MOD5282-100IR
MOD5282-100IR
    NETBURNER
    Module
    MOD5282-100IR
MOD5282-100IR 数据手册
MOD5282 Ethernet Core Module 100 Version with RJ-45 | 200 version with 10-pin header DATASHEET Key Points • Use as a high-performance single board computer or add Ethernet connectivity to a new or existing design • Customize with a development kit and begin writing application code immediately! • Industrial temperature range (-40°C to 85°C) Device Connectivity • 10/100Mbps Ethernet • 50 digital I/Os • 3 UARTs, I C, CAN and SPI • Eight 10-bit analog-to-digital converters (ADC) • SD/MMC flash card ready • 16-bit address and data bus with 3 chip selects 2 Performance and memory • 32-bit 66 MHz Processor • 8MB SDRAM and 512KB Flash Companion development kit The following is available with the development kit: • Customize any aspect of operation including web pages, data filtering, or custom network applications • Development software: NB Eclipse IDE, Graphical debugger, deployment tools, and examples • Communication software: TCP/IP stack, HTTP web server, FTP, E-mail, and flash file system • System software: uC/OS RTOS, ANSI C/C++ compiler and linker The following optional software modules are not included with kit and are sold separately: • SNMP Updated: August 10, 2021 | Page 1 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 Specifications Processor and Memory 32-bit Freescale ColdFire 5282 running at 66MHz with 8MB SDRAM, 512KB Flash, and 64Kb SRAM. Network Interface 10/100 BaseT with RJ-45 connector (100 Version) 10-pin header (200 Version) Data I/O Interface (J1 and J2) • Up to 3 UARTs • Up to 4 external timer in and up to 4 timer outputs • Up to 50 digital I/O • Up to 8 external general purpose timers • Up to 6 PWM outputs ( via general purpose timers) • Up to 4 external IRQs • Up to eight 10-bit analog-to-digital converters (ADC) with an input range of 0 - 5V • I2C interface • 16-bit address bus and 16-bit data bus with 3 chip selects • CAN interface • SPI interface • SD/MMC flash card ready Flash Card Support FAT32 support for SD Cards up to 8GB (requires exclusive use of SPI signals). Card types include SD/MMC (up to 2GB) and SDHC. Serial Configurations The UARTs can be configured in the following way: • 3 TTL ports • Add external level shifter for RS-232 • Add external level shifter for RS-422/485 (up to two ports) Note: UART 0/1 also provides RTS/CTS hardware handshaking signals. LEDs Link and Speed (100 Version only, on RJ-45) Physical Characteristics Dimensions (inches): 2.60” x 2.00” Weight: 1 oz. Mounting Holes: 2 x 0.125” dia. Power DC Input Voltage (with Ethernet): 3.3V @ 380mA typical 3.3V @ 630mA max Environmental Operating Temperature -40° to 85° C RoHS Compliance The Restriction of Hazardous Substances guidelines ensure that electronics are manufactured with fewer environment harming materials. Updated: August 10, 2021 | Page 2 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 Part Numbers MOD5282 Ethernet Core Module (100 Version, with RJ-45) Part Number: MOD5282-100IR MOD5282 Ethernet Core Module (200 Version, with 10-pin header) Part Number: MOD5282-200IR MOD5282 Development Kit Part Number: NNDK-MOD5282-KIT Kit includes all the hardware and software you need to customize the included platform hardware. See NetBurner Store product page for package contents. Note: Includes the MOD-DEV-100 development board. SNMP V1 (Module License Version) Part Number: NBLIC-SNMP Available as an option if you are using a development kit. Ordering Information E-mail: sales@netburner.com Online Store: www.Netburner.com Telephone: 1-800-695-6828 Updated: August 10, 2021 | Page 3 