CENGPXA270-416-11-505EXR
    BEACONEMBEDDEDWORKS
    CARD ENGINE 64MB SDRAM
CENGPXA270-416-11-505EXR 数据手册
PRODUCT BRIEF: Logic PD :: Marvell PXA270 CARD ENGINE System on Module The PXA270 Card Engine is a compact, product-ready hardware and software solution that fast forwards your embedded product design. PXA270 CARD ENGINE :: HIGHLIGHTS: + Product-ready System on Module with the Marvell PXA270 Applications Processor running at 416 or 520 MHz The PXA270 Card Engine is a complete System on Module (SOM) that offers essential features for handheld and embedded networking applications. Use of custom baseboards makes the Card Engine the ideal foundation for OEMs developing handheld and compact products. The Card Engine provides a common reference pin-out on its expansion connectors, which enables easy scalability to next generation microprocessor Card Engines when new functionality or performance is required. Application development is performed right on the product-ready PXA270 Card Engine and software Board Support Packages (BSPs), which enables you to seamlessly transfer your application code and hardware into production. The PXA270 Card Engine is ideal for applications in the medical, point-of-sale, industrial, and security markets. From patient + Compact form factor 60.2 mm x 67.8 mm x 4.4 mm + Long product lifecycle + 0 ˚C to 70 ˚C (commercial temp) or -25 ˚C to 85 ˚C (extended temp) + RoHS compliant PXA270 ZOOM ™ SDK :: FEATURES: + Application PXA270 CARD ENGINE monitoring and medical imaging, to card payment terminals and bar code readers, to CCTV cameras and intruder alarms, the PXA270 Card Engine allows for powerful versatility and long-life products. baseboard + PXA270 Card Engine (CENGPXA270-520-10-504HCR) + Necessary accessories to immediately get up and running + Kit available from Logic PD (SDK-PXA270-520-10-6432R) + See Zoom™ SDK product brief for more information Product Features PXA270 Card Engine Block Diagram EXP CONNECTOR #1 Processor + Marvell PXA270 Applications Processor running at 416 or 520 MHz EXP CONNECTOR #2 Flash Memory + 32 or 64 MB NOR standard CONFIG J TA G MARVELL PXA270 APPLICATIONS PROCESSOR U R AT AC97 / I2S TOUCHSCREEN & AUDIO CODEC SDRAM Memory + 64 MB SDRAM standard DMA INT PERIPHERALS ASYNC/SYNC BUS INTERFACE POWER IN NOR or NAND FLASH Touch Screen + Integrated 4-wire touch screen controller SDRAM BUFFERS CPLD Display + Programmable color LCD controller + Built-in driver supports up to 800x600 with 16-bit LCD interface RESETS & POWER MONITORING ETHERNET 10/100 BASE-T Network Support + 10/100 Base-T Ethernet controller for application/debug (SMSC LAN 91C111) SODIMM CONNECTOR Audio + AC97audio codec PXA270 Card Engine Ordering Information Speed SDRAM (MHz) (MB) NAND Flash NOR Flash (MB) (MB) Touch Audio Ethernet CENGPXA270-416-11-505EXR 416 64 0 64 Y Y – -25 – 85 CENGPXA270-416-11-505HXR 416 64 0 64 Y Y Y -25 – 85 CENGPXA270-520-11-504HCR 520 64 0 32 Y Y Y 0 – 70 Logic PD Model Number Temp (°C) PXA270 ZOOM SDK Ordering Information Logic PD Model Number SOM Configuration Recommended Resale SDK-PXA270-520-10-6432R CENGPXA270-520-10-504HCR $499 IrDA + SIR supports up to 115.2 Kbps, multiplexed IrDA/Bluetooth GPIO + Programmable I/O depending on peripheral requirements 1. The SDK contains a PXA270-10 Card Engine; quantities are limited. LOGIC PD WEBSITE :: DESIGN RESOURCES: + Logic PD Products : www.logicpd.com/products + Logic PD Technical Support : www.logicpd.com/product-support + For USB + USB 2.0 full-speed host and device interface Serial Ports + Three 16C550 compatible UARTs, two I2C 1 ™ PC Card Expansion + CompactFlash Type I card (memory-mapped mode only) + Smart Card, MMC/SD, dual PCMCIA interfaces more information contact Logic PD Sales : product.sales@logicpd.com Software + LogicLoader™ (bootloader/monitor) + Windows Embedded CE 5.0 BSP Mechanical + 60.2 mm wide x 67.8 mm long x 4.4 mm high RoHS Compliant 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com © 2011 Logic Product Development Company. All rights reserved. PN: 1001781 Rev E
CENGPXA270-416-11-505EXR 价格&库存
很抱歉,暂时无法提供与“CENGPXA270-416-11-505EXR”相匹配的价格&库存,您可以联系我们找货
