RM25C32DS-LSNI-B
RM25C32DS-LSNI-B
    DIALOGSEMICONDUCTOR(戴乐格)
    SOIC8_150MIL
    ICEEPROM32KBIT1MHZ8SOIC
RM25C32DS-LSNI-B 数据手册
RM25C32DS 32-Kbit 1.65V Minimum Non-volatile Serial EEPROM SPI Bus Advance Datasheet Features  Memory array: 32Kbit non-volatile serial EEPROM memory  Single supply voltage: 1.65V - 3.6V                   Serial peripheral interface (SPI) compatible -Supports SPI modes 0 and 3 1.6 MHz maximum clock rate for normal read 10 MHz maximum clock rate for fast read Flexible Programming - Byte/Page Program (1 to 32Bytes) - Page size: 32 Bytes 64-byte, One-Time Programmable (OTP) Security Register - 32 bytes factory programmed with a unique identifier - 32 bytes user programmable Low Energy Byte Write -Byte Write consuming 50 nJ Low power consumption -0.20 mA active Read current (Typical) -0.7 mA active Write current (Typical) -0.5 µA ultra deep power-down current Auto Ultra-Deep Power-Down -Device can enter Ultra-Deep Power-Down automatically after finishing a Write operation Fast write -Page Write in 1.5 ms (32 byte page) -Byte Write within 60 µs Industry’s lowest read cycle latency Unlimited read cycles Hardware reset Page or chip erase capability 8-lead SOIC, TSSOP and UDFN packages RoHS-compliant and halogen-free packaging Data Retention: >40 years at 125°C Endurance: 100,000 write cycles (for both byte and page write cycles) - No degradation across temperature range No data loss under UV exposure on bare die or WLCSP Based on Adesto's proprietary CBRAM® technology Description The Adesto® RM25C32DS is a 32Kbit, serial EEPROM memory device that utilizes Adesto's CBRAM® resistive memory technology. The memory devices use a single low-voltage supply ranging from 1.65V to 3.6V. DS-RM25C32DS–124C–11/2017 The RM25C32DS is accessed through a 4-wire SPI interface consisting of a Serial Data Input (SDI), Serial Data Output (SDO), Serial Clock (SCK), and Chip Select (CS). The maximum clock (SCK) frequency in normal read mode is 1.6MHz. In fast read mode the maximum clock frequency is 20MHz. Adesto's EEPROM endurance can be as much as 40X higher than industry standard EEPROM devices operating in byte write mode at 85°C. Unlike EEPROMs based on floating gate technology (which require read-modify-write on a whole page for every write operation) CBRAM write endurance is based on the capability to write each byte individually, irrespective of whether the user writes single bytes or an entire page. Additionally, unlike floating gate technology, CBRAM does not experience any degradation of endurance across the full temperature range. By contrast, in order to modify a single byte, most EEPROMs modify and write full pages of 32, 64 or 128 bytes. This provides significantly less endurance for floating gate devices used in byte write mode when compared to page write mode. The device supports direct write eliminating the need to pre-erase. Writing into the device can be done from 1 to 32 bytes at a time. All writing is internally self-timed. For compatibility with other devices, the device also features an Erase function which can be performed on 32-byte pages or on the whole chip. The device has both Byte Write and Page Write capability. Page Write is from 1 to 32 bytes. The Byte Write operation of CBRAM consumes only 10% of the energy consumed by a Byte Write operation of EEPROM devices of similar size. The Page Write operation of CBRAM is 4-6 times faster than the Page Write operation of similar EEPROM devices. Both random and sequential reads are available. Sequential reads are capable of reading the entire memory in one operation. RM25C32DS DS-RM25C32DS–124C–11/2017 2 Block Diagram Figure 1-1. Block Diagram VCC Status Registers & Control Logic I/O Buffers and Data Latches Page Buffer SCK SDI SDO CS Y-Decoder SPI Interface WP HOLD GND Address Latch & Counter X-Decoder 1. 32 Kb CBRAM Memory RM25C32DS DS-RM25C32DS–124C–11/2017 3 2. Absolute Maximum Ratings Table 2-1. Absolute Maximum Ratings(1) Parameter Specification Operating ambient temp range -40°C to +85°C Storage temperature range -65°C to +150°C Input supply voltage, VCC to GND Voltage on any pin with respect to GND - 0.3V to 3.6V -0.5V to (VCC + 0.5V) ESD protection on all pins (Human Body Model) >2kV Junction temperature 125°C DC output current 5mA 1. CAUTION: Stresses greater than Absolute Maximum Ratings may cause permanent damage to the devices. These are stress ratings only, and operation of the device at these, or any other conditions outside those indicated in other sections of this specification, is not implied. Exposure to absolute maximum rating conditions for extended periods may reduce device reliability. RM25C32DS DS-RM25C32DS–124C–11/2017 4 3. Electrical Characteristics 3.1 DC Operating Characteristics Applicable over recommended operating range: TA = -40°C to +85° C, VCC = 1.65V to 3.6V Symbol Parameter Condition Min Typ Max Units 3.6 V 1.55 V 0.4 0.6 mA TA = ‐40°C to +85° C,  VCC = 1.65V to 3.6V VCC Supply Range (1) VVccI VCC Inhibit ICC1 Supply current, Fast Read ICC2 Supply Current, Read Operation VCC= 3.3V SCK at 1.0 MHz SDO = Open, Read 0.18 0.2 mA ICC3 Supply Current, Program or Erase VCC= 3.3V, CS = VCC 0.7 1.3 mA @25C 71 77 @85C 89 97 @25C 34 39 @85C 52 61 @25C 1.6 2.7 @85C 9 12 @25C 1.6 2.8 @85C 9 12 @25C 0.04 0.15 @85C 0.5 0.7 1.65 VCC= 3.3V SCK at 10 MHz SDO = Open, Read Supply Current, Standby, LPSE=0 ICC4 Supply Current, Standby, LPSE=1 VCC= 3.3V, CS = VCC Supply Current, Standby, Auto Power Down enabled 1. µA ICC5 Supply Current, Power Down VCC= 3.3V Power Down ICC6 Supply Current, Ultra Deep Power Down Vcc = 3.3V, Ultra Deep Power Down IIL Input Leakage SCK, SDI, CS, HOLD, WP VIN=0V to VCC 1 µA IOL Output Leakage SDO , CS = VCC  VIN=0V to VCC 1 µA VIL Input Low Voltage SCK, SDI, CS, HOLD, WP -0.3 VCC x 0.3 V VIH Input High Voltage SCK, SDI, CS, HOLD, WP VCC x 0.7 VCC + 0.3 V VOL Output Low Voltage IOL = 3.0mA 0.4 V VOH Output High Voltage IOH = -100µA VCC - 0.2 µA µA V A low ESR 100nF capacitor should be connected between each supply pin and GND. RM25C32DS DS-RM25C32DS–124C–11/2017 5 3.2 AC Operating Characteristics Applicable over recommended operating range: TA = -40°C to +85° C, VCC = 1.65V to3.6V. CL = 1 TTL Gate plus 10pF (unless otherwise