SDM-USB-QS-S
SDM-USB-QS-S
    LINXTECHNOLOGIES(灵思)
    16-SMD模块
    SDM-USB-QS-S
SDM-USB-QS-S 数据手册
QS Series USB Module Data Guide ! Warning: Some customers may want Linx radio frequency (“RF”) products to control machinery or devices remotely, including machinery or devices that can cause death, bodily injuries, and/or property damage if improperly or inadvertently triggered, particularly in industrial settings or other applications implicating life-safety concerns (“Life and Property Safety Situations”). Table of Contents 1^ 1^ 1^ NO OEM LINX REMOTE CONTROL OR FUNCTION MODULE SHOULD EVER BE USED IN LIFE AND PROPERTY SAFETY SITUATIONS. No OEM Linx Remote Control or Function Module should be modified for Life and Property Safety Situations. Such modification cannot provide sufficient safety and will void the product’s regulatory certification and warranty. 2^ Customers may use our (non-Function) Modules, Antenna and Connectors as part of other systems in Life Safety Situations, but only with necessary and industry appropriate redundancies and in compliance with applicable safety standards, including without limitation, ANSI and NFPA standards. It is solely the responsibility of any Linx customer who uses one or more of these products to incorporate appropriate redundancies and safety standards for the Life and Property Safety Situation application. 5^ Do not use this or any Linx product to trigger an action directly from the data line or RSSI lines without a protocol or encoder/ decoder to validate the data. Without validation, any signal from another unrelated transmitter in the environment received by the module could inadvertently trigger the action. All RF products are susceptible to RF interference that can prevent communication. RF products without frequency agility or hopping implemented are more subject to interference. This module does not have a frequency hopping protocol built in. Do not use any Linx product over the limits in this data guide. Excessive voltage or extended operation at the maximum voltage could cause product failure. Exceeding the reflow temperature profile could cause product failure which is not immediately evident. Do not make any physical or electrical modifications to any Linx product. This will void the warranty and regulatory and UL certifications and may cause product failure which is not immediately evident. 2^ 3^ 4^ 4^ 5^ 7^ 8^ 8^ 9^ 10^ 10^ 11^ 12^ 14^ 14^ 14^ Description Features Applications Ordering Information Absolute Maximum Ratings Electrical Specifications Pin Assignments Pin Descriptions Module Description Theory of Operation Installing the Drivers Changing the Device Descriptions Software Considerations Serial Number Considerations Power Supply Guidelines Pad Layout Helpful Application Notes from Linx Typical Applications Production Guidelines Hand Assembly Automated Assembly QS Series USB Module Data Guide Description 0.812" The Linx QS Series USB module allows the rapid addition of USB to virtually any device. Housed in a compact SMD package, the 0.630" QS module provides a complete solution for SDM-USB-QS1-S LOT QUxxxx converting between USB and CMOS / TTL logic level serial sources. The module can be directly connected to virtually any serial device including 0.125" microprocessors, RS-232 / RS-485 level converters or Linx wireless RF modules. The QS Figure 1: Package Dimensions module is completely self contained so it requires no external components except a USB jack and includes all necessary firmware and drivers, freeing the designer from complicated programming. Power can be supplied externally or from the USB bus. Both USB 1.1 and USB 2.0 are supported at data rates up to 3Mbps. Features • Single chip USB-toasynchronous serial data conversion • Low cost • 3Mbps baud rate • Supports low-speed USB • Full handshaking support for RS-232 and RS-485 • Bus or self-powered • Compact surface-mount package • VID, PID, serial number and descriptors programmed via USB • No external components needed except a USB jack • Drivers and firmware included • Supports Windows 98 / 2000 / XP / Vista / Windows 7 and 10 • USB 1.1 and 2.0 compatible Applications • • • • Interface / upgrade legacy peripherals Interface microcontrollers & USB USB to RS-232 / RS-485 converters Interfacing RF modules to USB • • • • • • – 1 – USB smart card readers USB modems Robotics USB instrumentation USB game controllers USB-to-serial converter cables Revised 2/3/2020 Ordering Information Electrical Specifications Ordering