MR4A16B
1M x 16 MRAM
FEATURES
• +3.3 Volt power supply
• Fast 35 ns read/write cycle
• SRAM compatible timing
• Unlimited read & write endurance
• Data always non-volatile for >20 years at temperature
• RoHS-compliant small footprint BGA and TSOP2 package
• All products meet MSL-3 moisture sensitivity level
BENEFITS
• One memory replaces FLASH, SRAM, EEPROM and BBSRAM in systems
for simpler, more efficient designs
• Improves reliability by replacing battery-backed SRAM
INTRODUCTION
The MR4A16B is a 16,777,216-bit magnetoresistive random access memory
(MRAM) device organized as 1,048,576 words of 16 bits. The MR4A16B offers
SRAM compatible 35 ns read/write timing with unlimited endurance. Data
is always non-volatile for greater than 20 years. Data is automatically protected on power loss by low-voltage inhibit circuitry to prevent writes with voltage out of specification. To
simplify fault tolerant design, the MR4A16B includes internal single bit error correction code with 7 ECC
parity bits for every 64 data bits. The MR4A16B is the ideal memory solution for applications that must
permanently store and retrieve critical data and programs quickly.
RoHS
The MR4A16B is available in a small footprint 48-pin ball grid array (BGA) package and a 54-pin thin small
outline package (TSOP Type 2). These packages are compatible with similar low-power SRAM products and
other nonvolatile RAM products.
The MR4A16B provides highly reliable data storage over a wide range of temperatures. The product is
offered with commercial temperature (0 to +70 °C), and industrial temperature (-40 to +85 °C) operating
temperature options.
CONTENTS
1. DEVICE PIN ASSIGNMENT.........................................................................
3
2. ELECTRICAL SPECIFICATIONS.................................................................
4
3. TIMING SPECIFICATIONS..........................................................................
7
4. ORDERING INFORMATION.......................................................................
12
5. MECHANICAL DRAWING..........................................................................
13
6. REVISION HISTORY......................................................................................
15
How to Reach Us...................................................................................... ..........
16
Copyright © 2018 Everspin Technologies, Inc.
1
MR4A16B Rev. 11.7 3/2018
MR4A16B
Figure 1.1 Block Diagram
OUTPUT
ENABLE
BUFFER
G
A[19:0]
UPPER BYTE OUTPUT ENABLE
LOWER BYTE OUTPUT ENABLE
10
ADDRESS
BUFFER
10
ROW
DECODER
CHIP
ENABLE
BUFFER
E
FINAL
WRITE
DRIVERS
UPPER BYTE WRITE ENABLE
LB
LOWER
BYTE
OUTPUT
BUFFER
8
8
16
BYTE
ENABLE
BUFFER
LB
SENSE
AMPS
1M x 16
BIT
MEMORY
ARRAY
UB
UB
8
16
WRITE
ENABLE
BUFFER
W
COLUMN
DECODER
UPPER
BYTE
OUTPUT
BUFFER
8
UPPER
BYTE
WRITE
DRIVER
LOWER
BYTE
WRITE
DRIVER
8
8
8
8
DQU[15:8]
DQL[7:0]
LOWER BYTE WRITE ENABLE
Table 1.1 Pin Functions
Signal Name
Function
A
Address Input
E
Chip Enable
W
Write Enable
G
Output Enable
UB
Upper Byte Enable
LB
Lower Byte Enable
DQ
Data I/O
VDD
Power Supply
VSS
Ground
DC
Do Not Connect
NC
No Connection
2
MR4A16B
Figure 1.1 Pin Diagrams for Available Packages (Top View)
1
2
3
4
5
6
LB
G
A0
A1
A2
NC
A
DQU8
UB
A3
A4
E
DQL0
B
DQU9
DQU10
A5
A6
DQL1
DQL2
C
VSS
DQU11
A17
A7
DQL3
VDD
D
VDD
DQU12
DC
A16
DQL4
VSS
E
DQU14
DQU13
