RM25C64C-BSNC-B
RM25C64C-BSNC-B
    ADESTO
    8-SOIC(0.154",3.90mm宽)
    ICEEPROM64KBIT5MHZ8SOIC
RM25C64C-BSNC-B 数据手册
RM25C64C-L 64 Kbit 1.65V Minimum Non-volatile Serial EEPROM Memory SPI Bus Preliminary Datasheet  Features  Memory array: 64 Kbit non-volatile serial EEPROM memory  Single supply voltage: 1.65V - 3.6V  Serial peripheral interface (SPI) compatible -Supports SPI modes 0 and 3  1.6 MHz maximum clock rate for normal read  10 MHz maximum clock rate for fast read  Flexible Programming            - Byte/Page Program (1 to 32 Bytes)  - Page size: 32 Bytes Low Energy Byte Write -Byte Write consuming 50 nJ Low power consumption -0.25 mA active Read current (Typical) -1 mA active Write current (Typical) -2.2 µA power down current (Typical) Fast Page Write -Page Write in 1 ms (32 byte page) -Byte Write within 25 µs Self-timed erase and write cycles Unlimited read cycles Page or chip erase capability 8-lead SOIC and TSSOP packages RoHS-compliant and halogen-free packaging Data Retention: 10 years Endurance: 100,000 write cycles Based on Adesto's proprietary CBRAM® technology Description The Mavriq™ RM25C64C-L is a 64 Kbit serial EEPROM memory device that utilizes Adesto's CBRAM® resistive technology. The memory devices use a single lowvoltage supply ranging from 1.65V to 3.6V. The Mavriq RM25C-Series family is accessed through a 4-wire SPI interface consisting of a Serial Data Input (SDI), Serial Data Output (SDO), Serial Clock (SCK), and Chip Select (CS). The maximum clock (SCK) frequency in normal read mode is 1.6MHz. In fast read mode the maximum clock frequency is 10MHz. Writing into the device can be done from 1 to 32 bytes at a time. All writing is internally self-timed. The device also features an Erase which can be performed on 32-byte pages or on the whole chip. DS-RM25C64C-L–097D–1/2018 The device has both Byte Write and Page Write capability. Page Write is 32 bytes. The Byte Write operation of Mavriq memory consumes only 10% of the energy consumed by a Byte Write operation of EEPROM devices of similar size. The Page Write operation of Mavriq memory is 4-6 times faster than the Page Write operation of similar EEPROM devices. Both random and sequential reads are available. Sequential reads are capable of reading the entire memory in one operation. Block Diagram Figure 1-1. Block Diagram VCC Status Registers & Control Logic I/O Buffers and Data Latches Page Buffer SCK SDI SDO CS Y-Decoder SPI Interface WP HOLD GND Address Latch & Counter X-Decoder 1. 32 Kb - 512 Kb CBRAM Memory RM25C64C-L DS-RM25C64C-L-097D–1/2018 2 2. Absolute Maximum Ratings Table 2-1. Absolute Maximum Ratings(1) Parameter Specification Operating ambient temp range -40°C to +85°C Storage temperature range -65°C to +150°C Input supply voltage, VCC to GND Voltage on any pin with respect to GND - 0.3V to 3.6V -0.5V to (VCC + 0.5V) ESD protection on all pins (Human Body Model) >2kV Junction temperature 125°C DC output current 5mA 1. CAUTION: Stresses greater than Absolute Maximum Ratings may cause permanent damage to the devices. These are stress ratings only, and operation of the device at these, or any other conditions outside those indicated in other sections of this specification, is not implied. Exposure to absolute maximum rating conditions for extended periods may reduce device reliability RM25C64C-L DS-RM25C64C-L–097D–1/2018 3 3. Electrical Characteristics 3.1 DC Operating Characteristics  Applicable over recommended operating range: TA = -40°C to +85° C, VCC = 1.65V to 3.6V Symbol Parameter Condition Min Typ Max Units 3.6 V 1.55 V 1.0 3 mA 0.25 0.5 mA 1 3 mA @25C 80 90 @85C 100 120 @25C 45 55 @85C 65 75 @25C 2.2 3 @85C 11 17 @25C 2.2 3 @85C 11 17 @25C 1.6 2.5 @85C 11 17 TA = ‐40°C to +85° C,  VCC = 1.65V to 3.6V VCC Supply Range VVccI VCC Inhibit  ICC1 Supply current, Fast Read 1.65 VCC= 3.3V SCK at 10 MHz SDO = Open, Read ICC2 Supply Current, Read Operation VCC= 3.3V SCK at 1.0 MHz SDO = Open, Read ICC3 Supply Current, Program or Erase VCC= 3.3V, CS = VCC Supply Current, Standby, LPSE=0 ICC4 Supply Current, Standby, LPSE=1 VCC= 3.3V, CS = VCC Supply Current, Standby, Auto Power Down enabled µA ICC5 Supply Current, Power Down VCC= 3.3V Power Down ICC6 Supply Current,  Ultra Deep Power Down Vcc = 3.3V,  Ultra Deep Power Down IOL Output Leakage SDO , CS = VCC  VIN=0V to VCC 1 µA IIL Input Leakage SCK, SDI, CS, HOLD, WP VIN=0V to VCC 1 µA VIL Input Low Voltage SCK, SDI, CS, HOLD, WP -0.3 VCC x 0.3 V VIH Input High Voltage SCK, SDI, CS, HOLD, WP VCC x 0.7 VCC + 0.3 V VOL Output Low Voltage IOL = 3.0mA 0.4 V VOH Output High Voltage IOH = -100µA VCC - 0.2 µA µA V     RM25C64C-L DS-RM25C64C-L-097D–1/2018 4  3.2 AC Operating Characteristics Applicable over recommended operating range: TA = -40°C to +85° C, VCC = 1.65V to 3.6V CL = 1 TTL Gate plus 10pF (unless otherwise noted) Symbol Parameter Max Units fSCKF SCK Clock Frequency for Fast Read Mode 0 10 MHz fSCK SCK Clock Frequency for Normal Read Mode 0 1.6 MHz fAPD SCK Clock Frequency for Auto Power Down Mode 0 1.0 MHz tRI SCK Input Rise Time 1 µs tFL SCK Input Fall Time 1 µs tSCKH SCK High Time 7.5 ns tSCKL