Information QS Series USB Module Specifications Part Number Description Parameter SDM-USB-QS-S QS Series USB Module Power Supply MDEV-USB-QS QS Series Master Development Kit Figure 2: Ordering Information Symbol Min. Typ. Max. Units Operating Voltage VCC 4.35 5.0 5.25 VDC Supply Current lCC 26.0 28.0 mA 3.0 Mbps 0.6 VDC Notes UART SECTION Data Rate Absolute Maximum Ratings 0.0003 Data Output: Absolute Maximum Ratings Supply Voltage Vcc −0.5 to +6.0 VDC Any Input or Output Pin −0.5 to VCC + 0.5 VDC Max. Current Sourced by Output Pins 24 Operating Temperature Storage Temperature mA 0 to +70 ºC −65 to +150 ºC Exceeding any of the limits of this section may lead to permanent damage to the device. Furthermore, extended operation at these maximum ratings may reduce the life of this device. Figure 3: Absolute Maximum Ratings Logic Low VOL 0.3 0.4 Logic High VOH 3.2 4.1 EEPROM Size 4.9 VDC 1,024 Bits USB Section Data Output: Logic Low UVOL 0.0 0.3 VDC Logic High UVOH 2.8 3.6 VDC Single-Ended RX Threshold UVSE 0.8 2.0 VDC Differential Common Mode UCOM 0.8 2.5 VDC Differential Input Sensitivity UVDIF 0.2 Driver Output Impedance UDRVZ 29 44 Ω 0.0 +70 °C VDC Environmental Operating Temperature Range Figure 4: Electrical Specifications Warning: This product incorporates numerous static-sensitive components. Always wear an ESD wrist strap and observe proper ESD handling procedures when working with this device. Failure to observe this precaution may result in module damage or failure. – 2 – – 3 – Pin Assignments 1 2 3 4 5 6 7 8 Module Description USBDP RI USBDM DCD GND DSR VCC DATA_IN SUSP_IND DATA_OUT RX_IND RTS TX_IND CTS 485_TX DTR 16 15 14 13 12 11 10 9 Figure 5: SDM-USB-QS-S Pinout (Top View) Pin Descriptions Pin Descriptions Pin Number Name Description 1 USBDP USB data signal plus 2 USBDM USB data signal minus 3 GND 4 VCC 5 SUSP_IND 6 RX_IND The host application software can access the USB device by simple, custom functions or by standard Windows Win32 API calls. In addition, Virtual COM Port drivers are available that make the USB module appear to the PC as a COM port, without the need for additional system resources, such as an IRQ or address. This allows the designer to program the application software to use standard serial or parallel ports and then simply select the port that represents the USB module. The drivers automatically direct the data to the USB bus and the device. Theory of Operation Figure 7 shows a block diagram of the QS module. Ground supply SUSP_IND Positive power supply VCC GND Goes low during USB Suspend Mode. This pin can be used to power down external logic when the host puts the USB bus into suspend mode. This line will pulse low when receiving data from the USB bus. This allows for the connection of a LED indicator. 7 TX_IND This line will pulse low when transmitting data on the USB bus. This allows for the connection of a LED indicator. 8 485_TX Transmit enable line for RS-485 applications. 9 DTR 10 The Linx SDM-USB-QS module converts USB signals from a host, such as a PC or hub, into TTL logic level signals. This enables the module to be connected directly to microcontrollers (or Linx RF modules for wireless applications) or to RS-232 or RS-485 level converters for communication with legacy devices. The module handles all complicated enumeration and bus communication processes, freeing the designer to focus on handling the data. All necessary firmware is included in the module and the device descriptors can easily be changed to customize the module. TX Buffer 128 Bytes DATA_IN RTS CTS USBDP USBDM USB Transceiver Serial Interface Engine (SIE) Clear to Send control / handshake input 11 RTS Request To Send / handshake output 12 DATA_OUT 13 DATA_IN 14 DSR Data Set Ready control / handshake input 15 DCD Data Carrier Detect control / input 16 RI USB Protocol Engine UART FIFO Controller DTR UART DSR DCD RI 485_TX TX_IND Data Terminal Ready control / handshake output CTS DATA_OUT RX_IND USB DPLL RX Buffer 384 Bytes Transmit asynchronous data output Receive asynchronous data input Ring Indicator control input Clock Figure 7: SDM-USB-QS-S Block Diagram The USB transceiver block provides the physical interface for the USB signalling. Figure 6: Pin Descriptions – 4 – – 5 – The USB DPLL locks onto the NRZ data and provides separate recovered clock and data signals to the Serial Interface Engine (SIE). The SIE performs the parallel-to-serial and serial-to-parallel conversion, bitstuffing / un-stuffing, and CRC calculations on the USB