AS8515-ZMFM
AS8515-ZMFM
    AMSOSRAM(艾迈斯半导体)
    MLF32
    IC BATTERY MANAGEMENT
AS8515-ZMFM 数据手册
high performance needs great design. Datasheet: AS8515 Data Acquisition System with Power Management and LIN Transceiver for 12V Battery Sensor Applications Please be patient while we update our brand image as austriamicrosystems and TAOS are now ams. www.ams.com AS8515 D a t a A cq u is i t io n S y st e m w i t h P o w e r M a n a g em en t and L IN Tr an sc e iv er for 12V Battery Sensor Applications 1 General Description The AS8515 is designed for simultaneous measurement of shunt current sensor signal and battery voltage by two independent ADC channels. Both channels can measure small signals up to ±160 mV versus ground through programmable gain amplifier or larger signals in the 1V range without amplifier. After analog to digital conversion and digital filtering, the resulting digital values are accessible through 4-wire serial interface. The device is powered directly from the battery through LDO and provides a 3.3V supply for an external microcontroller. For communication with the next level ECU, the device offers a LIN 2.1 transceiver. Measurement of battery voltage is supported through resistive attenuator with disable for power saving in standby. The device is a stacked die system providing a high voltage CMOS IC for power management and transceiver functions as a Top die and low voltage sensor interface functions as a Bottom die inside a 32-pin MLF (5x5 mm) package. Internal temperature sensor Synchronous acquisition for both ADC channels Reference-voltage source (high precision and high stability) Offset auto zero architecture on both channels Current monitoring comparator with interrupt signal generation and µC clock enable. Timer with 2 related outputs for single shot sampling of current and voltage channel in low power mode. Precision on chip RC oscillator or external clock. Low slew, low EMC clock output which can be used by external microcontroller which is enabled respectively disabled by mode control through SPI and interrupt from current monitor in low power mode. The integrated circuit can execute measurements with internal and external sensors and sources for the voltage channel and with external sensor for the current channel. External Sensors: 2 Key Features A precision voltage attenuator with power down facility LIN 2.1 transceiver Power-On Reset with OTP adjustable reset timeout and brown- out detection A window Watchdog function in the normal mode and a timeout Watchdog in the device standby mode as a factory option Load dump protection (42V) for all battery supplied pins, LIN bus pin, and Enable pin Internal reverse polarity protection (up to -27V) for all battery- sensing pins, and LIN bus pin Over temperature warning & shutdown functions Two independent high resolution A/D converters with programmable over sampling ratio Current measurement via Shunt resistor (4 ranges) Battery voltage (internal voltage divider to battery) ETR and ETS for external temperature sensor (with switchable current source) Internal Sensors: On chip temperature sensor Internal current sources for functional test of measurement path and the connection of shunt resistor 3 Applications The AS8515 is suitable for battery sensors, having shunt current sensor at minus pole. For lead acid, AGM, Li-Ion batteries up to 18V nominal, 42V over voltage capability. The device is also ideal as a general purpose sensor interface for automotive LIN slaves. Programmable sampling rate up to 4kHz throughput Programmable gain, low noise amplifier for current channel with gain stages 5, 25, 40, 100 www.ams.com Revision 0.5 1 - 62 AS8515 Datasheet - A p p l i c a t i o n s VCC LDO POR_VSUP ETR AVDD DVDD Voltage Channel To voltage channel ADC Multiplexer, Current Source AS8515 Low Precision Clock POR_VCC lp_clk LPM Control Logic High Precision Clock CLK Current Channel ADC RSHH PGA RSHL VSENSE CHOP_CLK DEC hp_clk VSUP MEN ETS Figure 1. AS8515 Block Diagram Temperature Limiter VSENSE_IN VSENSE_IN Voltage Channel ADC PGA DEC VSENSE_GND VSENSE_GND SPI, Comparator, Filter Option CSB VREF VCM AVSS DVSS SCLK SDI SDO INT Reference Generator RESET CST VSS SPI, Diagnosis, WWD LIN Tx Rx EN LIN LIN www.ams.com Revision 0.5 2 - 62 AS8515 Datasheet - C o n t e n t s Contents 1 General Description .................................................................................................................................................................. 1 2 Key Features............................................................................................................................................................................. 1 3 Applications............................................................................................................................................................................... 1 4 Pin Assignments ....................................................................................................................................................................... 5 4.1 Pin Descriptions.................................................................................................................................................................................... 5 5 Absolute Maximum Ratings ...................................................................................................................................................... 7 6 Electrical Characteristics........................................................................................................................................................... 8 6.1 Operating Conditions............................................................................................................................................................................ 8 6.2 DC/AC Characteristics for Digital Inputs and Outputs .......................................................................................................................... 8 6.3 System Specifications ........................................................................................................................................................................ 7 AS8515 Top Die Overview...................................................................................................................................................... 10 11 7.1 Voltage Attenuator .............................................................................................................................................................................. 11 7.2 Voltage Regulators (LDO) .................................................................................................................................................................. 11 7.3 LIN Transceiver .................................................................................................................................................................................. 11 7.4 Temperature Monitor/Limiter............................................................................................................................................................... 11 7.5 VSUP Under-voltage Reset................................................................................................................................................................ 12 7.6 Reset .................................................................................................................................................................................................. 12 7.7 VCC Under-voltage Reset .................................................................................................................................................................. 12 7.8 Window Watchdog (WWD) ................................................................................................................................................................. 13 7.9 Timeout Watchdog (TWD) .................................................................................................................................................................. 13 7.10 Modes of Operation .......................................................................................................................................................................... 7.10.1 7.10.2 7.10.3 7.10.4 Normal Mode ........................................................................................................................................................................... Standby Mode.......................................................................................................................................................................... Temporary Shutdown Mode .................................................................................................................................................... Thermal Shutdown Mode......................................................................................................................................................... 14 15 15 15 15 7.11 Initialization ....................................................................................................................................................................................... 16 7.12 Wake-up ........................................................................................................................................................................................... 17 7.12.1 Remote Wake-up Event........................................................................................................................................................... 17 7.13 LIN BUS Transceiver........................................................................................................................................................................ 18 7.13.1 Transmit Mode......................................................................................................................................................................... 18 7.13.2 Receive Mode.......................................................................................................................................................................... 18 7.14 Rx and Tx Interface .......................................................................................................................................................................... 19 7.14.1 Input Tx.................................................................................................................................................................................... 19 7.14.2 Output Rx................................................................................................................................................................................. 19 7.15 MODE Input EN................................................................................................................................................................................ 20 7.16 Top Die Block Specifications ............................................................................................................................................................ 21 7.16.1 Voltage Attenuator ................................................................................................................................................................... 21 7.16.2 Voltage Regulator (LDO) ......................................................................................................................................................... 22 7.16.3 LIN Transceiver ....................................................................................................................................................................... 22 7.17 Timing Diagrams .............................................................................................................................................................................. 24 7.17.1 Tx Timeout Watchdog.............................................................................................................................................................. 26 7.17.2 Temperature Limiter ................................................................................................................................................................ 