noted) 1. Symbol Parameter fSCKF SCK Clock Frequency for Fast Read Mode fSCK Min Typ Max Units 0 10 MHz SCK Clock Frequency for Normal Read Mode 0 1.6 MHz fAPD SCK Clock Frequency for Auto Power-Down Mode 0 1.0 MHz tRI SCK Input Rise Time 1 µs tFL SCK Input Fall Time 1 µs tSCKH SCK High Time 7.5 ns tSCKL SCK Low Time 7.5 ns tCS CS High Time 100 ns tCL CS Low Time 100 ns tCSS CS Setup Time 10 ns tCSH CS Hold Time 10 ns tDS Data In Setup Time 4 ns tDH Data In Hold Time 4 ns tHS HOLD Setup Time 30 ns tHD HOLD Hold Time 30 ns tOV Output Valid tOH Output Hold Time Normal Mode 0 tLZ HOLD to output Low Z 0 tHZ 6.5 ns ns 200 ns HOLD to output High Z 200 ns tDIS Output Disable Time 100 ns tPW Page Write Cycle Time, 32 byte page (up to 30K write cycles) 1.5 Page Write Cycle Time, 32 byte page (up to 100K write cycles) 9 tBP Byte Write Cycle Time 60 tPUD Vcc Power-up Delay (1) tRPD Exit Power-Down Time 50 µs tRESET Exit Ultra-Deep Power-Down Time 70 µs tRDPD Chip Select High to Standby Mode 8 µs CIN SCK, SDI, CS, HOLD, WP VIN=0V 6 pF COUT SDO VIN=0V 8 pF 2.5 ms 100 µs 75 µs Endurance 100,000 (2) Write Cycles Retention 40 Years VCC must be within operating range. RM25C32DS DS-RM25C32DS–124C–11/2017 6 2. Adesto memory products based on CBRAM technology are “Direct‐Write” memories. Endurance cycle calculations follow  JEDEC specification JESD22‐A117B. Endurance data characterized at 2.5V, +85° C. Endurance specification is identical for both  byte and page write (unlike current EEPROM technologies where byte write operations result in lower endurance). 3.3 AC Test Conditions Timing Measurement Reference Level AC Waveform VLO = 0.2V VHI = 3.4V CL = 30pF (for 1.6 MHz SCK) Input 0.5 Vcc Output 0.5 Vcc CL = 10pF (for 10 MHz SCK) 4. Timing Diagrams Figure 4-1. Synchronous Data Timing CS VIH tCS VIL tCSS t CSH VIH tSCKH SCK tDS SDI tSCKL VIL t DH VIH VALID IN VIL tOV VIH SDO tOH HI-Z tDIS HI-Z VIL Figure 4-2. Hold Timing CS t HD t HD SCK t HS t HS HOLD t HZ SDO t LZ RM25C32DS DS-RM25C32DS–124C–11/2017 7 Figure 4-3. Power-up Timing VCC VCCmax Program, Read, Erase and Write Commands Rejected VCCmin Device Fully Accessible Device in Reset VVCCI tPUD TIME 5. Pin Descriptions and Pin-out Table 5-1. Mnemonic CS Pin Descriptions Pin Number 1 Pin Name Chip Select Description Making CS low activates the internal circuitry for device operation. Making CS high deselects the device and switches into standby mode to reduce power. When the device is not selected (CS high), data is not accepted via the Serial Data Input pin (SDI) and the Serial Data Output pin (SDO) remains in a high-impedance state. To minimize power consumption, the master should ensure that this pin always has a valid logic level. SDO 2 Serial Data Out Sends read data or status on the falling edge of SCK. A pull-up resistor, connected only when the device is in Ultra-Deep PowerDown mode, ensures that the SDO line always has a valid logic value. WP 3 Write Protect N/A GND 4 Ground SDI 5 Serial Data In Device data input; accepts commands, addresses, and data on the rising edge of SCK. To minimize power consumption, the master should ensure that this pin always has a valid logic level. RM25C32DS DS-RM25C32DS–124C–11/2017 8 Mnemonic Pin Number SCK 6 Pin Name Description Serial Clock Provides timing for the SPI interface. SPI commands, addresses, and data are latched on the rising edge on the Serial Clock signal, and output data is shifted out on the falling edge of the Serial Clock signal. To minimize power consumption, the master should ensure that this pin always has a valid logic level. HOLD 7 Hold When pulled low, serial communication with the master device is paused, without resetting the serial sequence. Vcc 8 Power Power supply pin. Figure 5-1. Pin Out SOIC, UDFN and TSSOP CS 1 SDO 2 8 VCC 7 HOLD SPI WP 3 6 SCK GND 4 5 SDI RM25C32DS DS-RM25C32DS–124C–11/2017 9 6. SPI Modes Description Multiple Adesto SPI devices can be connected onto a Serial Peripheral Interface (SPI) serial bus controlled by an SPI master, such as a microcontroller, as shown in Figure 6-1. Figure 6-1. Connection Diagram, SPI Master and SPI Slaves SDO SPI Interface with Mode 0 or Mode 3 SDI SCK SCK SDO SPI Master (i.e. Microcontroller) SDI SPI Memory Device CS3 CS2 SCK SDO SDI SCK SDO SPI Memory Device SDI SPI Memory Device CS1 CS CS CS The Adesto RM25C32DS supports two SPI modes: Mode 0 (0, 0) and Mode 3 (1, 1). The difference between these two modes is the clock polarity when the SPI master is in standby mode (CS high). In Mode 0, the Serial Clock (SCK) stays at 0 during standby. In Mode 3, the SCK stays at 1 during standby. An example sequence for the two SPI modes is shown in Figure 6-2. For both modes, input data (on SDI) is latched in on the rising edge of Serial Clock (SCK), and output data (SDO) is available beginning with the falling edge of Serial Clock (SCK). Figure 6-2. SPI Modes CS Mode 0 (0,0) SCK Mode 3 (1,1) SCK SDI SDO MSB MSB RM25C32DS DS-RM25C32DS–124C–11/2017 10 7. Registers 7.1 Instruction Register The Adesto RM25C32DS uses a single 8-bit instruction register. The instructions and their operation codes are listed in Table 7-1. All instructions, addresses, and data are transferred with the MSB first, and begin transferring with the first low-to-high SCK transition after the CS pin goes low. Table 7-1. Instruction 7.2 Device Operating Instructions Description Operation Code Address Cycles Dummy Cycles Data Cycles WRSR Write Status Register 01H 0 0 1 WR Write 1 to 32 bytes 02H 2 0 1-32 READ Read data from memory array 03H 2 0 1 to ∞ FREAD Fast Read data from data memory 0BH 2 1 1 to ∞ WRDI Write Disable 04H 0 0 0 RDSR Read Status Register 05H 0 0 1 to ∞ WREN Write Enable 06H 0 0 0 PERS Page Erase 32 bytes 42H 2 0 0 CERS Chip Erase 60H 0 0 0 C7H 0 0 0 WRSR2 Write Status Register2 31H 0 0 1 PD Power-Down B9H 0 0 0 ROTPSR Read the OTP Security Register 77H 0 0 1-64 UDPD Ultra-Deep PowerDown 79H 0 0 0 POTPSR Programming the OTP Security Register 9BH 0 0 3 RES Resume from Power-Down ABH 0 0 0 Status Register Byte 1 The Adesto RM25C32DS uses a 2-byte Status Register. The Write In Progress (WIP) and Write Enable (WEL) status of the device can be determined by reading the first byte of this register. The non-volatile configuration