AS8650B-ZQFP-01
AS8650B-ZQFP-01
    AMSOSRAM(艾迈斯半导体)
    VFQFN36_EP
    IC AUTO CAN INTERFACE 36QFN
AS8650B-ZQFP-01 数据手册
high performance needs great design. Datasheet: AS8650B High-efficient Power Management Device with High-speed CAN Interface Please be patient while we update our brand image as austriamicrosystems and TAOS are now ams. www.ams.com AS8650B High-efficient Power Management Device with High-speed CAN Interface 1 General Description 2 Key Features DCDC converter for 5V output with very high efficiency The AS8650B is a companion IC which combines power management functions and a fully conforming high-speed CAN Transceiver in one high performance analog device for automotive applications. The AS8650B is powered by the battery, provides 4 output voltage levels of which 3 outputs in the range of 1.8V to 3.3V with a maximum current consumption up to 120mA at the LDO voltage regulator outputs. An integrated DCDC converter with a very high efficiency for the 5V output supplies the 3 voltage regulators and ensures a voltage stability of ±2.5%. The combination of DCDC converter with low-drop-out voltage regulators makes the AS8650B suitable for all Automotive Control Units where power efficiency is a must. Three voltage regulators providing 3.3V, 2.8V and 1.8V with accuracy better than 2.5% (Two are adjustable through factory settings). High-speed CAN interface (ISO 11898-5) with remote wake-up Comprehensive voltage monitoring Configurable watchdog functions for start-up, operation, and standby Automatic thermal shutdown protection Excellent EMC performance with outstanding switching The AS8650B provides a high-speed CAN interface up to 1Mbps communication rate conforming to ISO 11898-5. The AS8650B provides wake-up via remote wake-up at CAN bus lines and a local wake pin. The watchdog unit provides three different timing functions: start-up, window- and timeout watchdog; configurable via the SPI and I²C interface. technology for the DCDC converter Ambient temperature range from -40°C to +105°C in maximum load conditions Lead-free 36-pin QFN (6x6x0.9) package 3 Applications Voltage monitoring is implemented for the battery supply, DCDC output and the 3 LDO regulator outputs. Undervoltage will be signalled on the INTN pin to the microcontroller. All diagnostics and status flags can be accessed with the SPI interface. The AS8650B provides high efficient and flexible power supply together with state-of-the-art high-speed CAN Interface for automotive control units.The device is pin compatible with AS8550 (LIN interface) in order to change from CAN to LIN easy. The product is available in a 36-pin QFN (6x6x0.9) package. Figure 1. AS8650B Block Diagram VSUP AS8650B I2C_EN FB CSSPI SCLKI2C / SCLKSPI SDAI2C / SDISPI I2C SPI DC / DC Converter 5V LX SDOSPI INTN Configurable Voltage Regulator CANH SPLIT CANL RxD High-speed CAN Transceiver Digital Logic TxD RESET Configurable Voltage Regulator Configurable Voltage Regulator Watchdog WAKE www.ams.com/AS8650 Revision 1.1 V5V_LDO1 V5V_LDO2 V5V_LDO3 VREG VREG VREG GND 1 - 46 AS8650B Datasheet - C o n t e n t s Contents 1 General Description .................................................................................................................................................................. 1 2 Key Features............................................................................................................................................................................. 1 3 Applications............................................................................................................................................................................... 1 4 Pin Assignments ....................................................................................................................................................................... 4 4.1 Pin Descriptions.................................................................................................................................................................................... 4 5 Absolute Maximum Ratings ...................................................................................................................................................... 6 6 Electrical Characteristics........................................................................................................................................................... 7 6.1 Electrical System Specification............................................................................................................................................................. 8 6.2 DCDC Converter .................................................................................................................................................................................. 8 6.3 Low Drop Out Regulators ..................................................................................................................................................................... 9 6.4 CAN Transceiver ................................................................................................................................................................................ 10 6.4.1 Timing Diagrams........................................................................................................................................................................ 12 6.5 Undervoltage Detection ...................................................................................................................................................................... 13 6.6 Digital Timing Specification ................................................................................................................................................................ 13 6.6.1 System Specification and Timings............................................................................................................................................. 16 7 Detailed Description................................................................................................................................................................ 17 7.1 Operating Modes and States.............................................................................................................................................................. 7.1.1 7.1.2 7.1.3 7.1.4 Normal Mode ............................................................................................................................................................................. Receive-Only Mode ................................................................................................................................................................... Standby Mode............................................................................................................................................................................ Sleep Mode................................................................................................................................................................................ 17 17 17 17 17 7.2 Power Management Strategy ............................................................................................................................................................. 17 7.3 State Diagram..................................................................................................................................................................................... 20 7.4 Initialization Sequence........................................................................................................................................................................ 20 7.5 DCDC Converter ................................................................................................................................................................................ 22 7.6 Voltage Regulator LDO1..................................................................................................................................................................... 22 7.7 Voltage Regulator LDO2..................................................................................................................................................................... 22 7.8 Voltage Regulator LDO3..................................................................................................................................................................... 22 7.9 Over-Temperature Monitor ................................................................................................................................................................. 22 7.10 Undervoltage Reset.......................................................................................................................................................................... 22 7.11 Reset Block...................................................................................................................................................................................... 23 7.12 CAN Transceiver .............................................................................................................................................................................. 24 7.12.1 7.12.2 7.12.3 7.12.4 7.12.5 7.12.6 BUS Driver............................................................................................................................................................................... Normal Receiver ...................................................................................................................................................................... Low Power Receiver................................................................................................................................................................ Operating Modes ..................................................................................................................................................................... Local Wake-up Event............................................................................................................................................................... Remote Wake-up..................................................................................................................................................................... 7.13 Internal Flags.................................................................................................................................................................................... 