26 7.18 Top Die Registers ............................................................................................................................................................................. www.ams.com Revision 0.5 26 3 - 62 AS8515 Datasheet - C o n t e n t s 8 AS8515 Bottom Die Overview ................................................................................................................................................ 28 8.1 Current Measurement Channel .......................................................................................................................................................... 28 8.2 Voltage/Temperature Measurement Channel ..................................................................................................................................... 28 8.3 Digital Implementation of Measurement Path..................................................................................................................................... 29 8.4 Reference-Voltage.............................................................................................................................................................................. 29 8.5 Oscillators........................................................................................................................................................................................... 29 8.6 Power-On Reset ................................................................................................................................................................................. 29 8.7 Modes of Operation ............................................................................................................................................................................ 8.7.1 8.7.2 8.7.3 8.7.4 Normal Mode 1 (NOM1) ............................................................................................................................................................ Normal Mode 2 (NOM2) ............................................................................................................................................................ Standby Mode1 (SBM1) ............................................................................................................................................................ Standby Mode2 (SBM2) ............................................................................................................................................................ 8.8 Initialization Sequence at Power ON .................................................................................................................................................. 8.8.1 8.8.2 8.8.3 8.8.4 8.8.5 Soft-reset of Device Using Bit D[7] of Reset Register 0x09....................................................................................................... Soft-reset of the Measurement Path Using Bit D[7] of Reset Register 0x09 ............................................................................. Reconfiguring Gain Setting of PGA .......................................................................................................................................... Configuring the Device During Normal Mode ............................................................................................................................ Standby Mode - Power Consumption ........................................................................................................................................ 8.9 Bottom Die Block Specifications......................................................................................................................................................... 30 31 31 32 33 33 34 35 35 35 36 36 8.9.1 Current Measurement Ranges (across 100µΩ (±5%) shunt resistor) ...................................................................................... 36 8.9.2 System Specifications................................................................................................................................................................ 42 9 4-Wire SPI Interface................................................................................................................................................................ 43 9.1 SPI Timing Parameters ...................................................................................................................................................................... 9.1.1 9.1.2 9.1.3 9.1.4 SPI Frame.................................................................................................................................................................................. Write Command......................................................................................................................................................................... Read Command......................................................................................................................................................................... Timing ........................................................................................................................................................................................ 9.2 Bottom Die Registers.......................................................................................................................................................................... 43 44 44 45 46 47 10 Application Information ......................................................................................................................................................... 57 11 Package Drawings and Markings.......................................................................................................................................... 58 12 Ordering Information............................................................................................................................................................. 61 www.ams.com Revision 0.5 4 - 62 AS8515 Datasheet - P i n A s s i g n m e n t s 4 Pin Assignments Figure 2. Pin Assignments (Top View) RSHH EN RESET Rx Tx CST INT 32 31 30 29 28 27 26 25 RSHL 1 24 CLK VREF 2 23 SDI VCM 3 22 MEN AVDD 4 21 CHOP_CLK AVSS 5 20 DVDD ETR 6 19 DVSS ETS 7 18 SDO VSENSE_IN 8 17 SCLK AS8515 9 VSENSE_GND 10 11 LIN 12 13 VSS VSENSE VSUP 14 15 16 VCC CSB 4.1 Pin Descriptions Table 1. Pin Descriptions Pin Name Pin Number Pin Type RSHL 1 Analog input Negative differential input for current channel VREF 2 Analog output Internal reference voltage to Sigma Delta ADC; Connect 100nF to AVSS from this pin. VCM 3 Analog output Common mode voltage to the internal measurement path; Connect 100nF to AVSS from this pin. 1 4 Analog input +3.3V Power-supply; Supplied by LDO output (VCC) in Top die; Should be shorted to pin 21 (VCC) externally. 2 5 Power supply 0V Power-supply Ground analog AVDD AVSS www.ams.com Description Revision 0.5 5 - 62 AS8515 Datasheet - P i n A s s i g n m e n t s Table 1. Pin Descriptions Pin Name Pin Number ETR 6 ETS 7 VSENSE_IN 8 Analog I/O VSENSE_GND 9 Analog input LIN 10 Analog I/O 11 Power supply 0V Power-supply Ground analog VSENSE 12 Analog input Battery voltage input Connect 100nF to VSS from this pin. VSUP 13 Power supply Supply input from battery (through external reverse polarity protection device) - 14 - 15 Analog output CSB 16 Digital input Chip select for Bottom die SCLK 17 Digital input Clock signal SPI SDO VSS VCC 2 1 Pin Type Analog input Description Voltage channel single ended input Battery voltage attenuator output and voltage channel input Input signal for voltage channel (low) LIN BUS Regulated 3.3V output supply for loads up to 50mA 18 Digital output Data signal SDO 2 19 Power supply 0V Power-supply digital 1 20 Analog input +3.3V Power-supply; Supplied by LDO output (VCC) in Top die; Should be shorted to pin 21(VCC) externally. CHOP_CLK 21 Digital output Chopper clock MEN 22 Digital I/O SDI 23 Digital I/O Data signal SDI CLK 24 Digital I/O Internal/External digital clock signal - 25 - INT 26 Digital I/O CST 27 Digital input Tx 28 Digital I/O LIN transceiver transmit pin Rx 29 Digital I/O LIN transceiver receive pin RESET 30 Digital output Reset output (open drain) EN 31 Digital input Enable input RSHH 32 Analog input Positive differential input for current channel DVSS DVDD 3 Digital output for Bottom die in SBM mode and input for Top die Interrupt not: Wake-up, digital interrupt, ready flag 2 Chip select for Top die 1. Pin #4, pin #20 and pin #21 needs to be shorted externally on the board. Pin #21 is the LDO output that supplies pin #4 and pin #20. 2. Pin #5, pin #11 and pin #19 needs to be shorted externally on the board as they are the grounds. 3. Use as output port only. www.ams.com Revision 0.5 6 - 62 AS8515 Datasheet - A b s o l u t e M a x i m u m R a t i n g s 5 Absolute Maximum Ratings Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 8 is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Table 2. Absolute Maximum Ratings Symbol Parameter Min Typ Max Units Comments Electrical Parameters VSUP Supply voltages -0.3 42 V VSENSE Battery voltage inputs -27 42 V AVDD, DVDD DC supply voltage -0.3 5 V EN Enable input -0.3 42 V VCC Regulated output supplies -0.3 5 V LIN LIN bus -27 40 V VCC generated by Top die must not be larger than 5V on board level as it has to be connected with Bottom die AVDD and AVCC Analog & digital inputs and outputs -0.3 5 V Input current (latch-up immunity) -100 100 mA Norm: AEC-Q100 – or Jedec 78 kV LIN, VSS ±4 kV VSUP, VSENSE ±2 kV All other pins 0.375 W MLF-32 in still air, soldered on JEDEC standard board @125º ambient, static operation = no time limit 40 ºC/W 150 ºC 130 ºC Electrostatic Discharge ESD Electrostatic discharge Norm: AEC-Q100 ±6 Continuous Power Dissipation 1 Ptot Total operating power dissipation (all supplies and outputs) Temperature Ranges and Storage Conditions RΘ Package thermal resistance Tstg Storage temperature TJ Junction temperature TBODY 34 -55 Package body temperature 260 ºC Soldering conditions 250 ºC 85 % Humidity non-condensing 5 The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). 1. Total power dissipation cannot exceed 0.375W to avoid increase in junction temperature, i.e. greater than 130ºC. VCC LDO can supply current externally, which is not greater than 17mA at 18V VSUP and 20mA at 16V VSUP. www.ams.com Revision 0.5 7 - 62 AS8515 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s 6 Electrical Characteristics Unless otherwise noted in this specification, all defined tolerances of parameters are assured over the whole operation conditions range and also over lifetime. 6.1 Operating Conditions Table 3. Operating Conditions Symbol Parameter Min VSUP Supply voltages VSENSE Max Unit 4.3 18 V Battery voltage input 4.5 18 V AVDD Positive supply voltage 3.15 3.45 V AVSS Negative supply voltage 0 V DVDD Positive digital supply voltage 3.15 3.45 DVSS Negative digital supply voltage 0 LIN LIN bus 0 18 V EN Enable input 0 18 V VCC Regulated output supply 3.15 3.45 V TAMB Ambient temperature -40 115 ºC 27 mA ISUP 1 fCLK Typ Referring to DVSS, Typical ±10% V Supply current System clock frequency V Note 8.192 MHz Maximum junction temperature (TJ) is 130ºC When external clock is selected, internal clock will be 4.096 MHz 1. Total power dissipation cannot exceed 0.375W to avoid increase in junction temperature, i.e. greater than 130ºC. VCC LDO can supply current externally, which is not greater than 17mA at 18V VSUP and 20mA at 16V VSUP. 6.2 DC/AC Characteristics for Digital Inputs and Outputs All pull-up, pull-downs have been implemented with active devices. SDO have been measured with 10pF load. INT Output. Table 4. INT Symbol Parameter Condition Min Typ Max VOH High level output voltage VOL Low level output voltage 0.4 V IO Output current 4 mA Max Unit 2.5 Unit V CST, CSB, TxD. Table 5. CST, CSB Symbol Parameter VIH High level input voltage VIL Low level input voltage ILEAK Input leakage current IPU Pull-up current www.ams.com Condition Min Typ 0.8*VCC V 0.2*VCC Pulled to GND Revision 0.5 V -1 +1 µA -150 -10 µA 8 - 62 AS8515 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s SDI, SCLK. Table 6. SDI, SCLK Symbol Parameter VIH High level input voltage VIL Low level input voltage ILEAK Input leakage current Condition Min Typ Max 2.0 Unit V -1 0.8 V +1 µA Max Unit SDO Output. Table 7. SDO Symbol Parameter Condition Min Typ VOH High level output voltage VOL Low level output voltage 0.4 V IO Output current 4 mA Max Units 2.5 V CHOP_CLK Output. Table 8. CHOP_CLK Symbol Parameter Conditions Min Typ VOH High level output voltage VOL Low level output voltage 0.4 V IO Output current 4 mA Max