AS3710-BQFR-FF
AS3710-BQFR-FF
    AMSOSRAM(艾迈斯半导体)
    VFQFN56_EP
    IC PMU CHARGER/BKLT DVR 56QFN
AS3710-BQFR-FF 数据手册
D ata sh eet A S3 7 1 0 Tri p le B u c k H ig h Cu rr e n t P M IC w i th Ch a r g e r 1 General Description HV Backlight Driver  3x step up with external transistor  - e.g. 0.5-1A@5V; 40mA@50V Voltage control mode and over-voltage protection  3 programmable current sinks (max. 40mA)  Possible external PWM dimming input (DLS, CABC) The AS3710 is a compact System PMU with integrated battery charger and back light driver. The device offers advanced power management functions. All necessary ICs and peripherals in a battery powered mobile device are supplied by the AS3710. It features 3 DCDC buck converters as well as 8 low noise LDOs. The different regulated supply voltages are programmable via the serial control interface. 4MHz operation with 1uH coils are reducing cost and PCB space. The three step-up converter generate voltages for e.g.the backlight, classD amplifier, USB host support or LCD display supply. Both constant voltage (for e.g. OLED supply) as well as constant current (white LED backlight) operations with three current sinks are possible. An internal voltage protection is limiting the output voltage in the case of external component failures. AS3710 contains a linear or switching mode Li-Ion battery charger with constant current and constant voltage. The maximum charging current is 1.5A. An integrated battery switch and an optional external switch are separating the battery during charging or whenever an external power supply is present. With this switch it is also possible to operate with no or deeply discharged batteries. A programmable current limit (100mA - 2.5A) can be used to control the maximum current used from a USB supply or charger input. Additional features are a 30V OV protection and battery temperature supervision. The single supply voltage may vary from 2.7V to 5.5V. Battery Charger  Programmable trickle charging (25-220mA)  Programmable constant current charging (up to 1500mA)  Programmable constant voltage charging (3.9V-4.25V)  Charger time-out and temperature supervision  Selectable current limitation for USB mode  Integrated battery switch & ideal diode (linear mode)  External battery switch control (switching mode)  External 30V OV protection Supervisor  Automatic battery monitoring with interrupt generation and selectable warning level  Automatic temperature monitoring with interrupt generation and selectable warning and shutdown levels Real Time Clock  Ultra low power 32kHz oscillator 2 Key Features  Sec and minute counter, auto wake-up Voltage Generation  Programmable alarm Repeating alarm (seconds, minutes, 2 minutes, or 8 minutes)  3 DCDC step down regulators (2-4MHz)   32kHz clock output to peripheral  3.0V, VCP=5.2V, Iout300mA 30 mV 1.2 18 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Table 7. Digital LDO (LDO3, LDO4, LDO5, LDO6, LDO7, LDO8) Characteristics VLDOx_IN=3.7V; ILOAD=150mA; Tamb=25ºC; CLOAD =1µF (Ceramic); unless otherwise specified Symbol Parameter Note Min Typ Max Unit ILIMIT_LDO3-8_L low current limit ldoX_ilimit = 0 300 mA ILIMIT_LDO3-8_H high current limit ldoX_ilimit = 1 500 mA 1.Guaranteed by design and verified by laboratory evaluation and characterization; not production tested www.austriamicrosystems.com 1.2 19 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s 8.4 Low power LDO V2_5 Regulators 8.4.1 General Description The low power LDO V2_5 is needed to supply the chip core (analog and digital) of the device. It is designed to get the lowest possible power consumption, and still offering reasonable regulation characteristics. The regulator has two supply inputs selecting automatically the higher one. This gives the possibility to supply the chip core either with the battery or with the charger depending on the conditions. Bulk switch comparators are used to avoid any parasitic current flow. To ensure high PSRR and stability, a low-ESR ceramic capacitor of min. 1µF must be connected to the output. 8.4.2 Parameter Table 8. Low power LDO (V2_5) Characteristics,VBAT=3.7V; ILOAD_ext=0; Tamb=25ºC; CLOAD =1 µF (Ceramic); unless otherwise specified Symbol VBAT VUSB Parameter Note Supply voltage rage RON On resistance IOFF Shut down current IVDD Supply current tstart Startup time Vout Output voltage www.austriamicrosystems.com Min Max 2.7 5.5 4.2 5.5 Guaranteed per design Guaranteed per design, consider chip internal load for measurements. 2.4 1.2 Typ Unit V 50 Ω 100 nA 3 µA 200 µs 2.5 2.6 V 20 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s 8.5 DCDC Step-Up Converter 8.5.1 General Description The DC/DC Step Up converter is a high efficiency current mode PWM regulator, which provides an output voltage dependent on the maximum VDS voltage of the external transistor, and maximum load current selectable by the external shunt resistor. For Example:  5V, 0.5-1A @ 1Mhz  25V, 50mA @ 1MHz  40V, 20mA @ 500kHz A constant switching frequency results in a low noise on supply and output voltage. Figure 14. DC/DC step-up Converter 1 & 3 www.austriamicrosystems.com 1.2 21 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Figure 15. DC/DC step-up Converter 2 8.5.2 Feedback selection SU1, SU3 For step up SU1, the feedback is always FB_SU1. For step up SU3, the feedback is always FB_SU3. 8.5.3 Feedback Selection SU2 For step up SU2 following feedback selections are possible (selected by setpup2_fb): (see Figure 15) Current Feedback CURR1, CURR2 or CURR3 can be selected by stepup2_fb as a current feedback pin. The step-up converter is regulated such that the required current at the feedback path can be supported. stepup2_fbprot selects the overvoltage protection feedback pin (FB2_SU2, GPIO2, GPIO3 or GPIO4). In this mode the output voltage will be limited by limiting the voltage on the selected feedback pin to 1.25V (select the external resistor network and stepup2_v to adjust this limitation voltage). stepup2_prot_dis has to be set to 0, otherwise the protection is disabled. Always choose the path with the higher voltage drop as feedback to guarantee adequate supply for the other, unregulated path. Current Feedback with Automatic Feedback Selection Same as above, but when currX_ctrl = 10b for the used current sinks, the chip automatically selects the highest string (CURR1, CURR2 or CURR3) as feedback input. www.austriamicrosystems.com 1.2 22 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Voltage Feedback stepup2_fb = 00b. FB2_SU2, GPIO2, GPIO3 or GPIO4 can be selected by stepup2_fbprot as a voltage feedback input. The step-up converter output voltage is regulated by regulating the selected feedback pin voltage to 1.25V. Calculating Resistors for Voltage Feedback or Over-Voltage