AS3710
Product Brief
H i g h C u r r e n t P o w e r M a n a g e m e n t U n i t fo r P o r ta b l e D e v i c e s
1 General Description
The AS3710 is a compact System PMU with integrated
battery charger and back light driver.
The device offers advanced power management functions. All necessary ICs and peripherals in a battery
powered mobile device are supplied by the AS3710. It
features 3 DCDC buck converters as well as 8 low noise
LDOs. The different regulated supply voltages are programmable via the serial control interface. 4MHz operation with 1uH coils are reducing cost and PCB space.
The three step-up converter generate voltages for
e.g.the backlight, classD amplifier, USB host support or
LCD display supply. Both constant voltage (for e.g.
OLED supply) as well as constant current (white LED
backlight) operations with three current sinks are possible. An internal voltage protection is limiting the output
voltage in the case of external component failures.
AS3710 contains a linear or switching mode Li-Ion battery charger with constant current and constant voltage.
The maximum charging current is 1.5A. An integrated
battery switch and an optional external switch are separating the battery during charging or whenever an external power supply is present. With this switch it is also
possible to operate with no or deeply discharged batteries. A programmable current limit can be used to control
the maximum current used from a USB supply. Additional features are a 30V OV protection and battery temperature supervision.
The single supply voltage may vary from 2.7V to 5.5V.
HV Backlight Driver
3x
step up with external transistor
voltage
3
control mode and over-voltage protection
programmable current sinks (max. 40mA)
e.g.
500mA@5V; 40mA@50V
possible
external PWM dimming input (DLS, CABC)
Battery Charger
prog.
trickle charging (25-220mA)
prog.
constant current charging (up to 1500mA)
prog.
constant voltage charging (3.9V-4.25V)
charger
time-out and temperature supervision
selectable
current limitation for USB mode
integrated
battery switch & ideal diode (linear mode)
external
battery switch control (switching mode)
external
30V OV protection
General
Supervisor
automatic
battery monitoring with interrupt generation and selectable warning level
automatic
temperature monitoring with interrupt
generation and selectable warning and shutdown
levels
Real Time Clock
2 Key Features
ultra
Power Management
selectable
Voltage Generation
3
2
DCDC step down regulators
DVM (0.6V-3.3V;1x 1.2-1.5A, 2x 0.7-1A)
50uA quiescent current
selectable switching frequency (2, 3 or 4MHz)
2A with combined DCDC 2 & 3
analog low noise LDOs, 6 digital LDOs
- 2x 1.2-3-3V, 6x 0.9-3.3V; 150-300mA
- 30uA quiescent current (low power mode)
1
ultra low power always on LDO 2.5V, 10mA
power
4sec
supply supervision
and 8sec emergency shut-down
stand-by
sec
low power 32kHz oscillator
and minute counter, auto wake-up
32kHz
很抱歉,暂时无法提供与“AS3710-BQFP”相匹配的价格&库存,您可以联系我们找货