7.13.1 7.13.2 7.13.3 7.13.4 7.13.5 7.13.6 VSUP_UV_flag ........................................................................................................................................................................ VSUP_POK_flag...................................................................................................................................................................... V5V_UV_flag ........................................................................................................................................................................... V5V_POK_flag......................................................................................................................................................................... VLDO2_UV_flag ...................................................................................................................................................................... VLDO2_POK_flag.................................................................................................................................................................... www.ams.com/AS8650 Revision 1.1 24 24 24 24 24 25 26 26 26 26 26 26 26 2 - 46 AS8650B Datasheet - C o n t e n t s 7.13.7 VLDO3_UV_flag ...................................................................................................................................................................... 7.13.8 VLDO3_POK_flag.................................................................................................................................................................... 7.13.9 BUS Wake_up Flag ................................................................................................................................................................. 7.13.10 Local Wake_up Flag .............................................................................................................................................................. 7.13.11 OVT_Warning Flag ................................................................................................................................................................ 7.13.12 OVT_Recover Flag ................................................................................................................................................................ 7.13.13 Bus Failure Flags................................................................................................................................................................... 7.13.14 Local Failure Flags ................................................................................................................................................................ 7.14 Watchdog (WD) ................................................................................................................................................................................ 26 26 27 27 27 27 27 27 28 7.14.1 Start-up Watchdog Behavior.................................................................................................................................................... 28 7.14.2 Window Watchdog Behavior.................................................................................................................................................... 28 7.14.3 Timeout Watchdog Behavior ................................................................................................................................................... 29 7.15 Interrupt Generation ......................................................................................................................................................................... 7.16 Status Registers ............................................................................................................................................................................... 8 Application Information ........................................................................................................................................................... 29 30 31 8.1 Serial Peripheral Interface .................................................................................................................................................................. 31 8.1.1 SPI Write Operation................................................................................................................................................................... 32 8.1.2 SPI Read Operation................................................................................................................................................................... 33 8.1.3 SPI Timing Diagram................................................................................................................................................................... 34 8.2 Inter-Integrated Circuit (I²C) Interface................................................................................................................................................. 35 8.2.1 I²C Slave Address...................................................................................................................................................................... 35 8.2.2 I²C Write Operation.................................................................................................................................................................... 35 8.2.3 I²C Read Operation.................................................................................................................................................................... 36 8.3 Register Space ................................................................................................................................................................................... 38 9 Package Drawings and Markings ........................................................................................................................................... 43 10 Ordering Information............................................................................................................................................................. 45 www.ams.com/AS8650 Revision 1.1 3 - 46 AS8650B Datasheet - P i n A s s i g n m e n t s 4 Pin Assignments LX LX FB V5V_LDO2 V5V_LDO3 V5V_LDO1 VLDO3 36 LX Figure 2. Pin Assignments (Top View) 35 34 33 32 31 30 29 28 VSUP 1 27 VLDO3FB VSUP 2 26 VLDO2 VSUP 3 25 VLDO2FB GND_DCDC 4 24 VLDO1FB GND 5 23 VLDO1 WAKE 6 22 RESERVED CANH 7 21 RESERVED CANL 8 20 RESERVED GND_CAN 9 19 RESET AS8650B QFN 6x6x0.9 13 14 15 16 17 18 SCLKI2C (SCLKSPI) CSSPI RxD INTN TxD I2C_EN 12 SDOSPI 11 SDAI2C / SDISPI 10 SPLIT GND (Exposed pad) 4.1 Pin Descriptions Table 1. Pin Descriptions Pin Pin Name 1, 2, 3 VSUP 4 GND_DCDC 5 GND 6 WAKE 7 CANH Analog Input / Output high-voltage High level CAN bus line 8 CANL Low level CAN bus line 9 GND_CAN 10 SPLIT www.ams.com/AS8650 Pin Type Description Power Supply Input Power Supply Local wake request (high-voltage input) Power Supply Input Power supply Analog Input / Output high-voltage Common-mode stabilization output Revision 1.1 4 - 46 AS8650B Datasheet - P i n A s s i g n m e n t s Table 1. Pin Descriptions Pin Pin Name Pin Type Description 11 I2C_EN Digital Input 12 SDAI2C / SDISPI Digital Input/Output / Digital Input 13 SDOSPI Digital Output 14 SCLKI2C / SCLKSPI Digital Input 15 CSSPI Digital input with pull-up SPI chip select 16 RxD Digital output with pull-up CAN Transceiver receive signal 17 INTN Digital Output 18 TxD Digital input with pull-up 19 RESET Digital Output I²C/SPI select signal (High = I²C, Low = SPI) Unidirectional for SPI, Bidirectional for I²C SPI data out Serial clock (Multiplexed for I²C and SPI) unidirectional Active low interrupt to µC. Generated if status / diagnostic is updated. CAN Transceiver transmit signal Digital Output referenced to VLDO1, active low Pin with Digital / Analog Input / Open-Drain-Output 20 Reserved Reserved 21 Analog Input / Output 22 Regulated voltage output 23 VLDO1 Power Supply Input 24 VLDO1FB Pin with Digital / Analog Input / Open-Drain-Output Regulated voltage feedback 25 VLDO2FB Pin with Digital / Analog Input / Open-Drain-Output Regulated voltage feedback 26 VLDO2 Power Supply Input 27 VLDO3FB Pin with Digital / Analog Input / Open-Drain-Output 28 VLDO3 29 V5V_LDO1 30 V5V_LDO3 31 V5V_LDO2 32 FB (DCDC) 33, 34, 35 LX (DCDC) 0 GND www.ams.com/AS8650 Regulated voltage output Regulated voltage feedback Regulated voltage output Power Supply Input Step-down converter 5V output, supply for LDO1 Step-down converter 5V output, supply for LDO3 Step-down converter 5V output, supply for LDO2 DCDC output voltage feedback Analog Input Power Supply Input DCDC output Exposed pad (GND) Revision 1.1 5 - 46 AS8650B Datasheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 7 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings 1 Parameter Min Max Units Voltage at positive supply pin (VVSUP) -0.3 40 V Voltage at pin V5V_LDO1, V5V_LDO2, V5V_LDO3, VLDO1, VLDO2, VLDO3, FB, VLDO1FB, VLDO2FB, VLDO3FB -0.3 7 V Voltage at pin CANH, CANL, SPLIT -40 +40 V Voltage at pin LX, WAKE -0.3 VVSUP + 0.3 V Voltage at pin RESET, INTN, RxD, TxD, CS, SCLK, SDO, SDA/SDI, I2C_EN -0.3 4.5 V 1 V/µs Notes Electrical Parameters Input Supply slew-rate (Vsup_slew) Input power supply ramp rate Electrostatic Discharge Electrostatic discharge voltage AEC-Q100-002 human body model standard (ESD) All pins except VSUP, GND, CANH, CANL, WAKE, SPLIT ±2 kV ±4 ±8 Latch-Up Immunity VSUP, GND, WAKE, SPLIT CANH, CANL -100 +100 mA AEC-Q100-004 1.2 W 170 ºC +150 ºC 30 ºC/W SEMI G42-88 ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/ JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). Continuous Power Dissipation Maximum power dissipation (Ptot) Temperature Ranges and Storage Conditions Junction temperature (TJ) Storage temperature (Tstg) -55 Thermal resistance MLF package (Rthj_36) Package body temperature (TBODY) Moisture Sensitivity Level 260 3 Represents a maximum floor life time of 168h 1. All voltages mentioned above are referred with respect to ground reference voltage VGND. www.ams.com/AS8650 Revision 1.1 6 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics Table 3. Electrical Characteristics Symbol Parameter Conditions Min VSUP Positive supply voltage Normal operating condition 6 GND Ground In reference to all the voltages 0 TAMB Ambient temperature Junction temperature (TJ) ≤ 150ºC (at full-load) -40 Typ Max Units 18 V Operating Conditions Isupp Supply current, Normal mode V 105 VSUP = 6V, LDOs at full load, DCDC load = 390mA, CAN dominant 425 VSUP = 18V, LDOs at full load, DCDC load = 390mA, CAN dominant, not production tested. 