DA7212-01UM2
DA7212-01UM2
    DIALOGSEMICONDUCTOR(戴乐格)
    CSP34
    ICAUDIOCODEC34CSP
DA7212-01UM2 数据手册
DA7212 Company confidential Datasheet/Ultra-low power stereo codec General description DA7212 is an ultra-low power audio codec targeting portable audio devices. The input paths support stereo FM line input and up to four analogue (or two analogue and two digital) microphones with two independent microphone biases. Comprehensive analogue mixing and bypass paths to the output drivers are available. The headphone output is true-ground Class G with integrated charge pump. There is also a differential Class AB speaker driver that can serve as a mono lineout. Digital audio transfer to/from the external processor is via a bidirectional digital audio interface that supports all common sample rates and formats. The device may be operated in slave or master modes using the internal PLL which may be bypassed if not required. To fully optimise each customer application, a range of built in filtering, equalisation and audio enhancements are available. These are accessible by the processor over the I2C serial interface. Key features ■ 100 dB SNR stereo audio playback into ■ Built-in 5-band equaliser, ALC and noise-gate 16 - 32 Ω headphones functions ■ 3.1 mW power consumption for stereo DAC to ■ headphone playback ■ ■ 1.2 W mono speaker driver ■ 650 µW mono voice record ■ ■ Stereo digital microphone support ■ ■ Supports up to four analogue microphones ■ ■ Two low-noise microphone-bias outputs ■ Low-power PLL provides system clocking and Built-in beep generator Integrated system controller to eliminate pops and clicks Minimised external component count 34-ball WLCSP (4.54 mm x 1.66 mm) package Staggered 0.5 mm pitch for easy PCB routing audio sample rate flexibility Applications ■ Personal Media Players ■ Audio headphone/headsets ■ Wearables ■ Embedded applications ■ Arduino-compatible development systems Figure 1: The DA7212 chip Datasheet CFR0011-120-00 Rev 4 Revision 3a 1 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Contents General description .................................................................................................................... 1 Key features ............................................................................................................................... 1 Applications ............................................................................................................................... 1 Contents .................................................................................................................................... 2 Figures ....................................................................................................................................... 6 Tables ........................................................................................................................................ 7 1 Terms and definitions ........................................................................................................... 9 2 Block diagram ......................................................................................................................10 3 Pinout .................................................................................................................................11 4 Absolute maximum ratings ..................................................................................................14 5 Recommended operating conditions ....................................................................................15 6 Electrical characteristics .......................................................................................................16 7 Parametric specifications .....................................................................................................17 8 Digital signal processing .......................................................................................................20 9 Audio outputs......................................................................................................................23 11 Clock generation ..................................................................................................................27 12 Phase Locked Loop (PLL) ......................................................................................................27 13 Digital interfaces..................................................................................................................28 13.1 Codec Start-Up Time ........................................................................................................... 31 14 Functional description .........................................................................................................32 14.1 General description............................................................................................................. 32 14.2 Input Signal Chain ............................................................................................................... 32 14.3 Microphone Inputs ............................................................................................................. 33 14.4 Digital microphones ............................................................................................................ 34 14.5 Auxiliary inputs ................................................................................................................... 35 14.6 Input mixers ........................................................................................................................ 35 14.7 Stereo audio ADC ................................................................................................................ 36 14.8 Automatic Level Control (ALC) ............................................................................................ 36 Datasheet CFR0011-120-00 Rev 4 Revision 3a 2 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.9 Beep Generator and Controller .......................................................................................... 38 14.10 Output Signal Chain ............................................................................................................ 39 14.11 Stereo Audio DAC................................................................................................................ 40 14.12 Output Mixer ...................................................................................................................... 40 14.13 Headphone Amplifier .......................................................................................................... 41 14.14 Speaker Amplifier................................................................................................................ 41 14.15 Charge Pump Control .......................................................................................................... 42 14.16 Charge pump clock control ................................................................................................. 44 14.17 Boosting the charge pump using demand feedback control .............................................. 44 14.17.1 Tracking the demands on the charge pump output ............................................. 44 14.17.1.1 CP_MCHANGE = 00 (manual mode) .................................................. 44 14.17.1.2 CP_MCHANGE = 01 (tracking the PGA gain setting) .......................... 44 14.17.1.3 CP_MCHANGE = 10 (tracking the DAC signal setting)........................ 