SBL2ECHIP-236IR
SBL2ECHIP-236IR
    NETBURNER
    LQFP-80
    SBL2ECHIP-236IR
SBL2ECHIP-236IR 数据手册
SBL2e CHIP and BOB Processor and Break Out Board CHIP Version with 80-pin LQFP | BOB Version with break out board DATASH EET Key Points • Serial to Ethernet server • Works out of the box - no programming is required • TTL serial device support • Chip level product and Break Out Board • Up to 10 LVTTL digital I/O • Customize with development kit • Eight 12-bit A/D inputs Features • 10/100Mbps Ethernet • Industrial Temperature Range (-40°C to 85°C) • TCP/UDP/Telnet modes • DHCP/Static IP modes • Standard and custom baud rates with factory application • Web or AT command based configuration • Custom serial packetization options • 32-bit performance • RS-232 and RS-422/485 ready (require external • level shifter) Optional The following features are available with the optional development kit: • Customize any aspect of operation including web pages, data filtering, or custom network applications • I2C, SPI, and CAN support • External timer inputs • 4-Channel DMA • 4-Channel 8-bit Pulse Width Modulator (PWM) CHIP Version with 80-pin LQFP Updated: August 5, 2014 | Page 1 of 9 BOB Version with break out board © 2014 NetBurner Inc. All Rights Reserved. SBL2e CHIP and BOB Factory Application Specifications Serial Port Baud Rate Factory application supports up to 115,200 bps. Supports custom baud rates. Serial Protocols Supported 2 TTL Serial Configurations The UARTs can be configured in the following way: • Up to 2 TTL ports • Add external level shifter for RS-232 • Add external level shifter for RS-422/485 (up to one port) Note: UART 0 also provides RTS/CTS hardware handshaking signals. Analog to Digital Converter Four 12-Bit Digital I/O Up to 10 Hardware Specifications Processor 32-bit Freescale ColdFire 52236 running at 50MHz Network Interface 10/100 BaseT (CHIP Version) 10-pin header (BOB Version) Data I/O Interface (80-Pin LQFP) • Three UARTs • Eight 12-bit A/D inputs • Up to 10 digital I/O • I2C peripheal interface Physical Characteristics Dimensions (inches): .63” x .63” (CHIP) Dimensions (inches): 2.05” x 1.54 (BOB) Power DC Input Voltage: - 3.3V @ 82mA (with Ethernet on) @ 260mA (with Ethernet off) Environmental Operating Temperature -40° to 85° C RoHS Compliance The Restriction of Hazardous Substances guidelines ensure that electronics are manufactured with fewer environment harming materials. Updated: August 5, 2014 | Page 2 of 9 © 2014 NetBurner Inc. All Rights Reserved. JP6 - 3 JP2 - 1 VCC3V JP2 - 3 JP2 - 9 JP2 - 7 JP2 - 5 JP6 - 6 JP6 - 8 VCC3V GND GND JP5 - 8 JP5 - 11 JP5 - 3 JP5 - 1 JP1 - 3 JP1 - 4 JP6 - 1 JP6 - 2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Updated: August 5, 2014 | Page 3 of 9 BOB Header/Pin CPU Pin UART 1 Clear to Send (UART1_CTS) GND JP5 - 9 JP5 - 15 38 39 40 Yes Yes External Timer Clock Input B (SYNCB) External Timer Clock Input A (SYNCA) Yes Y1 clock crystal 37 UART 0 Clear to Send (UART0_CTS)1,2 Y1 clock crystal 36 Yes Yes GND 35 UART 0 Request to Send (UART0_RTS)1,2 1,2 Yes UART 1 Request to Send (UART1_RTS)1,2 GND via capacitator JP2 - 8 VCC3V GND JP5 - 7 JP5 - 4 JP5 - 6 JP5 - 5 JP5 - 2 JP1 - 13 JP5 - 10 33 32 31 30 29 28 27 