AS3711-BQFP
AS3711-BQFP
    AMSOSRAM(艾迈斯半导体)
    VFQFN56_EP
    IC PMU CHARGER/BKLT DVR 56-QFN
AS3711-BQFP 数据手册
AS3711 Quad Buck High Current PMIC with Charger General Description The AS3711 is a compact System PMU with integrated battery charger and back light driver. The device offers advanced power management functions. All necessary ICs and peripherals in a battery powered mobile device are supplied by the AS3711. It features 3 DCDC buck converters as well as 8 low noise LDOs. The different regulated supply voltages are programmable via the serial control interface. 4MHz operation with 1uH coils are reducing cost and PCB space. AS3711 further features a DCDC buck controller which is ideal to support processor core currents up to 3A. The two step-up converter generate voltages for e.g.the backlight, classD amplifier, USB host support or LCD display supply. Both constant voltage (for e.g. OLED supply) as well as constant current (white LED backlight) operations with three current sinks are possible. An internal voltage protection is limiting the output voltage in the case of external component failures. AS3711 contains a linear or switching mode Li-Ion battery charger with constant current and constant voltage. The maximum charging current is 1.5A. An integrated battery switch and an optional external switch are separating the battery during charging or whenever an external power supply is present. With this switch it is also possible to operate with no or deeply discharged batteries. A programmable current limit (100mA - 2.5A) can be used to control the maximum current used from a USB supply or charger input. Additional features are a 30V OV protection and battery temperature supervision. The single supply voltage may vary from 2.7V to 5.5V. Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-34] 2014-Nov-10 Page 1 Document Feedback AS3711 − General Description Key Benefits & Features The benefits and features of AS3711, Quad Buck High Current PMIC with Charger are listed below: Figure 1: Added Value Of Using AS3711 Benefits Features Compact design due to small coils for IO and memory voltage generation • 3 DCDC step down regulators (2-4MHz) - DVM (0.6V-3.3V;1×1.2-1.5A, 2×0.7-1A) - 60μA quiescent current - 2A with combined DCDC 2 & 3 High current generation for processor core • DCDC step down controller - DVM (0.6V-3.3V; 2-3A) Supply multiple independent voltage rails for general IO supplies • 2 analog low noise LDOs, 6 digital LDOs - 2×1.2-3-3V, 6×0.9-3.3V; 150-300mA - 30μA quiescent current (low power mode) • 1 ultra low power always on LDO 2.5V, 10mA Backlight boost controller for multiple display configurations or fixed voltage supplies HV Backlight Driver • 2×step up with external transistor - e.g. 0.5-1A@5V; 40mA@50V • Voltage control mode and over-voltage protection • 3 programmable current sinks (max. 40mA) • Possible external PWM dimming input (DLS, CABC) Self contained free configurable charger with stand alone supervisory functions Battery Charger • Programmable trickle charging (25-220mA) • Programmable constant current charging (up to 1500mA) • Programmable constant voltage charging (3.9V-4.25V) • Charger time-out and temperature supervision • Selectable current limitation for USB mode • Integrated battery switch & ideal diode (linear mode) • External battery switch control (switching mode) • External 30V OV protection Save supervision in HV which works also without a processor Supervisor • Automatic battery monitoring with interrupt generation and selectable warning level • Automatic temperature monitoring with interrupt generation and selectable warning and shutdown levels Very low current time keeping and alarm functions without the need of a processor Real Time Clock • Ultra low power 32kHz oscillator • Sec and minute counter, auto wake-up • Programmable alarm • Repeating alarm (seconds, minutes, 2 minutes, or 8 minutes) • 32kHz clock output to peripheral • 0 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of DCDC SD3. GPIO ctrl only enabled, if sd3_vsel > 0 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of DCDC SD2. GPIO ctrl only enabled, if sd2_vsel > 0 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of DCDC SD1. GPIO ctrl only enabled, if sd1_vsel > 0 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 96: GPIOctrl_ldo1 Register (Address 26h) Addr: 26h Bit 7:6 5:4 3:2 1:0 Bit Name gpio_ctrl_ldo4 gpio_ctrl_ldo3 gpio_ctrl_ldo2 gpio_ctrl_ldo1 ams Datasheet [v1-34] 2014-Nov-10 GPIOctrl_ldo1 Default 'b00 'b00 'b00 'b00 Access Bit Description RW Enable GPIO control of LDO4. GPIO ctrl only enabled, if ldo4_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO3. GPIO ctrl only enabled, if ldo3_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO2. GPIO ctrl only enabled, if ldo2_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO1. GPIO ctrl only enabled, if ldo1_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 Page 93 Document Feedback AS3711 − Register Over view Figure 97: GPIOctrl_ldo2 Register (Address 27h) Addr: 27h Bit 7:6 5:4 3:2 1:0 Bit Name gpio_ctrl_ldo8 gpio_ctrl_ldo7 gpio_ctrl_ldo6 gpio_ctrl_ldo5 Page 94 Document Feedback GPIOctrl_ldo2 Default 'b00 'b00 'b00 'b00 Access Bit Description RW Enable GPIO control of LDO8. GPIO ctrl only enabled, if ldo8_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO7. GPIO ctrl only enabled, if ldo7_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO6. GPIO ctrl only enabled, if ldo6_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 RW Enable GPIO control of LDO5. GPIO ctrl only enabled, if ldo5_on = 1 0 : No GPIO control 1 : Controlled by GPIO1 2 : Controlled by GPIO2 3 : Controlled by GPIO3 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 98: Reg3_Voltage Register (Address 2bh) Addr: 2bh Bit 7:0 Bit Name reg3_voltage Reg3_Voltage Default 'b0000 0000 Access Bit Description RW This register is mapped to the register address 0h+Reg3_select , if gioX_iosf=5 or 6 (Vselect input), and GPIOx input = 1, This feature allows voltage switching of a predefined regulator with just one GPIO input 0 ..FFh : Selects voltage, ilimit, on or frequency bits of LDO or DCDC Bit Description Figure 99: Reg_control3 Register (Address 2ch) Addr: 2ch Reg3_Voltage Bit Bit Name Default Access 7:4 - 'b0000 n/a Do not use 3:0 reg3_select 'b1111 RW Selects regulator for mapping feature; if reg_select3 ≥ 0Ch, then feature is disabled. ams Datasheet [v1-34] 2014-Nov-10 Page 95 Document Feedback AS3711 − Register Over view Figure 100: SD_control1 Register (Address 30h) Addr: 30h Bit 7 6 5 4 3 2 1 0 Bit Name sd4_low_noise sd3_low_noise sd2_low_noise sd1_low_noise sd4_fast sd3_fast sd2_fast sd1_fast Page 96 Document Feedback SD_control1 Default 0 0 0 0 0 0 0 0 Access Bit Description RW Enables low noise mode of SD4. If enabled, smaller current pulses and output ripple is activated. 