data. The USB Protocol Engine manages the data from the USB control endpoint, the USB protocol requests from the USB host controller, and the commands for controlling the functional parameters of the UART. Installing the Drivers The drivers for the USB module are included with the module’s development system or may be downloaded from the Linx website at www.linxtechnologies.com. These drivers should be downloaded onto the hard drive of a PC or onto a disk. When the module is attached to the PC for the first time, Windows automatically detects the device and searches for the best driver. Windows prompts for the location of the drivers, so browse to the folder or the disk, click Next, and Windows does the rest. Windows XP may return an error window as shown in Figure 8. Data from the USB data out endpoint is stored in the TX buffer and removed from the buffer to the UART transmit register under control of the UART FIFO controller. Data from the UART receive register is stored in the RX buffer prior to being removed by the SIE on a USB request for data from the device data in endpoint. The UART FIFO controller handles the transfer of data between the RX and TX buffers and the UART transmit and receive registers. The UART performs asynchronous 7 / 8 bit parallel-to-serial and serial-toparallel conversion of the data on the RS-232 interface. Control signals supported by the UART include RTS, CTS, DSR, DTR, DCD, and RI. The UART provides a transmitter-enable control signal (485_TX) to assist with interfacing to RS-485 transceivers. The UART supports RTS / CTS, DSR / DTR and X-On / X-Off handshaking options. Handshaking, where required, is handled in hardware to ensure fast response times. The UART also supports the RS-232 BREAK setting and detection conditions. – 6 – Figure 8: Windows XP Driver Error Window This window is simply a warning that the driver has not gone through Microsoft’s certification process and could potentially pose a problem for the system. The drivers provided for the QS module are Microsoft Certified and should not pose any problems unless modified by the user. Click the Continue Anyway button to finish the installation process. – 7 – Changing the Device Descriptions Serial Number Considerations The QS can be customized to display the product’s name, manufacturer name, and to use different Product Identifiers (PID) and Vendor Identifiers (VID). This allows an end user to see the final product’s name in their Windows Device Manager and when the hardware is first loaded. The PID and VID are set by the USB Implementers Forum and should not be changed unless the final product has gone through the certification process and received its own unique IDs. The VID and PID are used by Windows to determine what devices are attached to the bus and which drivers to load in order to communicate with each device. A unique serial number is used to distinguish between different devices of the same type so that the operating system can be sure that it is communicating with the correct one. Windows views every different combination of VID, PID and serial number as a new device and starts the “Found New Hardware” wizard for each one. This is an issue in a mass production environment, so the QS modules are shipped with the “Enable Serial Number” option disabled in the EEPROM. This prevents the serial number from being used during ennumeration. The Manufacturer, Description, and Serial Number strings can all be modified using the QS EEPROM Programmer software, which can be downloaded from the Linx web site. This easy-to-use software reprograms the module via the USB bus and can be done during production testing. Once the module is reprogrammed, some modifications to the driver files may be necessary. If a VID and PID other than the default Linx numbers are used, these numbers need to be added to the files. This requires modifying several lines in the .inf files and is described in detail in the QS Series Programmer’s Guide. Modifying the name displayed by the Windows Device Manager requires changing only one line, also described in the Programmer’s Guide. Software Considerations The PC needs a set of drivers that tell it how to communicate with the QS module. The CDM drivers for the QS Series module install two different drivers at the same time. The first driver makes the QS appear as a COM port on the host PC. This allows the application to use standard writes and reads to a serial port, and the drivers redirect data to the USB module. The second