bits are also in the first byte. The Status Register can be read at any time, including during an internally self-timed write operation. RM25C32DS DS-RM25C32DS–124C–11/2017 11 The Status Register Byte 1 format is shown in Table 7-2. The Status Register Byte 1 bit definitions are shown in Table 73. Table 7-2. Status Register Byte 1 Format Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 SRWD APDE LPSE 0 BP1 BP0 WEL WIP Table 7-3. Bit Status Register Byte 1 Bit Definitions Name Description Write In Progress “0” indicates the device is ready “1” indicates that the program/erase cycle is in progress and the device is busy R/W Non-Volatile Bit R No R/W No 0 WIP 1 WEL “0” Indicates that the device is disabled “1” indicates that the device is enabled 2 BP0 3 BP1 Block Protection Bits. "0" indicates the specific blocks are not protected. "1" indicates that the specific blocks are protected. R/W Yes 4 Ultra-Deep Power-Down Status. Read as “0” if device is in Standby or in an active read/write operation, Read as UDPD “1” if device is in Ultra-Deep Power-Down. Reading this bit after power-up or after exiting Ultra-Deep Power-Down will indicate when the device is ready for operation. R No 5 LPSE R/W Yes 6 Auto Power-Down Enable. "0" indicates that the device will use Standby Mode. APDE "1" indicates that the device will use Power-Down Mode instead of Standby Mode. R/W Yes 7 SRWD R/W Yes Write Enable Latch Low Power Standby Enable. 7.3 "0" indicates that the device will not use Low Power Standby Mode. "1" indicates that the device will use Low Power Standby Mode. WP pin enable. See Table 8-1. Status Register Byte 2 The Adesto RM25C32DS uses the second byte in the Status Register to hold volatile configuration bits. The Status Register Byte 2 format is shown in table Table 7-4. The Status Register Byte 2 bit definitions are shown in table Table 75. Table 7-4. Status Register Byte 2 Format Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 0 0 0 0 0 0 SLOWOSC AUDPD RM25C32DS DS-RM25C32DS–124C–11/2017 12 Table 7-5. Bit Status Register Byte 2 Bit Definitions Name Description R/W Non-Volatile Bit R/W No R/W No Auto Ultra-Deep Power-Down Mode after Write Operation 0 AUDP D “1” specifies that the device will enter the Ultra-Deep Power-Down mode after a Write operation is completed. “0” specifies that the device will enter the Standby mode after a Write operation is completed. Slow Oscillator During Write Operation 1 8. "1" specifies that during the self-times Write operation the device will periodically SLOW slow down on-chip oscillator. OSC "0" specifies that during the self-times Write operation the device will not slow down on-chip oscillator 2 N/A Reserved. Read as “0” N/A No 3 N/A Reserved. Read as “0” N/A No 4 N/A Reserved. Read as “0” N/A No 5 N/A Reserved. Read as “0” N/A No 6 N/A Reserved. Read as “0” N/A No 7 N/A Reserved. Read as “0” N/A No Write Protection The Adesto RM25C32DS has two protection modes: hardware write protection, via the WP pin associated with the SRWD bit in the Status Register, and software write protection in the form of the SRWD, WEL, BP0, and BP1 bits in the Status Register. 8.1 Hardware Write Protection There are three hardware write protection features: • All write instructions must have the appropriate number of clock cycles before CS goes high or the write instruction will be ignored. • If the VCC is below the VCC Inhibit Voltage (VVccI, see DC Characteristics), all Read, Write, and Erase sequence instructions will be ignored. • The WP pin provides write protection for the Status Register. When WP is low, the Status Register is write protected if the SRWD bit in the Status Register is High. When WP is high, the Status Register is writable independent of the SRWD bit. See Table 8-1. RM25C32DS DS-RM25C32DS–124C–11/2017 13 Table 8-1. 8.2 Hardware Write Protection on Status Register SRWD WP Status Register 0 Low Writable 1 Low Protected 0 High Writable 1 High Writable Software Write Protection There are two software write protection features: • Before any program, erase, or write status register instruction, the Write Enable Latch (WEL) bit in the Status Register must be set to a one by execution of the Write Enable (WREN) instruction. If the WEL bit is not enabled, all program, erase, or write register instructions will be ignored. • The Block Protection bits (BP0 and BP1) allow a part or the whole memory area to be write protected. See Table 8-2. Table 8-2. BP1 9. Block Write Protect Bits BP0 Protected Region RM25C32DS Protected Address Protected Area Size 0 0 None None 0 0 1 Top ¼ 6000-7FFF 8K bytes 1 0 Top ½ 4000-7FFF 16K bytes 1 1 All 0-7FFF All Reducing Energy Consumption In normal operation, when the device is idle, (CS is high, no Write or Erase operation in progress), the device is in Standby Mode, waiting for the next command. To reduce device energy consumption, the Power-Down or Ultra-Deep Power-Down modes may be used. To minimize power consumption, the master should ensure that the SCK, SDI and CS pins always has a valid logic level, these pins should not be left floating when the device is in Standby, Power-Down or Ultra-Deep Power-Down modes. 9.1 Power-Down Mode Power-Down mode allows the user to reduce the power of the device to its lowest power consumption state. The PD command is used to instruct the device to enter Power-Down mode. All instructions given during the Power-Down mode are ignored except the Resume From Power-Down (RES) instruction. Therefore this mode can be used as an additional software write protection feature. 