74LVC2G53
2-channel analog multiplexer/demultiplexer
Rev. 14 — 22 April 2021
Product data sheet
1. General description
The 74LVC2G53 is a single-pole double-throw analog switch with a digital select input (S), two
independent inputs/outputs (Y0 and Y1), a common input/output (Z) and a digital enable input (E).
When E is HIGH, the switch is turned off. Inputs can be driven from either 3.3 V or 5 V devices.
This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments.
Schmitt trigger action at the select and enable inputs makes the circuit tolerant of slower input rise
and fall times across the entire VCC range from 1.65 V to 5.5 V.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
Very low ON resistance:
• 7.5 Ω (typical) at VCC = 2.7 V
• 6.5 Ω (typical) at VCC = 3.3 V
• 6 Ω (typical) at VCC = 5 V
Switch current capability of 32 mA
High noise immunity
CMOS low-power consumption
Overvoltage tolerant inputs to 5.5 V
TTL interface compatibility at 3.3 V
Latch-up performance meets requirements of JESD 78 Class I
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
• CDM JESD22-C101E exceeds 1000 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC2G53DP -40 °C to +125 °C
TSSOP8
plastic thin shrink small outline package; 8 leads;
body width 3 mm; lead length 0.5 mm
SOT505-2
74LVC2G53DC -40 °C to +125 °C
VSSOP8
plastic very thin shrink small outline package; 8 leads;
body width 2.3 mm
SOT765-1
74LVC2G53GT -40 °C to +125 °C
XSON8
plastic extremely thin small outline package; no leads;
8 terminals; body 1 × 1.95 × 0.5 mm
SOT833-1
74LVC2G53GN -40 °C to +125 °C
XSON8
8 terminals; body 1.2 × 1.0 × 0.35 mm
SOT1116
74LVC2G53GS -40 °C to +125 °C
XSON8
8 terminals; body 1.35 × 1.0 × 0.35 mm
SOT1203
74LVC2G53
Nexperia
4. Marking
Table 2. Marking codes
Type number
Marking code[1]
74LVC2G53DP
V53
74LVC2G53DC
V53
74LVC2G53GT
V53
74LVC2G53GN
V3
74LVC2G53GS
V3
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
Y0
S
Y1
S
Y0
Z
Z
Y1
E
E
001aah795
Fig. 1.
Logic symbol
Fig. 2.
001aad387
Logic diagram
6. Pinning information
6.1. Pinning
74LVC2G53
Z
1
8
VCC
E
2
7
Y0
GND
3
6
Y1
GND
4
5
S
74LVC2G53
Z
1
8
VCC
E
2
7
Y0
GND
3
6
Y1
GND
4
5
S
001aae800
Transparent top view
001aae798
Fig. 3.
Pin configuration SOT505-2 (TSSOP8) and
SOT765-1 (VSSOP8)
74LVC2G53
Product data sheet
Fig. 4.
Pin configuration SOT833-1, SOT1116 and
SOT1203 (XSON8)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 23
74LVC2G53
Nexperia
6.2. Pin description
Table 3. Pin description
Symbol
Pin
Description
Z
1
common output or input
E
2
enable input (active LOW)
GND
3
ground (0 V)
GND
4
ground (0 V)
S
5
select input
Y1
6
independent input or output
Y0
7
VCC
8
supply voltage
7. Functional description
Table 4. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
Input
Channel on
S
E
L
L
Y0 to Z or Z to Y0
H
L
Y1 to Z or Z to Y1
X
H
Z
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
VI
input voltage
IIK
input clamping current
ISK
Min
Max
Unit
-0.5
+6.5
V
-0.5
+6.5
V
VI < -0.5 V or VI > VCC + 0.5 V
-50
mA
switch clamping current
±50
mA
VSW
switch voltage
enable and disable mode
-0.5
VCC + 0.5
ISW
switch current
VSW > -0.5 V or VSW < VCC + 0.5 V
±50
mA
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
250
mW
[1]
[2]
[3]
Conditions
[1]
Tamb = -40 °C to +125 °C
[2]
[3]
V
The minimum input voltage rating may be exceeded if the input current rating is observed.
