistor 1 terminal input (Default) / Anode to CPU Thermal Diode. V CORE _SEN 13 AIN Analog Input. Monitors CPU core voltage (0V-3V). V RAM _SEN 14 AIN Analog Input. Monitors RAM’s voltage. VREF 15 AOUT Reference voltage. -6- W83L786NR/ W83L786NG Continued PIN NAME NO PIN TYPE GND 16 GROUND PWM / DC OUT1 17 OD12 PWM / DC OUT2 OD12 DESCRIPTION Ground pin for the W83L786NR Fan speed control output. This pin is default DC output level. It can be programmed as PWM output. Fan speed control output. This pin is default DC output level. It can be programmed as PWM output. 18 GPIO6 INT# I/OD12TS 19 VOLTAGE_FAULT# OD12 OD12 General purpose I/O function. This multi-functional pin is programmable. System Interrupt. Active-Low output. This pin will be a logic LOW when the voltage exceeds its high/low limit. (Default) 20 GPIO7 I/OD12TS General purpose I/O function. This multi-functional pin is programmable.. -7- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7. FUNCTIONAL DESCRIPTION 7.1 General Description The W83L786NR/NG provides 3 analog voltage inputs, 2 fan speed inputs and outputs which support both PWM (Pulse Width Modulation) fan control and DC (Direct Current) fan control, all of them being implemented with SMART FANTM I and SMART FANTM II, and 2 sets of thermal inputs for CPU/GPU thermal diode sensor or remote temperature sensor. W83L786NR/NG is I2C / SMBus interface compatible. Furthermore, the Watch Dog Timer will monitor every function and store the values to registers for comparison with preset ranges. If the monitored value exceeds the limit value, the interrupt status will be set to 1 and W83L786NR/NG will issue interrupt signals such as INT# and IRQ if not masked. W83L786NR/NG also provides software and hardware Watch Dog Timer to avoid system hang on. 7.2 Access Interface The W83L786NR/NG provides I2C Serial Bus for microprocessor to read/write internal registers, and the I2C address default value is 01011110b (Pin 6 pull high). If Pin 6 pulls low, the I2C address value is 01011100b. 7.3 The First Serial Bus Access Timing (a) Serial bus writes to internal address register followed by the data byte 0 7 8 0 7 8 SCL 0 SDA Start By Master 1 0 1 1 0 1 R/W D7 D6 Ack by 792D Frame 1 Serial Bus Address Byte D5 D4 D3 D2 D1 D0 Ack by 792D Frame 2 Internal Index Register Byte 0 7 8 SCL (Continued) SDA (Continued) D7 D6 D5 D4 D3 D2 D1 D0 Ack by 792D 784R Frame 3 Data Byte Figure 1. Serial Bus Write to Internal Address Register followed by the Data Byte -8- Stop by Master W83L786NR/ W83L786NG (b) Serial bus read from a register 0 7 8 0 7 8 SCL 0 SDA 1 0 Start By Master 1 1 0 1 R/W D7 D6 Ack by 792D Frame 1 Serial Bus Address Byte D5 D4 D3 D2 D1 D0 Ack by 792D Frame 2 Internal Index Register Byte 0 0 7 0 1 0 1 1 0 1 0 R/W 7 D7 Ack by 792D Frame 3 Serial Bus Address Byte Repeat start by Master 8 D6 D5 D4 D3 D2 D1 8 D0 Nak by Master Frame 4 Data Byte Stop by Master 0 Figure 2. Serial Bus Read from Internal Address Register 7.4 Analog Inputs The maximum input voltage of the analog pin is 2.048V because the 8-bit ADC has the 8mV LSB. Actually, the application of the voltage monitoring would most often be connected to power suppliers. The input voltage lower than 2.048V could directly connect to the analog inputs. The inputs voltage higher than 2.048V should be reduced by external resistors so as to meet the input range. This is shown in Figure 3. VCORE(M ax2.048V) Pin 13 Positive Inputs R1 VRAM (M ax2.048V) +2.5V Pin 14 100K, 1% R2 100K, 1% 10K, 1% Typical Therm ister Connection VREF 8-bit ADC with 8mV LSB Pin 15 VTIN1 Pin 10 R THM **The connections of D+ is same as VTIN1 10K, 25 C Figure 3 -9- Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7.4.1 Voltage Input can not be over 2.048V The input voltage Vcore, and Vram can be expressed as following equation: VRAM = V+ 2.5V × R2 R1 + R2 . V+2.5V is +2.5V inputs. The value of R1 and R2 can be selected to 100K Ohms and 100K Ohms, respectively, when the input voltage is 2.5V. The node voltage of VRAM can be subject to less than 2.048V for the maximum input range of the 8-bit ADC. The pin 5 is connected to the power supply VCC with +3.3V. There are two functions in this pin with 3.3V: the first function is to supply internal analog power of the W83L786NR/NG and the second function is to connect this pin to internal serial resistors to monitor the +3.3V voltage. The values of two serial resistors are 20K ohms and 40K ohms so that input voltage to ADC is 1.1V which is less than 2.048V of ADC maximum input voltage. The express equation can represent as follows. Vin = VCC × 20 KΩ ≅ 1.1V 20 KΩ + 40 KΩ where VCC is set to 3.3V. 7.4.2 Voltage Fault (VOLTAGE_FAULT #) W83L786NR/NG provides a good protection for voltage. Set Pin 20 (VOLTAGE_FAULT#) to monitor voltage. When Vcore (Pin13), Vram (Pin14), or VCC (Pin5) voltage exceeds high or low voltage limit in VR2B ~ VR34, Pin 20 VOLTAGE_FAULT# will be asserted (Figure 4). V o lta g e H ig h lim it V o lta g e L o w lim it VOLTAGE_FAULT# F ig u re 4 . V o lta g e F au lt 7.5 Temperature Measurement Machine - 10 - W83L786NR/ W83L786NG The temperature data format is 8-bit unsigned for thermal sensor. The 8-bit temperature data can be obtained by reading the VR [25h] or VR [26h]. The format of the temperature data is shown in Table 1. TEMPERATURE 8-BIT DIGITAL OUTPUT 8-BIT BINARY 8-BIT HEX +160°C 1010,0000 A0h +25°C 0001,1001 19h +2°C 0000,0010 02h +1°C 0000,0001 01h +0°C 0000,0000 00h Table 1 7.5.1 Monitor Temperature from Thermistor The W83L786NR/NG can connect one thermistor and one thermal diode sensor to measure two different environment temperatures. The specification of thermistor should be considered to (1) β value is 3435 K, and (2) resistor value is 10K ohms at 25°C. In the Figure 3, the themistor is connected by a serial resistor with 10K Ohms, and then connect to VREF (pin 15). 