Units 2.5 V EN Input. Table 9. EN Symbol Parameter Conditions VIH High level input voltage VIL Low level input voltage ILEAK Input leakage current EN = VSS Ipd_en Pull-down current Pulled up to VCC Min Typ 0.8*VCC V 0.2*VCC V -1 +1 µA 30 100 µA Max Unit CLK I/O. Table 10. CLK I/O Symbol Parameter VIH High level input voltage VIL Low level input voltage Condition Min Typ 2.4 V 1 V ILEAK Input leakage current -1 +1 µA IPD_EN Pull-down current 10 100 µA IO Output current 4 mA VOH High level output voltage VOL Low level output voltage 0.4 V www.ams.com 2.5 Revision 0.5 V 9 - 62 AS8515 Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s MEN Output. Table 11. MEN Symbol Parameter Conditions Min Typ Max VOH High level output voltage VOL Low level output voltage 0.4 V IO Output current 2 mA Max Units 2.5 Units V Rx Output. Table 12. Rx Symbol Parameter Conditions Min Typ VOH High level output voltage VOL Low level output voltage VSS+0.4 V IO Output Current 1 mA Ipu_reset Pull-up current Pulled down to VSS -30 -100 µA Symbol Parameter Conditions Min Max Units VOH High level output voltage VOL Low level output voltage IO Output current VCC-0.5 V RESET Output. Table 13. RESET Typ 2.5 V Open Drain Pull-down 0.4 V 8 mA Max Unit 7 mA 6.3 System Specifications Table 14. System Specifications Symbol Parameter Condition Ivsupnom Current consumption in normal mode No load on VCC, LIN bus in dominant state Ivsupstdby Current consumption standby No load on VCC, LIN bus in recessive state Min Typ 80 µA Note: Stand by mode power consumption is sum of stop mode power consumption and average of normal mode power consumption over a period of 2s (NOM1 time of device is low in Standby mode). www.ams.com Revision 0.5 10 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7 AS8515 Top Die Overview The AS8515 Top die consists of a resistive divider, a low dropout regulator, and a LIN bus transceiver. Additionally integrated are a RESET unit with a power-on-reset delay, programmable window watchdog and timeout watchdog timers. It also includes a watchdog timeout on LIN Tx node to indicate if the Microcontroller is stuck in a loop and the LIN bus remains in dominant time for more than the necessary time. 7.1 Voltage Attenuator A resistive divider is used as a battery voltage attenuator. Like the amplifier, the attenuator can be enabled or disabled through SPI, and in the device standby mode, we additionally need logic high on MEN pin for enabling. Internal reverse polarity protection is provided for VSENSE pin. Figure 3. Attenuator Implementation VSENSE PD VSENSE_IN VSENSE_GND 7.2 Voltage Regulators (LDO) The device has a low-dropout voltage regulator named LDO, 3.3V voltage outputs. The output of the LDO is VCC. The regulator is always ON except when the device enters the over-temperature shutdown. The regulator has in-built short-circuit current limitation feature. The regulator can be temporarily shut down for hard reset of the external circuitry by configuring the device to temporary shutdown mode through SPI. The LDO power-up happens when the POR-VSUP event occurs (RESET_VSUP_N switching from low to high). The LDO will be switched off if there is an under voltage on VCC, that is, when RESET_VCC_N switches back to low. 7.3 LIN Transceiver The device has a LIN transceiver with slew-controlled bus driver for controlling the electromagnetic emissions from the LIN bus. Further, the slew rate is independent of the bus load. The transmitter relays the data from the LIN controller (Tx pin) to the bus (LIN pin), and the receiver provides the data on the bus to the controller (Rx pin). The transceiver conforms to the LIN 2.1 standard. The LIN transceiver has a timeout watchdog for Tx. After the timeout, the LIN bus will be released to the recessive state from the dominant state. The bus driver has an in-built short-circuit current limitation facility to protect the device from damage when there is a short between the bus and the supply. In addition to the data receiver, there is a low-power receiver active in the device standby mode which received a wake-up event from the LIN bus to bring the device to normal mode. 7.4 Temperature Monitor/Limiter The temperature limiter circuit powers down the device when the junction temperature exceeds 170°C (nominal). It also issues an overtemperature warning at 160°C (nominal). The device is powered up again when the junction temperature falls below 140°C (nominal). The overtemperature warning flag is also cleared at this temperature. The temperature limiter circuit can be optionally disabled through SPI. www.ams.com Revision 0.5 11 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.5 VSUP Under-voltage Reset When VSUP drops below VSUVR_ON, the RESET_VSUP_N switches back to low level. This is treated as a master reset and will have the highest priority over all other signals. In this case, the regulators, LIN transceiver, and all other blocks are shut off, and the device comes to a complete stop. The device returns to the normal mode when VSUP rises over VSUVR_OFF again irrespective of the mode it was in prior to this under-voltage condition. 7.6 Reset RESET module generates an active-low reset signal for the external circuitry supplied by VCC. The behavior of the reset output is depicted in Figure 4 in different cases. As shown, RESET signal is affected by an under-voltage condition on VCC and Watchdogs which are described in detail in the subsequent sections. The reset period can be one-time programmed to 4, 16 and 32 ms with a default value of 8 ms. Figure 4. Reset Functionality VSUP T>Tj VCC T Vuvr_off (2.75V), active-low PORN_2_OTP is generated. The rising edge of PORN_2_OTP loads contents of fuse onto the OTP latch after load access time TLoad. LOAD_OTP_IN_PREREG signal loads contents of OTP latch onto a register. This register provides the actual settings of LDO, Vuvr_off and Reset Timeout period TRes. This is done as the OTP block is powered by the VCC. If VCC > Vuvr_off (phase 2), Reset timeout is restarted. RESET signal is de-asserted after Reset Timeout period TRes (phase 2) and then device enters into normal mode. The circuit also needs to initialize correctly for very slow ramp rates on VSUP (of the order of 0.5V/min). Figure 7. Initialization Sequence VSUP_POR_Threshold VSUP RESET_VSUP_N LDO Off Device Settings PHASE 1 PHASE 2 LDO On VCC Por Threshold = 2.75V LDO setting = 3.3V Reset Timeout = 4msec LDO On VCC Por Threshold = from OTP Block LDO setting = from OTP Block Reset Timeout = from OTP Block LDO settings to 5 V LDO settings to 3.3 V VCC_POR_Threshold VCC RESET_VCC_N PORN_2_OT P 6 Cycles of RC-Oscillator LOAD_OTP_IN_PREREG RESET If Phase 1 POR threshold != Phase 2 POR threshold Tres = Reset Timeout from OTP Block If Phase 1 POR threshold == Phase 2 POR threshold Tres = Reset Timeout from OTP Block Table 16. VSUP>Vsuvr_on and VCCVSUP). No additional termination resistor is necessary to use the AS8515 in LIN slave nodes. If this IC is used for LIN master nodes it is necessary that the BUS pin is terminated via an external 1kΩ resistor in series with a diode to VSENSE. 7.13.2 Receive Mode The data signals from the BUS pin will be transferred continuously to the pin Rx. Short spikes on the bus signal are suppressed by the implemented debouncing circuit. Including all tolerances the LIN specific receive threshold values of 0.4*VSUP and 0.6*VSUP will be securely observed. Figure 9. Receive Mode Impulse Diagram Vthr_max 60% BUS Vthr_hys Vthr_cnt 50% 40% Vthr_min t < tdeb_BUS t < tdeb_BUS Rx www.ams.com Revision 0.5 18 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.14 Rx and Tx Interface 7.14.1 Input Tx The 3.3V input Tx controls directly the BUS level. LIN Transmitter acts like a slew-controlled level shifter. A dominant state (low) on Tx leads to the LIN bus being pulled low (dominant state) too. The Tx pin has an internal active pull up connected to VCC. This guarantees that an open Tx pin generates a recessive BUS level. Figure 10. Tx Interface MCU AS8515 VCC VCC IPU_TxD Tx RC-Filter (10ns) 7.14.2 Output Rx The received BUS signal will be output to the Rx pin: BUS < Vthr_cnt – 0.5 * Vthr_hys → Rx = low BUS > Vthr_cnt + 0.5 * Vthr_hys → Rx = high This output is a push-pull driver between VCC and GND with an output current of 1mA Figure 11. Rx Interface AS8515 MCU VCC Rx www.ams.com Revision 0.5 19 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.15 MODE Input EN The AS8515 Top die is switched from normal mode to the standby mode with a falling edge on EN and keeping Tx high for TSTNDY_trigger time. Device is switched from standby mode to normal mode with a rising edge at the EN pin. The mode change for Top die with a falling edge on EN can be done independently from the state of the transceiver bus. This ensures the direct control of device to enter into standby mode by microcontroller using EN pin. Figure 12. EN Pin Functionality EN Tx Ttx_su Normal Mode TSTNDY_trigger Ttx_hd Standby/Sleep Mode Normal Mode The EN input has an internal active pull down to secure that if this pin is not connected, a low level will be generated. Figure 13. Enable Interface CLOAD EN VCC + +3.3V VBAT CIN RESET VSUP LIN VSS AS8515 + Tx Rx MCU VSENSE If the application doesn’t need the low-power modes of the device, a direct connection of EN to VCC is possible. In this case the Top die operates in permanent normal mode. Also possible is the external (outside of the module) control of the EN line via VSUP signal as shown below. www.ams.com Revision 0.5 20 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w Figure 14. EN Connection for Permanent Normal Mode CLOAD EN VCC + +3.3V VBAT CIN RESET VSUP LIN VSS AS8515 + Tx MCU Rx 7.16 Top Die Block Specifications This section provides specification of design related key parameters. 7.16.1 Voltage Attenuator Table 18. Voltage Attenuator Symbol Parameter RDIV Division ratio VSENSE Input voltage range/ Battery voltage range εp,RDIV Ratio error Condition Min Typ 4.5 12 At room temperature, VSENSE=12V Temperature: -25 to +65º @VSENSE=12V Maximum values will be added after device evaluation (to be guaranteed by evaluation) ±0.05 εdt2,RDIV Temperature: -40 to +125º @VSENSE=12V Maximum values will be added after device evaluation (to be guaranteed by evaluation) ±0.2 εdv1,RDIV VSENSE: 11V to 13V @Temperature=27º Maximum values will be added after device evaluation (to be guaranteed by evaluation) ±0.05 VSENSE: 6V to 18V @Temperature=27º Maximum values will be added after device evaluation (to be guaranteed by evaluation) ±0.2 εdt1,RDIV Ratio drift (with reference to Temperature) Ratio drift (with reference to VSENSE) εdv2,RDIV www.ams.com Max 21 Revision 0.5 Unit V/V 18 V ±1 % % % 21 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.16.2 Voltage Regulator (LDO) Table 19. Voltage Regulator Symbol Parameter VSUP Min Typ Max Unit Input Supply Voltage 4.3 12 18 V VCC Output Voltage Range 3.15 3.3 3.45 V ILOAD LDO Load Current 45 mA ICC_SH Output Short Circuit Current Normal mode 250 mA dVCC1 Line Regulation ΔVCC / ΔVSUP for VSUP range 8 mV/V LOREG Load Regulation ΔVCC / ΔICCn (0.5mA < ILOAD < 50mA) 1 mV/mA Output Capacitor 1 LDO Electrolytic 2.2 10 μF 1 10 Ω Output Capacitor 2 LDO Ceramic 100 220 nF CL1 ESR1 CL2 ESR2 CSUP1E ESR1_CSUP CSUP2C ESR2_CSUP Condition Input capacitor (Electrolytic) For EMC suppression Input capacitor (Ceramic) 0.02 1 W 22 100 μF 1 10 Ω 100 220 nF 0.02 1 Ω 7.16.3 LIN Transceiver DC Electrical Characteristics. Table 20. Driver Symbol Parameter Condition Min Typ Max Unit Ibus_lim Current limitation in dominant state LIN = VSUP_max 40 120 200 mA LIN_VOL Output Voltage BUS (dominant state), ILIN = 40mA (short-circuit condition tested at VOL=2.5V) 2 V Pull-up resistor Normal mode (recessive BUS level on Tx pin) 60 KΩ Ibus_leak_rec Driver OFF; 7.3V < VSUP < 18; 8V < VBAT < 18, VSUP < VBUS < 1.08 * VSUP (to be tested at VBUS = 18V) 20 µA Max Unit 20 40 Table 21. Receiver Symbol Parameter Condition Min Ibus_leak_dom Input Leakage current at receiver Driver OFF; VBUS = 0V; VSUP = 12V; VCC = 3.3V -1 Ibus_no_GND VSS = VSUP; VSUP = 12V; 0V < VBUS < 18V, VCC = 3.3V (to be tested at VBUS = 18V) -1 Ibus_no_bat VSUP = VSS; 0V < VBUS < 18V, VCC = VSS (to be tested at VBUS = 18V) Vbus_dom Vbus_rec www.ams.com 0.6 Revision 0.5 Typ mA 1 mA 100 µA 0.4 VSUP VSUP 22 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w Table 21. Receiver Symbol Parameter Condition Min Vbus_cnt Vbus_cnt = (Vth_dom + Vth_rec)/2 Vhys Vhys = (Vth_dom – Vth_rec) 1 1 Typ Max Unit 0.475 0.525 VSUP 0.05 0.175 VSUP Max Unit 1. Vth_dom : Receiver