Protection Bit stepupX_res should be set to 1 in voltage feedback mode using two resistors. The output voltage is regulated to a constant value, given by: R1 + R2 V SU = ------------------- × 1, 25 + I FB × R 1 R2 If R2 is not used, the output voltage is: V SU = 1, 25 + I FB × R 1 VSU: Step up regulator output voltage R1 Feedback resistor R1 R2 Feedback resistor R2 IFB: Tuning current on DCDC_FB pin: stepupX_v (0..31µA (1µA steps)) Example: Table 9. Step Up Output Voltage (Voltage mode or protection voltage) IFB (stepupX_v) VSU VSU µA R1=1M Ω,R2 not used R1=500k Ω,R2=64k Ω 0 - 11 1 - 11.5 2 - 12 3 - 12.5 4 - 13 5 6.25 13.5 6 7.25 14 7 8.25 14.5 8 9.25 15 9 10.25 15.5 10 11.25 16 11 12.25 16.5 12 13.25 17 13 14.25 17.5 14 15.25 18 15 16.25 18.5 Note: The voltage on pin CURR1, CURR2 and CURR3 must never exceed 30V. www.austriamicrosystems.com 1.2 23 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s 8.5.4 Output disconnect As the output voltage is always on, an additional output transistor can be added to reduce shutdown current through R1, R2 and the connected output circuit. Note: A similar circuit can be used for step up converter 2 or 3. Figure 16. StepUp 1 with regulated output voltage (15V), and switch off function of output voltage, to reduce shutdown current 8.5.5 StepUp1 Load Detection and Over-current Protection Circuit This circuit protects the DCDC step up1 converter during short circuit and startup, by regulation of the output current. An additional feature is the detection of a minimum output load of the Step-up converter. It is also possible to use this circuit without the DCDC step up converter, by using the sense resistor only:  Detection circuit: If the voltage on Rsense exceeds VDETECT for more than 1ms, or the DCDC Step up converter is not in pulse-skip for more than 1ms, the stepup1_det bit will be set.  Over-current protection: If the Over-current voltage VOVCURRENT has been exceeded by more than 5ms the bit stpup1_oc will be set and can only reset, by switching off and on the Protection circuit by writing stpup1_shortprot 0 – 1. If stpup1_oc is set the load will be disconnected, if stpup1_oc_timeout=1 www.austriamicrosystems.com 1.2 24 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Figure 17. StepUp 1 Load Detection and Over-current Protection Application Circuit 8.5.6 Parameter Table 10. DC/DC Step-up Controller Parameters Symbol Parameter Note IVDD Quiescent Current Pulse skipping mode VFB1 Feedback voltage for external resistor divider: for constant voltage control VFB2 Feedback voltage for current sink regulation CURR1, CURR2 or CURR3 Additional tuning current at FB_SUx adjustable by software in 1µA steps 0 31 µA Accuracy of feedback current @ full scale -7 7 % Vrsense_max Current limit voltage at Rsense E.g.: 0.65A for 0.15Ω sense resistor RSW switch resistance ON-resistance of external switching transistor Iload Load current at 25V output voltage fIN Switching frequency internal CLK frequency/4, default 1MHz tMIN_ON Minimum on time MDC Maximum duty cycle IDCDC_FB Min Typ Max 140 1.20 1.25 µA 1.30 0.6 @ 1MHz V V 100 0 Unit mV 1 Ω 50 mA fclk_int/4 MHz 130 ns 91 % Table 11. StepUp1 protection/detection circuit parameters Symbol Parameter Note Min Typ Max Unit VDETECT Detection Threshold For Rsense=0.150Ω => 83mA typ. 2 12.5 25 mV VOVCURRENT Over-current Threshold rising For Rsense=0.150Ω => 1.2A typ. 150 180 215 mV www.austriamicrosystems.com 1.2 25 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Table 11. StepUp1 protection/detection circuit parameters Symbol Parameter VOVhysteresis Over-current Hysteresis tOV_timeout Over-current timeout tdetect Detection de-bounce time Note Min Typ Max Unit 50 mV Interrupt and/or external PMOS switching off after timeout fclk_int = 2.2MHz 5 ms fclk_int = 2.2MHz 1 ms Table 12. DC/DC Step-up Controller External Components Symbol Parameter Note Cout Output capacitor ceramic, ±20% 2.2 µF Use inductors with small Cparasitic (8V 10 µH Use inductors with small Cparasitic (0 and charging time has been exceeded. (Can be reset by unplugging the charger, setting chg_on=0 or writing charging_tmax=0) - VUSB over-voltage detected - Die temp>140deg (ov_temp_140 set) 8.7.5 Battery presence indication and operation without battery After EOC state is reached a timer for NOBAT detection is started. If there is no battery present, the VBAT voltage will drop to VRESUME. Depending on the load on VBAT and the capacitor on VBAT this might take some milliseconds to 1 second. If the RESUME mode is enabled (Bit auto_resume=1), the charger will restart charging (ConstantCurrent charging) after 100msec delay. The 100msec dead time is necessary to get a battery oscillation frequency below 10Hz, if there is no battery present. If the NOBAT detection timer is below 2 seconds after reaching EOC state, and this happens 2 times in serial, the Nobat bit in ChargerStatus register is set. If an battery is inserted the bit will be reset after the timer exceeds the 2 seconds. In addition, if the nobat_ntc_det bit is set the looping will be stopped and a NTC detection is started. A pull up current of 0.5uA is applied to BATTEMP. If the BATTEMP voltage is above 1.8V, the state machine stays in the no bat state. If the BATTEMP voltage is below 1.8V, a charging cycle is initiated. 8.7.6 Charger overvoltage protection This blocks checks if the charger voltage VUSB is above VCHOVH. If the VUSB voltage is above VCHOVH , the pin XOFF is pulled to GND immediately, to protect the pin VCHG_IN, and the charger is set into off state. If the VUSB voltage is below VCHOVH the XOFF pin is charged up to VXOFF_REG with an integrated charge pump. If the pin exceeds VXOFF_MIN the usb_prot_ready bit is set and the charger is started. 8.7.7 NTC supervision This charger block also features a supply for an external NTC resistor to measure the battery temperature while charging. If the temperature is too high (voltage on BATTEMP pin is below VBATTEMP_ON) the charger will stop operation. If needed an interrupt can be generated based on this event. When the battery temperature drops the charger the voltage on BATTEMP pin will rise above VBATTEMP_OFF and the charger will start charging again. This is forming a temperature hysteresis of about 3 to 5°C to avoid an oscillation of the charger. www.austriamicrosystems.com 1.2 30 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s The levels for switching off the charger (ntc_temp: 45ºC or 55ºC) as well as the type of NTC (ntc_10k: 10k or 100k) can be selected via register settings. The battery temperature supervision via the NTC can be switched off (ntc_on = 0). The supply for the NTC will be only on when a charger is detected and ntc_on bit is set. 8.7.8 Charger Modes Figure 20. Linear Charger Modes www.austriamicrosystems.com 1.2 31 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Figure 21. DCDC Charger Modes 8.7.9 Alternative Charger Input Configurations Figure 22. Charger with Current Limiter Bypass www.austriamicrosystems.com 1.2 32 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s 8.7.10 Parameter TA= 25ºC, unless otherwise specified. Table 14. Charger Parameter Symbol VCHDET VCHMIN Parameter Condition Min Typ Max Unit Charger Detection threshold VUSB-VBAT Hysteresis is > 40mV 50 75 105 mV 0 20 35 mV VSOFT Apply ISOFT charging current below that VBAT voltage 1.8 V ISOFT Charging current if VBAT is below VSOFT 22 mA VTRICKLE Trickle to CC current threshold VBAT rising 2.9 V mA V ITRICKLE Trickle/EOC current limit Programmable in 60mA steps 60.. 