The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed.
For SOT505-2 (TSSOP8) package: Ptot derates linearly with 4.6 mW/K above 96 °C.
For SOT765-1 (VSSOP8) package: Ptot derates linearly with 4.9 mW/K above 99 °C.
For SOT833-1 (XSON8) package: Ptot derates linearly with 3.1 mW/K above 68 °C.
For SOT1116 (XSON8) package: Ptot derates linearly with 4.2 mW/K above 90 °C.
For SOT1203 (XSON8) package: Ptot derates linearly with 3.6 mW/K above 81 °C.
74LVC2G53
Product data sheet
3 / 23
74LVC2G53
Nexperia
9. Recommended operating conditions
Table 6. Operating conditions
Symbol
Parameter
Conditions
VCC
supply voltage
VI
input voltage
VSW
switch voltage
Tamb
ambient temperature
Δt/ΔV
input transition rise and fall rate
[1]
[2]
Min
Max
Unit
1.65
5.5
V
V
VCC
V
°C
[1]
-40
+125
VCC = 1.65 V to 2.7 V
[2]
ns/V
VCC = 2.7 V to 5.5 V
[2]
10
ns/V
To avoid sinking GND current from terminal Z when switch current flows in terminal Yn, the voltage drop across the bidirectional switch
must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current will flow from terminal Yn. In this case, there is no
limit for the voltage drop across the switch.
Applies to control signal levels.
10. Static characteristics
Table 7. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground 0 V).
Symbol
VIH
Parameter
HIGH-level input
voltage
Conditions
-40 °C to +85 °C
LOW-level input
voltage
Unit
Min
Typ [1]
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 3 V to 3.6 V
2.0
2.0
V
0.7VCC
0.7VCC
V
VCC = 1.65 V to 1.95 V
0.35VCC
0.7
VCC = 3 V to 3.6 V
0.8
VCC = 4.5 V to 5.5 V
0.3VCC
VIL
-40 °C to +125 °C
0.35VCC V
0.7
V
0.8
V
0.3VCC
V
II
input leakage
current
pin S and pin E;
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
[2]
±0.1
±1
±1
μA
IS(OFF)
OFF-state
leakage current
VCC = 5.5 V; see Fig. 5
[2]
±0.1
±0.2
±0.5
μA
IS(ON)
ON-state leakage VCC = 5.5 V; see Fig. 6
current
[2]
±0.1
±1
±2
μA
ICC
supply current
VI = 5.5 V or GND;
VSW = GND or VCC;
VCC = 1.65 V to 5.5 V
[2]
0.1
4
4
μA
ΔICC
additional supply
current
pin S and pin E;
VI = VCC - 0.6 V;
VSW = GND or VCC;
VCC = 5.5 V
[2]
5
500
500
μA
74LVC2G53
Product data sheet
4 / 23
74LVC2G53
Nexperia
Symbol
Parameter
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Min
Typ [1]
Max
Min
Max
Unit
CI
input capacitance
2.5
pF
CS(OFF)
OFF-state
capacitance
6.0
pF
CS(ON)
ON-state
capacitance
18
pF
[1]
[2]
Typical values are measured at Tamb = 25 °C.
These typical values are measured at VCC = 3.3 V.
10.1. Test circuits
VCC
S
VIL or VIH
Z
Y0
1
Y1
2
switch
switch
S
E
1
VIL
VIH
2
VIH
VIH
IS
E
GND
VIH
VI
VO
001aad390
VI = VCC or GND; VO = GND or VCC.
Fig. 5.