threshold of the recessive to dominant LIN bus edge Vth_rec : Receiver threshold of the dominant to recessive LIN bus edge AC Electrical Characteristics. LIN Driver, Bus load conditions (CBUS ; RBUS): 1nF; 1kΩ / 6, 8nF; 660Ω / 10nF; 500Ω Table 22. LIN Driver Symbol Parameter Condition Min D1 (worst case 20Kbps transmission) Vth_rec(max) = 0.744 x VSUP; Vth_dom(max) = 0.581 x VSUP; VSUP = 6.0V...18V; tbit = 50µs; D1 = tbus_rec(min) / (2 x tbit) 0.396 D2 (worst case 20kbps transmission) Vth_rec (min) = 0.422 x VSUP; Vth_dom (min) = 0.284 x VSUP; VSUP = 6V...18V; tbit = 50µs; D2 = tbus_rec(max) / (2 x tbit) D3 (worst case 10.4kbps transmission) Vth_rec (max) = 0.778 x VSUP; Vth_dom (max) = 0.616 x VSUP; VSUP = 6.0V...18V; tbit = 96µs; D3 = tbus_rec(min) / (2 x tbit) D4 (worst case 10.4kbps transmission) Vth_rec (min) = 0.389 x VSUP; Vth_dom (min) = 0.251 x VSUP; VSUP = 6V...18V; tbit = 96µs; D4 = tbus_rec(max) / (2 x tbit) 0.59 tdLR VCC = 3.3V; Propagation delay bus dominant to Rx LOW 6 µs tdHR VCC = 3.3V; Propagation delay bus dominant to Rx HIGH 6 µs tRS Receiver delay symmetry -2 2 µs tWAKE Dominant time for wake-up via LIN bus 30 150 µs tsln Transition from standby mode to normal mode (clock frequency is 128KHz ±25%) 4 Clock cycles tnsl Transition from normal mode to standby mode (clock frequency is 128KHz ±25%) 6 Clock cycles trec_deb Receiver de-bounce time Cint Internal capacitance of the LIN node configured as a slave with a 180pF cap on the LIN bus www.ams.com Revision 0.5 Typ 0.581 0.417 0.6 220 3 µs 250 pF 23 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.17 Timing Diagrams Figure 15. Timing Diagram for Propagation Delays TxD 50% t df_TXD t dr_TXD V BUS 100 % 95% BUS 50% 50% 5% 0% t df_RXD RxD www.ams.com t dr_RXD 50% Revision 0.5 24 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w Figure 16. Timing Diagram for Duty Cycle According to LIN 2.1 and J2602 tBit tBit TxD tx_dom_max tx_rec_max tx_dom_min VSUP t x_rec_min trec(min) 100 % tdom(max) BUS t dom(min) 58.1% 61.6% 74.4% 77.8% 42.2% 38.9% 28.4% 25.1% V SS 58.1% 61.6% trec(max) 28.4% 25.1% 0% tbit tbit TxD tbus_dom(max) tbus_rec(min) tbus_dom(min) tbus_rec(max) LIN Vth_rec(max) Vth_dom(max) Vth_rec(min) Vth_dom(min) www.ams.com Revision 0.5 25 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w 7.17.1 Tx Timeout Watchdog Table 23. Tx Timeout Watchdog Symbol Parameter Conditions tlin_wdog Timeout period for the dominant state Min Typ Max Units 0.5 1 2 s Min Typ Max Units 155 170 185 ºC 142 157 172 ºC 125 140 155 ºC 7.17.2 Temperature Limiter Table 24. Temperature Limiter Symbol Parameter Tsd Shut down temperature Totset Over-temperature warning Tret Return temperature Conditions Junction temperature 7.18 Top Die Registers The serial interface can be used for communication between AS8515 and an external microcontroller. The device is only a slave and the microcontroller has to initiate the communication. The device can be configured by writing into the control registers and the diagnostic information can be read out from the diagnostic registers. Pin CST is used as chip select for SPI communication. A total of 32 registers, each of 8-bits which include configuration, diagnostic, and backup are available. The registers can be accessed using the 4-wire serial interface. Table 25 provides a description of all AS8515 Top die registers. Table 25. AS8515 Top Die Registers Address Register Name Default Value R/W Description Configuration and Control Registers 0x00 Reserved 0x01 Reserved 0x02 Reserved 0x03 Device Configuration Register On POR_VCC 0000_1100 R/W D0 Reserved D1 Voltage Attenuator Enable Bit. 0 Disabled, 1 Enabled D2 Enable/Disable Over Temperature Monitor 0 Disabled, 1 Enabled D3 Enable/Disable LIN Transceiver 0 Disabled, 1 Enabled D4 Reserved D5-D7 Reserved 0x04 Device Control Register On POR_VSUP 0000_0001 R/W D0 High-slew / Low-slew control 1 High-slew, 0 Low-slew D1-D7 Reserved 0x05 Temporary Shutdown Register On POR_VCC 0000_0000 R/W D0 Temporary shutdown control bit 1 Enter temporary shutdown D1-D7 Reserved 0x06 Window Watch Dog Trigger Register 0x07 Reserved 0x0A Reserved 0x0B Reserved www.ams.com On POR_VCC 0000_0000 W D0 Window Watchdog trigger bit D1 Timeout Watchdog trigger bit Upon a trigger, the bit will be cleared within 2 internal clock cycles. D2-D7 Reserved Revision 0.5 26 - 62 AS8515 Datasheet - A S 8 5 1 5 To p D i e O v e r v i e w Table 25. AS8515 Top Die Registers Address Register Name 0x0C Reserved 0x0D Reserved 0x0E Default Value Watchdog Timer On POR_VCC Control Register 0000_0000 0x0F R/W Description R/W D0 Timer resolution 0 1 second, 1 32 seconds D1-D7 Timeout period. If D0=1, then timeout period = D[7:1]*64*0.512 seconds, else timeout period = D[7:1]*0.512 seconds Reserved OTP Registers 0x10 …… 0x17 OTP_BITS_RE G[0:7] POR_VSUP …………….. On0000_0000 OTP_BITS_RE G_[55:63] R 8 OTP data registers These registers contain all the 64 OTP bits. It can be read by the MCU when needed. OTP_bits 0 – 63 OTP_BITS_REG[00:07] = OTP_BITS[00:07] OTP_BITS_REG[08:15] = OTP_BITS[08:15] OTP_BITS_REG[16:23] = OTP_BITS[16:23] OTP_BITS_REG[24:31] = OTP_BITS[24:31] OTP_BITS_REG[32:39] = OTP_BITS[32:39] OTP_BITS_REG[40:47] = OTP_BITS[40:47] OTP_BITS_REG[48:55] = OTP_BITS[48:55] OTP_BITS_REG[56:63] = OTP_BITS[56:63] R D7-D0 = DR[7:0], 8-LSB bits of the 24-bit Diagnostic Register. D0 POR-VSUP Set when VSUP < Vsuvr_on, cleared after µC read D1 Under voltage VCC (UVVCC) Set when VCC < Vuvr_on, cleared after µC read D2 Over-temperature Reset (OTEMP170) Set when temp > Tsd, cleared after µC read D3 Over-temperature warning (OTEMP160) Set when temp > Totset, cleared after µC read D4 Overvoltage VSENSE (OVVSENSE) Set when VSUP > Vovthh, cleared after µC read D5 Reserved D6 Remote wakeup (RWAKE) Set on remote wakeup event on LIN Bus, cleared after µC read D7 Set on failure of window Watchdog trigger, cleared after µC read R D7-D0 = DR[15:8], Next 8-LSB bits of the 24-bit Diagnostic Register. D0 Tx timeout of 1sec (TXTIMEOUT) Set on Tx low > 1sec, cleared after µC read D1 TEMPSHUT This bit is set on entering temporary shutdown state and cleared after µC read. D2 Set on failure of timeout Watchdog trigger, cleared after µC read D3 Load Dump Flag D7-D4 Reserved Diagnostic Registers 0x08 0x09 www.ams.com Diagnostic Register-1 Diagnostic Register-2 On POR_VSUP 0000_0011 On POR_VSUP 0000_0000 Revision 0.5 27 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w 8 AS8515 Bottom Die Overview The AS8515 Bottom die consists of two independent high resolution 16-bit SD analog to digital conversion channels. The measurement path of these two channels integrates a programmable gain amplifier, chopper and de-chopper, sigma-delta modulator, decimator and a digital filter for simultaneous measurement of Current and Voltage/Temperature. The two measurement channels, namely the Current and Voltage/Temperature measurement channels have identical data path. The input signal is amplified in the Programmable Gain Amplifier (PGA) with any of the selected gains of 1, 5, 25, 40 and 100 facilitating measurement of a wide range of Current, voltage and temperature levels. Gain Settings for different input ranges and any associated restrictions are explained in the Table 27. Offset in the measurement path is minimized with the use of a chopper and a de-chopper at appropriate stages in the data path. By default the chopper/de-chopper is ON in the measurement path. It may be disabled by programming the appropriate register. The amplified input signal is converted into a single-bit pulse-density modulated stream by the Σ-Δ Modulator. A decimator acting as a low-pass filter filters out the quantization noise and generates 16-bit data corresponding to the input signal. The decimation ratios of 64, 128 may be selected in the first filter stage. For reducing data rate further, the second stage decimation can be used. An optional FIR Filter is provided to offer matched low pass filter response typically required in lead acid battery sensor systems. 8.1 Current Measurement Channel The voltage across a Shunt Resistor, connected in series with the Battery negative terminal, forms the input signal to the Current Measurement channel. RSHH and RSHL are the Current measurement input pins. Offset in the input signal is nullified with the use of a chopper and a dechopper at appropriate stages in the data path. The programmable gain amplifier in the data path with programmable settings of 1, 5, 25, 40 and 100 enables measurement of current ranges from ±1A to ±1500A. The sampled input signal is converted into a single-bit pulse-density modulated stream by the Σ-Δ Modulator. A decimator acting as a low-pass filter filters out the quantization noise and generates 16-bit data equivalent to the input current signal. The programmable input sampling rate and the decimation ratio determine the output data rates. The data path can be programmed to provide 1Hz to 2 kHz rates in the various modes available. An optional FIR filter is provided to offer matched low pass filter response typically required in lead acid battery sensor systems. After enabling the current measurement channel, the delay for the availability of the first sample is two conversion cycles. 8.2 Voltage/Temperature Measurement Channel The other two parameters of the Battery for measurement are Voltage and its Temperature. The second channel accepts signals from four independent sources through a Multiplexer as listed below: An attenuator battery voltage obtained through internal resistor divider from Top die, (or) A signal from the external temperature sensor, (or) A signal from external reference, (or) A signal from the internal temperature sensor. Apart from this difference in the multiplexing of four input signals, the rest of the data path is identical to the Current measurement channel. RSHH and RSHL are the Current measurement input pins. The Battery Voltage which can go up to 18V is attenuated through a Resistor Divider externally and is applied to the Voltage Channel. For Automotive Battery measurement, the Gain of the PGA should be restricted to 5 and 25. The latency for the first result from the voltage measurement channel is two conversion cycles. A second option on this measurement channel is to measure Temperature. Internally generated constant current is pumped through the Temperature Sensor with positive temperature coefficient, and, a high- precision resistor. The voltages across the sensor and the resistor form the inputs to the measurement channel one at a time. The difference between the two voltages which is independent of the magnitude of the current is used to determine the temperature accurately. The voltage across the sensor is applied between the ETS and VSS pins and, the voltage across the high-precision resistor is applied between ETR and VSS. External temperature measurement involves the acquisition of two signals one after the other using the same constant current source. The latency for the first result from the temperature measurement channel is two conversion cycles. A third option on the measurement channel is to measure the internal temperature. Hence, one of the three options for measurement of Battery Voltage, External Temperature and, internal temperature may be carried out by selection of appropriate inputs through the internal multiplexer selection. ETR and ETS inputs can optionally be used to measure other signal sources like external resistive attenuators for battery voltages different to 12V nominal. ETR and ETS are single ended inputs and referenced to AVSS. Voltage drop on internal bond wire causes ~100 digits of offset with systematic temperature dependency of another 50 LSB’s over temperature. www.ams.com Revision 0.5 28 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w 8.3 Digital Implementation of Measurement Path Figure 17. Block Diagram of Digital Implementation R2 R1 MOD_I N CIC1 64 / 128 fchop * 2 / R2 fchop * 2 fmod / R1 Dechopper fmod MOD_CLK fchop FIR_MA_SEL CIC2 fchop * 2 / R2 FIR / MA DATAOUT R1 R1 = First decimation ratio (64 or 128) R2 = Second decimation ratio (1 to 32768) CHP_CLK CLK DIVISION BLOCK MOD_CLK Figure 17 shows the digital implementation of the decimator and filter to process the 1-bit output of the Modulator. This block receives a 1-bit pulse density modulated output (MOD_IN) from the second order sigma delta modulator along with the oversampling frequency clock (MOD_CLK). The MOD_CLK directly goes to a clock division block, which generates chopper clock (CHOP_CLK). The CHOP_CLK can be one of 2kHz or 4kHz selected by Register CLK_REG in Table 46. The MOD_CLK can be either 1MHz or 2MHz. The Decimation is a two phase process. In the first phase, the R1 down sampling rate can be obtained by selecting either 64 or 128 in Registers DECREG_R1_I, DECREG_R1_V in Table 46. The 16-bit CIC1 output is dechopped with respect to CHOP_CLK. The output of Dechopper is passed through the CIC2 filter with a decimation ratio of 1to 32768 in steps of power of 2. This output is then processed through a FIR or Moving Average (MA) filter. FIR Filter is provided to offer matched low pass filter response typically required in lead acid battery sensor systems. MA filter is used to provide averaged output and the number of samples for averaging can be any integer value from 1 to 15. 