WIZ810MJ
WIZ810MJ
    WIZNET
    模块
    IC MODULE W5100 + MAG JACK
WIZ810MJ 数据手册
WIZ810MJ Datasheet (Ver. 1.3) © 2013 WIZnet Co., Ltd. All Rights Reserved. For more information, visit our website at www.wiznet.co.kr WIZ810MJ Datasheet Document History Information Revision Ver. 1.0 Data September , 2007 Ver. 1.1 February, 2008 Ver. 1.2 January, 2009 Ver. 1.3 January, 2013 Description Release with WIZ810MJ Launching Hardware revision(ver.1.1). Modified the SPI_EN signal description (P.8) Modified the Schematic & Partlist : R10 is mounted as SPI_EN pull-down resistor. (P.15~16) Added temperature specification Hardware revision(ver.1.2) Changed operation temperature range(P.5) Changed Partlist and schematic © Copyright 2013 WIZnet Co., Ltd. All rights reserved 2 TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet WIZnet’s Online Technical Support If you have something to ask about WIZnet Products, Write down your question on Q&A Board in WIZnet website (www.wiznet.co.kr). WIZnet Engineer will give an answer as soon as possible. 3 TOP WIZ8 10M J Data shee t © Copyright 2013 WIZnet Co., Ltd. All rights reserved WIZ810MJ Datasheet Table of Contents 1. 2. 3. Introduction .............................................................................. 5 1.1. Features ............................................................................. 5 1.2. Block Diagram ...................................................................... 5 Pin Assignments & descriptions ................................................... 6 2.1. Pin Assignments ................................................................... 6 2.2. Power & Ground ................................................................... 6 2.3. MCU Interfaces ..................................................................... 7 2.4. Network status & LEDs ........................................................... 8 2.5. Miscellaneous Signals ............................................................ 8 Timing Diagrams ....................................................................... 9 3.1. Reset Timing ...................................................................... 9 3.2. Register/Memory READ Timing ............................................... 10 3.3. Register/Memory WRITE Timing .............................................. 11 3.4. SPI Timing......................................................................... 12 4. Dimensions ............................................................................. 13 5. Connector Specification ............................................................ 14 6. Schematic .............................................................................. 15 7. Partlists .................................................................................. 16 © Copyright 2013 WIZnet Co., Ltd. All rights reserved 4 TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet 1. Introduction WIZ810MJ is the network module that includes W5100 (TCP/IP hardwired chip, include PHY), MAG-JACK (RJ45 with X’FMR) with other glue logics. It can be used as a component and no effort is required to interface W5100 and Transformer. The WIZ810MJ is an ideal option for users who want to develop their Internet enabling systems rapidly. For the detailed information on implementation of Hardware TCP/IP, refer to the W5100 Datasheet. WIZ810MJ consists of W5100 and MAG-JACK.  