74LV4066DB,112
74LV4066DB,112
    NEXPERIA(安世)
    SSOP14_208MIL
    IC SWITCH QUAD 1X2 14SSOP
74LV4066DB,112 数据手册
74LV4066 Quad bilateral switches Rev. 5 — 24 October 2022 Product data sheet 1. General description The 74LV4066 is a quad single pole, single throw analog switch. Each switch features two input/output terminals (nY and nZ) and an active HIGH enable input (nE). When nE is LOW, the analog switch is turned off. Digital inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess VCC. 2. Features and benefits • • • • • • • • • Wide supply voltage range from 1.0 to 6.0 V CMOS low power dissipation Direct interface with TTL levels Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) Typical VOLP (output ground bounce): < 0.8 V at VCC = 3.3 V and Tamb = 25 °C Very low ON-resistance: • 60 Ω (typical) at VCC = 2.0 V • 35 Ω (typical) at VCC = 3.0 V • 25 Ω (typical) at VCC = 4.5 V ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +80 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LV4066D -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 74LV4066DB -40 °C to +125 °C SSOP14 plastic shrink small outline package; 14 leads; body width 5.3 mm SOT337-1 TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 74LV4066PW -40 °C to +125 °C 74LV4066 Nexperia Quad bilateral switches 4. Functional diagram 1 13 4 5 8 6 11 12 1Y 1Z 1 2 13 # 1E 2Y 2Z 1 13 # 3 4 2E 3Y 3Z 3 5# 9 4 5# 8 8 3E 4Y 2 9 6# 6# 4Z 11 10 10 11 12 # 12 # 4E 1 2 X1 1 1 3 X1 1 1 9 X1 1 1 10 X1 (a) (b) 001aad270 001aad269 Fig. 1. 1 Logic symbol Fig. 2. IEC logic diagram nY nE VCC GND VCC nZ 001aad271 Fig. 3. Logic diagram (one switch) 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 2 / 21 74LV4066 Nexperia Quad bilateral switches 5. Pinning information 5.1. Pinning D package SOT108-1 (SO14) 1Y 1 14 VCC 1Z 2 13 1E 2Z 3 12 4E 2Y 4 11 4Y 10 4Z 2E 5 3E 6 9 3Z GND 7 8 3Y DB package SOT337-1 (SSOP14) 1Y 1 14 VCC 1Z 2 13 1E 2Z 3 12 4E 2Y 4 11 4Y 2E 5 10 4Z 3E 6 9 3Z GND 7 8 3Y aaa-035660 aaa-035659 PW package SOT402-1 (TSSOP14) 1Y 1 14 VCC 1Z 2 13 1E 2Z 3 12 4E 2Y 4 11 4Y 2E 5 10 4Z 3E 6 9 3Z GND 7 8 3Y aaa-035661 5.2. Pin description Table 2. Pin description Symbol Pin Description 1Y, 2Y, 3Y, 4Y 1, 4, 8, 11 independent input or output 1Z, 2Z, 3Z, 4Z 2, 3, 9, 10 independent output or input GND 7 ground (0 V) 1E, 2E, 3E, 4E 13, 5, 6, 12 enable input VCC 14 supply voltage 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 3 / 21 74LV4066 Nexperia Quad bilateral switches 6. Functional description Table 3. Function table Input nE Switch LOW off HIGH on 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V ISW switch current VO = -0.5 V to (VCC + 0.5 V) Tstg storage temperature Ptot total power dissipation [1] [2] Conditions Min Max Unit -0.5 +7.0 V - ±20 mA - ±50 mA - ±25 mA -65 +150 °C - 500 mW [1] Tamb = -40 °C to +125 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT337-1 (SSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Typ Max Unit 1.0 3.3 6.0 V VCC supply voltage VI input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 1.0 V to 2.0 V - - 500 ns/V VCC = 2.0 V to 2.7 V - - 200 ns/V VCC = 2.7 V to 3.6 V - - 100 ns/V VCC = 3.6 V to 5.5 V - - 50 ns/V [1] [1] Min in free air The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input levels GND or VCC). 