240 VCHOFF Charge termination threshold programmable in 20mV steps between 3.5 and 4.44V 3.5.. 4.44 @ ChVoltEOC=35 (4.2V) ICC CC current limit 4.15 linear charging mode -10% -7% USB input current limit @ 470mA VRESUME Resume voltage limit to start charger VBAT falling threshold (depending on ChVoltResume) VSUP_min VSUP level for charging current regulation (reduction), to avoid voltage drop on VSUP Trickle current (or constant current in linear mode) will be regulated down, if VSUP drops below this level 4.242 250.. 1500 Programmable in 50mA steps IUSB_limit 4.20 470 V mA +10% mA +6% mA 140/233 mV 3.9 -6% 4.2 4.5 3% V 4.7 IREV_OFF Reverse current shut down VDiode RON_BATSW VSUP_CHG = 5V, VUSB open 5 µA Ideal Diode start voltage 50 mV Battery Switch On-resistance 0.10 Ω Temp Supervision VBATTEMP_ON Battery Temp. high level (50 or 55ºC) VSUP >3V NTCbeta=4200 500 or 400 mV VBATTEMP_OFF Battery Temp. low level (45 or 50ºC) VSUP >3V NTCbeta=4200 600 or 500 mV IBATTEMP NTC Bias Current 100kΩ NTC 10kΩ NTC -15% 15 150 +15% 6.2 +3% µA XOFF overvoltage protection monitor voltage on VUSB, disable charging beyond this voltage (200mV hysteresis) VCHOVH VUSB Overvoltage Detection VXOFF_min Minimum XOFF voltage for charger startup 7.5 V VXOFF_REG Regulation voltage for XOFF pin 10 V IXOFF External pull down current on XOFF Connect XOFF pin to MOSFET gates only pin www.austriamicrosystems.com 1.2 -3% 6.0 100 V nA 33 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Table 15. External Components Symbol Q1PROT_NMOS Description Condition Min FDN337N Vds=30V, 2.2A Typ Max 65 Unit mΩ FDN339AN Vds=20V, 3A 35 mΩ FDN327N Vds=20V, 2A 70 mΩ FDG311N Vds=20V, 1.9A 115 mΩ 82 mΩ Si1472DH FDC637AN Vds=20V, 6.2A 24 mΩ FDT439N Vds=30V, 6.3A 45 mΩ FDN306P @ 4.5V 40 mΩ FDC602 @ 4.5V 33 mΩ FDC642 @ 4.5V 65 mΩ CUSB Bypass capacitor on VUSB pin ± 20%, X5R or X7R dielectric / 25V 4.7 µF CVSUP_CHG Bypass capacitor on VSUP_CHG X5R or X7R dielectric near to pin VSUP_CHG 4.7 µF CVSUP_MIN Bypass capacitor on VSUP X5R or X7R dielectric, total value CVBAT Bypass capacitor on VBAT X5R or X7R dielectric 10 µF LQM2HPN1R0MJ0 (MURATA) Ron=90mOhm / 1.5A rated current 1 µH MLP2520S1R0M (TDK) Ron=85mOhm / 1.5A rated current 1 µH Q1PROT_NMOS_HC BYPASS Q2BATSW_NMOS LCHGOUT DCHGOUT µF 10 PMEG2010 (NXP) 1A NSR10F20NXT5G (ONSEMI) 1A 100 95 90 85 80 75 70 65 60 55 50 45 40 35 30 25 1,2 1 Input Current (A) Efficiency (%) Figure 23. Step-Down vs Linear Charger; VSUP = 4.5/5.0V, TA = +25ºC SD charger 4.5V linear charger 4.5V 0,8 0,6 0,4 SD charger 4.5V linear charger 4.5V 0,2 SD charger 5V SD charger 5V linear charger 5V linear charger 5V 0 1 2 3 4 5 1 Battery Voltage (V) www.austriamicrosystems.com 2 3 4 5 Battery Voltage (V) 1.2 34 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - P o w e r M a n a g e m e n t F u n c t i o n s Figure 24. Step-Down vs Linear Charger; VSUP = 4.5/5.0V, TA = +25ºC 2,5 Internal Power Dissipation (W) SD charger 4.5V linear charger 4.5V 2 SD charger 5V linear charger 5V 1,5 1 0,5 0 1 2 3 4 5 Battery Voltage (V) www.austriamicrosystems.com 1.2 35 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - S y s t e m F u n c t i o n s 9 Detailed Description - System Functions 9.1 Start-up Figure 25. Startup flow chart www.austriamicrosystems.com 1.2 36 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - S y s t e m F u n c t i o n s 9.1.1 Normal Startup During a normal reset cycle (e.g. after the battery or a charger is inserted), after V2_5 is above VPOR and VSUP is above ResVoltRise a normal startup happens:  The external capacitor on CREF is charged to 1.8V.  Configuration of Charger (DCDC or linear) and SD2/SD3 (combined mode or separated) is read from the Boot-OTP.  Startup State machine reads out the internal Boot-OTP. The start-up sequence of Step-Down Converter, LDO’s and GPIOs are controlled by the Boot-OTP.  Reset-Timer is set by the Boot-OTP  The reset is released when the Reset Timer expires (external pin XRES) 9.1.2 Startup from Charger If the voltage on pin VUSB is within VSTARTCHARGER, the AS3710 is started (even with VBAT = 0V). This allows the battery to be charged (even from deeply discharged batteries) and finally a normal startup to happen. 9.1.3 Parameter Table 16. Charger and ON-input Startup Conditions Symbol Parameter Note Min Typ Max unit VSTARTCHARGER Voltage on VUSB for system to start on Pin VUSB 4.2 5.0 30 V VON_IL ON Low Level input voltage –0.3 0.4 VON_IH ON High Level input 1.4 VVSUP_G ION_PD ON Pull down current 4 www.austriamicrosystems.com 1.2 PIO 12 µA 37 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - S y s t e m F u n c t i o n s 9.2 Reset 9.2.1 General Description XRES is a low active bi-directional pin. An external pull-up to the periphery supply has to be added. During each reset cycle the following states are controlled by the AS3710:  pin XRES is forced to GND  normal startup with programmable power-on sequence and regulator voltages (see Start-up on page 36)  reset is active until the programmable reset timer (set by register bits res_timer) expires  all registers are set to their default values after power-on, except the reset control- and status-registers.  