SCK Low Time 7.5 ns tCS CS High Time 100 ns tCSS CS Setup Time 10 ns tCSH CS Hold Time 10 ns tDS Data In Setup Time 4 ns tDH Data In Hold Time 4 ns tHS HOLD Setup Time 30 ns tHD HOLD Hold Time 30 ns tOV Output Valid tOH Output Hold Time Normal Mode 0 tLZ HOLD to output Low Z 0 tHZ tDIS tPW tBP Min Typ 6.5 ns ns 200 ns HOLD to output High Z 200 ns Output Disable Time 100 ns 1 5 ms 25 100 µs 75 µs Page Write Cycle Time, 32 byte page Byte Write Cycle Time (1) tPUD Vcc Power-up Delay tRPD Exit Power Down Time 50 µs tCSLU Minimum Chip Select Low to Exit  Ultra-Deep Power-Down 20 ns tXUDPD Exit Ultra-Deep Power Down Time 70 µs tRDPD Chip Select High to Standby Mode 8 µs CIN SCK, SDI, CS, HOLD, WP VIN=0V 6 pf RM25C64C-L DS-RM25C64C-L–097D–1/2018 5 Symbol Parameter COUT SDO VIN=0V Min Typ Max Units 8 pf 100,000(2) Write Cycles Unlimited(3) Read Cycles Endurance Retention 10 Years Notes: 1. VCC must be within operating range. 2. Adesto memory products based on CBRAM technology are “Direct‐Write” memories. Endurance cycle calculations follow  JEDEC specification JESD22‐A117B. 3. Subject to expected 10‐year data retention specification. 3.3 AC Test Conditions Timing Measurement Reference Level AC Waveform VLO = 0.2V VHI = 3.4V CL = 30pF (for 1.6 MHz SCK) Input 0.5 Vcc Output 0.5 Vcc CL = 10pF (for 10 MHz SCK) 4. Timing Diagrams Figure 4-1. Synchronous Data Timing with HOLD high CS VIH tCS VIL tCSS t CSH VIH SCK tSCKH tDS SDI tSCKL VIL t DH VIH VALID IN VIL tOV VIH SDO HI-Z tOH tDIS HI-Z VIL RM25C64C-L DS-RM25C64C-L-097D–1/2018 6 Figure 4-2. Hold Timing CS t HD t HD SCK t HS t HS HOLD t HZ SDO t LZ Figure 4-3. Power-up Timing VCC VCCmax Program, Read, Erase and Write Commands Rejected VCCmin VVCCI Device Fully Accessible Device in Reset tPUD TIME RM25C64C-L DS-RM25C64C-L–097D–1/2018 7 5. Pin Descriptions and Pin-out Table 5-1. Mnemonic Pin Descriptions Pin Number Pin Name Description CS 1 Chip Select Making CS low activates the internal circuitry for device operation. Making CS high deselects the device and switches into standby mode to reduce power. When the device is not selected (CS high), data is not accepted via the Serial Data Input pin (SDI) and the Serial Data Output pin (SDO) remains in a high-impedance state. SDO 2 Serial Data Out Sends read data or status on the falling edge of SCK. WP 3 Write Protect N/A GND 4 Ground SDI 5 Serial Data In Device data input; accepts commands, addresses, and data on the rising edge of SCK. SCK 6 Serial Clock Provides timing for the SPI interface. SPI commands, addresses, and data are latched on the rising edge on the Serial Clock signal, and output data is shifted out on the falling edge of the Serial Clock signal. HOLD 7 Hold When pulled low, serial communication with the master device is paused, without resetting the serial sequence. Vcc 8 Power Power supply pin. Figure 5-1. Pin Out S SOIC, UDFN and TSSOP WLCSP (Bottom View) Pin 1 CS SDO 1 8 2 VCC 7 HOLD SPI 6. WP 3 6 SCK GND 4 5 SDI A Vcc SCK B GND SDI C CS SDO 1 2 SPI Modes Description Multiple Adesto SPI devices can be connected onto a Serial Peripheral Interface (SPI) serial bus controlled by an SPI master, such as a microcontroller, as shown in Figure 6-1, RM25C64C-L DS-RM25C64C-L-097D–1/2018 8 Figure 6-1. Connection Diagram, SPI Master and SPI Slaves SDO SPI Interface with Mode 0 or Mode 3 SDI SCK SCK SDO SPI Master (i.e. Microcontroller) SDI SPI Memory Device CS3 CS2 SCK SDO SDI SCK SDO SPI Memory Device SDI SPI Memory Device CS1 CS CS CS The Adesto RM25C family supports two SPI modes: Mode 0 (0, 0) and Mode 3 (1, 1). The difference between these two modes is the clock polarity when the SPI master is in standby mode (CS high). In Mode 0, the Serial Clock (SCK) stays at 0 during standby. In Mode 3, the SCK stays at 1 during standby. An example sequence for the two SPI modes is shown in Figure 6-2. For both modes, input data (on SDI) is latched in on the rising edge of Serial Clock (SCK), and output data (SDO) is available beginning with the falling edge of Serial Clock (SCK). Figure 6-2. SPI Modes CS Mode 0 (0,0) SCK Mode 3 (1,1) SCK SDI SDO MSB MSB RM25C64C-L DS-RM25C64C-L–097D–1/2018 9 7. Registers 7.1 Instruction Register The Adesto RM25C family uses a single 8-bit instruction register. The instructions and their operation codes are listed in Table 7-1. All instructions, addresses, and data are transferred with the MSB first, and begin transferring with the first low-to-high SCK transition after the CS pin goes low. Table 7-1. Instruction 7.2 Device Operating Instructions Description Operation  Code Address Cycles Dummy Cycles Data Cycles WRSR Write Status Register 01H 0 0 1 WR Write 1 to 32 bytes 02H 2 0 1-32 READ Read data from memory array 03H 2 0 1 to ∞ FREAD Fast Read data from data memory 0BH 2 1 1 to ∞ WRDI Write Disable 04H 0 0 0 RDSR Read Status Register 05H 0 0 1 to ∞ WREN Write Enable 06H 0 0 0 PERS Page Erase 32 bytes 42H 2 0 0 CERS Chip Erase 60H 0 0 0 C7H 0 0 0 PD Power Down B9H 0 0 0 UDPD Ultra Deep Power Down 79H 0 0 0 RES Resume from Power Down ABH 0 0 0 Status Register The Adesto RM25C family uses a single 8-bit Status Register. The