8.4 Reference-Voltage Band gap-reference voltage is used for the ADC as a reference and for the generation of the current for external temperature measurement. 8.5 Oscillators A High-speed oscillator (HS) generates the oversampling clock. For internal state machine and Interrupt generation, a low-speed Oscillator (LS) is also available. 8.6 Power-On Reset The AS8515 has PORs, APOR and DPOR on analog and digital power supplies respectively. On PORs of both supplies, initialization sequence happens and the system status is shown in state diagram (see Figure 18). As shown in the state diagram, the system is in RESET state until DPOR output goes to logic HIGH and subsequently until APOR output goes to logic HIGH. Once analog power supply is available, the system goes into OTP_INT state and loads the default values into the control and data registers and goes into STOP state. If analog POR, APOR goes low at any time, the system goes into RESET state. In the STOP state, the AS8515 can be programmed and by giving start command it starts working following the state machine. www.ams.com Revision 0.5 29 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w 8.7 Modes of Operation The device operates in four different modes, namely, Normal Mode 1 (NOM1) Normal Mode 2 (NOM2) Standby Mode 1 (SBM1) Standby Mode 2 (SBM2) The Normal Modes are full-power modes with the exception that in Normal Mode 2, sampling is normally at a programmed lower frequency and is increased to a higher rate only when a measured input signal level crosses the programmed threshold in the current measurement channel. The Standby Modes are lower power modes. Sampling is normally at a very low frequency interval. In Standby Mode 2, data sampling can be carried out only when the internal comparator detects the input current to be greater than the programmed threshold and it generates interrupt on the INT pin. The device enters into the “Stop” state on Power On. This is a state where in the data path is inactive and can be entered into from any of the four Modes. The State transition Diagram involving the state of Stop and the four Modes is illustrated in the Figure 18. !por_dvdd Figure 18. Finite State Machine Model of AS8515 Bottom Die por_avdd !por_avdd RESET Wait for otp_load Completes in 32 cycles of lp_clk otp_load OTP_INT STOP s to p 1.5msec & NORM A_STB SBM sto p www.ams.com SBM_ON ut eo NO RM tim 1_ TT Wait for x number of conversions NORM NORM or stop 1.5msec & SBM Analog Stablization period Wait for 1.5msec rt stop s ta SBM Revision 0.5 SBM_OFF Wait for TT1 timeout 30 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Figure Notes: 1. Device soft reset can be written in any of the following states STOP, A_STB, SBM_ON, SBM_OFF by writing “0” into D[7] of the RESET _REG (Address 0X09). 2. Measurement path of soft reset should be written in any the states, STOP, SBM_OFF by writing “0” into D[6] of the RESET _REG (Address 0X09). 3. When soft reset is used for the measurement path or for the device, external clock needs to be disabled if the system clock is external clock in the application. 8.7.1 Normal Mode 1 (NOM1) On Power-on-reset of the device, AS8515 goes into STOP State. Transition to Normal mode1 (NOM1) occurs when the “START BIT” D0 of Mode Control Register MOD_CTL_REG in Table 46 is set to “1” through the serial port SPI. Data Rate of voltage and current channels can be independently programmed and both the channels generate interrupts for every output available from ADC. The interrupt signal is generated on the INT pin. The width of the interrupt pulse is eight cycles of lp_clk. The data is stable up to the next interrupt. If the data rate is different for the two channels, the interrupt rate would follow the higher rate among the two channels. Data update can be known by reading the status register. The functionality is explained in the waveform shown in Figure 19. When the device is configured to NORMAL Mode1 from any mode the configuration should be through the STOP state only. Figure 19. Normal Mode 1 I IDATA Sampling with f1 t V,T V,TDATA Sampling with f2 t STOP START Current Channel DATA Register Voltage Channel DATA Register INT at f1 rate from current channel 8.7.2 Interrupt from the current channel is at f1 rate which is integer multiple of f2 rate from voltage channel TINT Normal Mode 2 (NOM2) NOM2 differs from NOM1 in such a way that it allows for a relaxed data rate at a period of TMC by programming the corresponding register as long as the amplitude of current is less than a programmed threshold ITHC. However, when, the measured input signal exceeds the programmed threshold, the data rate is changed to the rate of NOM1 mode. Transition to NOM2 occurs when the “START BIT” D0 of Mode Control register MOD_CTL_REG in Table 46 is set to 1 and mode control bits to 01 through SPI. In this mode the data rate should be programmed with the time of TMC. An interrupt signal is generated on INT at the rate of TMC secs with a pulse width of eight cycles of lp_clk. The data is stable up to the next interrupt. The data sample is compared against the programmed threshold and when it is exceeded, the data sampling rate is changed to provide data at the data rate of NOM1 mode. However, as soon as the data sample amplitude falls below the programmed threshold, the sampling rate is restored to provide data at the rate of TMC. The functionality is illustrated in the waveform Figure 20. www.ams.com Revision 0.5 31 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Figure 20. Normal Mode 2 I I < I THS V,I,T I DD V,I,T V,I,T TMC V,I,T V,I,T TMC ITHS t Sampling with f I > I THS INT T INT 8.7.3 Standby Mode1 (SBM1) The low-power Standby Mode can be entered only through the STOP state. Transition to SBM1 mode occurs when the “START BIT” D0 of Mode Control register MOD_CTL_REG in Table 46 is set to “1” and Mode Control Bits to “10” through SPI. In this mode the date rate is programmable with the time of Ta. An interrupt signal is generated on INT at the rate of Ta seconds, and with a pulse width of eight cycles of lp_clk. The data is stable up to the next interrupt. The functionality is illustrated in Figure. During the period of Ta, only one data sample is made available and, during the rest of the period, the device is maintained in STOP state to reduce power consumption. The microcontroller which receives the data on the Interrupt, is also expected to be processing the data for a short time as shown clearly in the Figure 21 to ensure the overall low-power consumption of the data acquisition and processing system. Figure 21. Standby Mode 1 I DD MCU MCU MCU V, I, T V, I, T ADC t Ta sec. Start SBM1 Channel DATA Register Ta Tconv DATA – A0 sec. DATA – A1 Tconv Ta sec. DATA – A2 Tconv DATA – A3 INT TINT www.ams.com Revision 0.5 32 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w 8.7.4 Standby Mode2 (SBM2) Standby Mode 2 is an extension of the Standby Mode1 to achieve even a lower power in the data acquisition system by providing interrupt to the microcontroller only when the data sample exceeds the set current threshold. The Standby Mode can be entered only through the STOP state. Transition to SBM2 mode occurs when the “START BIT” D0 of Mode Control register MOD_CTL_REG in Table 46 is set to “1” and Mode Control Bits D7,D6 to “1,1” through SPI. In this mode the date rate is programmable with the time of Ta in the Ta control registers B, C. The data sample is made available and an interrupt signal is generated on INT pin only when the input signal exceeds the threshold set in Current Threshold Registers D,E. It should be noted here that the data is stable for Ta seconds. The functionality is illustrated in Figure 22. Figure 22. Standby Mode 2 I DD MCU |I| > I Threshold I I ADC Ta sec. Tconv Start SBM2 Channel DATA Register Ta sec. DATA – A0 t Ta sec. Tconv DATA – A1 Tconv DATA – A3 DATA – A2 INT TINT 8.8 Initialization Sequence at Power ON Figure 23. AS8510 Device Initialization Sequence at Power ON VPORHID/VPORHIA DVDD/AVDD POR_N Start ADC 1.5mS TADC INT 500µS CHOP_CLK Channel Data Register Configure Device D1 D2 D3 D4 D1 0x0000 D2 D3 D4 D1 DATA1 TDATA_STATUS_RD TDATA_VALID D2 D3 D4 DATA2 TDATA_INVALID Device initialization starts if the DVDD and AVDD supplies are switched ON and DVDD > VPORHID. The duration period of Initialization is 500μsec and during this period, INT pin toggles at the rate of internal low power oscillator. Toggling on INT during the period of initialization should be ignored in the system. Device configuration and activation should be carried out only after the initialization period. On ADC start, device enters into analog stabilization state and takes 1.5msec for oscillator and Reference to settle. After this 1.5msec period, the first interrupt will occur after a time period of TADC. www.ams.com Revision 0.5 33 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w TDATA_STATUS_RD is the time period during which the micro-controller should complete reading of data and status from the device. If reading is carried out beyond this time period, then, ADC performance will degrade for next sample generation. Status register gets cleared automatically only when micro-controller reads this register. Data in the channel registers is changed after TDATA_VALID duration. Ensure that data channel registers and status registers are not read during the TDATA_INVALID duration. Example: Configuration registers are set as follows: CLK_REG = 8’b0010_0000 DEC_REG_R1_I = 0100_0101 DEC_REG_R2_I = 1100_0101 FIR_CTL_REG_I = 0000_0100 ADC is configured to a data rate of 1KHz, CHOP_CLK to 2KHz, and Modulator clock to 1MHz, Decimation ratio of CIC1 = 64, and Decimation ratio of CIC2 = 4. With these settings the various time periods as shown in the Figure 23 are as follows: TDATA_STATUS_RD = 100 μsec (TDATA_STATUS_RD = (1/mod_clk) * R1 * [((mod_clk/(2*chop_clk))*(1/R1)) - 2.5) TDATA_INVALID = 8 μsec TADC = 1msec TDATA_VALID = TADC - TDATA_INVALID = 1msec - 8 μsec CHOP_CLK and POR_N are internal signals of the device. Table 26 provides valid combinations of Modulator clock, Chopper clock and Decimation R1 and the corresponding values of TDATA_STATUS_RD and TADC. Table 26. Valid Combinations of Modulator Clock, Chopper Clock and Decimation Ratio R1 Modulator Clock Chopper Frequency CHOP_CLK Decimation Ratio R1 TDATA_STATUS_RD TADC R2/(2*CHOP_CLK) for R2=4 1.024MHz 2KHz 64 1usec * 64 * [4 - 2.5] = 96usec 1mSec 2.048MHz 2KHz 64 2.048MHz 2KHz 128 2.048MHz 4KHz 64 8.8.1 0.5usec * 64 * [8 - 2.5] = 176usec 0.5usec * 128 * [4 - 2.5] = 96usec 0.5usec * 64 * [4 - 2.5] = 48usec 1mSec 1mSec 0.5mSec Soft-reset of Device Using Bit D[7] of Reset Register 0x09 It is possible to soft-reset the device by writing “0” into D[7] bit of Reset Register at 0x09. On applying soft-reset, the device enters into initialization state and D[6] bit changes back to “1”. The duration period of Initialization is 500μsec, and, during this period, INT pin toggles at the rate of internal low power oscillator. Toggling on INT during the period of initialization should be ignored in the system. Device configuration and activation should be carried out only after the initialization period. See Figure 24 for the timing details of the sequence of device initialization on soft-reset. www.ams.com Revision 0.5 34 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Figure 24. AS8510 Device Initialization Sequence at Soft-reset Start ADC 1.5mS INT D4 D1 D3 D2 D4 500µS D1 Soft Reset D1 Re-Configure Device Using D7 D 3 D2 D4 D1 D3 D2 D4 D1 D3 D2 D4 CHOP_CLK Channel Data DATA-N Register TDATA_STATUS_RD DATA1 DATA2 TDATA_STATUS_RD TDATA_INVALID TDATA_VALID 8.8.2 0x0000 DATA-N+1 TDATA_INVALID TDATA_VALID Soft-reset of the Measurement Path Using Bit D[7] of Reset Register 0x09 Measurement path also can be reset by using D[6] bit of Reset Register at 0x09. On applying soft-reset only signal measurement path registers will be reset. For applying this reset, device should be in STOP state. If the device is working with external clock, at the time of soft-reset the clock needs to be disabled. 