SOMAM1808-10-1502QHCR
    BEACONEMBEDDEDWORKS
    SYSTEM ON MODULE AM1808
SOMAM1808-10-1502QHCR 数据手册
PRODUCT BRIEF: Logic PD :: Texas Instruments www.logicpd.com/am1808-som-m1 AM1808 SOM-M1 System on Module AM1808 SOM-M1 :: HIGHLIGHTS: The AM1808 System on Module (SOM) is a compact, product-ready hardware and software solution that fast forwards embedded designs while reducing risk and controlling cost. + Product-ready System on Module with a TI AM1808 processor running at 450 MHz + Compact form factor—SOM-M1 (30 x 40 x 4.5 mm) + Long Based on the Texas Instruments (TI) AM1808 processor and designed in the SOM-M1 form factor, the AM1808 module offers essential features for handheld and embedded networking applications. The AM1808 SOM-M1 brings the industry leading low power ARM926 core to a small, off-the-shelf solution. The standard SOM-M1 form factor allows developers to reuse existing baseboard designs when upgrading to new Sitara processors, which extends roadmap possibilities for end-products. product lifecycle + Linux™ and Windows® Embedded CE SDKs + Commercial temp (0˚C to 70˚C) Industrial temp (-40˚C to 85˚C) + RoHS compliant ZOOM DEVELOPMENT KIT :: OPTIONS: eXperimenter Kit + AM1808 AM1808 SOM-M1 + 4.3” products, the AM1808 SOM‑M1 allows for powerful versatility, long-life, and greener products. SOM-M1 + Application baseboard WQVGA LCD panel + Necessary accessories to immediately get up and running EVM Development Kit The compact size of the AM1808 SOM-M1 is ideal for medical patient monitoring wearables and other portable instrumentation applications; the built-in Serial ATA (SATA) controller provides fast access to large capacity storage devices. For medical, industrial, audio, and communication Two Zoom™ Development Kit options allow developers to choose the platform best suited to their application needs. By starting with the corresponding Zoom Development Kit, engineers can write application software on the same hardware that will be used in their final product. + AM1808 SOM-M1 + Application + User + WLAN + 4.3” baseboard Interface (UI) board daughter card WQVGA LCD panel + Necessary accessories to immediately get up and running AM1808 SOM-M1 Block Diagram Product Features 40.0 mm Three 100-pin High Density Connectors Power 4-wire touch TPS65070 PMIC / Touch controller SATA* JTAG Camera / VPIF_DIN UARTs (x3), I2c (x2) LCD / VPIF_DOUT McASP McBSPs EMIFA HPI / UPP USB HS OTG USB FS Host SPI AM1808 Processor Processor + TI AM1808 processor with ARM926EJ-S core running at 450 MHz This outline represents the actual size of the AM1808 SOM-M1 form factor. Mobile x16 DDR SDRAM 30.0mm Serial NOR Flash Flash Memory + Scalable serial NOR flash (8 MB standard) Display + Programmable color LCD controller supports up to a 16 bpp TFT interface Touchscreen + Integrated 4-wire touchscreen controller (TPS65070) Clock Generation (includes SATA) MII SDRAM Memory + Mobile DDR (64 or 128 MB) Network Support + 10/100 Base-T Ethernet controller 10/100 Ethernet Serial ATA Controller + SATA 1.5 & 3.0 Gbps support Ethernet NOTE: Block diagram is for reference purposes only; it is not drawn to scale. PC Card Expansion + MMC/SD card support AM1808 SOM-M1 Ordering Information USB + One USB 2.0 high-speed On-the-Go interface + One USB 1.1 full-speed host interface *on select configurations Model Number Processor Speed (MHz) mDDR (MB) NOR Flash (MB) Wired Ethernet SATA Temp (°C) SOMAM1808-10-1502QHCR AM1808 450 64 8 Y N 0°–70° SOMAM1808-10-1602QHIR AM1808 450 128 8 Y N -40°–85° NOTE: Custom configurations are available by special order. Please contact Logic PD Sales for details. Zoom™ AM1808 Development Kit Ordering Information 1 Development Kit Model Number SOM-M1 Configuration Included EVM Development Kit TMDXEVMWIFI1808L SOMAM1808-10-1602AHCR 2 eXperimenter Kit TMDSEXP1808L SOMAM1808-10-1602AHCR 2 Suggested Resale NOTES: 1. The EVM and eXperimenter Kits are available through Texas Instruments distributors. 2. This configuration has added power measurement circuitry. Serial Ports + Three external UARTs + Two I2Cs GPIO + Programmable I/O depending on peripheral requirements Software + U-Boot (bootloader/monitor) + Linux™ SDK + Windows® Embedded CE SDK Mechanical + SOM-M1 form factor + 30.0 mm wide x 40.0 mm long x 4.5 mm high RoHS Compliant LOGIC PD WEBSITE :: DESIGN RESOURCES: 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com + Logic PD Products : www.logicpd.com/products © 2014 Logic PD, Inc. All rights reserved. PN: 1015625 Rev E + Logic PD Sales : www.logicpd.com/contact/inquiry + Logic PD Technical Support : www.logicpd.com/support Sitara
SOMAM1808-10-1502QHCR 价格&库存
很抱歉,暂时无法提供与“SOMAM1808-10-1502QHCR”相匹配的价格&库存,您可以联系我们找货