44 14.17.1.4 CP_MCHANGE = 11 (tracking the output signal magnitude) ............. 44 14.17.2 Specifying clock frequencies when tracking the charge pump output demand................................................................................................................. 45 14.17.3 Controlling the boost of the charge pump clock-frequency ................................ 45 14.17.3.1 CP_ANALOGUE_LVL = 01 ................................................................... 45 14.17.3.2 CP_ANALOGUE_LVL = 10 ................................................................... 45 14.18 Other Charge Pump Controls .............................................................................................. 46 14.19 Digital Signal Processing Engine .......................................................................................... 46 14.20 Variable High Pass Audio Filter (DC Cut) ............................................................................. 47 14.21 Variable High Pass Filter (Wind Noise Filtering) ................................................................. 48 14.22 DAC 5-Band Equaliser ......................................................................................................... 49 14.23 Soft Mute ............................................................................................................................ 52 14.24 Playback Noise-Gate ........................................................................................................... 53 14.25 Clock Modes ........................................................................................................................ 53 Datasheet CFR0011-120-00 Rev 4 Revision 3a 3 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.26 PLL Bypass Mode ................................................................................................................ 54 14.26.1 Normal PLL Mode (DAI Master)............................................................................ 55 14.26.2 Example calculation of the Feedback Divider setting: ......................................... 55 14.27 SRM PLL Mode (DAI Slave) .................................................................................................. 56 14.28 32 kHz PLL Mode (DAI Master) ........................................................................................... 56 14.28.1 Operating with a 2 MHz to 5 MHz MCLK .............................................................. 57 14.29 Mixed Sample Rates............................................................................................................ 57 14.30 I2C Control Interface ........................................................................................................... 57 14.31 Details of the I2C Control interface protocol ...................................................................... 58 14.32 Digital Audio Interface (DAI) ............................................................................................... 61 14.33 I2S Mode ............................................................................................................................. 63 14.34 Left Justified Mode ............................................................................................................. 63 14.35 Right Justified Mode ........................................................................................................... 63 14.36 DSP Mode............................................................................................................................ 64 14.37 Time Division Multiplexing (TDM) Mode ............................................................................ 65 14.37.1 Configuration of the Digital Audio Interface ........................................................ 66 14.38 Pop-Free and Click-Free Start-up using the System Controllers ......................................... 66 14.38.1 Level 1 System Controller (SCL1) .......................................................................... 66 14.38.2 Level 2 System Controller (SCL2) .......................................................................... 67 14.39 Power Supply – Standby Mode ........................................................................................... 67 14.39.1 Entering Standby Mode ........................................................................................ 67 14.39.2 Exiting Standby Mode........................................................................................... 67 15 Register definitions ..............................................................................................................69 15.1 Register map ....................................................................................................................... 69 15.2 Status registers ................................................................................................................... 76 15.3 System initialisation registers ............................................................................................. 84 Datasheet CFR0011-120-00 Rev 4 Revision 3a 4 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 15.4 Input gain/select filter registers.......................................................................................... 92 15.4.1 Output Gain-Filter Registers ................................................................................. 98 15.4.2 System Controller Registers ............................................................................... 108 15.4.3 Control Registers ................................................................................................ 110 15.4.4 Mixed Sample Mode Registers ........................................................................... 121 15.4.5 Configuration Registers ...................................................................................... 122 16 Package information .......................................................................................................... 140 17 Ordering information ......................................................................................................... 141 Appendix A Applications information ....................................................................................... 142 A.1 Codec initialisation ............................................................................................................ 142 A.2 Automatic ALC calibration ................................................................................................ 142 Appendix B Components ......................................................................................................... 143 B.1 Audio inputs ...................................................................................................................... 143 B.2 Microphone Bias ............................................................................................................... 144 B.3 Digital Microphone ........................................................................................................... 144 B.4 Audio Outputs ................................................................................................................... 145 B.5 Headphone Charge pump ................................................................................................. 146 B.6 Digital Interfaces ............................................................................................................... 