8.8.3 Reconfiguring Gain Setting of PGA Only PGA gain settings can be changed dynamically while ADC conversions are in progress. When PGA gain settings are changed, the first sample from the ADC is invalid. Ignore the first interrupt after the gain re-configuration. Valid data starts from the second interrupt onwards. Figure 25. AS8510 - Re-configuration of Gain Setting of PGA Gain Re-Configuration can be carried out in this slot, skip next interrupt and Channel Data. Read Channel data in this slot VALID DATA TDATA_STATUS_RD INT D4 D1 D2 D3 D4 D1 D2 D3 D4 D1 D2 D3 D4 D1 D2 D3 D4 CHOP_CLK Channel Data Register DATA-N TDATA_STATUS_RD TDATA_VALID 8.8.4 DATA-N+1 DATA1 TDATA_STATUS_RD TDATA_INVALID TDATA_VALID DATA2 TDATA_INVALID Configuring the Device During Normal Mode Following registers can be programmed dynamically when the device is in operational mode (Normal mode). ACH_CTL_REG address is 0x17 for channel selection on the voltage measurement path PGA_CTL_REG address is 0x13 for gain setting PD_CTL_REG2 address is 0x15 for PGA Bypass ISC_CTL_REG address is 0x18 for current source programmability During the operation (Normal mode) of the device, if any of the registers need to be programmed or changed other than the above mentioned registers, then it is required to STOP the device by writing into MOD_CTL_REG “STOP” bit and configure the device as per the requirements and start the device. www.ams.com Revision 0.5 35 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w 8.8.5 Standby Mode - Power Consumption In Standby Mode 1 there is a timer based accurate measurement every Ta seconds. The device itself stays in idle-mode as long as it does not get a different command from the SPI interface. Internal oscillator frequency is typically foscint=262 kHz to reduce power consumption as long as the timer runs. After every time out of Ta seconds, it performs accurate measurement of current, voltage/ temperature. Data ready is signaled to microcontroller through an interrupt signal on INT and goes into STOP state. In the SBM the following equations hold: Tsbm1 = Ta= 10s (default value is 10secs); the power consumption is valid for this setting. This is the period of the repetition rate in SBM 1 and SBM2. Tsett ≈ 2ms (depending on external capacitors). This is the time required by the analog part to settle when the new measuring period is started. Any measurements performed during Tsett produce invalid results. T1 = 3ms (by default setting, every third measurement is sent to microcontroller in the SBM mode 1) is the time needed to perform the first measurement. Tmeas =Tsett +T1 is the total active time needed to get a valid result. DRSBM = Tmeas/Tsbm ≈ 5ms/10s. This is the ratio of repetition time versus the active time (Device in NOM mode). Power consumption = (DRSBM*NOM mode power consumption) + ((10s-5ms)/10s)*Stop mode power consumption) 8.9 Bottom Die Block Specifications This section provides specification of design related key parameters. 8.9.1 Current Measurement Ranges (across 100µΩ (±5%) shunt resistor) Table 27. Current Measurement Ranges Symbol Parameter Imax [A] Vsh [mV] PGA Gain Nominal Data Rate (fOUT) VINADC [mV] PSR [dB] I10 Input current range of 10A in NOM ±8.5 ±9 100 @ 1 kHz ±1209 60 I200 Input current range of 200A in NOM ±235 ±25 40 @ 1 kHz ±1165 60 I400 Input current range of 400A in NOM ±400 ±42 25 @ 1 kHz ±1132 60 I1500 Input current range of 1500A in NOM ±2000 ±219 5 @ 1 kHz ±1000 60 I1 Input current range of 1A in SBM ±1 ±0.1 100 @ 1 Hz ±10 60 I10 Input current range of 10A in SBM ±10 ±1 100 @ 1 Hz ±100 60 I200 Input current range of 200A in SBM ±200 ±20 40 @ 1 Hz ±800 60 3 3 3 1 2 1. VINADC = Vsh * Gain, gain deviations to be considered according to Table 29 and Table 30. 2. AVDD, DVDD of 3.3V with ±5% variation. 3. For low power current monitoring, single shot measurement is performed with internal oscillator. Note: The Data Rate at the output can be calculated according to the formula: fsout=2*fchop /R2 (R2 is down sampling ratio taking values 1, 2, 4 up to 32768 as powers of 2) Table 28. Valid Combinations of the Chopper Clock, Oversampling Clock and Decimation Ratios Over Sampling Frequency Chopper Frequency Decimation Ratio 1.024MHz 2kHz 64 2.048MHz 2kHz 64 2.048MHz 2kHz 128 2.048MHz 4kHz 64 www.ams.com Revision 0.5 36 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Differential Input Amplifier for Current Channel. Table 29. Differential Input Amplifier for Current Channel Symbol Parameter Conditions Min VIN_AMP Input voltage range RSHH and RSHL -160 RSHH and RSHL@ +160mV input voltage at 125ºC with PGA -50 IIN_AMP ICM Input current 1, 11 Absolute input voltage range Typ 2 3, 4, 9 I10 100 G = G2 Gain2 3, 4, 9 I200 40 G = G3 Gain3 3, 4, 9 I400 25 G = G4 Gain4 3, 4, 9 I1500 5 e fP_AMP εT1 VOSDRIFT Vos Gain deviation Pole frequency i = 1, 2, 3, 4 4, 5 Input referred offset 7, 10 Vos_ch VNdin THD 6 7, 10 mV 50 nA mV 1.1 * Gi kHz ±0.5 350 After trim, for temperature range -20 to 350µV at -20ºC 4, 8 Total harmonic distortion 0.9 * Gi -20ºC to +65ºC Gain 5, 25, referenced to room temperature Chopping enabled Noise density +160 15 Gain drift with temperature Offset drift with temperature Units -160 +300 2 Gain1 G = G1 Max For 150 Hz input signal % µV 350 µV 0 LSB 25 nV/√Hz 70 dB Notes: 1. Leakage test accuracy is limited by tester resource accuracy and tester hardware. 2. For gain 100 PGA input common mode is 0V and the minimum supply is 3.15V. 3. The measurement ranges are referred only by the gain of input amplifier, while other parameters such as bandwidth etc. are programmed independently. 4. This parameter is not measured directly in production. It is measured indirectly via gain measurements of the whole path. It is guaranteed by design. 5. Pole frequency of input amplifier changes with GAIN. The number is valid for the gain at G1, while the bandwidth will be higher for other ranges. This parameter is not measured in production. 6. Based on device evaluation. Not tested. 7. These offsets are cancelled if chopping enabled (default). 8. Noise density calculated by taking system bandwidth as 150Hz. 9. Refer to Measurement Ranges shown in Table 27. 10. No impact on the measurement path. If the chopping is enabled, both the offset and offset drift will be eliminated. 11. For negative input voltages up to -160mV below ground, Input leakage is typically -20nA @ 65ºC due to forward conductance of protection diode. www.ams.com Revision 0.5 37 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Differential Input Amplifier for Voltage Channel. Table 30. Differential Input Amplifier for Voltage Channel Symbol Parameter Conditions VIN_AMP Input voltage range IIN_RES Input resistance ICM 1, 10 Min Typ -160 VBAT_IN, ETR, ETS @ +160mV input voltage at 125ºC with PGA 2, 10 3 Absolute input voltage range mV 100 G = G2 Gain2 4, 5 40 G = G3 Gain3 4, 5 25 G = G4 Gain4 4, 5 5 fP_AMP Pole frequency VNDIN Noise density 5, 6 5, 7 Total harmonic distortion εT1 Gain drift with temperature Vos_ch VOSDRIFT Input referred offset 0.9 * Gi 1.1 * Gi 15 THD VOS mV -160 +300 4, 5 i = 1, 2, 3, 4 +160 kΩ Gain1 Gain deviation Units 12.5 G = G1 e Max For 150Hz input signal 8 9 Offset drift with temperature kHz 25 nV/√Hz 70 dB -20ºC to +65ºC Gain 5, 25, referenced to room temperature ±0.5 % After trim at -20ºC 350 µV Chopping enabled 9 0 LSB 350 µV Notes: 1. Input for the voltage channel can be as high as 1220mV, in this high input case PGA will be bypassed. 2. Leakage test accuracy is limited by tester resource accuracy and tester hardware, especially at low temperatures due to condensing moisture. 3. For gain 100 PGA input common mode is 0V and the minimum supply is 3.15V. 4. The measurement ranges are referred only by the gain of input amplifier, while other parameters such as bandwidth etc. are programmed independently. 5. This parameter is not measured directly in production. It is measured indirectly via gain measurements of the whole path. It is guaranteed by design. 6. Pole frequency of input amplifier changes with changing the GAIN. The number is valid for the gain at G1, while the bandwidth will be higher for other ranges. This parameter is not measured in production. 7. Noise density calculated by taking system bandwidth as 150Hz. 8. Based on device evaluation. Not tested. 9. No impact on the measurement path. If the chopping is enabled, both the offset and offset drift will be eliminated. 10. For negative input voltages up to -160mV below ground, Input leakage is typically -20nA @ 65ºC due to forward conductance of protection diode. www.ams.com Revision 0.5 38 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Sigma Delta Analog to Digital Converter. Table 31. Sigma Delta Analog to Digital Converter Symbol Parameter Conditions Min 6 VREF Reference voltage VINADC Input range R1 Oversampling ratio/Decimation Ratio fOVS Oversampling frequency RES Number of bits BW Bandwidth S/N Signal to noise ratio Typ Max 1.225 1 At VREF = 1.22V 2 0 64 V ±1.22 128 4 1 5 V 128 1024/ 2048 3 Units kHz 16 bits 500 Hz 90 dB Notes: Production test at ±800mV. Maximum VIN can be 1.22V with VREF=1.225V. Programmable. It is defined with respect to the first decimator in the ΣΔ ADC. Programmable: Internal clock is 1024/2048 kHz; external clock max is 8192 kHz. Dependent on fovs, R1 and R2. The bandwidth is calculated according to the formula: BW=fovs/(2*R1*R2); the sampling frequency at the output of the A/D converter is 2*BW. 5. Defined at maximum input signal, BW=500 Hz (1Hz to 500 Hz), fovs=1024 kHz, R1=64, fchop=2 kHz and R2=2. 6. Reference voltage might be forced from external. 1. 2. 3. 4. Bandgap Reference Voltage. Table 32. Bandgap Reference Voltage Symbol Parameter Conditions 1, 2 VREFTRIM Reference Voltage after trim VREFACC Reference Voltage Initial Accuracy VREFDRIFT PSRRREF Trim at 65ºC 1, 2 Reference Voltage Temperature drift SUTAVDD Start Up Time with supply ramp SUTPD Start Up Time from power down 3 RNDVREF Output resistance of band gap CLVREF ESRVREF Bandgap reference thermal noise density Typ Max 1.225 Units V At 65ºC ±3.5 mV Temperature range -20ºC to 65ºC ±0.4 % Temperature range -40ºC to 125ºC PSR @ dc 3 VNDVREF Min +0.4/ -0.6 % 80 dB 5 ms 500 3 1 ms 1000 Ω 300 nV/√Hz 100 Output Capacitor (Ceramic) 0.02 nF 1 Ω Notes: 1. Accuracy at 65ºC. 2. No DC current is allowed from this pin. 3. This is a design parameter and not production tested. www.ams.com Revision 0.5 39 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Internal (Programmable) Current Source for External Temperature Measurement. Table 33. External Temperature Measurement Symbol Parameter ICURON 5-bit current source enabled ICUROFF 5-bit current source disabled TK_CS Temperature coefficient of current source VMAXETR Voltage on pin ETR VMAXETRMOD Max voltage on pin ETR when PGA is 4 bypassed VMAXETS Voltage on pin ETS for resistor sensor VMAXETSMOD Max. Voltage on pin ETS when PGA is 5 bypassed 1 Conditions Min Typ Max Units 5-bit programmable current source 0 270 320 µA Limited by leakage 2 10 nA 1000 ppm / ºK 3 3 1000/G mV 1.22 V 1000/G V 1.22 V Notes: 1. Current value can be programmed through stop mode in steps of 8μA from 0 to 256μA with a process error of 30%. 2. Temperature coefficient is not important since external temperature measurement is a 2 step measurement. The value specified is guaranteed by design and will not be tested in production. 3. Maximum voltage on pin ETR (reference) can be calculated by given formula, where G is the gain of PGA (G=100). 4. Maximum voltage on pin ETR, if PGA is bypassed. 5. Maximum voltage on pin ETS, if PGA is bypassed. CMREF Circuit (VCM). Table 34. CMREF Circuit Symbol Parameter Min Typ Max Units VVCM Output voltage 1.6 1.7 1.8 V CL Load capacitance 100 nF Internal AVDD Power-on Reset. Table 35. Internal AVDD Power-on Reset Symbol VPORHIA Parameter Power On Reset Threshold tPORA POR time - The duration from Power ON till the time, internal Power On Reset signal 1 goes HIGH IPORA Current consumption in POR block Min Typ Max Units 2.2 2.4 2.6 V 1 2 µs 1.5 µA 1. POR pulse is always longer than tPORA whatever the slope of the supply. 