AS3658-BCTP
AS3658-BCTP
    AMSOSRAM(艾迈斯半导体)
    TFBGA124
    IC PMU POWER/AUDIO 124-CTBGA
AS3658-BCTP 数据手册
austriamicrosystems AG is now ams AG The technical content of this austriamicrosystems datasheet is still valid. Contact information: Headquarters: ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 e-Mail: ams_sales@ams.com Please visit our website at www.ams.com AS3658 D a ta S h e e t C o n f i d e n t i a l P o w e r a n d A u d i o M a n a g e m e n t U n i t f o r P o r ta b l e D e v i c e s System Control am lc s on A te G nt st il 2 Key Features al id The AS3658 is highly integrated power and audio management unit. The AS3658 is designed to include sophisticated audio features like high performance audio DAC and ADC. It has several analog and digital audio interface which are explained in detail in the following sections. The AS3658 is an integrated solution for power supply generation and monitoring, battery management including charging. - High Current (1.0A) Linear Charger with external pass transistor (no step down charger) - 0.1 Ω Battery switch for start-up and trickle charge - Integrated USB charger up to 880mA (can be used as wall adapter charger); current accuracy 440500mA for USB specification, in-circuit trimmable (±1.2% trimsteps) - Autonomous Battery Temperature Supervision (0ºC-45ºC or 0ºC- 50ºC) for 10k and 100k NTC - Charging Timeout (1h-8h in 30min steps) - Charging in Stanby mode - Completely Autonomous (no SW) Power Management Features lv 1 General Description - Serial Control Interface - On/Off Control Module with Boot-ROM / GPIO - Reset Generation for system controller - Programmable Interrupt Controller and Watchdog - Low power off mode (9µA; 2.5V LDO on) - 88 bit unique ID or Boot fuse array - Reset with long ON-Keypress (SW-Interuptable) - Touchscreen Interface (10 bit, interrupt) Supply Voltage Generation ni ca - 2 RF Programmable Low Noise LDOs (250mA) (1 LDO can be a current controlled switch for hotplug (200mA ± 40%)) - 1 RF Programmable Low Noise LDO (400mA) - 4 Programmable Dig. Low Power LDOs(200mA) - 2 General Purpose PWM DC/DC step up converter with three programmable current sinks (e.g. forwhite led); for current mode feedback is automatically slected (DCDC_CURR1,2,3) - 3 General Purpose high efficiency DC/DC step down converter (DCDC 1 support DVM) - 1 Low noise charge pump with 5V output voltage - 1 Ultra Low Power 2.5V LDO (always on) Current sinks Te ch - 4 programmable(8-bit) from 0.15mA to 38.25mA (±5% ) optional useable as GPIOs - 3 programmable high voltage (15V) (8-bit) from 0.15mA to 38.25mA (±5% ) - internal PWM generator (extended time range) (can control DCDC_CURR1,2,3) 10-bit 40µs Successive Approximation ADC - Two external Inputs (ADC_IN1, ADC_IN2) Battery Management - Wide Battery Supply Range 3.0…5.5V - On-Chip Bandgap Tuning for High Accuracy (±1%) - Thermal and Current Protection (int. sensor) - Standby Mode exit by interrupt e.g. Onkey/RTC Audio - 94dB Audio DAC, 16-48kHz sampling rate Two Digital Audio Inputs (2 x I2S interface) 2.9V low Noise LDO for Audio DAC Two Headphone Amplifier Output with GND separation - Two I2S Inputs and one I2S Output - I2S master mode with programmable sample rate (controlled by internal PLL) - GND Buffer for Headphone Amplifier - Line/ Headphone outputs with GND separation - Audio ADC, 82dB SNR with 16ksps - Microphone Bias Supply and Amplifier (mono) - 5 Band Adjustable Audio Equalizer (± 12dB in 3dB gain steps) - SPDIF Output - Audio Mixer and Gain Stages - PCM Interface