20-101-0955
20-101-0955
    DIGIINTERNATIONAL
    模块
20-101-0955 数据手册
RCM2200 RabbitCore® | Products | Rabbit Page 1 of 3 View Cart | Contact Us • Low-Cost Dev Kits • Application Kits RCM2200 RabbitCore® Models RCM2200, RCM2210, RCM2250, RCM2260 • RabbitCores • Latest Downloads RCM2200 Description • Single-Board Computers • Rabbit Support Forums • Training/Events D RCM2200 Specifications z z Large View | 360° View z z z z Description Our award-winning Ethernet-enabled RCM2200 RabbitCore microprocessor core module is a compact yet powerful embedded control solution for application developers working with a small design footprint. Only half the size of a credit card, the RCM2200 features the powerful Rabbit® 2000 microprocessor, 256K of Flash memory, 128K of SRAM, 4 serial ports, 26 I/O, real-time clock, and integrated Ethernet. (To permit parallel development and cost-effective implementation of both Ethernet-enabled and non-Ethernet systems, our pin-compatible RCM2300 model is also available.) z S z S Features z Compact size (2.3" x 1.6" x 0.86") z 10Base-T Ethernet z Up to 512K Flash z Up to 512K SRAM z 26 general-purpose I/O z z Designing with RabbitCores The RabbitCore family of microprocessor core modules is designed to facilitate rapid development and implementation of embedded systems. RabbitCores are powered by high-performance 8-bit Rabbit microprocessors with extensive integrated features and a C-friendly instruction set designed for use with the Dynamic C® development system. The RabbitCore mounts on a user-designed motherboard and acts as the controlling microprocessor for the user's system. Small in size but packed with powerful features, these core modules give designers a complete package for control and communication. http://www.rabbit.com/products/rcm2200/index.shtml 10/15/2008 RCM2200 RabbitCore® | Products | Rabbit Page 2 of 3 The integrated Ethernet port frees designers from the limitations of serial-port communications and control and also permits instant local or worldwide connectivity using low-cost networking hardware. Embedded systems using the Ethernet RabbitCore module can be controlled and monitored (as well as programmed and debugged when using appropriate accessory hardware) across any network or the Internet. RCM2200 CoreModule Specifications Features RCM2200 RCM2210 RCM2260 10Base-T, RJ-45, 2 LEDs 10BaseT, (raw signals only) Rabbit 2000T at 22.1 MHz Microprocessor Ethernet Port RCM2250 10Base-T, RJ-45, 2 LEDs 10Base-T (raw signals only) Flash 256K 512K SRAM 128K 512K Connection for user-supplied battery (to support RTC and SRAM) Backup Battery 26 parallel I/O include: General Purpose I/O z 16 configurable I/O z 7 fixed inputs z 3 fixed outputs 2 Startup Mode, Reset Additional Inputs Status, Reset Additional Outputs Memory I/O 4 address, 8 data, plus I/O Read-Write Serial Ports Four 5 V CMOS-compatible, 2 configurable as clocked ports (1 clocked line available only on programming header) Serial Rate Max. burst rate = CLK/32 Max. sustained rate = burst/2 Connectors Two 2 x 13, 2 mm IDC headers Slave Interface Slave port permits use as master or as intelligent peripheral with other master controller Yes Real-Time Clock Timers Five 8-bit timers (four cascadable from the first) and one 10-bit timer with 2 match registers Yes Watchdog/Supervisor 4.75-5.25 V DC, 134 mA Power -40°C to +70°C Operating Temp. 5-95%, non-condensing Humidity 2.3" x 1.6" x 0.86" (59 mm x 41 mm x 22 mm) Board Size Part Number 20-101-0454 Development Kit http://www.rabbit.com/products/rcm2200/index.shtml 20-101-0488 20-101-0494 20-1010955 U.S. 101-0475, Int'l 101-0476 10/15/2008 RCM2200 RabbitCore® | Products | Rabbit Site Map | Privacy Policy | Contact Us | Feedback http://www.rabbit.com/products/rcm2200/index.shtml Page 3 of 3 Copyright © 2008 Rabbit All Rights Reserved A Digi International® Brand 10/15/2008
20-101-0955 价格&库存
很抱歉,暂时无法提供与“20-101-0955”相匹配的价格&库存,您可以联系我们找货
