74LVC1G66GW,165
74LVC1G66GW,165
    NEXPERIA(安世)
    TSSOP-5_2.05X1.25MM
    IC SWITCH SPST 5TSSOP
74LVC1G66GW,165 数据手册
74LVC1G66 Bilateral switch Rev. 10 — 7 December 2016 Product data sheet 1. General description The 74LVC1G66 provides one single pole, single-throw analog switch function. It has two input/output terminals (Y and Z) and an active HIGH enable input pin (E). When E is LOW, the analog switch is turned off. Schmitt-trigger action at the enable input makes the circuit tolerant of slower input rise and fall times across the entire VCC range from 1.65 V to 5.5 V. 2. Features and benefits  Wide supply voltage range from 1.65 V to 5.5 V  Very low ON resistance:  7.5  (typical) at VCC = 2.7 V  6.5  (typical) at VCC = 3.3 V  6  (typical) at VCC = 5 V  Switch current capability of 32 mA  High noise immunity  CMOS low power consumption  TTL interface compatibility at 3.3 V  Latch-up performance meets requirements of JESD78 Class I  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Enable input accepts voltages up to 5.5 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1G66GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1G66GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1G66GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1G66 Nexperia Bilateral switch Table 1. Ordering information …continued Type number Package Temperature range Name Description Version 74LVC1G66GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1G66GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9  1.0  0.35 mm SOT1115 74LVC1G66GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0  1.0  0.35 mm SOT1202 4. Marking Table 2. Marking Type number Marking code[1] 74LVC1G66GW VL 74LVC1G66GV V66 74LVC1G66GM VL 74LVC1G66GF VL 74LVC1G66GN VL 74LVC1G66GS VL [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram (  =  <  PQD DDJ Fig 1. Logic symbol   ; Fig 2. IEC logic symbol = < ( 9&& Fig 3. DDP Logic diagram 74LVC1G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 25 74LVC1G66 Nexperia Bilateral switch 6. Pinning information 6.1 Pinning /9&* /9&* <  =  *1'   9&& <   9&& =   QF *1'  (  ( <   9&& =   QF *1'   ( DDJ DDJ 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ DDG Fig 4.  /9&* Pin configuration SOT353-1 and SOT753 Fig 5. Pin configuration SOT886 Fig 6. Pin configuration SOT891 and SOT1115 and SOT1202 6.2 Pin description Table 3. Symbol Pin description Pin Description SOT353-1, SOT753 SOT886, SOT891, SOT1115 and SOT1202 Y 1 1 independent input or output Z 2 2 independent output or input GND 3 3 ground (0 V) E 4 4 enable input (active HIGH) n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input E Switch L OFF-state H ON-state [1] H = HIGH voltage level; L = LOW voltage level 74LVC1G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 25 74LVC1G66 Nexperia Bilateral switch 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions [1] VI input voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V ISK switch clamping current VI < 0.5 V or VI > VCC + 0.5 V [2] Min Max Unit 0.5 +6.5 V 0.5 +6.5 V 50 - mA - 50 mA 0.5 VCC + 0.5 V VSW switch voltage enable and disable mode ISW switch current VSW > 0.5 V or VSW < VCC + 0.5 V - 50 mA ICC supply current - 100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C - 250 mW total power dissipation Ptot Tamb = 40  C to +125 C [3] [1] The minimum input voltage rating may be exceeded if the input current rating is observed. [2] The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed. [3] For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter VCC supply voltage VI input voltage VSW Conditions [1] switch voltage Tamb ambient temperature t/V input transition rise and fall rate Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V 40 - +125 C VCC = 1.65 V to 2.7 V [2] - - 20 ns/V VCC = 2.7 V to 5.5 V [2] - - 10 ns/V [1] To avoid sinking GND current from terminal Z when switch current flows in terminal Y, the voltage drop across the bidirectional switch must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current will flow from terminal Y. In this case, there is no limit for the voltage drop across the switch. [2] Applies to control signal levels. 