A14
A15
DQL5
DQL6
F
DQU15
NC
A12
A13
W
DQL7
G
A18
A8
A9
A10
A11
A19
H
1
2
3
4
54
53
52
51
5
6
7
50
49
48
8
9
47
46
10
11
12
13
45
44
43
42
14
15
16
17
18
19
41
40
39
38
37
36
22
35
34
33
23
32
24
25
26
27
31
30
29
28
NC
A19
A0
A1
A2
A3
A4
E
DQ0
DQ1
DQ2
DQ3
VDD
VSS
DQ4
DQ5
DQ6
DQ7
W
A5
A6
A7
A8
A9
NC
NC
NC
48-Pin BGA
NC
A18
A17
A16
A15
G
UB
LB
DQ15
DQ14
DQ13
DQ12
VSS
VDD
DQ11
DQ10
DQ9
DQ8
DC
A14
A13
A12
A11
A10
NC
NC
NC
54-Pin TSOP2
Table 1.2 Operating Modes
E1
G1
W1
LB1
UB1
Mode
VDD Current
DQL[7:0]2
DQU[15:8]2
H
X
X
X
X
Not selected
ISB1, ISB2
Hi-Z
Hi-Z
L
H
H
X
X
Output disabled
IDDR
Hi-Z
Hi-Z
L
X
X
H
H
Output disabled
IDDR
Hi-Z
Hi-Z
L
L
H
L
H
Lower Byte Read
IDDR
DOut
Hi-Z
L
L
H
H
L
Upper Byte Read
IDDR
Hi-Z
DOut
L
L
H
L
L
Word Read
IDDR
DOut
DOut
L
X
L
L
H
Lower Byte Write
IDDW
Din
Hi-Z
L
X
L
H
L
Upper Byte Write
IDDW
Hi-Z
Din
L
X
L
L
L
Word Write
IDDW
Din
Din
1
H = high, L = low, X = don’t care
2
Hi-Z = high impedance
3
MR4A16B
Absolute Maximum Ratings
This device contains circuitry to protect the inputs against damage caused by high static voltages or
electric fields; however, it is advised that normal precautions be taken to avoid application of any
voltage greater than maximum rated voltages to these high-impedance (Hi-Z) circuits.
The device also contains protection against external magnetic fields. Precautions should be taken
to avoid application of any magnetic field greater than the maximum field intensity specified
in the maximum ratings.
Table 2.1 Absolute Maximum Ratings 1
Symbol
Parameter
VDD
Supply voltage2
VIN
Voltage on an pin 2
IOUT
Output current per pin
PD
Package power dissipation 3
TBIAS
Temperature under bias
Tstg
Storage Temperature
TLead
Lead temperature during solder (3
minute max)
Hmax_write
Maximum magnetic field
Hmax_read
Conditions
Value
Unit
-0.5 to 4.0
V
-0.5 to VDD + 0.5
V
±20
mA
0.600
W
Commercial
-10 to 85
°C
Industrial
-45 to 95
°C
-55 to 150
°C
260
°C
8000
A/m
During Write
During Read or Standby
1
Permanent device damage may occur if absolute maximum ratings are exceeded. Functional operation
should be restricted to recommended operating conditions. Exposure to excessive voltages or magnetic
fields could affect device reliability.
2
All voltages are referenced to VSS. The DC value of VIN must not exceed actual applied VDD by more than
0.5V. The AC value of VIN must not exceed applied VDD by more than 2V for 10ns with IIN limited to less than
20mA.
Power dissipation capability depends on package characteristics and use environment.
3
4
MR4A16B
Electrical Specifications
Table 2.2 Operating Conditions
Symbol
VDD
Parameter
Temp Range
Min
Typical
Max
Unit
Power supply voltage
3.0
3.3
3.6
V
VWI
Write inhibit voltage
2.5
2.7
3.0 1
V
VIH
Input high voltage
2.2
VDD + 0.3 2
V
VIL
Input low voltage
-0.5 3
0.8
V
TA
°C
-40
85
°C
Commercial
Industrial
1
There is a 2 ms startup time once VDD exceeds VDD,(min). See Power Up and Power Down Sequencing below.
VIH(max) = VDD + 0.3 VDC ; VIH(max) = VDD + 2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA.
3
VIL(min) = -0.5 VDC ; VIL(min) = -2.0 VAC (pulse width ≤ 10 ns) for I ≤ 20.0 mA.
1
2
The MRAM is protected from write operations whenever VDD is less than VWI. As soon as VDD exceeds VDD(min),
there is a startup time of 2 ms before read or write operations can start. This time allows memory power
supplies to stabilize.