0 : Normal mode. Minimum current pulses of >100mA applied in skip mode. 1 : Low noise mode. Only minimum on time applied in skip mode. RW Enables low noise mode of SD3. If enabled, smaller current pulses and output ripple is activated. 0 : Normal mode. Minimum current pulses of >100mA applied in skip mode. 1 : Low noise mode. Only minimum on time applied in skip mode. RW Enables low noise mode of SD2. If enabled, smaller current pulses and output ripple is activated. 0 : Normal mode. Minimum current pulses of >100mA applied in skip mode. 1 : Low noise mode. Only minimum on time applied in skip mode. RW Enables low noise mode of SD1. If enabled, smaller current pulses and output ripple is activated. 0 : Normal mode. Minimum current pulses of >100mA applied in skip mode. 1 : Low noise mode. Only minimum on time applied in skip mode. RW Selects a faster regulation mode for SD4 suitable for larger load changes. 0 : Normal mode 1 : Fast mode, double Cext required (see external components) RW Selects a faster regulation mode for SD3 suitable for larger load changes. 0 : Normal mode 1 : Fast mode, double Cext required (see external components) RW Selects a faster regulation mode for SD2 suitable for larger load changes. 0 : Normal mode 1 : Fast mode, double Cext required (see external components) RW Selects a faster regulation mode for SD1 suitable for larger load changes. 0 : Normal mode 1 : Fast mode, double Cext required (see external components) ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 101: SD_control2 Register (Address 31h) Addr: 31h Bit 7:6 Bit Name sd_dvm_select SD_control2 Default 'b00 Access Bit Description RW Apply DVM counter to the following DCDC converter: 0 : Select SD1 for DVM 1 : Select SD2 for DVM 2 : Select SD3 for DVM 3 : Select SD4 for DVM 5:4 dvm_time 'b00 RW Time steps of DVM voltage change of selected step down, if voltage of step Down is changed during operation (sdx_vsel) voltage is decreased/increased by single steps 12.5mV 0 : 0 μsec, immediate change (no DVM) 1 : 4 μsec time delay between steps 2 : 8 μsec time delay between steps 3 : 16 μsec time delay between steps 3 sd3_slave 0 RW Enables slave mode of SD3 0 : Normal mode of SD3 1 : SD3 is slave of SD2 2 sd3_fsel 0 RW Selects between high and low frequency range 0 : 2 or 3MHz frequency (selectable by sd3_frequ) 1 : 3 or 4MHz frequency (selectable by sd3_frequ) 1 sd2_fsel 0 RW Selects between high and low frequency range 0 : 2 or 3MHz frequency (selectable by sd2_frequ) 1 : 3 or 4MHz frequency (selectable by sd2_frequ) 0 sd1_fsel 0 RW Selects between high and low frequency range 0 : 2 or 3MHz frequency (selectable by sd1_frequ) 1 : 3 or 4MHz frequency (selectable by sd1_frequ) ams Datasheet [v1-34] 2014-Nov-10 Page 97 Document Feedback AS3711 − Register Over view Figure 102: Battery_voltage_monitor Register (Address 32h) Addr: 32h Battery_voltage_monitor Bit Bit Name Default Access 7 FastResEn 0 RW 0 : ResVoltFall debounce time = 3msec 1 : ResVoltFall debounce time = 49sec RW 0 : A reset is generated if VSUP falls below 2.7V ** 1 : A reset is generated if VSUP falls below ResVoltFall ** If VBAT falls below ResVoltFall only an interrupt is generated (if enabled) and the μProcessor can shut down the system) RW This value determines the reset level ResVoltFall for falling VBAT. It is recommended to set this value at least 200mV lower than ResVoltRise 0 : 2.7V 1 : 2.9V 2 : 3.1V 3 : 3.2V 4 : 3.3V 5 : 3.4V 6 : 3.5V 7 : 3.6V RO (OTP) This value determines the reset level ResVoltRise for rising VBAT. It is recommended to set this value at least 200mV higher than ResVoltFall 0 : 2.7V 1 : 2.9V 2 : 3.1V 3 : 3.2V 4 : 3.3V 5 : 3.4V 6 : 3.5V 7 : 3.6V 6 5:3 2:0 SupResEn ResVoltFall ResVoltRise Page 98 Document Feedback 0 'b000 'b000 Bit Description ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 103: Startup_Control Register (Address 33h) Addr: 33h Startup_Control Bit Bit Name Default Access 7:2 - ‘b00 0000 n/a 1 0 chg_pwr_off_en power_off_at_vsupl ow ams Datasheet [v1-34] 2014-Nov-10 0 0 RO (OTP) RW Bit Description Do not use Select charger detection in power OFF mode Read only (OTP setting) 0 : Exit of Power OFF mode, if charger is detected (level detection) 1 : Exit of Power OFF mode, if charger insertion is detected (rising edge detection) . Switch ON Power OFF mode if low VSUP is detected during active or standby mode (Pin ON= low and bit auto_off=0) 0 : If low battery is detected, battery voltage is continuously monitored and chip startup initiated if battery voltage is above ResVoltRise 1 : If low battery is detected, enter power OFF mode Page 99 Document Feedback AS3711 − Register Over view Figure 104: ResetTimer Register (Address 34h) Addr: 34h ResetTimer Bit Bit Name Default Access 7 - 'b0 n/a Do not use RW Disable Reset output signal (pin XRES) in standby mode. 0 : Normal mode, reset is active in standby mode 1 : No reset in standby mode and during exit of standy mode RO Defines startup behavior at first battery insertion 0 : Startup of chip if VBAT>ResVoltRise 1 : Enter power OFF mode (Startup with ON key or charger insertion) 6 5 stby_reset_disable auto_off 0 0 Bit Description 4:3 off_delay 'b01 RW Set Delay between I²C command, GPIO or Reset signal for power_off, standby mode or reset and execution of that command. 