147 B.7 Capacitor Selection ........................................................................................................... 147 Appendix C Calibration Routine ............................................................................................... 149 C.1 Troubleshooting ................................................................................................................ 149 C.2 References ........................................................................................................................ 150 C.3 Supplies ............................................................................................................................. 151 C.4 Ground .............................................................................................................................. 151 Appendix D PCB Layout Guidelines .......................................................................................... 152 D.1 Layout and Schematic support ......................................................................................... 152 D.2 General Recommendations .............................................................................................. 152 Datasheet CFR0011-120-00 Rev 4 Revision 3a 5 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Figures Figure 1: The DA7212 chip .................................................................................................................... 1 Figure 2: Block diagram showing component values for a typical application ................................... 10 Figure 3: DA7212 Ball layout ............................................................................................................... 11 Figure 4: I2C Bus Timing ...................................................................................................................... 29 Figure 5 Digital audio interface timing diagram .................................................................................. 30 Figure 6: Audio input routing and gain ranges .................................................................................... 33 Figure 7: Typical microphone application for MIC1 (MIC2 is similar) ................................................. 34 Figure 8: Digital microphone timing example ..................................................................................... 35 Figure 9: Principle of Operation of the ALC......................................................................................... 37 Figure 10: Attack, Delay and Hold parameters ................................................................................... 38 Figure 11: Analogue output signal paths and gain ranges .................................................................. 40 Figure 12: Input (clk) and Output Clocks (cp_clk and cp_clk2) at CP_FCONTROL = 010 ..................... 44 Figure 13: ADC and DAC DC blocking (Cut-off frequency setting ‘00’ to ‘11’, 16 kHz)........................ 48 Figure 14: Wind noise high-pass filter (cut-off frequency setting ‘000’ to ‘111’, 16 kHz) .................. 49 Figure 15: Equaliser filter Band 1 frequency response at FS = 48 kHz ................................................ 50 Figure 16: Equaliser filter Band 2 frequency response at FS = 48 kHz ................................................ 51 Figure 17: Equaliser filter Band 3 frequency response at FS = 48 kHz ................................................ 51 Figure 18: Equaliser filter Band 4 frequency response at FS = 48 kHz ................................................ 52 Figure 19: Equaliser filter Band 5 frequency response at FS = 48 kHz ................................................ 52 Figure 20: Schematic of the I2C control interface bus ........................................................................ 58 Figure 21 Timing of I2C START and STOP Conditions .......................................................................... 58 Figure 22: I2C Byte write (SDA signal) ................................................................................................. 59 Figure 23: Examples of the I2C Byte Read (SDA line) .......................................................................... 59 Figure 24: Examples of I2C Page Read (SDA line) ................................................................................ 59 Figure 25: I2C Page Write (SDA Line) .................................................................................................. 60 Datasheet CFR0011-120-00 Rev 4 Revision 3a 6 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Figure 26: I2C Repeated Write (SDA Line) ........................................................................................... 61 Figure 27: Master Mode (DAI_CLK_EN = 1) ........................................................................................ 61 Figure 28: Slave Mode (DAI_CLK_EN = 0) ............................................................................................ 62 Figure 29: I2S Mode ............................................................................................................................ 63 Figure 30: Left Justified Mode ............................................................................................................. 63 Figure 31: Right Justified Mode ........................................................................................................... 63 Figure 32: DSP Mode ........................................................................................................................... 64 Figure 33: TDM Example (slave mode)................................................................................................ 65 Figure 34: TDM Mode (left justified mode)......................................................................................... 65 Figure 35: DA7212 package outline drawing .................................................................................... 140 Figure 36 Micbias decoupling ............................................................................................................ 144 Figure 37 Recommended Headphone layout.................................................................................... 145 Figure 38 Charge Pump Decoupling .................................................................................................. 146 Figure 39 Charge Pump Flying Capacitor .......................................................................................... 146 Figure 40 I2C pull ups ........................................................................................................................ 147 Figure 41 Reference Capacitors ........................................................................................................ 150 Figure 42 Power Supply Decoupling .................................................................................................. 151 Figure 43 DA7212 Example Layout.................................................................................................... 152 Tables Table 1: Pin descriptions ..................................................................................................................... 12 Table 2: Pin type definition ................................................................................................................. 13 Table 3: Absolute maximum ratings.................................................................................................... 