The E and W control signals should track VDD on power up to VDD- 0.2 V or VIH (whichever is lower) and remain
high for the startup time. In most systems, this means that these signals should be pulled up with a resistor so that a signal remains high if the driving signal is Hi-Z during power up. Any logic that drives E and W
should hold the signals high with a power-on reset signal for longer than the startup time.
During power loss or brownout where VDD goes below VWI, writes are protected and a startup time must be
observed when power returns above VDD(min).
Figure 2.1 Power Up and Power Down Diagram
VWI
VDD
BROWNOUT or POWER LOSS
2 ms
STARTUP
READ/WRITE
INHIBITED
2 ms
RECOVER
NORMAL
OPERATION
NORMAL
OPERATION
READ/WRITE
INHIBITED
VIH
VIH
E
W
5
MR4A16B
Table 2.3 DC Characteristics
Symbol
Parameter
Conditions
Min
Max
Unit
Ilkg(I)
Input leakage current
All
±1
μA
Ilkg(O)
Output leakage current
All
±1
μA
0.4
V
VSS + 0.2
V
2.4
V
VDD - 0.2
V
VOL
VOH
Output low voltage
IOL = +4 mA
IOL = +100 μA
Output high voltage
IOH = -4 mA
IOH = -100 μA
Table 2.4 Power Supply Characteristics
Symbol
IDDR
IDDW
Parameter
AC active supply current - read modes1
(IOUT= 0 mA, VDD= max)
AC active supply current - write modes1
(VDD= max)
Typical
Max
Unit
60
68
mA
152
180
mA
9
14
mA
5
9
mA
AC standby current
ISB1
(VDD= max, E = VIH)
no other restrictions on other inputs
CMOS standby current
ISB2
(E ≥ VDD - 0.2 V and VIn ≤ VSS + 0.2 V or ≥ VDD - 0.2 V)
(VDD = max, f = 0 MHz)
1
All active current measurements are measured with one address transition per cycle and at minimum cycle time.
6
MR4A16B
Table 3.1 Capacitance 1
Symbol
CIn
1
Parameter
Typical
Max
Unit
Address input capacitance
6
pF
CIn
Control input capacitance
6
pF
CI/O
Input/Output capacitance
8
pF
Value
Unit
Logic input timing measurement reference level
1.5
V
Logic output timing measurement reference level
1.5
V
0 or 3.0
V
Input rise/fall time
2
ns
Output load for low and high impedance parameters
See Figure 3.1
Output load for all other timing parameters
See Figure 3.2
f = 1.0 MHz, dV = 3.0 V, TA = 25 °C, periodically sampled rather than 100% tested.
Table 3.2 AC Measurement Conditions
Parameter
Logic input pulse levels
Figure 3.1 Output Load Test Low and High
ZD= 50 Ω
Output
RL = 50 Ω
VL = 1.5 V
Figure 3.2 Output Load Test All Others
3.3 V
590 Ω
Output
5 pF
435 Ω
7
MR4A16B
Timing Specifications
Table 3.3 Read Cycle Timing 1
Read Mode
Symbol
Parameter
Min
Max
Unit
35
ns
tAVAV
Read cycle time
tAVQV
Address access time
35
ns
tELQV
Enable access time
35
ns
tGLQV
Output enable access time
15
ns
tBLQV
Byte enable access time
15
ns
tAXQX
Output hold from address change
3
ns
tELQX
Enable low to output active
3
ns
tGLQX
Output enable low to output active 3
ns
tBLQX
Byte enable low to output active
ns
tEHQZ
Enable high to output Hi-Z 3
ns
tGHQZ
Output enable high to output Hi-Z
ns
tBHQZ
Byte high to output Hi-Z 3
ns
2
3
3
3
W is high for read cycle. Power supplies must be properly grounded and decoupled, and bus contention conditions must be
minimized or eliminated during read or write cycles.
2
Addresses valid before or at the same time E goes low.
3
This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage.
1
Figure 3.3A Read Cycle 1
t AVAV
A (ADDRESS)
t AXQX
Q (DATA OUT)
Previous Data Valid
Data Valid
t AVQV
Note: Device is continuously selected (E≤VIL, G≤VIL).
