NS9215B-0-I75
NS9215B-0-I75
    DIGIINTERNATIONAL
    LFBGA265
    NS9215B-0-I75
NS9215B-0-I75 数据手册
NS9210/NS9215 32-bit NET+ARM Processor Family Cost-efficient, small footprint ARM926EJ-S processor with integrated encryption and unique interface flexibility. The NS9210/NS9215 processor family offers a cost-efficient, small-footprint 32-bit ARM9 solution that combines high performance, integrated Ethernet networking, strong security, and unique interface flexibility. It is the ideal choice for a broad range of applications such as security/access control, medical, industrial/building automation, transportation and remote monitoring. NS9215 0.18µ CMOS, 265-pin BGA Vectored Interrupt Controller Bus Arbiter PLL CLK Generator JTAG Test and Debug ARM ARM926EJ-S 75-150 MHz 4k I-Cache/ 4k D-Cache Power Management Real-Time Clock NVRAM 64 Byte Ext. Peripheral Controller AES Accelerator 10/100 Ethernet MII MAC 75 MHz, AHB Bus Memory Controller 32 bit A/D I/O Hub Flexible Interface Module Data Memory Quadrature Decoder The complete and easy-to-use development kits for NET+OS are based on the field-proven ThreadX® Real-Time Operating System and deliver a true and IPv6-ready turnkey embedded development solution with the Eclipse-based Digi ESP™ IDE. Data Memory IRQ ® Flexible Interface Module Program Memory ADC 12b-8ch Program Memory I2 C UART UART Boot SPI UART 10 Timers/ Counters or 4 PWM UART Two independent Flexible Interface Modules (FIMs) with 300 MHz DRPIC1655X processor cores provide a growing list of application-specific peripheral interface options. The NISTcompliant 256-bit hardware AES accelerator combines stateof-the-art data privacy services with superior performance, and Digi’s patented dynamic power management addresses the needs of today’s power budget-conscious designs. Block Diagram GPIO Overview GPIO Features/Benefits Platforms and Services • High-performance 150 MHz ARM926EJ-S core • 10/100 Mbit Ethernet MAC integration • On-chip hardware AES accelerator • Software-configurable I/O flexibility through FIMs • Power management modes with dynamic clock scaling Design Services Accessory Kits NET OS Support • Rich set of integrated peripheral interfaces • Complete and royalty-free NET+OS development platform for network-enabled embedded devices • Upgrade path to ARM9 core performance for existing NS7520 designs through pin-compatible NS9210 Supported Software Platforms www.digi.com Development Kits Development Kit Overview Development Kit for NET+OS® NET+OS is a royalty-free turnkey solution for embedded software development based on the ThreadX Real-Time Operating System (RTOS), which is one of the most reliable and field-proven RTOS solutions available. In addition to ThreadX, NET+OS provides a complete set of integrated building blocks needed to create product solutions with leading network security using Digi embedded microprocessors and modules. For professional embedded software development, the Eclipse based Digi ESP™ Integrated Development Environment (IDE) for Microsoft Windows with graphical user interface and a high-speed USB 2.0 hardware debugger is provided out-of-thebox. A Green Hills MULTI IDE option is also available. Digi professional design and support services are also part of the development kit. The included professional design review service improves time-to-market by minimizing the traditional design risk for prototyping and production units. In addition, one year of premium support service covers any software development related questions through the assistance of Digi’s technical support experts. • • • • • Royalty-free