Write In Progress (WIP) and Write Enable (WEL) status of the device can be determined by reading this register. The Status Register format is shown in Table 7-2 The Status Register bit definitions are shown in Table 7-3. Table 7-2. Status Register Format Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 SRWD APDE LPSE 0 BP1 BP0 WEL WIP RM25C64C-L DS-RM25C64C-L-097D–1/2018 10 Table 7-3. Bit Status Register Bit Definitions Name Description R/W Non-Volatile Bit R No 0 WIP Write In Progress “0” indicates the device is ready “1” indicates that the program/erase cycle is in progress and the device is busy 1 WEL Write Enable Latch “0” Indicates that the device is disabled “1” indicates that the device is enabled R/W No 2 BP0 3 BP1 Block Protection Bits. "0" indicates the specific blocks are not protected.  "1" indicates that the specific blocks are protected. R/W Yes 4 N/A N/A No R/W Yes R/W Yes R/W Yes Reserved. Read as “0” Low Power Standby Enable. 5 8. LPSE "0" indicates that the device will not use Low Power Standby Mode. "1" indicates that the device will use Low Power Standby Mode. 6 APDE Auto Power Down Enable. "0" indicates that the device will use Standby Mode. "1" indicates that the device will use Power Down Mode instead of Standby Mode. 7 SRWD WP pin enable. See Table 8-1. Write Protection The Adesto RM25CxxC family has two protection modes: hardware write protection, via the WP pin associated with the SRWD bit in the Status Register, and software write protection in the form of the SRWD, WEL, BP0, and BP1 bits in the Status Register. 8.1 Hardware Write Protection There are three hardware write protection features: • All write instructions must have the appropriate number of clock cycles before CS goes high or the write instruction will be ignored. • If the VCC is below the VCC Inhibit Voltage (VVccI, see DC Characteristics), all Read, Write, and Erase sequence instructions will be ignored. • The WP pin provides write protection for the Status Register. When WP is low, the Status Register is write protected if the SRWD bit in the Status Register is High. When WP is high, the Status Register is writable independent of the SRWD bit. See Table 8-1. RM25C64C-L DS-RM25C64C-L–097D–1/2018 11 Table 8-1. 8.2 Hardware Write Protection on Status Register SRWD WP Status Register 0 Low Writable 1 Low Protected 0 High Writable 1 High Writable Software Write Protection There are two software write protection features: • Before any program, erase, or write status register instruction, the Write Enable Latch (WEL) bit in the Status Register must be set to a one by execution of the Write Enable (WREN) instruction. If the WEL bit is not enabled, all program, erase, or write register instructions will be ignored. • The Block Protection bits (BP0 and BP1) allow a part or the whole memory area to be write protected.  See Table 8-2. Table 8-2. BP1 8.3 Block Write Protect Bits BP0 Protected Region RM25C64C-L Protected Address Protected Area Size 0 0 None None 0 0 1 Top ¼ 30003FFF 4K bytes 1 0 Top ½ 20003FFF 8K bytes 1 1 All 03FFF All Reducing Energy Consumption In normal operation, when the device is idle, (CS is high, no Write or Erase operation in progress), the device is in Standby Mode, waiting for the next command. To reduce device energy consumption, the Power Down or Ultra-Deep Power Down modes may be used. 8.3.1 Power Down mode Power Down mode allows the user to reduce the power of the device to its lowest power consumption state. The PD command is used to instruct the device to enter Power Down mode. All instructions given during the Power Down mode are ignored except the Resume From Power Down (RES) instruction. Therefore this mode can be used as an additional software write protection feature. RM25C64C-L DS-RM25C64C-L-097D–1/2018 12 8.3.2 Ultra-Deep Power Down mode The Ultra-Deep Power Down mode allows the device to further reduce its energy consumption compared to the existing Standby and Power Down modes by shutting down additional internal circuitry. The UDPD command is used to instruct the device to enter Ultra-Deep Power Down mode. When the device is in the Ultra-Deep Power Down mode, all commands including the Read Status Register and Resume From Power Down commands will be ignored. Since all commands will be ignored, the mode can be used as an extra protection mechanism against inadvertent or unintentional program and erase operations. Only the Exit Ultra-Deep Power Down signal sequences described in section 8-13 will bring the device out of the UltraDeep Power Down mode. 8.3.3 Auto Power Down Enable. For frequencies lower than fAPD (see AC Operating Characteristics), the APDE bit in the Status Register may be enabled. The device will then automatically enter Power Down mode instead of Standby mode when idle. (CS is high, no Write or Erase operation in progress). In this mode, the device will behave normally to all commands, and will leave Power Down mode once CS is pulled down. If Auto Power Down is enabled, and the SCK Clock Frequency is increased to a speed higher than fAPD, the device may not react as expected to the command. Before