150 VSUP = 16V, LDOs at full load, CAN dominant 170 ºC mA CS Vt- Negative-Going Threshold Vt+ Positive-Going Threshold Ilil_cs Pull up current VOH High level output voltage VOL Low level output voltage IO Output drive current VLDO1 = 3.3V In CS pad, Pulled up to VLDO1 1.12 1.52 V 1.77 2.23 V -60 -15 µA SDO 2.5 VSUP ≥ 6V V 0.4 V 4 mA SDA / SDI 0.7* VLDO1 VIH High level input voltage VIL Low level input voltage 0.3* VLDO1 V VOL Low level output voltage 0.4 V V SCLK VIH High level input voltage VIL Low level input voltage Open-drain, external 500Ω pull-up 0.7* VLDO1 V 0.3* VLDO1 V RESET, INTN VOH High level output voltage VOL Low level output voltage IO Output drive current VIH High level input voltage VIL Low level input voltage IO Output drive current VSUP ≥ 6V Ilil Pull-up current TxD pulled up to VLDO1 with control RxD pulled up to VLDO1 2.5 VSUP ≥ 6V V 0.4 V 4 mA TxD www.ams.com/AS8650 2.0 Revision 1.1 -60 V 0.8 V 1 mA -15 µA 7 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 3. Electrical Characteristics Symbol Parameter Conditions Min Typ Max Units RxD VOH High level output voltage VOL Low level output voltage IO Output drive current VSUP ≥ 6V Ilil Pull-up current TxD pulled up to VLDO1 with control RxD pulled up to VLDO1 2.5 V 0.4 V 1 mA -15 µA Typ Max Units -60 6.1 Electrical System Specification -40°C < TJ < 150°C Table 4. Electrical System Specification Symbol Parameter Conditions Min IDDnom Current consumption Normal mode No load, VSUP = 12V, CAN recessive 3.5 6 mA IDDrecv Current consumption Receive-only mode No load, VSUP = 12V, CAN recessive 1 2 mA IDDstby Current consumption Standby mode No load, VSUP = 12V 135 270 µA IDDsleep Current consumption Sleep mode No load, VSUP = 12V 75 150 µA Min Typ Max Units 6.2 DCDC Converter -40°C < TJ < 150°C; all voltages are with respect to ground, normal operating mode, unless otherwise mentioned. Table 5. DCDC Converter Symbol Parameter Conditions VSUP Battery Voltage Range 6 12 18 V V5V Output Voltage 4.75 5 5.25 V ILXS LX current limit 0.8 1 1.25 A IV5V DCDC output current 500 mA RON LX switch on-resistance 0.8 1 Ω VFB Reference Voltage for FB 5 5.25 V For inductor 22µH and capacitor 100µF (bondwire resistance included) 4.75 Lireg_dc Line regulation Step from VIN = 6V to VIN2 = 18V, ILOAD = 100mA Lireg = 100*(VOUT1-VOUT2) / [VOUT2*(VIN1-VIN2)] Loreg_dc Load regulation ILOAD step from 90mA to 10mA VSUP = 12V Loreg = 100*(V_90mA-V_10mA) / V_90mA LX_ind Output inductor 10 22 µH V5V_cer1 Output ceramic capacitor 1 10 100 µF V5V_esr1 ESR of ceramic capacitor 1 0 0.05 Ω V5V_cer2 Output ceramic capacitor 2 100 220 nF V5V_esr2 ESR of ceramic capacitor 2 0.01 Ω 100 µF 1 Ω Csup Csup_esr www.ams.com/AS8650 Input capacitor (ceramic) X7R type For EMC suppression Revision 1.1 -0.1 +0.1 %/V -0.9 +0.9 % 22 8 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6.3 Low Drop Out Regulators -40°C < Tj < 150°C; all voltages are with respect to ground, normal operating mode, unless otherwise mentioned. The LDO block is a linear voltage regulator, which provides a regulated (band-gap stabilized) output voltage from the DCDC converter output voltage (V5V). Table 6. VLDO1 Block Specifications Symbol Parameter V5V Input Voltage Range IOUTLDO1 Output current VLDO1 Output Voltage Range ICC_SH Output Short Circuit Current Normal mode dVLDO1 Line Regulation ΔVLDO1 / ΔV5V (static) for the input range, ILOAD = 100mA LOREG_NM Load Regulation CL2 ESR2 Output Capacitor (Ceramic) CL1 Conditions Min Typ Max Units 4.75 5 5.25 V 100 mA 3.383 V 300 mA -8 8 mV/V ΔVLDO1 (for 100mA > ILOAD > 1mA), V5V = 5V -0.15 +0.15 mV/mA X7R type 2 5 µF 0.02 0.1 Ω 100 220 nF 0.01 Ω Guaranteed by design. Not production tested. 0 3.217 X7R type 3.3 ESR1 1 Table 7. VLDO2 Block Specifications Symbol Parameter V5V Input Voltage Range IOUTLDO2 Output current Guaranteed by design. Not production tested. 0 VLDO2 Output Voltage Range VOUT (typ) depends on the trim code as in OTP register mapping. Default code gives 2.8V 0.975* VOUT ICC_SH Output Short Circuit Current Normal mode dVLDO2 Line Regulation ΔVLDO2 / ΔV5V (static) for the input range, ILOAD = 100mA LOREG_NM Load Regulation CL2 ESR2 CL1 Output Capacitor (Ceramic) Conditions Min Typ Max Units 4.75 5 5.25 V 120 mA 1.025* VOUT V 300 mA -8 8 mV/V ΔVLDO2 (for 120mA > ILOAD > 1mA) -0.15 +0.15 mV/mA X7R type 2 5 µF 0.02 0.1 Ω 100 220 nF 0.01 Ω X7R type ESR1 VOUT 1. Factory setting: VOUT = 2.8V. www.ams.com/AS8650 Revision 1.1 9 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 1 Table 8. VLDO3 Block Specifications Symbol Parameter V5V Input Voltage Range IOUTLDO3 Output current Guaranteed by design. Not production tested. 0 VLDO3 Output Voltage Range VOUT (typ) depends on the trim code as in OTP register mapping. Default code gives 1.8V 0.975* VOUT ICC_SH Output Short Circuit Current Normal mode dVLDO3 Line Regulation ΔVLDO3 / ΔV5V (static) for the input range, ILOAD = 100mA LOREG_NM Load Regulation CL2 ESR2 Output Capacitor (Ceramic) CL1 Conditions Min Typ Max Units 4.75 5 5.25 V 100 mA 1.025* VOUT V 300 mA -8 8 mV/V ΔVLDO3 (for 100mA > ILOAD > 1mA) -0.15 +0.15 mV/mA X7R type 2 5 µF 0.02 0.1 Ω 100 220 nF 0.01 Ω X7R type VOUT ESR1 1. Factory setting: VOUT = 1.8V. 6.4 CAN Transceiver 6V < VSUP < 18V; -40°C < Tj < 150ºC; all voltages are with respect to ground; 4.75V < V5V_LDO1 < 5.25V; RL=60Ω. Table 9. DC Electrical Characteristics Symbol Parameter Conditions Dominant output voltage V_TxD = 0V Min Typ Max Units 3 4.25 V 0.5 1.75 V -0.1 0.15 V 45Ω < RL < 60Ω, V_TxD = 0V (dominant) 1.5 3 V No load; V_TxD = VLDO1 (recessive) -50 50 mV V_TxD = VLDO1; No bus load, Normal mode 2 3 V No bus load, Standby mode -0.1 0.1 V V_TxD = 0V, V_CANH = 0V -160 -50 mA V_TxD = 0V, V_CANL = 40V +50 +160 mA -27V < V_CAN < 40V -2.5 +2.5 mA -12V < V_CANH < 12V -12V < V_CANL < 12V Receive-only mode (CAN receiver) 0.5 0.9 V -12V < V_CANH < 12V -12V < V_CANL < 12V Standby mode (low-power receiver) 0.4 1.15 V Driver CANH_dom CANL_dom VO_dom_m Matching dominant output voltage V5V_LDO1-V_CANH-V_CANL VO_diff Differential output voltage V_CANH-V_CANL Recessive output voltage V_CANH, V_CANL VO_rec IO_short Short circuit output current IO_rec Recessive output current Receiver V_RxD_th Differential receiver threshold voltage www.ams.com/AS8650 Revision 1.1 10 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Table 9. DC Electrical Characteristics Symbol Parameter Conditions Min V_RxD_hys Differential receiver hysteresis voltage -12V < V_CANH < 12V -12V < V_CANL < 12V Receive-only mode (CAN receiver) I_RxD_LEAK Input leakage current R_IN_cm Max Units 20 130 mV V5V_LDO1 = 0V; V_CANH = V_CANL = 5V 100 250 µA Common mode input resistance Tested in Receive-only mode 15 35 kΩ R_IN_cm_m Common mode input resistance matching V_CANH = V_CANL (Tested in Receive-only mode) -3 +3 % R_IN_diff Differential input resistance Tested in Receive-only mode 25 75 kΩ VO_SPLIT Output voltage on SPLIT pin Normal mode -500µA < I_SPLIT < 500µA 0.3* V5V_LDO1 0.7* V5V_LDO1 V Standby mode 0V < V_SPLIT < 35V (Not production tested) -5 +5 µA Standby mode -22V < V_SPLIT < 0 (Not production tested) -1 +1 mA Max Units Leakage current on SPLIT pin IL_SPLIT Typ Table 10. AC Electrical Characteristics Symbol Parameter Conditions Min Typ t_TxD_BUS_on Delay TxD to bus dominant 10 110 ns t_TxD_BUS_off Delay TxD to bus recessive 10 140 ns t_BUS_on_RxD Delay bus dominant to RxD 15 115 ns t_BUS_off_RxD Delay bus recessive to RxD 20 160 ns t_TxD_RxD Propagation Delay TxD to RxD 40 255 ns Dominant time for wake-up detection via bus 0.75 5 µs WAKE UP via BUS t_BUS_WR BUS Diagnostic t_OC_CANH Time to detect over current CANH V_TxD = 0V, V_CANH = 0V (Not production tested) 60 µs t_LC_CANH Time to detect low current CANH V_TxD = 0V, V_CANH = 40V (Not production tested) 60 µs t_OC_CANL Time to detect over current CANL V_TxD = 0V, V_CANL = 40V (Not production tested) 60 µs t_LC_CANL Time to detect low current CANL V_TxD = 0V, V_CANL = 0V (Not production tested) 60 µs Table 11. Temperature Limiter Symbol Parameter Conditions Min Typ Max Units Tjshut Shut down temperature Junction temperature when IC shuts down 150 170 185 ºC Tjrecv Recovery temperature Junction temperature below which state machine returns from shutdown / warning 125 140 155 ºC Tjwarn Over-temperature warning flag set Junction temperature beyond which the warning flag is set 140 157 175 ºC www.ams.com/AS8650 Revision 1.1 11 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6.4.1 Timing Diagrams Figure 3. Timing Diagram and Hysteresis of CAN Receiver TxD CANH_dom Vo_rec CANL_dom 0.9V Vin_diff 0.5V 2.5V RxD 0.4V t_TxD_BUS_on t_TxD_BUS_off t_BUS_off_RxD t_BUS_on_RxD t_TxD_RxD V_RxD t_TxD_RxD V_RxD_hys V_RxD_th (low) www.ams.com/AS8650 V_RxD_th (high) Revision 1.1 Vin_diff 12 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6.5 Undervoltage Detection Table 12. Undervoltage Detection Symbol Parameter Conditions Min Typ Max Units VSUP_POR VSUP Power on Reset threshold on Rising edge of VSUP 5.09 5.5 5.91 V VSUP_RESET VSUP Power on Reset threshold off (Master Reset for Device) 4.49 4.85 5.21 V VSUP_POKTH VSUP undervoltage threshold off VSUP rising edge (Brown out reset threshold) 4.95 5.35 5.75 V VSUP_UVTH VSUP undervoltage threshold on (CAN bus in recessive state) VSUP falling edge (Brown out reset threshold) 4.625 5.0 5.375 V V5V_POKTH V5V undervoltage threshold off Rising edge of V5V 4.16 4.5 4.84 V V5V_UVTH V5V undervoltage threshold on Falling edge of V5V 3.8 4.1 4.4 V VLDO_POKTH LDO undervoltage threshold off (VLDO1, VLDO2 and VLDO3) Percent value is with respect to LDO output. Rising edge of LDO 87 89 91 % VLDO_UVTH LDO undervoltage threshold on (VLDO1, VLDO2 and VLDO3) Percent value is with respect to LDO output. Falling edge of LDO 78 80 82 % trr Spike filter on VLDO1 To remove disturbance 2 4 8 µs tRes Reset delay time 4 8 12 ms Min Typ Max Units 1 Mbps 6.6 Digital Timing Specification SPI Protocol. Table 13. SPI Timing Parameters Symbol Parameter Conditions General BRSPI Bit rate TSCLKH Clock high time 500 ns TSCLKL Clock low time 500 ns Write Operation Parameters tDIS Data in setup time 20 ns tDIH Data in hold time 10 ns TCSH CS hold time 40 ns Read Operation Parameters tDOD Data out delay tDOHZ Data out to high impedance delay Time for the SPI to release the SDO bus 80 ns 80 ns Timing Parameters for SCLK Polarity Identification tCPS Clock setup time (CLK polarity) Setup time of SCLK with respect to CS falling edge 20 ns tCPHD Clock hold time (CLK polarity) Hold time of SCLK with respect to CS falling edge 20 ns www.ams.com/AS8650 Revision 1.1 13 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s I²C Protocol. Electrical characteristics of SDA & SCLK bus lines for F/S mode Table 14. I²C Electrical Parameters Standard Fast Symbol Parameter VIL VLDO1related input levels VIH High level input voltage: VLDO1-related input levels 0.7V*LDO1 Vhys Hysteresis of Schmitt trigger input n/a VOL1 Low level output voltage (open drain or open collector) at 3mA sink current tof Output fall time from VIHmin to VILmax with a bus capacitance from 10pF to 400pF tSP Pulse width of spikes which must be suppressed by the