Test circuit for measuring OFF-state leakage current
VCC
S
VIL or VIH
IS
Z
Y0
1
Y1
2
switch
S
E
1
VIL
VIL
2
VIH
VIL
switch
E
GND
VIL
VI
VO
001aad391
VI = VCC or GND and VO = open circuit.
Fig. 6.
Test circuit for measuring ON-state leakage current
74LVC2G53
Product data sheet
5 / 23
74LVC2G53
Nexperia
10.2. ON resistance
Table 8. ON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Fig. 8 to Fig. 13.
Symbol
Parameter
RON(peak) ON resistance
(peak)
RON(rail)
ON resistance
(rail)
Conditions
-40 °C to +85 °C
-40 °C to +125 °C
Unit
Min
Typ[1]
Max
Min
Max
ISW = 4 mA; VCC = 1.65 V to 1.95 V
34.0
130
195
Ω
ISW = 8 mA; VCC = 2.3 V to 2.7 V
12.0
30
45
Ω
ISW = 12 mA; VCC = 2.7 V
10.4
25
38
Ω
ISW = 24 mA; VCC = 3 V to 3.6 V
7.8
Ω
ISW = 32 mA; VCC = 4.5 V to 5.5 V
6.2
15
23
Ω
8.2
18
27
Ω
7.1
16
24
Ω
6.9
14
21
Ω
6.5
12
18
Ω
5.8
10
15
Ω
10.4
30
45
Ω
7.6
Ω
7.0
18
27
Ω
6.1
15
23
Ω
4.9
10
15
Ω
ISW = 4 mA;VCC = 1.65 V to 1.95 V
26.0
Ω
5.0
Ω
3.5
Ω
2.0
Ω
1.5
Ω
VI = GND to VCC; see Fig. 7
VI = GND; see Fig. 7
VI = VCC; see Fig. 7
RON(flat)
[1]
[2]
ON resistance
(flatness)
VI = GND to VCC
[2]
Typical values are measured at Tamb = 25 °C and nominal VCC.
Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and
temperature.
74LVC2G53
Product data sheet
6 / 23
74LVC2G53
Nexperia
10.3. ON resistance test circuit and graphs
VSW
VCC
VIL or VIH
S
Y0
1
Z
Y1
2
switch
S
E
1
VIL
VIL
2
VIH
VIL
switch
E
GND
VIL
ISW
VI
001aad392
RON = VSW / ISW.
Fig. 7.
Test circuit for measuring ON resistance
mna673
40
RON
(Ω)
30
(1)
(3)
10
(4)
(5)
2
3
4
VI (V)
5
Tamb = 25 °C
1. VCC = 1.8 V
2. VCC = 2.5 V
3. VCC = 2.7 V
4. VCC = 3.3 V
5. VCC = 5.0 V
Fig. 8.
Typical ON resistance as a function of input voltage
74LVC2G53
Product data sheet
7 / 23
74LVC2G53
Nexperia
001aaa712
55
RON
(Ω)
001aaa708
15
RON
(Ω)
45
13
35
11
(4)
(3)
(2)
(1)
25
(1)
(2)
9
(3)
(4)
15
5
7
0.8
1.2
1.6
VI (V)
5
2.0
VCC = 1.8 V
1. Tamb = 125 °C
2. Tamb = 85 °C
3. Tamb = 25 °C
4. Tamb = -40 °C
Fig. 9.