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 Pinout and Signal Description The 200 version board has a 10-pin header instead of an RJ-45 jack. This header enables you to relocate the jack to another location or to add a different jack with power over ethernet (PoE) capabilities to your module. Table 1 provides descriptions of pin function of the 10-pin header. Refer to the application note, “Adding an External Ethernet RJ-45 Connector and PCB Layout Guidlines for NetBurner -200 Version Modules”, for details and examples. Table 1: Pinout and Signal Descriptions for JP2 Header (1) Pin Signal Description 1 2 3 4 5 6 7 8 9 10 TXTX+ TXCT1 RX+ RXRXCT1 Transmit Transmit + Transmit Data Center Tap Receive + Receive Receive Data Center Tap GND N/C LED LED Ground Not Connected LED control sink, link/activity LED control sink, speed Note: 1. The 2.5V pins are used for the magnetics taps and LED power. Updated: August 10, 2021 | Page 4 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 The module has two dual in-line 50 pin headers which enable you to connect to one of our standard NetBurner Carrier Boards, or a board you create on your own. Table 2-3 provides descriptions of pin function of the module header. Table 2: Pinout and Signal Descriptions for J1 Connector (1) J1 Connector Pin CPU Pin Function 1 1 GND 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 GND VCC3V R/W CS1 CS2 CS3 OE BS2 BS3 TIP D16 TA D18 D17 D20 D19 D22 D21 D24 D23 D26 D25 D28 D27 N15 L14 L15 L16 N16 T15 P14 M14 K3 P16 K1 K2 J3 J4 J1 J2 H3 H4 H1 H2 G3 G4 Function 2 General Purpose I/O Max Voltage Description Ground PE4 PJ1 PJ2 PJ3 PE7 SYNCB PE0 PE6 - Ground Input Power 3.3V Read / NOT Write1 Chip Select 11 Chip Select 21 Chip Select 31 Output Enable1 Byte Strobe for D16 to D23 (8 bits)1 Byte Strobe for D24 to D31 (8 bits)1 Transfer in Progress1 or GP Timer B Synchronization Input Data Bus - Data 16 Transfer Acknowledge1 Data Bus - Data 18 Data Bus - Data 17 Data Bus - Data 20 Data Bus - Data 19 Data Bus - Data 22 Data Bus - Data 21 Data Bus - Data 24 Data Bus - Data 23 Data Bus - Data 26 Data Bus - Data 25 Data Bus - Data 28 Data Bus - Data 27 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Note: 1. Active low signals, such as RESET, are indicated with an overbar. Updated: August 10, 2021 | Page 5 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 J1 Connector (continued) Pin CPU Pin Function 26 G1 D30 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 G2 R11 F3 P11 N7 F2 F1 E4 E3 E2 E1 D4 D3 D2 D1 C3 C2 C1 B2 B1 A2 D29 RESET D31 RSTOUT CLK_OUT A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 VCC3V GND GND General Purpose I/O Description Max Voltage Data Bus - Data 30 3.3VDC Data Bus - Data 29 Processor Reset Input1 Data Bus - Data 31 Processor Reset Output1 Clock Out (CLKOUT-66.355 Mhz) Data Bus - Address 0 Data Bus - Address 1 Data Bus - Address 2 Data Bus - Address 3 Data Bus - Address 4 Data Bus - Address 5 Data Bus - Address 6 Data Bus - Address 7 Data Bus - Address 8 Data Bus - Address 9 Data Bus - Address 10 Data Bus - Address 11 Data Bus - Address 12 Data Bus - Address 13 Data Bus - Address 14 Data Bus - Address 15 Input power 3.3V Ground Ground 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC - Note: 1. Active low signals, such as RESET, are indicated with an overbar. Updated: August 10, 2021 | Page 6 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 Table 3: Pinout and Signal Descriptions for J2 Connector (1) J2 Connector Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 CPU Pin N6 T7 R1 R2 T2 R3 T3 T4 R4 P3 T13 T12 R13 R12 P13 P12 R7 P7 N13 N12 F14 Function 1 Function 2 Function 3 GND VCC3V UART0_RX UART0_TX