input filter n/a n/a Ii Input current of each I/O pin with an input voltage between 0.1VLDO1 and 0.9VLDO1 maximum -10 10 Ci Capacitance for each I/O pin Min Max Low level input voltage: Min 0.3V*LDO1 n/a Max 0.3V*LDO1 Units V 0.7V*LDO1 V 0.05V*LDO1 V 0.4 0.4 250 20 + 0.1Cb 250 (see Footnote 2) (see Footnote 1) (see Footnote 2) 50 -10 10 (see Footnote 3) (see Footnote 3) 10 10 V ns (lab tested only) ns µA pF (guaranteed by design) 1. Cb = capacitance of one bus line in pF. 2. The maximum tf for the SDA and SCLK bus lines quoted in Table 15 (300ns) is longer than the specified maximum tof for the output stages (250ns). This allows for any series protection resistors to be connected between the SDA/SCLK pins and the SDA/SCLK bus lines without exceeding the maximum specified tf. 3. I/O pins of Fast-mode devices must not obstruct the SDA and SCLK lines if VLDO1 is switched off. www.ams.com/AS8650 Revision 1.1 14 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s Characteristics of the SDA and SCLK Bus Lines for F/S Mode I²C Bus. Table 15. I²C Timing Parameters Standard Symbol Parameter fSCLK Fast Min Max Min Max (see Footnote 1) Units SCLK clock frequency 0 100 0 400 kHz tHD_STA Hold time (repeated) START condition. After this period, the first clock pulse is generated 4 - 0.6 - µs tLOW Low period of the SCLK clock 4.7 - 1.3 - µs tHIGH High period of the SCLK clock 4.0 - 0.6 - µs tSU_STA Set-up time for a repeated START condition 4.7 - 0.6 - µs tSU_DAT Data set-up time 250 - 100 (see Footnote 2) - ns tHD_DAT Data hold-time tr Rise time of SDA and SCLK signals - 1000 20+ 0.1Cb (see Footnote 4) 300 ns tf Fall time of SDA and SCLK signals - 300 20+ 0.1Cb (see Footnote 4) 300 ns tSU_STO Set-up time for STOP condition 4.0 - 0.6 - µs tBUF Bus free time between a STOP and START condition 4.7 - 1.3 - µs Cb Capacitive load for each bus line - 400 - 400 pF VnL Noise margin at the Low level for each connected device (including hysteresis) 0.1V*LDO1 - 0.1V*LDO1 - VnH Noise margin at the High level for each connected device (including hysteresis) 0.2V*LDO1 - 0.2V*LDO1 - 0 900 0 3450 (see Footnote 5) (see Footnote 3) (see Footnote 5) (see Footnote 3) ns 1. All values referred to VIHmin and VIlmax levels (see Table 14). 2. A fast mode I²C bus device can be used in Standard mode I²C bus system, but the requirement tSU_DAT ≥ 250ns must then be met. This will automatically be the case if the device do not stretch the low period of the SCLK signal. If such a device does stretch the low period of the SCLK signal, it must output the next data bit to the SDA line trmax. TSU_DAT = 1000 + 250 = 1250ns (according to standard mode I²C bus specification) before the SCLK line released. 3. The maximum tHD;DAT has only to be met if the device does not stretch the low period (tLOW) of the SCLK signal. 4. Cb = total capacitance of one bus line in pF. If mixed with Hs-mode devices, faster fall-times according to Table 14 allowed. 5. This device internally provides a hold time of at least 300ns for the SDA signal to bridge the undefined region of the falling edge of the SCLK. www.ams.com/AS8650 Revision 1.1 15 - 46 AS8650B Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6.6.1 System Specification and Timings Table 16. System Timing Parameters Symbol Parameter Conditions Min Typ Max Units 70 ms 10 ms 50 ms Mode Transition Related Timing TPOST Power-up to Standby mode TSTNO Standby to Normal mode TSLST Sleep to Standby mode Reset time included, Start-up watchdog not included Reset time included Wake-up Timing Tdom(wake) Minimum dominant pulse for CAN wake-up detection (remote wake) 5 µs Trec(wake) Minimum recessive pulse for CAN wake-up detection (remote wake) 5 µs TL_wake Time between edge on WAKE pin to local wake detection TLW_filter Time between edge on WAKE pin to WAKE_LOCAL signal (Filter on WAKE pin) TR_wake Remote wake detection time from the valid pattern detection TINTN INTN pin high time 7 V_LWUTH Local WAKE threshold input 2 32 0.75 µs 5 24 µs µs µs 4 V Local Failure Related Timing TTxDC(dom) TxD dominant timeout period 600 1000 1400 µs TBUSC(dom) BUS dominant clamping timeout period 600 1000 1400 µs Watchdog Timing & Timeouts TWD(init) Start-up Watchdog timeout (initialization time) Twd_trig Window watchdog Trigger window www.ams.com/AS8650 300 Twwd_period is defined in WWD register Revision 1.1 0.375 0.5 ms 0.625 Twwd_period 16 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7 Detailed Description The AS8650B consists of the following components on chip: DCDC converter with 5V outputs that supplies the three LDO voltage regulators and the CAN Transceiver Three voltage regulators with output voltages 3.3V, 2.8V and 1.8V and output accuracy up to 2.5% High-speed CAN bus Transceiver according to ISO 11898-5 Integrated RESET unit with a power-on-reset delay and a programmable watchdog time 7.1 Operating Modes and States The AS8650B provides four main operating modes Normal, Receive-only, Standby, and Sleep. In Normal mode, the CAN Transceiver can be disabled in case of over-temperature condition. The detailed transition table for each mode is shown in the subsequent pages. 7.1.1 Normal Mode In Normal mode DCDC converter, the three voltage regulators, BUS Transceiver, and Window Watchdog are turned on with full functionality. All the LDO regulators are capable of delivering maximum load current possible as per their respective ratings. The BUS Transceiver is capable of sending the TxD data from the microcontroller to the CANH at the maximum rate. 7.1.2 Receive-Only Mode In this mode, the CAN transmitter is disabled. The CAN receiver, the three voltage regulators, and over-temperature monitor circuit are enabled. 7.1.3 Standby Mode This is the mode after power up. The Standby mode is a functional low-power mode where the CAN Transceiver is disabled. The bus wake-up (low power receiver) circuit, LDO1, and over-temperature monitor circuit are enabled. Both LDO2 and LDO3 can be enabled or disabled (default state) using the host command. The AS8650B can enter Normal mode, Sleep mode or Receive-only mode through host command. 7.1.4 Sleep Mode Sleep mode is the current saving mode that is entered by host command or by over-temperature condition. The DCDC converter, the three voltage regulators, CAN Transceiver, the reset, and window watchdog unit are all switched off. The bus wake-up (low power receiver) circuit, oscillator, and over-temperature monitor circuit are active. The bus is in recessive state (high). The only wake-up possible is through remote wake-up (through the bus lines) or local wake up (through the WAKE pin) as described in the WAKE specification. In the case of entering Sleep mode due to over-temperature condition (T > Tjshut), the device can come out of Sleep only after the temperature falls back below the return temperature Tjrecv and any one of the wake up events mentioned above. 7.2 Power Management Strategy The detailed block diagram and the power management strategy are shown in Figure 4. Internal Regulator. This module is powered externally by the VSUP. All the critical modules that needs to be kept always on, work on this supply. Some of the important modules among them are Over-temperature monitor, Local Wake block, Internal Power-on Reset module, Internal Oscillator, complete mode-control unit, Undervoltage comparators of three external LDOs. DCDC Converter. This is the main supply regulator for all the internal blocks. A step-down hysteretic buck converter is used to generate 5V output from VSUP. This 5V output is then used to generate all the three LDOs. This high-efficiency step-down DCDC converter contains the following features: Current limited operation Thermal shutdown LDO1. This is the main I/O supply. This is generated internally from the 5V DCDC converter output and gives a regulated 3.3V output to powerup the external micro-controller. All the I/Os that interface with the microcontroller work on this supply. LDO2. This regulator is generated internally from the 5V DCDC converter output and gives a regulated 2.8V output. The voltage level can be changed through factory settings. LDO3. This regulator is generated internally from the 5V DCDC converter output and gives a regulated 1.8V output. The voltage level can be changed through factory settings. www.ams.com/AS8650 Revision 1.1 17 - 46 18 - 46 Figure 4. Power Management Strategy VSUP GND WAKE CANH SPLIT CANL Local WAKE CAN Transceiver LX ldo1_uvb otm_160 otm_170 otm_en ldo2_en loc_wake tx_en tx rx_en rx flags ldo1_en ldo2_uvb ldo3_en Mode Control / Reset Generation ldo3_uvb Datasheet - D e t a i l e d D e s c r i p t i o n AS8650B Level Shifter Definer Window WatchDog Digital Interface V5V LDO1 (100mA) VLDO1 UV Comp LDO2 (120mA) Revision 1.1 OTM FB DCDC Converter 5V VLDO2 UV Comp LDO3 (100mA) VLDO3 UV Comp OTP Level Shifter Level Shifter Definer Level Shifter RESET INTN TxD RxD Definer Definer Definer Level Shifter Definer CSSPI SCLKI2C / SCLKSPI SDAI2C / SDISPI SDOSPI I2C_EN LDO1 Pre-reg DCDC 5V www.ams.com/AS8650 Osc start done Pre-Reg 3.3V & 5.0V por clk osc_en POR AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n Table 17. Power Management Strategy for AS8650B Control States Analog Blocks Power-up Normal Rx Only Standby Sleep DCDC Converter ON ON ON ON OFF Oscillator ON ON ON ON ON Internal Regulator ON ON ON ON ON OTM ON ON ON ON ON LDO1 ON ON ON ON 2 LDO2 OFF ON LDO3 OFF ON CAN Tx OFF ON CAN Rx OFF Low Power Rx OFF LOCAL WAKE 2 ON 2 ON 2 1 OFF OFF 1 OFF OFF 1 OFF OFF OFF OFF ON ON OFF OFF OFF OFF ON ON OFF OFF OFF ON ON OFF ON ON ON ON WWD OFF ON ON ON OFF Digital Interface OFF ON ON ON OFF SPLIT Generation Digital Blocks 1. Can be turned ON using Device Configuration Register 2. Can be turned OFF using Device Configuration Register www.ams.com/AS8650 Revision 1.1 19 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7.3 State Diagram Figure 5. State Machine Model VSUP_UV_flag = 1 OR V5V_UV_flag =1 → BUS transceiver disabled VSUP_UV_flag =1 OR → V5V_UV_flag= 1 BUS transceiver disabled Host command (go to ReceiveOnly) Normal Receive Only (go to No rm al) Ho st st c Ho om nd ma (g co mm an d ep) Sle o to (g ot oS tan db y) Sleep Standby → BUS wake VLD BUS Wake OR Local Wake =0 O1 PO R t ime O out atc R hdo g tim eou t Power-up Power Off Normal OR Receive_only OR Standby state T= star tup w ESE T == 1 R es & et tim e ou t From any state Host command (go to Sleep) VLD O1_ R TEMP > Tjshut disabled Host command (go to Standby) Host command (go to Sleep) co mm an d T SE RE R_ O _P UP VS == VL DO 1_ RE SE Ho st → TEMP>Tjwarn BUS transmitter disabled BUS transmitter will be enabled on TEMP < Tjrecv Host command (go to ReceiveOnly) Host command (go to Normal) 0 7.4 Initialization Sequence The DCDC converter is switched ‘ON’. Subsequently, on receiving power-good (PG) signal from the