7.5.2 Monitor Temperature from Thermal Diode The W83L786NR/NG can alternate the thermistor to thermal diode interface and the circuit connection is shown as Figure 5. The pin of D- is connected to power supply ground (GND) and the pin D+ is connected to pin D+ or VTIN1 in the W83L786NR/NG. The bypass capacitor C=2200pF should be added to filter the high frequency noise. CPU or G PU D+ D+ T h e r m in a l D io d e C=2200pF D- D- W 83L 786N R B ip o la r T r a n s is to r T e m p e r a tu r e s e n s o r V T IN 1 C=2200pF 2N 3904 Figure 5 - 11 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7.5.3 Temperature Fault (TEMP_FAULT #) W83L786NR/NG provides a good protection for temperature fault. Set Pin 2 (TEMP_FAULT#) to monitor temperature. When D+-D- (Pin12, 11), or VTIN1 (Pin10) temperature exceeds temperature fault limit in VR35 or VR37, Pin 2 TEMP_FAULT# will be asserted (Figure 6). TEM P_FA U LT lim it TEM P_FA U LT# F ig u re 6 . T E M P _ F A U L T 7.6 7.6.1 FAN Speed Count and FAN Speed Control Fan Speed Count Inputs are provided by the signals from fans equipped with tachometer outputs. The level of these signals should be set to TTL level, and maximum input voltage cannot be over VCC. If the input signals from the tachometer outputs are over the VCC, the external trimming circuit should be added to reduce the voltage to obtain the input specification. The normal circuit and trimming circuits are shown in Figure 7. Determine the fan counter according to: Count = 135 . × 106 RPM × Divisor In other words, the fan speed counter has been read from register VR28 or VR29, and the fan speed can be evaluated by the following equation. 135 . × 10 6 RPM = Count × Divisor The default divisor is 2 and defined at CR54.bit0~2, bit4~6 which are three bits for divisor. That provides very low speed fan counter such as power supply fan. Table 2 is an example for the relation of divisor, RPM, and count. DIVISOR NOMINAL RPM COUNTS TIME PER - 12 - 70% RPM TIME FOR 70% W83L786NR/ W83L786NG REVOLUTION 1 8800 6.82 ms 153 6160 9.74 ms 2 (default) 4400 13.64 ms 153 3080 19.48 ms 4 2200 27.27 ms 153 1540 38.96 ms 8 1100 54.54 ms 153 770 77.92 ms 16 550 109.08 ms 153 385 155.84 ms 32 275 218.16 ms 153 192 311.68 ms 64 137 436.32 ms 153 96 623.36 ms 128 68 872.64 ms 153 48 1246.72 ms Table 2 +12V +12V Pull-up resister 4.7K Ohms Pull-up resister < 1K or totem-pole output +12V +12V 22K~30K Fan Input FAN Out > 1K Pin 8 Pin 9 Fan Input FAN Out Pin 8 Pin 9 GND GND 10K W83L786NR 3.3V Zener W83L786NR FAN Connector Figure 7-2. Fan with Tach Pull-Up to +12V, or Totem-Pole Putput and Zener Clamp Figure 7-1. Fan with Tach Pull-Up to +12V, or Totern-Pole Output and Register Attenuator +5V +5V Pull-up resister 4.7K Ohms Pull-up resister < 1K or totem-pole output +5V +5V 1K~2.7K FAN Out Fan Input > 1K Pin 8 Pin 9 Fan Input FAN Out Pin 8 Pin 9 GND GND 10K W83L786NR 3.3V Zener W83L786NR FAN Connector Figure 7-4. Fan with Tach Pull-Up to +5V, or Totem-Pole Putput and Zener Clamp Figure 7-3. Fan with Tach Pull-Up to +5V, or Totern-Pole Output and Register Attenuator - 13 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7.6.2 Fan Speed Control The W83L786NR/NG provides two sets for PWM/DC fan speed control. The duty cycle of PWM or the output voltage of DC can be programmed by a 4-bit register. There are four mode to control fan speed which are set by programming CR80 [3:2] and CR [5:4], and default are FAN_SET mode. 7.6.2.1. Default Fan Speed Setting There is a pin to set the default value for fan speed control by adjusting external serial resistors. After power up, the default value will be stored in CR90 (FAN_SET mode). The figure and table are shown below. V C C R a F A N _ S E T R b SECTION FAN SPEED RATE RA RB 3 100﹪ 9.1K × 2 81﹪ 4.7K 9.1K 1 62﹪ 9.1K 4.7K 0 43﹪ × 9.1K Figure 8 OFFSET Setting 7.6.2.2. PWM Mode Duty − cycle(%) = Programmed 4 - bit Register Value ×100% 16 - 14 - W83L786NR/ W83L786NG +5V +12V R1 R1 R2 R2 PNP Transistor D G PWM Clock Input PNP Transis D G PWM Clock Input NMOS S + C NMOS S + C FAN FAN - - Figure 9 7.6.2.3. DC Mode W83L786NR/NG has a 4-bit DAC, which produces 0 to 3.3 voltages DC output that provides maximum 2 sets for fan speed control. The analog output can be programmed in the CR 81, and CR 87 (manual mode). The expression of output voltage can be represented as follows, OUTPUT Voltage = VCC × Programmed 4 - bit Register Value 16 The application circuit is shown as follows, IO+12V IO+12V Q1 NPN R1 3 FANOUT 0 C1 2 4 + LM358 1 - Tachometer ou 0.1U 3 2 1 11 IO-12V R3 FAN R4 47K 33K Figure 10 Be careful when choosing the OP-AMP and the transistor. The OP-AMP is used for amplify the 5V range of the DC output up to 12V. The transistor should has a suitable β value to avoid its base current pulling down the OP-AMP ’s output and gain the common current to operate the fan at fully speed. (For more cost and effort efficient solution please refer to W83391TS/QS – the DC fan predriver that could provide up to 24V gate voltage for external N-channel MOSFET driving) - 15 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7.6.3 SMART FANTM I Control W83L786NR/NG supports two sets SMART FANTM I function and mapping to D+,D- (PWM/DC_OUT1), VTIN1 (PWM/DC_OUT2) . If CR80 [3:2] or CR80 [5:4] set to 2’b10, Fan1 