14 Table 4: Recommended operating conditions .................................................................................... 15 Table 5: Power consumption............................................................................................................... 16 Table 6: Reference voltage generation ............................................................................................... 16 Table 7: Analogue to Digital Converter (ADC) ..................................................................................... 17 Datasheet CFR0011-120-00 Rev 4 Revision 3a 7 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 8: Microphone bias .................................................................................................................... 18 Table 9: Input mixing units .................................................................................................................. 19 Table 10: ADC/DAC Digital high-pass filter cut-off frequencies in music mode ................................. 20 Table 11: ADC/DAC Digital high-pass filter cut-off frequencies in voice mode .................................. 20 Table 12: DAC 5-Band equaliser frequencies ...................................................................................... 21 Table 13: Beep generator .................................................................................................................... 22 Table 14: Digital to Analogue Converter (DAC) ................................................................................... 23 Table 15: Class AB lineout amplifier / speaker .................................................................................... 24 Table 16: True Ground charge pump .................................................................................................. 25 Table 17: True Ground headphone amplifier ...................................................................................... 26 Table 18: MCLK Input .......................................................................................................................... 27 Table 19: PLL Mode ............................................................................................................................. 27 Table 20: Bypass Mode ....................................................................................................................... 28 Table 21: I/O Characteristics ............................................................................................................... 28 Table 22: I2C Control bus .................................................................................................................... 29 Table 23: Digital Audio Interface Timing (I2S/DSP in Master/Slave Mode) ........................................ 30 Table 24 Codec start-up times ............................................................................................................ 31 Table 25: DTMF Keypad frequencies ................................................................................................... 39 Table 26: Charge pump output voltage control .................................................................................. 42 Table 27: CP_THRESH_VDD2 Settings in DAC_VOL mode (CP_MCHANGE = 10) ................................ 43 Table 28: CP_THRESH_VDD2 Settings in Signal Size mode (CP_MCHANGE = 11)............................... 43 Table 29: Charge pump current load control ...................................................................................... 46 Table 30: ADC/DAC Digital High Pass Filter specifications in Audio Mode ......................................... 47 Table 31: Wind noise high-pass filter specifications ........................................................................... 48 Table 32: DAC 5-Band Equaliser Turnover/Centre Frequencies ......................................................... 50 Table 33: Sample rate control register and corresponding system clock frequency .......................... 54 Datasheet CFR0011-120-00 Rev 4 Revision 3a 8 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 34: PLL Input Divider .................................................................................................................. 55 Table 35: Example PLL configurations ................................................................................................. 56 Table 36: Ordering information......................................................................................................... 141 Table 37: Audio inputs....................................................................................................................... 143 Table 38: Microphone bias ................................................................................................................ 144 Table 39: Digital microphones ........................................................................................................... 144 Table 40: Headphone outputs ........................................................................................................... 145 Table 41: Speaker outputs................................................................................................................. 145 Table 42: Headphone charge pump .................................................................................................. 146 Table 43: Digital interfaces – I2C ....................................................................................................... 147 Table 44: Offset calibration, MIC1_P and MIC2_P single ended, slave mode .................................. 149 Table 45: Digital interfaces - I2S ........................................................................................................ 150 Table 46: References ......................................................................................................................... 150 Table 47: Power supplies................................................................................................................... 151 Table 48: Ground ............................................................................................................................... 151 1 Terms and definitions ADC ALC DAC DAI DTMF I2C I2S PLL PSSR SNR TDM THD+N Datasheet CFR0011-120-00 Rev 4 Analogue Digital Converter Automatic Level Control Digital Audio Converter Digital Audio Interface Dual Tone Multi-Frequency Inter-Integrated Circuit interface Inter-IC Sound Phase Locked Loop Power Supply Rejection Ratio Signal to Noise Ratio Time Division multiplexing Total Harmonic Distortion plus Noise Revision 3a 9 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 2 Block diagram AUX_L MICBIAS1 1µF AUX_L _AMP + MIC BIAS1 MIC1_P/ DMICCLK GND_SENSE DAC_L HP_L_ AMP MIC1_N/ DMICIN AUX Input MIC_1 _AMP + MIXIN_L Headphones ADC DIGITAL FILTERS DAC DIGITAL FILTERS Wind Noise Filtering, Automatic Level Control (ALC) Digital Mixer, Digital Volume, 5 Band Equaliser, Noise Gate VDD_MIC MIC2_P MIC_2 _AMP + MIXIN_R HP_L ADC_L HP_R_ AMP HP_R HPCSP DA7212 HPCFP 1uF HPCFN Charge Pump ADC_R 1uF GND_CP HPCSN 1uF MIC2_N + DAC_R VDD_SP MICBIAS2 SP_P MIC BIAS2 LINE_ AMP + SP_N 1µF AUX_R_ AMP VMID VREF DACREF VDIG BIAS VDD_IO VDD_A LDO GND_A WCLK DATIN DIGITAL AUDIO INTERFACE (DAI) BCLK BEEP GENERATOR DATOUT CONTROL INTERFACE SCL MCLK PLL SDA AUX_R Figure 2: Block diagram showing component values for a typical application ADC Digital Filter Control (ALC) Analogue filter