Figure 3.3B Read Cycle 2
t AVAV
A (ADDRESS)
t AVQV
E (CHIP ENABLE)
t ELQV
t EHQZ
t ELQX
G (OUTPUT ENABLE)
t GLQX
t GHQZ
t GLQV
LB, UB (BYTE ENABLE)
Q (DATA OUT)
t BLQX
t BHQZ
t BLQV
Data Valid
8
MR4A16B
Table 3.4 Write Cycle Timing 1 (W Controlled) 1
Symbol
Parameter
Min
Max
Unit
tAVAV
Write cycle time 2
35
ns
tAVWL
Address set-up time
ns
tAVWH
Address valid to end of write (G high)
ns
tAVWH
Address valid to end of write (G low)
ns
Write pulse width (G high)
15
ns
Write pulse width (G low)
15
ns
Data valid to end of write
10
ns
tWHDX
Data hold time
ns
tWLQZ
Write low to data Hi-Z 3
ns
tWHQX
Write high to output active 3
3
ns
tWHAX
Write recovery time
12
ns
tWLWH
tWLEH
tWLWH
tWLEH
tDVWH
All write occurs during the overlap of E low and W low. Power supplies must be properly grounded and decoupled and bus
contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after
W goes low, the output will remain in a high impedance state. After W, E or UB/LB has been brought high, the signal must
remain in steady-state high for a minimum of 2 ns. The minimum time between E being asserted low in one cycle to E being
asserted low in a subsequent cycle is the same as the minimum cycle time allowed for the device.
2
All write cycle timings are referenced from the last valid address to the first transition address.
3
This parameter is sampled and not 100% tested. Transition is measured ±200 mV from the steady-state voltage. At any given
voltage or temperate, tWLQZ(max) < tWHQX(min).
1
Figure 3.4 Write Cycle Timing 1 (W Controlled)
t AVAV
A (ADDRESS)
t AVWH
t WHAX
E (CHIP ENABLE)
t WLEH
t WLWH
W (WRITE ENABLE)
t AVWL
UB, LB (BYTE ENABLED)
t DVWH
D (DATA IN)
t WHDX
DATA VALID
t WLQZ
Q (DATA OUT)
Hi -Z
Hi -Z
t WHQX
9
MR4A16B
Table 3.5 Write Cycle Timing 2 (E Controlled) 1
Symbol
Parameter
Min
Max
Unit
tAVAV
Write cycle time 2
35
ns
tAVEL
Address set-up time
ns
tAVEH
ns
tAVEH
ns
Enable to end of write (G high)
15
ns
Enable to end of write (G low) 3
15
ns
tDVEH
10
ns
tEHDX
Data hold time
ns
tEHAX
Write recovery time
12
ns
tELEH
tELWH
tELEH
tELWH
W goes low, the output will remain in a high impedance state. After W, E or UB/ LB has been brought high, the signal must
2
3
If E goes low at the same time or after W goes low, the output will remain in a high-impedance state. If E goes high at the
same time or before W goes high, the output will remain in a high-impedance state.