XRES is pulled high by the external resistor and the whole system is leaving the reset state Note: Programming is controlled by the internal Boot-OTP 9.2.2 Parameter Table 17. XRES-input Characteristics Symbol Parameter VXRES_IL XRES Low Level input voltage VXRES_IH XRES High Level input voltage Note Min Typ Max Unit -0.3 0.4 V 1.4 VSUP_G PIO V 9.2.3 Reset Conditions Reset can be activated from 7 different sources:  Power on (battery or charger insertion)  Low Battery  Software forced reset  Power off mode  External triggered through the pin XRES  Over-temperature  Watchdog  On-key long press Voltage detection: There are two types of voltage dependent resets: VPOR and VXRES. VPOR monitors the voltage on V2_5 and VXRES monitors the voltage on VSUP. The linear regulator for V2_5 is always on and uses the voltage CHGIN or VBAT VSUP as its source. The pin XRES is only released if V2_5 is above VPOR and VSUP is above ResVotlRise. www.austriamicrosystems.com 1.2 38 - 98 AS3710 2V1 Datasheet - D e t a i l e d D e s c r i p t i o n - S y s t e m F u n c t i o n s Table 18. Reset Levels Symbol Parameter Note Min Typ Max Unit VPOR Overall power on reset Monitor voltage on V2_5; power on reset for all internal functions 1.5 2.0 2.3 V VXRESRISE Reset level for Vsupply rising Monitor voltage on VSUP; rising level ResVolt 1 Rise V Reset level for Vsupply falling Monitor voltage on VSUP; falling level 2.7 V VXRESFALLING if SupResEn=1 only ResVoltF all V FastResEn = 0 3 ms VXRESMASK Mask time for VXRESFALLING. Duration for VBATResVoltRise 1 :€Enter power off mode (Startup with ON key or charger insertion) 4:3 off_delay 'b01 RW Set Delay between I2C command, GPIO or Reset signal for power_off, standby mode or reset and execution of that command. 0 :€No delay 1 :€8 msec 2 :€16 msec 3 :€32 msec 2 - 'b0 n/a do not use RW Set RESTime, after the last regulator has started 0 :€RESTIME = 10ms 1 :€RESTIME = 50ms 2 :€RESTIME = 100ms 3 :€RESTIME = 150ms 1:0 res_timer www.austriamicrosystems.com 'b00 1.2 71 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ReferenceControl Register (Address 35h). ReferenceControl Addr: 35h Bit Bit Name Default Access 7 on_reset_delay 0 RW Sets the on reset delay time 0 :€8 sec (if onkey_reset=1) 1 :€4 sec (if onkey_reset=1) 6 reg_low_bias_mode 0 RW Sets the on reset delay time 0 :€normal operation 1 :€reduces the bias for the analog LDO1 and LDO2 RW Divide internal clock oscillator by 2 to reduce quiescent current for low power operation 0 :€Normal mode 1 :€Internal clock frequency divided by two. All timings are increased by two. Switching frequency of all DCDC converters are divided by two. Reduced transient performance of DCDC converters. RW Setting to 1 sets the PMU into standby mode. All regulators are disabled except those regulators enabled by register Reg standby mode. XRES will be pulled to low. A normal startup of all regulators will be done with any interrupt (has to be enabled before entering standby mode). During this startup, regulators defined by Reg standby mode register are continuously on. RW Sets the internal CLK frequency fCLK used for DCDCs, PWM, ... 0 :€4 MHz (default) 1 :€3.8 MHz 2 :€3.6 MHz 3 :€3.4 MHz 4 :€3.2 MHz 5 :€3.0 MHz 6 :€2.8 MHz 7 :€2.6 MHz All frequencies, timings and delays in this datasheet are based on 4MHz clk_int RW Enable low power mode of internal reference. 0 :€Standard mode 1 :€Low power mode - all specification except noise parameters are still valid. Iq reduced by approx. 30µA 5 4 3:1 0 clk_div2 standby_mode_on clk_int low_power_on www.austriamicrosystems.com 0 0 'b000 0 Bit Description 1.2 72 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ResetControl Register (Address 36h). ResetControl Addr: 36h Bit Bit Name Default Access 7 onkey_reset 0 RW Bit Description 0 :€Reset after 4/8 seconds ON pressed disabled 1 :€Reset after 4/8 seconds ON pressed enabled Flags to indicate to the software the reason for the last reset .0 :€VPOR has been reached (battery or charger insertion from scratch) .1 :€ResVoltFall was reached (battery voltage drop below 2.75V) .2 :€Software forced by force_reset .3 :€Software forced by power_off and ON was pulled high .4 :€Software forced by power_off and charger was detected .5 :€External triggered through the pin XRES .6 :€Reset caused by overtemperature T140 .7 :€Reset caused by watchdog .8 :€Reset caused by 4/8 seconds ON press .9 :€NA 10 :€Reset caused by RTC repeated wakeup or alarm wakeup 11 :€Reset caused by interrupt in standby mode 12 :€Reset caused by ON pulled high in standby mode 6:3 reset_reason 'b0000 RW 2 on_input 0 R_PUSH 1 power_off 0 RW Setting to 1 starts a reset cycle, but waits after the Reg_off state for a rising edge on the pin ON or until the charger is detected. 0 force_reset 0 RW Setting to 1 starts a complete reset cycle Read: This flag represents the state of the ON pad directly Write: Setting to 1 resets the 4/8 sec. onkey_reset timer OvertemperatureControl Register (Address 37h). OvertemperatureControl Addr: 37h Bit Bit Name Default Access 7:4 - 'b0000 n/a do not use 3 rst_ov_temp_140 0 RW If the over-temperature threshold 2 has been reached, the flag ov_temp_140 is set and a reset cycle is started. ov_temp_140 should be reset by writing 1 and afterward 0 to rst_ov_temp_140. 2 ov_temp_140 0 RO Flag that the over-temperature threshold 2 (T140) has been reached this flag is not reset by a over-temperature caused reset and has to be reset by rst_ov_temp_140. 1 ov_temp_110 0 RO Flag that the over-temperature threshold 1 (T110) has been reached 0 temp_pmc_on 1 RO Switch on / off of temperature supervision; default: on - all other bits are only valid if set to 1. Leave at 1, do not disable www.austriamicrosystems.com Bit Description 1.2 73 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w WatchdogControl Register (Address 38h). WatchdogControl Addr: 38h Bit Bit Name Default Access Bit Description 7:2 - 'b00 0000 n/a do not use 1 wtdg_res_on 0 RW If the watchdog expires and wtdg_res_on = 1 a reset cycle will be started 0 wtdg_on 0 RW Switches on the complete watchdog 0 :€Watchdog off 1 :€Watchdog enabled Reg_standby_mod1 Register (Address 39h). Reg_standby_mod1 Addr: 39h Bit Bit Name Default Access Bit Description 7 disable_regpd 0 RW This bit disables the pulldown of all regulators 0 :€Normal operation approx. 1kΩ pulldown of all regulators 1 :€Pulldown disabled >100kΩ of all regulators 6:4 - b000 n/a do not use 3 - 0 n/a do not use 2 sd3_stby_on 0 RW Enable Step down 3 in standby mode 1 sd2_stby_on 0 RW Enable Step down 2 in standby mode 0 sd1_stby_on 0 RW Enable Step down 1 in standby mode Reg_standby_mod2 Register (Address 3ah). Reg_standby_mod2 Addr: 3ah Bit Bit Name Default Access 7 ldo8_stby_on 0 RW Enable LDO8 in standby mode 6 ldo7_stby_on 0 RW Enable LDO7 in standby mode 5 ldo6_stby_on 0 RW Enable LDO6 in standby mode 4 ldo5_stby_on 0 RW Enable LDO5 in standby mode 3 ldo4_stby_on 0 RW Enable LDO4 in standby mode 2 ldo3_stby_on 0 RW Enable LDO3 in standby mode 1 ldo2_stby_on 0 RW Enable LDO2 in standby mode 0 ldo1_stby_on 0 RW Enable LDO1 in standby mode www.austriamicrosystems.com Bit Description 1.2 74 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w curr_control Register (Address 40h). curr_control Addr: 40h Bit 7:4 3:2 1:0 Bit Name curr3_ctrl curr2_ctrl curr1_ctrl Default 'b0000 'b00 'b00 Access Bit Description RW On/Off control of the pad CURR3 ...0 :€Current sink is turned off ...1 :€Current sink is active .. .2 :€Current sink is active and LED string connected to SU2. Required for automatic feedback selection. .3 :€Controlled by internal PWM generator, or external, if gpioX_iosf=4 .4 :€XINT output (active low interrupt output) .5 :€VSUP_low output .6 :€Charger active output .7 :€EOC output .8 :€Inverted signal of ON pin as output .9 :€Signal of ON pin as output 10: Q32k output (if osc_pd=1 then internal RC oscillator with 32kHz divider is used) .11 :€PWM output .12 :€PWRGOOD output 13-15 :€NA RW On/Off control of the pad CURR2 0 :€Current sink is turned off 1 :€Current sink is active 2 :€Current sink is active and LED string connected to SU2. Required for automatic feedback selection. 