74LVC1G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 25 74LVC1G66 Nexperia Bilateral switch 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 40 C to +85 C Conditions Min HIGH-level input voltage VIH LOW-level input voltage VIL VCC = 1.65 V to 1.95 V Typ[1] 40 C to +125 C Unit Max Min Max 0.65VCC - - 0.65VCC - V VCC = 2.3 V to 2.7 V 1.7 - - 1.7 - V VCC = 2.7 V to 3.6 V 2.0 - - 2.0 - V VCC = 4.5 V to 5.5 V 0.7VCC - - 0.7VCC - V VCC = 1.65 V to 1.95 V - - 0.35VCC - VCC = 2.3 V to 2.7 V - - 0.7 - 0.7 V VCC = 2.7 V to 3.6 V - - 0.8 - 0.8 V VCC = 4.5 V to 5.5 V 0.35VCC V - - 0.3VCC - 0.3VCC V - 0.1 1 - 1 A II input leakage pin E; VI = 5.5 V or GND; current VCC = 0 V to 5.5 V [2] IS(OFF) OFF-state leakage current VCC = 5.5 V; see Figure 7 [2] - 0.1 0.2 - 0.5 A IS(ON) ON-state leakage current VCC = 5.5 V; see Figure 8 [2] - 0.1 1 - 2 A ICC supply current VI = 5.5 V or GND; VSW = GND or VCC; VCC = 1.65 V to 5.5 V [2] - 0.1 4 - 4 A ICC additional supply current pin E; VI = VCC  0.6 V; VSW = GND or VCC; VCC = 5.5 V [2] - 5 500 - 500 A CI input capacitance - 2.0 - - - pF CS(OFF) OFF-state capacitance - 6.5 - - - pF CS(ON) ON-state capacitance - 11 - - - pF [1] All typical values are measured at Tamb = 25 C. [2] These typical values are measured at VCC = 3.3 V. 74LVC1G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 25 74LVC1G66 Nexperia Bilateral switch 10.1 Test circuits 9&& 9&& ( 9,/ = 9, ( 9,+ < ,6 *1' ,6 92 = < *1' 9, 92 DDP DDP VI = VCC or GND and VO = GND or VCC. Fig 7. VI = VCC or GND and VO = open circuit. Test circuit for measuring OFF-state leakage current Fig 8. Test circuit for measuring ON-state leakage current 10.2 ON resistance Table 8. ON resistance At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 10 to Figure 15. Symbol Parameter RON(peak) ON resistance (peak) RON(rail) ON resistance (rail) 40 C to +85 C Conditions 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 4 mA; VCC = 1.65 V to 1.95 V - 34.0 130 - 195  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 12.0 30 - 45  ISW = 12 mA; VCC = 2.7 V - 10.4 25 - 38  ISW = 24 mA; VCC = 3.0 V to 3.6 V - 7.8 20 - 30  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 6.2 15 - 23  ISW = 4 mA; VCC = 1.65 V to 1.95 V - 8.2 18 - 27  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.1 16 - 24  ISW = 12 mA; VCC = 2.7 V - 6.9 14 - 21  ISW = 24 mA; VCC = 3.0 V to 3.6 V - 6.5 12 - 18  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 5.8 10 - 15  ISW = 4 mA; VCC = 1.65 V to 1.95 V - 10.4 30 - 45  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 7.6 20 - 30  ISW = 12 mA; VCC = 2.7 V - 7.0 18 - 27  ISW = 24 mA; VCC = 3.0 V to 3.6 V - 6.1 15 - 23  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 4.9 10 - 15  VI = GND to VCC; see Figure 9 VI = GND; see Figure 9 VI = VCC; see Figure 9 74LVC1G66 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 25 74LVC1G66 Nexperia Bilateral switch Table 8. ON resistance …continued At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 10 to Figure 15. Symbol RON(flat) Parameter 40 C to +85 C Conditions ON resistance (flatness) 40 C to +125 C Unit Min Typ[1] Max Min Max ISW = 4 mA; VCC = 1.65 V to 1.95 V - 26.0 - - -  ISW = 8 mA; VCC = 2.3 V to 2.7 V - 5.0 - - -  ISW = 12 mA; VCC = 2.7 V - 3.5 - - -  ISW = 24 mA; VCC = 3.0 V to 3.6 V - 2.0 - - -  ISW = 32 mA; VCC = 4.5 V to 5.5 V - 1.5 - - -  [2] VI = GND to VCC [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and temperature. 