changing SCK frequency, the APDE bit in the Status Register must be disabled. Note that the PD or UDPD commands may still be used as additional software write protection features when Auto Power Down is enabled. Note that if the PD command is issued while Auto Power Down is enabled, the device will enter Power Down mode, and all instructions given will be ignored except the Resume From Power Down (RES) instruction. The device will not wake up immediately after CS is pulled down. 8.3.4 Low Power Standby Enable. For frequencies lower than fAPD (see AC Operating Characteristics), the LPSE bit in the Status Register may be enabled. The device will then automatically enter Low Power Standby mode when idle. (CS is high, no Write or Erase operation in progress). In this mode, the device will behave normally to all commands, and will leave Low Power Standby mode once CS is pulled down. If Low Power Standby Mode is enabled, and the SCK Clock Frequency is increased to a speed higher than fAPD, the device may not react as expected to the command. Before changing SCK frequency, the LPSE bit in the Status Register must be disabled. Note that the PD or UDPD commands may still be used as additional software write protection features when Low Power Standby Mode is enabled. Note that if the PD command is issued while Low Power Standby Mode is enabled, the device will enter Power Down mode, and all instructions given will be ignored except the Resume From Power Down (RES) instruction. The device will not wake up immediately after CS is pulled down. 9. Command Descriptions 9.1 WREN (Write Enable): The device powers up with the Write Enable Latch set to zero. This means that no write or erase instructions can be executed until the Write Enable Latch is set using the Write Enable (WREN) instruction. The Write Enable Latch is also set to zero automatically after any non-read instruction. Therefore, all page programming instructions and erase instructions must be preceded by a Write Enable (WREN) instruction. The sequence for the Write Enable instruction is shown in Figure 9-1. RM25C64C-L DS-RM25C64C-L–097D–1/2018 13 Figure 9-1. WREN Sequence (06h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 1 0 SCK SDI HI-Z SDO Table 9-1 is a list of actions that will automatically set the Write Enable Latch to zero when successfully executed. If an instruction is not successfully executed, for example if the CS pin is brought high before an integer multiple of 8 bits is clocked, the Write Enable Latch will not be reset. Table 9-1. Write Enable Latch to Zero Instruction/Operation Power-Up WRDI (Write Disable) WR (Write) PERS (Page Erase) CERS (Chip Erase) PD (Power Down) 9.2 WRDI (Write Disable): To protect the device against inadvertent writes, the Write Disable instruction disables all write modes. Since the Write Enable Latch is automatically reset after each successful write instruction, it is not necessary to issue a WRDI instruction following a write instruction. The WRDI instruction is independent of the status of the WP pin. The WRDI sequence is shown in Figure 9-2. Figure 9-2. WRDI Sequence (04h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 0 0 SCK SDI SDO 9.3 HI-Z RDSR (Read Status Register): The Read Status Register instruction provides access to the Status Register and indication of write protection status of the memory. RM25C64C-L DS-RM25C64C-L-097D–1/2018 14 Caution: The Write In Progress (WIP) and Write Enable Latch (WEL) indicate the status of the device. The RDSR sequence is shown in Figure 9-3. Figure 9-3. RDSR Sequence (05h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 0 1 8 9 10 11 12 13 14 15 5 4 3 2 1 0 SCK SDI HI-Z SDO 7 6 WEL WIP 9.4 WRSR (Write Status Register): The Write Status Register (WRSR) instruction allows the user to select one of three levels of protection. The memory array can be block protected (see Table 8-2) or have no protection at all. The SRWD bit (in conjunction with the WP pin) sets the write status of the Status Register (see Table 8-1). Only the BP0, BP1, APDE, LPSE and SRWD bits are writable and are nonvolatile cells. When the WP pin is low, and the SRWD bit in the Status Register is a one, a zero cannot be written to SRWD to allow the part to be writable. To set the SRWD bit to zero, the WP pin must be high. The WRSR sequence is shown in Figure 9-4. Figure 9-4. WRSR Sequence (01h) CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 3 2 1 0 SCK INSTRUCTION SDI SDO 9.5 0 0 0 0 STATUS 0 0 0 1 7 6 5 4 HI-Z READ (Read Data): Reading the Adesto RM25C family via the Serial Data Output (SDO) pin requires the following sequence: First the CS line is pulled low to select the device; then the READ op-code is transmitted via the SDI line, followed by the address to be read (A15-A0). Although not all 16 address bits are used, a full 2 bytes of address must be transmitted to the device. For the 64 Kb device, only address A0 to A12 are used; the rest are don't cares and must be set to “0”. Once the read instruction and address have been sent, any further data on the SDI line will be ignored. The data (D7-D0) at