1.0
1.5
2.0
VI (V)
2.5
VCC = 2.5 V
1. Tamb = 125 °C
2. Tamb = 85 °C
3. Tamb = 25 °C
4. Tamb = -40 °C
001aaa709
13
RON
(Ω)
Fig. 10. ON resistance as a function of input voltage
001aaa710
10
RON
(Ω)
11
8
(1)
(1)
9
(2)
(2)
6
(3)
(3)
7
(4)
5
1.0
(4)
1.5
2.0
2.5
3.0
VI (V)
VCC = 2.7 V
1. Tamb = 125 °C
2. Tamb = 85 °C
3. Tamb = 25 °C
4. Tamb = -40 °C
Product data sheet
2
3
VI (V)
4
VCC = 3.3 V
1. Tamb = 125 °C
2. Tamb = 85 °C
3. Tamb = 25 °C
4. Tamb = -40 °C
Fig. 11. ON resistance as a function of input voltage
74LVC2G53
4
Fig. 12. ON resistance as a function of input voltage
8 / 23
74LVC2G53
Nexperia
001aaa711
7
RON
(Ω)
6
5
(1)
(2)
(3)
4
(4)
3
2
3
4
VI (V)
5
VCC = 5.0 V
1. Tamb = 125 °C
2. Tamb = 85 °C
3. Tamb = 25 °C
4. Tamb = -40 °C
Fig. 13. ON resistance as a function of input voltage
74LVC2G53
Product data sheet
9 / 23
74LVC2G53
Nexperia
11. Dynamic characteristics
Table 9. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 16.
Symbol
Parameter
Conditions
-40 °C to +85 °C
Typ[1]
Max
Min
Max
2
2.5
ns
1.2
1.5
ns
VCC = 2.7 V
1.0
1.25
ns
VCC = 3.0 V to 3.6 V
0.8
1.0
ns
0.6
0.8
ns
2.6
6.7
10.3
2.6
12.9
ns
1.9
4.1
6.4
1.9
8.0
ns
VCC = 2.7 V
1.9
4.0
5.5
1.8
7.0
ns
1.8
3.4
5.0
1.8
6.3
ns
1.3
2.6
3.8
1.3
4.8
ns
1.9
4.0
7.3
1.9
9.2
ns
1.4
2.5
4.4
1.4
5.5
ns
VCC = 2.7 V
1.1
2.6
3.9
1.1
4.9
ns
1.2
2.2
3.8
1.2
4.8
ns
1.0
1.7
2.6
1.0
3.3
ns
2.1
6.8
10.0
2.1
12.5
ns
1.4
3.7
6.1
1.4
7.7
ns
VCC = 2.7 V
1.4
4.9
6.2
1.4
7.8
ns
1.1
4.0
5.4
1.1
6.8
ns
1.0
2.9
3.8
1.0
4.8
ns
2.3
5.6
8.6
2.3
11.0
ns
1.2
3.2
4.8
1.2
6.0
ns
VCC = 2.7 V
1.4
4.0
5.2
1.4
6.5
ns
2.0
3.7
5.0
2.0
6.3
ns
1.3
2.9
3.8
1.3
4.8
ns
[2]
[3]
ten
enable time
S to Z or Yn; see Fig. 15
E to Z or Yn; see Fig. 15
tdis
disable time
[1]
[2]
[3]
Unit
Min
propagation delay Z to Yn or Yn to Z; see Fig. 14
tpd
-40 °C to +125 °C
[2]
[2]
[2]
[2]
tpd is the same as tPLH and tPHL; ten is the same as tPZH and tPZL; tdis is the same as tPLZ and tPHZ
Propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when
driven by an ideal voltage source (zero output impedance).
74LVC2G53
Product data sheet
10 / 23
74LVC2G53
Nexperia
11.1. Waveforms and test circuits
VI
Yn or Z
input
VM
VM
GND
tPLH
tPHL
VOH
Z or Yn
output
VM
VM
VOL
001aac361
Measurement points are given in Table 10.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 14. Input (Yn or Z) to output (Z or Yn) propagation delays
VI
S, E input
VM
GND
Z, Yn
Z, Yn
tPLZ
tPZL
VCC
output
LOW to OFF
OFF to LOW
output
HIGH to OFF
OFF to HIGH
VM
VX
VOL
tPHZ
VOH
tPZH
VY
VM
GND
switch
enabled
switch
disabled
switch
enabled
001aad393
Fig. 15. Enable and disable times
Table 10. Measurement points
Supply voltage
Input
Output
VCC
VM
VM
VX
VY
1.65 V to 2.7 V
0.5VCC
0.5VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V to 5.5 V
0.5VCC
0.5VCC
VOL + 0.3 V
VOH - 0.3 V
74LVC2G53
Product data sheet
11 / 23
74LVC2G53
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
VI
PULSE
GENERATOR
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 11.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = Test voltage for switching times.