or Fan2 will enable SMART FANTM I function. At this mode, W83L786NR/NG provides the SMART FANTM system to automatically control fan speed to keep the temperatures of CPU and the system within specific range. At first a wanted temperature and interval must be set (ex. 55 °C ± 3 °C) by BIOS and the fan speed will be lowered as long as the current temperature remains below the setting value. Once the temperature exceeds the high limit (58°C), the fan will be turned on with a specific speed set by BIOS (ex: 80% duty cycle) and automatically controlled its PWM duty cycle with the temperature varying. Three conditions may occur: (1) If the temperature still exceeds the high limit (ex: 58°C), PWM duty cycle will increase slowly. If the fan has been operating in its full speed but the temperature still exceeds the high limit (ex: 58°C), a warning message will be issued to protect the system. (2) If the temperature goes below the high limit (ex: 58°C), but still above the low limit (ex: 52°C), the fan speed will be fixed at the current speed because the temperature is in the target range (ex: 52 °C ~ 58°C). (3) If the temperature goes below the low limit (ex: 52°C), PWM duty cycle will decrease slowly to 0 or a preset stop value until the temperature exceeds the low limit. Figure 11-1, 11-2 gives an illustration of Thermal Cruise Mode. A B C 58`C 55`C 52`C PWM Duty Cycle 100 Fan Start = 20% 50 0 Figure 11-1 - 16 - D W83L786NR/ W83L786NG A B C D 58`C 55`C 52`C Fan Start = 20% PWM 100 Fan Start = 20% Duty Cycle 50 Fan Stop = 10% 0 Figure 11-2 Of course, SMART FANTM control system can be disabled and the fan speed control algorithm can be programmed by BIOS or application software. 7.6.4 SMART FANTM II Control W83786NR/NG provides 4 temperature points each can automatically control PWM or DC fan mode. Each temperature maps ps different fan out level, the relationship is shown as follows: Fan Duty Cycle Temp. Tolerance Fan Duty Cycle 100% Fan Duty Cycle Level 3 Fan Duty Cycle Level 2 Fan Duty Cycle Level 1 Non-Stop Duty Cycle Temp. 1 Temp.2 Temp.3 Temp.4 Temperature Figure 12 SMART FANTM II behaviors - 17 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG The SMART FANTM II, a new innovation of Nuvoton, is specifically designed to operate fans at the lowest possible speed so as to minimize acoustic noise. As the figure shown above, it is clear that SMART FANTM II describes a relationship between Fan PWM Duty Cycle/DC Level and temperature. Users can program CR [80h] to enable SMART FANTM II mode. SMART FANTM II registers allow users to define suitable fan output levels to improve acoustic noise, power consumption and reliability issues regarding to specific fan. Each fan has 4 duty cycle registers and 4 temperature point registers to setup the relation between fan output and temperature. Tolerance registers CR [8Dh] is used to postpone the response of fan output and avoid fan output throttles at each temperature point because fan throttling might produce some undesired noise. TM The mechanism of SMART FAN II is described as follows: (1) At first, the fan speed operates at Non-Stop Duty Cycle, and keeps constant while temperature rises. When rising temperature hits critical Temp.1, fan speed remains unchanged. If the temperature keeps on rising and finally hits the upper edge of Temp. Tolerance of Temp.1, it triggers the fan speed change mechanism and fan speed jumps from Non-Stop Duty Cycle to Fan Duty Cycle Level 1. (2) Fan speed remains constant at Fan Duty Cycle Level 1 even though the monitored temperature hits Temp.2. (3) Fan speed will directly jump from Fan Duty Cycle Level 1 to Fan Duty Cycle Level 2 while the monitored temperature hits the upper edge of Temp. Tolerance of Temp.2. (4) Same mechanism happens between Temp.3 and Temp.4. (5) If the monitored temperature between Temp.3 and Temp.4, for example, begins to fall, the fan will keep its speed at Fan Duty Cycle Level 3, which is a constant. (6) If the monitored temperature keeps on falling, the fan speed still remains the same unless the temperature hits the lower edge of Temp. Tolerance of Temp.3. (7) Once the monitored temperature hits the lower edge of Temp. Tolerance of Temp.3, the fan speed reduces directly from Fan Duty Cycle Level 3 to Fan Duty Cycle Level 2, and keeps the same speed until the temperature hits the next lower edge of Temp. Tolerance. - 18 - W83L786NR/ W83L786NG REGISTER D+, D- – FAN1 Non-Stop Duty Cycle Duty Level 1 Duty Level 2 Duty Level 3 Temp Point 1 Temp Point 2 Temp Point 3 Temp Point 4 Tolerance 7.6.5 CR[81h] b3:b0 CR[81h] b7:b4 CR[82h] b3:b0 CR[82h] b7:b4 CR[83h] b7:b0 CR[84h] b7:b0 CR[85h] b7:b0 CR[86h] b7:b0 CR[8Dh] b3:b0 VTIN1 – FAN2 CR[87h] b3:b0 CR[87h] b7:b4 CR[88h] b3:b0 CR[88h] b7:b4 CR[89h] b7:b0 CR[8Ah] b7:b0 CR[8Bh] b7:b0 CR[8Ch] b7:b0 CR[8Dh] b7:b4 Fan Fault (FAN_FAULT #) W83L786NR/NG provides a good protection for fan speed. Set Pin 1 (FAN_FAULT#) to monitor fan speed. When FANIN1 (Pin8) or FANIN2 (Pin9) exceeds fan count high limit in VR3B or VR3C. Pin1 FAN_FAULT# will be asserted (Figure 13). F a n c o u n t lim it FA N _FA U LT # F ig u re 1 3 . F A N _ F A U L T 7.7 7.7.1 Fault Signal—INT# Temperature Pin INT# for temperature has 3 modes. 