20-101-0454
20-101-0454
    DIGIINTERNATIONAL
    模块
20-101-0454 数据手册
RCM2200 RabbitCoreTM Microprocessor Core Module Models RCM2200, RCM2210, RCM2250, RCM2260 Specifically designed for small applications, the award-winning RCM2200 RabbitCore microprocessor core module provides a complete embedded control solution in an area half the size of a credit card. Based on the powerful Rabbit 2000™ microprocessor, the RCM2000 includes features for embedded control such as Flash memory, SRAM, serial ports, I/O, real-time clock, and integrated Ethernet. To permit parallel development and cost-effective implementation of both Ethernet-enabled and non-Ethernet systems, our pin-compatible RCM2300 model is also available. Features ƒ Compact size (2.3" x 1.6" x 0.86") ƒ 10Base-T Ethernet ƒ Up to 512K Flash ƒ Up to 512K SRAM ƒ 26 general-purpose I/O Designing with RabbitCores The RabbitCore family of microprocessor core modules is designed to facilitate rapid development and implementation of embedded systems. RabbitCores are powered by high-performance 8-bit Rabbit microprocessors with extensive integrated features and a C-friendly instruction set designed for use with the Dynamic C® development system. The RabbitCore mounts on a user-designed motherboard and acts as the controlling microprocessor for the user’s system. Small in size but packed with powerful features, these core modules give designers a complete package for control and communication. The integrated Ethernet port frees designers from the limitations of serial-port communications and control and also permits instant local or worldwide connectivity using low-cost networking hardware. Embedded systems using the Ethernet RabbitCore module can be controlled and monitored (as well as programmed and debugged when using appropriate accessory hardware) across any network or the Internet. Programming the RCM2200 Programs are developed using Z·World’s industry-proven Dynamic C software development system, which is included in low-cost development kits. An extensive library of drivers and sample programs is provided. Development Kit Jumpstart your evaluation and design efforts with a complete development kit, which includes RCM2200 RabbitCore (with Ethernet, 256K Flash, and 128K SRAM), prototyping board, AC adapter (U.S. only), Dynamic C development system and complete documentation on CD-ROM, serial cable for programming and debugging, and Getting Started manual. 1/14/2005 RCM 2200 RabbitCore Specifications Feature RCM2200 RCM2210 RCM2260 Rabbit2000TM at 22.1 Mhz Microprocessor Ethernet Port RCM2250 10Base-T, RJ-45 2 LEDs 10Base-T (raw signals only) 10Base-T, RJ-45 2 LEDs 10Base-T (raw signals only) Flash 256K 512K SRAM 128K 512K Connection for user-supplied battery (to support RTC and SRAM) Backup Battery 26 parallel I/O • 16 configurable I/O • 7 fixed inputs • 3 fixed outputs 2 Startup Mode, Reset General Purpose I/O Additional Inputs Status, Reset Additional Outputs 4 address, 8 data, I/O Read-Write Four 5 V CMOS-compatible* • 4 configurable as asynchronous • 2 configurable as clocked serial (SPI) External I/O Serial Ports Serial Rate Max. burst rate = CLK/32 Max. sustained rate=burst/2 Connectors Two 2 x 13, 2 mm IDC headers Slave Interface Slave Port permits use as master or as intelligent peripheral with Rabbit-based or other master controller Yes Real-Time Clock Timers Five 8-bit timers (four cascadable from the first) and one 10-bit timer with 2 match registers Yes Watchdog/Supervisor 4.75-5.25 V DC, 134 mA Power -40°C to + 70°C Operating Temp. 5-95%, non condensing Humidity 2.3” x 1.6” x 0.86” (59 x 41 x 22 mm) Board Size Pricing (qty. 1/100/1000) Part Number Development Kit Part Number 101-0454 101-0488 U.S. 101-0475 101-0494 101-0955 Int’l 101-0478 1/14/2005
20-101-0454 价格&库存
很抱歉,暂时无法提供与“20-101-0454”相匹配的价格&库存,您可以联系我们找货