DCDC converter, the LDO1 regulator is switched ‘ON’. During the initialization sequence, the VLDO1 is set to 2.5V if VLDO1 > VLDO1_POKTH threshold. VLDO1_RESET is released to ‘high’. Then, active-low PORN_2_OTP is generated. Initially the rising edge of PORN_2_OTP loads contents into the OTP latch. Next the LOAD_OTP_IN_PREREG signal loads the content of OTP latch into the pre-regulator domain register. Once the VLDO1_POKTH threshold is reached, the reset timeout timer also starts. The RESET signal expires after Reset timeout period TRes. After the RESET signal is ‘high’, the startup watchdog is launched. If the microcontroller generates a trigger within the startup window, then the device enters into Standby mode. If the microcontroller fails to generate the trigger, then the RESET signal is generated and the Reset timeout will start. If the microcontroller fails to generate the startup watchdog trigger for 3 consecutive times, then the device enters into Sleep mode. On receiving Normal mode command from the microcontroller, the LDO2 and LDO3 regulators are activated. By the time VLDO2 and VLDO3 reach their respective power-ok (POK) threshold values, an interrupt signal is generated. The AS8650B supports very slow VSUP ramp up of 0.5V/min. www.ams.com/AS8650 Revision 1.1 20 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n The power initialization sequence diagram is shown in Figure 6. After activating the power supply on VSUP pin, the VSUP_POR_RESET flag becomes inactive (high) while the voltage exceeds the VSUP_POR threshold. The DCDC output voltage V5V exceeds the V5V_POKTH thresholds after the DCDC settling time and the first voltage regulator (LDO1) will be activated with the V5V_POK set. If the voltage output at LDO1 (set to 2.5V on power-up) reaches the VLDO1_POKTH threshold, the PORN_2_OTP flag is set and OTP register setting for the LDO1 is read. Consequently the output voltage will be regulated to the actual OTP settings. The initialization phase of the device is terminated after the preset output voltage level threshold is exceeded and the reset timeout is expired. After entering Standby mode the host controller can switch the device in any operation mode through the I²C or SPI interface. Figure 6. Initialization Sequence VSUP_POR Tpost = Power-up to Standby mode time VSUP VSUP_POR_RESET V5V_POKTH V5V V5V_POK VLDO1_POKTH VLDO1 VLDO1_POKTH VLDO1_RESET PORN_2_OTP 6 Cycles of RC- Oscillator LOAD_OTP_IN_ PREREG RESET Tres = Reset Timeout DEVICE STATE INITIALIZATION Start-up watchdog disabled by default STARTUP WATCHDOG STANDBY MODE NORMAL MODE VLDO2_POKTH VLDO2 VLDO3_POKTH VLDO3 INTN Host Command Tstno = Standby to Normal mode time www.ams.com/AS8650 Revision 1.1 21 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7.5 DCDC Converter The high-efficiency, high-voltage, hysteretic step-down DCDC converter, operates in asynchronous mode and delivers 500mA of output load to drive the three internal LDOs and the CAN Transceiver. The low-power architecture extends hold-up time in battery-backed and critical applications where maximum up-time over a wide input supply voltage range is needed, while still providing for high efficiencies of up to 90% during peak current demands. 7.6 Voltage Regulator LDO1 The stability of the voltage output is below ±2.5% over the full input range and temperature for load current up to 100mA at 3.3V. Power Input to this LDO is the V5V_LDO1 pin. This LDO is activated in Normal, Receive-only or Standby mode. It is switched OFF in Sleep mode. 7.7 Voltage Regulator LDO2 The stability of the voltage output is below ±2.5% over input range and temperature for load current up to 120mA at 2.8V. Power Input to this LDO is the V5V_LDO2 pin. LDO2 is activated in Normal and Receive-only mode. The output voltage level can be changed through factory settings. For further information, please contact ams regional sales person. 7.8 Voltage Regulator LDO3 The stability of the voltage output is below ±2.5% over input range and temperature for load current up to 100mA at 1.8V. Power Input to this LDO is the V5V_LDO3 pin. LDO3 is activated in Normal and Receive-only mode. The output voltage level can be changed through factory settings. For further information, please contact ams regional sales person. 7.9 Over-Temperature Monitor In Normal mode, if the junction temperature reaches the over-temperature threshold Tjwarn, a warning flag is set in the diagnostic register which can be accessed via the I²C and the SPI interface and an interrupt is signalled on INTN pin. The CAN transmitter is disabled and the device remains in Normal mode. If the junction temperature falls below Tjrecv, the CAN transmitter is enabled. The warning flag is cleared in the diagnostic register and an interrupt is signalled at the INTN pin. If the junction temperature exceeds the over-temperature threshold Tjshut, the device enters Sleep mode irrespective of the current mode and bus wake receiver (Low power receiver) is disabled. As soon as the temperature falls below Tjrecv (thermal recovery), the device goes through the power-up sequencing while entering Power-up mode and enters Standby mode if the boundary conditions of the statemachine are fulfilled. 7.10 Undervoltage Reset Undervoltage on VSUP (Brown out Indication). If VSUP voltage falls below VSUP_UVTH threshold, the VSUP_UV_flag is set and an interrupt at INTN is generated. In this case the device enters into the Standby mode. The LDO1 voltage regulator remains activated. Two scenarios are possible at this stage: VSUP is recovering: If VSUP exceeds the VSUP_POKTH threshold, the VSUP_POK_flag is set and the device remains in Standby mode. VSUP is still falling: In this case the device continues to stay in Standby mode. If voltage falls below VSUP_RESET threshold, then the device enters Power-Off and the logic is reset. Undervoltage on V5V. If the V5V falls below V5V_UVTH threshold, the V5V_UV_flag is set. Once V5V returns to V5V_POKTH threshold value, V5V_POK_flag is set. In case a flag is set, an interrupt is generated at the INTN pin. If undervoltage on V5V occurs in Normal or Receiveonly modes then CAN Transceiver is disabled and the device remains in its operation mode. Undervoltage on LDO1. If the voltage level of LDO1 falls below the VLDO1_UVTH threshold value and device is not in Sleep mode, the device enters into power-up state while RESET signal is asserted and the voltage regulator is still active. Once the VLDO1_POKTH threshold is reached, RESET signal is de-asserted after reset timeout period and device enters into Standby mode. Undervoltage on LDO2. If the voltage level of the LDO2 falls below the VLDO2_UVTH threshold value a VLDO2_UV_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. Once VLDO2 returns to VLDO2_POKTH threshold value, VLDO2_POK_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. Undervoltage on LDO3. If the voltage level of the LDO3 falls below the VLDO3_UVTH threshold value a VLDO3_UV_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. Once VLDO3 returns to VLDO3_POKTH threshold value, VLDO3_POK_flag is set. An indication is given to microcontroller by setting a bit in interrupt register and giving interrupt on INTN pin. www.ams.com/AS8650 Revision 1.1 22 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n Figure 7. Power-up and Undervoltage Sequence VLDO2_POKTH VSUP_POR VLDO2_UVTH VSUP_POKTH VSUP_RESET VSUP_UVTH VSUP VLDO2 VSUP_POR_RESET VSUP recovering VSUP_UV_flag VLDO2_POK_flag VSUP still falling VSUP recovering VSUP still falling VSUP_POK_flag VSUP Supply V5V_POKTH VLDO2_UV_flag LDO2 Supply VLDO3_POKTH V5V_UVTH V5V VLDO3_UVTH VLDO3 V5V_POK_flag VLDO3_POK_flag V5V_UV_flag VLDO3_UV_flag DCDC Supply LDO3 Supply VLDO1_POKTH VLDO1_UVTH VLDO1 VLDO1_RESET LDO1 Supply 7.11 Reset Block The reset block generates an external RESET signal to reset the microcontroller and all other external circuits. The reset functionality is explained in Figure 8. The reset block consists of a digital buffer at the output. The RESET signal is affected by VLDO1_RESET (during overload, reset on VLDO1) and watch dog output. All conditions which cause a drop of the VLDO1 voltage will be detected from the low voltage reset unit which in-turn generates a reset signal. Figure 8. Reset Block Functional Waveform VVSUP_UV VSUP T>Tjshut TTrec(wake) >Tdom(wake) WAKE_remote_flag >Trec(wake) Remote wake detected 7.13 Internal Flags The AS8650B supports internal flags to indicate the failures in the system. If any of these flag is set an interrupt is generated on INTN pin. 7.13.1 VSUP_UV_flag This is a VSUP undervoltage flag. This flag is set when VSUP falls below the VSUP_UVTH threshold. When this flag is set the device enters into Standby mode and BUS Transceiver is switched off to save power. When VSUP recovers and raises above VSUP_POKTH threshold the VSUP_UV_flag is reset. 7.13.2 VSUP_POK_flag This is a VSUP power ok flag. This indicates the VSUP recovery from undervoltage condition. When the VSUP rises above VSUP_POKTH threshold, this flag is set. This indicates the microcontroller that undervoltage condition on battery is cleared. 7.13.3 V5V_UV_flag This is a V5V undervoltage flag. This flag is set when V5V falls below the V5V_UVTH threshold. When this flag is set the device enters into Standby mode and BUS Transceiver is switched off to save power. When V5V recovers and raises above V5V_POKTH threshold the V5V_UV_flag is reset. 7.13.4 V5V_POK_flag This is a V5V power ok flag. This indicates the V5V recovery from undervoltage condition. When the V5V rises above V5V_POKTH threshold, this flag is set. This indicates the microcontroller that undervoltage condition on DCDC converter is cleared. 7.13.5 VLDO2_UV_flag This is a VLDO2 undervoltage flag. This flag is set when VLDO2 falls below the VLDO2_UVTH threshold. When VLDO2 recovers and raises above VLDO2_POKTH threshold the VLDO2_UV_flag is reset. 7.13.6 VLDO2_POK_flag This is a VLDO2 power ok flag. This indicates the VLDO2 recovery from undervoltage condition. When the VLDO2 rises above VLDO2_POKTH threshold this flag is set. This indicates the microcontroller that undervoltage condition on LDO2 is cleared. 7.13.7 VLDO3_UV_flag This is a VLDO3 undervoltage flag. This flag is set when VLDO3 falls below the VLDO3_UVTH threshold. When VLDO3 recovers and raises above VLDO3_POKTH threshold the VLDO3_UV_flag is reset. 7.13.8 VLDO3_POK_flag This is a VLDO3 power ok flag. This indicates the VLDO3 recovery from undervoltage condition. When the VLDO3 rises above VLDO3_POKTH threshold this flag is set. This indicates the microcontroller that undervoltage condition on LDO3 is cleared. www.ams.com/AS8650 Revision 1.1 26 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7.13.9 BUS Wake_up Flag The BUS Wake_up flag is set when the device detects a remote wake-up (BUS message) request. The remote wake-up request is detected when pattern shown in Figure 11 is found on wake_remote port of low power receiver. This indicates the microcontroller about the Bus wake event. 