1
Figure 3.5 Write Cycle Timing 2 (E Controlled)
t AVAV
A (ADDRESS)
t EHAX
t AVEH
t ELEH
E (CHIP ENABLE)
t AVEL
t ELWH
W (WRITE ENABLE)
UB, LB (BYTE ENABLE)
t DVEH
D (DATA IN)
Q (DATA OUT)
t EHDX
Data Valid
Hi-Z
10
MR4A16B
Table 3.6 Write Cycle Timing 3 (LB/UB Controlled) 1
Symbol
Parameter
Min
Max
Unit
tAVAV
Write cycle time 2
35
ns
tAVBL
Address set-up time
ns
tAVBH
ns
tAVBH
ns
15
ns
15
ns
tDVBH
10
ns
tBHDX
Data hold time
ns
tBHAX
Write recovery time
12
ns
tBLEH
tBLWH
tBLEH
tBLWH
contention conditions must be minimized or eliminated during read and write cycles. If G goes low at the same time or after W
goes low, the output will remain in a high impedance state. After W, E or UB/LB has been brought high, the signal must remain
in steady-state high for a minimum of 2 ns. If both byte control signals are asserted, the two signals must have no more than 2
ns skew between them. The minimum time between E being asserted low in one cycle to E being asserted low in a subsequent
2
1
Figure 3.6 Write Cycle Timing 3 (LB/UB Controlled)
t AVAV
A (ADDRESS)
t AVEH
t BHAX
E (CHIP ENABLE)
W (WRITE ENABLE)
t AVBL
t BLEH
t BLWH
t DVBH
D (DATA IN)
Q (DATA OUT)
t BHDX
Data Valid
Hi -Z
Hi -Z
11
MR4A16B
Figure 4.1 Part Numbering System
MR
4
A
16
B
C
MA
35
R
Carrier
Speed
Package
Temperature Range
Blank = Tray, R = Tape & Reel
35 ns
MA = FBGA, YS = TSOP
Blank= Commercial (0 to +70 °C),
C= Industrial (-40 to +85°C )
Revision
Data Width
Type
16 = 16-bit
A = Asynchronous
Density
4 =16Mb
Magnetoresistive RAM
Table 4.1 Available Parts
Grade
Temp Range
Package
48-BGA
Commercial
0 to +70 °C
54-TSOP2
48-BGA
Industrial
-40 to +85°C
54-TSOP2
Shipping Container
Trays
Tape & Reel
Trays
Tape & Reel
Order Part Number
MR4A16BMA35
MR4A16BMA35R
MR4A16BYS35
MR4A16BYS35R
Tray
MR4A16BCMA35
Tape & Reel
MR4A16BCMA35R
Tray
MR4A16BCYS35
Tape & Reel
MR4A16BCYS35R
12
MR4A16B
Figure 5.1 48-FBGA
BOTTOM VIEW
TOP VIEW
(DATUM B)
PIN A1
INDEX
PIN A1
INDEX
6 5 4 3 2 1
A
(DATUM A)
B
C
D
E
F
G
H
SEATING PLANE
SOLDER BALL DIAMETER REFERS
TO POST REFLOW CONDITION.
THE PRE-REFLOW DIAMETER IS ø 0.35mm
Ref
Min
Nominal
Max
A
1.19
1.27
1.35
A1
0.22
0.27
0.32
b
D
E
D1
E1
DE
SE
e
0.31
0.36
0.41
Ref
aaa
bbb
ddd
eee
fff
Tolerance of, from and position
Print Version Not To Scale
1. Dimensions in Millimeters.
10.00 BSC
2. The ‘e’ represents the basic solder ball grid pitch.
10.00 BSC
3. ‘b’ is measurable at the maximum solder ball diameter
5.25 BSC
3.75 BSC
4. Dimension ‘ddd’ is measured parallel to primary datum
C.
0.375 BSC
0.375 BSC
0.75 BSC
in a plane parallel to datum C.
5. Primary datum C (seating plane) is defined by the
crowns
of the solder balls.
6. Package dimensions refer to JEDEC MO-205 Rev. G.
0.10
0.10
0.10
0.15
0.08
13
MR4A16B
Figure 5.2 54-TSOP2
A2
D
54
A1
A
28
θ3
L1
E
E1
θ2
c
27
1
⊕0.20(0.008) M
b
e
R1
R2
0.71 REF.
0.21(0.008)REF.
C
0.665(0.026)REF.
GAGE PLANE
θ
SEATING PLANE
0.25 mm
0.10 C
θ1
Ref
Min
Nominal
A
Max
1.20
A1
0.05
0.10
0.15
A2
b
c
D
E
E1
e
L
L1
R1
R2
θ
θ1
θ2
θ3
0.95
1.00
1.05
0.30
0.35
0.45
0.12
0.21
2. Package dimensions refer to JEDEC MS-024
22.10
22.22
22.35
11.56
11.76
11.95
10.03
10.16
10.29
0.80 BSC
0.40
0.50
0.60
0.80 REF
0.12
0.12
0.25
0°
8°
0.40
15° REF
15° REF
14
MR4A16B
6. REVISION HISTORY
Rev
Date
Description of Change
1
May 29, 2009
Establish Speed and Power Specifications
2
July 27, 2009
Increase BGA Package to 11 mm x 11 mm
3
Nov 26, 2009
Changed ball definition of H6 to A19 and G2 to NC in Figure 1.2.