block incorporating wind noise filtering and Automatic Level DAC Digital Filter Digital filter block incorporating digital mixing, digital volume control, a 5-band equaliser and a noise gate Beep Generator The Beep Generator block has two sine wave generators, each of which can be independently controlled. Output frequency is controllable in 10 Hz step sizes, and output gain is controllable in 3 dB steps from 0 dB to 45 dB. The Beep Generator block can also output standard DTMF keypad frequencies (see Table 25). Datasheet CFR0011-120-00 Rev 4 Revision 3a 10 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 3 Pinout 1 A HPCSP B C 2 3 HP_L HPCSN 2 9 VMID DATOUT 6 10 GND_A SDA 9 10 13 14 SP_N VDD_MIC AUX_L 12 16 MIC1_N AUX_R 13 14 17 MICBIAS2 MIC2_N VDIG 11 15 MICBIAS1 SP_P VDD_IO 8 12 MCLK SCL 7 11 VDD_SP VREF WCLK 5 8 DACREF DATIN 4 7 VDD_A BCLK 3 6 HP_R HPCFN HPCFP 1 5 GND_ SENSE GND_CP D 4 MIC1_P MIC2_P 15 16 17 KEY Sensitive Analogue Low Power (up to 100mA) Quiet Ground Noisy Digital Medium Power (up to 500mA) Noisy Ground View from above “Live Bug” Figure 3: DA7212 Ball layout Datasheet CFR0011-120-00 Rev 4 Revision 3a 11 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 1: Pin descriptions Pin Name Bump/Pin Function Alternate Function Class Audio Inputs MIC1_P C17 Differential mic. input 1 (pos) / Single-ended mic. input 1 (left) Digital mic. clock (DMICCLK) AI/DO MIC1_N B16 Differential mic. input 1 (neg) / Single-ended mic. input 2 (left) Digital Mic. data (DMICIN) AI/DI MIC2_P D16 Differential mic. input 2 (pos) / Single-ended mic. input 1 (right) AI MIC2_N C15 Differential mic. input 2 (neg) / Single-ended mic. input 2 (right) AI AUX_L C13 Single-ended auxiliary input left AI AUX_R D14 Single-ended auxiliary input right AI MICBIAS1 A15 Microphone bias output 1 AO MICBIAS2 A17 Microphone bias output 2 AO Audio Outputs HP_L A3 True-ground headphone output left AO HP_R A5 True-ground headphone output right AO SP_P B12 Differential speaker output (pos) AO SP_N A13 Differential speaker output (neg) AO Audio Charge pump HPCSP A1 Charge pump reservoir capacitor (pos) AIO HPCSN C1 Charge pump reservoir capacitor (neg) AIO HPCFP D2 Charge pump flyback capacitor (pos) AIO HPCFN C3 Charge pump flyback capacitor (neg) AIO Digital Interfaces SDA C9 I2C bidirectional data DIO SCL D8 I2C clock input DI DATIN C5 DAI data input DIO DATOUT C7 DAI data output DIO BCLK D4 DAI bit clock DIO WCLK D6 DAI word clock (L/R select) DIO MCLK C11 Master clock DI References DACREF A7 Audio DAC reference capacitor AIO VMID A9 Audio mid-rail reference capacitor AIO GND_SENSE B4 Ground reference for headphone output VREF B8 Bandgap reference capacitor Datasheet CFR0011-120-00 Rev 4 Revision 3a 12 of 154 AI AIO 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Pin Name Bump/Pin Function Alternate Function Class Supplies VDD_A B6 Supply for analogue circuits PS VDD_IO D10 Supply for digital interfaces PS VDD_SP A11 Supply for speaker driver PS VDD_MIC B14 Supply for microphone bias circuits PS VDIG D12 Supply for digital circuits (LDO Output) PS Grounds GND_A B10 Analogue ground PG GND_CP B2 Charge pump/digital ground PG Table 2: Pin type definition Pin type Description Pin type Description DI Digital Input AI Analogue Input DO Digital Output AO Analogue Output DIO Digital Input/Output AIO Analogue Input/Output DIOD Digital Input/Output open drain PU Fixed pull-up resistor SPU Switchable pull-up resistor PD Fixed pull-down resistor SPD Switchable pull-down resistor Datasheet CFR0011-120-00 Rev 4 Revision 3a 13 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 4 Absolute maximum ratings Table 3: Absolute maximum ratings Symbol Ta Parameter Test Conditions Unit +165 °C Operating Temperature -40 +85 °C -0.3 6.0 V -0.3 2.75 V -0.3 5.5 V -0.3 VDD_IO + 0.3 Supply Voltages Digital Interface Signals Package Thermal Resistance ESD Susceptibility Note 1 Max -65 VDD_IO VDD_MIC SDA SCL BCLK WCLK DATIN DATOUT Typ Storage Temperature VDD_SP VDD_A Min 60 Human body model °C/W 2 kV Stresses beyond those listed under ‘Absolute maximum ratings’ may cause permanent damage to the device. These are stress ratings only, so functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Datasheet CFR0011-120-00 Rev 4 Revision 3a 14 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 5 Recommended operating conditions Table 4: Recommended operating conditions Symbol Parameter Test Conditions Min Typ Max Unit Operating temperature -40 +85 °C Supply Voltages 1.6 2.65 V VDD_IO 1.5 3.6 V VDD_MIC 1.8 3.6 V VDD_SP 0.95 5.25 V Ta VDD_A Note 2 Within the specified limits, a life time of 10 years is guaranteed Note 3 All Voltages are referenced to VSS unless otherwise stated Note 4 Currents flowing into DA7212 are deemed positive. Currents flowing out are deemed negative Note 5 All parameters are valid over the recommended temperature range and power supply range unless otherwise noted. Datasheet CFR0011-120-00 Rev 4 Revision 3a 15 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 6 Electrical characteristics Table 5: Power consumption Power Consumption Unit 5 µA DAC_L/R to LINE, 10 kΩ load 2.2 mW Digital playback to Headphone, no load DAC_L/R to HP_L/R, quiescent 3.1 mW Digital playback to Headphone, with load DAC_L/R to HP_L/R, 16 Ω load, 0.1 mW at 0 dBFS 6.9 mW AUX_L/R to LINE, 10 kΩ load 2.0 mW AUX_L/R to HP_L/R, quiescent 2.6 mW AUX_L/R to HP_L/R, 16 Ω load, 0.1 mW at 0 dBFS 6.7 mW MIC_1/2 to ADC_L/R 2.1 mW Microphone stereo record and digital playback to Headphone, no load MIC_1/2 to ADC_L/R and DAC_L/R to HP_L/R, quiescent 4.8 mW Microphone stereo record and digital playback to Headphone, with load MIC_1/2 to ADC_L/R and DAC_L/R to HP_L/R, 16 Ω load, 0.1 mW at 0 dBFS 8.9 mW MIC_1 to ADC_R, 8 kHz, quiescent, optimised clocking and bias 0.65 mW Operating Mode Conditions (Note 6) Powerdown mode Digital playback to Lineout Analogue bypass to Lineout Analogue bypass to Headphone, no load Analogue bypass to Headphone, with load Microphone stereo record Ultra-low power microphone mono record Note 6 VDD_A=VDD_SP=VDD_IO=1.8 V, Ta=25°C, Fs=48 kHz, Charge pump signal-size mode, 0x95 = 0x06 Table 6: Reference voltage generation Symbol Parameter VMID Audio mid-rail voltage CVMID VMID decoupling capacitor Test Conditions Min Typ Max Unit 0.45 × VDD_A V 1.0 µF 0.9 × VDD_A V DACREF decoupling capacitor 1.0 µF VBG Bandgap voltage 1.2 V CVBG Bandgap decoupling capacitor 1.0 µF DACREF CDACREF Audio DAC/ADC reference voltage Datasheet CFR0011-120-00 Rev 4 Revision 3a 16 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 7 Parametric specifications Table 7: Analogue to Digital Converter (ADC) Symbol VMAX SNR (Note 7) THD+N (Note 8) Parameter Test Conditions Full-scale input signal Digital output level = 0 dBFS 1.6 × VDD_A VPP Signal to Noise Ratio A-weighted no input selected 90 dB -1 dBFS 44.1 kHz slave mode -85 dB -1 dBFS 32 kHz PLL mode -80 dB Analog input level = 0 dBFS -85 dB 90 dB Total Harmonic Distortion plus Noise In-band Spurious Min Channel separation BPASS Pass band BSTOP Stop band PSRR (Note 9) with respect to VDD_A Fs  48 kHz Fs = 88.2/96 kHz Pass band Ripple Voice mode Music mode Stop band Attenuation Voice mode Music mode Group delay Voice mode Music mode Fs = 88.2/96 kHz Group delay mismatch Between left and right channels Power Supply Rejection Ratio 20Hz – 2 kHz 20 kHz Typ 0.56*Fs Max Unit 0.45*Fs Hz 7*Fs 3.5*Fs Hz ±0.3 ±0.1 dB 70 55 dB 4.3/Fs 18/Fs 9/Fs 600 µs 2 µs 70 50 dB Note 7 SNR (Signal-to-Noise Ratio) is a ratio of the full-scale