MOD5282-100CR
MOD5282-100CR
    NETBURNER
    Module
    PROCESSOR MODULE 512KB FLASH
MOD5282-100CR 数据手册
MOD5282 e t B u r n e r Networking in 1 Day! Features • Companion development kit includes all of the hardware and software you will need to develop embedded applications. This includes an RTOS, TCP/IP, Web Server, C/C++ Compiler, IDE, Graphical Debugger, configuration and deployment tools. • Start writing your application code immediately, instead of integrating development tools or building custom hardware. • Use as a high-performance single board computer, or as a network interface processor. • Module supports 3 serial ports, 16 timers, address bus, data bus, GPIO, A/D, CAN, SPI, I2C, interrupts, PWM and more. • Integrated 66Mhz 32-bit Coldfire 5282 processor with integrated 10/100 Ethernet and MAC. • 8MB SDRAM, 512K of Flash Memory. • Temperature Range: -40°C to +85° C. MOD5282 NetBurner’s High Performance Embedded Network Core Module Overview The MOD5282 processor modules are low cost, high performance single board computers that are excellent solutions to network-enable both existing and new product designs with 10/100BaseT Ethernet. Based on the Freescale ColdFire 5282 32-bit processors with integrated 10/100 Ethernet MAC, they have plenty of horsepower for the most demanding applications (rated at 60+MIPS with 66MHz clock). Network-Enable New or Existing Applications Add a module to an existing application, network enable your device though its serial ports, GPIO pins, or serial bit streams. If you have an application-specific motherboard, you can add a module and have a powerful processing platform that can function as the control processor for your product, or as a low cost network interface processor. Customize to Suit Any Application The NetBurner Network Development Kit enables you to quickly and easily create custom applications. NetBurner has a solid reputation for development platforms to facilitate rapid product development, and the module kits are no exception. The kit includes the MOD5282 module, development board, TCP/IP Stack, uC/OS Real-time operating system, Web Server, GNU C/C++ compiler and linker, GDB graphical debugger, end-user device configuration, flash update utilities, and much more. Real 32-Bit Performance Traditionally, companies using 8 and 16-bit platforms find it nearly impossible to run resource-intensive applications on fast Ethernet connections. The NetBurner Embeded Network Core Module features a Web-based control interface, a full 32-bit architecture providing 60+ MIPS, and the ability to send and receive email. This processing platform provides the horsepower to handle both 10/100 Ethernet connections and resource-demanding applications with ease and flexibility. www.NetBurner.com NetBurner Datasheet MOD5282-A MOD5282 Specifications Part Numbers Processor and Memory 32-bit Freescale ColdFire 5282 running at 66MHz with 8MB SDRAM, 512KB Flash, and 64KB SRAM NetBurner MOD5282 Development Kit P/N: NNDK-MOD5282-KIT Includes all the hardware and software you need to customize the included NetBurner MOD5282 module. This kit includes the NetBurner MOD-DEV-100 Carrier Board. Flash Card Support SD/MMC (up to 2GB), SDHC (16GB+) , Compact Flash (32GB+) Software Development NetBurner MOD5270 Development Kit includes MOD5282 module, TCP/IP stack, Web Server, real-time operating system (RTOS), ANSI C/C++ compiler and linker, assembler, graphical debugger, NetBurner Eclipse integrated development environment (IDE), code update, configuration, and deployment tools. Network Interface & Serial Interfacees 10/100 BaseT with RJ-45 connector, 3 UARTS, I2C, SPI, Up to50 Digital I/O Network Protocols Supported Please reference the NetBurner Software Datasheet for a complete list of the protocols included with the development kit (www.NetBurner.com). Connectors Two dual row 50-pin male headers Physical Characteristics Dimensions: 2.0” x 2.6” Mounting Holes: 2 x 0.125” dia Note: For more detailed diagrams please reference the MOD5282 Mechanical Drawing which can be found on the NetBurner MOD5282 Ethernet Core Module web page. Power DC Input Voltage: 3.3V @500mA Environmental Operating Temperature -40°C to 85°C NetBurner MOD5282 Ethernet Core Module P/N: MOD5282-100IR The MOD5282-100IR Module is a industrial temperature, RoHS compliant part. NetBurner