7.7.1.1. Comparator Interrupt Mode Temperature exceeding TO causes an interrupt and this interrupt will be reset when reading all of the Interrupt Status Registers. Once an interrupt event has occurred by exceeding TO, then reset, if the temperature remains above the THYST, the interrupt will occur again when the next conversion has completed. If an interrupt event has occurred by exceeding TO and not reset, the interrupts will not occur again. The interrupts will continue to occur in this manner until the temperature goes below THYST. (Figure 14-1) - 19 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 7.7.1.2. Two-Times Interrupt Mode Temperature exceeding TO causes an interrupt and then temperature going below THYST will also cause an interrupt if the previous interrupt has been reset by reading all the interrupt Status Register. Once an interrupt event has occurred by exceeding TO, then reset, if the temperature remains above the THYST, the interrupt will not occur. (Figure 14-2) 7.7.1.3. One-Time Interrupt Mode Temperature exceeding TO causes an interrupt and then temperature going below THYST will not cause an interrupt. Once an interrupt event has occurred by exceeding TO, then going below THYST, an interrupt will not occur again until the temperature exceeding TO. (Figure 14-3) TOI TOI THYST THYST SMI# * * * * * SMI# * * * *Interrupt Reset when Interrupt Status Registers are read Figure 14-1. Comparator Interrupt Mode TO TH Figure 14-2. Two-Times Interrupt Mode I Y S T S M I# * * * In te rru p t R e s e t w h e n In te rru p t S ta tu s R e g is te rs a re re a d F ig u re 1 4 -3 . O n e -T im e In te rru p t M o d e - 20 - W83L786NR/ W83L786NG 7.7.2 Voltage INT# interrupt for voltage is Two-Times Interrupt Mode. Voltage exceeding high limit or going below low limit will causes an interrupt if the previous interrupt has been reset by reading all the interrupt Status Register. (Figure 15-1) 7.7.3 Fan INT# interrupt for fan is Two-Times Interrupt Mode. Fan count exceeding the limit, or exceeding and then going below the limit (set at value ram index 3Bh and 3Ch), will causes an interrupt if the previous interrupt has been reset by reading all the interrupt Status Register. (Figure 15-2) Voltage High limit Fan Count limit Voltage Low limit SMI# * * * SMI# * * * *Interrupt Reset when Interrupt Status Registers are read Figure 15-1. Voltage SMI# Mode Figure 15-2. Fan SMI# Mode - 21 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8. CONTROL AND STATUS REGISTER 8.1 Configuration Register - Index 40h Power on default [7:0] = 0000, 0001b BIT 7 NAME READ/WRITE Software Reset Read/Write Reserved Read/Write 4 SOFT_PWDN Read/Write 3 2 Reserved Reserved Read/Write Read/Write 1 INT# Main Mask Read/Write 0 START Read/Write 6-5 8.2 DESCRIPTION A one restores power on default value to all registers except the Serial Bus Address register. This bit is itself clear when it is set. Reserved Software Power Down. Set to 1 to power down this chip, but I2C interface is still working. Reserved Reserved A one disables the INT# outputs without affecting the contents of Interrupt Status Registers. The device will stop monitoring. It will resume upon clearing of this bit. A one enables startup of monitoring operations; a zero puts the part in standby mode. Note: The outputs of Interrupt pins will not be cleared if the user writes a zero to this location after an interrupt has occurred unlike "INT_Clear'' bit. INT# Status Register 1 - Index 41h Power on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION 7 Reserved Read Only Reserved 6 TEMP1_STS Read Only A one indicates a High or Low limit has been exceeded from temperature sensor 1 (VTIN1). This bit is cleared when this register is read. 5 TEMP0_STS Read Only A one indicates a High or Low limit has been exceeded from temperature sensor 0 (D+_D-). This bit is cleared when this register is read. 4-3 Reserved Read Only Reserved 2 VCC_STS Read Only A one indicates a High or Low limit has been exceeded. (VCC, +3.3V) This bit is cleared when this register is read. 1 VRAM_STS Read Only A one indicates a High or Low limit has been exceeded. (VRAM) This bit is cleared when this register is read. 0 VCORE_STS Read Only A one indicates a High or Low limit has been exceeded. (VCORE) This bit is cleared when this register is read. 8.3 INT# Status Register 2 - Index 42h - 22 - W83L786NR/ W83L786NG Power on default [7:0] = 0000, 0000 b BIT 7-2 NAME READ/WRITE DESCRIPTION Reserved Read Only Reserved. 1 FAN2_STS Read Only A one indicates the fan count limit has been exceeded. This bit is cleared when this register is read. 0 FAN1_STS Read Only A one indicates the fan count limit has been exceeded. This bit is cleared when this register is read. 8.4 INT# Mask Register 1 - Index 43h Power on default = 1101, 1110 b BIT NAME READ/WRITE DESCRIPTION 7 Reserved Read/Write Reserved 6 MSK_T1_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (Temperature 1) 5 MSK_T0_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (Temperature 0) Reserved Read/Write Reserved 2 MSK_VCC_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (VCC, +3.3V) 1 MSK_VRAM_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (VRAM) 0 MSK_VCORE_I NT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (VCORE) 4-3 8.5 INT# Mask Register 2 - Index 44h Power on default = 1111, 1110 b BIT 7-2 NAME READ/WRITE DESCRIPTION Reserved Read/Write Reserved. 1 MSK_FAN2_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (Fan 2 speed counter) 0 MSK_FAN1_INT Read/Write A one disables the corresponding interrupt status bit for SMI# interrupt. (Fan 1 speed counter) 8.6 Register - Index 45h Power on default [7:0] = 0000, 0000 b - 23 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG BIT 7-0 8.7 NAME READ/WRITE Reserved Read/write DESCRIPTION Reserved. Register - Index 46h Power on default [7:0] = 0000, 0000 b BIT 7-0 8.8 NAME READ/WRITE Reserved Read/write DESCRIPTION Reserved GPIO/GPO Function Enable Control Register - Index 47h Power on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION Pin 2 Function Select. 