26 25 24 JP1 - 12 JP1 - 1 22 23 JP1 - 2 BOB Header/Pin 21 CPU Pin 34 Yes Yes Yes Yes GPIO Timer Input 3 (T3IN) Timer Input 2 (T2IN) JTAG_EN VSSX VDDX Timer Input 1 (T1IN) Timer Input 0 (T0IN) ALLPST DSCLK DSO DSI EZPCS1 BKPT 1 PSTCLK Function Table 1: Multi-function I/O Connector (80-Pin LQFP) Pinout and Signal Descriptions Yes © 2014 NetBurner Inc. All Rights Reserved. Interrupt Request 7 (IRQ7) Yes 1 Yes Yes Yes Yes Yes Yes Yes Yes Yes GPIO Interrupt Request 1 (IRQ1)1 TEST XTAL EXTAL VSSPLL RSTO1 VDDPLL RESET1 VDDX VSSX Interrupt Request 4 (IRQ4) 1 SPI Chip Select 0 (SPI_CS0) SPI Clock (SPI_CLK) SPI Data Out (SPI_DOUT) SPI Data In (SPI_DIN) UART 1 Transmit (UART1_TX)2 UART 1 Receive (UART1_RX)2 UART 0 Transmit (UART0_TX) 2 2 UART 0 Receive (UART0_RX) Function The SBL2e chip has one 80-pin LQFP, which enables you to quickly and easily connect to a board you create on your own. Table 1 provides a description of pin function for the 80-pin LQFP. Multi-function I/O Connector (80-Pin LQFP) SBL2e CHIP and BOB JP5 - 12 JP5 - 14 JP5 - 13 GND GND via capacitor Pulled to GND GND GND via capacitor GND via capacitor JP3 - 1 JP3 - 2 GND JP3 - 3 JP3 - 6 GND via capacitor GND JP3 - 9 VCC3V JP3 - 10 JP6 - 14 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 Ethernet Activity LED (ACTLED) Ethernet Link LED (LNKLED) VDDR Ethernet Speed LED (SPDLED) PHY_VSSRX PHY_VDDRX PHY_RXN (Ethernet Receive -) PHY_RXP (Ethernet Receive +) PHY_VSSTX PHY_TXN (Ethernet Transmit -) PHY_TXP (Ethernet Transmit +) PHY_VDDTX PHY_VDDA PHY_VSSA PHY_RBIAS VDD VSS Ethernet Duplex LED (DUPLED) Ethernet Collision LED (COLLED) Interrupt Request 11 (IRQ11)1 Function Yes Yes Yes Yes GPIO BOB Header/Pin JP6 - 13 JP6 - 12 JP6 - 11 JP6 - 10 JP1 - 10 JP1 - 9 JP1 - 8 JP1 - 7 VCC3V + GND Referance Voltage GND GND GND GND via capacitor JP6 - 9 JP6 - 7 JP6 - 5 JP6 - 4 JP1 - 14 JP1 - 15 CPU Pin 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 Updated: August 5, 2014 | Page 4 of 9 Note: 1. Active low signals, such as RESET, are indicated with an overbar 2. All UART signals are TTL Level, external level shifters may be added for RS-232 or RS-422/485 operation 3. If using I2C, pull-up resistors must be added to open drain SDA/SCL signals. BOB Header/Pin CPU Pin SBL2e CHIP and BOB Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes GPIO © 2014 NetBurner Inc. All Rights Reserved. I2C Serial Data (I2C_SDA)3 I2C Serial Clock (I2C_SCL)3 General Purpose Timer 0 (GPT0) General Purpose Timer 1 (GPT1) General Purpose Timer 2 (GPT2) General Purpose Timer 3 (GPT3) VDD VSS VSSA VRL VRH VDDA A2D Input Channel 0 (AN0) A2D Input Channel 1 (AN1) A2D Input Channel 2 (AN2) A2D Input Channel 3 (AN3) A2D Input Channel 7 (AN7) A2D Input Channel 6 (AN6) A2D Input Channel 5 (AN5) A2D Input Channel 4 (AN4) Function 67 66 65 8 9 10 UART1_RX 23 24 79 80 32 12 13 14 15 16 CAN_RX CAN_TX CAN_RX CAN_TX Function 2 UART2_RX UART2_TX FEC_COL FEX0_TX FEC_RXCLK FEC_RXDV FEC0_RX FEC_CRS Function 3 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Updated: August 5, 2014 | Page 5 of 9 or CAN Transmit or Ethernet RX Data Valid Processor Reset Input1 3.3VDC 3.3VDC © 2014 NetBurner Inc. All Rights Reserved. 