0 : No delay 1 : 8 msec 2 : 16 msec 3 : 32 msec 2 - 'b0 n/a Do not use RW Set RESTime, after the last regulator has started 0 : RESTIME = 10ms 1 : RESTIME = 50ms 2 : RESTIME = 100ms 3 : RESTIME = 150ms 1:0 res_timer Page 100 Document Feedback 'b00 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 105: ReferenceControl Register (Address 35h) Addr: 35h ReferenceControl Bit Bit Name Default Access 7 on_reset_delay 0 RW Sets the ON reset delay time 0 : 8 sec (if onkey_reset=1) 1 : 4 sec (if onkey_reset=1) 6 reg_low_bias_mode 0 RW Sets the ON reset delay time 0 : Normal operation 1 : Reduces the bias for the analog LDO1 and LDO2 RW Divide internal clock oscillator by 2 to reduce quiescent current for low power operation 0 : Normal mode 1 : Internal clock frequency divided by two. All timings are increased by two. Switching frequency of all DCDC converters are divided by two. Reduced transient performance of DCDC converters. RW Setting to 1 sets the PMU into standby mode. All regulators are disabled except those regulators enabled by register Reg standby mode. XRES will be pulled to low. A normal startup of all regulators will be done with any interrupt (has to be enabled before entering standby mode). During this startup, regulators defined by Reg standby mode register are continuously ON. RW Sets the internal CLK frequency fCLK used for DCDCs, PWM, ... 0 : 4 MHz (default) 1 : 3.8 MHz 2 : 3.6 MHz 3 : 3.4 MHz 4 : 3.2 MHz 5 : 3.0 MHz 6 : 2.8 MHz 7 : 2.6 MHz All frequencies, timings and delays in this datasheet are based on 4MHz clk_int RW Enable low power mode of internal reference. 0 : Standard mode 1 : Low power mode -all specification except noise parameters are still valid. Iq reduced by approx. 30μA 5 4 3:1 0 clk_div2 standby_mode_on clk_int low_power_on ams Datasheet [v1-34] 2014-Nov-10 0 0 'b000 0 Bit Description Page 101 Document Feedback AS3711 − Register Over view Figure 106: ResetControl Register (Address 36h) Addr: 36h ResetControl Bit Bit Name Default Access 7 onkey_reset 0 RW 0 : Reset after 4/8 seconds ON pressed disabled 1 : Reset after 4/8 seconds ON pressed enabled RW Flags to indicate to the software the reason for the last reset 0 : VPOR has been reached (battery or charger insertion from scratch) 1 : ResVoltFall was reached (battery voltage drop below 2.75V) 2 : Software forced by force_reset 3 : Software forced by power_off and ON was pulled high 4 : Software forced by power_off and charger was detected 5 : External triggered through the pin XRES 6 : Reset caused by overtemperature T140 7 : Reset caused by watchdog 8 : Reset caused by 4/8 seconds ON press 9 : NA 10 : Reset caused by RTC repeated wakeup or alarm wakeup 11 : Reset caused by interrupt in standby mode 12 : Reset caused by ON pulled high in standby mode 6:3 reset_reason 'b0000 Bit Description Read: This flag represents the state of the ON pad directly Write: Setting to 1 resets the 4/8 sec. onkey_reset timer 2 on_input 0 R_PUSH 1 power_off 0 RW Setting to 1 starts a reset cycle, but waits after the Reg_off state for a rising edge on the pin ON or until the charger is detected. 0 force_reset 0 RW Setting to 1 starts a complete reset cycle Page 102 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 107: OvertemperatureControl Register (Address 37h) Addr: 37h OvertemperatureControl Bit Bit Name Default Access 7:4 - 'b0000 n/a Do not use RW If the over-temperature threshold 2 has been reached, the flag ov_temp_140 is set and a reset cycle is started. ov_temp_140 should be reset by writing 1 and afterward 0 to rst_ov_temp_140. 3 rst_ov_temp_140 0 Bit Description 2 ov_temp_140 0 RO Flag that the over-temperature threshold 2 (T140) has been reached -this flag is not reset by a over-temperature caused reset and has to be reset by rst_ov_temp_140. 1 ov_temp_110 0 RO Flag that the over-temperature threshold 1 (T110) has been reached 0 temp_pmc_on 1 RO Switch ON /OFF of temperature supervision; default: ON -all other bits are only valid if set to 1. Leave at 1, do not disable Figure 108: WatchdogControl Register (Address 38h) Addr: 38h WatchdogControl Bit Bit Name Default Access 7:2 - 'b00 0000 n/a Do not use 1 wtdg_res_on 0 RW If the watchdog expires and wtdg_res_on = 1 a reset cycle will be started 0 wtdg_on 0 RW Switches ON the complete watchdog 0 : Watchdog OFF 1 : Watchdog enabled ams Datasheet [v1-34] 2014-Nov-10 Bit Description Page 103 Document Feedback AS3711 − Register Over view Figure 109: Reg_standby_mod1 Register (Address 39h) Addr: 39h Bit Bit Name Reg_standby_mod1 Default Access Bit Description 7 disable_regpd 0 RW This bit disables the pulldown of all regulators 0 : Normal operation approx. 1kΩ pulldown of all regulators 1 : Pulldown disabled >100kΩ of all regulators 6:4 - b000 n/a Do not use 3 sd4_stby_on 0 RW Enable Step down 4 in standby mode 2 sd3_stby_on 0 RW Enable Step down 3 in standby mode 1 sd2_stby_on 0 RW Enable Step down 2 in standby mode 0 sd1_stby_on 0 RW Enable Step down 1 in standby mode Figure 110: Reg_standby_mod2 Register (Address 3ah) Addr: 3ah Reg_standby_mod2 Bit Bit Name Default Access 7 ldo8_stby_on 0 RW Enable LDO8 in standby mode 6 ldo7_stby_on 0 RW Enable LDO7 in standby mode 5 ldo6_stby_on 0 RW Enable LDO6 in standby mode 4 ldo5_stby_on 0 RW Enable LDO5 in standby mode 3 ldo4_stby_on 0 RW Enable LDO4 in standby mode 2 ldo3_stby_on 0 RW Enable LDO3 in standby mode 1 ldo2_stby_on 0 RW Enable LDO2 in standby mode 0 ldo1_stby_on 0 RW Enable LDO1 in standby mode Page 104 Document Feedback Bit Description ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 111: curr_control Register (Address 40h) Addr: 40h Bit 7:4 3:2 1:0 Bit Name curr3_ctrl curr2_ctrl curr1_ctrl ams Datasheet [v1-34] 2014-Nov-10 curr_control Default 'b0000 'b00 'b00 Access Bit Description RW ON/OFF control of the pad CURR3 0 : Current sink is turned OFF 1 : Current sink is active 2 : Current sink is active and LED string connected to SU2. Required for automatic feedback selection. 3 : Controlled by internal PWM generator, or external, if gpioX_iosf=4 4 : XINT output (active low interrupt output) 5 : VSUP_low output 6 : Charger active output 7 : EOC output 8 : Inverted signal of ON pin as output 9 : Signal of ON pin as output 10: Q32k output (if rtc_on=0 then internal RC oscillator with 32kHz divider is used) 11 : PWM output 12 : PWRGOOD output 13-15 : NA RW ON/OFF control of the pad CURR2 0 : Current sink is turned OFF 1 : Current sink is active 2 : Current sink is active and LED string connected to SU2. Required for automatic feedback selection. 3 : Controlled by internal PWM generator, or external, if gpioX_iosf=4 RW ON/OFF control of the pad CURR1 0 : Current sink is turned OFF 1 : Current sink is active 2 : Current sink is active and LED string connected to SU2. Required for automatic feedback selection. 