Real Time Clock (RTC) - Alarm and Time function - Repeated Wakeup (every second or minute) - 32kHz output - Backup Battery Charger and Switchover Programmable System clock - 1.6 MHz to 2.3 MHz with 100 kHz steps Package - BGA124 8x8mm, 0.5mm pitch (can be assembled without micro via boards) - Full featured chemistry independent step down charger with Gas Gauge and Current limitation www.austriamicrosystems.com Revision 1v13 1 - 157 AS3658 Data Sheet Confidential - Applications 3 Applications The AS3658 is ideal for PDA, PMP, GPS-Navigation Systems and 1 Cell Li+ or 3 Cell NiMH powered devices. Figure 1. Blockdiagram AS3658 *+-    )        !"#" $%&  .  !"/     , * , *, " ) ,*!(" !.89 6. ""  !"#" * 01,0 * 01,0 5!6 7# *8"& "6.  ,& * 01,0 * 01,0  3 ,& * 0%-03 ' 3& (!# ) ."4 4 *) * 0%-03 ', ,& * 0%-03 ',&  *+ & !"# & '( !# %%B. *)  *" ""  "64  (!#4@ = 6  .=          *) 7; *)    (!# +    (!#" ""  +, + 5." "9!6 * ,0: 7.4(/ , ! 7 =!(.>" , ) ,  ' ni  '*3  , ,& am lc s on A te G nt st il     '" * " ""  "64  "!( "4   307 ?4.35V for V_USB and VCHARGER, and for V_USB, if usb_hold_chdet=1. Warning: Backcharging is possible if usb_hold_chdet=1 6.0 6.5 7.0 V ChOVDetEn=’1’ for external linear charger only V ChOVDetEn=’1’ for external linear charger only 6.0 Revision 1v13 54 - 157 AS3658 Data Sheet Confidential - Detailed Description-Power Management Functions Table 45. Charger Characteristics VVBAT=3.0…5.5V; Tamb=–20…+85°C; unless otherwise specified Symbol Parameter Typ Min Unit ISTARTmax Maximum load current during startup on Vsupply VUVLO Undervoltage lockout threshold –3% 2.7… 3.4 +3% V Value is set by ResVoltRise in the Battery Voltage Monitor register VCHOFF Charge termination threshold –0.06 3.90… 4.25 +0.06 V Li+ battery; value is set by ChVoltEOC in the Charger Config register VCHRES Charger resume voltage V Value is set by ChVoltResume in the Charger Config register. Do not set VCHRES higher than VCHOFF! Vcurr_preset Charger constant current pre-set voltage VEOC Charger EOC voltage mA 3.85… 4.20 al id 5 Note lv Min VRESRI SE V 3.60 V am lc s on A te G nt st il + 100mV If isolate_bat=0; to prevent a system reset if the battery is removed in EOC operation Table 46. Charger status Bit definitions Addr:99 Charger status These bits show the status of the charger Bit Name Default Access Description 0 ChDet NA R Bit is set when external charge adapter has been detected on pin VCHARGER 1 ChAct NA R Bit is set when step down charger is operating (independent of Reg. bit no_charging) 2 Resume NA R Bit is set when battery voltage has dropped below resume level 3 Trickle NA R Bit is set when charger is in trickle charge mode 4 CVM NA R Bit is set when charger is in top-off charge mode (constant voltage mode) 5 EOC R Bit is set when charging has been terminated. Bit is cleared automatically when ChEn is cleared, no_charging is set or charging is resumed. NA R Bit is set when battery detection circuit indicates that no battery is connected to the system. Detection is started after EOC and if bit autoresume=1 only. Bit is cleared automatically when a battery is connected, when DisBDet is set and/or when ChEn is cleared. NA R Bit is set, if Linear charger is detected, and chDet=1. This state is latched on the rising edge of chDet. Detected if VOFF_B is connected to ground ni NoBat ch 6 ca Bit ChLinear Te 7 NA www.austriamicrosystems.com Revision 1v13 55 - 157 AS3658 Data Sheet Confidential - Detailed Description-Power Management Functions Table 47. Charger control Bit definitions Charger Control1 Addr:11 