ADVCC ADC_IN3 ADC_IN1 ADC_IN2 ADC_IN56 ADC_IN0 ADC_IN53 ADC_IN52 ADC_IN55 GND GPTA3 GPTB3 GPTA2 GPTB2 GPTA1 GPTB1 UART1_RX UART1_TX GPTA0 GPTB0 SPI_CLK General Purpose I/O PUA1 PUA0 PQB3 PQB1 PQB2 PQA4 PQB0 PQA1 PQA0 PQA3 PTA3 PTB3 PTA2 PTN2 PTA1 PTB1 PUA3 PUA1 PTA0 PTB0 PQS2 Description Max Voltage Ground Input power 3.3V UART 0 Receive4 UART 0 Transmit4 ADVCC Analog to Digital Converter Input 3 Analog to Digital Converter Input 1 Analog to Digital Converter Input 2 Analog to Digital Converter Input 56 Analog to Digital Converter Input 0 Analog to Digital Converter Input 53 Analog to Digital Converter Input 52 Analog to Digital Converter Input 55 Ground General Purpose Timer A3 General Purpose Timer B3 General Purpose Timer A2 General Purpose Timer B2 General Purpose Timer A1 General Purpose Timer B1 UART 1 Receive4 UART 1 Transmit4 General Purpose Timer A0 General Purpose Timer B0 SPI Clock 3.3VDC 3.3VDC 3.3VDC 5V 5V 5V 5V 5V 5V 5V 5V 5V 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Note: 1. Active low signals, such as RESET, are indicated with an overbar. 2. 3. 4. If using I2C, pull-up resistors must be added to SDA/SCL. The third UART (UART2) can be routed to either of the two pin configurations: replacing CAN RX andTX, or I2C SDA and SCL. TIN0, TIN1 and TIN2 can be used as external baud rate clocks for UART0, UART1 and UART2 Updated: August 10, 2021 | Page 7 of 8 © 2021 NetBurner Inc. All Rights Reserved. MOD5282 J2 Connector (continued) Pin CPU Pin Function 1 26 27 28 G14 E16 F13 SPI_CS3 SPI_DIN SPI_DOUT 29 K14 T2IN 30 F15 SPI_CS0 31 J14 T0IN UART1_CTS UART0_CTS PTD1 32 K15 T3OUT UART1_RTS UART0_RTS PTC2 33 K13 T2OUT UART1_CTS UART0_CTS PTC0 34 J15 T1OUT UART1_RTS UART0_RTS PTD2 35 G13 SPI_CS2 36 J13 T0OUT UART1_CTS UART0_CTS PTD0 37 J16 T1IN UART1_RTS UART0_RTS PTD3 38 K16 T3IN UART1_RTS UART0_RTS PTC3 39 40 41 42 43 44 45 46 47 48 49 50 E14 F16 D16 E15 D15 E13 C16 I2C_SDA SPI_CS1 CAN_RX I2C_SCL IRQ1 CAN_TX IRQ3 GND IRQ5 IRQ7 GND VCC3V UART2_RX C14 B15 Function 2 Function 3 General Purpose I/O PQS6 PQS1 PQS0 UART1_CTS UART0_CTS PTC1 PQS3 PQS5 UART2_RX UART2_TX UART2_TX PAS1 PQS4 PAS3 PAS0 PNQ1 PAS2 PNQ3 PNQ5 PNQ7 Max Voltage Description SPI Chip Select 3 SPI Data In SPI Data Out Timer 24 Input or UART 1 Clear to Send4 or UART 0 Clear to Send4 SPI Chip Select 0 Timer 04 Input or UART 1 Clear to Send1,4 or UART 0 Clear to Send1,4 Timer 3 Output or UART 1 Request to Send1,4 or UART 0 Request to Send1,4 Timer 2 Output or UART 1 Clear to Send1,4 or UART 0 Clear to Send1,4 Timer 1 Output or UART 1 Request to Send1,4 or UART 0 Request to Send1,4 SPI Chip Select 2 Timer 0 Output or UART 1 Clear to Send1,4 or UART 0 Clear to Send1,4 Timer 14 Input or UART 1 Request to Send1,4 or UART 0 Request to Send1,4 Timer 3 Input or UART 1 Request to Send1,4 or UART 0 Request to Send1,4 I2C Serial Data2 or UART 2 Receive3,4 SPI Chip Select 1 CAN Receive or UART 2 Receive3,4 I2C Serial Clock2 or UART 2 Transmit3,4 External Interrupt 11 CAN Transmit or UART 2 Transmit3,4 External Interrupt 31 Ground External Interrupt 51 External Interrupt 71 Ground Input power 3.3V 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Note: 1. Active low signals, such as RESET, are indicated with an overbar. 2. 3. 4. If using I2C, pull-up resistors must be added to SDA/SCL. The third UART (UART2) can be routed to either of the two pin configurations: replacing CAN RX andTX, or I2C SDA and SCL. TIN0, TIN1 and TIN2 can be used as external baud rate clocks for UART0, UART1 and UART2 Updated: August 10, 2021 | Page 8 of 8 © 2021 NetBurner Inc. All Rights Reserved.
MOD5282-100IR 价格&库存
很抱歉,暂时无法提供与“MOD5282-100IR”相匹配的价格&库存,您可以联系我们找货