3 : Controlled by internal PWM generator, or external, if gpioX_iosf=4 Page 105 Document Feedback AS3711 − Register Over view Figure 112: pwm_control_l Register (Address 41h) Addr: 41h Bit 7:0 Bit Name pwm_l_time pwm_control_l Default 'b00000000 Access Bit Description RW This bit defines the low time of the PWM generator in 1MHz units. 0 : pwm_div * 1μsec 1 : pwm_div * 2μsec 2 : pwm_div * 3μsec ... : ... 255 : pwm_div * 256μsec Figure 113: pwm_control_h Register (Address 42h) Addr: 42h Bit 7:0 Bit Name pwm_h_time pwm_control_h Default 'b00000000 Access RW Bit Description This bit defines the high time of the PWM generator in 1MHz units. 0 : pwm_div * 1μsec 1 : pwm_div * 2μsec 2 : pwm_div * 3μsec ... : ... 255 : pwm_div * 256μsec Figure 114: curr1_value Register (Address 43h) Addr: 43h Bit 7:0 Bit Name curr1_current Page 106 Document Feedback curr1_value Default 'b00000000 Access RW Bit Description Defines the current into CURR1, if enabled by curr1_ctrl 0 : Power down (default state) 1 : 0.1563mA (LSB) ... : ... 255 : 39.84mA ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 115: curr2_value Register (Address 44h) Addr: 44h Bit 7:0 Bit Name curr2_current curr2_value Default 'b00000000 Access RW Bit Description Defines the current into CURR2, if enabled by curr2_ctrl 0 : Power down (default state) 1 : 0.1563mA (LSB) ... : ... 255 : 39.84mA Figure 116: curr3_value Register (Address 45h) Addr: 45h Bit 7:0 Bit Name curr3_current curr3_value Default 'b00000000 Access RW Bit Description Defines the current into CURR3, if enabled by curr3_ctrl 0 : Power down (default state) 1 : 0.1563mA (LSB) ... : ... 255 : 39.84mA Figure 117: Watchdog_min_timer Register (Address 46h) Addr: 46h Watchdog_min_timer Bit Bit Name Default Access 7:0 wtdg_min_timer 'b00000000 RW Bit Description Defines the minimum watchdog trigger time (LSB=7.5ms, range: 0 - 1.9s) Figure 118: Watchdog_max_timer Register (Address 47h) Addr: 47h Watchdog_max_timer Bit Bit Name Default Access 7:0 wtdg_max_timer 'b00000000 RW ams Datasheet [v1-34] 2014-Nov-10 Bit Description Defines the maximum watchdog trigger time (LSB=7.5ms, range: 7.5ms - 1.9s), do not set to (00)h Page 107 Document Feedback AS3711 − Register Over view Figure 119: WatchdogSoftwareSignal Register (Address 48h) Addr: 48h Bit Bit Name WatchdogSoftwareSignal Default Access Bit Description 7:6 pwm_div 'b00 RW This bit defines the divider ratio of the prescaler for the PWM generator. 0 : Divide by 1 1 : Divide by 2 2 : Divide by 4 3 : Divide by 16 0 wtdg_sw_sig 0 PUSH Trigger input by the serial interface if gpioX_iosf9 Figure 120: Stepup_control1 Register (Address 50h) Addr: 50h Bit 7:3 Bit Name stepup1_v Stepup_control1 Default 'b0000 Access Bit Description RW Defines the tuning current at FB_SU1 pin; 0 : 0 μA 1 : 1 μA ... : ... 31 : 31 μA 2 stepup1_res 0 RW Gain selection for DCDC SU1 0 : If FB_SU1 is used with current feedback only (Only R1,C1 connected) 1 : If FB_SU1 is used with external resistor divider (2 resistors) 1 stepup1_freq 0 RW Selects SU1 frequency 0 : 1 MHz 1 : 0.5 MHz 0 stepup1_on 0 RW ON/OFF control of SU1 0 : SU1 OFF 1 : SU1 ON Page 108 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 121: Stepup_control2 Register (Address 51h) Addr: 51h Bit 7:3 Bit Name stepup2_v Stepup_control2 Default 'b0000 Access Bit Description RW Defines the tuning current at FB_SU2 pin; 0 : 0 μA 1 : 1 μA ... : ... 31 : 31 μA 2 stepup2_res 0 RW Gain selection for DCDC SU2 0 : If DCDC is used with current feedback (CURR1,CURR2,CURR3) or if FB_SU2 is used with current feedback only (Only R1,C1 connected) 1 : If FB_SU2 is used with external resistor divider (2 resistors) 1 stepup2_freq 0 RW Selects SU3 frequency 0 : 1 MHz 1 : 0.5 MHz 0 stepup2_on 0 RW ON/OFF control of SU2 0 : SU2 OFF 1 : SU2 ON ams Datasheet [v1-34] 2014-Nov-10 Page 109 Document Feedback AS3711 − Register Over view Figure 122: Stepup_control4 Register (Address 53h) Addr: 53h Bit 7 6 Bit Name stpup1_det stpup1_oc Stepup_control4 Default 0 0 Access Bit Description RO SU1 detection status register 0 : VRsense < VDETECT for more than 1ms, and DCDC SU1 converter is in pulseskip for more than 1ms. 1 : VRsense > VDETECT for more than 1ms, or the DCDC SU1 converter is not in pulseskip for more than 1ms. RO SU1 overcurrent status bit 0 : VRsense < VOVCURRENT 1 : VRsense > VOVCURRENT for more than 5ms (latched state) 5 stpup1_oc_timeout 0 RW Controls GPIOx switch-OFF, after overcurrent timeout (5ms) for DCDC SU1 0 : Disabled 1 : Enabled 4 stpup1_shortprot 0 RW Enables Protection and Detection circuit for DCDC SU1 0 : No protection and load detection 1 : Short protection and load detection enabled RW Selects PWM operation of SU2 0 : High frequency operation PWM>20kHz** 1 : Low frequency PWM operation: stepup2_on and curr1 to 3_on (if PWM enabled) switched OFF during PWM low time ** Step_up switched ON all the time. (current sinks are not switched OFF (currX_on=1 all the time), but currX_current masked to 00h during PWM low time.). During PWM OFF-time then feedback voltage is sampled. RW DCDC SU2 overvoltage protection to prevent damage of external NFET, if CURR1, CURR2 or CURR3 feedback selected, and no LED string connected. 0 : Switch OFF DCDC SU2 if the voltage on FB_SU2 exceeds 1.25V 1 : Overvoltage protection disabled RW Controls the feedback source 0 : Voltage feedback (external resistor divider) selected by stepup2_fbprot 1 : CURR1 feedback enabled (feedback through white LEDs) 2 : CURR2 feedback enabled (feedback through white LEDs) 3 : CURR3 feedback enabled (feedback through white LEDs) 3 2 1:0 stpup2_pwm_lowf stepup2_prot_dis stepup2_fb Page 110 Document Feedback 0 0 'b00 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 123: Stepup_control5 Register (Address 54h) Addr: 54h Stepup_control5 Bit Bit Name Default Access Bit Description 7:4 - 'b0000 n/a Do not use 3 stepup2_pwm_mode 0 RW Enable PWM mode 0 : Normal operation 1 : PWM mode operation. Feedback is sampled during PWM OFF-time, if stpup2_lowf=0. 2 stepup12_clkinv 0 RW Invert input clock of SU1 and SU2 converter 0 : Use positive edge of internal clk 1 : Use negative edge of internal clk RW Controls the feedback protection of SU2 with external resistor divider (regulated to 0.8V). 