0 Default Access ChEn Ch_pwroff_en ROM 0 Disable step down charger (Independent of bit no_charging) 1 Enable step down charger (default) (Independent of bit no_charging) 0 Startup of AS3658 if charger is connected in power_off mode 1 Don't exit power off mode, if charger is already connected before entering power off mode; no autonomous charging upon static charger detect. Startup with rising edge of VCHARGER or V_USB, RTC wakeup and XON pin only 0 Overvoltage detection with linear external charger enabled 1 Overvoltage detection with linear external charger enabled. Battery charging disabled, if voltage exceeded 0 Charging does not restart automatically in EOC when bit Resume is set. 1 Charging will restart automatically in EOC when bit Resume is set 0 Normal charge_detect operation 1 Charger detect of USB charger will not be reset, if VUSB=VBAT. (Allow Battery charging, with V_USB 6, ,% $>(@A$ B6B$ $&$  *$>( A >( ?( Te ,*$0"& ,&.*$,&&   $>@A   *$> A > ?   &""&$,&& > 6,   C/ && 6,   .&%$ www.austriamicrosystems.com ' 6,"& 3%"9:; < 0*1 6,"& ' 6,"& =%"9:; < 0*1 6,"& ' 6,"& >%"9:; <    Revision 1v13 3%" &*$"*& 3+"9; < =+"9; < >+"9; < /0"& &.* 143 - 157 AS3658 Data Sheet Confidential - Detailed Description - System Functions The touchpen controller is operating according to the following state diagram: Figure 60. Touchpen State diagram         al id         ("  (&              *+,   am lc s on A te G nt st il  lv   ("   (&                                       (&- *+,      !"#"$%#&#&" ' .       *+, ca )    )    ni 10.10.1 Software guidelines Te ch 1. Setup the configuration registers (tpen – control 1..3) according the hardware 2. Enable receiving of touchpen interrupts (either through XINT or GPIO4_CURR4) 3. Upon receiving of a touchpen interrupt, readout tpen_xmsb, tpen_ymsb (and if required tpen_pressmsb and tpen_xypresslsb) with a single I2C blockread. This ensured, that the x,y,z is correctly readout and all data belong to one single touchpen x,y,z conversion 4. Perform all the required processing with the data (e.g. accept a pen-down only if the pen is forced onto the touchscreen with a minimum pressure [z-position]) www.austriamicrosystems.com Revision 1v13 144 - 157 AS3658 Data Sheet Confidential - Detailed Description - System Functions 10.10.2 Touchpen Registers Table 178. Touchpen Register Map Register Definition Addr Default Content Name b7 b6 b5 b4 b3 b2 b1 b0 XD2 108 NA XD9 XD8 XD7 XD6 XD5 XD4 XD3 tpen_ymsb 109 NA YD9 YD8 YD7 YD6 YD5 YD4 YD3 YD2 tpen_pressmsb 110 NA PD9 PD8 PD7 PD6 PD5 PD4 PD3 PD2 tpen_xypresslsb 111 NA PD1 PD0 0 YD1 YD0 0 XD1 XD0 tpen – control 1 112 00h tpen_st_ tpen_eo pen c tpen – control 2 113 00h tpen_so tpen_wa tpen_curr cpd it press tpen – control 3 114 00h tpen_soc tpen_convint tpen_on lv tpen_avg al id tpen_xmsb tpen_pu tpen_sample am lc s on A te G nt st il tpen_timeo tpen_deb ut _en ounce Note: The cells marked in color are Read only Table 179. Touchpannel Result Register Bits Touchpad_XMSB result Addr:108 X-MSB result register Bit Bit Name Default Access Description 7:0 tpen_xmsb 00000000 R X – MSB Data Table 180. Touchpannel Result Register Bits Touchpad_YMSB result Addr:109 Y-MSB result register Bit Bit Name Default Access Description 7:0 tpen_ymsb 00000000 R Y – MSB Data ca Table 181. Touchpannel Result Register Bits Touchpad_Pressure result Addr:110 7:0 Bit Name Default Access Description tpen_pressmsb 00000000 R Pressure - Data ni Bit Pressure result register ch Table 182. Touchpannel Result Register Bits Touchpad_XY - LSB result