7.13.10 Local Wake_up Flag The Local Wake_up flag is set when the device detects a local wake-up request on WAKE pin. A local wake-up request is detected when a logic state change on pin WAKE as shown in Figure 9. This indicates the microcontroller about the local wake event. 7.13.11 OVT_Warning Flag The OVT_Warning flag is set when temperature exceeds Tjwarn. This indicates the microcontroller about temperature exceeding warning levels. 7.13.12 OVT_Recover Flag The OVT_Recover flag is set when temperature falls back below Tjrecv. This indicates the microcontroller about temperature falling back below recovery levels. 7.13.13 Bus Failure Flags The bus failure flag is set if the CAN Transceiver detects a bus line short-circuit condition to VSUP, V5V_LDO1 or GND. Such possible conditions are indicated to microcontroller through these flags. All these flags are cleared on microcontroller read. If the fault condition still exist after microcontroller read, the particular flag is set again. The device still be working in the current state. The microcontroller takes appropriate action on reading of these flags. CANH_short_GND. This flag indicates Over Current condition on pin CANH. For example short to ground on pin CANH. When the output current on pin CANH exceeds the threshold OC_CANH_th then the output OC_CANH switches on high level after a filter time t_OC_CANH. CANH_short_VSUP. This flag indicates Low Current on pin CANH. For example open load or short to VSUP on pin CANH. When the output current on pin CANH falls below the threshold LC_CANH_th then the output LC_CANH switches on high level after a filter time t_LC_CANH. CANL_short_VSUP. This flag indicates Over Current on pin CANL. For example short to VSUP on pin CANL. When the output current on pin CANL exceeds the threshold OC_CANL_th, then the output OC_CANL switches on high level after a filter time t_OC_CANL. CANL_short_GND. This flag indicates Low Current on pin CANL. For example open load or short to ground on pin CANL. When the output current on pin CANL falls the threshold LC_CANL_th then the output LC_CANL switches on high level after a filter time t_LC_CANL. 7.13.14 Local Failure Flags The AS8650B prevents the system from four kinds of local failures without disturbing the BUS network. The four failures are TxD dominant clamping, RxD recessive clamping, TxD & RxD short, and bus dominant clamping. All these failures are indicated to microcontroller through flags. TxD_Dom_Clamp flag. A permanent Low-level on pin TxD (due to a hardware or software application failure) would drive the BUS into a permanent dominant state, blocking BUS network communication. If pin TxD remains at a Low level for longer than the TxD dominant timeout period TTxDC(dom), the device disables the transmitter of BUS Transceiver and TxD_Dom_Clamp flag is set. The device prevents such BUS network lock-up by disabling the transmitter of the transceiver. The device will not change the functional state. The transmitter remains disabled until the local failure persists. The flag is cleared with microcontroller read request. TxD_RxD_Short flag. The TxD_RxD short circuit would result in a dead-lock situation clamping the bus dominant. For example the Transceiver receives a dominant signal, RxD outputs a dominant level. Because of the short circuit, TxD reflects a dominant signal, retaining the dominant bus state. As a result TxD and the bus are clamped continuously dominant. The resulting effect is the same as for the continuously clamped dominant TxD signal. The TxD dominant timeout interrupts the deadlock situation by disabling the transmitter and the TxD_RxD short condition is differentiated. The bus becomes recessive again and TxD will be recessive if it is not driven by microcontroller. However, the failure scenario may still exist and with the next dominant signal on the bus the described procedure will start again. The device keeps the transmitter off after detection of TxD_RxD short fault and keeps updating this flag status. The microcontroller has to send 2 consecutive low pulses of duration 500ns with high period of 500ns in-between, in regular intervals to check short circuit recovery. This way a local TxD/RxD short circuit will not disturb the communication of the remaining bus system. BUS_Dom_Clamp flag. In the case of a short circuit from BUS to GND, the circuit for the BUS receiver senses dominant signal continuously even if there is no dominant transmitting node. The result may be a permanently dominant clamped bus. The device detects and reports a Bus Dominant Clamping situation to microcontroller through BUS_Dom_Clamp flag. If the receiver detects a bus dominant phase of longer than the bus dominant time out TBUSC(dom) BUS_Dom_Clamp flag is set. The flag is cleared on microcontroller read. www.ams.com/AS8650 Revision 1.1 27 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7.14 Watchdog (WD) The WD has the following three monitory timing functions: Start-up watchdog: Gives opportunity to microcontroller to initialize the system. Window watchdog: Detects too early or too late microcontroller software response (loops and hangs). Timeout watchdog: Detects too very long response from microcontroller. 7.14.1 Start-up Watchdog Behavior Following any reset event the watchdog is used to monitor the ECU start-up procedure. Once the reset is released the watchdog counter will start. In case the watchdog is not properly served (a trigger from microcontroller) within TWD(init), another reset is forced on RESET pin and the monitoring procedure is restarted. The watchdog will give three opportunities to microcontroller to initialize the system. In case the watchdog is not properly served for three times, then the system enters into Sleep mode. 7.14.2 Window Watchdog Behavior Whenever the device enters Normal mode, the Window mode of the watchdog is activated. This ensures that the microcontroller operates within the required speed; a too fast as well as a too slow operation will be detected. Watchdog triggering using the Window watchdog is illustrated in Figure 12. Figure 12. Window Watchdog Triggering Twwd_period Twd_no_trig Twd_trig NON-TRIGGER WINDOW TRIGGER WINDOW Trigger restarts period SPI TRIGGER Last Trigger Point 50% 100% Latest Trigger Point Earliest Trigger Point Trigger restarts period ( with new period if desired) New Period NON-TRIGGER WINDOW TRIGGER WINDOW 50% SPI TRIGGER Unwanted Trigger (RESET generated, watchdog enter Start-up mode) Earliest Trigger Point 100% Latest Trigger Point The AS8650B provides 8 different period timings. This timing can be changed through digital interface when desired. The period can be changed within any valid trigger window. Whenever the watchdog is triggered within the window time Twd_trig, the timer will be reset to start a new period. The watchdog window is defined to be between 50% and 100% of the nominal programmed watchdog period. Any too early (trigger in nontrigger window) or too late watchdog trigger will result an immediate system reset on RESET pin and watchdog entering Start-up watchdog mode. During undervoltage condition on VLDO1 the watchdog timer is disabled. www.ams.com/AS8650 Revision 1.1 28 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n 7.14.3 Timeout Watchdog Behavior Whenever the AS8650B operates in Standby mode, active watchdog operates in Timeout watchdog mode. The watchdog has to be triggered within the actual programmed period time Twd_tout_period. The device provides 8 different possible periods for programming through digital interface. If the microcontroller fails to trigger the watchdog within trigger range then the system reset is generated on RESET pin and watchdog enters into Start-up watchdog mode. The timeout watchdog function is illustrated in Figure 13. Figure 13. Timeout Watchdog Triggering Twwd_period Twd_no_trig Twd_trig NON-TRIGGER WINDOW TRIGGER WINDOW Trigger restarts period SPI TRIGGER Last Trigger Point 50% 100% Latest Trigger Point Earliest Trigger Point Trigger restarts period ( with new period if desired) New Period NON-TRIGGER WINDOW TRIGGER WINDOW 50% SPI TRIGGER Unwanted Trigger (RESET generated, watchdog enter Start-up mode) Earliest Trigger Point 100% Latest Trigger Point 7.15 Interrupt Generation The pin INTN is an interrupt output. The INTN is forced ‘low’ if one bit in the Interrupt register is set. The Interrupt register bits are cleared when the microcontroller clears the corresponding interrupt source register. The Interrupt register will also be cleared during a system reset (RESET LOW). As there are microcontrollers with level sensitive or edge sensitive interrupt port, pin INTN will be ‘high’ for at least TINTN after any of the interrupt source register is cleared. The Interrupt source register is cleared through write operation by overwriting ‘1’ in to respective set bits position. Without further interrupts within TINTN pin INTN stays ‘high’, otherwise it will revert to ‘low’ again. The Interrupt register indicates the cause of an interrupt event. There are two levels of interrupt registers. First level register indicates the source region of interrupt and the second level register indicates the exact source of interrupt. With this structured interrupt, the microcontroller can trace source of interrupt by two read operations instead of polling for source of interrupt and also interrupts can be prioritized by microcontroller. The interrupt register structure is given in Figure 14. The register is cleared through digital interface write operation and upon any reset event. The hardware ensures no interrupt event is lost in case there is a new interrupt forced while reading the register. www.ams.com/AS8650 Revision 1.1 29 - 46 AS8650B Datasheet - D e t a i l e d D e s c r i p t i o n Figure 14. Interrupt Register Structure D6 D5 R R R I3 I2 I1 D4 D3 CANH_Short_VCC Reserved D7 CANL_Short_VCC TxD_RxD_Short D0 CANH_Short_GND BUS_Dom_Clamp D1 TxD_Dom_Clamp Wake_up D3 D2 CANL_Short_GND Local Wake_up R BUS and Local failure Interrupt R R wake-up, temperature and LDO timeout Interrupt R R Supply Related interrupt Interrupt Register OVT_Recovery R OVT_Warning D0 Reserved D1 Reserved Reserved D2 Reserved D3 VSUP_UV_flag D4 VSUP_POK_flag V2P8_UV_flag D5 V5V_UV_flag V2P8_POK_flag D7 D6 V5V_POK_flag V1P8_UV_flag V1P8_POK_flag Interrupt Source Registers D2 D1 D0 7.16 Status Registers The AS8650B has three Flag status registers and one RESET Reason Register. The Flag status registers indicate the current status of flags which are related to respective interrupt source registers. The Flag status registers