7 EN_GPIO2 Read/Write - Function of Pin 2 is TEMP_FAULT#. - Function of Pin 2 is GPIO2. Pin 1 Function Select. 6 EN_GPIO1 Read/Write - Function of Pin 1 is FAN_FAULT#. - Function of Pin 1 is GPIO1. Pin 20 Function Select. 5 EN_GPIO7 Read/Write - Function of Pin 20 is VOLTAGE_FAULT#. - Function of Pin 20 is GPIO7. 4-3 Reserved Read/Write Reserved Pin 18 Function Select. 2 EN_GPIO6 Read/Write - Function of Pin 18 is PWM/DC_OUT2. - Function of Pin 18 is GPIO6. Pin 9 Function Select. 1 EN_GPIO5 Read/Write - Function of Pin 9 is FANIN2. - Function of Pin 9 is GPIO5. Enable GPO3 & GPO4 Function of Pin 6 & Pin7. 0 EN_GPO3 &4 Read/Write - Functions of GPO3 & GPO4 are disabled. - Functions of GPO3 & GPO4 are enabling. 8.9 Register - Index 48h Reserved 8.10 GPIO1-2 & 5-7 I/O Mode Control Register - Index 49h Power on default [7:0] = 0000, 0000 b - 24 - W83L786NR/ W83L786NG BIT 7 NAME Reserved READ/WRITE Read/write DESCRIPTION Reserved. GPIO2 I/O Mode Select. (Only for GPIO function of Pin 2 is enabled.) 6 GPIO2_MODE Read/Write - GPIO2 is an input port. - GPIO2 is an output port. GPIO1 I/O Mode Select. (Only for GPIO function of Pin 1 is enabled.) 5 GPIO1_MODE Read/Write - GPIO1 is an input port. - GPIO1 is an output port. GPIO7 I/O Mode Select. (Only for GPIO function of Pin 20 is enabled.) 4 GPIO7_MODE Read/Write - GPIO7 is an input port. - GPIO7 is an output port. 3-2 Reserved Read/Write Reserved GPIO6 I/O Mode Select. (Only for GPIO function of Pin 18 is enabled.) 1 GPIO6_MODE Read/Write - GPIO6 is an input port. - GPIO6 is an output port. GPIO5 I/O Mode Select. (Only for GPIO function of Pin 9 is enabled.) 0 GPIO5_MODE Read/Write - GPIO5 is an input port. - GPIO5 is an output port. 8.11 GPO3-4 Output Data Register - Index 4Ah Power on default [7:0] = 000P, PPPP b (P: power on trapping) BIT NAME READ/WRITE DESCRIPTION 7 Reserved Read/write Reserved. 6 GPO4_VAL Read/Write GPO4 Value. Set the output value of GPO4 pin. 5 GPO3_VAL Read/Write GPO3 Value. Set the output value of GPO3 pin. Reserved Read/Write Reserved 4-0 - 25 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.12 GPIO1-2 & 5-7 Data Register - Index 4Bh Power on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION 7 Reserved Read/write Reserved. 6 GPIO2_VAL Read/Write GPIO2 Value. Set the output value of GPIO2 pin. Reading this bit will return the value of pin 2. 5 GPIO1_VAL Read/Write GPIO1 Value. Set the output value of GPIO1 pin. Reading this bit will return the value of pin 1. 4 GPIO7_VAL Read/Write GPIO7 Value. Set the output value of GPIO7 pin. Reading this bit will return the value of pin 20. Reserved Read/Write Reserved 1 GPIO6_VAL Read/Write GPIO6 Value. Set the output value of GPIO6 pin. Reading this bit will return the value of pin 18. 0 GPIO5_VAL Read/Write GPIO5 Value. Set the output value of GPIO5 pin. Reading this bit will return the value of pin 9. 3-2 8.13 Nuvoton Vendor ID (Low Byte) - Index 4Ch Power-on default [7:0] = 1010, 0011 b (0xA3h) BIT NAME 7:0 VIDL[7:0] READ/WRITE Read Only DESCRIPTION Vendor ID Low Byte. Default A3h. 8.14 Nuvoton Vendor ID (High Byte) - Index 4Dh Power-on default [7:0] = 0101, 1100 b (0x5Ch) BIT 7:0 NAME VIDH[7:0] READ/WRITE Read Only DESCRIPTION Vendor ID High Byte. Default 5Ch 8.15 Chip ID - Index 4Eh Power on default [7:0] = 1000, 0000 b BIT NAME READ/WRITE DESCRIPTION 7-0 CHIPID[7:0] Read Only Nuvoton Chip ID number. Read this register will return 0x80h for W83L786NR/NG. - 26 - W83L786NR/ W83L786NG 8.16 Register - Index 4Fh Reserved 8.17 Register - Index 50h Reserved 8.18 GPIO1-2 & 5-7 Output Mode Control Register - Index 51h Power on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE 7 Reserved Read/write 6 GPIO2_OB Read/write 5 GPIO1_OB Read/write 4 GPIO7_OB Read/write Reserved Read/write 1 GPIO6_OB Read/write 0 GPIO5_OB Read/write 3-2 DESCRIPTION Reserved. Enable GPIO2 as Output Buffer. Set to GPIO2 can drive logical high or logical low. GPIO2 is open-drain. Enable GPIO1 as Output Buffer. Set to GPIO1 can drive logical high or logical low. GPIO1 is open-drain. Enable GPIO7 as Output Buffer. Set to GPIO7 can drive logical high or logical low. GPIO7 is open-drain. Reserved Enable GPI6 as Output Buffer. Set to GPIO6 can drive logical high or logical low. GPIO6 is open-drain. Enable GPIO5 as Output Buffer. Set to GPIO5 can drive logical high or logical low. GPIO5 is open-drain. - 27 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.19 INT# Property Select - Index 52h Power on - --0000, 0100 b BIT NAME READ/WRITE DESCRIPTION 7-4 Reserved Read/Write 3-2 TEMP_INT_MD [1:0] Read/Write 1 EN_INT# Read/Write 0 Reserved Read/Write Reserved. Temperature INT Mode Select. - Comparator Interrupt Mode: Temperature 1/2 exceeds TO (Overtemperature) limit causes an interrupt. Reading the Interrupt Status will reset this interrupt. - Two Time Interrupt Mode:(Default) This bit use in temperature sensor 1/2 interrupt mode with hysteresis and TO type. Temperature exceeding TO, causes an interrupt and then temperature going below THYST will also cause another interrupt if the previous interrupt has been reset by reading the interrupt Status Register. Once an interrupt event has occurred by exceeding TO, then reset, if the temperature remains above the THYST. - One Time Interrupt Mode: This bit use in temperature sensor 1/2 interrupt mode with hysteresis type. Temperature exceeding TO (Over-temperature) causes an interrupt and then temperature going below THYST (Hysteresis temperature) will not cause an interrupt. Once an interrupt event has occurred by exceeding TO, then going below THYST, and interrupt will not occur again until the temperature exceeding TO. Enable INT# Output. A one enables the INT# Interrupt output. Reserved. 