driver supports a series of functions that allow direct control of the QS module. These functions are described in Application Note AN-00200: SDM-USB-QS Programmer's Guide, where examples are given in both Visual Basic and C. The Programmer's Guide can be downloaded from the Application Notes page in the Support section of the Linx website. Sample software is available on the Software page in the Support section. With the serial number disabled, Windows tracks each device by connection and assign a USB port to a particular device. If the device is moved to another port, it needs to be reinstalled. The problem that arises is that the device is installed on the same PC multiple times, once for each USB port into which it has been plugged. It is recommended to set the “Enable Serial Number” option and to use a unique serial number as a part of the product's final testing procedure. The QS EEPROM Programmer can be downloaded from the Linx website and the EEPROM programming functions can be found in Application Note AN-00200. These can be used as a part of an automated test program at the end of the production line to program custom descriptors and a unique serial number into the product. Note: Avoid using the same serial number for multiple devices, as it can cause a conflict in the operating system. Windows XP has a particular problem with this and may crash if it sees two of the same type of device with the same serial number on the same bus. In addition to the Programmer's Guide, the QS Series Master Development System (MDEV-USB-QS) includes example software and sample system source code. This source code provides the driver function declarations, examples of how to use the functions in a program, and other code that may be of use. – 8 – – 9 – Helpful Application Notes from Linx The USB module can be powered in two ways: from the USB bus or from an external source. If necessary, a voltage regulator can be used to supply a clean 5V as the external source, or the VCC pin can be connected to the bus power pin of the USB connector. Using the bus to power the module is an advantage because the module then uses power from the host rather than from the peripheral. This is especially helpful if the peripheral is battery-powered. Figure 9 shows the schematic powering from the bus. USB Type B Connector 4 SDM-USB-QS-S GND GND It is not the intention of this manual to address in depth many of the issues that should be considered to ensure that the modules function correctly and deliver the maximum possible performance. We recommend reading the application notes listed in Figure 11 which address in depth key areas of RF design and application of Linx products. These applications notes are available online at www.linxtechnologies.com or by contacting Linx. DAT+ DAT 5V 3 2 1 1 2 GND 3 4 6 5 GSHD GSHD Power Supply Guidelines 5 GND GND 6 7 8 USBDP RI USBDM DCD GND DSR VCC DATA_IN SUSP_IND DATA_OUT RX_IND RTS TX_IND CTS 485_TX DTR 16 15 Helpful Application Note Titles Note Number Note Title AN-00200 SDM-USB-QS-S Programmer's Guide AN-00201 Installing the SDM-USB-QS-S Drivers 14 13 Figure 11: Helpful Application Note Titles 12 11 10 9 Figure 9: USB Bus-Powered Schematic The USB specification has strict allowances for using power from the bus. A device is allowed to use 100mA before enumeration, 500mA during normal operation, and 500mA in suspend mode. A descriptor stored in the EEPROM tells the host how much current the device will pull from the bus so that the host can allocate the appropriate power. The modules come programmed for 100mA, but if the final product draws more than this, then the device descriptors need to be changed. Pad Layout The following pad layout diagram is designed to facilitate both hand and automated assembly. 0.065" 0.610" 0.070" 0.100" Figure 10: Recommended PCB Layout – 10 – – 11 – Typical Applications 1 VCC 2 3 4 5 0.1uF + 16V 14 15 16 DTR RTS CTS DCD DSR RX DATA VCC RI 7 6 20 21 8 5 26 22 19 24 SUSP_IND 25 C1+ C1C2+ + V+ MAX213 V- 13 17 + C2T1IN T1OUT T2IN T2OUT T3IN T3OUT T4IN T4OUT R1OUT R1IN R2OUT R2IN R3OUT R3IN R4OUT R4IN R5OUT R5IN 2 3 1 28 0.1uF 16V GND DAT+ DAT 5V GND GND 4 27 23 18 GND SUSP_IND 3 4 5 6 8 DTR2 RI USBDM DCD GND DSR VCC DATA_IN SUSP_IND DATA_OUT RX_IND RTS TX_IND CTS 485_TX DTR 16 15 14 13 12 11 10 9 RI DCD DSR RX DATA TX Side TX DATA RTS CTS DTR 16 Connector +5V INPUT 4 15 3 DAT+ 14 2 + DAT 0.1uF 5V GND 12 11 11 VCC 12 C1+ + GND GND 10 0.1uF V+ +5VVCC TO 220 =10V 9 6.3V C114 VOLTAGE DOUBLER 15 C2+ V0.1uF + +10V TO -10V 16V C2- VOLTAGE INVERTER 16 VCC Figure 13: Wireless Modem Using ES Series RF Modules 400k 7 T1IN 220 DCD2 DSR2 CTS2 TX DATA2 DCD2 RTS2 DSR2 RX DATA2 RX DATA2 CTS2 RI2 DTR2 RI2 Figure 14 below shows the QS module connected to a microprocessor. 