Te Addr:111 X - MSB result register Bit Bit Name Default Access Description 1:0 tpen_xlsb 00 R X – LSB Data 4:3 tpen_ylsb 00 R Y – LSB Data 7:6 tpen_presslsb 00 R Pressure – LSB Data www.austriamicrosystems.com Revision 1v13 145 - 157 AS3658 Data Sheet Confidential - Detailed Description - System Functions Table 183. Touchpannel Control Register Bits Touchpad – control 1 Addr:112 Bit Bit Name This register controls the different modes of the Touchpad Default Access Description Enables Touch Pen Function tpen_on 0 0 OFF (No wakeup on pen down) 1 Pen Detect enabled wakes up Pen Digitizer Check Pen_Status -> if pendetect or tpen_soc_pd=1 and tpen_soc=1 then perform X,Y,Z measurements R/W al id 0 Conversion Interval Timer 00 R/W 01 every 512 clock periods (0,5 ms) ADC – Averaging limited to max. 4 10 every 1024 clock periods (1ms) ADC – Averaging limited to max. 8 11 every 10240 clock periods (10ms) lv tpen_convint No delay between conversions am lc s on A te G nt st il 2:1 00 Start Conversion (x,y, and z conversion) 3 tpen_soc 0 0 No Conversion if pen down detected 1 Start Conversion if pen down detected or tpen_soc_pd=1 and tpen_on=1 (X, Y and Z-Pressure Measurement) R/W Averaging of x and y measurement 5:4 tpen_avg 0 R/W 00 no averaging 01 4 measurements (per channel) 10 8 measurements (per channel) 11 16 measurements (per channel) ADC - End of Conversion bit tpen_eoc 0 ni tpen_st_pen TP in Power down or Conversion ongoing 1 Valid TP data available (x,y, and pressure) generates an interrupt on GPIO4_CURR4 and/or XINT; the interrupt is released when the readout from the tpen_xmsb is started Pen status 0 R 0 penup 1 pendown Te ch 7 0 R/W ca 6 www.austriamicrosystems.com Revision 1v13 146 - 157 AS3658 Data Sheet Confidential - Detailed Description - System Functions Table 184. Touchpannel Control Register Bits Touchpad – control 2 Addr:113 Bit Bit Name This register controls the different modes of the Touchpad Default Access Description Internal Resistor used for Pen detection Do not use this Setting 00001 4kΩ 00010 8kΩ ... tpen_pu 00000 R/W 00100 16kΩ lv 4:0 al id 00000 ... 01000 32kΩ am lc s on A te G nt st il ... 10000 64kΩ (most sensitive) ... 11111 ~ 2kΩ Current used for pressure measurement 5 tpen_currpress 6 0 tpen_wait 7 0 tpen_soc_pd 0 R/W R/W 0 200µA 1 400µA 0 Do not wait until tpen_xmsb is readout 1 Start next ADC – conversion after data is read from Register tpen_xmsb 0 Start conversion only if tpen_st_pen is 1 and tpen_soc=1 and tpen_on=1 1 Measure regardless of pen Status (only if tpen_soc=1 and tpen_on=1) R/W Table 185. Touchpannel Control Register Bits Bit Name ni Bit tpen_sample This register controls the different modes of the Touchpad Default Access Te 2 3 tpen_debounce Description Sample Time of ADC 00 R/W ch 0:1 Touchpad – control 3 ca Addr:114 0 R/W 0 3µs 1 10µs 2 50µs 3 200µs 0 Pen-down Debounce Time 100µs 1 Pen-down Debounce Time = 3ms Enables Timeout Signal (ADC conversion is stopped during tiemeout = 1) tpen_timeout _en www.austriamicrosystems.com 0 R/W Revision 1v13 0 off 1 GPIO3_CURR3 can be configured as input for the timeout signal – see block diagram 147 - 157 AS3658 Data Sheet Confidential - Register map 11 Register map Table 186. Register Map Default hex Content Addr Register Definition Step Down Voltage1 0 0h sd1_freq ROM sd1_clki nv u step_down1_v Step Down Voltage2 1 1h sd2_freq ROM sd2_clki nv u step_down2_v Step Down Voltage3 2 2h sd3_freq ROM sd3_clki nv u step_down3_v LDO_RF1 Voltage 3 3h ROM rf1_swpr rf1_lcurr ot_en _en ldo_rf1_v LDO_RF2 