8.20 Thermal Sensor 1/2 Type Register - Index 53h Power on default [7:0] = 0100, 0001 b BIT NAME READ/WRITE 7-2 Reserved Read/Write 1 T1_TYPE Read/Write 0 T0_TYPE Read/Write DESCRIPTION Reserved. Temperature sensor 1 type. - Thermistor (10K @ 25 degree C, B=3435). - thermal diode. Temperature sensor 0 (GPU) type. - Thermistor (10K @ 25 degree C, B=3435) - thermal diode. 8.21 Fan Divisor Register - Index 54h - 28 - W83L786NR/ W83L786NG Power on default [7:0] = 0001, 0001 b BIT 7 NAME Reserved READ/WRITE Read/write DESCRIPTION Reserved. FAN2 Divisor Select. - divide by 1; - divide by 2; - divide by 4; 6-4 FAN2_DIV_SEL[2:0] Read/Write - divide by 8. - divide by 16. - divide by 32. - divide by 64. - divide by 128. 3 Reserved Read/write Reserved. FAN1 Divisor Select. - divide by 1; - divide by 2; - divide by 4; 2-0 FAN1_DIV_SEL[2:0] Read/Write - divide by 8. - divide by 16. - divide by 32. - divide by 64. - divide by 128. 8.22 Reserved - Index 55h ~ 5Fh Reserved - 29 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.23 FAN Configuration Register - Index 80h Power on default [7:0] = 0011, 1100 b BIT NAME READ/WRITE DESCRIPTION FAN2 Control Mode 7 EN_PWM2 Read/Write - PWM FAN Control Mode - DC FAN Control Mode FAN1 Control Mode 6 EN_PWM1 Read/Write - PWM FAN Control Mode - DC FAN Control Mode FAN2 Control Mode. - Manual Control Mode. (Default) 5-4 FAN2_MODE Read/Write - Thermal Cruise mode. - SMART FANTM II Mode. - FAN_SET. FAN 1 Control Mode. - Manual Control Mode. (Default) 3-2 FAN1_MODE Read/Write - Thermal Cruise mode. - SMART FANTM II Mode. - FAN_SET. 1-0 Reserved Read/Write Reserved. 8.24 DC FAN1 Output Voltage Level Control Register (Manual Mode) / FAN1 Output Voltage Table (SMART FANTM II Mode) – Index 81h Power on default [7:0] 1111, 1111 b For Manual Mode BIT 7-4 NAME Reserved READ/WRITE Read/Write DESCRIPTION Reserved. DC FAN1 Output Level. Only for Thermal Manual Mode while CR80h bit3-2 is 00. This 3-bit register determines the DC FAN driving voltage. 3-0 FAN1_DC [3:0] Read/Write - DC output is 0V. - DC output is 3.3V. - DC output levels are from 0V to 3.3v and they are separated into 16 levels equally. - 30 - W83L786NR/ W83L786NG For SMART FANTM II Mode BIT NAME READ/WRITE DESCRIPTION 7-4 FAN1_TAB2[3:0] Read/Write FAN1 Output Level 2 for SMART FANTM II Mode. 3-0 FAN1_TAB1[3:0] Read/Write FAN1 Output Level 1 for SMART FANTM II Mode. 8.25 FAN1 Output Voltage Table (SMART FANTM II Mode) - Index 82h Power on default [7:0] 1111, 1111 b BIT NAME READ/WRITE DESCRIPTION 7-4 FAN1_TAB4[3:0] Read/Write FAN1 Output Level 4 for SMART FANTM II Mode. 3-0 FAN1_TAB3[3:0] Read/Write FAN1 Output Level 3 for SMART FANTM II Mode. 8.26 TEMP0 (D+_D-) Target Temperature Register (Thermal Cruise Mode) / TEMP_POINT1 for FAN1 (SMART FANTM II Mode) - Index 83h Power on default [7:0] = 0000, 0000 b TEMP1 target temperature register for Thermal Cruise mode. BIT NAME READ/WRITE DESCRIPTION 7-0 TEMP_TAR_T0[7:0] Read/Write TEMP0 Target Temperature. Only for Thermal Cruise Mode while CR84h bit3-2 is 01. TEMP_POINT1 register for Smart FAN II Mode. BIT 7-0 NAME TEMP_P1F1[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT1 for FAN1 use Smart FAN II Mode. 8.27 TEMP_POINT2 for FAN1 (SMART FANTM II Mode) - Index 84h Power on default [7:0] = 0000, 0000 b BIT 7-0 NAME TEMP_P2F1[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT2 for FAN1 use SMART FANTM II Mode. - 31 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.28 FAN 1 Speed Low Limit Rate Control Register (Thermal Cruise Mode) / TEMP_POINT3 for FAN1 (SMART FANTM II Mode) - Index 85h Power on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION 7-4 Reserved Read/Write Reserved. 3-0 FAN1_LL [3:0] Read/Write Low Limit Speed of FAN1. Only for Thermal Cruise mode. TEMP_POINT3 register for Smart FAN II Mode. BIT 7-0 NAME TEMP_P3F1[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT3 for FAN1 use SMART FANTM II Mode. 8.29 TEMP_POINT4 for FAN1 (SMART FANTM II Mode) - Index 86h Power on default [7:0] = 0000, 0000 b BIT 7-0 NAME TEMP_P4F1[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT4 for FAN1 use SMART FANTM II Mode. 8.30 DC FAN2 Output Voltage Level Control Register (Manual Mode)/ FAN2 Output Voltage Table (SMART FANTM II Mode) - 87h Power on default [7:0] 1111, 1111 b For Manual Mode BIT 7-4 NAME Reserved READ/WRITE Read/Write DESCRIPTION Reserved. DC FAN2 Output Level. Only for Thermal Manual Mode while CR80h bit5-4 is 00. This 3-bit register determines the DC FAN driving voltage. 