0 : LX_SD4 enabled as input (If SD4 not used) 1 : GPIO2 enabled as input 2 : GPIO3 enabled as input 3 : GPIO4 enabled as input 1:0 stepup2_fbprot 'b00 Figure 124: RTCcontrol Register (Address 60h) Addr: 60h RTCcontrol Bit Bit Name Default Access Bit Description 7:5 - 'b000 n/a Do not use 4:3 rtc_irq_mode 'b00 RW 0 : Generates an interrupt every second 1 : Generates an interrupt every minute 2 : Generates an interrupt every 2 minute 3 : Generates an interrupt every 8 minute 2 rtc_on 0 RW Switch ON the 32kHz RTC oscillator 0 : 32kHz oscillator disabled 1 : 32kHz oscillator enabled 1 rtc_alarm_wakeup_en 0 RW 0 : Disables RTC alarm wake-up in power OFF mode 1 : Enable RTC alarm wake-up in power OFF mode RW 0 : Disables RTC repeated wake-up in power OFF mode 1 : Enable RTC repeated wake-up in power OFF mode 0 rtc_rep_wakeup_en ams Datasheet [v1-34] 2014-Nov-10 0 Page 111 Document Feedback AS3711 − Register Over view Figure 125: RTCSecond Register (Address 61h) Addr: 61h RTCSecond Bit Bit Name Default Access 7:0 second 00h RW Bit Description - Figure 126: RTCMinute1 Register (Address 62h) Addr: 62h RTCMinute1 Bit Bit Name Default Access 7:0 minute0 00h RW Bit Description - Figure 127: RTCMinute2 Register (Address 63h) Addr: 63h RTCMinute2 Bit Bit Name Default Access 7:0 minute1 00h RW Bit Description - Figure 128: RTCMinute3 Register (Address 64h) Addr: 64h RTCMinute3 Bit Bit Name Default Access 7:0 minute2 00h RW Bit Description - Figure 129: RTCAlarmSecond Register (Address 65h) Addr: 65h RTCAlarmSecond Bit Bit Name Default Access Bit Description 7:0 alarmsecond 3Fh RW AlarmMinute2 has to be written to latch the whole alarm register Page 112 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 130: RTCAlarmMinute Register (Address 66h) Addr: 66h RTCAlarmMinute Bit Bit Name Default Access Bit Description 7:0 alarmminute0 FFh RW AlarmMinute2 has to be written to latch the whole alarm register Figure 131: RTCAlarmMinute2 Register (Address 67h) Addr: 67h RTCAlarmMinute2 Bit Bit Name Default Access Bit Description 7:0 alarmminute1 FFh RW AlarmMinute2 has to be written to latch the whole alarm register Figure 132: RTCAlarmMinute3 Register (Address 68h) Addr: 68h RTCAlarmMinute3 Bit Bit Name Default Access 7:0 alarmminute2 FFh RW Bit Description - Figure 133: SRAM Register (Address 69h) Addr: 69h SRAM Bit Bit Name Default Access 7:0 SRAM 00h RW ams Datasheet [v1-34] 2014-Nov-10 Bit Description - Page 113 Document Feedback AS3711 − Register Over view Figure 134: ADC_control Register (Address 70h) Addr: 70h ADC_control Bit Bit Name Default Access Bit Description 7 start_conversion 0 RW Writing a 1 into this bit starts one ADC conversion 6 adc_on 0 RW Writing a 1 into this bit continuously activates the ADC S/H and the input multiplexer. The ADC and the MUX are also activated for a conversion period when start_conversion is set to 1. Useful for high impedance input sources on ADC inputs 5 adc_slow 0 RW Select ADC sampling frequency 0 : 250kHz (conversion time: approx. 60μs) 1 : 62.5kHz (conversion time:approx. 240μs) RW 0 : High voltage range of GPIO1 to 4/SENSEN_SU1 (4:1 divider active) 1 : Low voltage range of GPIO1 to 4/SENSEN_SU1 (1:1 divider, 1.8V max) RW Selects an ADC channel 0 : BATTEMP NTCADCIN (1:1) 1 : Temperature sensor: DIE temperature [ºC] = adc_result * 0.866 -274 (1:1) 2 : XOUT32K (1:1, 1.8Vmax) 3 : CURR1 (1:1, 1V max) 4 : CURR2 (1:1, 1V max) 5 : CURR3 (1:1, 1V max) 6 : VUSB(15:1, 15V max) 7 : CHGIN (4:1) 8 : VBAT (4:1) 9 : VSUP (4:1) 10 : SENSEN_SU1 (4:1 or 1:1 ) 11 : LX_SD4 (4:1 or 1:1 ) 12 : GPIO2 (4:1 or 1:1 ) 13 : GPIO3 (4:1 or 1:1 ) 14 : GPIO4 (4:1 or 1:1 ) 15 : NA 4 3:0 gpio_lv adc_select Page 114 Document Feedback 0 'b0000 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 135: ADC_MSB_result Register (Address 71h) Addr: 71h ADC_MSB_result Bit Bit Name Default Access Bit Description 7 result_not_ready 0 RO Indicates end of conversion 0 result is ready 1 conversion is running 6:0 D9_3 'b000 0000 RO ADC result register Bit9 to Bit3 Figure 136: ADC_LSB_result Register (Address 72h) Addr: 72h ADC_LSB_result Bit Bit Name Default Access 7:3 - 'b0000 0 n/a Do not use 2:0 D2_0 'b000 RO ADC result register Bit2 to Bit0 ams Datasheet [v1-34] 2014-Nov-10 Bit Description Page 115 Document Feedback AS3711 − Register Over view Figure 137: RegStatus Register (Address 73h) Addr: 73h RegStatus Bit Bit Name Default Access Bit Description 7 curr3_lv 0 RO Bit is set when voltage of current sink CURR3 drops below low voltage threshold (1ms debounce time default) 6 curr2_lv 0 RO Bit is set when voltage of current sink CURR2 drops below low voltage threshold (1ms debounce time default) 5 curr1_lv 0 RO Bit is set when voltage of current sink CURR1 drops below low voltage threshold (1ms debounce time default) 4 - 0 n/a Do not use 3 sd4_lv 0 RO Bit is set when voltage of SD4 drops below low voltage threshold (-5%) (1ms debounce time default) 2 sd3_lv 0 RO Bit is set when voltage of SD3 drops below low voltage threshold (-5%) (1ms debounce time default) 1 sd2_lv 0 RO Bit is set when voltage of SD2 drops below low voltage threshold (-5%) (1ms debounce time default) 0 sd1_lv 0 RO Bit is set when voltage of SD1 drops below low voltage threshold (-5%) (1ms debounce time default) Page 116 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 138: InterruptMask1 Register (Address 74h) Addr: 74h InterruptMask1 Bit Bit Name Default Access 7 LowBat_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 6 ovtmp_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 5 onkey_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 4 chdet_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 3 eoc_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 2 resume_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 1 nobat_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 0 trickle_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) ams Datasheet [v1-34] 2014-Nov-10 Bit Description Page 117 Document Feedback AS3711 − Register Over view Figure 139: InterruptMask2 Register (Address 75h) Addr: 75h InterruptMask2 Bit Bit Name Default Access Bit Description 7 rtc_rep_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 6 stpup1_det_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 5 stpup1_oc_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 4 bat_temp_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 3 sd4_lv_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 2 sd3_lv_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 1 