2 I C Serial Data or CAN Receive or UART 2 Receive 2 3 3.3VDC 2 I C Serial Clock or CAN Transmit or UART 2 Transmit 3 3.3VDC 2 UART 1 Transmit or Ethernet Collision 2 3.3VDC - 3.3VDC 3.3VDC 3.3VDC 3.3VDC - 3.3VDC 3.3VDC 3.3VDC UART 1 Receive2 or Ethernet 0 Transmit Ground Analog to Digital Converter Input 3 Analog to Digital Converter Input 2 Analog to Digital Converter Input 1 Analog to Digital Converter Input 0 Ground Input Voltage 3.3VDC UART 0 Clear To Send1,2 or CAN Receive or Ethernet RX Clock UART 0 Request To Send 1,2 3.3VDC 2 UART 0 Receive or Ethernet 0 Receive Max Voltage 3.3VDC 2 UART 0 Transmit or Ethernet Carrier Sense General Purpose I/O Description Note: 1. Active low signals, such as RESET, are indicated with an overbar 2. All UART signals are TTL Level, external level shifters may be added for RS-232 or RS-422/485 operation 3. If using I2C, pull-up resistors must be added to open drain SDA/SCL signals. RESET I2C_SDA I2C_SCL UART1_TX GND 11 ADC_IN3 ADC_IN2 ADC_IN1 ADC_IN0 68 UART0_CTS 7 18 4 UART0_RTS GND 17 3 UART0_RX 6 21 2 UART0_TX VCC3V 22 1 Function 1 5 CPU Pin Pin Table 1: I/O Connector (JP1) Pinout and Signal Descriptions The SBL2e Break Out Board (BOB) has several headers, which enable you to quickly and easily connect to one of our standard NetBurner Adapter Boards, or a board you create on your own. Tables 1 through 5 provide a description of pin function for headers JP1 to JP3 and JP5 to JP6. Connector Interface Pinout and Signal Description SBL2e CHIP and BOB DSCLK RESET DSO GND 6 32 5 Active low signals, such as RESET, are indicated with an overbar Function 2 50 51 53 1 2 3 4 5 6 7 8 9 10 Updated: August 5, 2014 | Page 6 of 9 57 59 54 CPU Pin Pin Input Voltage 3.3VDC Ethernet Receive Input Voltage 3.3VDC Ground Ethernet Speed LED Ethernet Link LED Description VCC3V ERXVCC3V GND SPDLED LNKLED General Purpose I/O Development Serial Clock Processor Reset Input1 Development Serial Output Ground All Processor Status Output Breakpoint1 Input Voltage 3.3VDC Development Serial Input Description Ethernet Transmit + Ethernet Transmit Ethernet Receive + Function 2 General Purpose I/O ETX+ ETXERX+ Function 1 Table 3: I/O Connector (JP3) Pinout and Signal Descriptions 1. Note: ALLPST 7 4 BKPT VCC3V DSI 2 1 2 3 4 5 6 7 8 9 10 Function 1 CPU Pin Pin Table 2: I/O Connector (JP2) Pinout and Signal Descriptions SBL2e CHIP and BOB © 2014 NetBurner Inc. All Rights Reserved. 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Max Voltage 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC - Max Voltage 16 25 15 28 26 27 29 13 39 34 14 41 43 42 40 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 GND Yes IRQ7 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes If using I2C, pull-up resistors must be added to open drain SDA/SCL signals. Updated: August 5, 2014 | Page 7 of 9 3. 