3-0 FAN2_DC [3:0] Read/Write - DC output is 0V. - DC output is 3.3V. - DC output levels are from 0V to 3.3v and they are separated into 16 levels equally. - 32 - W83L786NR/ W83L786NG For SMART FANTM II Mode BIT NAME READ/WRITE DESCRIPTION 7-4 FAN2_TAB2[3:0] Read/Write FAN2 Output Level 2 for SMART FANTM II Mode. 3-0 FAN2_TAB1[3:0] Read/Write FAN2 Output Level 1 for SMART FANTM II Mode. 8.31 FAN2 Output Voltage Table (SMART FANTM II Mode) - Index 88h Power on default [7:0] 1111, 1111 b BIT NAME READ/WRITE DESCRIPTION 7-4 FAN2_TAB4[3:0] Read/Write FAN2 Output Level 4 for SMART FANTM II Mode. 3-0 FAN2_TAB3[3:0] Read/Write FAN2 Output Level 3 for SMART FANTM II Mode. 8.32 TEMP1 (VTIN1) Target Temperature Register (Thermal Cruise Mode) / TEMP_POINT1 for FAN2 (SMART FANTM II Mode) - Index 89h Power on - [7:0] = 0000, 0000 b TEMP2 target temperature register for Thermal Cruise mode. BIT 7-0 NAME TEMP_TAR_T1[7:0] READ/WRITE DESCRIPTION Read/Write TEMP1 Target Temperature. Only for Thermal Cruise Mode while CR84h bit5-4 is 01. TEMP_POINT1 register for SMART FANTM II Mode. BIT 7-0 NAME TEMP_P1F2[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT1 for FAN2 use SMART FANTM II Mode. 8.33 TEMP_POINT2 for FAN2 (SMART FANTM II Mode) - Index 8Ah Power on - [7:0] = 0000, 0000 b BIT 7-0 NAME TEMP_P2F2[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT2 for FAN2 use SMART FANTM II Mode. - 33 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.34 FAN 2 Speed Low Limit Rate Control Register/ TEMP_POINT3 for FAN2 SMART FANTM II Mode) - Index 8Bh Power on default [7:0] =0000, 0000 b BIT NAME READ/WRITE DESCRIPTION 7-5 Reserved Read/Write Reserved. 4-1 FAN2_LL [3:0] Read/Write Low Limit Speed of FAN2. Only for Thermal Cruise mode. TEMP_POINT3 register for SMART FANTM II Mode. BIT 7-0 NAME TEMP_P3F2[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT3 for FAN2 use SMART FANTM II Mode. 8.35 TEMP_POINT4 for FAN2 (SMART FANTM II Mode) - Index 8Ch Power on default [7:0] = 0000, 0000 b. BIT 7-0 NAME TEMP_P4F2[7:0] READ/WRITE DESCRIPTION Read/Write TEMP_POINT4 for FAN2 use SMART FANTM II Mode. 8.36 Tolerance of Temperature Register - Index 8Dh Power on default [7:0] = 0011, 0011 b For Thermal Cruise mode BIT NAME READ/WRITE DESCRIPTION 7-4 TOL_T1[3:0] Read/Write Tolerance of Fan 2 Target Temperatures (Temp1). Only for Thermal Cruise mode. 3-0 TOL_T0[3:0] Read/Write Tolerance of Fan 1 Target Temperature (Temp0). Only for Thermal Cruise mode. READ/WRITE DESCRIPTION For Smart FAN II Mode BIT NAME 7-4 TOL_T1[3:0] Read/Write Tolerance of Fan 2 Temperatures (Temp1). Only for SMART FANTM II Mode. 3-0 TOL_T0[3:0] Read/Write Tolerance of Fan 1 Temperature (Temp0). Only for SMART FANTM II Mode. - 34 - W83L786NR/ W83L786NG 8.37 FAN 2D/3D state Control Register - Index 8Eh At SMART FANTM II Mode, FAN will be controlled by 2D/3D mode after writing 2Dh/3Dh to CR8A 8.38 FAN Pre-Scale Register - Index 8Fh Power on default [7:0] = 0010, 0010 b BIT NAME READ/WRITE DESCRIPTION PWM Input Clock Select of Fan 2. This bit select FAN input clock to pre-scale divider. 7 PWM2_CLK_SEL Read/Write - 1.44MHz - 180KHz FAN 2 PWM Input Clock divider. - divider is 1 - divider is 2 - divider is 4 6-4 PWM2_CLK_DIV [2:0] Read/Write - divider is 8 - divider is 16 - divider is 32 - divider is 64 - divider is 128 PWM Input Clock Select of Fan 1. This bit select FAN input clock to pre-scale divider. 3 PWM1_CLK_SEL Read/Write - 1.44MHz - 180KHz FAN 1 PWM Input Clock divider. - divider is 1 - divider is 2 - divider is 4 2-0 PWM1_CLK_DIV [2:0] Read/Write - divider is 8 - divider is 16 - divider is 32 - divider is 64 - divider is 128 - 35 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.39 FAN Initial Output Value – Index90h Power on trapping BIT NAME READ/WRITE DESCRIPTION 7 FAN_3DST Read A one indicates FAN is working at 3D mode (for SMART FANTM II Mode). It can be programmed directly by I2C. 6-4 Reserved Read/Write Reserved. FAN Initial Speed. VDD Ra FAN_SET Rb 3-0 FANINI [3:0] Read/Write Use two resistors to divide a four section to represent different initial FAN Speed. The table is shown as following. Section FAN Speed rate Ra Rb 3 100﹪ 9.1K × 2 81﹪ 4.7K 9.1K 1 62﹪ 9.1K 4.7K 0 43﹪ × 9.1K 8.40 Fan Step down Time Register - Index 91h Power on default [7:0] = 0001, 0100 b BIT NAME READ/WRITE DESCRIPTION 7-0 STEP_DOWN_T[7:0] Read/Write The time interval, which is 1-second unit, to decrease DC output level in SMART FANTM II Control mode. 8.41 Fan Step up Time Register - Index 92h Power on default [7:0] = 0000, 1010 b BIT NAME READ/WRITE DESCRIPTION 7-0 STEP_UP_T[7:0] Read/Write The time interval, which is 1-second unit, to increase DC output level in SMART FANTM II Control mode. - 36 - W83L786NR/ W83L786NG 8.42 Temperature Sensor 0 (D+_D-) Offset Register - Index 93h Power-on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION Temperature 0 base temperature. The real temperature is sum of both monitor value and offset value. 0111,1111 => +127/4 degree C 0111,1110 => +126/4 degree C : 7-0 OFFSET0[7:0] Read/Write 0000,0001 => +1/4 degree C 0000,0000 => +0 degree C 1111,1111 => -1/4 degree C 1111,1110 => -2/4 degree C : 1000,0000 => -128/4 degree 8.43 Temperature Sensor 1 (VTIN1) Offset Register – Index 94h Power-on default [7:0] = 0000, 0000 b BIT NAME READ/WRITE DESCRIPTION Temperature 1 base temperatures. The real temperature is sum of both monitor value and offset value. 0111,1111 => +127/4 degree C 0111,1110 => +126/4 degree C : 7-0 OFFSET1[7:0] Read/Write 0000,0001 => +1/4 degree C 0000,0000 => +0 degree C 1111,1111 => -1/4 degree C 1111,1110 => -2/4 degree C : 1000,0000 => -128/4 degree 8.44 Register - Index 95h Power-on default [7:0] = 0000, 0000 b BIT 7-0 NAME Reserved READ/WRITE DESCRIPTION Read/Write - 37 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 8.45 Register - Index 96h Power-on default [7:0] = 0001, 1001 b BIT 7-0 NAME Reserved READ/WRITE DESCRIPTION Read/Write 8.46 Register - Index 97h Power-on default [7:0] = 0001, 1001 b BIT 7-0 NAME Reserved READ/WRITE DESCRIPTION Read/Write Value RAM and Limit Value 8.47 Value RAM - Index 20h- 3Fh or 60h - 7Fh INDEX A7-A0 DESCRIPTION UNIT 20h VCORE reading 21h VRAM reading 22h VCC reading 23h Reserved 24h Reserved 25h Temperature 0 reading (D+_D-, 0 ~ 255) °C 26h Temperature 1 reading (VTIN1, 0 ~ 255) °C 27h Reserved FANIN1 reading 28h Note: This location stores the number of counts of the internal clock per revolution. Count FANIN2 reading 29h Note: This location stores the number of counts of the internal clock per revolution. 