the specified address is then shifted out onto the SDO line. If only one byte is to be read, the CS line should be driven high after the byte of data comes out. This completes the reading of one byte of data. The READ sequence can be automatically continued by keeping the CS low. At the end of the first data byte the byte address is internally incremented and the next higher address data byte will be shifted out. When the highest address is reached, the address counter will roll over to the lowest address (00000), thus allowing the entire memory to be read in one continuous read cycle. The READ sequence is shown in Figure 9-5. RM25C64C-L DS-RM25C64C-L–097D–1/2018 15 Figure 9-5. Single Byte READ Sequence (03h) CS 0 1 2 3 4 5 0 0 6 7 8 9 10 11 20 21 22 23 24 25 26 27 28 29 30 31 SCK INSTRUCTION SDI 0 0 0 0 2 BYTE ADDRESS 1 1 15 14 13 3 2 1 0 DATA OUT HI-Z 9.6 7 6 5 4 3 2 1 0 FREAD (Fast Read Data): The Adesto RM25C family also includes the Fast Read Data command, which facilitates reading memory data at higher clock rates, up to 10 MHz. After the CS line is pulled low to select the device, the FREAD op-code is transmitted via the SDI line. This is followed by the 2-byte address to be read (A15-A0) and then a 1-byte dummy. For the 64 Kbit device, only address A0 to A12 are used; the rest are don't cares and must be set to "0". The next 8 bits transmitted on the SDI are dummy bits. The data (D7-D0) at the specified address is then shifted out onto the SDO line. If only one byte is to be read, the CS line should be driven high after the data comes out. This completes the reading of one byte of data. The FREAD sequence can be automatically continued by keeping the CS low. At the end of the first data byte, the byte address is internally incremented and the next higher address data byte is then shifted out. When the highest address is reached, the address counter rolls over to the lowest address (00000), allowing the entire memory to be read in one continuous read cycle. The FREAD sequence is shown in Figure 9-6. Figure 9-6. Two Byte FREAD Sequence (0Bh) CS 0 1 2 3 4 5 6 7 8 9 10 20 21 22 23 SCK INSTRUCTION SDI 0 0 0 0 2 BYTE ADDRESS 1 0 1 1 30 31 32 1 0 15 14 13 3 2 1 36 37 38 0 HI-Z SDO CS 24 25 26 7 6 27 28 29 33 34 35 39 40 41 42 43 44 45 46 47 2 1 SCK DUMMY BYTE SDI 5 4 3 2 DATA BYTE 1 OUT SDO HI-Z 7 6 5 4 3 2 DATA BYTE 2 OUT 1 0 7 6 5 4 3 0 RM25C64C-L DS-RM25C64C-L-097D–1/2018 16 9.7 WRITE (WR): Product Density Page Size (bytes) RM25C64C-L 64 Kbit 32 The Write (WR) instruction allows bytes to be written to the memory. But first, the device must be write-enabled via the WREN instruction. The CS pin must be brought high after completion of the WREN instruction; then the CS pin can be brought back low to start the WR instruction. The CS pin going high at the end of the WR input sequence initiates the internal write cycle. During the internal write cycle, all commands except the RDSR instruction are ignored. A WR instruction requires the following sequence: After the CS line is pulled low to select the device, the WR op-code is transmitted via the SDI line, followed by the byte address (A15-A0) and the data (D7-D0) to be written. For the 64 Kb device, only address A0 to A12 are used; the rest are don't cares and must be set to “0”. The internal write cycle sequence will start after the CS pin is brought high. The low-to-high transition of the CS pin must occur during the SCK low-time immediately after clocking in the D0 (LSB) data bit. The Write In Progress status of the device can be determined by initiating a Read Status Register (RDSR) instruction and monitoring the WIP bit. If the WIP bit (Bit 0) is a “1”, the write cycle is still in progress. If the WIP bit is “0”, the write cycle has ended. Only the RDSR instruction is enabled during the write cycle. The sequence of a one-byte WR is shown in Figure 9-7. Figure 9-7. One Byte Write Sequence (0Bh) CS 0 1 2 0 0 0 3 4 5 6 7 8 9 10 11 20 21 22 23 24 25 26 27 28 29 30 31 SCK INSTRUCTION SDI SDO 0 0 0 2 BYTE ADDRESS 1 0 15 14 13 3 2 1 DATA IN 0 7 6 5 4 3 2 1 0 HI-Z The Adesto RM25C family is capable of a 32-byte write operation. For the RM25C64C-L: After each byte of data is received, the six low-order address bits (A5-A0) are internally incremented by one; the high-order bits of the address will remain constant. All transmitted data that goes beyond the end of the current page are written from the start address of the same page (from the address whose 6 least significant bits [A5-A0] are all zero). If more than 32 bytes are sent to the device, previously latched data are discarded and the last 32 data bytes are ensured to be written correctly within the same page. If less than 32 data bytes are sent to the device, they are correctly written at the requested addresses without having any effects on the other bytes of the same page. The Adesto RM25C64C-L is automatically returned to the write disable state at the completion of a program cycle. The sequence for a 32byte WR is shown in Figure 9-8. Note that the Multi-Byte Write operation is internally executed by sequentially writing the words in