400k T2 3 This is the design used in the QS Master6 T2Development Kit and the VCC 400k documentation for the kit describes the connections and software. 6 2 IN 7 3 8 20 T3IN 4 OUT T2 T3OUT 1 T3 VCC 9 220 5 1 2 3 4 5 6 7 8 9 220 DB9M Figure 12: RS-232 to USB Converter VCC 400k RA2/AN2 21 T4IN RA3/AN3 8 R1OUT RA4/AN4 MCLR/VPP GND RB0/INT 5 R2OUT RB1 RB2/RX RB3 18 RA1/AN1T4OUT 28 17 R1 IN 169 R1 RA7 15 RA6 5k 14 VCC 13 RB7 R2IN 4 R2 12 RB6 11 5k RB5/TX 10 RB4 T4 26 R3OUT 22 R4OUT 10K VCC SW-PB 200K R3IN 27 R3 PIC16F88 5k R4IN 23 R4 5k 6 GSHD GSHD USB Type B Connector GND DAT+ DAT 5V 19 R5OUT 4 3 2 1 1 2 3 4 5 The QS Series modules can be used with Linx RF modules to create a wireless link between two PCs. Figure 13 shows a design using the ES Series RF modules. An option not shown in the schematic below is that one of the output lines of the QS module (RTS or DTR) could be connected to the PDN lines of the RF modules, enabling the host to turn the RF modules on and off. 5 220 VCC 220 6 7 8 SDM-USB-QS-S 24 EN USBDP RI USBDM DCD GND DSR VCC DATA_IN SUSP_IND RX_IND DATA_OUT RTS TX_IND CTS 485_TX DTR Figure 14: Interface with a Microprocessor – 12 – T1OUT 2 T1 VCC 1 220 GND 10 SDM-USB-QS-S 1 USBDP RI 2 USBDM DCD 3 GND DSR 4 0.1uF VCC DATA_IN + 6.3V 5 13 SUSP_IND DATA_OUT 6 RX_IND RTS 7 TX_IND CTS 8 17 485_TX DTR 0.1uF + 16V RX Side RTS2 220 NC NC 16 15 14 13 12 11 10 9 GND USB Type B SDM-USB-QS-S USBDP RI USBDM GND DSR VCC SUSP_IND DATA_OUT RX_IND RTS TX_IND CTS 485_TX DTR GSHD GSHD VCC 220 GND SDM-USB-QS-S USBDP 1 2 3 4 5 6 7 8 NC NC PDN RSSI DATA AUDIO AREF NC VCC GSHD 6 1 2 TX DATA2 EN SHDN GND 7 VCC 9 4 3 2 1 10 9 8 7 6 5 0.1uF 6.3V PDN ANT LVL ADJ GND LOW V DET GND /CLK SEL DATA /CLK 6 11 VCC GSHD 12 GSHD + 5 0.1uF 6.3V TX DATA USB Type B Connector + 6 0.1uF GND 5 VCC GND DAT+ DAT 5V RXM-XXX-ES 1 TXM-XXX-ES 8 USB Type B Connector GSHD There are many potential uses for the QS Series modules, three of which will be described here. Figure 12 shows the QS and a MAX213 RS-232 level converter IC from Maxim. This creates a USB-to-RS-232 converter that supports all of the standard handshaking lines. Similarly, RS-485 or RS-422 level converter chips could be used for designs requiring those standards. – 13 – R5IN 18 R5 5k 16 25 GND 1510 14 13 12 11 VCC 220 10 9 220 SHDN 16 15 14 13 12 11 10 9 The module is housed in a hybrid SMD package that supports hand and automated assembly techniques. Since the modules contain discrete components internally, the assembly procedures are critical to ensuring the reliable function of the modules. The following procedures should be reviewed with and practiced by all assembly personnel. Hand Assembly Pads located on the bottom Soldering Iron of the module are the primary Tip mounting surface (Figure 15). Since these pads are inaccessible during mounting, castellations that run up the side of the module Solder have been provided to facilitate PCB Pads Castellations solder wicking to the module’s Figure 15: Soldering Technique underside. This allows for very quick hand soldering for prototyping and small volume production. If the recommended pad guidelines have been followed, the pads will protrude slightly past the edge of the module. Use a fine soldering tip to heat the board pad and the castellation, then introduce solder to the pad at the module’s edge. The solder will wick underneath the module, providing reliable attachment. Tack one module corner first and then work around the device, taking care not to exceed the times in Figure 16. Warning: Pay attention to the absolute maximum solder times. Absolute Maximum Solder Times Hand Solder Temperature: +427ºC for 10 seconds for lead-free alloys Reflow Oven: +255ºC max (see Figure 40) Figure 16: Absolute Maximum Solder Times Automated Assembly For high-volume assembly, the modules are generally auto-placed. The modules have been designed to maintain compatibility with reflow processing techniques; however, due to their hybrid nature, certain aspects of the assembly process are far more critical than for other component types. Following are brief discussions of the three primary areas where caution must be observed. – 14 – Reflow Temperature Profile The single most critical stage in the automated assembly process is the reflow stage. The reflow profile in Figure 17 should not be exceeded because excessive temperatures or transport times during reflow will irreparably damage the modules. Assembly personnel need to pay careful attention to the oven’s profile to ensure that it meets the requirements necessary to successfully reflow all components while still remaining within the limits mandated by the modules. The figure below shows the recommended reflow oven profile for the modules. 