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 4 / 21 74LV4066 Nexperia Quad bilateral switches 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max Unit VCC = 1.2 V 0.90 - - V VCC = 2.0 V 1.40 - - V VCC = 2.7 V to 3.6 V 2.00 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.20 - - V VCC = 1.2 V - - 0.30 V VCC = 2.0 V - - 0.60 V VCC = 2.7 V to 3.6 V - - 0.80 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 20 μA VCC = 6.0 V - - 40 μA - - 500 μA - 3.5 - pF Tamb = -40 °C to +85 °C VIH VIL II IS(OFF) IS(ON) ICC HIGH-level input voltage LOW-level input voltage input leakage current OFF-state leakage current ON-state leakage current supply current ΔICC additional supply current CI input capacitance 74LV4066 Product data sheet VI = VCC or GND VI = VIH or VIL; see Fig. 4 VI = VIH or VIL; see Fig. 5 VI = VCC or GND; IO = 0 A per input; VI = VCC - 0.6 V; VCC = 2.7 V to 3.6 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 5 / 21 74LV4066 Nexperia Quad bilateral switches Symbol Parameter Conditions Min Typ Max Unit VCC = 1.2 V 0.90 - - V VCC = 2.0 V 1.40 - - V VCC = 2.7 V to 3.6 V 2.00 - - V VCC = 4.5 V 3.15 - - V VCC = 6.0 V 4.20 VCC = 1.2 V - - 0.30 V VCC = 2.0 V - - 0.60 V VCC = 2.7 V to 3.6 V - - 0.80 V VCC = 4.5 V - - 1.35 V VCC = 6.0 V - - 1.80 V VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 1.0 μA VCC = 6.0 V - - 2.0 μA VCC = 3.6 V - - 40 μA VCC = 6.0 V - - 80 μA - - 850 μA Tamb = -40 °C to +125 °C VIH VIL II IS(OFF) IS(ON) ICC ΔICC HIGH-level input voltage LOW-level input voltage VI = VCC or GND input leakage current VI = VIH or VIL; see Fig. 4 OFF-state leakage current VI = VIH or VIL; see Fig. 5 ON-state leakage current VI = VCC or GND; IO = 0 A supply current additional supply current VIL per input; VI = VCC - 0.6 V; VCC = 2.7 V to 3.6 V nE VIH nY V nE nZ nY nZ A A A A VI = VCC or GND VO = GND or VCC VI = VCC or GND VO (open circuit) GND GND 001aad274 001aad273 Fig. 4. Test circuit for measuring OFF-state leakage current 74LV4066 Product data sheet Fig. 5. Test circuit for measuring ON-state leakage current All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 6 / 21 74LV4066 Nexperia Quad bilateral switches Table 7. ON-resistance At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 6. Symbol Parameter Min Typ[1] Max - 300 - Ω VCC = 2.0 V - 60 130 Ω VCC = 2.7 V - 41 60 Ω VCC = 3.0 V to 3.6 V - 37 72 Ω VCC = 4.5 V - 25 52 Ω VCC = 6.0 V - 23 47 Ω - 75 - Ω VCC = 2.0 V - 35 98 Ω VCC = 2.7 V - 26 60 Ω VCC = 3.0 V to 3.6 V - 24 52 Ω VCC = 4.5 V - 15 40 Ω VCC = 6.0 V - 13 35 Ω - 75 - Ω VCC = 2.0 V - 40 110 Ω VCC = 2.7 V - 35 72 Ω VCC = 3.0 V to 3.6 V - 30 65 Ω VCC = 4.5 V - 22 47 Ω VCC = 6.0 V - 20 40 Ω VCC = 2.0 V - 5 - Ω VCC = 2.7 V - 4 - Ω VCC = 3.0 V to 3.6 V - 4 - Ω VCC = 4.5 V - 3 - Ω VCC = 6.0 V - 2 - Ω Conditions Unit Tamb = -40 °C to +85 °C; see Fig. 7 RON(peak) ON resistance (peak) VI = VIH or VIL VCC = 1.2 V RON(rail) ON resistance (rail) [2] VI = VIH or VIL; Vis = GND VCC = 1.2 V [2] VI = VIH or VIL; Vis = VCC VCC = 1.2 V RON(flat) ON resistance (flatness) 74LV4066 Product data sheet [2] VI = VIH or VIL; Vis = VCC All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 7 / 21 74LV4066 Nexperia Quad bilateral switches Symbol Parameter Min Typ[1] Max Unit VCC = 2.0 V - - 150 Ω VCC = 2.7 V - - 90 Ω VCC = 3.0 V to 3.6 V - - 83 Ω VCC = 4.5 V - - 60 Ω VCC = 6.0 V - - 54 Ω VCC = 2.0 V - - 115 Ω VCC = 2.7 V - - 68 Ω VCC = 3.0 V to 3.6 V - - 60 Ω VCC = 4.5 V - - 45 Ω VCC = 6.0 V - - 40 Ω VCC = 2.0 V - - 130 Ω VCC = 2.7 V - - 85 Ω VCC = 3.0 V to 3.6 V - - 75 Ω VCC = 4.5 V - - 55 Ω VCC = 6.0 V - - 47 Ω Conditions Tamb = -40 °C to +125 °C RON(peak) RON(rail) VI = VIH or VIL ON resistance (peak) VI = VIH or VIL; Vis = GND ON resistance (rail) VI = VIH or VIL; Vis = VCC [1] [2] All typical values are measured at Tamb = 25 °C. At supply voltage approaching 1.2 V, the analog switch ON-resistance becomes extremely non-linear. Therefore it is recommended that these devices be used to transmit digital signals only, when using these supply voltages. 