Fig. 16. Test circuit for measuring switching times
Table 11. Test data
Supply voltage Input
Load
VEXT
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
1.65 V to 1.95 V
VCC
≤ 2.0 ns
30 pF
1 kΩ
open
GND
2VCC
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
GND
2VCC
2.7 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
GND
2VCC
3 V to 3.6 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
GND
2VCC
4.5 V to 5.5 V
VCC
≤ 2.5 ns
50 pF
500 Ω
open
GND
2VCC
74LVC2G53
Product data sheet
12 / 23
74LVC2G53
Nexperia
11.2. Additional dynamic characteristics
Table 12. Additional dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); Tamb = 25 °C.
Symbol
Parameter
Conditions
THD
total harmonic distortion
fi = 600 Hz to 20 kHz; RL = 600 Ω;
CL = 50 pF; VI = 0.5 V (p-p); see Fig. 17
f(-3dB)
αiso
Qinj
Min
Typ
Max
Unit
VCC = 1.65 V
0.260
VCC = 2.3 V
0.078
VCC = 3.0 V
0.078
VCC = 4.5 V
0.078
VCC = 1.65 V
200
MHz
VCC = 2.3 V
300
MHz
VCC = 3.0 V
300
MHz
VCC = 4.5 V
300
MHz
VCC = 1.65 V
-42
dB
VCC = 2.3 V
-42
dB
VCC = 3.0 V
-40
dB
VCC = 4.5 V
-40
dB
VCC = 1.8 V
3.3
pC
VCC = 2.5 V
4.1
pC
VCC = 3.3 V
5.0
pC
VCC = 4.5 V
6.4
pC
VCC = 5.5 V
7.5
pC
-3 dB frequency response RL = 50 Ω; CL = 5 pF; see Fig. 18
RL = 50 Ω; CL = 5 pF; fi = 10 MHz;
see Fig. 19
isolation (OFF-state)
CL = 0.1 nF; Vgen = 0 V; Rgen = 0 Ω;
fi = 1 MHz; RL = 1 MΩ; see Fig. 20
charge injection
11.3. Test circuits
VCC
S
VIL or VIH
0.1 µF
Z
0.5VCC
Y0
1
Y1
2
RL
switch
10 µF
switch
S
E
1
VIL
VIL
2
VIH
VIL
E
VIL
fi
CL
600 Ω
D
GND
001aad394
Fig. 17. Test circuit for measuring total harmonic distortion
74LVC2G53
Product data sheet
13 / 23
74LVC2G53
Nexperia
VCC
0.5VCC
S
VIL or VIH
0.1 µF
Z
Y0
1
Y1
2
RL
switch
switch
S
E
1
VIL
VIL
2
VIH
VIL
E
VIL
fi
dB
CL
50 Ω
GND
001aad395
Adjust fi voltage to obtain 0 dBm level at output. Increase fi frequency until dB meter reads -3 dB.
Fig. 18. Test circuit for measuring the frequency response when switch is in ON-state
0.5VCC
0.5VCC
VCC
RL
RL
S
VIL or VIH
0.1 µF
Z
Y0
1
Y1
2
switch
switch
S
E
1
VIH
VIH
2
VIL
VIH
E
VIH
fi
CL
50 Ω
dB
GND
001aad396
Adjust fi voltage to obtain 0 dBm level at input.