Voltage 4 4h ROM double_r slow_sta rf2_lcurr eset rtup _en ldo_rf2_v LDO_RF3 Voltage 5 LDO_DIG1 Voltage 6 LDO_DIG2 Voltage 7 LDO_DIG3 Voltage 8 LDO_DIG4 Voltage 9 USB Charger Control b5 b4 b3 b2 b1 rf3_hotpl rf3_lcurr ug_en _en 5h ROM 6h ROM ldo_dig1_v 7h ROM ldo_dig2_v 8h ROM ldo_dig3_v 9h ROM ldo_dig4_v 10 Ah No_char dis_bats ROM ext_bats w_temp usb_chg w_en ging En _prot Charger Control1 11 Bh Auto ch_det_ charging usb_hol CHOVD Ch_pwr ROM Isolate_b at 500ms _tmax d_chdet Resume etEn off_en Battery voltage monitor 12 Ch SupRes ROM FastRes En En Charger Config 13 Dh ROM FuelGauge 15 Charger Current 16 ldo_rf3_v auto_sh ROM ntc_type ntc_hyst ntc_high _temp utdown Fh ROM ch 10h ROM power_o ff_at_vs uplow ch_voltage ChEn ResVoltRise Vsupply_min Eh ntc_on usb_Current ResVoltFall ChVoltResume ca 14 ni Charger supervision b0 al id b6 lv b7 am lc s on A te G nt st il Name ChVoltEOC ch_timeout CalMod CalReq ConstantCurrent UpdReq FGEn TrickleCurrent 17 11h ROM GPIO 1 18 12h ROM gpio1_pulls gpio1_in vert gpio1_iosf gpio1_mode GPIO 2 19 13h ROM gpio2_pulls gpio2_in vert gpio2_iosf gpio2_mode GPIO 3 20 14h ROM gpio3_pulls gpio3_in vert gpio3_iosf gpio3_mode GPIO 4 21 15h ROM gpio4_pulls gpio4_in vert gpio4_iosf gpio4_mode Te Charge Pump Control www.austriamicrosystems.com sdx_1A_mode Revision 1v13 sd1_dvm_time cp_puls eskip cp_freq 148 - 157 AS3658 Data Sheet Confidential - Register map Table 186. Register Map Default hex Content Addr Register Definition Reset Timer 22 16h ROM Reg Power1 Ctrl @ 6 msec 23 17h ROM cp_on sd3_on sd2_on ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on Reg Power1 Ctrl @ 7 msec 24 18h ROM cp_on @7 msec sd3_on @7 msec sd2_on @7 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @7 @7 @7 @7 @7 msec msec msec msec msec Reg Power1 Ctrl @ 8 msec 25 19h ROM cp_on @8 msec sd3_on @8 msec sd2_on @8 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @8 @8 @8 @8 @8 msec msec msec msec msec b6 b5 b4 b3 b2 rtc_rep_ rtc_alar xon_ena wakeup m_wake ble _en up_en b0 res_timer al id rtc_mode b1 lv b7 am lc s on A te G nt st il Name sd3_on @9 msec sd2_on @9 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @9 @ 9 @ 9 @ 9 @ 9 msec msec msec msec msec 26 1Ah ROM cp_on @9 msec Reg Power1 Ctrl @ 10 msec 27 1Bh ROM cp_on @10 msec sd3_on @ 10 msec sd2_on @ 10 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @ 10 @ 10 @10 @10 @ 10 msec msec msec msec msec Reg Power1 Ctrl @ 11 msec 28 1Ch ROM cp_on @ 11 msec sd3_on @11 msec sd2_on @ 11 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @ 11 @ 11 @ 11 @ 11 @ 11 msec msec msec msec msec 1Dh ROM cp_on @ 12 msec sd3_on @ 12 msec sd2_on @ 12 msec ldo_dig1 ldo_rf2_ ldo_rf1_ sd1_on ldo_dig2 _on _on on on @ 12 @ 12 @ 12 @ 12 @ 12 msec msec msec msec msec rf3_sw stpup2_ stpup1_ on on Reg Power1 Ctrl @ 9 msec Reg Power1 Ctrl @ 12 msec 29 Reg Power2 Ctrl 30 1Eh ROM Reg GPIO Ctrl 31 sd3_gpi sd2_gpi 1Fh ROM ldo_dig3 _gpio o o Step Up DC/DC Control 32 20h 00h Step Up1 DC/ DC Control 33 21h stpup1_o stpup1_ stpup1_ 00h c_timeou shortprot clkinv t stpup1_v 00h stpup2_p rot stpup2_v ni 34 22h ch Step Up2 DC/ DC Control rf1_sw ldo_dig4 ldo_dig3 _on _on stpup2_fb stpup1_f stpup2_ req clkinv 35 23h 00h Step Down Control2 36 24h sd2_dis 00h sd3_dis_ pon _pon Step down charger control 37 25h 02h sd3_dis sd2_dis sd1_dis _curmin _curmin _curmin sdc_pas sdc_freq s_mode sdc_pon u Backup Battery charger 38 26h 40h BBCPwr BBCVolt Save BBCRes Off DCDC_CURR1 39 value 27h 00h Te Step Down Control1 www.austriamicrosystems.com sd2_nsw _on ldo_rf3 sd1_gpi