TAI-TECH
P1
SMD Power Inductor
TMPA1004SV-Series(N)-D
1. Features
1. Shielded construction.
2. Capable of corresponding high frequency .
Halogen
3. Low loss realized with low DCR.
4. High performance (Isat) realized by metal dust core.
Halogen-free
5. Ultra low buzz noise, due to composite construction.
6. 100% Lead(Pb)-Free and RoHS compliant.
7. High reliability -Reliability test complied to AEC-Q200
8. Operating temperature -55~+155℃(Including self - temperature rise)
2. Applications
1. DC/DC converters in distributed power systems.
2. DC/DC converter for Field Programmable Gate Array(FPGA).
3. Battery powered devices.
4. Thin type on-board power supply module for exchanger.
5. VRM for server.
6. High current, low profile POL converters.
7. PDA/notebook/desktop/server and battery powered devices.
3. Dimensions
C
2R2
2019
D
E
B
A
A`
leadframe
C
Customer Recommend PC Board
D
Pattern
1R0
2019
H
non-leadframe
Series
L
E
B
A
A`
A
A`
TMPA1004SV 11.0±0.3
G
B
10.0±0.3
10.0±0.3
C
3.8±0.2
D
E
2.0±0.3
See spec
table
Unit:mm
L(mm)
4. Part Numbering
TMPA
1004
SV
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: Code
1R0
MN
D
E
G(mm)
H(mm)
12.5
5.4
3.5
Note: 1. The above PCB layout reference only.
2. Recommend solder paste thickness at
0.15mm and above.
D
F
BxC
Standard. V:Vehicle
1R0=1.0uH
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking: Black.1R0 and 2019(20YY,19 WW,follow production date).
TAI-TECH
P2
5. Specification
Part Number
Inductance
L0 A(uH)
±20%
Heat Rating
Current DC
I rms ( A )
Saturation
Current DC
I sat ( A )
DCR
(mΩ)Typ
DCR
(mΩ)Max
TMPA1004SV-R15YN-D
0.15±30%
44.0
82.0
0.5
TMPA1004SV-R22MN-D
0.22
36.0
70.0
TMPA1004SV-R36MN-D
0.36
33.0
51.0
TMPA1004SV-R47MN-D
0.47
32.0
TMPA1004SV-R56MN-D
0.56
25.0
TMPA1004SV-R68MN-D
0.68
TMPA1004SV-1R0MN-D
TMPA1004SV-1R5MN-D
E(mm)
±0.3
Type
0.6
3.0
non-leadframe
0.72
0.83
3.0
non-leadframe
1.05
1.18
3.0
non-leadframe
46.0
1.3
1.5
3.0
non-leadframe
34.0
1.6
1.8
2.5
non-leadframe
23.0
31.0
1.9
2.2
2.5
non-leadframe
1.00
20.0
29.0
2.9
3.25
2.5
non-leadframe
1.50
17.5
26.0
3.7
4.2
2.5
non-leadframe
TMPA1004SV-1R8MN-D
1.80
16.5
23.0
5.1
5.7
3.0
leadframe
TMPA1004SV-2R2MN-D
2.20
15.0
20.0
5.8
6.7
3.0
leadframe
TMPA1004SV-3R3MN-D
3.30
11.0
17.5
10.5
11.8
3.0
leadframe
TMPA1004SV-4R7MN-D
4.70
8.8
15.2
15.8
19
3.0
leadframe
TMPA1004SV-5R6MN-D
5.60
8.0
14.1
19
22.8
3.0
leadframe
TMPA1004SV-6R8MN-D
6.80
7.8
12.2
22
24.5
3.0
leadframe
TMPA1004SV-8R2MN-D
8.20
7.6
9.5
25
28
3.0
leadframe
TMPA1004SV-100MN-D
10.0
7.5
8.6
27
30
3.0
leadframe
TMPA1004SV-150MN-D
15.0
6.25
7.0
41
45
3.0
leadframe
TMPA1004SV-220MN-D
22.0
5.0
6.2
58
66
3.0
leadframe
TMPA1004SV-330MN-D
33.0
4.4
5.5
84
91
3.0
leadframe
TMPA1004SV-470MN-D
47.0
3.5
4.0
125
143
3.0
leadframe
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 155℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Special inquiries besides the above common used types can be met on your requirement.
TAI-TECH
6. Typical Performance Curves
P3
TAI-TECH
P4
很抱歉,暂时无法提供与“TMPA1004SV-R22MN-D”相匹配的价格&库存,您可以联系我们找货