are BUS Status Register, Temperature Status Register, and Supply Status Register. The microprocessor can read these registers any time to check the status of device. The function of each flag is listed in register space description in subsequent sections. A RESET Reason register indicates the reasons for RESET generation. Once the RESET pin goes ‘low’, the reason of this reset event is stored in RESET Reason register. When RESET is released microprocessor can read this register to know the cause for last RESET signal. The RESET Reason register is cleared once microprocessor reads this register through read operation. The bits functionality of this register is explained in register space description table. www.ams.com/AS8650 Revision 1.1 30 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8 Application Information Device Interfaces. There are two ways to communicate with AS8650B, one is 4 wires SPI and other is I²C. The selection between these two interfaces is through I2C_EN pin, as shown in Table 19. The pins CS, SCLK, SDI, and SDO are used for SPI interface. For I²C interface, SCLK is used as I²C Clock and SDA is used as I²C data line. Pins SCLKI2C / SCLKSPI and SDAI2C / SDISPI are multiplexed for both SPI and I²C interface. Since I2C_EN is a digital input pin, it has to be connected either to VLDO1 or GND. Note: I2C_EN should not be changed during a I²C/SPI Read/Write operation. Maximum switching delay between I²C and SPI is 8µs. Table 19. Device Interface Selection I2C_EN Description LOW Interface is 4-wire SPI HIGH Interface is I²C 8.1 Serial Peripheral Interface The Serial Peripheral Interface (SPI) provides the communication link with the microcontroller. The SPI is configured for half-duplex data transfer. The SPI provides access to configuration registers, control registers, and diagnostic registers. The modes of the AS8650B are changed by writing required code in to Mode Control Register through SPI. The SPI is also used to enter into test and OTP modes. This interface is only slave interface and only master can initiate SPI operation. The SPI can work on both the clock polarities. The polarity of the clock depends on the value of SCLK at the falling edge of CS. At the falling edge of CS if SCLK is “1” then the SPI is positive edge triggered and if the SCLK is “0” then SPI is negative edge triggered logic (see Table 20). Table 20. SPI Clock Polarity CS SCLK Description LOW HIGH Serial data is transferred at falling edge and sampled at rising edge of SCLK LOW LOW Serial data is transferred at rising edge and sampled at falling edge of SCLK The SPI protocol frame is divided in to two fields, the header field and the data field. The header field is 1 byte long containing a read/write command bit, 5 address bits and 2 reserved bits. The data field is of one data byte. The SPI frame format is shown in Figure 15. In the data phase MSB is sent first and LSB is sent last. Figure 15. SPI Frame Format Header Field Data Field 1 byte R/W 0 0 Reserved Bits 0– 1– www.ams.com/AS8650 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 5 bits Address WRITE READ Revision 1.1 31 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8.1.1 SPI Write Operation The SPI write operation begins with clock polarity selection at negative edge of CS, given in Table 20. Once the clock polarity is selected the SPI write command is given by providing ‘0’ in R/W bit of the header field in first sampling edge at SDI pin. The 5 bits address of register to be written is provided at SDI pin in next five consecutive sampling edges of SCLK. The first 2 bits in header fields are reserved and set to ‘0’. The data to be written is followed by last bit of header field. With each sampling edge a bit is sampled starting from MSB to LSB. During complete SPI write operation the CS has to be ‘low’. The SPI write operation ends with positive edge of CS. The wave form for SPI write operation with single data byte is shown in Figure 16 and Figure 17. Figure 16. SPI Write Operation with Negative Clock Polarity and 1 Byte of Data Field CS SCLK SDI R1 R0 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 SDO Sampling Edge High Impedance Sate Figure 17. SPI Write Operation with Positive Clock Polarity and 1 Byte of Data Field CS SCLK R1 R0 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 SDI SDO Sampling Edge High Impedance Sate www.ams.com/AS8650 Revision 1.1 32 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8.1.2 SPI Read Operation The SPI read operation also begins with clock polarity selection at negative edge of CS, given in Table 20. Once the clock polarity is selected the SPI read command is given by providing ‘1’ in R/W bit of the header field in first sampling edge at SDI pin. The 5 bits address of register to be read is provided at SDI pin in next five consecutive sampling edges of SCLK. The first 2 bits in header fields are reserved and set to ‘0’. The read data is followed by last bit of header field on SDO pin. With each sampling edge a bit can be read on SDO pin starting from MSB to LSB. During complete SPI read operation the CS has to be ‘low’. The SPI read operation ends with positive edge of CS. The wave form for SPI read operation with single data byte is shown in Figure 18 and Figure 19. Figure 18. SPI Read Operation with Negative Clock Polarity and 1 Byte of Data Field CS SCLK SDI R1 R0 A4 A3 A2 A1 A0 D7 SDO D6 D5 Sampling Edge D4 D3 D2 D1 D0 D1 D0 High Impedance Sate Figure 19. SPI Read Operation with Positive Clock Polarity and 1 Byte of Data Field CS SCLK SDI R1 R0 A4 A3 A2 A1 A0 D7 SDO Sampling Edge www.ams.com/AS8650 D6 D5 D4 D3 D2 High Impedance Sate Revision 1.1 33 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8.1.3 SPI Timing Diagram Figure 20. Timing Diagram for SPI Write Operation CS ... tCPS tCPHD tSCLKH tSCLKL tCSH CLK polarity SCLK ... tDIH tDIS SDI DATAI ... DATAI DATAI ... SDO Figure 21. Timing Diagram for SPI Read Operation CS tSCLKL tSCLKH SCLK SDI DATAI DATAI tDOHZ tDOD SDO www.ams.com/AS8650 DATAO (D7 N ) Revision 1.1 DATAO (D0 0 ) 34 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8.2 Inter-Integrated Circuit (I²C) Interface I²C is a bidirectional 2 line bus interface with a serial data line (SDA) and a serial clock line (SCLK) for inter IC control. This interface is only slave interface and only microcontroller can start and stop the I²C operation. The overview of I²C protocol is shown in Figure 22. A ‘high’ to ‘low’ transition on SDA line while SCLK is ‘high’ is the START (S) condition and a ‘low’ to ‘high’ transition on SDA line while SCLK is ‘high’ is the STOP (P) condition, as shown in Figure 22. The START and STOP conditions should always be generated by the microcontroller. After the START condition, microcontroller has to make sure that data on SDA line must be stable during the ‘high’ period of SCLK. The data should only change when SCLK line is ‘low’. The Bus is busy after the START condition and it is free after the STOP condition. Any number of data bytes can be transmitted between START and STOP. Each byte is followed by an acknowledgement (which is the ninth bit). The data transmitter always receives an acknowledgement from the data receiver at end of each byte. The data transmitter releases the SDA bus at start of ‘low’ period of 8th clock pulse and data receiver acknowledges by pulling the SDA to ‘low’ during the ‘low’ period of the SCLK. The Data receiver releases the bus at start of ‘low’ period of 9th clock pulse of the SCLK and data transmitter gets the data bus.The AS8650B does not support general call address, START byte and high-speed mode. Figure 22. I²C Bus Protocol SDA MSB S SCLK 1 LSB 2 3 4 5 6 8 7 1 9 3 2 7 bit Slave address 5 6 8 7 9 1 2 3 4 5 6 8 7 S or P 9 8 bit Data 8 bit Data R/W 8.2.1 4 ACK ACK ACK I²C Slave Address The 7-bit slave address of the device is by default set to 0000000. On request the slave address can be changed in the range from 0000000 to 1111110 through factory settings. 8.2.2 I²C Write Operation After the START condition, microcontroller has to send, in the first byte, the 7-bit slave address and 0 into the R/W bit as shown in Figure 23. The microcontroller has to send the address of the register to be written in the second byte. The first 3 MSB bits are reserved and remaining 5 bits are used as address bits. The data is sent starting from MSB to LSB. The AS8650B sends acknowledgement on 9th clock pulse. In the next byte (3rd byte) microcontroller has to send the data to be written into addressed register. If it is a single write operation, after receiving the acknowledgment from AS8650B, microcontroller has to send START or STOP condition, as shown in Figure 23. In case of auto increment write operation, microcontroller should not generate START or STOP condition after the third byte. If microcontroller continuously writes then address pointer rolls back to the starting register address after reaching the last register address. Data bytes coming from the microcontroller are written at the consecutive address locations, starting from the address sent in first data byte. After each data byte, direction of the bus line changes and AS8650B acknowledges by pulling the SDA line ‘low’. To terminate the write operation microcontroller has to generate STOP or repeated START condition. For details, see Figure 24. Figure 23. I²C Write Operation acknowledge from slave Slave address A SDA MSB SCLK S 1 acknowledge from slave register address A4 A3 A2 A1 A0 A 8 9 data to register acknowledge from slave A LSB 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 1 2 3 4 5 6 7 8 9 S or P R/W www.ams.com/AS8650 Revision 1.1 35 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Figure 24. I²C Auto-increment Write Operation acknowledge From slave Slave address SDA Master transmitter SCLK A MSB S 1 acknowledge From slave register address A3 A2 A4 A1 A0 A 8 9 data to register acknowledge From slave data to register + n A LSB 2 3 4 5 6 7 8 9 1 2 3 4 5 6 7 1 2 3 4 5 6 8 7 S or P 9 R/W 8.2.3 I²C Read Operation After the START condition, microcontroller has to send, in the first byte, the 7-bit slave address and 0 into the R/W bit as shown in Figure 25. The microcontroller has to send the address of the register to be written in the second byte. The first 3 MSB bits are reserved and remaining 5 bits are used as address bits. The data is sent starting from MSB to LSB. After receiving the acknowledgement on the 9th clock pulse, microcontroller has to send on the SDA line repeated START or STOP, as shown in Figure 25. If microcontroller sends STOP then microcontroller has to send START again. If microcontroller sends repeated START then there is no need to generate START again. The microcontroller again has to send the 7-bit slave address and writes ‘1’ into the R/W bit (8th bit). Now AS8650B sends