sd2_lv_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 0 sd1_lv_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) Figure 140: InterruptMask3 Register (Address 76h) Addr: 76h InterruptMask3 Bit Bit Name Default Access 7:3 - 'b0000 0 n/a Do not use 2 gpio_restart_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 1 gpio_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) 0 rtc_alarm_int_m 1 RW 0 : Interrupt enabled 1 : Interrupt masked (disabled) Page 118 Document Feedback Bit Description ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 141: InterruptStatus1 Register (Address 77h) Addr: 77h InterruptStatus1 Bit Bit Name Default Access Bit Description 7 LowBat_int_i 0 POP Bit is set when VSUP drops below ResVoltFall 6 ovtmp_int_i 0 POP Bit is set when 110deg is exceeded 5 onkey_int_i 0 POP Rising and falling edge 4 chdet_int_i 0 POP Rising and falling edge 3 eoc_int_i 0 POP Rising and falling edge 2 resume_int_i 0 POP Rising and falling edge 1 nobat_int_i 0 POP Rising and falling edge 0 trickle_int_i 0 POP Rising and falling edge Figure 142: InterruptStatus2 Register (Address 78h) Addr: 78h InterruptStatus2 Bit Bit Name Default Access 7 rtc_rep_int_i 0 POP Rising edge only 6 stpup1_det_i 0 POP Rising edge only 5 stpup1_oc_i 0 POP Rising edge only 4 bat_temp_i 0 POP Rising and falling edge 3 sd4_lv_int_i 0 POP Rising edge only 2 sd3_lv_int_i 0 POP Rising edge only 1 sd2_lv_int_i 0 POP Rising edge only 0 sd1_lv_int_i 0 POP Rising edge only ams Datasheet [v1-34] 2014-Nov-10 Bit Description Page 119 Document Feedback AS3711 − Register Over view Figure 143: InterruptStatus3 Register (Address 79h) Addr: 79h InterruptStatus3 Bit Bit Name Default Access 7:3 - 'b0000 0 n/a Do not use 2 gpio_restart_int_i 0 POP Falling edge 1 gpio_int_i 0 POP Rising and falling edge 0 rtc_alarm_int_i 0 POP Rising edge only Page 120 Document Feedback Bit Description ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 144: ChargerControl1 Register (Address 80h) Addr: 80h ChargerControl1 Bit Bit Name Default Access 7 nobat_ntc_det 1 RW Enables nobat_det feature with NTC, ntc_nobat debounce time=100ms RW 0 : Charger will stay in EOC even when the battery voltage drops 1 : Charger will start charging when the battery voltage hits the resume level RW 0 : USB is supplying VSUP, but battery switch is open. USB charger regulates to Vsup_voltage 1 : Normal battery charger operation form USB charger RW Sets the USB input current limit, if not GPIO controlled 0 : 94mA (USB low current, also if gpiox_iosf=12 and gpiox=0) 1 : 141mA 2 : 189mA 3 : 237mA 4 : 285mA 5 : 332mA 6 : 380mA 7 : 428mA 8 : 470mA (USB high current, also if gpiox_iosf=12 and gpiox=1) 9 : 517mA 10 : 754A 11 : 1.29A 12 : 1.7A 13 : 2.53A 14 : 2.53A 15 : 2.53A RW ON/OFF control of USB charger input current limiter 0 : Input current limiter disabled 1 : Input current limiter enabled 6 5 4:1 0 auto_resume bat_charging_enable usb_current usb_chgEn ams Datasheet [v1-34] 2014-Nov-10 1 0 'b1000 1 Bit Description Page 121 Document Feedback AS3711 − Register Over view Figure 145: ChargerVoltageControl Register (Address 81h) Addr: 81h Bit 7:6 5:0 Bit Name vsup_min ChVoltEOC Page 122 Document Feedback ChargerVoltageControl Default 'b01 'b10 0011 Access Bit Description RW Regulate down battery charging current on that level of VSUP during trickle charging and constant current charging, to prevent voltage drop on VSUP. 0 : 3.9V 1 : 4.2V 2 : 4.50V 3 : 4.70V RW Sets the end-of-charge voltage level VCHOFF (20mV steps) 0 : 3.5V 1 : 3.52V ... : ... 35 : 4.2V ... : ... 47-63 : 4.44V ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 146: ChargerCurrentControl Register (Address 82h) Addr: 82h ChargerCurrentControl Bit Bit Name Default Access 7 eoc_current 0 RW Sets eoc_current 0 : eoc current = TrickleCurrent 1 : eoc current = TrickleCurrent / 2 RW Sets the range of the charging current limit in constant current mode. 0 : Normal mode 1 : Low current mode Current= ConstantCurrent -500mA RW Sets the charging current limit in constant current mode. 0 : 750mA 1 : 800mA 2 : 850mA 3 : 900mA 4 : 950mA 5 : 1000mA 6 : 1050mA 7 : 1100mA 8 : 1150mA 9 : 1200mA 10 : 1250mA 11 : 1300mA 12 : 1350mA 13 : 1400mA 14 : 1450mA 15 : 1500mA RW Sets the charging current limit in trickle current mode. 0 : 60mA 1 : 120mA 2 : 180mA 3 : 240mA 6 5:2 1:0 cc_lowlimit ConstantCurrent TrickleCurrent ams Datasheet [v1-34] 2014-Nov-10 1 'b0000 'b01 Bit Description Page 123 Document Feedback AS3711 − Register Over view Figure 147: ChargerConfig Register (Address 83h) Addr: 83h ChargerConfig Bit Bit Name Default Access Bit Description 7 - 0 n/a Do not use 6 Charging_1Hz_clk 0 RW Sets the mode for the charging output status (gpioX_iosf=10) 0 : Normal operation: charging=1, not charging=0 1 : 1Hz blinking operation: charging=1Hz, not charging=0 5 ChVoltResume 0 RW Sets the resume voltage level VCHRES. 0 : 120mV 1 : 240mV RW Selects temperature regulation of charging current (die temperature) 0 : 110°C 1 : 90°C 2 : 120°C 3 : 130°C RW Voltage regulation of VSUP of the input current limiter 0 : 4.4V 1 : 4.5V 2 : 4.6V 3 : 4.7V 4 : 4.8V 5 : 4.9V 6 : 5.0V 7 : 5.5V 4:3 2:0 temp_sel vsup_voltage Page 124 Document Feedback 'b00 'b101 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 148: NTCsupervision Register (Address 84h) Addr: 84h NTCsupervision Bit Bit Name Default Access 7:3 - 'b0000 0 n/a Do not use 2 ntc_temp 0 RW Select NTC mode 0 : 50deg temperature limit 1 : 45deg temperature limit 1 ntc_10k 0 RW Select NTC resistor type 0 : 100kΩ 1 : 10kΩ 0 ntc_on 0 RW ON/OFF control of battery NTC supervision 0 : Disabled 1 : Enabled ams Datasheet [v1-34] 2014-Nov-10 Bit Description Page 125 Document Feedback AS3711 − Register Over view Figure 149: Chargersupervision Register (Address 85h) Addr: 85h Chargersupervision Bit Bit Name Default Access Bit Description 7 - 0 n/a Do not use 6 ovprot_dis 0 RW Disables external overvoltage protection, function of XOFF pin 0 : Overvoltage protection enabled 1 : Overvoltage protection disabled 5 dcdc_chmode 1 RW Enables DCDC charger mode 0 : Linear charger mode enabled 1 : Step down charger enabled 4 charging_tmax 1 RW 0 : Read: no time-out reached, Write: reset charger time-out counter 1 : ch_timeout reached and charging stopped RW Sets the charger time-out timer 0 : OFF 1 : 0.5 hour 2 : 1 hour 3 : 1.5 hour 4 : 2 hour 5 : 2.5 