3 :€Controlled by internal PWM generator, or external, if gpioX_iosf=4 RW On/Off control of the pad CURR1 0 :€Current sink is turned off 1 :€Current sink is active 2 :€Current sink is active and LED string connected to SU2. Required for automatic feedback selection. 3 :€Controlled by internal PWM generator, or external, if gpioX_iosf=4 pwm_control_l Register (Address 41h). pwm_control_l Addr: 41h Bit 7:0 Bit Name pwm_l_time www.austriamicrosystems.com Default 'b00000000 Access RW Bit Description This bit defines the low time of the PWM generator in 1MHz units. .0 :€pwm_div * 1µsec .1 :€pwm_div * 2µsec .2 :€pwm_div * 3µsec ... :€... 255 :€pwm_div * 256µsec 1.2 75 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w pwm_control_h Register (Address 42h). pwm_control_h Addr: 42h Bit 7:0 Bit Name pwm_h_time Default 'b00000000 Access RW Bit Description This bit defines the high time of the PWM generator in 1MHz units. ..0 :€pwm_div * 1µsec ..1 :€pwm_div * 2µsec ..2 :€pwm_div * 3µsec ... :€... 255 :€pwm_div * 256µsec curr1_value Register (Address 43h). curr1_value Addr: 43h Bit 7:0 Bit Name curr1_current Default 'b00000000 Access RW Bit Description Defines the current into CURR1, if enabled by curr1_ctrl ..0 :€Power down (default state) ..1 :€0.15mA (LSB) ... :€... 255 :€38.25mA curr2_value Register (Address 44h). curr2_value Addr: 44h Bit 7:0 Bit Name curr2_current Default 'b00000000 Access RW Bit Description Defines the current into CURR2, if enabled by curr2_ctrl ..0 :€Power down (default state) ..1 :€0.15mA (LSB) ... :€... 255 :€38.25mA curr3_value Register (Address 45h). curr3_value Addr: 45h Bit 7:0 Bit Name curr3_current www.austriamicrosystems.com Default 'b00000000 Access RW Bit Description Defines the current into CURR3, if enabled by curr3_ctrl ..0 :€Power down (default state) ..1 :€0.15mA (LSB) ... :€... 255 :€38.25mA 1.2 76 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w Watchdog_min_timer Register (Address 46h). Watchdog_min_timer Addr: 46h Bit Bit Name Default Access 7:0 wtdg_min_timer 'b00000000 RW Bit Description Defines the minimum watchdog trigger time (LSB=7.5ms, range: 0 - 1.9s) Watchdog_max_timer Register (Address 47h). Watchdog_max_timer Addr: 47h Bit Bit Name Default Access 7:0 wtdg_max_timer 'b11111111 RW Bit Description Defines the maximum watchdog trigger time (LSB=7.5ms, range: 7.5ms - 1.9s), do not set to (00)h WatchdogSoftwareSignal Register (Address 48h). WatchdogSoftwareSignal Addr: 48h Bit Bit Name Default Access Bit Description This bit defines the divider ratio of the prescaler for the PWM generator. 0 :€Divide by 1 1 :€Divide by 2 2 :€Divide by 4 3 :€Divide by 16 7:6 pwm_div 'b00 RW 0 wtdg_sw_sig 0 PUSH Trigger input by the serial interface if gpioX_iosf9 Access Bit Description Stepup_control1 Register (Address 50h). Stepup_control1 Addr: 50h Bit 7:3 Bit Name stepup1_v Default 'b0000 RW Defines the tuning current at FB_SU1 pin; ..0 :€0 µA ..1 :€1 µA ... :€... .31 :€31 µA 2 stepup1_res 0 RW Gain selection for DCDC SU1 0 :€If FB_SU1 is used with current feedback only (Only R1,C1 connected) 1 :€If FB_SU1 is used with external resistor divider (2 resistors) 1 stepup1_freq 0 RW Selects SU1 frequency 0 :€1 MHz 1 :€0.5 MHz 0 stepup1_on 0 RW On/Off control of SU1 0 :€SU1 off 1 :€SU1 on www.austriamicrosystems.com 1.2 77 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w Stepup_control2 Register (Address 51h). Stepup_control2 Addr: 51h Bit 7:3 Bit Name stepup2_v Default 'b00000 Access Bit Description RW Defines the tuning current at FB_SU2 pin ..0 :€0 µA ..1 :€1 µA ... :€... .31 :€31 µA 2 stepup2_res 0 RW Gain selection for DCDC SU2 0 :€If DCDC is used with current feedback (CURR1,CURR2,CURR3) or if FB_SU2 is used with current feedback only (Only R1,C1 connected) 1 :€If FB_SU2 is used with external resistor divider (2 resistors) 1 stepup2_freq 0 RW Selects SU3 frequency 0 :€1 MHz 1 :€0.5 MHz 0 stepup2_on 0 RW On/Off control of SU2 0 :€SU2 off 1 :€SU2 on Stepup_control3 Register (Address 52h). Stepup_control3 Addr: 52h Bit 7:3 Bit Name stepup3_v Default 'b00000 Access Bit Description RW Defines the tuning current at FB_SU3 pin ..0 :€0 µA ..1 :€1 µA ... :€... .31 :€31 µA 2 stepup3_res 0 RW Gain selection for DCDC SU3 0 :€If FB_SU3 is used with current feedback only (Only R1,C1 connected) 1 :€If FB_SU3 is used with external resistor divider (2 resistors) 1 stepup3_freq 0 RW Selects SU3 frequency 0 :€1 MHz 1 :€0.5 MHz 0 stepup3_on 0 RW On/Off control of SU3. 0 :€SU3 off 1 :€SU3 on www.austriamicrosystems.com 1.2 78 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w Stepup_control4 Register (Address 53h). Stepup_control4 Addr: 53h Bit Bit Name Default Access Bit Description 7 stpup1_det 0 RO SU1 detection status register 0 :€VRsense < VDETECT for more than 1ms, and DCDC SU1 converter is in pulseskip for more than 1ms. 1 :€VRsense > VDETECT for more than 1ms, or the DCDC SU1 converter is not in pulseskip for more than 1ms. 6 stpup1_oc 0 RO SU1 overcurrent status bit 0 :€VRsense < VOVCURRENT 1 :€VRsense > VOVCURRENT for more than 5ms (latched state) 5 stpup1_oc_timeout 0 RW Controls GPIOx switch-off, after overcurrent timeout (5ms) for DCDC SU1 0 :€Disabled 1 :€Enabled 4 stpup1_shortprot 0 RW Enables Protection and Detection circuit for DCDC SU1 0 :€No protection and load detection 1 :€Short protection and load detection enabled RW Selects PWM operation of SU2 0 :€High frequency operation PWM>20kHz** 1 :€Low frequency PWM operation: stepup2_on and curr1…3_on (if PWM enabled) switched off during PWM low time ** Step_up switched on all the time. (current sinks are not switched off (currX_on=1 all the time), but currX_current masked to 00h during PWM low time.). During PWM off-time then feedback voltage is sampled. RW DCDC SU2 overvoltage protection to prevent damage of external NFET, if CURR1, CURR2 or CURR3 feedback selected, and no LED string connected. 