the Page Buffer. NOTE: If the device is not write enabled (WREN) previous to the Write instruction, the device will ignore the write instruction and return to the standby state when CS is brought high. A new CS falling edge is required to re initiate the serial communication. RM25C64C-L DS-RM25C64C-L–097D–1/2018 17 Figure 9-8. WRITE Sequence (02h) CS 0 1 0 0 2 3 4 5 6 7 8 9 10 11 20 21 22 23 24 25 0 7 6 26 27 28 29 30 31 2 1 0 SCK INSTRUCTION SDI 0 0 0 2 BYTE ADDRESS 0 1 0 15 14 13 3 2 DATA BYTE 1 1 5 4 3 HI-Z SDO CS 32 33 7 6 34 35 36 37 38 39 40 41 2 1 0 7 6 42 43 44 45 46 47 2 1 0 SCK DATA BYTE 2 SDI 5 3 DATA BYTE 3 5 4 3 DATA BYTE N (N= 32,64) 7 6 5 4 3 2 1 0 HI-Z SDO 9.8 4 PER (Page Erase 32 bytes): Page Erase sets all bits inside the addressed 32-byte page to a 1. A Write Enable (WREN) instruction is required prior to a Page Erase. After the WREN instruction is shifted in, the CS pin must be brought high to set the Write Enable Latch. The Page Erase sequence is initiated by bringing the CS pin low; this is followed by the instruction code, then 2 address bytes. Any address inside the page to be erased is valid. This means the bottom six bits (A5-A0) of the address are ignored. Once the address is shifted in, the CS pin is brought high, which initiates the self-timed Page Erase function. The WIP bit in the Status Register can be read, using the RDSR instruction, to determine when the Page Erase cycle is complete. The sequence for the PER is shown in Figure 9-9. Figure 9-9. PERS Sequence (42h) CS 0 1 2 3 4 5 6 7 8 9 10 11 20 21 22 23 1 0 SCK INSTRUCTION SDI SDO 9.9 0 1 0 0 2 BYTE ADDRESS 0 0 1 0 15 14 13 3 2 HI-Z CERS (Chip Erase): Chip Erase sets all bits inside the device to a 1. A Write Enable (WREN) instruction is required prior to a Chip Erase. After the WREN instruction is shifted in, the CS pin must be brought high to set the Write Enable Latch. The Chip Erase sequence is initiated by bringing the CS pin low; this is followed by the instruction code. There are two different instruction codes for CER, 60h and C7h. Either instruction code will initiate the Chip Erase sequence. No RM25C64C-L DS-RM25C64C-L-097D–1/2018 18 address bytes are needed. Once the instruction code is shifted in, the CS pin is brought high, which initiates the selftimed Chip Erase function. The WIP bit in the Status Register can be read, using the RDSR instruction, to determine when the Chip Erase cycle is complete. The sequence for the 60h CER instruction is shown in Figure 9-10. The sequence for the C7h CER instruction is shown in Figure 9-11. Figure 9-10. CERS Sequence (60h) CS 0 1 2 3 4 5 6 7 0 1 1 0 0 0 0 0 SCK SDI HI-Z SDO Figure 9-11. CERS Sequence (C7h) CS 0 1 2 3 4 5 6 7 1 1 0 0 0 1 1 1 SCK SDI HI-Z SDO 9.10 PD (Power Down): Power Down mode allows the user to reduce the power of the device to its lowest power consumption state. All instructions given during the Power Down mode are ignored except the Resume from Power down (RES) instruction. Therefore this mode can be used as an additional software write protection feature. The Power Down sequence is initiated by bringing the CS pin low; this is followed by the instruction code. Once the instruction code is shifted in the CS pin is brought high, which initiates the PD mode. The sequence for PD is shown in Figure 9-12. Figure 9-12. PD Sequence CS 0 1 2 3 4 5 6 7 1 0 1 1 1 0 0 1 SCK SDI SDO HI-Z RM25C64C-L DS-RM25C64C-L–097D–1/2018 19 9.11 RES (Resume from Power Down): The Resume from Power Down mode is the only command that will wake the device up from the Power Down mode. All other commands are ignored. In the simple instruction command, after the CS pin is brought low, the RES instruction is shifted in. At the end of the instruction, the CS pin is brought back high. The rising edge of the SCK clock number 7 (8th rising edge) initiates the internal RES instruction. The device becomes available for Read and Write instructions 75μs after the 8th rising edge of the SCK (tPUD, see AC Characteristics). The sequence for simple RES instruction is shown in Figure 9-13. Figure 9-13. Simple RES Sequence (ABh) CS 0 1 2 3 4 5 1 0 6 7 SCK INSTRUCTION SDI 1 0 SDO 1 0 1 1 HI-Z tRPD 9.12 UDPD (Ultra-Deep Power Down): The Ultra-Deep Power Down mode allows the device to further reduce its energy consumption compared to the existing Standby and Power Down modes by shutting down additional internal circuitry. When the device is in the Ultra-Deep Power Down mode, all commands including the Read Status Register and Resume from Deep Power Down commands will be ignored. Since all commands will be ignored, the mode can be used as an extra protection mechanism against inadvertent or unintentional program and erase operations. Entering the Ultra-Deep Power Down mode is accomplished by simply asserting the CS pin, clocking in the opcode 79h, and then deasserting the CS pin. Any additional data clocked into the device after the opcode will be ignored. When the CS pin is deasserted, the device will enter the Ultra-Deep Power Down mode within the maximum time of tEUDPD. The complete opcode must be clocked in before the CS pin is