TCP/IP, MAC protocol layer: W5100  Physical layer: Included in W5100  Connector: MAG-JACK(RJ45 with Transformer) 1.1. Features               Supports 10/100 Base TX Supports half/full duplex operation Supports auto-negotiation and auto crossover detection IEEE 802.3/802.3u Complaints Operates 3.3V with 5V I/O signal tolerance Supports network status indicator LEDs Includes Hardware Internet protocols: TCP, IP Ver.4, UDP, ICMP, ARP, PPPoE, IGMP Includes Hardware Ethernet protocols: DLC, MAC Supports 4 independent connections simultaneously Supports MCU bus Interface and SPI Interface Supports Direct/Indirect mode bus access Supports Socket API for easy application programming Interfaces with Two 2.0mm pitch 2 * 14 header pin Temperature : [PCB rev1.0] : 0 ~ 70℃ (Operation), -40 ~ 85℃ (Storage) [PCB rev1.1] : 0 ~ 70℃ (Operation), -40 ~ 85℃ (Storage) [PCB rev1.2] : -40 ~ 85℃ (Operation), -40 ~ 85℃ (Storage) 1.2. Block Diagram © Copyright 2013 WIZnet Co., Ltd. All rights reserved 5 TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet 2. Pin Assignments & descriptions 2.1. Pin Assignments 6 TOP WIZ8 10M J Data shee t I : Input I/O : Bi-directional Input and output O : Output P : Power 2.2. Power & Ground Symbol Type VCC GND P P Pin No. JP1:1 , JP1:8, JP2:1, JP2:13, JP2:24 JP1:13, JP1:24, JP2:4, JP2:7 JP2:14, JP2:23 © Copyright 2013 WIZnet Co., Ltd. All rights reserved Description Power : 3.3 V power supply Ground WIZ810MJ Datasheet 2.3. MCU Interfaces Symbol Type A14_SCLK I Pin No. JP1:7 Description ADDRESS PIN OR SCLK(Serial Clock) This pin is used to select a register or memory. When asserting SPI_EN pin high, this pin is used to SPI Clock signal Pin. A13_/SCS I JP1:10 ADDRESS PIN or /SCS (Slave Select) * This pin is used to select a register or memory. When asserting SPI_EN pin high, this pin is used to SPI Slave Select signal Pin. In only SPI Mode, this pin is active low A12_MOSI I JP1:9 ADDRESS PIN or MOSI (Master Out Slave In) * This pin is used to select a register or memory. When asserting SPI_EN pin high, this pin is used to SPI MOSI signal pin. A11_MISO I/O JP1:12 ADDRESS PIN or MISO (Master In Slave Out) * This pin is used to select a register or memory. When asserting SPI_EN pin high, this pin is used to SPI MISO signal pin. A10~A8 I JP1:11, JP1:15 A7~A0 I JP1:16 ~ JP1:23 Address Used as Address[7-0] pin D7~D0 I/O JP2:21, JP2:19, JP2:17, JP2:15, Data 8 bit-wide data bus /CS I JP1:5 Module Select : Active low. /CS of W5100 /RD I JP1:4 Read Enable : Active low. /RD of W5100 /WR I JP1:3 Write Enable : Active low /WR of W5100 JP1:14 JP2:22 JP2:20 JP2:18 JP2:16 © Copyright 2013 WIZnet Co., Ltd. All rights reserved Address Used as Address[10-8] pin 7 TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet /INT O Interrupt : Active low After reception or transmission it indicates that the W5100 requires MCU attention. By writing values to the Interrupt Status Register of W5100 the interrupt will be cleared. All interrupts can be masked by writing values to the IMR of W5100 (Interrupt Mask Register). For more details refer to