0 :€Switch off DCDC SU2 if the voltage on FB_SU2 exceeds 1.25V 1 :€Overvoltage protection disabled 3 2 stpup2_pwm_lowf stepup2_prot_dis 0 0 Controls the feedback source 0 :€voltage feedback (external resistor divider) selected by 1:0 stepup2_fb www.austriamicrosystems.com 'b00 RW stepup2_fbprot 1 :€CURR1 feedback enabled (feedback through white LEDs) 2 :€CURR2 feedback enabled (feedback through white LEDs) 3 :€CURR3 feedback enabled (feedback through white LEDs) 1.2 79 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w Stepup_control5 Register (Address 54h). Stepup_control5 Addr: 54h Bit Bit Name Default Access 7:4 - 'b0000 n/a do not use 3 stepup2_pwm_mode 0 RW Enable PWM mode 0 :€Normal operation 1 :€PWM mode operation. Feedback is sampled during PWM off-time, if stpup2_lowf=0. 2 stepup12_clkinv 0 RW Invert input clock of SU1 and SU2 converter 0 :€Use positive edge of internal clk 1 :€Use negative edge of internal clk RW Controls the feedback protection of SU2 with external resistor divider (regulated to 0.8V). 0 : FB_SU2 enabled as input 1 : GPIO2 enabled as input 2 : GPIO3 enabled as input 3 : GPIO4 enabled as input 1:0 stepup2_fbprot 'b00 Bit Description RTCcontrol Register (Address 60h). RTCcontrol Addr: 60h Bit Bit Name Default Access 7:5 - 'b000 n/a Bit Description do not use 0 :€Generates an interrupt every second 1 :€Generates an interrupt every minute 2 :€Generates an interrupt every 2 minute 3 :€Generates an interrupt every 8 minute 4:3 rtc_irq_mode 'b00 RW 2 rtc_on 0 RW 1 rtc_alarm_wakeup_en 0 RW 0 :€Disables RTC alarm wake-up in power off mode 1 :€Enable RTC alarm wake-up in power off mode 0 rtc_rep_wakeup_en 0 RW 0 :€Disables RTC repeated wake-up in power off mode 1 :€Enable RTC repeated wake-up in power off mode Switch on the 32kHz RTC oscillator 0 :€32kHz oscillator disabled 1 :€32kHz oscillator enabled RTCSecond Register (Address 61h). RTCSecond Addr: 61h Bit Bit Name Default Access 7:0 second 00h RW Bit Description - RTCMinute1 Register (Address 62h). RTCMinute1 Addr: 62h Bit Bit Name Default Access 7:0 minute0 00h RW www.austriamicrosystems.com Bit Description - 1.2 80 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w RTCMinute2 Register (Address 63h). RTCMinute2 Addr: 63h Bit Bit Name Default Access 7:0 minute1 00h RW Bit Description - RTCMinute3 Register (Address 64h). RTCMinute3 Addr: 64h Bit Bit Name Default Access 7:0 minute2 00h RW Bit Description - RTCAlarmSecond Register (Address 65h). RTCAlarmSecond Addr: 65h Bit 7:0 Bit Name alarmsecond Default 3Fh Access RW Bit Description AlarmMinute2 has to be written to latch the whole alarm register RTCAlarmMinute Register (Address 66h). RTCAlarmMinute Addr: 66h Bit Bit Name Default Access 7:0 alarmminute0 FFh RW Bit Description AlarmMinute2 has to be written to latch the whole alarm register RTCAlarmMinute2 Register (Address 67h). RTCAlarmMinute2 Addr: 67h Bit Bit Name 7:0 alarmminute1 Default FFh Access RW Bit Description AlarmMinute2 has to be written to latch the whole alarm register RTCAlarmMinute3 Register (Address 68h). RTCAlarmMinute3 Addr: 68h Bit Bit Name Default Access 7:0 alarmminute2 FFh RW Bit Description - SRAM Register (Address 69h). SRAM Addr: 69h Bit Bit Name Default Access 7:0 SRAM 00h RW www.austriamicrosystems.com Bit Description - 1.2 81 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ADC_control Register (Address 70h). ADC_control Addr: 70h Bit Bit Name Default Access 7 start_conversion 0 RW Writing a 1 into this bit starts one ADC conversion 6 adc_on 0 RW Writing a 1 into this bit continuously activates the ADC S/H and the input multiplexer. The ADC and the MUX are also activated for a conversion period when start_conversion is set to 1. Useful for high impedance input sources on ADC inputs 5 adc_slow 0 RW Select ADC sampling frequency 0 :€250kHz (conversion time: approx. 60µs) 1 :€62.5kHz (conversion time:approx. 240µs) 4 gpio_lv RW 0 :€High voltage range of GPIO1…4/SENSEN_SU1 (4:1 divider active) 1 :€Low voltage range of GPIO1…4/SENSEN_SU1 (1:1 divider, 1.8V max) RW Selects an ADC channel .0 :€BATTEMP NTCADCIN (1:1) .1 :€Temperature sensor: DIE temperature [C] = adc_result * 0.866 274 (1:1) .2 :€XOUT32K (1:1, 1.8Vmax) .3 :€CURR1 (1:1, 1V max) .4 :€CURR2 (1:1, 1V max) .5 :€CURR3 (1:1, 1V max) .6 :€VUSB(15:1, 15V max) .7 :€CHGIN (4:1) .8 :€VBAT (4:1) .9 :€VSUP (4:1) 10 :€SENSEN_SU1 (4:1 or 1:1 ) 11 :€FB_SU2 (4:1 or 1:1 ) 12 :€GPIO2 (4:1 or 1:1 ) 13 :€GPIO3 (4:1 or 1:1 ) 14 :€GPIO4 (4:1 or 1:1 ) 15 :€NA 3:0 adc_select 0 'b0000 Bit Description ADC_MSB_result Register (Address 71h). ADC_MSB_result Addr: 71h Bit Bit Name Default Access Bit Description 7 result_not_ready 0 RO Indicates end of conversion 0 result is ready 1 conversion is running 6:0 D9_3 'b000 0000 RO ADC result register Bit9..Bit3 ADC_LSB_result Register (Address 72h). ADC_LSB_result Addr: 72h Bit Bit Name Default Access 7:3 - 'b0000 0 n/a do not use 2:0 D2_0 'b000 RO ADC result register Bit2…Bit0 www.austriamicrosystems.com Bit Description 1.2 82 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w RegStatus Register (Address 73h). RegStatus Addr: 73h Bit Bit Name Default Access Bit Description 7 curr3_lv 0 RO Bit is set when voltage of current sink CURR3 drops below low voltage threshold (1ms debounce time default) 6 curr2_lv 0 RO Bit is set when voltage of current sink CURR2 drops below low voltage threshold (1ms debounce time default) 5 curr1_lv 0 RO Bit is set when voltage of current sink CURR1 drops below low voltage threshold (1ms debounce time default) 4 - 0 n/a do not use 3 - 0 n/a do not use 2 sd3_lv 0 RO Bit is set when voltage of SD3 drops below low voltage threshold (-5%) (1ms debounce time default) 1 sd2_lv 0 RO Bit is set when voltage of SD2 drops below low voltage threshold (-5%) (1ms debounce time default) 0 sd1_lv 0 RO Bit is set when voltage of SD1 drops below low voltage threshold (-5%) (1ms debounce time default) InterruptMask1 Register (Address 74h). InterruptMask1 Addr: 74h Bit Bit Name Default Access 7 LowBat_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 6 ovtmp_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 5 onkey_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 4 chdet_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 3 eoc_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 2 resume_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 1 nobat_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 0 trickle_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) www.austriamicrosystems.com Bit Description 1.2 83 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w InterruptMask2 Register (Address 75h). InterruptMask2 Addr: 75h Bit Bit Name Default Access Bit Description 7 rtc_rep_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 6 stpup1_det_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 5 stpup1_oc_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 4 bat_temp_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 3 - 1 n/a do not use 2 sd3_lv_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 1 sd2_lv_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 