2. IPORA can not be switched off. www.ams.com Revision 0.5 40 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Internal DVDD Power-on Reset. Table 36. Internal DVDD Power-on Reset Symbol Parameter Power On Reset Threshold VPORHID 1 VHYST Hysteresis tPORD POR time - The duration from Power ON till the time, internal Power On Reset signal goes 2 HIGH IPORD Current Min Typ Max Units 2.2 2.4 2.7 V 0.2 0.25 0.4 V 1 3 µs 1.5 µA 1. VPORLO = VPORHI - VHYST where VPORLO is the lower threshold of POR. 2. VPORLO = VPORHI - VHYST where VPORLO is the lower threshold of POR. 3. IPORD can not be switched off. Low Speed Oscillator. Table 37. Low Speed Oscillator Symbol Parameter Min Typ Max Units fLS Frequency 262.144 kHz fLS_ACC Accuracy ±7 % ILS Supply current 5 µA High Speed Oscillator. Table 38. High Speed Oscillator Symbol Parameter fHS Frequency Min 1 fHSACC Accuracy IHS Supply current Typ Max Units 4.096 MHz ±4 % 300 µA Notes: 1. Accuracy after trimming. External Clock. Table 39. External Clock Symbol Parameter fCLKEXT Clock frequency DIVCLKEXT Clock division factor DCCLKEXT Duty Cycle of external clock www.ams.com Conditions Min Typ Max 2048/ 4096/ 8192 to be programmed in Register 08 CLK_REG through the serial bus SPI. kHz 2/4/8 40 Revision 0.5 Units 60 % 41 - 62 AS8515 Datasheet - A S 8 5 1 5 B o t t o m D i e O v e r v i e w Internal Temperature Sensor. Table 40. Internal Temperature Sensor Symbol Parameter TINTRNG Temperature sensor range ΔTIN Temperature measurement accuracy TINTSLP Temperature sensor slope TINT65G5 Temperature sensor output at gain 5 8.9.2 Conditions Min Typ -40 Guaranteed by design; at PGA gain 5 which is the recommended Gain for internal temperature measurement. 40660 Max Units 125 ºC 3 ºC 27 Digits/C 41807 43012 Digits System Specifications Table 41. System Specifications Symbol Parameter IS Channel to channel isolation At Ph Min Typ Max Units -90 dB Difference in channel to channel attenuation 1, 2 @600Hz 3 dB Difference in phase shift between the two 1, 2 channels @600Hz 5 Deg 1 System Measurement Error Budget for Voltage and Current Channel. Temperature Range: -20ºC to +65ºC; Output data rate is 1kHz, VCC = 3.3V, chopping enabled. Table 42. System Measurement Error Budget for Gains 5 and 25 Symbol Parameter Err System measurement error Conditions 3, 4 Measurement error due to PGA gain drift From device evaluation Measurement error due to VREF drift Measurement error due to non-linearity of PG Tested by distortion measurements Min Typ Max Units ±0.6 1 % ±0.5 % ±0.4 % ±0.025 % Notes: 1. 2. 3. 4. These specifications are defined by taking one channel as reference and measured on the other channel. Guaranteed by design. System measurement error due to noise, individual block parameter drifts and non linearity. Based on evaluation, not tested. System error due to offset is neglected because of chopper architecture. www.ams.com Revision 0.5 42 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e 9 4-Wire SPI Interface The SPI interface can also be used as interface between the AS8515 and an external micro-controller to configure the device and access the status information. Micro-controller begins communication with the SPI configured as a slave. The SPI protocol is very simple and the length of each frame is an integer multiple of byte except when a transmission is started. Basically each frame has 1 command bits, 5 address/ configuration bits, 1 or more data bytes. SPI clock polarity settings depend on the value of the SCLK on the CS falling edge. This setting is done on each start of the SPI transaction. During the transaction SPI clock polarity will be fixed to the settings done. On the CS falling edge the values on SCLK signal decide setting of the active SPI clock edge for data transfer (see Table 43). Table 43. CS and SCLK 1 SCLK Description FALL LOW Serial data transferred on rising edge of SPI clock. Sampled at falling edge of SPI clock. FALL HIGH Serial data transferred on falling edge of SPI clock. Sampled at rising edge of SPI clock. ANY ANY Serial data transfer edge is unchanged. CS 1. Pin CST is used to program top device and pin CSB is used to program bottom device. 9.1 SPI Timing Parameters Table 44. 4-Wire Serial Port Interface Symbol Parameter Conditions Min Typ Max Units 250 Kbps General BRSPI Bit rate TSCLKH Clock high time 2 µs TSCLKL Clock low time 2 µs tDIS Data in setup time 20 ns tDIH Data in hold time 10 ns TCSH CS hold time 20 ns Write Timing Read Timing tDOD Data out delay tDOHZ Data out to high impedance delay Time for the SPI to release the SDO bus 80 ns 80 ns Timing parameters when entering 4-Wire SPI mode (for determination of CLK polarity) tCPS Clock setup time (CLK polarity) Setup time of SCLK with respect to CS falling edge 20 ns tCPHD Clock hold time (CLK polarity) Hold time of SCLK with respect to CS falling edge 20 ns www.ams.com Revision 0.5 43 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e 9.1.1 SPI Frame A frame is formed by a first byte for command and address/configuration and a following bit stream that can be formed by an integer number of bytes. Command is coded on the 1 first bit, while address is given on LSB 5 bits (see Table 45). Table 45. Command Bits Command Bits C0 Reserved Register Address or Transmission Configuration Reserved A4 A3 A2 A1 C0 Command Description 0 WRITE ADDRESS Writes data byte on the given starting address 1 READ ADDRESS Reads data byte from the given starting address A0 If the command is read or write, one or more bytes follow. When the micro-controller sends more bytes (keeping CS LOW and SCLK toggling), the SPI interface increments the address of the previous data byte and writes/reads data to/from consecutive addresses. 9.1.2 Write Command For Write command C0 = 0. After the command code C0 and two reserved bits, the address of register to be written has to be provided from the MSB to the LSB. Then one or more data bytes can be transferred, always from the MSB to the LSB. For each data byte following the first one, used address is the incremented value of the previously written address. Each bit of the frame has to be driven by the SPI master on the SPI clock transfer edge and the SPI slave on the next SPI clock edge samples it. These edges are selected as per clock polarity settings. In the following figures two examples of write command (without and with address self-increment. Figure 26. Protocol for Serial Data Write with Length = 1 CS SCLK SDI 0 RES1 RES0 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 SDO Transfer edge www.ams.com Sampling edge Revision 0.5 Data D7 – D0 is moved to Address A4..A0 here 44 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Figure 27. Protocol for Serial Data Write with Length = 4 CS SCLK SDI RE RE A A A A A D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D D 0 S1 S0 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 SDO Data D7-D0 is moved to Address A4-A0 here 9.1.3 Data D7-D0 is moved to Address A4-A0 +1 here Data D7-D0 is moved to Address A4-A0 +2 here Data D7-D0 is moved to Address A4-A0 +3 here Data D7-D0 is moved to Address A4-A0 +4 here Read Command For Read command C0=1. After the command code C0 and two reserved bits, the address of register to be read has to be provided from the MSB to the LSB. Then one or more data bytes can be transferred from the SPI slave to the master, always from the MSB to the LSB. To transfer more bytes from consecutive addresses, SPI master has to keep active the SPI CS signal and the SPI clock as long as it desires to read data from the slave. Each bit of the command and address sections of the frame have to be driven by the SPI master on the SPI clock transfer edge and the SPI slave on the next SPI clock edge samples it. Each bit of the data section of the frame has to be driven by the SPI slave on the SPI clock transfer edge and the SPI master on the next SPI clock edge samples it. These edges are selected as per clock polarity settings. In the following figures, two examples of read command (without and with address self-increment) have been shown. Figure 28. Protocol for Serial Data Read with Length = 1 CS SCLK SDI 1 RES1 RES0 A4 A3 A2 A1 SDO D7 Transfer edge www.ams.com A0 Sampling edge D6 D5 Data D7 – D0 at Address A4..A0 is read here Revision 0.5 D4 D3 D2 Transfer edge D1 D0 Sampling edge 45 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Figure 29. Protocol for Serial Data Read with Length = 4 CS SCLK SDI 1 RE RE S1 S0 A A A A A 4 3 2 1 0 D D D D D D D D D D D D D D D D D D D D D D D D D D D DD D D D D D D D D D D D 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 SDO Data D7-D0 at Address A4-A0 is read here 9.1.4 Data D7-D0 at Address A4-A0 +1 is read here Data D7-D0 at Address A4-A0 +2 is read here Data D7-D0 at Address A4-A0 +3 is read here Data D7-D0 at Address A4-A0 +4 is read here Timing In the following figures timing waveforms and parameters are exposed. Figure 30. Timing for Writing CS ... t CPS SCLK t CPHD t SCLKH t CSH CLK polarity ... t DIS SDI t SCLKL t DIH DATAI DATAI DATAI ... SDO www.ams.com ... Revision 0.5 46 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Figure 31. Timing for Reading CS t SCLKH t SCLKL SCLK DATAI SDI DATAI t DOD SDO DATAO (D7) t DOHZ DATAO (D0) 9.2 Bottom Die Registers This section describes the control registers used in AS8515 Bottom die. Registers can be broadly classified into the following categories. Data access registers Status Registers Digital signal path control registers Digital Control registers Analog Control Registers Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data Data Access Registers 00 DREG_I1 (ADC Data Register for Current) 0000_0000 R D[7:0] Denotes the Current ADC MSB Byte (ADC_I[15:8]) 01 DREG_I2 (ADC Data Register for Current) 0000_0000 R D[7:0] Denotes the Current ADC LSB Byte (ADC_I[7:0]) 02 DREG_V1 (ADC Data Register for Voltage) 0000_0000 R D[7:0] Denotes the Voltage ADC MSB Byte (ADC_V[15:8]) 03 DREG_V2 (ADC Data Register for Voltage) 0000_0000 R D[7:0] Denotes the Voltage ADC LSB Byte (ADC_V[7:0]) D[7] NOM1/NOM2 Data Ready D[6] NOM2 Threshold Crossover D[5] SBM1 Data Ready D[4] SBM2 Threshold Crossover D[3] APOR status D[2] Data from current channel updated D[1] Data from voltage channel updated D[0] Reserved Status Registers 04 www.ams.com STATUS_REG 0000_0000 R Revision 0.5 47 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data Digital Signal Path Control Registers for Current Channel D[7] This bit selects decimation rate is used for current channel. Default is 0 (Down Sampling Rate is 64) 0 Down Sampling Rate is 64 1 Down Sampling Rate is 128 These two bits select division ratio of oversampling frequency clock MOD_CLK to be used as chopper clock, CHOP_CLK. Default is “10” (divide by 512) D[6:5] 00 Chopper Clock Always High 01 Divide by 256 10 Divide by 512 11 Divide by 1024 These four bits select the decimation ratio of second CIC stage. Default is “0010” (equal to 4) 05 DEC_REG_R1_I 0100_ 0101 R/W D[4:1] 0000 1 0001 2 0010 4 0011 8 0100 16 0101 32 0110 64 0111 128 1000 256 1001 512 1010 1024 1011 2048 1100 4096 1101 8192 1110 16384 1111 32768 CIC1 Saturation Interrupt Mask Control. Default is 1 D[0] www.ams.com Revision 0.5 0 Unmask 1 Mask 48 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data D[7] I-Channel Enable, Default 1=enable D[6] V-Channel Enable, Default 1=enable Interrupt polarity D[5] 0 Active high 1 Active low . Interrupt Mask Control for Current Channel Data Ready Interrupt on INT pin (Default is 0) D[4] 06 DEC_REG_R2_I 1100_0101 0 Unmasked 1 Masked These two bits select the source of output 16-bit data in Normal mode from Current channel. Default is 01 R/W D[3:2] 00 FIR / MA Output 01 CIC2 Output 10 Dechop/Demod Output 11 CIC1 Output These two bits select the source of output 16-bit data in SBM mode from Current channel. Default is 01 D[1:0] 00 FIR / MA Output 01 CIC2 Output 10 Dechop/Demod Output 11 CIC1 Output This bit selects FIR / MA Filter in Current channel. Default is 0 (FIR) D[7] 0 FIR 1 MA Filter These bits select the number of data samples for averaging in MA filter in Current channel. Default is 0000 (bypass) D[6:3] 07 FIR CTL_REG_I 0000_0100 R/W 0000 bypass 0001 1 0011 3 0111 7 1111 15 These two bits select the Measurement Path architecture in both Current and Voltage channels. Default is 10 (Dechopper after CIC) D[2:1] D[0] www.ams.com Revision 0.5 00 Demodulator after CIC1 01 Demodulator before CIC1 10 Dechopper after CIC1 (preferred and suggested) 11 Demodulator before CIC1 with settled sample Reserved. Default 0. Do not change 49 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data Digital Control Registers Oversampling frequency clock selection. Default is 00 (high speed (HS) internal Clock) D[7:6] 00 Internal HS