output signal level to the noise level with no signal applied Note 8 THD+N (Total Harmonic Distortion plus Noise) is a ratio of the level of the harmonics and noise to the output signal Note 9 PSRR (Power Supply Rejection Ratio) is a measure of the attenuation of a signal on the supply to the signal at the output Datasheet CFR0011-120-00 Rev 4 Revision 3a 17 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 8: Microphone bias MICBIAS1 and MICBIAS2 Symbol VMICBIAS IBIAS PSRR with respect to VDD_MIC VNOISE Parameter Bias Voltage Maximum Current Power Supply Rejection Ratio Output Noise Voltage Capacitive Load Datasheet CFR0011-120-00 Rev 4 Test Conditions No load, VDD_MIC > VMICBIAS + 200 mV Min Typ Max 1.52 1.57 1.62 2.18 2.25 2.32 2.41 2.48 2.56 2.91 3.00 3.10 V Voltage drop < 50 mV 20Hz – 200 Hz >2 kHz Unit 2 70 50 mA dB VMICBIAS ≤ 2.2 V 5 µVRMS IBIAS < 100 µA 100 µA < IBIAS < 2 mA 100 200 pF Revision 3a 18 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 9: Input mixing units (MIC1_P/MIC1_N/MIC2_P/MIC2_N/AUX_L/AUX_R ) to ADC_L/ADC_R Symbol VMAX Parameter Test Conditions Full-scale input signal Single-ended Differential MIC_1/2_AMP = AUX_L/R_AMP = MIXIN_L/R = 0dB RIN Input resistance CIN Input capacitance Amplitude ripple PSRR with respect to VDD_A MIC, single-ended AUX Min Typ Max Unit 0.8 × VDD_A 1.6 × VDD_A VPP 12 6 15 18 40 1 kΩ pF 20Hz to 20 kHz -0.5 +0.5 dB Programmable gain MIC_1_AMP and MIC_2_AMP AUX_L_AMP and AUX_R_AMP MIXIN_L and MIXIN_R -6 -54 -4.5 36 15 18 dB Programmable gain step size MIC_1_AMP and MIC_2_AMP AUX_L_AMP and AUX_R_AMP MIXIN_L and MIXIN_R 6 1.5 1.5 dB Absolute gain accuracy 0 dB @ 1 kHz -1.0 +1.0 dB Left/Right gain mismatch 20 Hz to 20 kHz -0.1 +0.1 dB Gain step error 20 Hz to 20 kHz -0.1 +0.1 dB Input noise level Inputs connected to GND, A-weighted, input-referred, measured @ ADC output MIC_1/2_AMP = 24 dB AUX_L/R_AMP = 15 dB Power supply rejection ratio Datasheet CFR0011-120-00 Rev 4 µVRMS 5 6.5 Single-ended input 20Hz to 2 kHz 20 kHz 70 50 dB Differential input 20Hz to 2 kHz 20 kHz 90 70 dB Revision 3a 19 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 8 Digital signal processing Table 10: ADC/DAC Digital high-pass filter cut-off frequencies in music mode Sampling Frequency (kHz) Music Mode – Cut-Off Frequency (-3 dB) in Hz at ADC_AUDIO_HPF_CORNER / DAC_AUDIO_HPF_CORNER Register Settings 00 01 10 11 8 0.3 0.7 1.3 2.7 11.025 0.4 0.9 1.8 3.7 12 0.5 1 2 4 16 0.7 1.3 2.7 5.3 24 1 2 4 8 32 1.3 2.7 5.3 10.7 44.1 1.8 3.7 7.3 14.7 48 2 4 8 16 88.2 3.6 7.4 14.6 29.4 96 4 8 16 32 Table 11: ADC/DAC Digital high-pass filter cut-off frequencies in voice mode Sampling Frequency (kHz) Voice Mode – Cut-Off Frequency (-3 dB) in Hz at ADC_VOICE_HPF_CORNER / DAC_VOICE_HPF_CORNER Register Settings 000 001 010 011 100 101 110 111 8 2.66 25 50 100 150 200 300 400 11.025 3.5 35 69 138 207 275 415 553 12 4 37.5 75 150 225 300 450 600 16 5 50 100 200 300 400 600 800 Datasheet CFR0011-120-00 Rev 4 Revision 3a 20 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 12: DAC 5-Band equaliser frequencies Centre/Cutoff frequency of 5-Band Equaliser (Hz) Sampling Frequency (kHz) Band 1 Cutoff (Note 10) Band 2 Centre Band 3 Centre Band 4 Centre Band 5 Cutoff (Note 10) 8 21 85 563 1151 2909 11.025 29 117 776 2137 4009 12 31 128 845 2326 4364 16 41 90 441 2128 5840 22.05 56 124 607 2933 8048 24 61 135 664 3192 8759 32 58 95 418 1731 6374 44.1 80 132 577 2385 8784 48 87 143 628 2596 9560 88.2 N/A N/A N/A N/A N/A 96 N/A N/A N/A N/A N/A Note 10 For equaliser bands 1 and 5 the cut-off frequency depends on the gain setting. The figures quoted in this table refer to the –1 dB point with the band gain set to –3 dB Datasheet CFR0011-120-00 Rev 4 Revision 3a 21 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 13: Beep generator Symbol Parameter Test Conditions Single-tone frequency Min 10 Max Unit 12000 Hz Single-tone frequency step 10 Hz Dual-tone modulation frequency A 697 770 852 941 Hz Dual-tone modulation frequency B 1209 1336 1477 1633 Hz Output signal level -45 Output signal step size TON,TOFF Typ 3 On/off pulse duration On/off pulse step size On/off pulse repeat Datasheet CFR0011-120-00 Rev 4 0 10 dBFS dB 2000 ms TON/OFF=10 – 200ms TON/OFF=200 – 2000ms 10 50 ms continuous mode 1,2,4,8,16,32 ∞ cycles Revision 3a 22 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 9 Audio outputs Table 14: Digital to Analogue Converter (DAC) Symbol Parameter VMAX Full-scale output signal SNR Signal to Noise Ratio THD+N Total Harmonic Distortion Plus Noise Test Conditions Min Pass band BSTOP Stop band PSRR with respect to VDD_A Datasheet CFR0011-120-00 Rev 4 Unit 1.6×VDD_A VPP A-weighted 100 dB -1 dBFS 44.1 kHz slave mode -90 dB -1 dBFS 32 kHz PLL mode -80 dB 90 dB Fs  48 kHz Fs = 88.2/96 kHz Pass band Ripple Voice mode Music mode Stop band Attenuation Voice mode Music mode Group delay Max Digital input level = 0 dBFS Channel separation BPASS Typ 0.56×Fs 0.45×Fs kHz 7×Fs 3.5×Fs kHz ±0.15 ±0.1 dB 70 55 Voice mode Music mode Fs = 88.2/96 kHz dB 4.8/Fs 18.5/Fs 9/Fs 650 µs Group delay variation 20Hz to 20 kHz 1 µs Group delay mismatch Between left and right channels 2 µs Power Supply Rejection Ratio 20Hz to 2 kHz 20 kHz Revision 3a 23 of 154 70 50 dB 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 15: Class AB lineout amplifier / speaker From DAC_L/DAC_R to (SP_P, SP_N) Symbol Parameter Test Conditions VMAX Full-scale output signal No load 1.8×VD D_SP VPP VDD_SP = 1.2 V THD < 10 % RLOAD = 8 Ω, 1 kHz 65 mW RMS VDD_SP = 1.5 V THD < 10 % RLOAD = 8 Ω, 1 kHz 115 mW RMS VDD_SP = 3.7 V THD < 10 % RLOAD = 8 Ω, 1 kHz 745 mW RMS VDD_SP = 5.0 V THD < 10 % RLOAD = 8 Ω, 1 kHz 1200 mW RMS PMAX Maximum output power Min 6.4 RLOAD Typ Amplitude ripple Ω µH pF ±0.5 dB 20 20k Hz 20Hz to 20 kHz -0.5 0.5 dB -48 +15 dB Programmable gain Mute attenuation Programmable gain step size Absolute gain accuracy Unit 1 200 8 Load impedance Frequency response Max 100 dB 1 dB 0 dB @ 1 kHz -0.8 +0.8 dB Gain step error 20 Hz to 20 kHz -0.1 +0.1 dB SNR Signal to noise ratio A-weighted gain = 0 dB VDD_SP = 1.6 V 96.5 dB VNOISE Output Noise Level Non A-weighted Gain ≤ -15 dB 20Hz to 20 kHz 6 µV VDD_SP = 1.6 V -1 dBFS 44.1 kHz slave mode RLOAD > 2 kΩ -86 dB VDD_SP = 1.6 V -1 dBFS 32 kHz PLL mode RLOAD > 2 kΩ -80 dB THD+N PSRR with respect to VDD_SP Total Harmonic Distortion Plus Noise Power Supply Rejection Ratio Datasheet CFR0011-120-00 Rev 4 20 Hz to 2 kHz 20 kHz Revision 3a 24 of 154 90 70 dB 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 16: True Ground charge pump HPCSP and HPCSN Symbol Parameter Test Conditions Min Typ Max Unit VDDCSP Positive rail output CP_MOD = 11 CP_MOD = 10 VDD_A VDD_A / 2 V VDDCSN Negative rail output CP_MOD = 11 CP_MOD = 10 -VDD_A -(VDD_A / 2) V Flyback capacitor One capacitor 1.0 µF Reservoir capacitors Two capacitors 1.0 µF Datasheet CFR0011-120-00 Rev 4 Revision 3a 25 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 17: True Ground headphone amplifier From DAC_L/DAC_R to (HP_L/HP_R) Symbol Parameter Test Conditions VMAX Full-scale Output Signal No load DC output offset PMAX RLOAD LLOAD CLOAD Maximum power per channel HP Gain < -30 dB PSRR with respect to VDD_A Datasheet CFR0011-120-00 Rev 4 Unit VPP µV VDD_A = 1.6 V THD < 0.1 % RLOAD=16 Ω, 1 kHz L = 23 R = 23 mW RMS VDD_A = 1.8 V THD < 0.1 % RLOAD=16 Ω, 1 kHz L = 29 R = 29 mW RMS VDD_A = 2.5 V THD < 0.1 % RLOAD=16 Ω, 1 kHz L = 67 R = 67 mW RMS 400 500 Ω µH pF 16 ±0.5 dB 20 20k Hz 20Hz to 20 kHz -0.5 +0.5 dB -56 +6 dB Programmable Gain THD+N Max 100 