the W5100 Datasheet JP1:2 8 2.4. Network status & LEDs You can observe the network status using MAG-JACK LEDs. LED interface can be extended to the LED of the main board. Symbol Type Pin No. COL_LED O JP2:6 TX_LED O JP2:8 RX_LED O JP2:10 FDX_LED O JP2:11 LINK_LED O JP2:12 Description Collision LED : Active low when collisions occur. Transmit activity LED : Active low indicates the presence of transmitting activity. Receive activity LED : Active low indicates the presence of receiving activity. Full Duplex LED : Active low when in full duplex operation. Active high when in half duplex operation. Link LED : Active low in link state indicates a good status for 10/100M. It is always ON when the link is OK and it flashes while in a TX or RX state. 2.5. Miscellaneous Signals Symbol Type Pin No. /RESET I JP2:2 SPI_EN I JP2:9 NC - JP1 : 6, 25, 26, 27, 28 JP2 : 3, 5, 25, 26, 27, 28 © Copyright 2013 WIZnet Co., Ltd. All rights reserved Description Reset : This pin is active low input to initialize or re-initialize W5100. By asserting this pin low for at least 2us, all internal registers will be re-initialized to their default states. SPI Enable : This pin selects Enable/Disable W5100 SPI Mode. Low = SPI Mode Disable High = SPI Mode Enable A pull-down resistor(R10) sets to the default of SPI Mode Disable. H/W ver.1.0 : R10 is not mounted H/W ver.1.1 : R10 is mounted Not Connect TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet 3. Timing Diagrams WIZ810MJ provides following interfaces of W5100. -. Direct/Indirect mode bus access -. SPI access Reset Timing 3.1. 9 TOP 1 2 Description Reset Cycle Time /RESET to internal PLOCK © Copyright 2013 WIZnet Co., Ltd. All rights reserved Min 2 us - Max 10 ms WIZ8 10M J Data shee t WIZ810MJ Datasheet 3.2. Register/Memory READ Timing 10 TOP WIZ8 10M J Data shee t 1 2 3 4 5 6 Description Read Cycle Time Valid Address to /CS low time /CS low to /RD low time /RD high to /CS high time /RD low to Valid Data Output time /RD high to Data High-Z Output time © Copyright 2013 WIZnet Co., Ltd. All rights reserved Min 80 ns 8 ns - Max 1 ns 1 ns 80 ns 1 ns WIZ810MJ Datasheet 3.3. Register/Memory WRITE Timing 11 TOP WIZ8 10M J Data shee t 1 2 3 4 5 6 Description Write Cycle Time Valid Address to /CS low time /CS low to /WR high time /CS low to /WR low time /WR high to /CS high time /WR low to Valid Data time © Copyright 2013 WIZnet Co., Ltd. All rights reserved Min 70 ns 7 ns 70 ns - Max 1 ns 1 ns 14 ns WIZ810MJ Datasheet 3.4. SPI Timing 12 TOP WIZ8 10M J Data shee t 1 2 3 4 5 6 Description /SS low to SCLK Input setup time Input hold time Output setup time Output hold time SCLK time © Copyright 2013 WIZnet Co., Ltd. All rights reserved Mode Slave Slave Slave Slave Slave Slave Min 21 ns 7 ns 28 ns 7 ns 21 ns 70 ns Max 14 ns - WIZ810MJ Datasheet 4. Dimensions 13 TOP WIZ8 10M J Data shee t Symbols Dimensions (mm) A 48.0 B 3.5 C 25.0 D 22.4 E 18.4 F 1.0 G 2.0 H 2.0 I 16.0 J 13.5 © Copyright 2013 WIZnet Co., Ltd. All rights reserved WIZ810MJ Datasheet 5. Connector Specification UNIT:mm 14 TOP WIZ8 10M J Data shee t © Copyright 2013 WIZnet Co., Ltd. All rights reserved © Copyright 2013 WIZnet Co., Ltd. All rights reserved 3V3D A8 A6 A4 A2 A0 D7 D6 2 4 6 8 10 12 14 16 18 20 22 24 