deasserted; otherwise, the device will abort the operation and return to the standby mode once the CS pin is deasserted. In addition, the device will default to the standby mode after a power cycle. The Ultra-Deep Power Down command will be ignored if an internally self-timed operation such as a program or erase cycle is in progress. The sequence for UDPD is shown in Figure 9-14. RM25C64C-L DS-RM25C64C-L-097D–1/2018 20 Figure 9-14. Ultra-Deep Power Down (79h) CS tEUDPD 0 1 2 3 4 5 6 7 SCK Opcode SI 0 1 1 1 1 0 0 1 MSB High-impedance SO Active Current ICC Standby Mode Current Ultra-Deep Power-Down Mode Current 9.13 Exit Ultra-Deep Power Down To exit from the Ultra-Deep Power Down mode, any one of three operations can be performed: 9.13.1 Chip Select Toggle The CS pin must simply be pulsed by asserting the CS pin, waiting the minimum necessary tCSLU time, and then deasserting the CS pin again. To facilitate simple software development, a dummy byte opcode can also be entered while the CS pin is being pulsed; the dummy byte opcode is simply ignored by the device in this case. After the CS pin has been deasserted, the device will exit from the Ultra-Deep Power Down mode and return to the standby mode within a maximum time of tXUDPD If the CS pin is reasserted before the tXUDPD time has elapsed in an attempt to start a new operation, then that operation will be ignored and nothing will be performed. Figure 9-15. Exit Ultra-Deep Power Down (Chip Select Toggle) CS tCSLU tXUDPD SO High-impedance Active Current ICC Standby Mode Current Ultra-Deep Power-Down Mode Current 9.13.2 Chip Select Low By asserting the CS pin, waiting the minimum necessary tXUDPD time, and then clocking in the first bit of the next Opcode command cycle. If the first bit of the next command is clocked in before the tXUDPD time has elapsed, the device will exit Ultra Deep Power Down, however the intended operation will be ignored. RM25C64C-L DS-RM25C64C-L–097D–1/2018 21 Figure 9-16. Exit Ultra-Deep Power Down (Chip Select Low) CS tXUDPD SO High-impedance Active Current ICC Ultra-Deep Power-Down Mode Current 9.13.3 Power Cycling The device can also exit the Ultra Deep Power Mode by power cycling the device. The system must wait for the device to return to the standby mode before normal command operations can be resumed. Upon recovery from Ultra Deep Power Down all internal registers will be at there Power-On default state. 10. Typical Characteristics Figure 10-1. Icc4 , Auto Powerdown Average Icc Standby (Icc4, Auto Pow erdown, uA) vs Temperature (C), by Vcc 3.60 3.30 2.70 1.65 12 Voltage 11.5 11 10.5 10 9.5 9 8.5 8 7.5 7 Current 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 -40 0 23 55 85 Temperature RM25C64C-L DS-RM25C64C-L-097D–1/2018 22 Figure 10-2. Icc4, Mode 0 Average Icc Standby (Icc4, Mode 0, uA) vs Temperature (C), by Vcc Voltage 3.60 3.30 2.70 110 105 1.65 100 95 90 85 80 75 70 65 Current 60 55 50 45 40 35 30 25 20 15 10 5 0 -40 0 23 55 85 Temperature Figure 10-3. Icc4, Mode 1 Average Icc Standby (Icc4, Mode 1, uA) vs Temperature (C), by Vcc 110 105 100 95 90 Voltage 85 3.60 3.30 80 2.70 75 70 1.65 65 60 Current 55 50 45 40 35 30 25 20 15 10 5 0 -40 0 23 55 85 Temperature RM25C64C-L DS-RM25C64C-L–097D–1/2018 23 Figure 10-4. Icc5 Average PD (Icc5) Current (uA) vs Temperature (C), Lines by Vcc 3.60 3.30 2.70 12 1.65 Voltage 11.5 11 10.5 10 9.5 9 8.5 8 7.5 7 Current 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 -40 0 23 55 85 Temperature Figure 10-5. Icc6 Average UDPD (Icc6) Current (uA) vs Temperature (C), Lines by Vcc 3.60 3.30 2.70 1.65 12 Voltage 11.5 11 10.5 10 9.5 9 8.5 8 7.5 7 Current 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 -40 0 23 55 85 Temperature RM25C64C-L DS-RM25C64C-L-097D–1/2018 24 11. Ordering Information 11.1 Ordering Detail RM25C64C-LSNI-T Device Type Shipping Carrier Option RM25C = SPI serial access EEPROM B = Tube T = Tape & Reel Density Grade & Temperature 64 = 64Kbit I = Green, NiPd Au lead finish, Industrial temperature (-40-85°C) Package Option SN = 8 lead 0.150” SOIC, Narrow TA = 8 lead TSSOP MA =8 pad 2 x 3 x 0.6mm UDFN CS = Wafer Level Chip Scale Device/Die Revision C Operating Voltage L = 1.65V to 3.6V 11.2 Ordering Codes Ordering Code RM25C64C-LSNI-B RM25C64C-LSNI-T RM25C64C-LTAI-B RM25C64C-LTAI-T 1. Package Density Operating Voltage Device Grade fSCK SN Commercial TA RM25C64C-LMAI-T MA RM25C64C-LCSI-T (1) CS6 64 Kbit 1.65V to 3.6V 10 MHz (-40C to 85C) Ship Carrier Qty. Carrier Tube 100 Reel 4000 Tube 100 Reel 4000 Reel 5000 Contact Factory Contact Adesto for availability. Package Type SN 8-lead 0.150" wide, Plastic Gull Wing Small Outline (JEDEC SOIC) TA 8-lead 3 x 4.4 mm, Thin Shrink Small Outline Package MA 8-pad, 2 x 3 x 0.6mm, Thermally Enhanced Plastic Ultra Thin Dual Flat No Lead Package (UDFN) CS6 6-Ball Wafer Level Chip Scale Package RM25C64C-L DS-RM25C64C-L–097D–1/2018 25 12. Package Information 12.1 SN (JEDEC SOIC) C 1 E E1 L N Ø TOP VIEW END VIEW e b COMMON DIMENSIONS (Unit of Measure = mm) A A1 D SIDE VIEW SYMBOL MIN A 1.35 – 1.75 A1 0.10 – 0.25 b 0.31 – 0.51 C 0.17 – 0.25 D 4.80 – 5.05 E1 3.81 – 3.99 E 5.79 – 6.20 e Notes: This drawing is for general information only. Refer to JEDEC Drawing MS-012, Variation AA for proper dimensions, tolerances, datums, etc. MAX NOM NOTE 1.27 BSC L 0.40 – 1.27 Ø 0° – 8° 8/20/14 TITLE Package Drawing Contact: contact@adestotech.com 8S1, 8-lead (0.150” Wide Body), Plastic Gull Wing Small Outline (JEDEC SOIC) GPC SWB DRAWING NO. 8S1 REV. G RM25C64C-L DS-RM25C64C-L-097D–1/2018 26 MA – 2 x 3 UDFN 8 7 6 5 5 8 E2 D2 E 12.2 Chamfer or half-circle notch for Pin 1 indicator. PIN 1 ID L3 L L1 1 2 3 4 1 4 D COMMON DIMENSIONS (Unit of Measure = mm) eee SYMBOL MIN A 0.45 A1 0.00 0.60 0.05 A3 b 0.150 REF 0.20 0.30 D D2 2.00 BSC 1.50 1.60 E Notes: 1. All dimensions are in mm. Angles in degrees. 