data of the corresponding addressed register in the next eight clock cycles. In case of single read, microcontroller does not acknowledge on the 9th clock pulse and generates START or STOP condition after the ninth clock pulse. If it is an auto increment read operation, microcontroller acknowledges on the 9th clock pulse and AS8650B sends data from the consecutive address locations, (see Figure 25). If microcontroller continuously reads then address pointer rolls back to the starting register address after reaching the last register address. In the data phase MSB is sent first and LSB is sent last. After each data byte, microcontroller has to send the acknowledgement. The microcontroller can terminate the auto read operation by not generating acknowledgement for the last byte that was sent by the AS8650B and generates STOP or repeated START condition after the 9th clock pulse. Figure 25. I²C Read Operation acknowledge from slave Slave address SDA MSB SCLK S 1 0 A 8 9 acknowledge from slave register address A4 A3 A2 A1 A0 A LSB 2 3 4 5 6 7 1 2 3 4 5 6 7 8 9 S or P W acknowledge from slave SDA MSB SCLK S 1 1 A 8 9 acknowledge from master Data byte Slave address A LSB 2 3 4 5 6 7 1 2 3 4 5 6 7 8 9 S or P R www.ams.com/AS8650 Revision 1.1 36 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Figure 26. I²C Auto-increment Read Operation 0 A 7 8 9 SDA MSB SCLK S 1 acknowledge register address from slave acknowledge from slave Slave address A 4 LSB 2 3 4 5 6 1 2 3 4 A 3 5 A 2 6 A 1 A 0 A 7 8 9 S or P W acknowledge from slave Slave address 1 A 7 8 9 SDA MSB SCLK S 1 Data byte 1 acknowledge from master Last data byte Data byte n No acknowledge from master A A LSB 2 3 4 5 6 1 2 3 4 5 6 7 8 1 9 2 3 4 5 6 7 8 9 S or P R Figure 27. Definition of I²C Timing Parameters SDA tr tf SCLK tLOW tr tf tSU_DAT tHD_DAT tBUF tSP S tHD_STA www.ams.com/AS8650 tHIGH tSU_STA Revision 1.1 Sr tSU_STO P S 37 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n 8.3 Register Space The AS8650B register space consists of configuration registers, control registers and diagnostic registers. All of these registers are accessible through SPI or I²C commands. Table 21. Configuration Registers Addr Register Name 0x00 Reserved 0x01 Reserved 0x02 WD Access Control Register POR Value Bit Type Description Reserved Reserved 0000_0000 POR_VLDO1 D[7:0] R/W 0101_1010 01 D[7:6] WD Configuration Register access Enabled Else WD Configuration Register access disabled WD disabled Else WD enabled Timeout Watchdog mode Window period Twd_tout_period. (Accuracy of the timings is ±25%) D[5:3] 0x03 WD Configuration Register 0000_1001 POR_VSUP R/W 000 80 ms 001 160 ms 010 320 ms 011 480 ms 100 800 ms 101 1000 ms 110 2000 ms 111 4000 ms Window Watchdog mode Window period Twwd_period (50% of above value is trigger window) D[2:0] D[7:1] 0x04 WD Trigger Register www.ams.com/AS8650 0000_0000 POR_VLDO1 D[0] 000 10 ms 001 40 ms 010 80 ms 011 120 ms 100 160 ms 101 240 ms 110 320 ms 111 400 ms Reserved W Watchdog trigger bit. The microcontroller set this bit within the required window of watchdog timer. After this internal counter is reset and this bit is cleared internally. Revision 1.1 38 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Table 21. Configuration Registers Addr Register Name POR Value Bit Type Description D[7] D[6] D[5] 0x05 Device Configuration Register 0110_1101 POR_VSUP D[4] R/W D[3] D[2] D[1] 0 LDO3 disable in Standby mode 1 LDO3 enable in Standby mode 0 LDO3 disable in Receive-only mode 1 LDO3 enable in Receive-only mode 0 LDO3 disable in Normal mode 1 LDO3 enable in Normal mode 0 LDO2 disable in Standby mode 1 LDO2 enable in Standby mode 0 LDO2 disable in Receive-only mode 1 LDO2 enable in Receive-only mode 0 LDO2 disable in Normal mode 1 LDO2 enable in Normal mode 0 DCDC disable in Sleep mode 1 DCDC enable in Sleep mode D[7:6] Reserved Device state (Read-only values) D[5:4] 0x06 Mode Control Register 0000_0000 POR_VSUP D[3:2] R/W D[1:0] 0 Device in Standby mode 1 Device in Normal mode 10 Device in Receive-only mode 00 Standby mode 01 Normal mode 10 Receive-only mode 11 Sleep mode Reserved D[7:3] Reserved D[2] 0x07 Interrupt Register 0000_0000 POR_VSUP D[1] No Interrupt 1 Supply Related Interrupt. The source of interrupt is known by reading Interrupt Source Register 3 0 No Interrupt 1 Wake-up & temperature Related Interrupt. The source of interrupt is known by reading Interrupt Source Register 2 0 No Interrupt 1 BUS & Local Failure Related Interrupt. The source of interrupt is known by reading Interrupt Source Register 1 R D[0] www.ams.com/AS8650 0 Revision 1.1 39 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Table 21. Configuration Registers Addr Register Name POR Value Bit Type D[7] D[6] Description 0 No Interrupt 1 Interrupt due to BUS clamped to dominant 0 No Interrupt 1 Interrupt due to short TxD & RxD pins D[5] Reserved D[4] 0x08 Interrupt Source Register 1 0000_0000 POR_VSUP D[3] R/W D[2] D[1] D[0] 0 No Interrupt 1 Interrupt due to TxD pin clamped to Dominant 0 No Interrupt 1 Interrupt due to CANL pin shorted to VCC 0 No Interrupt 1 Interrupt due to CANL pin shorted to GND 0 No Interrupt 1 Interrupt due to CANH pin shorted to GND 0 No Interrupt 1 Interrupt due to CANH pin shorted to VCC D[7:4] Reserved D[3] 0x09 Interrupt Source Register 2 0000_0000 POR_VSUP D[2] D[1] D[0] www.ams.com/AS8650 Revision 1.1 0 No Interrupt 1 Interrupt due to junction temperature falling back below Tjrecv 0 No Interrupt 1 Interrupt due to junction temperature exceeding Tjwarn 0 No Interrupt 1 Interrupt due to Local Wake up event on WAKE pin 0 No Interrupt 1 Interrupt due to Wake up by BUS message (remote wake) 40 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Table 21. Configuration Registers Addr Register Name POR Value Bit Type D[7] D[6] D[5] D[4] 0x0A Interrupt Source Register 3 0000_0000 POR_VSUP R/W D[3] D[2] D[1] D[0] 0x0B 0x0C 0x0D 0x0E Reserved BUS Status Register Temperature Status Register Supply Status Register www.ams.com/AS8650 0000_0000 POR_VSUP 0000_0000 POR_VSUP 0000_0000 POR_VSUP 1010_1010 POR_VSUP Description 0 No Interrupt 1 Interrupt due to VLDO3_POK_flag set 0 No Interrupt 1 Interrupt due to VLDO3_UV_flag set 0 No Interrupt 1 Interrupt due to VLDO2_POK_flag set 0 No Interrupt 1 Interrupt due to VLDO2_UV_flag set 0 No Interrupt 1 Interrupt due to V5V_POK_flag set 0 No Interrupt 1 Interrupt due to V5V_UV_flag set 0 No Interrupt 1 Interrupt due to VSUP_POK_flag set 0 No Interrupt 1 Interrupt due to VSUP_UV_flag set D[7:0] Reserved D[7] BUS clamped to dominant D[6] TxD & RxD pins short D[4] TxD pin clamped to Dominant D[3] R CANL pin shorted to VCC D[2] CANL pin shorted to GND D[1] CANH pin shorted to GND D[0] CANH pin shorted to VCC D[7:2] Reserved D[1] R OTM 140 Recovery flag D[0] OTM 160 Warning flag D[7] VLDO3_POK_flag D[6] VLDO3_UV_flag D[5] VLDO2_POK_flag D[4] D[3] R VLDO2_UV_flag V5V_POK_flag D[2] V5V_UV_flag D[1] VSUP_POK_flag D[0] VSUP_UV_flag Revision 1.1 41 - 46 AS8650B Datasheet - A p p l i c a t i o n I n f o r m a t i o n Table 21. Configuration Registers Addr Register Name POR Value Bit Type Description These bits are cleared on microcontroller read 0x0F RESET Reason Register 0000_0000 POR_VSUP D[7] Reserved D[6] Sleep mode exit by Local Wake up on WAKE pin D[5] Sleep mode exit by Remote wake D[4] R Window Watchdog failure D[3] Timeout Watchdog failure D[2] Start-up Watchdog failure D[1] Undervoltage on VLDO1 D[0] OTM Shutdown flag 0x10 D[7:0] OTP_BITS[32:25] / MCU Backup Data 0x11 D[7:0] OTP_BITS[40:33] / MCU Backup Data 0x12 D[7:0] OTP_BITS[48:41] / MCU Backup Data 0x13 0x14 Backup Register 0000_0000 POR_VSUP D[7:0] D[7:0] R/W OTP_BITS[56:49] / MCU Backup Data {1’b0, OTP_BITS[63:57]} / MCU Backup Data 0x15 D[7:0] {2'd0, Slave address[6:1]}/MCU Backup Data 0x16 D[7:0] 10bit_slave_address[3:0]/MCU Backup Data 0x17 D[7:0] MCU Backup Data www.ams.com/AS8650 Revision 1.1 42 - 46 AS8650B Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 9 Package Drawings and Markings The device is available in a 36-pin QFN (6x6x0.9) package. Figure 28. Drawings and Dimensions 18249-03 AS8650B YYWWXZZ @ Symbol A A1 A3 L L1 b D E e D2 E2 aaa bbb ccc ddd eee fff N Notes: Min 0.80 0 0.35 0 0.18 4.60 4.60 - Nom 0.90 0.02 0.20 REF 0.40 0.25 6.00 BSC 6.00 BSC 0.50 BSC 4.70 4.70 0.15 0.10 0.10 0.05 0.08 0.10 36 Max 1.00 0.05 0.45 0.15 0.30 1. Dimensions and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters, angle is in degrees. 3. Dimension b applies to metallized terminal and is measured between 0.25mm and 0.30mm from terminal tip. Dimension L1 represents terminal full back from package edge up to 0.15mm is acceptable. 4. Coplanarity applies to the exposed heat slug as well as the terminal. 5. Radius on terminal is optional. 6. N is the total number of terminals. 4.80 4.80 - Marking Description: YY WW X ZZ @ Last two digits of the current year Manufacturing Week Assembly plant identifier Assembly traceability code Sublot identifier www.ams.com/AS8650 Revision 1.1 43 - 46 AS8650B Datasheet - R e v i s i o n H i s t o r y Revision History Revision Date 1.0 28 Mar, 2012 1.1 Jan 11, 2013 Owner hgl Description Initial release for AS8650B Updated Ordering Information Note: Typos may not be explicitly mentioned under revision history. www.ams.com/AS8650 Revision 1.1 44 - 46 AS8650B Datasheet - O r d e r i n g I n f o r m a t i o n 10 Ordering Information The devices are available as the standard products shown in Table 22. 1 Table 22. Ordering Information Ordering Code Marking Description AS8650B-ZQFP-01 AS8650B AS8650B-ZQFM-01 AS8650B AS8650B Power Management device with high-speed CAN Interface (standard configuration) Delivery Form Package Tape & Reel in Dry Pack (1 reel = 4000 units) 36-pin QFN (6x6x0.9) Tape & Reel in Dry Pack (1 reel = 1000 units) 36-pin QFN (6x6x0.9) 1. The AS8650B provides various configuration options during production. For more information, please contact our sales office. Note: All products are RoHS compliant and ams green. Buy our products or get free samples online at www.ams.com/ICdirect Technical Support is available at www.ams.com/Technical-Support For further information and requests, email us at sales@ams.com (or) find your local distributor at www.ams.com/distributor www.ams.com/AS8650 Revision 1.1 45 - 46 AS8650B Datasheet - C o p y r i g h t s Copyrights Copyright © 1997-2013, ams AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by ams AG is believed to be correct and accurate. However, ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. Contact Information Headquarters ams AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Tel Fax : +43 (0) 3136 500 0 : +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.ams.com/contact www.ams.com/AS8650 Revision 1.1 46 - 46
AS8650B-ZQFP-01 价格&库存
很抱歉,暂时无法提供与“AS8650B-ZQFP-01”相匹配的价格&库存,您可以联系我们找货