Fig. 19. Test circuit for measuring isolation (OFF-state)
74LVC2G53
Product data sheet
14 / 23
74LVC2G53
Nexperia
VCC
S
Y0
1
Z
Y1
2
switch
E
Rgen
VIL
VI G
VO
RL
CL
Vgen
GND
001aad398
a. Test circuit
logic
(S) off
input
on
VO
off
ΔVO
001aac478
b. Input and output pulse definitions
Qinj = ΔVO × CL.
ΔVO = output voltage variation.
Rgen = generator resistance.
Vgen = generator voltage.
Fig. 20. Test circuit for measuring charge injection
74LVC2G53
Product data sheet
15 / 23
74LVC2G53
Nexperia
12. Package outline
TSSOP8: plastic thin shrink small outline package; 8 leads; body width 3 mm; lead length 0.5 mm
D
E
A
SOT505-2
X
c
HE
y
v M A
Z
5
8
A
A2
pin 1 index
(A3)
A1
θ
Lp
L
1
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D(1)
E(1)
e
HE
L
Lp
v
w
y
Z(1)
θ
mm
1.1
0.15
0.00
0.95
0.75
0.25
0.38
0.22
0.18
0.08
3.1
2.9
3.1
2.9
0.65
4.1
3.9
0.5
0.47
0.33
0.2
0.13
0.1
0.70
0.35
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT505-2
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
02-01-16
Fig. 21. Package outline SOT505-2 (TSSOP8)
74LVC2G53
Product data sheet
16 / 23
74LVC2G53
Nexperia
VSSOP8: plastic very thin shrink small outline package; 8 leads; body width 2.3 mm
D
SOT765-1
E
A
X
c
y
HE
v
A
Z
5
8
Q
A
A2
A1
pin 1 index
(A3)
θ
Lp
1
detail X
4
e
L
w
bp
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
max.
max
nom
min
1
A1
A2
0.15 0.85
0.00 0.60
A3
0.12
D(1)
E(2)
0.27 0.23
2.1
2.4
0.17 0.08
1.9
2.2
bp
c
e
HE
0.5
3.2
3.0
L
0.4
Lp
Q
0.40 0.21
0.15 0.19
v
w
y
0.2
0.08
0.1
Z(1)
θ
0.4
8°
0.1
0°
Note
2. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT765-1
References
IEC
JEDEC
JEITA
sot765-1_po
European
projection
Issue date
07-06-02
16-05-31
MO-187
Fig. 22. Package outline SOT765-1 (VSSOP8)
74LVC2G53
Product data sheet
17 / 23
74LVC2G53
Nexperia
XSON8: plastic extremely thin small outline package; no leads; 8 terminals; body 1 x 1.95 x 0.5 mm
1
2
SOT833-1
b
4
3
4×
(2)
L
L1
e
8
7
6
e1
5
e1
e1
8×
A
(2)
A1
D
E
terminal 1
index area
2 mm
scale
UNIT
A(1)
max
A1
max
b
D
E
e
e1
L
L1
mm
0.5
0.04
0.25
0.17
2.0
1.9
1.05
0.95
0.6
0.5
0.35
0.27
0.40
0.32
Notes
1. Including plating thickness.
2. Can be visible in some manufacturing processes.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT833-1
MO-252
EUROPEAN
PROJECTION
ISSUE DATE
07-11-14
07-12-07
Fig. 23. Package outline SOT833-1 (XSON8)
74LVC2G53
Product data sheet
18 / 23
74LVC2G53
Nexperia
XSON8: extremely thin small outline package; no leads;
8 terminals; body 1.2 x 1.0 x 0.35 mm
1
2
SOT1116
b
4
3
(4×)(2)