turn-key solution for embedded development Built on field-proven and compact ThreadX RTOS Fully integrated support for secure, IPv4/IPv6 networking applications Eclipse-based Digi ESP IDE for Windows software development Professional hardware design review included Development Kit Contents Processor Module Development Board CD/DVD Documentation Power Supplies and Accessories Other Kit Part Numbers NS9210 NS9215 NS9210 processor module with 150 MHz, 4 MB Flash, 8 MB SDRAM NS9215 processor module with 150 MHz, 4 MB Flash, 8 MB SDRAM Ethernet connector, 4 serial ports (1 x RS-232/422/485, 1 x RS-232, 2 x TTL), User/Application connectors, I2C/SPI headers, ADC header, Screw terminal for access to 8 GPIO signals, 2 user push-buttons, 2 user LEDs, Wake-up button, Reset button, 802.3af PoE module connector, Prototyping area, Battery backup, 9-30VDC power supply, Power switch, Mounting holes Digi NET+OS CD: NET+OS 7, Digi ESP IDE, BSP source code, Sample code, Green Hills MULTI support option, User documentation Quick start guide, Digi ESP tutorial, NET+OS programmer’s guide, NET+OS API documentation, Advanced Web Server, Hardware reference manual, Complete design schematics and bill of material External wall power supply (110/240VAC) with interchangeable outlet adapters (North America, EU, UK and Australia), Ethernet cable, Serial cable Digi JTAG Link USB 2.0 hardware debugger, 802.3af PoE module, Professional Hardware Design Review, 1 year of Premium Support Service NS-9210-NET NS-9215-NET Please refer to the feature specs on our website for detailed information about the NET+OS software platform capabilities. Platform NS9210 NS9215 General Processor ARM926EJ-S Speed Grades 75/150 MHz Cache 4 KB I-cache / 4 KB D-cache Process 0.18µ CMOS 32-bit ARMv5TEJ Instruction Set • 16-bit Thumb Instruction Set • MMU • • (Improved divide, Single cycle multiply accumulate) DSP Instruction Extensions ARM Jazelle® Java Accelerator • Embedded ICE-RT Debug Unit • JTAG Boundary Scan, BSDL • Power Management Modes • AES Accelerator Key Length 128-, 192-, 256-bit Cipher Modes ECB, CBC, OFB, CTR, CCM Hardware Key Expander • DMA-Enabled • NIST-Compliant • FIM (Flexible Interface Module) FIMs 1/2; Availability depending on application-specific use of external 16-/32-bit memory bus 2 Cores 8-bit DRPIC1655X Speed Up to 300 MHz (4x bus speed) Data Memory (SRAM) 192 Bytes Program Memory (SRAM) Interface Options 2 KB SD/SDIO, UART, 1-Wire, CAN, USB device (low-speed), Other; Please contact us for custom interface implementation options. Power Management Dynamic Clock Scaling (patent pending) Full, /2, /4, /8, /16 speeds, with hardware clock scale control (wake-up events) Low-Power Sleep Modes Configurable Wake-Up Conditions • External IRQ, I C, SPI, UART, Ethernet External IRQ, I2C, SPI, UART, Ethernet, RTC 2 Disabling of Unused System Modules • Memory Controller • (SDRAM, SRAM, Buffered DIMM, EEPROM, Flash) Glue-less Interface Self-Refresh (Sleep Mode) Dynamic/Static Memory Chip Selects Wait States Per Memory Chip Select Static Memory Controller Extended Waits (EW) Automatic Dynamic Bus Sizing Burst Support External DMA Channels • Selection of 5 4/4 0-32 Up to 16,368 • 8-transfer, with automatic data width adjustment 2 •● Chip Feature Platform NS9210 NS9215 System Bus DMA High-Speed Rotating AHB arbiter 16 channels Deterministic Bus Bandwidth Allocation • Multiple Bus Masters Ethernet Tx/Rx, I/O Hub, Ext DMA, ARM core External DMA Independent DMA Channels 2 Transfer Modes External peripherals, External memory, AHB peripherals AES DMA Support • AHB Master • I/O Hub