0 sd1_lv_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) InterruptMask3 Register (Address 76h). InterruptMask3 Addr: 76h Bit Bit Name Default Access Bit Description 7:3 - 'b0000 0 n/a 2 gpio_restart_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 1 gpio_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) 0 rtc_alarm_int_m 1 RW 0 :€interrupt enabled 1 :€interrupt masked (disabled) do not use InterruptStatus1 Register (Address 77h). InterruptStatus1 Addr: 77h Bit Bit Name Default Access 7 LowBat_int_i 0 POP Bit is set when VSUP drops below ResVoltFall 6 ovtmp_int_i 0 POP Bit is set when 110deg is exceeded 5 onkey_int_i 0 POP Rising and falling edge 4 chdet_int_i 0 POP Rising and falling edge 3 eoc_int_i 0 POP Rising and falling edge 2 resume_int_i 0 POP Rising and falling edge 1 nobat_int_i 0 POP Rising and falling edge 0 trickle_int_i 0 POP Rising and falling edge www.austriamicrosystems.com Bit Description 1.2 84 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w InterruptStatus2 Register (Address 78h). InterruptStatus2 Addr: 78h Bit Bit Name Default Access Bit Description 7 rtc_rep_int_i 0 POP Rising edge only 6 stpup1_det_i 0 POP Rising edge only 5 stpup1_oc_i 0 POP Rising edge only 4 bat_temp_i 0 POP Rising and falling edge 3 - 0 n/a do not use 2 sd3_lv_int_i 0 POP Rising edge only 1 sd2_lv_int_i 0 POP Rising edge only 0 sd1_lv_int_i 0 POP Rising edge only Bit Description InterruptStatus3 Register (Address 79h). InterruptStatus3 Addr: 79h Bit Bit Name Default Access 7:3 - 'b0000 0 n/a do not use 2 gpio_restart_int_i 0 POP Falling edge 1 gpio_int_i 0 POP Rising and falling edge 0 rtc_alarm_int_i 0 POP Rising edge only www.austriamicrosystems.com 1.2 85 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ChargerControl1 Register (Address 80h). ChargerControl1 Addr: 80h Bit Bit Name Default Access Bit Description 7 nobat_ntc_det 1 RW Enables nobat_det feature with NTC, ntc_nobat debounce time=100ms 6 auto_resume 1 RW 0 :€charger will stay in EOC even when the battery voltage drops 1 :€charger will start charging when the battery voltage hits the resume level 5 bat_charging_enable 0 RW 0 :€USB is supplying VSUP, but battery switch is open. USB charger regulates to Vsup_voltage 1 :€Normal battery charger operation form USB charger 4:1 usb_current 'b1000 RW Sets the USB input current limit, if not GPIO controlled .0 :€94mA (USB low current, also if gpiox_iosf=12 and gpiox=0) .1 :€141mA .2 :€189mA .3 :€237mA .4 :€285mA .5 :€332mA .6 :€380mA .7 :€428mA .8 :€470mA (USB high current, also if gpiox_iosf=12 and gpiox=1) .9 :€517mA 10 :€754A 11 :€1.29A 12 :€1.7A 13 :€2.53A 14 :€2.53A 15 :€2.53A 0 usb_chgEn 1 RW ON/OFF control of USB charger input current limiter 0 :€input current limiter disabled 1 :€input current limiter enabled ChargerVoltageControl Register (Address 81h). ChargerVoltageControl Addr: 81h Bit 7:6 5:0 Bit Name vsup_min ChVoltEOC www.austriamicrosystems.com Default 'b01 'b10 0011 Access Bit Description RW Regulate down battery charging current on that level of VSUP during trickle charging and constant current charging, to prevent voltage drop on VSUP. 0 :€3.9V 1 :€4.2V 2 :€4.50V 3 :€4.70V RW Sets the end-of-charge voltage level VCHOFF (20mV steps) ...0 :€3.5V ...1 :€3.52V ..... :€... .35 :€4.2V ..... :€... 47-63 :€4.44V 1.2 86 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ChargerCurrentControl Register (Address 82h). ChargerCurrentControl Addr: 82h Bit Bit Name Default Access 7 eoc_current 0 RW Sets eoc_current 0 :€eoc current = TrickleCurrent 1 :€eoc current = TrickleCurrent / 2 6 cc_lowlimit 1 RW Sets the range of the charging current limit in constant current mode. 0 :€Normal mode 1 :€Low current mode Current=ConstantCurrent - 500mA RW Sets the charging current limit in constant current mode. .0 :€750mA .1 :€800mA .2 :€850mA .3 :€900mA .4 :€950mA .5 :€1000mA .6 :€1050mA .7 :€1100mA .8 :€1150mA .9 :€1200mA 10 :€1250mA 11 :€1300mA 12 :€1350mA 13 :€1400mA 14 :€1450mA 15 :€1500mA RW Sets the charging current limit in trickle current mode. 0 :€60mA 1 :€120mA 2 :€180mA 3 :€240mA 5:2 1:0 ConstantCurrent TrickleCurrent www.austriamicrosystems.com 'b0000 'b01 Bit Description 1.2 87 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ChargerConfig Register (Address 83h). ChargerConfig Addr: 83h Bit Bit Name Default Access 7 - 0 n/a do not use 6 Charging_1Hz_clk 0 RW Sets the mode for the charging output status (gpioX_iosf=10) 0 :€Normal operation: charging=1, not charging=0 1 :€1Hz blinking operation: charging=1Hz, not charging=0 5 ChVoltResume 0 RW Sets the resume voltage level VCHRES. 0 :€120mV 1 :€240mV RW Selects temperature regulation of charging current (die temperature) 0 :€110ºC 1 :€90ºC 2 :€120ºC 3 :€130ºC RW Voltage regulation of VSUP of the input current limiter 0 :€4.4V 1 :€4.5V 2 :€4.6V 3 :€4.7V 4 :€4.8V 5 :€4.9V 6 :€5.0V 7 :€5.5V 4:3 2:0 temp_sel vsup_voltage 'b00 'b101 Bit Description NTCsupervision Register (Address 84h). NTCsupervision Addr: 84h Bit Bit Name Default Access 7:3 - 'b0000 0 n/a do not use 2 ntc_temp 0 RW Select NTC mode 0 :€50deg temperature limit 1 :€45deg temperature limit 1 ntc_10k 0 RW Select NTC resistor type 0 :€100kΩ 1 :€10kΩ 0 ntc_on 0 RW ON/OFF control of battery NTC supervision 0 :€Disabled 1 :€Enabled www.austriamicrosystems.com Bit Description 1.2 88 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w Chargersupervision Register (Address 85h). Chargersupervision Addr: 85h Bit Bit Name Default Access 7 - 0 n/a do not use 6 ovprot_dis 1 RW Disables external overvoltage protection, function of XOFF pin 0 :€Overvoltage protection enabled 1 :€Overvoltage protection disabled 5 dcdc_chmode 1 RW Enables DCDC charger mode 0 :€Linear charger mode enabled 1 :€Step down charger enabled 4 charging_tmax 1 RW 3:0 ch_timeout 'b0000 RW Bit Description 0 :€Read: no time-out reached, Write: reset charger time-out counter 1 :€ch_timeout reached and charging stopped Sets the charger time-out timer .0 :€Off .1 :€0.5 hour .2 :€1 hour .3 :€1.5 hour .4 :€2 hour .5 :€2.5 hour .6 :€3 hour .7 :€3.5 hour .8 :€4 hour .9 :€4.5 hour 10 :€5 hour 11 :€5.5 hour 12 :€6 hour 13 :€6.5 hour 14 :€7 hour 15 :€7.5 hour ChargerStatus1 Register (Address 86h). ChargerStatus1 Addr: 86h Bit Bit Name Default Access 7 Nobat 0 RO Bit is set, if no battery has been detected (after EOC measured on NTC) 6 Battemp_hi 0 RO Bit is set, if high battery temperature has been detected 5 EOC 0 RO Bit is set, if End of charge state has been reached 4 CVM 0 RO Bit is set, if charger is operating in constant voltage mode 3 Trickle 0 RO Bit is set, if charger is operating in trickle current. VBAT < 2.9V 2 Resume 0 RO Bit is set, if Battery voltage is below resume level 1 CCM 0 RO Bit is set, if charger is operating in constant current mode 0 ChDet 0 RO Bit is set when external charge adapter has been detected on pin VCHARGER www.austriamicrosystems.com Bit Description 1.2 89 - 98 AS3710 2V1 Datasheet - R e g i s t e r O v e r v i e w ChargerStatus2 Register (Address 87h). ChargerStatus2 Addr: 87h Bit Bit Name Default Access Bit Description 7:3 - ‘b0000 0 n/a do not use 2 usb_prot_ready 0 RO Bit indicates, that the USB input voltage protection pin XOFF is precharged to a voltage > 7.5V XOFF is pull to GND if an overvoltage on VUSB is detected. 