26 28 HEADER 14X2 1 3 5 7 9 11 13 15 17 19 21 23 25 27 JP1 1V8D 1V8D 1V8_OUT RXIP RXIN 1V8A TXOP TXON 3V3D 3V3A XTLN R1 1M RSET_BG /WR /CS A14_SCLK A12_MOSI A10 R7 300 (1%) R6 12K (1%) C2 15pF Y1 RSET_BG VCC3V3A NC GNDA RXIP RXIN VCC1V8A TXOP TXON GNDA 1V8_OUT VCC3V3D GNDD GNDD VCC1V8D VCC1V8D GNDD VCC3V3D DATA7 DATA6 A13_/SCS A11_MISO A9 A7 A5 A3 A1 /INT /RD 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 U1 D1 D3 D5 D7 SPI_EN FDX_LED C11 10uF/16V D5 D4 D3 D2 D1 D0 MISO MOSI /SCS SCLK SPI_EN 25MHz (SMD) XTLP XTLN 1V8A TX_LED RX_LED COL_LED FDX_LED 1V8D 1V8D XTLP LINK_LED 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 NC NC NC GNDA XTLP XTLN VCC1V8A TXLED RXLED COLLED FDXLED VCC1V8D GNDD SPDLED LINKLED OPMODE2 OPMODE1 OPMODE0 NC NC DATA5 DATA4 DATA3 DATA2 DATA1 DATA0 MISO MOSI /SCS SCLK SEN GNDD VCC1V8D TEST_MODE3 TEST_MODE2 TEST_MODE1 TEST_MODE0 ADDR14 ADDR13 ADDR12 2 4 6 8 10 12 14 16 18 20 22 24 26 28 3V3D 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 D0 D2 D4 D6 COL_LED TX_LED RX_LED LINK_LED /RESET 0.1uF C14 W5100 NC /RESET /RD /WR /INT /CS ADDR0 ADDR1 ADDR2 ADDR3 ADDR4 ADDR5 ADDR6 ADDR7 ADDR8 ADDR9 VCC3V3D GNDD ADDR10 ADDR11 3V3D 0.1uF C13 HEADER 14X2 1 3 5 7 9 11 13 15 17 19 21 23 25 27 JP2 0.1uF C12 3V3D 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 A14 A13 A12 C1 15pF FB1 3V3D 1uH 11 10 14 13 A12 MOSI A11 MISO 4B1 4B2 3B1 3B2 2B1 2B2 1B1 1B2 U3 /OE S GND 1A 2A 3A 4A VCC 15 1 8 4 7 9 12 16 4.7K R10 FB2 RXIP RXIN TXOP TXON C22 0.1uF C18 10uF/16V 1V8D 1V8D SPI_EN C17 3.3uF/16V A14_SCLK A13_/SCS A12_MOSI A11_MISO 3V3D 1V8_OUT SN74CB3Q3257 5 6 2 3 C9 0.01uF A13 /SCS A14 SCLK C7 10uF/16V 3V3A A10 A11 /RESET /RD /WR /INT /CS A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 49.9 R9 C23 0.1uF 1uH 1V8A 0.1uF C5 49.9 R8 49.9 R2 0.1uF C3 Date: B Size Title 200 200 C20 0.1uF 9 10 1 2 3 4 5 6 7 8 1 U2 CON1 LOGO 0.1uF C10 0.1uF C6 Sheet CHGND CHGND BS-RB10005 CH_GND1 CH_GND2 L2L1+ L4L3+ TD+ TDTCT NC1 NC2 NC3 RD+ RD- Friday, January 25, 2013 Document Number WIZ810MJ C21 0.1uF CHGND 13 14 LINK_LED 11 12 FDX_LED R5 R4 C25 0.1uF C19 10uF/16V 0.1uF C4 3V3A C24 0.1uF 1V8A 49.9 R3 3V3A 1 3V3D of 1 VCC Rev 1.2 WIZ810MJ Datasheet 6. Schematic 15 TOP WIZ8 10M J Data shee t WIZ810MJ Datasheet 7. Partlists Item 1 Q.ty 2 Part 15pF Tech. Characteristics 50V-20% Ceramic Package CASE 0603 0.1uF 50V-20% Ceramic CASE 0603 4 Reference C1,C2 C3,C4,C5,C6,C10, C12,C13,C14,C20, C21,C22,C23,C24,C25 C7,C11,C18,C19 2 14 3 10uF/16V 16Vmin 10% EIA/IECQ 3216 4 5 1 2 C9 FB1,FB2 50V-20% Ceramic CASE 0603 CASE 0805 6 2 JP1,JP2 7 8 9 10 11 12 13 14 15 1 4 2 1 1 1 1 1 1 R1 R2,R3,R8,R9 R5,R4 R6 R7 R10 U1 U2 U3 0.01uF 1uH Chip Ferrite Inductor 2X14 28PIN 2mm DIP STRAIGHT Header 1M 49.9 200 12K 300 16 1 Y1 25MHz (SMD) 17 1 PCB WIZ810MJ REV1.2 1.6T 4LAYER 4.7K W5100 BS-RB10005 SN74CB3Q3257 © Copyright 2013 WIZnet Co., Ltd. All rights reserved 2 X 14 2mm pitch 1/10W-5% SMD 1/10W-1% SMD 1/10W-5% SMD 1/10W-1% SMD 1/10W-1% SMD 1/10W-5% SMD WIZnet Hardware TCP/IP Transformer + RJ45 Bus Switch(vendor : TI) SMD Type, CL=18pF, Industrial. FR4, OSP CASE 0603 CASE 0603 CASE 0603 CASE 0603 CASE 0603 CASE 0603 LQFP80 TSSOP SX-1 16 TOP WIZ8 10M J Data shee t
WIZ810MJ 价格&库存
很抱歉,暂时无法提供与“WIZ810MJ”相匹配的价格&库存,您可以联系我们找货