4
Mar 10, 2010
Changed speed marking and timing specs to 35 ns part. Changed BGA package to 10 mm x 10mm
5
Apr 7, 2010
Added 54-TSOP package options.
6
Oct 7, 2011
Added AEC-Q100 Grade 1 product option. Max. magnetic field during write (Hmax_write ) increased
to 8000 A/m. Revised IDDW typical from110 to 152mA, max from TBD to 180mA; IDDR max from
TBD to 68mA; ISB1 typical from 11 to 9ma; ISB2 from typical 7 to 5mA.
7
Oct 28, 2011
8
August 6, 2012
9
August 27, 2013
Corrected the AEC Q-100 Grade A ordering option to be available in 54-TSOP2, not 48BGA.
9.1
Jaunary 29,
2014
Corrected minor typo in Ordering PN table.
10
April 25, 2014
AEC-Q100 removed until qualified product is available.
11
September 17,
2014
48-BGA package options moisture sensitivity level upgraded to MSL-5.
11.1
May 19, 2015
Revised Everspin contact information.
11.2
June 11, 2015
Corrected Japan Sales Office telephone number.
11.3
July 29, 2015
Minor correction to the ‘ddd’ tolerance value for the BGA Package (Note 4.)
11.4
March 11, 2016
The BGA package moisture sensitivity level rating is changed to MSL-6 in Table 4.1.
11.5
November 22,
2016
The BGA package moisture sensitivity level rating is changed to MSL-5 in Table 4.1.
11.6
May 09, 2017
11.7
March 23, 2018
Updated the Contact Us table
Added note to BGA package option products are MSL-6 only, MSL-3 qualification underway.
Fixed typo on BGA drawing: Top View incorrectly labeled Bottom View.
Figure 2.1 Power Up and Power Down Timing redrawn. Added 54-TSOP illustrations. Reformatted all parametric tables. Reformatted Table 4.1 Ordering Part Numbers.
15
7. HOW TO CONTACT US
How to Reach Us:
Home Page:
Information in this document is provided solely to enable system and software
implementers to use Everspin Technologies products. There are no express or
implied licenses granted hereunder to design or fabricate any integrated circuit or circuits based on the information in this document. Everspin Technologies reserves the right to make changes without further notice to any products
herein. Everspin makes no warranty, representation or guarantee regarding
the suitability of its products for any particular purpose, nor does Everspin
Technologies assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including
without limitation consequential or incidental damages. “Typical” parameters,
which may be provided in Everspin Technologies data sheets and/or specifications can and do vary in different applications and actual performance
may vary over time. All operating parameters including “Typicals” must be
validated for each customer application by customer’s technical experts. Everspin Technologies does not convey any license under its patent rights nor the
rights of others. Everspin Technologies products are not designed, intended,
or authorized for use as components in systems intended for surgical implant
into the body, or other applications intended to support or sustain life, or for
any other application in which the failure of the Everspin Technologies product
could create a situation where personal injury or death may occur. Should
Buyer purchase or use Everspin Technologies products for any such unintended
or unauthorized application, Buyer shall indemnify and hold Everspin Technologies and its officers, employees, subsidiaries, affiliates, and distributors
harmless against all claims, costs, damages, and expenses, and reasonable
attorney fees arising out of, directly or indirectly, any claim of personal injury
or death associated with such unintended or unauthorized use, even if such
claim alleges that Everspin Technologies was negligent regarding the design
or manufacture of the part. Everspin™ and the Everspin logo are trademarks of
Everspin Technologies, Inc. All other product or service names are the property
of their respective owners.
www.everspin.com
World Wide Information Request
WW Headquarters - Chandler, AZ
5670 W. Chandler Blvd., Suite 100
Chandler, Arizona 85226
Tel: +1-877-480-MRAM (6726)
Local Tel: +1-480-347-1111
Fax: +1-480-347-1175
support@everspin.com
orders@everspin.com
sales@everspin.com
Europe, Middle East and Africa
Everspin Europe Support
support.europe@everspin.com
Japan
Everspin Japan Support
support.japan@everspin.com
Asia Pacific
Everspin Asia Support
support.asia@everspin.com
Filename:
EST00352_MR4A16B_Datasheet_Rev11.7032318
16