ldo_dig2 ldo_dig1 ldo_rf2_ ldo_rf1_ o _gpio _gpio gpio gpio stpup2_f stpup2_f stpup1_r req b_auto es ca stpup2_r es rf2_sw sd2_psw sd1_nsw _on _on sd1_psw _on sd1_dis sdX_lpo sd3_nsw _pon _on sd3_psw _on BBCCur BBCMode dcdc_curr1_current Revision 1v13 149 - 157 AS3658 Data Sheet Confidential - Register map Table 186. Register Map Default Content b6 b5 b4 b3 28h 00h dcdc_curr2_current CURR1 value 41 29h 00h curr1_current CURR2 value 42 2Ah 00h curr2_current CURR3 value 43 2Bh 00h curr3_current CURR4 value 44 2Ch 00h curr4_current DCDC_CURR3 45 value 2Dh 00h dcdc_curr3_current 2Eh 00h ADC idac 46 b2 b1 b0 al id b7 lv DCDC_CURR2 40 value hex Name Addr Register Definition adc_idac 2Fh ovtmp_ FFh LowBat_i nt_m int_m Interrupt Mask2 48 30h FFh Interrupt Mask3 49 31h FFh onkey_ int_m chdet_ int_m am lc s on A te G nt st il Interrupt Mask1 47 usb_chd charging cheoc_i chstate_ et_ _tmax_i nt_m int_m int_m nt_m stpup1_i bat_tem hphcurr_ dig2_lv_i dig1_lv_i sd3_lv_i sd2_lv_i sd1_lv_i nt_m p_m int_m nt_m nt_m nt_m nt_m nt_m voxm_in mic_rem mic_con rtc_rep_i rtc_alar dig4_lv_i dig3_lv_i t_m _int_m _int_m nt_m m_int_m nt_m nt_m - Interrupt Status1 50 32h NA LowBat_i ovtmp_i Interrupt Status2 51 33h NA hphcurr_ dig2_lv_i dig1_lv_i sd3_lv_i sd2_lv_i sd1_lv_i stpup1_i bat_tem p_i i Interrupt Status3 52 34h NA Low voltage Status1 53 35h NA Low voltage Status2 54 36h NA GPIO Signal 55 37h NA PWM Frequency Control High Time 56 38h 00h pwm_h_time PWM Frequency Control Low Time 57 39h 00h pwm_l_time CURR control 58 3Ah 00h - voxm_i onkey_i usb_chd charging cheoc_i chstate_ et_i _tmax_i i mic_rem mic_con rtc_rep_i rtc_alar dig4_lv_i dig3_lv_i _i _i m_i stpup1_d stpup1_ et oc dig2_lv dig1_lv ca gpio4_in gpio3_in gpio2_in gpio1_in pwm_div dcdc_curr3_ctrl gpio4 Reg_low standby _bias_m clk_div2 _mode_ ode on 59 3Bh 0ch Watchdog Control 60 3Ch 02h Watchdog_min Timer 61 3Dh 00h wtdg_min_timer Watchdog_max 62 Timer 3Eh FFh wtdg_max_timer Watchdog Software Signal 63 3Fh 00h Te gpio3 dcdc_curr2_ctrl References Control www.austriamicrosystems.com sd3_lv bat_high bat_lowt dcdc_cu dcdc_cu dcdc_cu temp emp rr3_lv rr2_lv rr1_lv ni ch chdet_i clk_int sd2_lv sd1_lv dig4_lv dig3_lv gpio2 gpio1 dcdc_curr1_ctrl low_pow er_on wtdg_tri wtdg_re wtdg_on gger s_on wtdg_ sw_sig Revision 1v13 150 - 157 AS3658 Data Sheet Confidential - Register map Table 186. Register Map Default hex Content Addr RTCSecond 64 40h 00h second RTCMinute1 65 41h 00h minute RTCMinute2 66 42h 00h minute RTCMinute3 67 43h 00h minute RTCAlarmSeco 68 nd 44h 3Fh alarmsecond RTCAlarmMinu 69 te1 45h FFh alarmminute RTCAlarmMinu 70 te2 46h FFh alarmminute RTCAlarmMinu 71 te3 47h FFh alarmminute b6 b5 b4 b3 b2 rtc_irq_ mode RTCT 72 48h 00h SRAM 73 49h 00h Audio Set1 74 4Ah 00h Audio Set2 75 4Bh I2S_sele 00h I2S_mclk _en ct Audio Set3 76 4Ch 00h linmix_of micmix_ dacmix_ f off off DAC_L 77 4Dh 00h dac_mut e_off DAC_R 78 4Eh 00h ADC_L 79 4Fh 00h ADC_R 80 50h 00h adcmux adc2dac adr_vol HPH out R 81 51h 00h hp_ovc_to hpcm_of f hpr_vol HPH out L 82 52h 00h hp_mux hpl_vol Line out R 83 53h 00h b0 rtc_tbc sram equ_on aud_ldo mclk256 mclk_inv ert _on ibr_hph agc_off gnd_sw _on mix_on I2S_3_o n dith_on mic_on voxm_o hp_pulld pll_mod n _en e ca ad_fs2 hp_mute adc_mut adc_on _off ibr_dac hp_on ni ibr_line adl_vol liner_vol 54h 00h line_mut e LINE_IN_R 85 55h 00h mute_mi c_sf LINE_IN_L 86 56h 00h MIC_R 87 57h 00h MIC_L 88 58h 00h msup_off mute_off rdet_off _d SPDIF 89 59h sdo3_se spdif_co spdif_m spdif_inv 00h audio_off sclk_inv ert lect py_ok clk_inv alid EQ_LP 90 