SOMDM3730-30-2780AKCR
    BEACONEMBEDDEDWORKS
    SYSTEM ON MODULE TORP+ DM3730
SOMDM3730-30-2780AKCR 数据手册
PRODUCT BRIEF: Logic PD :: Texas Instruments www.logicpd.com/ti DM3730 / AM3703 Torpedo + Wireless System on Module :: SUPPORTED PROCESSORS: DM3730 AM3703 Combine a powerful applications processor with PC-like speeds and a wireless chipset with 802.11a/b/g/n, Bluetooth, and GPS support; toss in Android and Linux BSPs developed using processes compliant with the ISO 13485 medical system standard; and the outcome is an innovative off-theshelf solution that reduces your development time and risk. The award-winning Torpedo + Wireless System on Module (SOM) is an ultra-compact form factor built around the Texas Instruments’ DaVinciTM DM3730 processor or SitaraTM AM3703 processor and WiLinkTM 7.0 wireless solution. Confining these two systems to a single board isolates the complex design, manufacturing, and wireless certifications from the rest of your product. The DM3730/AM3703 Torpedo + Wireless SOM occupies less than one square inch, but boasts PC-like speeds up to 1 GHz with long battery life. Partnered with such high performance is a startlingly low power consumption in suspend state. This balance of speed and power is accomplished through Logic PD’s vast system design experience; understanding the most detailed workings of each component and their interaction with one another creates a product that operates at optimal efficiency. The WL1283 wireless chipset provides access to all the wireless protocols required in today’s connected world. 802.11a/b/g/n, Bluetooth, and GPS signals are natively integrated with the DM3730/AM3703 Torpedo + Wireless SOM and Logic PD BSPs. AWARDS WON IN 2012: + CONNECT + Design Most Innovative Product News Golden Mousetrap Award + Embedded Innovation Computing Design Top Embedded DM3730 / AM3703 TORPEDO + WIRELESS SOM :: HIGHLIGHTS: + Product-ready System on Module with a TI DM3730 or AM3703 ARM® Cortex™-A8 processor running up to 1 GHz DM3730 / AM3703 TORPEDO + WIRELESS SOM + Android & Linux™ Board Support Packages (BSPs) + Network By using the same connectors as Logic PD’s existing OMAP35x and DM3730/AM3703 Torpedo SOMs, the DM3730/AM3703 Torpedo + Wireless SOM extends the roadmaps of existing products and provides an upgrade path from today’s products to future technologies. & GPS + FCC & IC modular certified + Commercial & industrial temp configurations + Ultra-compact form factor (15 x 33 x 3.8 mm installed) + Same connectors as DM3730 / AM3703 Torpedo SOM + Long The ultra-compact DM3730/AM3703 Torpedo + Wireless SOM is an ideal off-the-shelf solution for applications in markets where network connectivity is required and space is a premium. From point-ofcare medical products to handheld communication devices, the DM3730/AM3703 Torpedo + Wireless SOM allows for the powerful versatility and compact designs needed in today’s market-changing products. connectivity: 802.11a/b/g/n, Bluetooth, product lifecycle ZOOM™ DM3730 TORPEDO DEVELOPMENT KIT :: FEATURES: + Application baseboard + DM3730 Torpedo + Wireless SOM DM3730 Torpedo SOM + 4.3” WQVGA LCD with 4-wire touchscreen + Wattson™ + Necessary power measurement application accessories to immediately get up and running DM3730 / AM3703 Torpedo + Wireless SOM Block Diagram Product Features 33 mm 15 mm TOP VIEW :: ACTUAL SIZE BOTTOM VIEW :: ACTUAL SIZE (Block diagram is not drawn to scale. For reference purposes only.) DM3730 / AM3703 Torpedo + Wireless SOM Ordering Information Model Number1 Speed (MHz) SDRAM (MB) NAND Flash (MB) Temperature SOMAM3703-30-1780AKIR 800 256 512 Industrial2 SOMDM3730-30-2780AKCR 1000 256 512 Commercial3 SOMDM3730-30-1780AKIR 800 256 512 Industrial2 SOMDM3730-30-1880AKIR 800 512 512 Industrial2 NOTES: 1. Custom configurations are available by special order. Please contact Logic PD Sales for details. 2. Junction temperature of the DM3730/AM3703 processor must stay below 105°C. 3. Junction temperature of the DM3730/AM3703 processor must stay below 90°C. Zoom™ DM3730 Torpedo Development Kit Ordering Information Model Number SOM Configuration SDK-DM3730-30-256512R SOMDM3730-30-2780AKCR SOMDM3730-20-2780AGCR Suggested Resale LOGIC PD WEBSITE :: DESIGN RESOURCES: + Logic PD Products : www.logicpd.com/products + Logic PD Technical Support : www.logicpd.com/support 411 N. Washington Ave. Suite 400 Minneapolis, MN 55401 T : 612.672.9495 F : 612.672.9489 I : www.logicpd.com + Contact Logic PD Sales : www.logicpd.com/contact/inquiry © 2013 Logic PD, Inc. All rights reserved. PN: 1020571 Rev F Processor + TI DaVinci™ DM3730 or Sitara™ AM3703 ARM® Cortex™-A8 core running up to 1 GHz + TMS320C64x DSP core running up to 800 MHz (DM3730 only) + POWER SGX™ graphics accelerator (DM3730 only) Memory + Mobile DDR / NAND flash (PoP technology) 256 MB / 512 MB (standard) 512 MB / 512 MB (standard) Network Connectivity + WL1283 wireless module featuring 802.11a/b/g/n, Bluetooth, & GPS Display + Programmable color LCD controller supports up to a 24 bpp TFT interface + Hardware supports XGA 1024x768 at 24-bit color Camera + Parallel camera interface Audio + I2S compliant audio codec (16-bit stereo DAC, 13-bit ADC) User Interface + Optional 4x4 keypad interface PC Card Expansion + Multiple SD/MMC card support USB + One USB 2.0 high-speed On-the-Go interface Serial I/O + UARTs, SPI, I2C, McBSPs GPIO + Programmable I/O depending on peripheral requirements + General purpose memory controller (GPMC) interface Debug + 40-pin debug connector on top side of SOM + JTAG & ETM support Software + Android BSP + Linux™ BSP + LogicLoader™ (bootloader/monitor) + Wattson™ power measurement application Mechanical (Installed) + 15 mm wide x 33 mm long x 3.8 mm high FCC & IC Modular Certified RoHS Compliant
SOMDM3730-30-2780AKCR 价格&库存
很抱歉,暂时无法提供与“SOMDM3730-30-2780AKCR”相匹配的价格&库存,您可以联系我们找货