1,2 or External Timer Clock Input B or UART 2 Ground External Interrupt 71 Ethernet Collision LED Ethernet Duplex LED External Interrupt 111 - 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC © 2014 NetBurner Inc. All Rights Reserved. Timer Input 3 or Timer Output 3 or PWM 6 Output Signal/Input Capture 3.3VDC 3.3VDC External Interrupt 11 or External Timer Clock Input A or PWM 1 Output Signal/ Input Capture Processor Reset Output1 3.3VDC Timer Input 2 or Timer Output 2 or PWM 4 Output Signal/Input Capture 3.3VDC 3.3VDC SPI Clock or I2C Serial Clock3 or UART 1 Request to Send2 External Interrupt 41 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC Max Voltage SPI Data Out or CAN Transmit or UART 1 Transmit2 SPI Chip Select 0 or I2C Serial Data3 or UART 1 Clear to Send2 UART 1 Request To Send Transmit2 1,2 2 or External Timer Clock Input A or UART 2 Transmit SPI Data In or CAN Receive or UART 1 Receive2 UART 1 Clear to Send General Purpose I/O Description Yes PWM_6 PWM_1 PWM_4 UART1_RTS UART1_TX UART1_CTS UART2_TX UART1_RX UART2_TX Function 3 COLLED DUPLED IRQ11 T3IN T3OUT SYNCA IRQ1 RSTOUT T2OUT I2C_SCL CAN_TX T2IN IRQ4 SPI_CLK SPI_DOUT I2C_SDA SYNCB UART1_RTS SPI_CS0 CAN_RX SYNCA Function 2 SPI_DIN UART1_CTS Function 1 Note: 1. Active low signals, such as RESET, are indicated with an overbar 2. All UART signals are TTL Level, external level shifters may be added for RS-232 or RS-422/485 operation 16 CPU Pin Pin Table 4: I/O Connector (JP5) Pinout and Signal Descriptions SBL2e CHIP and BOB 78 77 8 76 9 75 64 63 62 61 60 4 5 6 7 8 9 10 11 12 13 14 ACTLED ADC_IN4 ADC_IN5 ADC_IN6 ADC_IN7 GPT3 T1IN GPT2 T0IN GPT1 GPT0 PSTCLK Updated: August 5, 2014 | Page 8 of 9 GND 1 3 SYNCA 16 20 2 SYNCB GND 19 1 Function 1 15 CPU Pin Pin FEC3_TX T1OUT FEC2_TX T0OUT FEC1_TX FEC_TXER CAN_TX CAN_RX Function 2 PWM_7 PWM_2 PWM_5 PWM_0 PWM_2 PWM_1 FEC_MDIO FEC_MDC Function 3 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Ground Ground Ethernet Activity LED Analog to Digital Converter Input 4 Analog to Digital Converter Input 5 Analog to Digital Converter Input 6 © 2014 NetBurner Inc. All Rights Reserved. - - 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC 3.3VDC General Purpose Timer 3 or Ethernet 3 Transmit or PWM 7 Output Signal/ Input Capture Analog to Digital Converter Input 7 3.3VDC Timer Input 1 or Timer Output 1 or PWM 2 Output Signal/Input Capture 3.3VDC General Purpose Timer 2 or Ethernet 2 Transmit or PWM 5 Output Signal/ Input Capture 3.3VDC General Purpose Timer 1 or Ethernet 1 Transmit or PWM 2 Output Signal/ Input Capture 3.3VDC 3.3VDC General Purpose Timer 0 or Ethernet Transmit Error or PWM 1 Output Signal/Input Capture Timer Input 0 or Timer Output 0 or PWM 0 Output Signal/Input Capture 3.3VDC 3.3VDC 3.3VDC Max Voltage Processor Status Clock External Timer Clock Input A or CAN Transmit or Ethernet Mgmt Data I/O External Timer Clock Input B or CAN Receive or Ethernet Mgmt Data Clock General Purpose I/O Description Table 5: Multi-function I/O Connector (JP6) Pinout and Signal Descriptions SBL2e CHIP and BOB SBL2e CHIP and BOB Part Numbers SBL2e Processor Part Number: SBL2eCHIP-236IR SBL2e Break Out Board Part Number: SBL2E-BOB-200IR SBL2e Break Out Board Development Kit Part Number: NNDK-SBL2EBOB-KIT Kit includes all the hardware and software you need to customize the included platform hardware. Ordering Information E-mail: sales@netburner.com Online Store: www.Netburner.com Telephone: 1-800-695-6828 Updated: August 5, 2014 | Page 9 of 9 © 2014 NetBurner Inc. All Rights Reserved.
SBL2ECHIP-236IR 价格&库存
很抱歉,暂时无法提供与“SBL2ECHIP-236IR”相匹配的价格&库存,您可以联系我们找货
