CENGLH79520-10-403HCR
    BEACONEMBEDDEDWORKS
    CARD ENGINE 32MB SDRAM
CENGLH79520-10-403HCR 数据手册
WWW.LOGICPD.COM A B C LH79520 CARD ENGINE The LH79520 Card Engine is a compact, product-ready hardware and software solution for developing embedded products with less time, less cost, less risk ... more innovation. Developing embedded solutions is as simple as A B C The LH79520 Card Engine is a complete single board computer offering essential features for handheld and embedded networking applications in the industrial, consumer and medical markets. The use of custom peripheral boards makes the Card Engine the ideal foundation for OEMs developing handheld and compact products. The Card Engine provides a common reference pin-out on its expansion connectors, which enables customers to easily scale to next generation microcontroller Card Engines when new functionality or performance is required. A Application Development Kits B Board Support Packages C Card Engines LH79520 Custom Card Engine Peripheral Board Final Product Actual Size (2.37” x 2.67”) SOFTWARE HIGHLIGHTS Ready to run Linux Bootloader/Monitor Board Support Packages Custom Linux device driver development services available Supports other operating systems S T R AT E G I C PA R T N E R APPLICATION DEVELOPMENT KITS Processor Sharp LH79520 32 bit ARM720T RISC processor running up to 77.414 MHz SDRAM Memory Up to 64 Mbytes Flash Memory Up to 16 Mbytes on board Display Programmable color LCD controller - Built in driver supports up to 800 x 600 x 16 bit color - Supports STN, Color STN, HR-TFT, AD-TFT, TFT Touch Screen Four wire resistive touch controller Network Support 10/100 BASE-T Ethernet controller (application/debug) - SMSC LAN 91C111 (MAC & PHY) Audio Audio Codec Stereo Output (TI TLV320DAC23) PC Card Expansion Compact Flash Type 1 card (memory mode only) Serial Ports 2 X 16C550 like, standard UARTS IrDA SIR supports up to 115.2 Kbps GPIO Programmable depending on peripheral requirements SSP Supports either Motorola SPITM, National Semiconductor MICROWIRETM, TI SSI Software - Linux BSP available Q1 ‘03 - LogicLoaderTM (bootloader/monitor) Mechanical - Compact Size: 2.37”(60.2 mm) long x 2.67”(67.8 mm) wide x 0.17”(4.4 mm) high - 144 pin SODIMM connector for connection to custom peripheral board - Two high density 80-pin expansion connectors for peripheral access Application Development Kits - ZoomTM Starter Development Kit - ZoomTM Integrated Development Kit - available Q2 ‘03 BSPS & SOFTWARE CARD ENGINES PRODUCT DEVELOPMENT SERVICES © 2002 LOGIC PRODUCT DEVELOPMENT 411 WASHINGTON AVE N SUITE 101 MINNEAPOLIS MN 55401 TEL: 612.672.9495 FAX: 612.672.9489 WWW.LOGICPD.COM DN: 70000022 Rev C
CENGLH79520-10-403HCR 价格&库存
很抱歉,暂时无法提供与“CENGLH79520-10-403HCR”相匹配的价格&库存,您可以联系我们找货