300 Recommended RoHS Profile Max RoHS Profile Recommended Non-RoHS Profile 255°C 250 235°C 217°C Temperature (oC) Production Guidelines 200 185°C 180°C 150 125°C 100 50 0 30 60 90 120 150 180 210 240 270 300 330 360 Time (Seconds) Figure 17: Maximum Reflow Temperature Profile Shock During Reflow Transport Since some internal module components may reflow along with the components placed on the board being assembled, it is imperative that the modules not be subjected to shock or vibration during the time solder is liquid. Should a shock be applied, some internal components could be lifted from their pads, causing the module to not function properly. Washability The modules are wash-resistant, but are not hermetically sealed. Linx recommends wash-free manufacturing; however, the modules can be subjected to a wash cycle provided that a drying time is allowed prior to applying electrical power to the modules. The drying time should be sufficient to allow any moisture that may have migrated into the module to evaporate, thus eliminating the potential for shorting damage during power-up or testing. If the wash contains contaminants, the performance may be adversely affected, even after drying. – 15 – Linx Technologies 159 Ort Lane Merlin, OR, US 97532 Phone: +1 541 471 6256 Fax: +1 541 471 6251 www.linxtechnologies.com Disclaimer Linx Technologies is continually striving to improve the quality and function of its products. For this reason, we reserve the right to make changes to our products without notice. The information contained in this Data Guide is believed to be accurate as of the time of publication. Specifications are based on representative lot samples. Values may vary from lot-to-lot and are not guaranteed. “Typical” parameters can and do vary over lots and application. Linx Technologies makes no guarantee, warranty, or representation regarding the suitability of any product for use in any specific application. It is the customer’s responsibility to verify the suitability of the part for the intended application. NO LINX PRODUCT IS INTENDED FOR USE IN ANY APPLICATION WHERE THE SAFETY OF LIFE OR PROPERTY IS AT RISK. Linx Technologies DISCLAIMS ALL WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL LINX TECHNOLOGIES BE LIABLE FOR ANY OF CUSTOMER’S INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING IN ANY WAY FROM ANY DEFECTIVE OR NON-CONFORMING PRODUCTS OR FOR ANY OTHER BREACH OF CONTRACT BY LINX TECHNOLOGIES. The limitations on Linx Technologies’ liability are applicable to any and all claims or theories of recovery asserted by Customer, including, without limitation, breach of contract, breach of warranty, strict liability, or negligence. Customer assumes all liability (including, without limitation, liability for injury to person or property, economic loss, or business interruption) for all claims, including claims from third parties, arising from the use of the Products. The Customer will indemnify, defend, protect, and hold harmless Linx Technologies and its officers, employees, subsidiaries, affiliates, distributors, and representatives from and against all claims, damages, actions, suits, proceedings, demands, assessments, adjustments, costs, and expenses incurred by Linx Technologies as a result of or arising from any Products sold by Linx Technologies to Customer. Under no conditions will Linx Technologies be responsible for losses arising from the use or failure of the device in any application, other than the repair, replacement, or refund limited to the original product purchase price. Devices described in this publication may contain proprietary, patented, or copyrighted techniques, components, or materials. Under no circumstances shall any user be conveyed any license or right to the use or ownership of such items. ©2015 Linx Technologies. All rights reserved. The stylized Linx logo, Wireless Made Simple, WiSE, CipherLinx and the stylized CL logo are trademarks of Linx Technologies.
SDM-USB-QS-S 价格&库存
很抱歉,暂时无法提供与“SDM-USB-QS-S”相匹配的价格&库存,您可以联系我们找货