hour 6 : 3 hour 7 : 3.5 hour 8 : 4 hour 9 : 4.5 hour 10 : 5 hour 11 : 5.5 hour 12 : 6 hour 13 : 6.5 hour 14 : 7 hour 15 : 7.5 hour 3:0 ch_timeout Page 126 Document Feedback 'b0000 ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Register Overview Figure 150: ChargerStatus1 Register (Address 86h) Addr: 86h ChargerStatus1 Bit Bit Name Default Access Bit Description 7 Nobat 0 RO Bit is set, if no battery has been detected (after EOC measured on NTC) 6 Battemp_hi 0 RO Bit is set, if high battery temperature has been detected 5 EOC 0 RO Bit is set, if End of charge state has been reached 4 CVM 0 RO Bit is set, if charger is operating in constant voltage mode 3 Trickle 0 RO Bit is set, if charger is operating in trickle current. VBAT < 2.9V 2 Resume 0 RO Bit is set, if Battery voltage is below resume level 1 CCM 0 RO Bit is set, if charger is operating in constant current mode 0 ChDet 0 RO Bit is set when external charge adapter has been detected on pin VCHARGER Figure 151: ChargerStatus2 Register (Address 87h) Addr: 87h ChargerStatus2 Bit Bit Name Default Access 7:3 - ‘b0000 0 n/a Do not use Bit indicates, that the USB input voltage protection pin XOFF is precharged to a voltage > 7.5V XOFF is pull to GND if an overvoltage on VUSB is detected. 2 usb_prot_ready 0 RO 1 batsw_on 0 RO 0 batsw_mode 0 RO ams Datasheet [v1-34] 2014-Nov-10 Bit Description Bits indicates the status of the battery switch 00 : Battery switch closed 01 : Battery switch open with ideal diode 10 : Charging mode 11 : Battery switch closed Page 127 Document Feedback AS3711 − Register Over view Figure 152: Lock Register (Address 8eh) Addr: 8eh Lock Bit Bit Name Default Access 7:3 - ‘b0000 0 n/a Do not use RW Enables lock of the following charger registers: 81h, 82h, 83h, Chargervoltagecontrol, Chargercurrentcontrol, Chargerconfig. Bits can only be set. Reset only with full reset cycle RW Enables lock of Regulator voltages Bits can only be set. Reset only with full reset cycle 0 : No lock 1 : Lock of voltage of LDOs (LDO1..8_vsel) (all bits) and voltage of StepDownBits(sd1..4_vsel) [5:6] only 2 : Lock voltage of StepDownbits 5:6 only (no LDOs) 3 : Lock voltage of StepDowns (all bits) and LDOs (all bits). Note: Setting sdx_vsel to 0 is possible all the time to allow switching OFF the regulator. Writing a non-zero value after that will restore the old value. Bit Description 2 1:0 charger_lock 0 reg_lock 'b00 Bit Description Figure 153: ASIC_ID1 Register (Address 90h) Addr: 90h ASIC_ID1 Bit Bit Name Default Access 7:0 ID1 8Bh RO - Figure 154: ASIC_ID2 Register (Address 91h) Addr: 91h ASIC_ID2 Bit Bit Name Default Access 3:0 revision 'b0001 RO Page 128 Document Feedback Bit Description For chip version 2v1 (metal fuse) ams Datasheet [v1-34] 2014-Nov-10 1 3 5 1 3 5 J5 2 4 6 BU4 GND R16 1M BU3 VBAT 2.2uF 10uF 47uF C41 C19 1 U2 5 4 3 2 I2C 2 4 6 100nF C28 Q2 VSUP BU2 C24 GND Shield BUS_GND D+ D- BUS_PWR C15 R17 10k S1 D1 1μH L3 RESET R15 10k ON BATTEMP VSUP C13 4.7uF 10uF C23 4.7uF Q1 S2 C29 1 Q5 D4 1uF R9 1k VSUP Y1 57 25 24 23 22 38 39 37 36 40 5 34 4 1 3 2 35 2.2uF VSS(exp) XRES SDA SCL ON XOUT32 XIN32 V2_5 CREF BATTEMP CHGOUT VBAT VSUP_CHG EXTBATSW CHGIN XOFF VUSB 2.2uF C9 C10 C11 2.2uF VSUP 31 56 18 AS3711 VIN_LDO123 VIN_LDO456 VIN_LDO78 CURR1 CURR2 CURR3 BU1 3 2 GPIO1 GPIO2 GPIO3 GPIO4 VSUP_GPIO D6 D7 C17 26 27 28 29 21 GPIO1 GPIO2 GPIO3 GPIO4 15 16 17 CURR1 CURR2 CURR3 32 30 33 55 54 53 20 19 LDO1 LDO2 LDO3 LDO4 LDO5 LDO6 LDO7 LDO8 VSUP_SU 45 C8 C3 C4 C5 C6 C7 C1 D8 2.2uF VSUP D9 FB_SD4 NGATE_SD4 LX_SD4 PGATE_SD4 SENSEN_SD4 GATE_SU2 SENSEN_SU2 FB_SU1 GATE_SU1 SENSEN_SU1 FB_SD1 LX_SD1 FB_SD2 LX_SD2 FB_SD3 LX_SD3 VSUP_SD1 VSUP_SD2 VSUP_SD3 46 42 43 44 41 49 51 52 48 47 12 13 9 10 8 7 14 11 6 1μH 1μH L2 L4 1 Q6 3 1μH L7 1.5μH 4 6 C35 2.2uF 33m VSUP R19 C25 10μF SD3 * SD1 10μH L6 4.7μH L5 Project Title 150m R7 VSUP 150m R4 C14 10μF Date 01/06/2011 Originator * Size A4 Title C36 33uF SD4 SD2 C20 10μF C21 2.2uF VSUP C16 2.2uF LDO1 LDO2 LDO3 LDO4 LDO5 LDO6 LDO7 LDO8 2.2uF C12 2.2uF L1 1uF 1uF 2.2uF 2.2uF 2.2uF 1uF 2.2uF C2 SENSEP 50 2 5 1 Q4 1 Q3 2.2uF C22 VSUP 3 2.2uF C31 2 3 ams Datasheet [v1-34] 2014-Nov-10 2 VUSB D3 D2 C34 SU1 C33 2.2uF SU2 C27 10uF of * Revision * 15nF Sheet * R14 100k 1M R11 1.5nF C32 C30 33nF 330k 15nF C26 R8 1M R6 AS3711 − Application Information Application Information Figure 155: AS3711 Application Schematic Page 129 Document Feedback AS3711 − Application Information Figure 156: PCB Layout Recommendation for SD1, SD2, SD3 and Switched Mode Charger Page 130 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Application Information Figure 157: PCB Layout Recommendation for SU1, SU2, SD4 ams Datasheet [v1-34] 2014-Nov-10 Page 131 Document Feedback AS3711 − Package Drawings & Mark ings Package Drawings & Markings Figure 158: Package Drawings and Dimensions QFN56 Symbol Min Nom Max A 0.80 0.90 1.00 A1 0 0.02 0.05 A2 - 0.65 1.00 A3 - 0.20REF - L 0.35 0.40 0.45 Θ 0° - 14° b 0.15 0.20 0.25 D 7.00BSC E 7.00BSC e 0.40BSC D2 4.90 5.00 5.10 E2 4.90 5.00 5.10 D1 - 6.75BSC - E1 - 6.75BSC - aaa - 0.10 - bbb - 0.07 - ccc - 0.10 - ddd - 0.05 - eee - 0.08 - fff - 0.10 - N RoHS 56 Green Note(s) and/or Footnote(s): 1. Dimensions and tolerancing confirm to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. 3. Coplanarity applies to the exposed heat slug as well the terminal. 4. Radius on the terminal is optional. 5. N is the total number of the terminal. Page 132 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 A S 3 7 1 1 − Package Drawings & Markings Figure 159: Package Drawings and Dimensions CSP64 RoHS Green Note(s) and/or Footnote(s): 1. Pin 1 = A1 2. ccc Coplanarity 3. All dimensions are in μm ams Datasheet [v1-34] 2014-Nov-10 Page 133 Document Feedback AS3711 − Package Drawings & Mark ings Figure 160: Marking YYWWIZZ AS3711 @ M2V1-xx Figure 161: Package Code YYWWIZZ YY WW I ZZ @ Year Working week assembly / packaging Plant identifier Free choice Sublot Identifier (for QFN only) Figure 162: Start-up Revision Code xx Sequence FF Engineering samples, no sequence programmed or sequence programmed on request 00 Default sequence (no sequence programmed) xx Customer specified sequence programmed during production test Page 134 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Ordering & Contact Information Ordering & Contact Information The devices shown in