Load Impedance Amplitude Ripple VNOISE Typ 1.6×VDD_A 13 Frequency Response SNR Min Mute Attenuation 70 dB Programmable Gain Step Size 1.0 dB Absolute Gain Accuracy 0 dB @ 1 kHz -0.8 +0.8 dB Input Gain L/R-Mismatch 20Hz to 20 kHz -0.1 +0.1 dB Input Gain Step Error 20Hz to 20 kHz -0.1 +0.1 dB Signal to Noise Ratio A-weighted gain = 0 dB VDD_A = 2.5 V VDD_A = 1.8 V Output Noise Level 20 to 20 kHz, non A-weighted gain < -20 dB Total Harmonic Distortion Plus Noise VDD_A = 1.6 V -5 dBFS RLOAD=16 Ω Power Supply Rejection Ratio 20Hz to 2 kHz 20 kHz Revision 3a 26 of 154 dB 100 98 2.5 -87 70 50 µVrms dB dB 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 11 Clock generation Table 18: MCLK Input Symbol Parameter Test Conditions Min Typ Input Amplitude MCLK squarer enabled MCLK squarer disabled 0.3 0.9×VDD_IO Input Impedance DC impedance > 10 MΩ 300 0.5 1 Max Unit VDD_IO VDD_IO V 2 Ω pF 12 Phase Locked Loop (PLL) Table 19: PLL Mode Symbol JC JA Parameter MCLK Input Jitter Test Conditions Min Typ Cycle jitter (rms) Absolute jitter (rms) Max Unit 50 100 ps ps FIN Input frequency Normal mode 32 kHz mode SRM Tracking Range DAI slave mode WCLK frequency variation SRM Tracking Rate DAI slave mode WCLK drift rate 2 (Note 11) -4 5 - 50 32.768 50 MHz kHz 4 % 50 ppm/s Note 11 See section 32 kHz PLL Mode (DAI Master) on page 56 for further details on using an MCLK frequency between 2 MHz and 5 MHz Datasheet CFR0011-120-00 Rev 4 Revision 3a 27 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 20: Bypass Mode Symbol Parameter JC JA Input Jitter FIN Input frequency Test Conditions Min Typ Cycle jitter (rms) Absolute jitter (rms) Sample frequency: 11.025, 22.05, 44.1, 88.2 kHz 8, 12, 16, 24, 32, 48, 96 kHz Max Unit TBD TBD ps 11.2896 12.288 ps MHz 13 Digital interfaces Table 21: I/O Characteristics Symbol Parameter VIH SCL, SDA, Input High Voltage VIL SCL, SDA, Input Low Voltage VIH MCLK, BCLK, WCLK, DATIN, DATOUT Input High Voltage VIL MCLK, BCLK, WCLK, DATIN, DATOUT Input Low Voltage VOL @3mA Test Conditions CFR0011-120-00 Rev 4 Typ Max 0.7*VDD_IO 0.7*VDD_IO Revision 3a 28 of 154 Unit V 0.3*VDD_IO SDA Output Low Voltage Datasheet Min V V 0.3*VDD_IO V 0.24 V 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec CLKL CLKH SCL STH DST DHT TSS SDA Figure 4: I2C Bus Timing Table 22: I2C Control bus Symbol Test Conditions (Note 12) Parameter Bus free time STOP to START Min Typ Max 500 Bus line capacitive load Unit ns 150 pF 1000 kHz Standard/Fast Mode SCL clock frequency 0 Start condition setup time 260 ns STH Start condition hold time 260 ns CLKL SCL low time 500 ns CLKH SCL high time 260 ns SCL rise/fall time Input requirement 1000 ns SDA rise/fall time Input requirement 300 ns DST SDA setup time 50 ns DHT SDA hold time 0 ns TSS Stop condition setup time 260 ns High-Speed Mode SCL clock frequency 0 3400 kHz Start condition setup time 160 ns STH Start condition hold time 160 ns CLKL SCL low time 160 ns CLKH SCL high time 60 ns SCL rise/fall time Datasheet CFR0011-120-00 Rev 4 Input requirement Revision 3a 29 of 154 160 ns 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec SDA rise/fall time Input requirement 160 ns DST SDA setup time 10 ns DHT SDA hold time 0 ns TSS Stop condition setup time 160 ns Note 12 VDD_IO = 1.8 V T WCLK tdCW tf tsW thW thC tr tlC BCLK tdWD tdCD DATOUT tsD thD DATIN Figure 5 Digital audio interface timing diagram Note 13 Diagram shown is valid for all modes except DSP. For DSP mode the BCLK signal is inverted Table 23: Digital Audio Interface Timing (I2S/DSP in Master/Slave Mode) Symbol Parameter Input impedance Test Conditions (Note 14) Min DC impedance > 10MΩ 300 1.0 Typ Max Unit 2.5 Ω pF T BCLK period 75 ns tr BCLK rise time 8 ns tf BLCK fall time 8 ns thC BCLK high period 40 % 60 % T tlC BCLK low period 40 % 60 % T tdCW BCLK to WCLK delay -30 % +30 % T tdCD BCLK to DATOUT delay -30 % +30 % T thW WCLK high time Datasheet CFR0011-120-00 Rev 4 DSP mode 100 % Revision 3a 30 of 154 T 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec tlW WCLK low time Non-DSP mode Word length (Note 15) T DSP mode 100 % T Non-DSP mode Word length (Note 16) T tsW WCLK setup time Slave mode 7 ns thW WCLK hold time Slave mode 2 ns tsD DATIN setup time 7 ns thD DATIN hold time 2 ns tdWD DATOUT to WCLK delay DATOUT is synchronised to BCLK Note 14 VDD_IO = 1.8 V Note 15 WCLK must be high for at least the word length number of BCLK periods Note 16 WCLK must be low for at least the word length number of BCLK periods 13.1 Codec Start-Up Time After the audio system controller has been enabled using SYSTEM_MODES_INPUT and SYSTEM_MODES_OUTPUT, the startup times for the various codec paths are as specified below: Table 24 Codec start-up times Source Output Comment VMID VMID > 90 % of final value 1µF capacitor Any analogue input or DAC_L/R HP_L HP_R PLL bypass or PLL normal mode Any analogue input or DAC_L/R HP_L HP_R Any analogue input or DAC_L/R Min Typ Max Unit 25 ms 200 ms PLL SRM or PLL 32 kHz mode 500 ms SP_P SP_N PLL bypass or PLL normal mode 250 ms Any analogue input ADC_L ADC_R PLL bypass or PLL normal mode 200 ms Any analogue input ADC_L ADC_R PLL SRM or PLL 32 kHz mode 600 ms Datasheet CFR0011-120-00 Rev 4 Revision 3a 31 of 154 200 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14 Functional description 14.1 General description DA7212 is an ultra-low-power audio CODEC with true ground headphone drivers, mixing capability, and digital audio enhancement. It offers HiFi audio quality with class-leading power consumption for portable media and embedded applications. Featuring a high efficiency headphone amplifier and minimum supply voltage of 1.6 V, the ultra-low 3.1 mW quiescent power consumption extends music playback time for battery-operated equipment. Control and data interfaces are supplied from a dedicated VDD_IO rail. For compatibility with higher I/O levels, an extended voltage range up to 3.6 V can be selected. The integrated PLL uses a fractional-N architecture that supports frequencies from 2 MHz to 50 MHz. Standard mobile phone/USB system clock frequencies are supported, and audio data synchronisation is supported even when no master clock is available. The DA7212 has a stereo pair of single-ended line inputs as well as two microphone inputs, each of which can be configured as single-ended or differential. Both line and microphone signals can be routed to the ADC or directly to the output mixers via a bypass path. In addition, the DA7212 supports both single and dual-channel digital microphone inputs by routing the digital signals directly to the ADC digital filters. Input and output mixers with stereo-to-mono conversion also support mono configurations such as single speaker outputs. Three output drivers are available in the output stage of the DA7212. A stereo true-ground amplifier directly drives standard 3-wire 16 ohm headphones while a differential mono speaker amplifer is capable of driving 1.2W into 8 ohms. Audio enhancement functions are performed digitally including programmable high-pass filtering, 5band EQ, noise-gate and an AGC with configurable attack and decay parameters. The multislot I2S/PCM Digital Audio Interface (DAI) supports all common sample rates between 8 kHz and 96 kHz in master or slave modes. The CODEC register space can be accessed via the I2C interface of DA7212 on the default 7-bit address 0x1A. DA7212 implements a unique Smart Controller that enables easy configuration of the Codec for different application scenarios, thereby reducing the number of register writes needed for each case. The Smart Controller runs automatically once enabled, and is optimised to allow pop-free and click-free power-up and power-down operation. 