2. Bilateral coplanarity zone applies to the exposed heat sink slug as well as the terminals. E2 1.70 3.00 BSC 0.10 0.20 e 0.30 0.50 BSC L 0.40 0.45 L1 0.00 0.10 L3 0.30 eee MAX NOM – 0.50 0.50 – 0.08 8/26/14 ® Package Drawing Contact: contact@adestotech.com GPC TITLE 8MA3, 8-pad, 2 x 3 x 0.6 mm Body, 0.5 mm Pitch, 1.6 x 0.2 mm Exposed Pad, Saw Singulated YCQ Thermally Enhanced Plastic Ultra Thin Dual Flat No Lead Package (UDFN/USON) DRAWING NO. 8MA3 RM25C64C-L DS-RM25C64C-L–097D–1/2018 REV. GT 27 12.3 TA-TSSOP C 1 Pin 1 indicator this corner E1 E L1 H N L Top View End View A b A1 e A2 MIN NOM MAX A - - 1.20 A1 0.05 - 0.15 SYMBOL D Side View Notes: COMMON DIMENSIONS (Unit of Measure = mm) 1. This drawing is for general information only. Refer to JEDEC Drawing MO-153, Variation AA, for proper dimensions, tolerances, datums, etc. 2. Dimension D does not include mold Flash, protrusions or gate burrs. Mold Flash, protrusions and gate burrs shall not exceed 0.15mm (0.006in) per side. 3. Dimension E1 does not include inter-lead Flash or protrusions. Inter-lead Flash and protrusions shall not exceed 0.25mm (0.010in) per side. 4. Dimension b does not include Dambar protrusion. Allowable Dambar protrusion shall be 0.08mm total in excess of the b dimension at maximum material condition. Dambar cannot be located on the lower radius of the foot. Minimum space between protrusion and adjacent lead is 0.07mm. 5. Dimension D and E1 to be determined at Datum Plane H. NOTE A2 0.80 1.00 1.05 D 2.90 3.00 3.10 2, 5 E 6.40 BSC E1 4.30 4.40 4.50 3, 5 b 0.19 – 0.30 4 e L 0.65 BSC 0.45 L1 C 0.60 0.75 1.00 REF 0.09 - 0.20 12/8/11 TITLE Package Drawing Contact: contact@adestotech.com 8X, 8-lead 4.4mm Body, Plastic Thin Shrink Small Outline Package (TSSOP) GPC TNR DRAWING NO. REV. 8X RM25C64C-L DS-RM25C64C-L-097D–1/2018 E 28 12.4 CS6- 6-Ball WLCSP 0.015 C 4X 0.075 C A C D Pin 1 A B A1 C 0.015 0.05 C C A B C B Øb Pin 1 A 1 1 E e 2 2 A2 d2 d A TOP VIEW SIDE VIEW BALL SIDE * Dimensions are NOT to scale. COMMON DIMENSIONS (Unit of Measure = mm) SYMBOL B C 1 VCC GND CS 2 SCK SDI SDO PCB Land Pad Diameter Recommendation: Description Value Non-soldermask defined (NSMD) 225um Soldermask defined (SMD) 250um TYP A 0.35 A1 0.08 A2 0.27 E 1.28 e 0.4 Pin Assignment Matrix A MIN d 0.8 d2 0.4 D 1.47 MAX NOTE 2/29/16 ® Package Drawing Contact: contact@adestotech.com TITLE CS-6, 6-ball (3x3 Array) Wafer Level Chip Scale Package, WLCSP GPC DRAWING NO. REV. GCL CS6-SP 0A RM25C64C-L DS-RM25C64C-L–097D–1/2018 29 13. Revision History Doc. Rev. Date Comments RM25C64C-L-097A 3/2016 Initial document release. Document status changed to Preliminary. RM25C64C-L-097B 11/2016 Various formatting updates. RM25C64C-L-097C 11/2017 Added patent information. RM25C64C-L-097D 1/2018 Updated endurance specification. RM25C64C-L DS-RM25C64C-L-097D–1/2018 30 Corporate Office California | USA Adesto Headquarters 3600 Peterson Way Santa Clara, CA 95054 Phone: (+1) 408.400.0578 Email: contact@adestotech.com © 2018 Adesto Technologies. All rights reserved. / Rev.: DS-RM25C64C-L–097D–1/2018 Adesto®, the Adesto logo, CBRAM®, Mavriq™ and DataFlash® are registered trademarks or trademarks of Adesto Technologies. All other marks are the property of their respective owners. Adesto products in this datasheet are covered by certain Adesto patents registered in the United States and potentially other countries. Please refer to http://www.adestotech.com/patents for details. Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems. For Release Only Under Non-Disclosure Agreement (NDA)
RM25C64C-BSNC-B
物料型号:RM25C64C-L
器件简介: - 由Adesto Technologies生产的64 Kbit非易失性串行EEPROM存储器。 - 使用CBRAM®阻变技术。 - 支持1.65V至3.6V的单电源电压。 - 兼容串行外设接口(SPI)。
引脚分配: - CS(1号引脚):芯片选择,低电平激活。 - SDO(2号引脚):串行数据输出。 - WP(3号引脚):写保护,具体功能未在文档中说明。 - GND(4号引脚):地。 - SDI(5号引脚):串行数据输入。 - SCK(6号引脚):串行时钟,提供SPI接口的时序。 - HOLD(7号引脚):保持,低电平时暂停与主设备的串行通信。 - VCC(8号引脚):电源。
参数特性: - 支持SPI模式0和模式3。 - 正常读取模式下的最大时钟频率为1.6MHz,快速读取模式下为10MHz。 - 灵活的编程方式,支持字节/页编程,页大小为32字节。 - 低功耗,典型读电流为0.25mA,写电流为1mA,掉电电流为2.2µA。 - 快速页写入,32字节页写入时间为1ms,字节写入在25µs内完成。 - 自我计时的擦除和写入周期,无限制的读取周期,支持页擦除或芯片擦除。
功能详解: - 设备通过4线SPI接口访问,包括SDI、SDO、SCK和CS。 - 支持随机和顺序读取,顺序读取可以一次性读取整个内存。 - 具有字节写入和页写入能力,页写入为32字节。 - 与其他类似大小的EEPROM设备相比,字节写入能耗仅为10%,页写入速度是其他EEPROM设备的4-6倍。
应用信息: - 数据保留时间为10年,写入寿命为100,000次写入周期。
封装信息: - 提供8引脚SOIC和TSSOP封装。 - 符合RoHS标准,无卤素包装。
RM25C64C-BSNC-B 价格&库存
很抱歉,暂时无法提供与“RM25C64C-BSNC-B”相匹配的价格&库存,您可以联系我们找货