001aad275 80 RON (Ω) 60 VCC = 2.0 V 40 VIH 3.0 V nE nY Vis = 0 V to (VCC - GND) 4.5 V V 20 nZ I is 0 GND 0 1.2 2.4 3.6 001aad272 Fig. 6. Test circuit for measuring ON resistance 74LV4066 Product data sheet Fig. 7. Vis (V) 4.8 ON resistance as a function of input voltage All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 8 / 21 74LV4066 Nexperia Quad bilateral switches 10. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10. Symbol Parameter Min Typ[1] VCC = 1.2 V - 8 - ns VCC = 2.0 V - 5 26 ns VCC = 2.7 V to 3.6 V - 3 15 ns VCC = 4.5 V - 2 13 ns VCC = 6.0 V - 2 10 ns VCC = 1.2 V - 40 - ns VCC = 2.0 V - 22 43 ns VCC = 2.7 V to 3.6 V - 12 25 ns VCC = 3.3 V; CL = 15 pF - 10 - ns VCC = 4.5 V - 10 21 ns VCC = 6.0 V - 8 16 ns VCC = 1.2 V - 50 - ns VCC = 2.0 V - 27 65 ns VCC = 2.7 V to 3.6 V - 15 38 ns VCC = 3.3 V; CL = 15 pF - 13 - ns VCC = 4.5 V - 13 32 ns VCC = 6.0 V - 12 28 ns - 11 - pF Conditions Max Unit Tamb = -40 °C to +85 °C tpd ton toff CPD Vis to Vos; see Fig. 8 propagation delay nE to Vos; see Fig. 9 turn-on time nE to Vos; see Fig. 9 turn-off time power dissipation capacitance 74LV4066 Product data sheet per switch; VCC = 3.3 V; VI = GND to VCC; CL = 15 pF All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 [2] [3] [4] [5] © Nexperia B.V. 2022. All rights reserved 9 / 21 74LV4066 Nexperia Quad bilateral switches Symbol Parameter Min Typ[1] Max VCC = 2.0 V - - 31 ns VCC = 2.7 V to 3.6 V - - 18 ns VCC = 4.5 V - - 15 ns VCC = 6.0 V - - 12 ns VCC = 2.0 V - - 51 ns VCC = 2.7 V to 3.6 V - - 30 ns VCC = 4.5 V - - 26 ns VCC = 6.0 V - - 20 ns VCC = 2.0 V - - 81 ns VCC = 2.7 V to 3.6 V - - 47 ns VCC = 4.5 V - - 40 ns VCC = 6.0 V - - 34 ns Conditions Unit Tamb = -40 °C to +125 °C tpd ton [2] nE to Vos; see Fig. 9 turn-on time toff [1] [2] [3] [4] [5] Vis to Vos; see Fig. 8 propagation delay [3] nE to Vos; see Fig. 9 turn-off time [4] Typical values are measured at nominal VCC and Tamb = 25 °C. tpd is the same as tPLH and tPHL. ton is the same as tPZH and tPZL. toff is the same as tPHZ and tPLZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ[(CL + CS) x VCC x fo] where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CS = maximum switch capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ[(CL + CS) x VCC x fo] = sum of the outputs. 10.1. Waveforms and test circuit VI Vis VM VM GND t PLH t PHL VOH Vos VM VOL VM 001aad284 Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 8. Input to output propagation delays 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 10 / 21 74LV4066 Nexperia Quad bilateral switches VI nE input VM GND t PLZ output LOW-to-OFF OFF-to-LOW t PZL VCC VM VX VOL t PHZ output HIGH-to-OFF OFF-to-HIGH VOH t PZH VY VM GND outputs enabled outputs disabled outputs enabled 001aad285 Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. Turn-on and turn-off times for the inputs to the output Table 9. Measurement points Supply voltage Input Output VCC VM VM VX VY < 2.7 V 0.5 x VCC 0.5 x VCC VOL + 0.15 VOH - 0.15 V ≥ 2.7 V 1.5 V 1.5 V VOL + 0.3 VOH - 0.3 V 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 11 / 21 74LV4066 Nexperia Quad bilateral switches tW VI 90 % negative pulse 90 % VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V 10 % tW 001aac221 a. Input pulse definition VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 10. Definitions test circuit: RL = Load resistance; CL = Load capacitance includes jig and probe capacitance; RT = Termination resistance should be equal to Zo of the pulse generator; VEXT = Test voltage for switching times. Test circuit Fig. 10. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr, tf CL RL [1] tPHZ, tPZH tPLZ, tPZL tPLH, tPHL < 2.7 V VCC ≤ 2.5 ns 50 pF 1 kΩ GND 2 x VCC open 2.7 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 1 kΩ GND 2 x VCC open ≥ 4.5 V VCC ≤ 2.5 ns 50 pF 1 kΩ GND 2 x VCC open [1] Load VEXT RL = ∞ Ω for measuring the propagation delays tPLH and tPHL. 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 12 / 21 74LV4066 Nexperia Quad bilateral switches 10.2. Additional dynamic characteristics Table 11. Additional dynamic characteristics Voltages are referenced to GND (ground = 0 V); Vis is the input voltage at pin nY or nZ, whichever is assigned as an input; Vos is the output voltage at pin nY or nZ, whichever is assigned as an output. Symbol Parameter Conditions Min Typ Max dsin sine-wave distortion RL = 10 kΩ; f = 1 kHz; CL = 50 pF; see Fig. 11 Unit VCC = 3.0 V; Vis = 2.75 V (p-p) - 0.04 - % VCC = 6.0 V; Vis = 5.50 V (p-p) - 0.02 - % VCC = 3.0 V; Vis = 2.75 V (p-p) - 0.12 - % VCC = 6.0 V; Vis = 5.50 V (p-p) - 0.06 - % VCC = 3.0 V - -50 - dB VCC = 6.0 V - -50 - dB VCC = 3.0 V - -60 - dB VCC = 6.0 V - -60 - dB - 110 - mV - 220 - mV VCC = 3.0 V - 180 - MHz VCC = 6.0 V - 200 - MHz - 8 - pF RL = 10 kΩ; f = 10 kHz; CL = 50 pF; see Fig. 11 RL = 600 kΩ; f = 1 MHz; CL = 50 pF; see Fig. 12 and Fig. 13 αOFF(feedthru) switch OFF-state signal feed-through attenuation αct(S) Vct(pp) [1] crosstalk between switches RL = 600 kΩ; f = 1 MHz; CL = 50 pF; see Fig. 14 [1] crosstalk voltage between enable input to any switch (peak-to-peak value) RL = 600 kΩ; f = 1 MHz; CL = 50 pF; see Fig. 15 and Fig. 16 [2] minimum frequency response (-3 dB) RL = 50 kΩ; CL = 50 pF; see Fig. 17 and Fig. 18 VCC = 3.0 V VCC = 6.0 V fmax CS [1] [2] [3] [3] maximum switch capacitance Adjust input voltage Vis is 0 dBm level (0 dBm = 1 mW into 600 Ω). Pin nE: square wave between VCC and GND, tr = tf = 6 ns. Adjust input voltage Vis is 0 dBm level at Vos for 1 MHz (0 dBm = 1 mW into 50 Ω). VCC 10 µF Vis fin = 1 kHz sine-wave 2RL nY/nZ channel ON 2RL nZ/nY CL Vos distortion meter GND 001aad282 Fig. 11. Test circuit for measuring sine-wave distortion 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 13 / 21 74LV4066 Nexperia Quad bilateral switches 001aad276 0 α OFF(feedthru) (dB) - 20 - 40 - 60 VCC 0.1 µF Vis 2RL nY/nZ nZ/nY 2RL channel OFF CL - 80 Vos - 100 dB GND RL VCC Vis 2RL nY/nZ channel ON nY/nZ nZ/nY 2RL 104 105 f (kHz) 106 Fig. 13. Switch OFF-state signal feed-through as a function of frequency VCC 0.1 µF 103 VCC = 3.0 V; GND = 0 V; RL = 50 Ω; RSOURCE = 1 kΩ 001aad283 Fig. 12. Test circuit for measuring switch OFF-state signal feed-through 102 10 CL VCC 2RL 2RL RL channel OFF nZ/nY 2RL CL Vos dB GND GND 001aad314 001aad278 a. Channel ON condition b. Channel OFF condition Fig. 14. Test circuit for measuring crosstalk between switches VCC nE VCC VCC GND 2RL nY/nZ 2RL nZ/nY DUT 2RL 2RL CL oscilloscope VCT(pp) GND 001aad279 Fig. 15. Test circuit for measuring crosstalk between