1 batsw_on 0 RO 0 batsw_mode 0 RO Bits indicates the status of the battery switch 00 : Battery switch closed 01 : Battery switch open with ideal diode 10 : Charging mode 11 : Battery switch closed Lock Register (Address 8eh). Lock Addr: 8eh Bit Bit Name Default Access 7:3 - ‘b0000 0 n/a do not use 2 charger_lock 0 RW Enables lock of the following charger registers: 81h, 82h, 83h, Chargervoltagecontrol, Chargercurrentcontrol, Chargerconfig. Bits can only be set. Reset only with full reset cycle RW Enables lock of Regulator voltages Bits can only be set. Reset only with full reset cycle 0 :€No lock 1 :€Lock of voltage of LDOs (LDO1..8_vsel) (all bits) and voltage of StepDownBits(sd1..4_vsel) [5:6] only 2 :€Lock voltage of StepDownbits 5:6 only (no LDOs) 3 :€Lock voltage of StepDowns (all bits) and LDOs (all bits). Note: Setting sdx_vsel to 0 is possible all the time to allow switching off the regulator. Writing a non-zero value after that will restore the old value. 1:0 reg_lock 'b00 Bit Description ASIC_ID1 Register (Address 90h). ASIC_ID1 Addr: 90h Bit Bit Name Default Access 7:0 ID1 0Ah RO Bit Description - ASIC_ID2 Register (Address 91h). ASIC_ID2 Addr: 91h Bit Bit Name Default Access 3:0 revision 'b0000 RO www.austriamicrosystems.com Bit Description Note: Metal fuse!!! 1.2 90 - 98 D C B A C41 1 3 5 1 3 5 J5 2 4 6 BU4 GND R16 1M BU3 2.2uF 10uF C19 2 U2 5 4 3 I2C 2 4 6 100nF C28 Q2 VSUP BU2 VBAT 47uF C24 GND Shield BUS_GND D+ D- BUS_PWR 1 1 C15 C13 Q1 L3 D1 1µH RESET R15 10k ON BATTEMP S1 4.7uF 10uF C23 4.7uF VSUP R17 10k 1 S2 C29 1 Q5 D4 1uF R9 1k VSUP Y1 57 25 24 23 22 38 39 37 36 40 5 34 4 1 3 2 35 2.2uF VSS(exp) XRES SDA SCL ON XOUT32 XIN32 V2_5 CREF BATTEMP CHGOUT VBAT VSUP_CHG EXTBATSW CHGIN XOFF VUSB 2.2uF C9 C10 C11 2.2uF VSUP 2 31 56 18 2 AS3710 VIN_LDO123 VIN_LDO456 VIN_LDO78 BU1 3 2 GPIO1 GPIO2 GPIO3 GPIO4 VSUP_GPIO C17 D7 D6 26 27 28 29 21 CURR1 CURR2 CURR3 15 16 17 CURR1 CURR2 CURR3 32 30 33 55 54 53 20 19 VSUP_SU 45 C8 C3 C4 C5 C6 C7 C1 D8 2.2uF VSUP D9 NC FB_SU3 GATE_SU3 SENSEN_SU3 FB_SU2 GATE_SU2 SENSEN_SU2 FB_SU1 GATE_SU1 SENSEN_SU1 FB_SD1 LX_SD1 FB_SD2 LX_SD2 FB_SD3 LX_SD3 VSUP_SD1 VSUP_SD2 VSUP_SD3 44 46 42 41 43 49 51 52 48 47 12 13 9 10 8 7 14 11 6 1µH 1µH 1 Q7 10µH L8 150m R21 3 2.2uF C37 C25 10µF 3 D5 SD3 SD2 SD1 Project Title C38 2.2uF SU3 10µH L6 4.7µH L5 R7 150m VSUP R4 150m C14 10µF Date 01/06/2011 Originator * * C40 15nF C39 Size A4 Title 100k R23 1M R22 1.5nF C20 10µF C21 2.2uF VSUP C16 2.2uF LDO1 LDO2 LDO3 LDO4 LDO5 LDO6 LDO7 LDO8 2.2uF C12 2.2uF 1µH VSUP L4 L2 L1 1uF 1uF 2.2uF 2.2uF 2.2uF 1uF 2.2uF C2 SENSEP 50 LDO1 LDO2 LDO3 LDO4 LDO5 LDO6 LDO7 LDO8 GPIO1 GPIO2 GPIO3 GPIO4 3 1.2 2 1 Q4 1 Q3 2.2uF C22 VSUP 3 2.2uF C31 2 3 www.austriamicrosystems.com 2 VUSB D3 D2 C30 33nF C34 4 SU1 C33 2.2uF SU2 C27 10uF of * Revision * 15nF Sheet * R14 100k 1M R11 1.5nF C32 R8 15nF C26 330k 1M R6 4 D C B A AS3710 2V1 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 11 Application Information Figure 34. AS3710 Application Schematics 91 - 98 AS3710 2V1 Datasheet - A p p l i c a t i o n I n f o r m a t i o n Figure 35. PCB Layout Recommendation for SD1, SD2, SD3 and Switched Mode Charger www.austriamicrosystems.com 1.2 92 - 98 AS3710 2V1 Datasheet - A p p l i c a t i o n I n f o r m a t i o n Figure 36. PCB Layout Recommendation for SU1, SU2, SU3 www.austriamicrosystems.com 1.2 93 - 98 AS3710 2V1 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 12 Package Drawings and Markings Figure 37. Package Drawings and Dimensions www.austriamicrosystems.com 1.2 94 - 98 AS3710 2V1 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s Figure 38. QFN Marking Table 31. Package Code YWWZZZ YY WW X ZZ year working week assembly / packaging plant identifier free choice Table 32. Start-up Revision Code xx Sequence FF engineering samples, no sequence programmed or sequence programmed on request 00 default sequence (no sequence programmed) xx customer specified sequence programmed during production test www.austriamicrosystems.com 1.2 95 - 98 AS3710 2V1 Datasheet - R e v i s i o n H i s t o r y Revision History Revision Date Owner 0.10 3.2011 pkm Description Initial draft typo corrections; updated block diagrams, PCB layout recommendations, charger mode diagrams, application schematics, DCDC performance characteristics added register 2bh and 2ch for chip version 2v1. 0.20 10.2011 pkm, cwo 1.0 10.2011 pkm first official release 1.1 12.2011 pkm corrected ntc_on bit description, adjusted max die temperature, updated dcdc mode description pkm corrected “enter standby mode”, GPIO1 input mode description, GPIO block diagram, GPIO IOSF, interrupt signal polarity added switching charger graphs, added step-up external components, ASIC ID 1.2 4.2012 Note: Typos may not be explicitly mentioned under revision history. www.austriamicrosystems.com 1.2 96 - 98 AS3710 2V1 Datasheet - O r d e r i n g I n f o r m a t i o n 13 Ordering Information The devices are available as the standard products shown below. Table 33. Ordering Information Ordering Code Marking Sequence Description Delivery Form Package AS3710-BQFR-FF M2V1-FF sequence programmable on request Triple Buck High Current PMIC with Charger Tray QFN56 7x7 0.4mm pitch AS3710-BQFP-00 M2V1-00 default sequence Triple Buck High Current PMIC with Charger Tape & Reel dry pack QFN56 7x7 0.4mm pitch AS3710-BQFP-xx M2V1-xx customer specified Triple Buck High Current PMIC with Charger Tape & Reel dry pack QFN56 7x7 0.4mm pitch Note: All products are RoHS compliant and austriamicrosystems green. Buy our products or get free samples online at ICdirect: http://www.austriamicrosystems.com/ICdirect Technical Support is available at http://www.austriamicrosystems.com/Technical-Support For further information and requests, please contact us mailto: sales@austriamicrosystems.com or find your local distributor at http://www.austriamicrosystems.com/distributor www.austriamicrosystems.com 1.2 97 - 98 AS3710 2V1 Datasheet - C o p y r i g h t s Copyrights Copyright © 1997-2012, austriamicrosystems AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. Contact Information Headquarters austriamicrosystems AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com 1.2 98 - 98
AS3710-BQFR-FF 价格&库存
很抱歉,暂时无法提供与“AS3710-BQFR-FF”相匹配的价格&库存,您可以联系我们找货
