SOMC6748-10-1602AHCR
    BEACONEMBEDDEDWORKS
    - Embedded Module TMS320C6748 300MHz 128MB 8MB
SOMC6748-10-1602AHCR 数据手册
PRODUCT BRIEF Logic PD :: Texas Instruments www.logicpd.com/products OMAP-L138 SOM-M1 OMAP-L138 SOM-M1 :: HIGHLIGHTS: Essential features for handheld and embedded networking applications and DSP functionality + Compact form factor—SOM-M1 (30 x 40 x 4.1 mm) System on Module + Long product lifecycle + RoHS compliant Based on Texas Instruments’ OMAP-L138 processor and designed in the SOM-M1 form factor, the OMAP-L138 module offers essential features for handheld and embedded networking applications. The OMAP-L138 SOM-M1 features the superset OMAP-L138 processor, but also supports the TMS320C6748 digital signal processor (DSP). For medical, industrial, audio, and communication products, the OMAP-L138 SOM‑M1 allows for powerful versatility, long-life, and greener products. + Linux™ DVSDK + Commercial temp (0˚C to 70˚C) Industrial temp (-40˚C to 85˚C) The OMAP-L138 System on Module (SOM) is a compact, product-ready hardware and software solution that fast forwards embedded designs while reducing risk and controlling cost. The OMAP-L138 SOM-M1 brings the industry leading low power ARM926 core to a small, off-the-shelf solution. The standard SOM-M1 form factor allows developers to reuse existing baseboard designs when upgrading to new OMAP processors, which extends roadmap possibilities for their end-product. + Product-ready System on Module with a TI OMAP-L138 processor or TMS320C6748 DSP running at 375 MHz OMAP-L138 SOM M-1 The compact size of the OMAP-L138 SOM-M1 is ideal for medical patient monitoring wearables and other portable instrumentation applications; the built-in Serial ATA (SATA) controller provides fast access to large capacity storage devices. OMAP-L138/C6748 SOM-M1 Block Diagram Product Features Choice of Processor Three 100-pin High Density Connectors Power 4-wire touch SATA* JTAG Camera / VPIF_DIN UARTs (x3), I2c (x2) LCD / VPIF_DOUT McASP McBSPs EMIFA HPI / UPP USB HS OTG USB FS Host SPI + TI OMAP-L138 processor with dual core ARM926EJ-S and C6748 VLIW DSP running at 375 MHz TPS65070 PMIC / Touch controller + TI TMS320C6748 VLIW DSP running at 375 MHz 40.0 mm OMAP-L138 Processor / TMS320C6748 x16 DSP SDRAM Memory + Mobile DDR, 64 or 128 MB Mobile DDR SDRAM Flash Memory 30.0 mm Clock Generation MII Display + Programmable color LCD controller supports up to a 16 bpp TFT interface (includes SATA) Touchscreen TOP VIEW :: ACTUAL SIZE Serial NOR Flash + Scalable serial NOR flash (16 MB standard) + Integrated 4-wire touchscreen controller (TPS65070) 10/100 Ethernet Network Support + 10/100 Base-T Ethernet controller Ethernet Serial ATA Controller *on select configurations + SATA 1.5 & 3.0 Gbps support (Block diagram is not drawn to scale; for reference purposes only.) PC Card Expansion + MMC/SD card support OMAP-L138/C6748 SOM-M1 Ordering Information USB + One USB 2.0 high-speed On-the-Go interface Model Number Processor Speed (MHz) mDDR (MB) NOR Flash(MB) 10/100 Ethernet SATA Temp (°C) + One USB 1.1 full-speed host interface SOMOMAPL138-10-1603AHCR OMAPL138 375 128 16 Y Y 0°–70° Serial Ports SOMOMAPL138-10-1503QHCR OMAPL138 375 64 16 Y N 0°–70° + Three external UARTs SOMOMAPL138-10-1603QHIR OMAPL138 375 128 16 Y N -40°–85° + Two I2Cs SOMC6748-10-1603AHCR TMS320C6748 375 128 16 Y Y 0°–70° GPIO + Programmable I/O depending on peripheral requirements NOTE: Custom configurations are available by special order. Please contact Logic PD Sales for details. Software + U-Boot (bootloader/monitor) + Linux™ DVSDK + Windows® Embedded CE SDK + DSP/BIOS + Board Support Library (BSL) sample programs Mechanical LOGIC PD WEBSITE :: DESIGN RESOURCES: 6201 Bury Dr. | Eden Prairie, MN 55346 T : 952.941.8071 F : 952.941.8065 l www.logicpd.com + Logic PD Products : www.logicpd.com/products © 2017 Logic PD, Inc. All rights reserved. PN: 1013566 Rev H + Logic PD Sales : www.logicpd.com/contact/ + Logic PD Technical Support : support.logicpd.com + SOM-M1 form factor + 30.0 mm wide x 40.0 mm long x 4.1 mm high RoHS Compliant
SOMC6748-10-1602AHCR 价格&库存
很抱歉,暂时无法提供与“SOMC6748-10-1602AHCR”相匹配的价格&库存,您可以联系我们找货