Low Latency • DMA DMA or Direct Access Mode Direct Access Mode Only 8 channels UART, SPI, FIM UART, SPI, ADC, FIM IC I2C, RTC 2 AHB Master • External Interrupts External Programmable Interrupts 4 Advanced Vectored Interrupt Controller Two-Tier Priority • (FIRQ/IRQ) Low-Latency FIRQ • Interrupt Sources 32 Ethernet MAC Data Rates Duplex 10 / 100 Mbit/s Full and Half PHY Interface Address Filtering FIFO MII Station, Broadcast, Multicast 2 KB Rx / 256 Byes Tx Separate Tx and Rx DMA Channels • Programmable 8-Entry Restrictive Multicast Filtering • Access Modes Interrupt and DMA AHB Master • UART Ports Bit Rates Data Format Channel Modes Modem Control Signals Maskable Interrupt Conditions FIFO Transmit FIFO Bypass 2 / 4; Availability depending on application-specific use of external 16-/32-bit memory bus 4 Up to 1.8432 Mbps 5 to 8 data bits; Odd, Even, or No parity; 1 or 2 stop bits; MSB or LSB first Normal, Local loopback, Remote loopback RTS, CTS, DTR, DSR, DCD, RI Receiver idle; Transmitter idle; Receive error conditions; Character gap timeout; Character match events; State change detection: CTS, DSR, DCD, RI 2 KB Rx / 256 Byes Tx • •● Chip Feature Platform NS9210 NS9215 I2C v1.0 Master/Slave • Bit Rates 100 kbit/s and 400 kbit/s modes Address Modes 7-bit, 10-bit Bus Arbitration • SPI (with Boot) Master/Slave • Bit Rates 33 Mps (Master) / 7.5 Mpbs (Slave) max SPI Modes 0, 1, 2, 3 Maskable Interrupt Conditions • Boot Support Patent Pending Serial Boot Circuit Serial EEPROM, High-speed ROM/flash Automatic configuration, Internal register setup, Boot code transfer to external memory POR 3.3V Voltage Monitoring – • Early Power-Loss Comparator with Alert for Main Power Shutdown – • Auxiliary Analog Comparator – 2.4V trip point Resolution/Conversion – 12 bit/1 MHz Multiplexed Inputs – Single-ended 8:1 Rail-to-Rail Input Range – • 12-Bit Output – DMA/Direct External Reference – • ADC Timers/Counters/PWM General Purpose Timers/Counters 10 (32-bit) PWM Up to 4 with basic or enhanced functionality Quadrature Decoder • Software Watchdog Timer IRQ, FIQ, RESET GPIO Multiplexed GPIOs Up to 54 Up to 108 Alarm Masks and Event Detection – • Calendar – 1900-2999 Resolution – 10 ms Integrated NVRAM – 64 Bytes External Battery Backup – • External Clock Source – • Real-Time Clock Operating Voltage Core 1.8V I/O Ring 3.3V 5V-Tolerant GPIO and Memory Inputs • •● Chip Feature Platform NS9210 NS9215 Operating Temperature 75/150 MHz -40° C to +85° C Power Dissipation 150 MHz Core/75 MHz Bus 1.019 W 75 MHz Core/75 MHz Bus 0.828 W 112 MHz Core/56 MHz Bus 0.638 W 56 MHz Core/56 MHz Bus 0.499 W Sleep Mode, Wake on Ethernet 0.073 W Sleep Mode, Wake on Ext IRQ 0.055 W Main Power Down, Battery Draw – 3.0V – 32 µA; 1.8V – 6 µA Package Type 177-pin BGA (Pin-compatible with NS7520) Ball Pitch 265-pin BGA 0.8 mm Size 13 x 13 mm 15 x 15 mm Lead-Free, RoHS Compliant • •● Chip Feature NS9210 NS9215 You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support Digi International Worldwide HQ 877-912-3444 952-912-3444 www.digi.com Digi International France +33-1-55-61-98-98 www.digi.fr Digi International Japan +81-3-5428-0261 www.digi-intl.co.jp Digi International Singapore +65-6213-5380 91001450 B3/1209 Digi International China +86-21-50492199 www.digi.com.cn © 1996-2015 Digi International Inc. All rights reserved. All other trademarks are the property of their respective owners. www.digi.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: DIGI: NS9210B-0-I150 NS9210B-0-I75 NS9215B-0-I150 NS9215B-0-I75 NS-9210-NET
NS9215B-0-I75 价格&库存
很抱歉,暂时无法提供与“NS9215B-0-I75”相匹配的价格&库存,您可以联系我们找货