10.3 ON resistance test circuit and graphs PQD  521 ȍ  96:    9&& ( 9,+     <  =   9, *1'   ,6:       RON = VSW/ISW.  9, 9 DDP (1) VCC = 1.8 V. (2) VCC = 2.5 V. (3) VCC = 2.7 V. (4) VCC = 3.3 V. (5) VCC = 5.0 V. Fig 9. Test circuit for measuring ON resistance 74LVC1G66 Product data sheet Fig 10. Typical ON resistance as a function of input voltage; Tamb = 25 C All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 7 of 25 74LVC1G66 Nexperia Bilateral switch DDD  521 ȍ DDD  521 ȍ                                 9, 9 (1) Tamb = 125 C. (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. Fig 11. ON resistance as a function of input voltage; VCC = 1.8 V DDD  521 ȍ  9, 9 Fig 12. ON resistance as a function of input voltage; VCC = 2.5 V DDD  521 ȍ                       9, 9   (1) Tamb = 125 C. (2) Tamb = 85 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (3) Tamb = 25 C. (4) Tamb = 40 C. (4) Tamb = 40 C. 74LVC1G66 Product data sheet   9, 9 (1) Tamb = 125 C. Fig 13. ON resistance as a function of input voltage; VCC = 2.7 V  Fig 14. ON resistance as a function of input voltage; VCC = 3.3 V All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 8 of 25 74LVC1G66 Nexperia Bilateral switch DDD  521 ȍ               9, 9 (1) Tamb = 125 C. (2) Tamb = 85 C. (3) Tamb = 25 C. (4) Tamb = 40 C. Fig 15. ON resistance as a function of input voltage; VCC = 5.0 V 11. Dynamic characteristics Table 9. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 18. Symbol Parameter tpd 40 C to +85 C Conditions Min Max Min Max VCC = 1.65 V to 1.95 V - 0.8 2.0 - 3.0 ns VCC = 2.3 V to 2.7 V - 0.4 1.2 - 2.0 ns VCC = 2.7 V - 0.4 1.0 - 1.5 ns VCC = 3.0 V to 3.6 V - 0.3 0.8 - 1.5 ns - 0.2 0.6 - 1.0 ns [2][3] propagation delay Y to Z or Z to Y; see Figure 16 VCC = 4.5 V to 5.5 V ten enable time 74LVC1G66 Product data sheet 40 C to +125 C Unit Typ[1] E to Y or Z; see Figure 17 [4] VCC = 1.65 V to 1.95 V 1.0 5.3 12 1.0 15.5 ns VCC = 2.3 V to 2.7 V 1.0 3.0 6.5 1.0 8.5 ns VCC = 2.7 V 1.0 2.6 6.0 1.0 8.0 ns VCC = 3.0 V to 3.6 V 1.0 2.5 5.0 1.0 6.5 ns VCC = 4.5 V to 5.5 V 1.0 1.9 4.2 1.0 5.5 ns All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 December 2016 © Nexperia B.V. 2017. All rights reserved 9 of 25 74LVC1G66 Nexperia Bilateral switch Table 9. Dynamic characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 18. Symbol Parameter 40 C to +85 C Conditions Min tdis disable time 40 C to +125 C Unit Max Min Max [5] E to Y or Z; see Figure 17 VCC = 1.65 V to 1.95 V 1.0 4.2 10 1.0 13 ns VCC = 2.3 V to 2.7 V 1.0 2.4 6.9 1.0 9.0 ns VCC = 2.7 V 1.0 3.6 7.5 1.0 9.5 ns VCC = 3.0 V to 3.6 V 1.0 3.4 6.5 1.0 8.5 ns 1.0 2.5 5.0 1.0 6.5 ns VCC = 2.5 V - 9.8 - - - pF VCC = 3.3 V - 12.0 - - - pF VCC = 5.0 V - 17.3 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance CPD Typ[1] [6] CL = 50 pF; fi = 10 MHz; VI = GND to VCC [1] Typical values are measured at Tamb = 25 C and nominal VCC. [2] tpd is the same as tPLH and tPHL [3] propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when driven by an ideal voltage source (zero output impedance). [4] ten is the same as tPZH and tPZL [5] tdis is the same as tPLZ and tPHZ [6] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + {(CL + CS(ON)) VCC2  fo} where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; CS(ON) = maximum ON-state switch capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; {(CL + CS(ON))  VCC2  fo} = sum of the outputs. 11.1 Waveforms and test circuit 9, 90
74LVC1G66GW,165 价格&库存
很抱歉,暂时无法提供与“74LVC1G66GW,165”相匹配的价格&库存,您可以联系我们找货