MOD5282-200IR Ethernet Core Module with 10-pin Ethernet Jack Header P/N: MOD5282-200IR The MOD5270 Board is a industrial temperature, RoHS compliant part. NetBurner Development Kit Support & Maintenance Agreement Renewal P/N: NBMAINT-100 Extends software updates, tools updates and email support for a period of 1 year. Note: 1. All NetBurner hardware produced after July of 2006 is RoHS compliant. Ordering Information E-mail: sales@netburner.com Online Store: www.NetburnerStore.com Telephone: 1-800-695-6828 MCF5282 Block Diagram JTAG BDM 8 ch QADC 10/100 Ethernet 2 KB I-Cache DMA I2C UART 4 ch, 32-bit Timer QSPI UART 8 ch, 16-bit Timer CAN UART 4 ch PIT 512 KB Flash 64 KB RAM eMAC ColdFire® V2 Core DMA Bus Control SDRAM Chip Selects Figure 2: Freescale ColdFire Block Diagram e t B u r n e r Networking in 1 Day! Revision 1.0, April 4, 2006. © 2006 NetBurner, Inc. Specifications are subject to change without notice. Every effort has been made to ensure all information is correct, but NetBurner, Inc. is not responsible for inadvertant errors. Freescale(tm) and the Freescale logo are Note: trademarks of Freescale Semiconductor, Inc. All other product or service MOD5282 is based on the Freescale ColdFire 5282 processor. For addinames are the property of their respectiveThe owners. (c) Freescale Semiconductor, Inc. 2006 tional processor specific information please reference the Freescale Coldfire 5282 Manual. www.NetBurner.com NetBurner Datasheet MOD5282-B MOD5282 Ethernet Jack Pinout and Signal Description (200 version module) The MOD5282-200IR version NetBurner Ethernet Core Module has a 10-pin header which enables you to connect to your own Ethernet jack. Table 2: Module Ethernet 10- Pin Dual Row Header Pinout and Signal Descriptions Pin 1 2 3 4 5 6 7 8 9 10 Signal TXTX+ VCC1 RX+ RXVCC1 GND N/C LED LED Description Transmit Transmit + 2.5V Recieve + Recieve 2.5V Ground Not Connected Link LED Speed LED Note: 1. The 2.5V pins are used for the magnetics taps and LED power. e t B u r n e r Revision 1.0, April 4, 2006. © 2006 NetBurner, Inc. Specifications are subject to change without notice. Every effort has been made to ensure all information is correct, but NetBurner, Inc. is not responsible for inadvertant errors. Freescale(tm) and the Freescale logo are trademarks of Freescale Semiconductor, Inc. All other product or service names are the property of their respective owners. (c) Freescale Semiconductor, Inc. 2006 Networking in 1 Day! www.NetBurner.com NetBurner Datasheet MOD5282-B MOD5282 MOD5282 Pinout and Signal Description The MOD5282 module has two dual in-line 50 pin headers which enable you to quickly and easily connect to one of our standard NetBurner Carrier Boards, or a board you create on your own. Table 1 and 2 provide descriptions of pin function of the MOD5282 header. Table 1: NetBurner MOD5282 Pinout and Signal Connector (1) for J1 Connector Pin 1 2 3 4 5 6 7 8 9 10 11 +2 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 CPU Pin N15 L14 L15 L16 N16 M14 P16 J1 Connector Function GPIO Description GND Ground GND Ground VCC3V Input Power 3.3V R/*W Read / NOT Write *CS1 Chip Select 1 *CS2 Chip Select 2 *CS3 Chip Select 3 *OE Output Enable *BS2 Byte Strobe for D16 to D23 (8 bits) *BS3 Byte Strobe for D24 to D31 (8 bits) *TIP Transfer in Progress SYNCB GP Timer B Synchronization Input D16 Data Bus - Data 16 *TA Transfer Acknowledge D18 Data Bus - Data 18 D17 Data Bus - Data 17 D20 Data Bus - Data 20 D19 Data Bus - Data 19 D22 Data Bus - Data 22 D21 Data Bus - Data 21 D24 Data Bus - Data 24 D23 Data Bus - Data 23 D26 Data Bus - Data 26 D25 Data Bus - Data 25 D28 Data Bus - Data 28 D27 Data Bus - Data 27 D30 Data Bus - Data 30 D29 Data Bus - Data 29 *RSTI Processor Reset Input D31 Data Bus - Data 31 *RSTO Processor Reset Output CLKOUT Clock Out (CLKOUT-66.355 Mhz) A0 Data Bus - Address 0 A1 Data Bus - Address 1 A2 Data Bus - Address 2 A3 Data Bus - Address 3 A4 Data Bus - Address 4 A5 Data Bus - Address 5 A6 Data Bus - Address 6 A7 Data Bus - Address 7 A8 Data Bus - Address 8 A9 Data Bus - Address 9 A10 Data Bus - Address 10 A11 Data Bus - Address 11 A12 Data Bus - Address 12 A13 Data Bus - Address 13 A14 Data Bus - Address 14 A15 Data Bus - Address 15 VCC3V Input power 3.3V GND Ground GND Ground e t B u r n e r • • • • • Note: 1. Asterisk (*) denotes active low. All input/output