SOMAM3517-10-1780RJCR
    BEACONEMBEDDEDWORKS
    AM35x Embedded Module ARM® Cortex®-A8, AM3517 600MHz 256MB 512MB
SOMAM3517-10-1780RJCR 数据手册
PRODUCT BRIEF: Logic PD :: Texas Instruments www.logicpd.com/ti AM3517 SOM-M2 System on Module :: SUPPORTED PROCESSORS: AM3505 AM3517 AM3517 SOM-M2 :: HIGHLIGHTS: The AM3517 System on Module (SOM) is a compact, productready pre-certified hardware and software solution that fast forwards embedded designs while reducing risk and controlling cost. + Product-ready System on Module with a TI AM3517 processor running at 600 MHz + Compact form factor—SOM-M2 (40.9 x 51.2 x 5.4 mm) Based on Texas Instruments’ new Sitara AM3517 microprocessor and designed in the SOM-M2 form factor, the AM3517 module offers essential features for handheld and embedded networking applications. The AM3517 SOM-M2 features the superset AM3517 processor, but also supports the AM3505 processor. + Long product lifecycle + Open source Linux™ BSP + Commercial temp (0˚C to 70˚C) Extended temp (-20˚C to 70˚C)  Industrial temp (-40˚C to 85˚C) + RoHS compliant ZOOM™ DEVELOPMENT KIT :: OPTIONS: The standard SOM-M2 form factor allows developers to reuse existing baseboard designs when upgrading to new AM processors, which extends roadmap possibilities for their end-product. Two Zoom™ Development Kit options allow developers to choose the platform best suited to their application needs. By starting with the corresponding Zoom Development Kit, engineers can write application software on the same hardware that will be used in their final product. The compact size of the AM3517 SOM-M2 is ideal for medical patient monitoring wearables and other portable instrumentation Low-cost eXperimenter Kit + AM3517 AM3517 SOM-M2 applications. The AM3517 includes an SGX530 graphics accelerator and multiple communication ports, including Bluetooth, wireless 802.11b/g/n, and wired 10/100 Ethernet. For commercial signage, medical imaging, avionics, and industrial displays, the AM3517 SOM‑M2 allows for powerful versatility, long-life, and greener products. SOM-M2 + eXperimenter baseboard EVM Development Kit + AM3517 SOM-M2 + eXperimenter + Application + 4.3” baseboard board WQVGA LCD panel + Necessary accessories to immediately get up and running AM3517 SOM-M2 Block Diagram Three 100-pin High Density Connectors HS USB Host USB 2.0 HS PHY UARTs LCD McBSPs TPS65023 SPI 4-Wire Touch SDRAM Memory + DDR2 256 MB (scalable to 512 MB) This outline represents the actual size of the AM3517 SOM-M2 form factor. DDR2 SDRAM AM3517/05 Processor Flash Memory + NAND flash 512 MB (scalable) 51.2 mm NAND Flash Display & Graphics + SGX530 graphics accelerator (AM3517 only) + Programmable color LCD controller supports up to a 24 bpp TFT interface Level Shifter Touchscreen + Integrated 4-wire touchscreen controller GPMC BUS Ethernet Processor + TI AM3517 processor with ARM Cortex-A8 core running at 600 MHz Clock Generation HS USB OTG Power Product Features 40.9 mm 10/100 Ethernet PHY Touch Controller Wireless 802.11* & Bluetooth* Network Support + 10/100 Base-T Ethernet PHY + 802.11b/g/n wireless Ethernet + Bluetooth 2.1 + EDR Antenna Connector PC Card Expansion + Multiple SD/MMC card support USB + One USB 2.0 high-speed On-the-Go interface + One USB 2.0 high-speed host interface *on select configurations (Block diagram is not drawn to scale. For reference purposes only.) AM3517 SOM-M2 Ordering Information Model Number Speed (MHz) DDR2 (MB) NAND Flash (MB) Wired Ethernet 802.11 Ethernet Bluetooth Temp. (°C) SOMAM3517-10-1780RJCR 600 256 512 Y b/g/n Y 0°–70° SOMAM3517-10-1780FJCR 600 256 512 Y — — 0°–70° SOMAM3517-10-1780RJXR 600 256 512 Y b/g/n Y -20°–70° SOMAM3517-10-1780FJIR 600 256 512 Y — — -40°–85° NOTE: Custom configurations are available by special order. Please contact Logic PD Sales for details: product.sales@logicpd.com. Zoom™ AM3517 Development Kit Ordering Information Development Kit Model Number SOM-M2 Configuration(s) Included Suggested Resale EVM Development Kit TMDXEVM3517 SOMXAM3517-10-1780RJCR $999 Low-cost eXperimenter Kit SDK-XAM3517-10-256512R SOMXAM3517-10-1780FJCR $199 Serial Ports + Up to four external UARTs + Three I2C ports + Three SPI ports GPIO + Programmable I/O depending on peripheral requirements Software + U-Boot (bootloader/monitor) + Open source Linux BSP Mechanical + SOM-M2 form factor + 40.9 mm wide x 51.2 mm long x 5.4 mm high FCC Part 15 Subpart C Compliant RoHS Compliant NOTES: The Zoom AM3517 EVM Development Kit is available through Texas Instruments distributors.   The Zoom AM3517 eXperimenter Kit is available through Logic PD distributors.  Both kits currently use pre-release (X) processor silicon. LOGIC PD WEBSITE :: DESIGN RESOURCES: + Logic PD Products : www.logicpd.com/products + Logic PD Technical Support : www.logicpd.com/product-support 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com + For more information contact Logic PD Sales : product.sales@logicpd.com © 2010 Logic Product Development Company. All rights reserved. PN: 1014275 Rev B Sitara
SOMAM3517-10-1780RJCR 价格&库存
很抱歉,暂时无法提供与“SOMAM3517-10-1780RJCR”相匹配的价格&库存,您可以联系我们找货