2Ah Reserved 2Bh VCORE High Limit. (0xff) 2Ch VCORE Low Limit. (0x00) 2Dh VRAM High Limit. (0xff) 2Eh VRAM Low Limit. (0x00) 2Fh VCC High Limit. (0xff) - 38 - Count W83L786NR/ W83L786NG Value RAM - Index 20h- 3Fh or 60h - 7Fh, continued. INDEX A7-A0 DESCRIPTION UNIT 30h VCC Low Limit. (0x00) 31h Reserved 32h Reserved 33h Reserved 34h Reserved 35h Over Temperature 0 Limit (High). (0x50) °C 36h Temperature 0 Hysteresis Limit (Low). (0x4b) °C 37h Over Temperature 1 Limit (High). (0x50) °C 38h Temperature 1 Hysteresis Limit (Low). (0x4b) °C 39h Reserved °C 3Ah Reserved °C FAN1 Fan Count Limit. (0xff) 3Bh Note: It is the number of counts of the internal clock for the Low Limit of the fan speed. Count FAN2 Fan Count Limit. (0xff) 3Ch Note: It is the number of counts of the internal clock for the Low Limit of the fan speed. 3Dh FAN1 Speed Control Output Level 3Eh FAN2 Speed Control Output Level 3Fh Reserved - 39 - Count Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 9. ELECTRICAL CHARACTERISTICS 9.1 Absolute Maximum Ratings PARAMETER RATING Power Supply Voltage Input Voltage Operating Temperature Storage Temperature UNIT -0.5 to 7.0 -0.5 to VCC+0.5 0 to +70 -55 to +150 V V °C °C Note: Exposure to conditions beyond those listed under Absolute Maximum Ratings may adversely affect the life and reliability of the device. 9.2 DC Characteristics (Ta = 0° C to 70° C, VDD = 5V ± 10%, VSS = 0V) PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS I/O12t - TTL level bi-directional pin with source-sink capability of 12 mA Input Low Voltage VIL Input High Voltage VIH Output Low Voltage VOL Output High Voltage VOH Input High Leakage ILIH Input Low Leakage ILIL 0.8 2.0 V V 0.4 V IOL = 12 mA V IOH = - 12 mA +10 μA VIN = VDD -10 μA VIN = 0V 2.4 I/O12ts - TTL level bi-directional pin with source-sink capability of 12 mA and schmitt-trigger level input Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VDD = 5 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VDD = 5 V Hysteresis VTH 0.5 1.2 V VDD = 5 V Output Low Voltage VOL V IOL = 12 mA Output High Voltage VOH V IOH = - 12 mA Input High Leakage ILIH +10 μA VIN = VDD Input Low Leakage ILIL -10 μA VIN = 0V 0.4 2.4 - 40 - W83L786NR/ W83L786NG DC Characteristics, continued PARAMETER SYM. MIN. TYP. MAX. UNIT CONDITIONS OUT12t - TTL level output pin with source-sink capability of 12 mA Output Low Voltage VOL Output High Voltage VOH 0.4 2.4 V IOL = 12 mA V IOH = -12 mA OD8 - Open-drain output pin with sink capability of 8 mA Output Low Voltage VOL 0.4 V IOL = 8 mA OD12 - Open-drain output pin with sink capability of 12 mA Output Low Voltage VOL 0.4 V IOL = 12 mA OD48 - Open-drain output pin with sink capability of 48 mA Output Low Voltage VOL 0.4 V 0.8 V IOL = 48 mA INt - TTL level input pin Input Low Voltage VIL Input High Voltage VIH Input High Leakage ILIH +10 μA VIN = VDD Input Low Leakage ILIL -10 μA VIN = 0 V INts 2.0 V - TTL level Schmitt-triggered input pin Input Low Threshold Voltage Vt- 0.5 0.8 1.1 V VDD = 5 V Input High Threshold Voltage Vt+ 1.6 2.0 2.4 V VDD = 5 V Hysteresis VTH 0.5 1.2 V VDD = 5 V Input High Leakage ILIH +10 μA VIN = VDD Input Low Leakage ILIL -10 μA VIN = 0 V - 41 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 9.3 9.3.1 AC Characteristics Serial Bus Timing Diagram t SCL tR t R SCL t t HD;SDA t SU;STO SU;DAT VALID DATA SDA IN t HD;DAT SDA OUT Serial Bus Timing Diagram Serial Bus Timing PARAMETER SCL clock period Start condition hold time Stop condition setup-up time DATA to SCL setup time DATA to SCL hold time SCL and SDA rise time SCL and SDA fall time 9.3.2 SYMBOL MIN. - 10 4.7 4.7 120 5 t SCL tHD;SDA tSU;STO tSU;DAT tHD;DAT tR tF MAX. 1.0 300 UNIT uS uS uS nS nS uS nS VID Input Skew t skew t hold VIDA[5:0]/VIDB[5:0] VALID VID VALID VID VID Input Timing PARAMETER SYMBOL VID Input Unstable Time t-Skew VID Valid Input Hold Time t-hold - 42 - MIN. MAX. 0.8 4 UNIT uS uS W83L786NR/ W83L786NG 10. THE TOP MARKING The top marking of W83L786NR W83L786NR 2826978Y-61 443OB Left: Nuvoton logo 1st line: part number: W83L786NR 2nd line: Tracking code 2 826978Y-61 3rd line: Tracking code 443 O B 443: packages made in '04, week 43 O: assembly house ID; A means ASE, S means SPIL, O means OSE B: IC revision The top marking of W83L786NG W83L786NG 2826978Y-61 443OB Left: Nuvoton logo 1st line: part number: W83L786NG, G means Pb-free package 2nd line: Tracking code 2 826978Y-61 3rd line: Tracking code 443 O B 443: packages made in '04, week 43 O: assembly house ID; A means ASE, S means SPIL, O means OSE B: IC revision - 43 - Publication Release Date: March 31, 2006 Revision 0.9 W83L786NR/ W83L786NG 11. PACKAGE SPECIFICATION „ 20L SSOP-209 mil D 11 20 DTEAIL A HE E 1 10 b A2 A SEATING PLANE θ Y e b SYMBOL A A1 A2 b c D E HE e L L1 Y θ A1 DETAIL A DIMENSION IN MM DIMENSION IN INCH MIN. NOM MAX. MIN. NOM MAX. 0.079 2.00 0.05 1.65 1.75 0.22 0.09 6.90 7.20 5.00 5.30 7.40 7.80 0.65 0.55 0.75 1.25 0 1.85 0.38 0.25 7.50 5.60 8.20 0.002 0.065 0.009 0.004 0.272 0.197 0.291 0.069 0.073 0.015 0.010 0.283 0.295 0.209 0.220 0.307 0.323 0.0256 0.95 0.10 8 0.021 0.030 0.037 0.050 0.004 0 8 - 44 - SEATING PLANE L L1 W83L786NR/ W83L786NG Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. - 45 - Publication Release Date: March 31, 2006 Revision 0.9
W83L786NG 价格&库存
很抱歉,暂时无法提供与“W83L786NG”相匹配的价格&库存,您可以联系我们找货