5Ah 00h ch lin_on dar_vol 84 www.austriamicrosystems.com dac_on dal_vol Line out L Te b1 al id b7 am lc s on A te G nt st il Name lv Register Definition mic_agc _off line_on dac2line _on linel_vol mute_off _inr lir_vol mute_off _inl lil_vol pre_gain mr_vol ml_vol spdif_cntr eq_lp_gain Revision 1v13 151 - 157 AS3658 Data Sheet Confidential - Register map Table 186. Register Map Default hex Content Addr Register Definition EQ_Band1 91 5Bh 00h eq_band1_gain EQ_Band2 92 5Ch 00h eq_band2_gain EQ_Band3 93 5Dh 00h eq_band3_gain EQ_HP 94 5Eh 00h eq_hp_gain EQ_preamp 95 5Fh 00h ADC_control 96 60h 00h start_con version adc_on ADC_MSB result 97 61h NA ADC_LSB result 98 62h NA ChargerStatus 99 63h NA ChargerStatus_ 100 64h usb NA DeltaChargeMS 101 65h NA sign DeltaChargeLS 102 66h NA 2 ElapsedTimeM 103 67h NA 2 ElapsedTimeLS 104 68h NA 2 105 69h NA Onkey_r eset_5s Overtemperatu 106 6Ah re Control NA B B SB B b5 b4 b3 b2 b1 eq_ pre_gain D9 D8 D7 adc_select D6 lv result_no t_ready adc_slo w ChLinear NoBat EOC CVM Trickle ch_over batsw_o voltage n 7 15 7 14 2 6 2 14 2 6 2 13 2 5 2 13 2 5 2 12 2 2 4 12 2 2 4 b0 al id b6 D5 D4 D3 D2 D1 D0 11 2 3 2 11 2 3 2 Resume ChAct ChDet batsw_ USB_Ch USB_Ch mode Act Det 10 2 2 2 2 2 10 2 2 2 2 2 9 1 9 1 8 2 0 2 8 2 0 2 xon_inp power_o force_re ut ff set reset_reason rst_ov_t ov_temp temp_p emp_14 ov_temp _140 _110 mc_on 0 rom_ valid 107 6Bh NA tpen_xmsb 108 6Ch NA XD9 XD8 XD7 XD6 XD5 XD4 XD3 XD2 tpen_ymsb 109 6Dh NA YD9 YD8 YD7 YD6 YD5 YD4 YD3 YD2 tpen_pressmsb 110 6Eh NA PD9 PD8 PD7 PD6 PD5 PD4 PD3 PD2 tpen_xypressls 111 6Fh b NA PD1 PD0 0 YD1 YD0 0 XD1 XD0 tpen – control 1 112 70h 00h tpen – control 2 113 71h tpen_wa tpen_cur 00h tpen_soc pd it rpress Te ni ca Boot_status ch Reset Control b7 am lc s on A te G nt st il Name tpen – control 3 114 72h tpen_st_ tpen_eo pen c tpen_avg tpen_convint tpen_tim tpen_de eout_en bounce ASIC ID 1 127 7Fh NA 1 1 0 0 ASIC ID 2 128 80h NA 0 1 0 1 Reg_ standby mod 129 81h sd3_stb sd2_stb 00h cp_stby_ on y_on y_on Revision 1v13 tpen_on tpen_pu 00h www.austriamicrosystems.com tpen_so c rom_adr 1 1 tpen_sample 0 1 rev ldo_dig1 sd1_stb ldo_dig2 ldo_rf1_ _stby_o _stby_o ldo_rf2_ y_on stby_on stby_on n n 152 - 157 AS3658 Data Sheet Confidential - Register map Table 186. Register Map Default b7 b6 b5 b4 b3 b2 00 b1 b0 usb_add_trim_current i2s master control1 131 83h 00 i2s master control2 132 84h 00 step Down Control3 133 85h 00 UniqueID0, addrf0 197 C5h NA ID, addrf UniqueID1, addrf1 198 C6h NA ID, addrf UniqueID2, addrf2 199 C7h NA ID, addrf UniqueID3, addrf3 200 C8h NA ID, addrf UniqueID4, romf0 201 C9h NA ID, romf0 UniqueID5, romf1 202 CAh NA ID, romf1 UniqueID6, romf2 203 CBh NA ID, romf2 UniqueID7, romf3 204 CCh NA ID, romf3 UniqueID8, romf4 205 CDh NA ID, romf4 UniqueID9, romf5 206 CEh NA ID, romf5 UniqueID10, romf6 207 CFh NA ID, romf6 i2s_clk_divider i2s_lrclk i2s_mas pcm_mo sdo_on_ i2s_mclk _sclk_ou mclk1_e de _out_en ter_on n t_en al id Usb_current_tri 130 82h m Content i2s_clk_divider sd3_uvli sd2_uvli sd1_uvli mit mit mit Entries marked are read only Entries are not reset in power off mode Te ch ni ca am lc s on A te G nt st il lv hex Name Addr Register Definition www.austriamicrosystems.com Revision 1v13 153 - 157 AS3658 Data Sheet Confidential - Package Drawings and Marking 12 Package Drawings and Marking PACKAGE OUTLINE DWG NO. 97SPP01046A ISSUE O DATE OCT.010, 2007 am lc s on A te G nt st il ±0. lv ASE Advanced Semiconductor Engineering Korea, Inc. al id Figure 61. CTBGA124 8x8 0.5mm pitch TOP VIEW BOTTOM VIEW ca (124 SOLDER BALLS ) ch ni SIDE VIEW NOTE 1. GENERAL TOLERANCE : ± 0.10 Te TITLE : POD for FBGA 8mm X 8mm X 1.09mm, 2L, 0.65CAP, 124BGA, 0.50PITCH, 0.30BALL www.austriamicrosystems.com Unit : mm Dimension & Tolerance ASME Y14.5M Customer : AMS COMPANY ASE KOREA SHEET 1 OF 2 Revision 1v13 154 - 157 AS3658 Data Sheet Confidential - Package Drawings and Marking al id Figure 62. CTBGA124 Marking lv Table 187. Package Code AYWWZZZ A Y WW ZZZ B ... for Green year working week assembly / packaging free choice x B, C, D, E, E1 or F 12.1 am lc s on A te G nt st il Table 188. Boot ROM revison Pinout Drawing (Top view) CTBGA 8x8mm Figure 63. Pinout drawing Bottom View (Ball Side) 14 13 A 12 11 10 9 8 7 6 5 4 3 2 1 A B B C C D D E E F ca F G H H J K K L L M M ch ni J G Te N P 14 13 12 www.austriamicrosystems.com 11 10 9 8 7 6 5 4 Revision 1v13 c N c P 3 2 Inner Balls PCB Layout Example shown with dotted blue lines 1 155 - 157 AS3658 Data Sheet Confidential - Ordering Information 13 Ordering Information The device is available as the standard products listed in Table 189. Table 189. Ordering Information Marking Descriptiom Delivery Form Audio Management Unit for Portable AS3658B Power and Devices, Boot-ROM Version B Tape and Reel in Dry Pack AS3658C-BCTP Audio Management Unit for Portable AS3658C Power and Devices, Boot-ROM Version C Tape and Reel in Dry Pack AS3658D-BCTP Audio Management Unit for Portable AS3658D Power and Devices, Boot-ROM Version D Tape and Reel in Dry Pack AS3658E-BCTP Audio Management Unit for Portable AS3658E Power and Devices, Boot-ROM Version E Tape and Reel in Dry Pack AS3658E1-BCTP AS3658E1 Power and Audio Management Unit for Portable Devices, Boot-ROM Version E1 Tape and Reel in Dry Pack Audio Management Unit for Portable AS3658F Power and Devices, Boot-ROM Version F Tape and Reel in Dry Pack am lc s on A te G nt st il AS3658F-BCTP lv AS3658B-BCTP Package BGA124 8x8mm, 0.5mm pitch BGA124 8x8mm, 0.5mm pitch BGA124 8x8mm, 0.5mm pitch BGA124 8x8mm, 0.5mm pitch BGA124 8x8mm, 0.5mm pitch BGA124 8x8mm, 0.5mm pitch al id Model Description: AS3658x-BCTP x: Boot-ROM version B: Teperature Range: Z = -40ºC to 85ºC CT: Pacakage: CTBGA Te ch ni ca P:Delivery Form: Tape and Reel in Dry Pack www.austriamicrosystems.com Revision 1v13 156 - 157 AS3658 Data Sheet Confidential - Ordering Information Copyrights Copyright © 1997-2010, austriamicrosystems AG, Schloss Premstaetten, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. al id Disclaimer am lc s on A te G nt st il lv Devices sold by austriamicrosystems AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. austriamicrosystems AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. austriamicrosystems AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with austriamicrosystems AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by austriamicrosystems AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. ca The information furnished here by austriamicrosystems AG is believed to be correct and accurate. However, austriamicrosystems AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of austriamicrosystems AG rendering of technical or other services. ni Contact Information Headquarters ch austriamicrosystems AG A-8141 Schloss Premstaetten, Austria Te Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.austriamicrosystems.com/contact www.austriamicrosystems.com B Revision 1v13 157 - 157 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: ams: AS3658-BCTP
AS3658-BCTP 价格&库存
很抱歉,暂时无法提供与“AS3658-BCTP”相匹配的价格&库存,您可以联系我们找货