9.2 Ultra-Deep Power-Down Mode The Ultra-Deep Power-Down mode allows the device to further reduce its energy consumption compared to the existing Standby and Power-Down modes by shutting down additional internal circuitry. The UDPD command is used to instruct the device to enter Ultra-Deep Power-Down mode. RM25C32DS DS-RM25C32DS–124C–11/2017 14 When the device is in the Ultra-Deep Power-Down mode, all commands including the Read Status Register and Resume From Power-Down commands will be ignored. Since all commands will be ignored, the mode can be used as an extra protection mechanism against inadvertent or unintentional program and erase operations. To test if the device is in Ultra-Deep Power-Down mode without risk of bringing it out of Ultra-Deep Power-Down mode, use the Read Status Register Byte 1 instruction. The UDPD bit in Status Register Byte 1 will be 1 (pulled high by the internal pull-up resistor) if the device is in Ultra-Deep Power-Down mode, 0 otherwise. Only the Exit Ultra-Deep Power-Down signal sequences described in Section 10.15 will bring the device out of the UltraDeep Power-Down mode. 9.3 Auto Ultra-Deep Power-Down Mode after Write Operation The Auto Ultra-Deep Power-Down Mode after Write Operation allows the device to further reduce its energy consumption by automatically entering the Ultra-Deep Power-Down Mode after completing an internally timed Write operation. The operation can be any one of the commands WR (Write), or WRSR (Write Status Register). Note that the WRSR2 command does not cause the device to go into Ultra-Deep Power-Down Mode. Only the Exit Ultra-Deep Power-Down signal sequences described in Section 10.15 will bring the device out of the UltraDeep Power-Down Mode. 9.4 Auto Power-Down Enable For frequencies lower than fAPD (see AC Operating Characteristics), the APDE bit in the Status Register may be enabled. The device will then automatically enter Power-Down mode instead of Standby mode when idle. (CS is high, no Write or Erase operation in progress). In this mode, the device will behave normally to all commands, and will leave Power-Down mode once CS is pulled down. If Auto Power-Down is enabled, and the SCK Clock Frequency is increased to a speed higher than fAPD, the device may not react as expected to the command. Before changing SCK frequency, the APDE bit in the Status Register must be disabled. Note that the PD or UDPD commands may still be used as additional software write protection features when Auto Power-Down is enabled. Note that if the PD command is issued while Auto Power-Down is enabled, the device will enter Power-Down mode, and all instructions given will be ignored except the Resume From Power-Down (RES) instruction. The device will not wake up immediately after CS is pulled down. 9.5 Low Power Standby Enable For frequencies lower than fAPD (see AC Operating Characteristics), the LPSE bit in the Status Register may be enabled. The device will then automatically enter Low Power Standby mode when idle. (CS is high, no Write or Erase operation in progress). In this mode, the device will behave normally to all commands, and will leave Low Power Standby mode once CS is pulled down. If Low Power Standby Mode is enabled, and the SCK Clock Frequency is increased to a speed higher than fAPD, the device may not react as expected to the command. Before changing SCK frequency, the LPSE bit in the Status Register must be disabled. Note that the PD or UDPD commands may still be used as additional software write protection features when Low Power Standby Mode is enabled. Note that if the PD command is issued while Low Power Standby Mode is enabled, the device will enter Power-Down mode, and all instructions given will be ignored except the Resume From Power-Down (RES) instruction. The device will not wake up immediately after CS is pulled down. RM25C32DS DS-RM25C32DS–124C–11/2017 15 9.6 Slow Oscillator During Write Operation The Slow Oscillator During Write Operation mode allows the device to further reduce its average current consumption by periodically slowing down the internal oscillator. This creates a duty cycle effect with time periods of high activity followed by timer periods of low activity. While this operating mode will increase the effective Write time, the average current over this Write time will be lower compared to the mode without this feature. 9.7 Exit Ultra-Deep Power-Down mode Only the Exit Ultra-Deep Power-Down signal sequences described in Section 10.15 will bring the device out of the UltraDeep Power-Down mode. 10. Command Descriptions 10.1 WREN (Write Enable, 06h): The device powers up with the Write Enable Latch set to zero. This means that no write or erase instructions can be executed until the Write Enable Latch is set using the Write Enable (WREN) instruction. The Write Enable Latch is also set to zero automatically after any non-read instruction. Therefore, all page programming instructions and erase instructions must be preceded by a Write Enable (WREN) instruction. The sequence for the Write Enable instruction is shown in Figure 10-1. Figure 10-1. WREN Sequence (06h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 1 0 SCK SDI SDO HI-Z Table 10-1 is a list of actions that will automatically set the Write Enable Latch to zero when successfully executed. If an instruction is not successfully executed, for example if the CS pin is brought high before an integer multiple of 8 bits is clocked, the Write Enable Latch will not be reset. Table 10-1. Write Enable Latch to Zero Instruction/Operation Power-Up WRDI (Write Disable) WR (Write) WRSR (Write Status Register) WRSR2 (Write Status Register2) RM25C32DS DS-RM25C32DS–124C–11/2017 16 Instruction/Operation PERS (Page Erase) CERS (Chip Erase) PD (Power-Down) 10.2 WRDI (Write Disable, 04h): To protect the device against inadvertent writes, the Write Disable instruction disables all write modes. Since the Write Enable Latch is automatically reset after each successful write instruction, it is not necessary to issue a WRDI instruction following a write instruction. The WRDI instruction is independent of the status of the WP pin. The WRDI sequence is shown in Figure 10-2. Figure 10-2. WRDI Sequence (04h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 0 0 SCK SDI HI-Z SDO 10.3 RDSR (Read Status Register Byte 1, 05h): The Read Status Register Byte 1 instruction provides access to the Status Register and indication of write protection status of the memory. Caution: The Write In Progress (WIP) and Write Enable Latch (WEL) indicate the status of the device. The RDSR sequence is shown in Figure 10-3. Figure 10-3. RDSR Sequence (05h) CS 0 1 2 3 4 5 6 7 0 0 0 0 0 1 0 1 8 9 10 11 12 13 5 4 3 2 14 15 1 0 SCK SDI SDO HI-Z 7 6 WEL WIP 10.4 WRSR (Write Status Register Byte 1, 01h): The Write Status Register (WRSR) instruction allows the user to select one of three levels of protection. The memory array