lines are 3.3V only. 2. Plus sign (+) denotes additional alternate pin function • • Revision 1.0, April 4, 2006. © 2006 NetBurner, Inc. Specifications are subject to change without notice. Every effort has been made to ensure all information is correct, but NetBurner, Inc. is not responsible for inadvertant errors. Freescale(tm) and the Freescale logo are trademarks of Freescale Semiconductor, Inc. All other product or service names are the property of their respective owners. (c) Freescale Semiconductor, Inc. 2006 Networking in 1 Day! www.NetBurner.com NetBurner Datasheet MOD5282-B MOD5282 Table 2: NetBurner MOD5282 Pinout and Signal Descriptions (1) for J2 Connector Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 +1 30 31 +1 32 +1 33 +1 34 +1 35 36 +1 37 +1 38 +1 39 40 41 42 43 +1 44 45 +1 46 47 +1 48 +1 49 50 CPU Pin T13 T12 R13 R12 P13 P12 R7 P7 N13 N12 F14 G14 F16 F13 K14 Function GND VCC3V URXD0 UTXD0 ADVCC AN3 AN1 AN2 AN56 AN0 AN53 AN52 AN55 GND GPTA3 GPTB3 GPTA2 GPTB2 GPTA1 GPTB1 URXD1 UTXD1 GPTA0 GPTB0 SPI_CLK SPI_CS3 SPI_DIN SPI_DOUT TIN2 F15 J14 SPI_CS0 TIN0 K15 DTOUT3 K13 DTOUT2 J15 DTOUT1 G13 J13 SPI_CS2 DTOUT0 J13 TIN1 K16 TIN3 E14 F16 D16 E15 D15 SDA SPI_CS1 CANRX SCL IRQ1_LVS IRQ1_FET CANTX IRQ3_LVS IRQ3_FET GND IRQ5_LVS IRQ5_FET IRQ7_LVS IRQ7_FET GND VCC3V N6 T7 R1 R2 T2 R3 T3 T4 R4 P3 E13 C16 C14 B15 e t B u r n e r J2 Connector Note: Description 1. Plus sign (+) denotes additional Ground alternate pin function Input power 3.3V UART 0 Receive4 2. If using I2C, the module must add UART 0 Transmit4 pull-up resistors to SDA/SCL. ADVCC 3. The third UART ( UART2) can be Analog I/O CH3 routed to either of the two pin Analog I/O CH1 configurations: replacing CAN RX Analog I/O CH2 Analog I/O CH56 andTX, or I2C SDA and SDL. Analog I/O CH0 4.TIN0, TIN1 and TIN2 can be used as Analog I/O CH53 external baud rate clocks for UART0, Analog I/O CH52 UART1 and UART2 Analog I/O CH55 Ground General Purpose Timer A3 General Purpose Timer B3 General Purpose Timer A2 General Purpose Timer B2 General Purpose Timer A1 General Purpose Timer B1 UART 1 Receive4 UART 1 Transmit4 General Purpose Timer A0 General Purpose Timer B0 QSPI Clock QSPI Chip Select 3 QSPI Input QSPI Data Out UCTS0 DMA Timer 24 In or UART 0 Clear to Send4 or UCTS1 UART 1 Clear to Send4 QSPI Chip Select 0 UCTS0 DMA Timer 04 In or UART 0 Clear to Send4 or UCTS1 UART 1 Clear to Send4 URTS0 DMA Timer 3 Out or UART 0 Request to Send4 or URTS1 UART 1 Request to Send4 UCTS0 DMA Timer 2 Out or UART 0 Clear to Send4 or UCTS1 UART 1 Clear to Send4 URTS0 DMA Timer 1 Out or or UART 0 Request to Send4 or URTS1 UART 1 Request to Send4 QSPI Chip Select 2 UCTS0 DMA Timer 0 Out or UART 0 Clear to Send4 or UCTS1 UART 1 Clear to Send4 URTS0 DMA Timer 14 In or UART 0 Request to Send4 or URTS1 UART 1 Request to Send4 URTS0 DMA Timer 34 In or UART 0 Request to Send4 or URTS1 UART 1 Request to Send4 URXD2 I2C Data Line2 or UART 2 Receive3,4 QSPI Chip Select 1 URXD2 CAN Receive or UART 2 Receive3,4 UTXD2 I2C Clock Line2 or UART 2 Transmit3,4 IRQ1_RET IRQ1 Level-Sensitive, Rising Edge Triggered, IRQ1_FRT Falling Edge Triggered, Falling and Rising Edge Triggered CAN Transmit IRQ1_RET IRQ3 Level-Sensitive, Rising Edge Triggered, IRQ1_FRT Falling Edge Triggered, Falling and Rising Edge Triggered Ground IRQ5_RET IRQ5 Level-Sensitive, Rising Edge Triggered, IRQ5_FRT Falling Edge Triggered, Falling and Rising Edge Triggered IRQ7_LVS IRQ5 Level-Sensitive, Rising Edge Triggered, IRQ7_FET Falling Edge Triggered, Falling and Rising Edge Triggered Ground Revision 1.0, April 4, 2006. 2006 NetBurner, Inc. Specifications are subject to change without notice. Every effort Input power © 3.3V has been made to ensure all information is correct, but NetBurner, Inc. is not responsible for inadvertant errors. Freescale(tm) and the Freescale logo are trademarks of Freescale Semiconductor, Inc. All other product or service names are the property of their respective owners. (c) Freescale Semiconductor, Inc. 2006 Alt. Func. GPIO • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Networking in 1 Day! www.NetBurner.com NetBurner Datasheet MOD5282-B Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: NetBurner: NNDK-MOD5282-KIT MOD5282-100CR MOD5282-100IR NNDK-MOD5282LC-KIT MOD5282-200IR
MOD5282-100CR 价格&库存
很抱歉,暂时无法提供与“MOD5282-100CR”相匹配的价格&库存,您可以联系我们找货