enable and any switch 74LV4066 Product data sheet 001aad281 Fig. 16. Crosstalk definition (oscilloscope output) All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 14 / 21 74LV4066 Nexperia Quad bilateral switches 001aad277 5 Vos (dB) 0 VCC 0.1 µF Vis 2RL nY/nZ sine-wave channel ON 2RL nZ/nY CL Vos dB -5 GND 001aad280 Fig. 17. Test circuit for measuring minimum frequency response 74LV4066 Product data sheet 10 102 103 104 105 f (kHz) 106 VCC = 3.0 V; GND = 0 V; RL = 50 Ω; RSOURCE = 1 kΩ Fig. 18. Frequency response All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 15 / 21 74LV4066 Nexperia Quad bilateral switches 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 19. Package outline SOT108-1 (SO14) 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 16 / 21 74LV4066 Nexperia Quad bilateral switches SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm D SOT337-1 E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp L 7 1 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 6.4 6.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 1.4 0.9 8o 0o Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT337-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 20. Package outline SOT337-1 (SSOP14) 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 17 / 21 74LV4066 Nexperia Quad bilateral switches TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 21. Package outline SOT402-1 (TSSOP14) 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 18 / 21 74LV4066 Nexperia Quad bilateral switches 12. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 13. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LV4066 v.5 20221024 Product data sheet - 74LV4066 v.4 Modifications: • • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Section 1 and Section 2 updated. Section 5.1 updated. Section 7: Derating values for Ptot total power dissipation updated. 74LV4066 v.4 20151209 Modifications: • 74LV4066 v.3 20050704 Modifications: • • 74LV4066 v.2 74LV4066 Product data sheet Product data sheet - Type number 74LV4066N (SOT27-1) removed. Product data sheet - 74LV4066 v.3 Modifications: 74LV4066 v.2 The format of this data sheet has been redesigned to comply with the new presentation and information standard of Philips Semiconductors. Table 1: corrected package names. 19980623 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 - © Nexperia B.V. 2022. All rights reserved 19 / 21 74LV4066 Nexperia Quad bilateral switches 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LV4066 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 20 / 21 74LV4066 Nexperia Quad bilateral switches Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................4 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 9 10.1. Waveforms and test circuit...................................... 10 10.2. Additional dynamic characteristics...........................13 11. Package outline........................................................ 16 12. Abbreviations............................................................ 19 13. Revision history........................................................19 14. Legal information......................................................20 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 October 2022 74LV4066 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 24 October 2022 © Nexperia B.V. 2022. All rights reserved 21 / 21
74LV4066DB,112 价格&库存
很抱歉,暂时无法提供与“74LV4066DB,112”相匹配的价格&库存,您可以联系我们找货