can be block protected (see Table 8-2) or have no protection at all. The SRWD bit (in conjunction with the WP pin) sets the write status of the Status Register (see Table 8-1). RM25C32DS DS-RM25C32DS–124C–11/2017 17 Only the BP0, BP1, APDE, LPSE and SRWD bits are writable and are nonvolatile cells. When the WP pin is low, and the SRWD bit in the Status Register is a one, a zero cannot be written to SRWD to allow the part to be writable. To set the SRWD bit to zero, the WP pin must be high. The WRSR sequence is shown in Figure 10-4. Figure 10-4. WRSR Sequence (01h) CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 3 2 1 0 SCK INSTRUCTION 0 SDI 0 0 0 0 0 1 7 6 5 4 HI-Z SDO 10.5 0 STATUS WRSR2 (Write Status Register Byte 2, 31h): The Write Status Register Byte 2 (WRSR2) instruction allows the user to set or clear the SLOWOSC or AUDPD bits. The user must set the WEL bit before issuing this command. Once the device accepts the WRSR2 command the WIP bit will be set to indicate that the device is busy. Once the device completes the operation, the WEL and WIP bits will be automatically cleared. The WRSR sequence is shown in Figure 10-5. Figure 10-5. WRSR2 Sequence (31h) CS 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 3 2 1 0 SCK INSTRUCTION SDI 0 SDO 10.6 0 1 1 STATUS 0 0 0 1 7 6 5 4 HI-Z READ (Read Data, 03h): Reading the Adesto RM25C32DS via the Serial Data Output (SDO) pin requires the following sequence: First the CS line is pulled low to select the device; then the READ op-code is transmitted via the SDI line, followed by the address to be read (A15-A0). Although not all 16 address bits are used, a full 2 bytes of address must be transmitted to the device. For the 32Kb device, only address A0 to A14 are used; the rest are don't cares and must be set to “0”. Once the read instruction and address have been sent, any further data on the SDI line will be ignored. The data (D7-D0) at the specified address is then shifted out onto the SDO line. If only one byte is to be read, the CS line should be driven high after the byte of data comes out. This completes the reading of one byte of data. The READ sequence can be automatically continued by keeping the CS low. At the end of the first data byte the byte address is internally incremented and the next higher address data byte will be shifted out. When the highest address is reached, the address counter will roll over to the lowest address (00000), thus allowing the entire memory to be read in one continuous read cycle. The READ sequence is shown in Figure 10-6. RM25C32DS DS-RM25C32DS–124C–11/2017 18 Figure 10-6. Single Byte READ Sequence (03h) CS 0 1 2 3 4 5 0 0 6 7 8 9 10 11 20 21 22 23 24 25 26 27 28 29 30 31 SCK INSTRUCTION SDI 0 0 0 0 2 BYTE ADDRESS 1 1 15 14 13 3 2 1 0 DATA OUT HI-Z 10.7 7 6 5 4 3 2 1 0 FREAD (Fast Read Data, 0Bh): The Adesto RM25C32DS also includes the Fast Read Data command, which facilitates reading memory data at higher clock rates, up to 10 MHz. After the CS line is pulled low to select the device, the FREAD op-code is transmitted via the SDI line. This is followed by the 2-byte address to be read (A15-A0) and then a 1-byte dummy. For the 32-Kbit device, only address A0 to A14 are used; the rest are don't cares and must be set to "0". The next 8 bits transmitted on the SDI are dummy bits. The data (D7-D0) at the specified address is then shifted out onto the SDO line. If only one byte is to be read, the CS line should be driven high after the data comes out. This completes the reading of one byte of data. The FREAD sequence can be automatically continued by keeping the CS low. At the end of the first data byte, the byte address is internally incremented and the next higher address data byte is then shifted out. When the highest address is reached, the address counter rolls over to the lowest address (00000), allowing the entire memory to be read in one continuous read cycle. The FREAD sequence is shown in Figure 10-7. Figure 10-7. Two Byte FREAD Sequence (0Bh) CS 0 1 2 3 4 5 6 7 8 9 10 20 21 22 23 SCK INSTRUCTION SDI 0 0 0 0 2 BYTE ADDRESS 1 0 1 1 30 31 32 1 0 15 14 13 3 2 1 36 37 38 0 HI-Z SDO CS 24 25 26 7 6 27 28 29 33 34 35 39 40 41 42 43 44 45 46 47 2 1 SCK DUMMY BYTE SDI 5 4 3 2 DATA BYTE 1 OUT SDO HI-Z 7 6 5 4 3 2 DATA BYTE 2 OUT 1 0 7 6 5 4 3 0 RM25C32DS DS-RM25C32DS–124C–11/2017 19 10.8 WRITE (Write Data, 02h): Product Density Page Size (bytes) RM25C32CDS 32 Kbit 32 The Write (WR) instruction allows bytes to be written to the memory. But first, the device must be write-enabled via the WREN instruction. The CS pin must be brought high after completion of the WREN instruction; then the CS pin can be brought back low to start the WR instruction. The CS pin going high at the end of the WR input sequence initiates the internal write cycle. During the internal write cycle, all commands except the RDSR instruction are ignored. A WR instruction requires the following sequence: After the CS line is pulled low to select the device, the WR op-code is transmitted via the SDI line, followed by the byte address (A15-A0) and the data (D7-D0) to be written. For the 32Kb device, only address A0 to A14 are used; the rest are don't cares and must be set to “0”. The internal write cycle sequence will start after the CS pin is brought high. The low-to-high transition of the CS pin must occur during the SCK low-time immediately after clocking in the D0 (LSB) data bit. The Write In Progress status of the device can be determined by initiating a Read Status Register (RDSR) instruction and monitoring the WIP bit. If the WIP bit (Bit 0) is a “1”, the write cycle is still in progress. If the WIP bit is “0”, the write cycle has ended. Only the RDSR instruction is enabled during the write cycle. The sequence of a one-byte WR is shown in Figure 10-8. Figure 10-8. One Byte Write Sequence (0Bh) CS 0 1 2 0 0 0 3 4 5 6 7 8 9 10 11 20 21 22 23 24 25 26 27 28 29 30 31 SCK INSTRUCTION SDI SDO 0 0 0 2 BYTE ADDRESS 1 0 15 14 13 3 2 1 DATA IN 0 7 6 5 4 3 2 1 0 HI-Z The Adesto RM25C32DS is capable of a 32-byte write operation. For the RM25C32DS: After each byte of data is received, the six low-order address bits (A5-A0) are internally incremented by one; the high-order bits of the address