Figure 163 are available as standard products. Figure 163: Ordering Information Part Number Marking Sequence Description Delivery Form Package AS3711-BQFR-FF M2V1-FF Sequence programmable on request Quad Buck High Current PMIC with Charger Tape & Reel dry pack QFN56 7×7 0.4mm pitch AS3711-BQFP-00 M2V1-00 Default sequence Quad Buck High Current PMIC with Charger Tape & Reel dry pack QFN56 7×7 0.4mm pitch AS3711-BQFP-xx M2V1-xx Customer specified Quad Buck High Current PMIC with Charger Tape & Reel dry pack QFN56 7×7 0.4mm pitch AS3711-BWLT-FF M2V1-FF Sequence programmable on request Quad Buck High Current PMIC with Charger Tape & Reel WL-CSP64, 0.4mm pitch AS3711-BWLT-00 M2V1-00 Default sequence Quad Buck High Current PMIC with Charger Tape & Reel WL-CSP64, 0.4mm pitch AS3711-BWLT-xx M2V1-xx Customer specified Quad Buck High Current PMIC with Charger Tape & Reel WL-CSP64, 0.4mm pitch Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Unterpremstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-34] 2014-Nov-10 Page 135 Document Feedback AS3711 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 136 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-34] 2014-Nov-10 Page 137 Document Feedback AS3711 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 138 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Revision Information Revision Information Changes from 1.2 (2012-May) to current revision 1-34 (2014-Nov-10) Page Content of austriamicrosystems datasheet was updated to latest ams design Added CSP package information to the datasheet Added benefits and CSP package to Figure 1 2 Updated QFN blockdiagram (Figure 2) 4 Added CSP block diagram (Figure 3) 5 Added Ball Assignment CSP (Figure 5) 7 Added CSP ball info. and updated pins VINLDO78, XRES, VINLDO456 & VSSA (Figure 6) 7 Updated Figure 7 11 Added Cload_LDO3-8_L & Cload_LDO3-8_H parameters to Figure 28 29 Added Iout to Figure 29 31 Updated text under DCDC Step-Up Converter 32 Renamed VFB2 to VCURR in Figure 35 38 Updated ICURR1,2,3 in Figure 39 and text under Current Sinks 40 Updated text under Charger 41 Updated text under NTC supervision 45 Updated Figure 51 53 Renamed VXRES to VRES in Figure 52 54 Updated Figure 54 57 Updated descriptions of IO Functions 59 Updated sections Vselect Input & Stand-by and Vselect input 60 Updated Figure 62 67 Updated description of Real Time Clock 69 Replaced osc_pd=1with rtc_on=0 in GPIO1-,GPIO2-,GPIO3-, GPIO4- control registers Replaced osc_pd=1with rtc_on=0 in curr_control register Changed 0.15mA to 0.1562mA and 38.25 to 39.84 in curr1-,curr2-, curr3_value registers Updated bit 6 in Chargersupervision register ams Datasheet [v1-34] 2014-Nov-10 86 - 89 105 106 - 107 126 Page 139 Document Feedback AS3711 − Revision Information Changes from 1.2 (2012-May) to current revision 1-34 (2014-Nov-10) Page Updated ASIC_ID2 Register 128 Updated Figure 159 133 Updated Figure 160 & Figure 161 134 Updated Figure 163 135 Note(s) and/or Footnote(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. Page 140 Document Feedback ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Content Guide Content Guide 1 2 3 General Description Key Benefits & Features Applications 6 11 13 14 Pin Assignments Absolute Maximum Ratings Electrical Characteristics Typical Operation Characteristics 15 Detailed Description - Power Management Functions DCDC Step-Down Converter Description Mode Settings Low ripple, low noise operation: High efficiency operation (default setting): Low power mode operation (automatically controlled): DVM (Dynamic Voltage Management) Fast Regulation Mode Selectable Frequency Operation 100% PMOS ON Mode for Low Dropout Regulation Step-Down Converter Configuration Modes Parameter DCDC Step-Down Controller Description Parameter Analog LDO Regulators Description Parameter Digital LDO Regulators Description Parameter Low power LDO V2_5 Regulators Description Parameter DCDC Step-Up Converter Description Feedback selection SU1 Feedback Selection SU2 Current Feedback Current Feedback with Automatic Feedback Selection Voltage Feedback Calculating Resistors for Voltage Feedback or Over-Voltage Protection Output Disconnect StepUp1 Load Detection and Over-current Protection Circuit Parameter Current Sinks Description Parameter Charger Description Charging Cycle Description 15 15 16 16 16 17 18 18 18 18 18 20 23 23 24 27 27 28 29 29 29 31 31 31 32 32 34 34 34 34 34 34 35 36 38 40 40 40 41 41 42 ams Datasheet [v1-34] 2014-Nov-10 Page 141 Document Feedback AS3711 − Content Guide 42 42 42 43 43 44 44 45 Page 142 Document Feedback 45 45 46 47 48 Charge adapter detection Soft charging Low current (trickle) charging Constant current charging Constant voltage charging Charger States Stop charging conditions Battery presence indication and operation without battery Charger overvoltage protection NTC supervision Charger Modes Alternative Charger Input Configurations Parameter 52 52 53 53 53 54 54 54 54 55 56 56 56 56 56 56 57 57 58 58 58 59 59 59 59 59 60 60 60 60 60 61 61 61 61 61 61 61 61 Detailed Description - System Functions Start-up Normal Startup Startup from Charger Parameter Reset Description Parameter Reset Conditions Voltage Detection: Power OFF: Software forced reset External triggered reset: Over-temperature reset: Watchdog reset: Long ON-key press: Stand-by Description Internal References Low Power Mode Parameter GPIO Pins Description IO Functions Normal IO operation: Interrupt output: VSUP_low output GPIO interrupt input Current sink PWM input Vselect input Stand-by and Vselect input PWRGOOD output Q32k output Watchdog input SU1 OC output Charger active output EOC output 100/500mA charger input 500/2.5A charger input ams Datasheet [v1-34] 2014-Nov-10 AS3711 − Content Guide ams Datasheet [v1-34] 2014-Nov-10 61 62 62 63 63 64 64 64 65 65 66 66 67 69 69 69 70 70 70 74 Charging enable input PWM output Parameter Supervisor Description Watchdog Description Parameter Interrupt Generation Description 10-Bit ADC Input Sources Parameter Real Time Clock Description Alarm 2-Wire-Serial Control Interface Feature List Protocol Parameter 75 129 132 135 136 137 138 139 Register Overview Application Information Package Drawings & Markings Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Page 143 Document Feedback
AS3711-BQFP 价格&库存
很抱歉,暂时无法提供与“AS3711-BQFP”相匹配的价格&库存,您可以联系我们找货