L
L1
e
8
7
e1
6
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
max 0.35 0.04 0.20 1.25 1.05
nom
0.15 1.20 1.00 0.55
min
0.12 1.15 0.95
e1
0.3
L
L1
0.35 0.40
0.30 0.35
0.27 0.32
Note
2. Visible depending upon used manufacturing technology.
Outline
version
sot1116_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-07
SOT1116
Fig. 24. Package outline SOT1116 (XSON8)
74LVC2G53
Product data sheet
19 / 23
74LVC2G53
Nexperia
8 terminals; body 1.35 x 1.0 x 0.35 mm
SOT1203
b
1
2
3
(4×)(2)
4
L
L1
e
8
7
6
e1
e1
5
e1
(8×)(2)
A1
A
D
E
terminal 1
index area
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
D
E
e
e1
L
L1
max 0.35 0.04 0.20 1.40 1.05
0.35 0.40
nom
0.15 1.35 1.00 0.55 0.35 0.30 0.35
min
0.12 1.30 0.95
0.27 0.32
Note
Outline
version
sot1203_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
10-04-02
10-04-06
SOT1203
Fig. 25. Package outline SOT1203 (XSON8)
74LVC2G53
Product data sheet
20 / 23
74LVC2G53
Nexperia
13. Abbreviations
Table 13. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 14. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC2G53 v.14
20210422
Product data sheet
Modifications:
74LVC2G53 v.13
20190731
Modifications:
74LVC2G53 v.12
20181116
Modifications:
74LVC2G53 v.11
20170821
Modifications:
74LVC2G53 v.13
Section 1 and Section 2 updated.
Type number 74LVC2G53GF (SOT1089 / XSON8) removed.
Product data sheet
74LVC2G53 v.12
Type number 74LVC2G53GM (SOT902-2/XQFN8) removed.
Table 5: Derating values for Ptot total power dissipation updated.
Product data sheet
74LVC2G53 v.11
Type number 74LVC2G53GD (SOT996-2/XSON8) removed.
Product data sheet
74LVC2G53 v.10
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74LVC2G53 v.10
20161215
Modifications:
74LVC2G53 v.9
20130405
Modifications:
74LVC2G53 v.8
20120622
Modifications:
74LVC2G53 v.7
20111125
Modifications:
74LVC2G53 v.6
20100927
74LVC2G53 v.5
74LVC2G53 v.4
Product data sheet
74LVC2G53 v.9
Table 7: The maximum limits for leakage current and supply current have changed.
Product data sheet
74LVC2G53 v.8
For type number 74LVC2G53GD XSON8U has changed to XSON8.
Product data sheet
74LVC2G53 v.7
For type number 74LVC2G53GM the SOT code has changed to SOT902-2.
74LVC2G53 v.6
Product data sheet
74LVC2G53 v.5
20080618
Product data sheet
74LVC2G53 v.4
20080228
Product data sheet
74LVC2G53 v.3
74LVC2G53 v.3
20070828
Product data sheet
74LVC2G53 v.2
74LVC2G53 v.2
20060331
Product data sheet
74LVC2G53 v.1
74LVC2G53 v.1
20060110
Product data sheet
74LVC2G53
Product data sheet
Product data sheet
Legal pages updated.
21 / 23
74LVC2G53
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74LVC2G53
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
22 / 23
74LVC2G53
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Marking.......................................................................... 2
5. Functional diagram.......................................................2
6. Pinning information......................................................2
6.1. Pinning.........................................................................2
6.2. Pin description............................................................. 3
7. Functional description................................................. 3
8. Limiting values............................................................. 3
9. Recommended operating conditions..........................4
10. Static characteristics..................................................4
10.1. Test circuits................................................................5
10.2. ON resistance............................................................6
10.3. ON resistance test circuit and graphs........................7
11. Dynamic characteristics...........................................10
11.1. Waveforms and test circuits.....................................11
11.2. Additional dynamic characteristics........................... 13
11.3. Test circuits.............................................................. 13
12. Package outline........................................................ 16
13. Abbreviations............................................................ 21
14. Revision history........................................................21
15. Legal information......................................................22
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 April 2021
74LVC2G53
Product data sheet
23 / 23