will remain constant. All transmitted data that goes beyond the end of the current page are written from the start address of the same page (from the address whose 6 least significant bits [A5-A0] are all zero). If more than 32 bytes are sent to the device, previously latched data are discarded and the last 32 data bytes are ensured to be written correctly within the same page. If less than 32 data bytes are sent to the device, they are correctly written at the requested addresses without having any effects on the other bytes of the same page. The Adesto RM25C32DS is automatically returned to the write disable state at the completion of a program cycle. The sequence for a 32 byte WR is shown in Figure 10-9. Note that the Multi-Byte Write operation is internally executed by sequentially writing the words in the Page Buffer. NOTE: If the device is not write enabled (WREN) previous to the Write instruction, the device will ignore the write instruction and return to the standby state when CS is brought high. A new CS falling edge is required to re initiate the serial communication. RM25C32DS DS-RM25C32DS–124C–11/2017 20 Figure 10-9. WRITE Sequence (02h) CS 0 1 0 0 2 3 4 5 6 7 8 9 10 11 20 21 22 23 24 25 0 7 6 26 27 28 29 30 31 2 1 0 SCK INSTRUCTION SDI 0 0 0 0 2 BYTE ADDRESS 1 0 15 14 13 3 2 DATA BYTE 1 1 5 4 3 HI-Z SDO CS 32 33 7 6 34 35 36 37 38 39 40 41 2 1 0 7 6 42 43 44 45 46 47 2 1 0 SCK DATA BYTE 2 SDI 5 3 DATA BYTE 3 5 4 3 DATA BYTE N (N= 32,64) 7 6 5 4 3 2 1 0 HI-Z SDO 10.9 4 OTP Security Register The RM25C32DS device contains a specialized One-Time Programmable Security Register that can be used for purposes such as unique device serialization or locked key storage. The register is comprised of a total of 64 bytes that is divided into two portions. The first 32 bytes (byte locations 0 through 31) of the Security Register are allocated as an One-Time Programmable space. Once these 32 bytes have been programmed, they cannot be erased or reprogrammed. The remaining 32 bytes of the register (byte locations 32 through 63) are factory programmed by Adesto and will contain a unique value for each device. The factory programmed data is fixed and cannot be changed. Access: Security Register Security Register Byte Number 0 Data Type 1 ··· 31 One-Time User Programmable 32 33 ··· 63 Factory Programmed by Adesto 10.9.1 Programming the OTP Security Register (9Bh, 00h, 00h) The user programmable portion of the Security Register does not need to be erased before it is programmed. To program the Security Register, a 3-byte opcode sequence of 9Bh, 00h, and 00h must be clocked into the device. After the last bit of the opcode sequence has been clocked into the device, the data for the contents of the 32-byte user programmable portion of the Security Register must be clocked in. After the last data byte has been clocked in, the CS pin must be deasserted to initiate the internally self-timed program cycle. The programming of the Security Register should take place in a time of tP, during which time the RDY/BUSY bit in the Status Register will indicate that the device is busy. If the device is powered-down during the program cycle, then the contents of the 32-byte user programmable portion of the Security Register cannot be guaranteed. If the full 32 bytes of data are not clocked in before the CS pin is deasserted, then the values of the byte locations not clocked in cannot be guaranteed. RM25C32DS DS-RM25C32DS–124C–11/2017 21 Example: If only the first two bytes are clocked in instead of the complete 32 bytes, then the remaining 30 bytes of the user programmable portion of the Security Register cannot be guaranteed. Furthermore, if more than 32 bytes of data is clocked into the device, then the data will wrap back around to the beginning of the register. For example, if 33 bytes of data are clocked in, then the 33rd byte will be stored at byte location 0 of the Security Register. Warning: The user programmable portion of the Security Register can only be programmed one time. Therefore, it is not possible, for example, to only program the first two bytes of the register and then program the remaining 30 bytes at a later time. The Program Security Register command utilizes the internal buffer for processing. Therefore, the contents of the Buffer will be altered from its previous state when this command is issued. Figure 10-10.Program Security Register CS SI 9Bh 00h Data 0 00h Data 1 Data 2 Data 63 Each transition represents eight bits 10.9.2 Reading the OTP Security Register (77h) To read the Security Register, an opcode of 77h and two bytes of 00h must be clocked into the device. After the last dummy bit has been clocked in, the contents of the Security Register can be clocked out on the SO pin. After the last byte of the Security Register has been read, additional pulses on the SCK pin will result in undefined data being output on the SO pin. Deasserting the CS pin will terminate the Read Security Register operation and put the SO pin into a high-impedance state. Figure 10-11.Read Security Register CS SI 77h 00h 00h Data 0 SO Data 1 Data x Each transition represents eight bits 10.10 PERS (Page Erase 32 bytes, 42h): Page Erase sets all bits inside the addressed 32-byte page to a 1. A Write Enable (WREN) instruction is required prior to a Page Erase. After the WREN instruction is shifted in, the CS pin must be brought high to set the Write Enable Latch. The Page Erase sequence is initiated by bringing the CS pin low; this is followed by the instruction code, then 2 address bytes. Any address inside the page to be erased is valid. This means the bottom six bits (A5-A0) of the address are ignored. Once the address is shifted in, the CS pin is brought high, which initiates the self-timed Page Erase function. The WIP bit in the Status Register can be read, using the RDSR instruction, to determine when the Page Erase cycle is complete. The sequence for the PERS is shown in Figure 10-12. RM25C32DS DS-RM25C32DS–124C–11/2017 22 Figure 10-12.PERS Sequence (42h) CS 0 1 2 3 4 5 6 7 8 9 10 11 20 21 22 23 1 0 SCK INSTRUCTION 0 SDI 1 0 0 2 BYTE ADDRESS 0 0 1 0 15 14 13 3 2 HI-Z SDO 10.11 CERS (Chip Erase): Chip Erase sets all bits inside the device to a 1. A Write Enable (WREN) instruction is required prior to a Chip Erase. After the WREN instruction is shifted in, the CS pin must be brought high to set the Write Enable Latch. The Chip Erase sequence is initiated by bringing the CS pin low; this is followed by the instruction code. There are two different instruction codes for CER, 60h and C7h. Either instruction code will initiate the Chip Erase sequence. No address bytes are needed. Once the instruction code is shifted in, the CS pin is brought high, which initiates the selftimed Chip Erase function. The WIP bit in the Status Register can be read, using the RDSR instruction, to determine when the Chip Erase cycle is complete. The sequence for the 60h CER instruction is shown in Figure 10-13. The sequence for the C7h CER instruction is shown in Figure 10-14. Figure 10-13.CERS Sequence (60h) CS 0 1 2 3 4 5 6 7 0 1 1 0 0 0 0 0 SCK SDI HI-Z SDO Figure 10-14.CERS Sequence (C7h) CS 0 1 2 3 4 5 6 7 1 1 0 0 0 1 1 1 SCK SDI SDO HI-Z 10.12 PD (Power-Down, B9h): Power-Down mode allows the user to reduce the power of the device to its lowest power consumption state. RM25C32DS DS-RM25C32DS–124C–11/2017 23 All instructions given during the Power-Down mode are ignored except the Resume from Power-Down (RES) instruction. Therefore this mode can be used as an additional software write protection feature. The Power-Down sequence is initiated by bringing the CS pin low; this is followed by the instruction code. Once the instruction code is shifted in the CS pin is brought high, which initiates the PD mode. The sequence for PD is shown in Figure 10-15. Figure 10-15.PD Sequence (B9h) CS 0 1 2 3 4 5 6 7 1 0 1 1 1 0 0 1 SCK SDI HI-Z SDO 10.13 RES (Resume from Power-Down, ABh): The Resume from Power-Down mode is the only command that will wake the device up from the Power-Down mode. All other commands are ignored. In the simple instruction command, after the CS pin is brought low, the RES instruction is shifted in. At the end of the instruction, the CS pin is brought back high. The rising edge of the SCK clock number 7 (8th rising edge) initiates the internal RES instruction. The device becomes available for Read and Write instructions 75μS after the 8th rising edge of the SCK (tPUD, see AC Characteristics). The sequence for simple RES instruction is shown in Figure 10-16. Figure 10-16.Simple RES Sequence (ABh) CS 0 1 2 3 4 5 1 0 6 7 SCK INSTRUCTION SDI SDO 1 0 1 0 1 1 HI-Z tRPD 10.14 UDPD (Ultra-Deep Power-Down, 79h) The Ultra-Deep Power-Down mode allows the device to further reduce its energy consumption compared to the existing Standby and Power-Down modes by shutting down additional internal circuitry. When the device is in the Ultra-Deep Power-Down mode, all commands including the Read Status Register and Resume from Deep Power-Down commands will be ignored. Since all commands will be ignored, the mode can be used as an extra protection mechanism against inadvertent or unintentional program and erase operations. RM25C32DS DS-RM25C32DS–124C–11/2017 24 10.14.1 UDPD mode Entering the Ultra-Deep Power-Down mode is accomplished by simply asserting the CS pin, clocking in the opcode 79h, and then deasserting the CS pin. Any additional data clocked into the device after the opcode will be ignored. When the CS pin is deasserted, the device will enter the Ultra-Deep Power-Down mode within the maximum time of tEUDPD. The complete opcode must be clocked in before the CS pin is deasserted; otherwise, the device will abort the operation and return to the standby mode once the CS pin is deasserted. In addition, the device will default to the standby mode after a power cycle. The Ultra-Deep Power-Down command will be ignored if an internally self-timed operation such as a program or erase cycle is in progress. The sequence for UDPD is shown in Figure 10-17. Figure 10-17.Ultra-Deep Power-Down (79h) CS tEUDPD 0 1 2 3 4 5 6 7 SCK Opcode SI 0 1 1 1 1 0 0 1 MSB SO High-impedance Active Current ICC Standby Mode Current Ultra-Deep Power-Down Mode Current 10.15 Exit Ultra-Deep Power-Down To exit from the Ultra-Deep Power-Down mode, one of the following operations can be performed: 10.15.1 Exit Ultra-Deep Power-Down / Hardware Reset Issue the Exit Ultra-Deep Power-Down / Hardware Reset sequence as described in Section 10.16, Hardware Reset. 10.15.2 Power Cycling The device can also exit the Ultra-Deep Power Mode by power cycling the device. The system must wait for the device to return to the standby mode before normal command operations can be resumed. Upon recovery from Ultra-Deep PowerDown all internal registers will be at their Power-On default state. 10.16 Hardware Reset The Exit Ultra-Deep Power-Down / Hardware Reset command sequence can be used to wakeup the device from UltraDeep Power-Down. This sequence can also be used to reset the device to its power on state without cycling power. It is in any case recommended to run a Hardware Reset command sequence after every time the device is powered up. The reset sequence does not use the SCK pin. The SCK pin has to be held low (mode 0) or high (mode 3) through the entire reset sequence.This prevents any confusion with a command, as no command bits are transferred (clocked). A reset is commanded when the data on the SDI pin is 0101 on four consecutive positive edges of the CS pin with no edge on the SCK pin throughout. This is a sequence where 1) CS is driven active low to select the device. This powers up the SPI slave. RM25C32DS DS-RM25C32DS–124C–11/2017 25 2) Clock (SCK) remains stable in either a high or low state. 