SOMOMAP3530-11-1782JFIR
    BEACONEMBEDDEDWORKS
    SYSTEM ON MODULE LV OMAP3530
SOMOMAP3530-11-1782JFIR 数据手册
PRODUCT BRIEF Logic PD :: Texas Instruments www.logicpd.com/products OMAP35x SOM-LV OMAP35x SOM-LV :: HIGHLIGHTS: + Product-ready System on Module with a TI OMAP 35x processor running up to 600 MHz System on Module Essential features for handheld and embedded networking applications with optional DSP functionality The OMAP35x SOM-LV is an off-theshelf solution that reduces development risks associated with the complex design and manufacturing details of the OMAP 3 processor. The standard SOM-LV form factor allows developers to reuse existing baseboard designs when upgrading to new OMAP processors, which extends roadmap possibilities for end-products. The OMAP35x SOM-LV is ideal for applications in the medical, point-of-sale, industrial, and security markets. + Compact form factor—SOM-LV Type III (31.2 x 76.5 x 7.4 mm) + Microsoft Windows® Embedded CE 6.0 Board Support Package (BSP) + Open source Linux™ BSP The OMAP35x System on Module (SOM) is a compact, product-ready hardware and software solution that fast forwards embedded designs. Based on the Texas Instruments (TI ) OMAP 3 processor family and designed in the SOMLV Type III form factor, the OMAP35x SOM-LV offers essential features for handheld and embedded networking applications. The OMAP35x SOM-LV features the superset OMAP3530 processor, but also supports the OMAP3503 processor. +TMS320C64x DSP core running up to 430 MHz (OMAP3530 only) + Extended temp (-20˚C to 70˚C) Industrial temp (-40˚C to 85˚C) + Long product lifecycle + RoHS compliant OMAP35x SOM-LV From patient monitoring and medical imaging, to card payment terminals and bar code readers, to CCTV cameras and intruder alarms, the OMAP35x SOM-LV allows for powerful versatility and long-life products. OMAP35x SOM-LV Block Diagram USB Host Controller Two 240-pin High Density Connectors HS Host (x3) Product Features 31.2 mm Processor Clock Generation + TI OMAP 3 processor with ARM® Cortex™-A8 core running up to 600 MHz POP technology HS OTG OTG PHY Power TPS65950 PMIC Audio I/O Audio UARTs (x3) LCD +TMS320C64x DSP core running up to 430 MHz (OMAP3530 only) mDDR Memory OMAP 3 NAND Flash / Processor mDDR SDRAM OMAP 3 NAND Flash Processor + Mobile DDR / NAND flash (PoP technology) 256 MB / 512 MB Display NOR Flash McBSPs 76.5 mm GPMC BUS (x16) Ethernet SPI 4-Wire Touch + Hardware supports XGA 1024x768 at 24-bit color Wireless 802.11* & Bluetooth* 10/100 Ethernet* Touchscreen + Integrated 4-wire touchscreen controller (TSC2004) Network Support Antennas Connectors (x2) Touch Controller + Programmable color LCD controller supports up to a 24 bpp TFT interface + 10/100 Base-T Ethernet controller + 802.11b/g wireless Ethernet *on select configurations + Bluetooth 2.0 + EDR TOP VIEW :: ACTUAL SIZE (Block diagram is not drawn to scale; for reference purposes only.) Audio + I2S compliant audio codec (16-bit stereo DAC, 13-bit ADC) PC Card Expansion + CompactFlash Type I card (memory-mode only) OMAP35x SOM-LV Ordering Information + MMC/SD card support Model Number1 mDDR (MB) NAND NOR Flash (MB) Flash (MB) 10/100 Ethernet 802.11b/g Ethernet Bluetooth 2.0 + EDR Temp. (°C) DSP SOMOMAP3503-12-1783GFIR2 256 512 16 Y N N -40°–85° N SOMOMAP3530-12-1783IFXR 256 512 16 Y Y Y -20°–70° Y SOMOMAP3530-12-1783JFIR 256 512 16 Y N Y -40°–85° Y NOTES: 1. Custom configurations are available by special order. Please contact Logic PD Sales for details. 2. Does not include touch controller. USB + One USB 2.0 high-speed host interface + One USB 2.0 high-speed On-the-Go interface Serial Ports +Three external UARTs GPIO + Programmable I/O depending on peripheral requirements Software + LogicLoader™ (bootloader/monitor) + Windows® Embedded CE 6.0 BSP + Open source Linux™ BSP LOGIC PD WEBSITE :: DESIGN RESOURCES: Mechanical + SOM-LV Type III form factor 6201 Bury Dr. | Eden Prairie, MN 55346 T : 952.941.8071 F : 952.941.8065 l www.logicpd.com + Logic PD Products : www.logicpd.com/products + Logic PD Technical Support : support.logicpd.com + 31.2 mm wide x 76.5 mm long x 7.4 mm high © 2017 Logic PD, Inc. All rights reserved. PN: 1009584 Rev M + Logic PD Sales : www.logicpd.com/contact/ RoHS Compliant
SOMOMAP3530-11-1782JFIR 价格&库存
很抱歉,暂时无法提供与“SOMOMAP3530-11-1782JFIR”相匹配的价格&库存,您可以联系我们找货
