TMPA1205SP-R22MN-D
TMPA1205SP-R22MN-D
    TAI-TECH(台庆)
    IND_13.5X12.6MM_SM
    功率电感 220nH ±20% IND_13.5X12.6MM_SM 5.00mm 13.50 x 12.60mm
TMPA1205SP-R22MN-D 数据手册
TAI-TECH P1 SMD Power Inductor TMPA1205SP-Series(N)-D 1. Features 1. Shielded construction. 2. Capable of corresponding high frequency . Halogen 3. Low loss realized with low DCR. 4. High performance (Isat) realized by metal dust core. Halogen-free 5. Ultra low buzz noise, due to composite construction. 6. 100% Lead(Pb)-Free and RoHS compliant. 7. Operating temperature -40~+125℃(Including self - temperature rise) 2. Applications 1. DC/DC converters in distributed power systems. 2. DC/DC converter for Field Programmable Gate Array(FPGA). 3. Battery powered devices. 4. Thin type on-board power supply module for exchanger. 5. VRM for server. 6. High current, low profile POL converters. 7. PDA/notebook/desktop/server and battery powered devices. 3. Dimensions C 100 2019 D E B A leadframe C A Recommend PC Board Pattern D 1R0 2019 H E B L non-leadframe Series TMPA1205 A B 13.5±0.5 G C 12.6±0.2 4.7±0.3 D E 2.3±0.3 See Spec table Unit:mm L(mm) 4. Part Numbering TMPA 1205 SP A B C A: Series B: Dimension C: Type D: Inductance E: Inductance Tolerance F: Code - 100 MN D E - G(mm) H(mm) 14.5 8.0 5.0 Note: 1. The above PCB layout reference only. 2. Recommend solder paste thickness at 0.15mm and above. D F BxC. Standard. 100=10uH K=±10%,L=±15%,M=±20%,N=±25%,Y=±30% Marking: Black.100 and 2019(20 YY, 19 WW,follow production date). TAI-TECH P2 5. Specification Part Number Inductance L0 A(uH) ±20% Heat Rating Saturation Current DC Current DC Irms( A ) I sat ( A ) DCR (mΩ) Typ DCR (mΩ) Max E(mm) ±0.3 Type TMPA1205SP-R47MN-D 0.47 38 65 0.77 0.9 4.0 non-leadframe TMPA1205SP-R68MN-D 0.68 TMPA1205SP-1R0MN-D 1.00 34 50 1.3 1.55 4.0 non-leadframe 30 40 1.6 1.9 4.0 non-leadframe TMPA1205SP-1R5MN-D TMPA1205SP-2R2MN-D 1.50 25 31 3.2 3.8 4.7 leadframe 2.20 17 26 4.1 4.8 4.7 leadframe TMPA1205SP-3R3MN-D 3.30 15.5 23 6.0 7.0 4.7 leadframe TMPA1205SP-4R7MN-D 4.70 14 18.5 8.8 10.2 4.7 leadframe TMPA1205SP-6R8MN-D 6.80 12 16.5 13 16 4.7 leadframe TMPA1205SP-100MN-D 10.0 10 13 19.2 22 4.7 leadframe TMPA1205SP-150MN-D 15.0 9.4 11 30 36 4.7 leadframe TMPA1205SP-220MN-D 22.0 8.0 8.5 42 52 4.7 leadframe TMPA1205SP-330MN-D 33.0 6.0 7.3 66 80 4.7 leadframe Note: 1. Test frequency : Ls : 100KHz /1.0V. 2. All test data referenced to 25℃ ambient. 3. Testing Instrument(or equ) : L: HP4284A,CH11025,CH3302,CH1320,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER. 4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃ 5. Saturation Current (Isat) will cause L0 to drop approximately 30%. 6. The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 7. Special inquiries besides the above common used types can be met on your requirement. TAI-TECH 6. Typical Performance Curves P3
TMPA1205SP-R22MN-D 价格&库存
很抱歉,暂时无法提供与“TMPA1205SP-R22MN-D”相匹配的价格&库存,您可以联系我们找货