3) SDI is driven low by the bus master, simultaneously with CS going active low. No SPI bus slave drives SDI during CS low before a transition of SCK ie: slave streaming output active is not allowed until after the first edge of SCK. 4) CS is driven inactive. The slave captures the state of SI on the rising edge of CS. The above steps are repeated 4 times, each time alternating the state of SI. After the fourth CS pulse, the slave triggers its internal reset. SI is low on the first CS, high on the second, low on the third, high on the fourth. This provides a 5h, unlike random noise. Any activity on SCK during this time will halt the sequence and a Reset will not be generated. Figure 10-18 below illustrates the timing for the Hardware Reset operation. Figure 10-18.Hardware Reset tCL tCH CS mode 3 SCK mode 0 SDI SDO HI-Z tXUPD Internal Reset Device is ready RM25C32DS DS-RM25C32DS–124C–11/2017 26 11. Typical Characteristics Figure 11-1. Icc4 , Auto Powerdown Average Icc Standby (Icc4, Auto Pow erdown, uA) vs Temperature (C), by Vcc 3.60 3.30 2.70 1.65 12 Voltage 11.5 11 10.5 10 9.5 9 8.5 8 7.5 7 Current 6.5 6 5.5 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 -40 0 23 55 85 Temperature RM25C32DS DS-RM25C32DS–124C–11/2017 27 Figure 11-2. Icc4, Mode 0 Figure 11-3. Icc4, Mode 1 RM25C32DS DS-RM25C32DS–124C–11/2017 28 Figure 11-4. Icc5 Figure 11-5. Icc6 RM25C32DS DS-RM25C32DS–124C–11/2017 29 12. Ordering Information 12.1 Ordering Detail RM25C32DS-LSNI-T Device Type Shipping Carrier Option RM25C = SPI serial access EEPROM B = Tube T = Tape & Reel Density Grade & Temperature 32= 32Kbit I = Green, NiPd Au lead finish, Industrial temperature (-40-85°C) Device/Die Revision Package Option D SN = 8 lead 0.150” SOIC, Narrow TA = 8 lead TSSOP MA = 8 pad 2 x 3 x 0.6 mm UDFN Series S = OTP Security Register Operating Voltage L = 1.65V to 3.6V 12.2 Ordering Codes Ordering Code RM25C32CDS-LSNI-B RM25C32CDS-LSNI-T RM25C32CDS-LTAI-B RM25C32CDS-LTAI-T RM25C32CDS-LMAI-T Package Density Operating Voltage fSCK SN 32 Kbit 1.65V to 3.6V 20 MHz TA 32 Kbit 1.65V to 3.6V 20 MHz MA 32 Kbit 1.65V to 3.6V 20 MHz Device Grade Ship Carrier Qty. Carrier Industrial Tube 100 (-40C to 85C) Reel 4000 Industrial Tube 100 (-40C to 85C) Reel 4000 Reel 5000 Industrial (-40C to 85C) Package Type SN 8-lead 0.150" wide, Plastic Gull Wing Small Outline (JEDEC SOIC) TA 8-lead 3 x 4.4 mm, Thin Shrink Small Outline Package MA 8-pad, 2 x 3 x 0.6mm, Thermally Enhanced Plastic Ultra Thin Dual Flat No Lead Package (UDFN) RM25C32DS DS-RM25C32DS–124C–11/2017 30 13. Package Information 13.1 SN (JEDEC SOIC) C 1 E E1 L N Ø TOP VIEW END VIEW e b COMMON DIMENSIONS (Unit of Measure = mm) A A1 D SIDE VIEW SYMBOL MIN A 1.35 – 1.75 A1 0.10 – 0.25 b 0.31 – 0.51 C 0.17 – 0.25 D 4.80 – 5.05 E1 3.81 – 3.99 E 5.79 – 6.20 e Notes: This drawing is for general information only. Refer to JEDEC Drawing MS-012, Variation AA for proper dimensions, tolerances, datums, etc. MAX NOM NOTE 1.27 BSC L 0.40 – 1.27 Ø 0° – 8° 8/20/14 TITLE Package Drawing Contact: contact@adestotech.com 8S1, 8-lead (0.150” Wide Body), Plastic Gull Wing Small Outline (JEDEC SOIC) GPC SWB DRAWING NO. 8S1 REV. G RM25C32DS DS-RM25C32DS–124C–11/2017 31 13.2 TA-TSSOP C 1 Pin 1 indicator this corner E1 E L1 H N L Top View End View A b A1 e A2 MIN NOM MAX A - - 1.20 A1 0.05 - 0.15 A2 0.80 1.00 1.05 D 2.90 3.00 3.10 2, 5 4.40 4.50 3, 5 – 0.30 4 SYMBOL D Side View Notes: COMMON DIMENSIONS (Unit of Measure = mm) 1. This drawing is for general information only. Refer to JEDEC Drawing MO-153, Variation AA, for proper dimensions, tolerances, datums, etc. 2. Dimension D does not include mold Flash, protrusions or gate burrs. Mold Flash, protrusions and gate burrs shall not exceed 0.15mm (0.006in) per side. 3. Dimension E1 does not include inter-lead Flash or protrusions. Inter-lead Flash and protrusions shall not exceed 0.25mm (0.010in) per side. 4. Dimension b does not include Dambar protrusion. Allowable Dambar protrusion shall be 0.08mm total in excess of the b dimension at maximum material condition. Dambar cannot be located on the lower radius of the foot. Minimum space between protrusion and adjacent lead is 0.07mm. 5. Dimension D and E1 to be determined at Datum Plane H. E 6.40 BSC E1 4.30 b 0.19 e L 0.65 BSC 0.45 L1 C NOTE 0.60 0.75 1.00 REF 0.09 - 0.20 12/8/11 ® Package Drawing Contact: contact@adestotech.com TITLE TA, 8-lead 4.4mm Body, Plastic Thin Shrink Small Outline Package (TSSOP) GPC TNR DRAWING NO. 8X REV. E RM25C32DS DS-RM25C32DS–124C–11/2017 32 MA- – 2 x 3 UDFN 8 7 6 5 5 8 E2 D2 E 13.3 Chamfer or half-circle notch for Pin 1 indicator. PIN 1 ID L3 L L1 1 2 3 4 1 4 D COMMON DIMENSIONS (Unit of Measure = mm) eee SYMBOL MIN A 0.45 A1 0.00 A3 b E2 0.05 0.20 0.30 2.00 BSC 1.50 E Notes: 1. All dimensions are in mm. Angles in degrees. 2. Bilateral coplanarity zone applies to the exposed heat sink slug as well as the terminals. 0.60 0.150 REF D D2 1.60 1.70 3.00 BSC 0.10 e 0.20 0.30 0.50 BSC L 0.40 0.45 L1 0.00 0.10 L3 0.30 eee MAX NOM – 0.50 0.50 – 0.08 8/26/14 ® Package Drawing Contact: contact@adestotech.com GPC TITLE 8MA3, 8-pad, 2 x 3 x 0.6 mm Body, 0.5 mm Pitch, 1.6 x 0.2 mm Exposed Pad, Saw Singulated YCQ Thermally Enhanced Plastic Ultra Thin Dual Flat No Lead Package (UDFN/USON) DRAWING NO. 8MA3 RM25C32DS DS-RM25C32DS–124C–11/2017 REV. GT 33 13.4 Revision History Doc. Rev. Date Comments RM25C32DS-A 7/2016 Initial document release RM25C32DS-B 11/2016 Updated Endurance and Data Retention specifications. Updated TPW and TBW and fSCKF specifications. Updated DC specifications and Typical Characteristics curves. RM25C32DS-C 11/2017 Added patent information. RM25C32DS DS-RM25C32DS–124C–11/2017 34 Corporate Office California | USA Adesto Headquarters 3600 Peterson Way Santa Clara, CA 95054 Phone: (+1) 408.400.0578 Email: contact@adestotech.com © 2017 Adesto Technologies. All rights reserved. / Rev.: DS-RM25C32DS–124C–11/2017 Adesto®, the Adesto logo, CBRAM®, and DataFlash® are registered trademarks or trademarks of Adesto Technologies. All other marks are the property of their respective owners. Adesto products in this datasheet are covered by certain Adesto patents registered in the United States and potentially other countries. Please refer to http://www.adestotech.com/patents for details. Disclaimer: Adesto Technologies Corporation makes no warranty for the use of its products, other than those expressly contained in the Company's standard warranty which is detailed in Adesto's Terms and Conditions located on the Company's web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Adesto are granted by the Company in connection with the sale of Adesto products, expressly or by implication. Adesto's products are not authorized for use as critical components in life support devices or systems. For Release Only Under Non-Disclosure Agreement (NDA)
RM25C32DS-LSNI-B 价格&库存
很抱歉,暂时无法提供与“RM25C32DS-LSNI-B”相匹配的价格&库存,您可以联系我们找货