Clock with No Clock Output 01 Internal HS Clock with Clock Output 10 External Clock These two bits select the division ratio for HS clock/ external clock. Default is 10 (division by 4) D[5:4] 08 CLK_REG (Clock Control Register) 0010_0000 R/W 00 No division 01 Divide by 2 10 Divide by 4 11 Divide by 8 These two bits select the division ratio of HS clock, by which it should be divided before providing it on CLK pin. Default is 00 (No Division) D[3:2] 00 No Division 01 Divide by 2 10 Divide by 4 11 Divide by 8 This bit selects the division ratio of LS clock D[1] 09 www.ams.com RESET_REG (Reset Control Register) 1100_0000 R/W 0 LS _CLK undivided (Low Speed clock) 1 LS _CLK divide by 2 D[0] Reserved D[7] Entire device can be soft reset by writing “0” into this register bit. This bit will take a default 1 value on coming out of Reset D[6] Measurement Path can be soft reset by writing “0” into this register bit. This bit will take a default 1 value after Measurement Path is reset. D[5:0] Reserved Revision 0.5 50 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data These two bits select the operating mode of the Device. Default is 00 (Normal Mode 1) 00 D[7:6] Normal Mode 1 01 Normal Mode 2 10 Standby Mode 1 11 Standby Mode 2 These three bits select the number of cycles to be ignored before comparison with the set threshold in Standy Mode. Default is 000 (3 cycles of data) D[5:3] 0A MOD_CTL_REG (Mode Control Registers) 0000_0000 R/W D[2] 000 3 cycles of data 001 4 cycles of data 010 5 cycles of data 011 6cycles of data 100 7 cycles of data 101 8 cycles of data 110 9 cycles of data 111 10 cycles of data This bit controls the CHOP_CLK availability on CHOP_CLK pin. Default is 0 0 Disabled 1 Enabled Enabling the MEN pin to indicate transition from Standby to Normal Mode. D[1] 0 Disabled 1 Enabled This bit is used to take the device from STOP state to any of the Modes based on D[7:6] selection of this register. D[0] 0 Retain in STOP state 1 Enables transition to Normal or Standby Modes. Unit of Ta in SBM1/SBM2. Default is 1 0B MOD_Ta_REG1 (Ta Control Register) D[7] 1000_0000 0 Unit is in milliseconds 1 Unit is in seconds D[6:0] MSB value of Ta 0C MOD_Ta_REG2 (Ta Control Register) 0000_0000 R/W D[7:0] Unit of Ta in SBM1/SBM2 LSB value of Ta 0D MOD_ITH_REG1 (Current Threshold Register) 0000_0000 R/W D[7:0] MSB bits of 16 bits SBM2 threshold register 0E MOD_ITH_REG2 (Current Threshold Register) 0000_0000 R/W D[7:0] LSB bits of 16 bits SBM2 threshold register www.ams.com Revision 0.5 51 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 0F MOD_TMC_REG1 (TMC Control Registers) 0000_0000 R/W D[7:0] MSB value of number of data samples to be dropped from ADC before sending Interrupt in NOM2 10 MOD_TMC_REG2 (TMC Control Register) 0000_0000 R/W D[7:0] LSB value of number of data samples to be dropped from ADC before sending Interrupt in NOM2 11 NOM_ITH_REG1 0000_0000 R/W D[7:0] Eight MSB bits of NOM2 current threshold register 12 NOM_ITH_REG2 0000_0000 R/W D[7:0] Eight LSB bits of NOM2 current threshold register 8-bit Control / Status Data Analog Control Registers Setting of Gain G of Current Channel PGA. Default is 01 (G = 25) D[7:6] 13 PGA_CTL_REG (PGA Control Registers) 0101_0000 R/W 00 5 01 25 10 40 11 100 Setting of Gain G in Voltage channel. Default is 01 (G = 25) D[5:4] 00 5 01 25 10 40 11 100 D[3:0] D[7] D[6] 14 PD_CTL_REG_1 (Power Down Control Register) 1100_1111 R/W 0 Disable Chopper clock to Current channel 1 Enable Chopper clock to Current channel 0 Disable Chopper clock to Voltage channel 1 Enable Chopper clock to Voltage channel D[5] Reserved D[4] Reserved D[3] D[2] D[1] D[0] www.ams.com Reserved Revision 0.5 0 Disable Current channel PGA 1 Enable Current channel PGA 0 Disable Current channel ΣΔ Modulator 1 Enable Current channel ΣΔ Modulator 0 Disable Voltage channel PGA 1 Enable Voltage channel PGA 0 Disable Voltage channel ΣΔ Modulator 1 Enable Voltage channel ΣΔ Modulator 52 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data D[7] D[6] D[5] D[4] 15 PD_CTL_REG_2 (Power Down Control Register) 1111_0011 R/W D[3] D[2] D[1] D[0] D[7] D[6] D[5] 16 PD_CTL_REG_3 (Power Down Control Register) 1111_1000 Disable CIC1 of both channels 1 Enable CIC1 of both channels 0 Disable CIC2 of both channels 1 Enable CIC2 of both channels 0 Disable Dechopper in both channels 1 Enable Dechopper in both channels 0 Disable FIR in both channels 1 Enable FIR in both channels 0 Do not bypass PGA in Current Channel Default 0 1 Bypass PGA in Current Channel 0 Do not bypass PGA in Voltage Channel Default 0 1 Bypass PGA in Voltage Channel 0 Disable Current Channel Chopper 1 Enable Current Channel Chopper 0 Disable Voltage Channel Chopper 1 Enable Voltage Channel Chopper 0 Disable Common Mode Reference 1 Enable Common Mode Reference 0 Disable Internal Current Source 1 Enable Internal Current Source 0 Disable Internal temperature sensor 1 Enable Internal temperature sensor D[4] Reserved. (Default 1) Do not change D[3] Reserved. (Default 1) Do not change D[2] www.ams.com 0 0 Data Output in binary numbering system 1 Data Output in 2’s complement numbering system D[1] Reserved. (Default 0) Do not change D[0] Reserved Revision 0.5 53 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data These bits specify the selection of voltage/temperature in Voltage Channel Default is 00 (Voltage Channel) D[7:6] 00 Voltage Channel 01 External Temperature Channel ETR 10 External Temperature Channel ETS 11 Internal Temperature Channel D[5] Reserved. (Default 0) Do not change Internal current source switch enable. Default is 0 17 ACH_CTL_REG (Analog Channel Selection Register) 0000_0000 R/W D[4] Note: D4 bit is used for Enabling current source to the channel selected by bits D[7,6] of this register. 0 Disabled 1 Enabled Enable/disable Internal current source to RSHH pin of Current channel D[3] 0 Disabled 1 Enabled Enable/disable current source switch to RSHL pin of Current channel D[2] 0 Disabled 1 Enabled D[1:0] Reserved These three bits specify the selection of magnitude of current from the Internal current source. Default is 00000 (0µA). 18 ISC_CTL_REG (Current Source Setting Register) 0000_0000 R/W D[7:3] 00000 0µA 00001 8.5µA 00010 17µA 00100 34.5µA 01000 68µA 10000 135µA 11111 270µA D[2:0] 19 44 www.ams.com OTP_EN_REG STATUS_REG_2 0000_0000 0000_0000 R/W R D[7] Reserved 1 Reserved (default = 1) Do not change D[6:0] Reserved D[7] Status indicating data saturation in Current channel D[6] Status indicating data saturation in Voltage channel D[5:0] Reserved Revision 0.5 54 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data Digital Signal path control registers for Voltage Channel D[7] Selection of Decimation ratio for Voltage/Temperature channel. Default is 0 (Down Sampling Rate is 64) 0 Down Sampling Rate is 64 1 Down Sampling Rate is 128 Division of oversampling clock, which is used as Chopper Clock. Default is 10 (divide by 512) D[6:5] 00 Chopper Clock Always High 01 Divide by 256 10 Divide by 512 11 Divide by 1024 Decimation ratio of CIC2. Default is 0010 (4) 45 DEC_REG_R1_V 0100_ 0101 R/W D[4:1] 0000 1 0001 2 0010 4 0011 8 0100 16 0101 32 0110 64 0111 128 1000 256 1001 512 1010 1024 1011 2048 1100 4096 1101 8192 1110 16384 1111 32768 CIC1 Saturation Interrupt Mask Control. Default is 1 D[0] www.ams.com Revision 0.5 0 Unmasked 1 Masked 55 - 62 AS8515 Datasheet - 4 - W i r e S P I I n t e r f a c e Table 46. Control Registers Addr in HEX Register Name POR Value R/W 8-bit Control / Status Data D[7:5] Reserved Interrupt Mask Control for Voltage channel data Ready Interrupt on INT pin (Default is 0) D[4] 46 DEC_REG_R2_V 0000_0100 0 Unmasked 1 Masked These two bits select the source of output 16-bit data in Normal mode from Voltage channel. Default is 01 R/W D[3:2] 00 FIR / MA Output 01 CIC2 Output 10 Dechop/Demod Output 11 CIC Output D[1:0] Reserved This bit selects FIR / MA Filter in Voltage channel. Default is 0 (FIR) D[7] 47 FIR CTL_REG_V 0000_0000 0 FIR 1 MA Filter These bits select the number of data samples for averaging in MA filter in Voltage channel. Default is 0000 (bypass) R/W D[6:3] D[2:0] 0000 bypass 0001 1 0011 3 0111 7 1111 15 Reserved Note: All the registers from address 0x19 to 0x2C are read-only. www.ams.com Revision 0.5 56 - 62 AS8515 Datasheet - A p p l i c a t i o n I n f o r m a t i o n 10 Application Information 10k Figure 32. Application Diagram 100nF 27 26 24 INT Tx 25 CLK 28 CST 29 RESET EN RSHL 2 30 31 RSHH Rx 32 1 23 VREF SDI VCM MEN 22 3 21 4 100nF AVDD 3.3V 5 CHOP_CLK AS8515 AVSS 20 DVDD ETR DVSS 18 ETS 13 100nF 12V Battery 100µohm SCLK VCC 200nF VBAT - 14 15 16 100nF 12 Diode VSENSE_GND 11 CLIN 10 9 17 CSB 2.2µF LIN VSS 8 VSUP VSENSE SDO VSENSE_IN + 3.3V 19 6 7 Optional 22µF SUP Diode µC Load Note: VSENSE_IN, VSENSE_GND, MEN, and CHOP_CLK should be left unconnected. Note: Keep the differential input signal lines short, symmetric, and as close as possible. Use of PCB shielding layers is recommended, but consider Eddy currents for fast changes in shunt current and related parasitic signal / ground shift generation. www.ams.com Revision 0.5 57 - 62 AS8515 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s 11 Package Drawings and Markings The devices are available in a 32-pin MLF (5x5 mm) package. Figure 33. Package Drawings and Dimensions austriamicrosystems AS8515 18278-001 YYWWIZZ www.ams.com Revision 0.5 58 - 62 AS8515 Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s Symbol A A1 A2 A3 L θ b D E e D1 E1 Min 0.80 0 0.30 0º 0.18 Nom 0.90 0.02 0.65 0.20 REF 0.40 0.25 5.00 BSC 5.00 BSC 0.50 BSC 4.75 BSC 4.75 BSC Max 1.00 0.05 1.00 0.50 14º 0.30 Symbol D2 E2 aaa bbb ccc ddd eee fff N Min 3.40 3.40 - Nom 3.50 3.50 0.15 0.10 0.10 0.05 0.08 0.10 32 Max 3.60 3.60 - Notes: 1. 2. 3. 4. 5. Dimensions and tolerancing conform to ASME Y14.5M -1994. All dimensions are in millimeters. Angles are in degrees. Bilateral coplanarity zone applies to the exposed pad as well as the terminal. Radius on terminal is optional. N is the total number of terminals. Marking: YYWWIZZ. YY WW I ZZ Last two digits of the manufacturing year Manufacturing Week Plant Identifier Traceability Code www.ams.com Revision 0.5 59 - 62 AS8515 Datasheet - R e v i s i o n H i s t o r y Revision History Revision Date Owner Description 0.1 Dec 16, 2011 zmo/mbr Initial draft 0.2 Jan 25, 2012 0.3 Mar 07, 2012 0.4 Aug 14, 2012 0.5 Nov 22, 2012 Updated table information on LIN Driver (page 23) Pins 10, 11 updated in the file (Pin Assignments, Figure 32) zmo Updated power dissipation info in Absolute Maximum Ratings (page 7) Updated Table 14, Figure 32. Updated Operating Conditions, Electrical Characteristics, Ordering Information, Figure 12. Table 27, Table 29, Table 30, Table 42. zmo/mbr Note: Typos may not be explicitly mentioned under revision history. www.ams.com Revision 0.5 60 - 62 AS8515 Datasheet - O r d e r i n g I n f o r m a t i o n 12 Ordering Information The devices are available as the standard products shown in Table 47. Table 47. Ordering Information Ordering Code Description Delivery Form AS8515-ZMFP Data acquisition system with power management and LIN transceiver Tape & Reel (5000 pcs) AS8515-ZMFM Tape & Reel (500 pcs) Package 32-pin MLF (5x5 mm) Note: All products are RoHS compliant and ams green. Buy our products or get free samples online at ICdirect: http://www.ams.com/ICdirect Technical Support is available at http://www.ams.com/Technical-Support For further information and requests, please contact us mailto: sales@ams.com or find your local distributor at http://www.ams.com/distributor www.ams.com Revision 0.5 61 - 62 AS8515 Datasheet - C o p y r i g h t s Copyrights Copyright © 1997-2012, ams AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. All products and companies mentioned are trademarks or registered trademarks of their respective companies. Disclaimer Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described devices from patent infringement. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in normal commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard production flow, such as test flow or test location. The information furnished here by ams AG is believed to be correct and accurate. However, ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. Contact Information Headquarters ams AG Tobelbaderstrasse 30 A-8141 Unterpremstaetten, Austria Tel: +43 (0) 3136 500 0 Fax: +43 (0) 3136 525 01 For Sales Offices, Distributors and Representatives, please visit: http://www.ams.com/contact www.ams.com Revision 0.5 62 - 62
AS8515-ZMFM 价格&库存
很抱歉,暂时无法提供与“AS8515-ZMFM”相匹配的价格&库存,您可以联系我们找货