14.2 Input Signal Chain The DA7212 has a stereo pair of single-ended line inputs as well as two microphone inputs that can each be configured as single-ended or differential. Both line and microphone signals can be routed to the ADC or directly to the output mixers via a bypass path. In addition, the DA7212 supports both single and dual channel digital microphone inputs by routing the digital signals directly to the ADC digital filters. The input routing paths and input amplifier gain ranges are illustrated in Figure 5. Datasheet CFR0011-120-00 Rev 4 Revision 3a 32 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec -54dB to +15dB in 1.5dB steps AUX_L_AMP AUX_L MIC1_P / -6dB to +36dB in 6dB steps MIC_1_AMP DMICCLK to ADC_L MIXIN_L -4.5dB to +18dB in 1.5dB steps MIC1_N / DMICIN to ADC filters MICBIAS1 MICBIAS2 MIC2_P MIC2_N MIC_2_AMP -6dB to +36dB in 6dB steps to ADC_R MIXIN_R -4.5dB to +18dB in 1.5dB steps AUX_R AUX_R_AMP -54dB to +15dB in 1.5dB steps from PLL Figure 6: Audio input routing and gain ranges 14.3 Microphone Inputs The DA7212 includes two pairs of analogue microphone inputs that can be connected in three ways: ● fully differential mode for improved common mode noise rejection ● single ended or pseudo-differential mode by connecting MIC1_N or MIC2_N to GND (see Figure 7). The microphone source is specified using MIC_1_AMP_IN_SEL and MIC_2_AMP_IN_SEL ● single ended or pseudo-differential mode by connecting MIC1_P or MIC2_P to GND (see Figure 7). The microphone source is specified using MIC_1_AMP_IN_SEL and MIC_2_AMP_IN_SEL The microphone PGAs are enabled by the MIC_1_AMP_EN / MIC_2_AMP_EN controls and can be muted via MIC_1_AMP_MUTE_EN / MIC_2_AMP_MUTE_EN. For maximum flexibility, each microphone channel includes an individual gain setting (MIC_1_AMP_GAIN / MIC_2_AMP_GAIN controls) that has a range of -6 dB to +36 dB in 6 dB steps. The currently active gain setting of each microphone is stored in MIC_1_GAIN_STATUS and MIC_2_GAIN_STATUS. A maximum analogue gain from microphone to ADC input of +54 dB with a resolution of 1.5 dB can be selected. Datasheet CFR0011-120-00 Rev 4 Revision 3a 33 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec MICBIAS1 MICBIAS1 MICBIAS1 MICBIAS2 MIC1_P MIC1_P MIC1_P MIC1_N MIC1_N MIC1_N (a) Differential (b) Pseudo-differential (c) Single-ended (c) Single-ended Figure 7: Typical microphone application for MIC1 (MIC2 is similar) Standard electret microphones can be supplied from an embedded microphone bias regulator, enabled using the MICBIAS2_EN control bit. Two separate outputs are available on either the MICBIAS1 pin or the MICBIAS2 pin. These are enabled using the MICBIAS2_EN and MICBIAS1_EN controls. The voltage on the MICBIAS pins is set to 1.6 V, 2.2 V, 2.5 V or 3.0 V by the MICBIAS2_LEVEL and MICBIAS1_LEVEL controls. The microphone bias generates an ultralow-noise voltage to feed several electret microphones with up to 2mA. 14.4 Digital microphones DA7212 implements a digital microphone interface via a clock output (shared pin with MIC1_P) and a serial data input (shared pin with MIC1_N). The serial data is a sigma delta sampled bitstream. Modulators up to 3rd Order are supported. MICBIAS1 can be used to power the digital microphone, but it must be enabled because it is MICBIAS1 that supplies the digital microphone pins. The clock and data pins are shared with two analogue microphone inputs. This allows DA7212 to record from single or dual channel digital microphones, or from conventional mono/stereo analogue microphones. The clock frequency can be selected to be either 1.5 MHz or 3 MHz by using DMIC_CLK_RATE control. Single channel and dual channel digital microphone modules are supported. The dual channel modules change the output data on both the rising and the falling edges of the clock, as illustrated in Figure 7. In this case DMIC_SAMPLEPHASE must be set to zero in order to enable the sample detection at the edges of the clock. Each DMIC input is enabled via DMIC_L_EN / DMIC_R_EN and is associated with a clock edge via DMIC_DATA_SEL control. A digital microphone requires a decimation filter to reconstruct the signal at the required sampling rate. The ADC decimation filters are re-used for this purpose, so either digital microphones or analogue sources may be used for recording at any one time. Datasheet CFR0011-120-00 Rev 4 Revision 3a 34 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Falling edge to valid data on 1 Rising edge to valid data on 2 Falling edge to high impedance on 2 Rising edge to high impedance on 1 DMICCLK Output 1 to DMIC1 DATA VALID DATA HIGH Z DATA VALID Output 2 to DMIC1 DATA HIGH Z DATA VALID DATA HIGH Z Figure 8: Digital microphone timing example 14.5 Auxiliary inputs Standard analogue sources (for example FM radio) are supported via the AUX stereo line inputs. Auxiliary inputs are enabled by AUX_L_AMP_EN / AUX_R_AMP_EN. They can be summed with each other, and with the microphone paths, which enables flexible audio mixing. Each channel includes individual gain settings in 1.5 dB steps from -54 dB to +15 dB using AUX_L_AMP_GAIN and AUX_R_AMP_GAIN. The auxiliary amplifiers can be muted by asserting AUX_L_AMP_MUTE_EN and AUX_R_AMP_MUTE_EN. Changes in gain can be synchronised with zero-crossing by asserting the AUX_L_AMP_ZC_EN and AUX_R_AMP_ZC_EN bits. If no zero-crossing is detected within approximately 85ms, the gain change is applied unconditionally. The sensitivity of the zero-cross detector is maximised by automatic selection of whether the zero-cross detection is performed at the input to the AUX amplifier, or the output from it. This is configured using the AUX_L_AMP_ZC_SEL and AUX_R_AMP_ZC_SEL controls. Smooth changes in gain are enabled by asserting the AUX_L_AMP_RAMP_EN and AUX_R_AMP_RAMP_EN controls. If the ramp controls are asserted, the rate of ramping is specified by the GAIN_RAMP_RATE control. Any zero-cross activation is over-ridden if gain ramping is set. The currently active AUX_L_GAIN and AUX_R_GAIN settings are stored in the AUX_L_GAIN_STATUS and AUX_R_GAIN_STATUS controls. NOTE: When implementing fade-in and fade-out effects on the record path, it is recommended that this is done through ADC L and ADC_R. When implementing fade-in and fade-out effects on the output path, this should be done using the HP L, HP R and LINE amplifiers. 14.6 Input mixers The DA7212 has two second level input amplifiers (MIXIN_L and MIXIN_R) that mix the analogue inputs as well as providing up to 18 dB extra gain. They are enabled by asserting the controls MIXIN_L_AMP_EN and MIXIN_R_AMP_EN. Gain can be controlled in 1.5 dB steps from 4.5 dB to +18 dB using the MIXIN_L_GAIN and MIXIN_R_GAIN register bits. Zero-crossing can be enabled by asserting MIXIN_L_AMP_ZC_EN or MIXIN_R_AMP_ZC_EN. If no zero crossing is detected within approximately 85ms, the gain change is applied unconditionally. Smooth changes in gain are performed by asserting the MIXIN_L_AMP_RAMP_EN and MIXIN_R_AMP_RAMP_EN controls. If the ramp controls are asserted, the rate of ramping is specified by the GAIN_RAMP_RATE control. Any zero-cross activation is over-ridden if gain ramping is set. Datasheet CFR0011-120-00 Rev 4 Revision 3a 35 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec The left mixer accepts inputs from AUX_L_AMP and from either or both of the microphone PGAs (MIC_1_AMP and MIC_2_AMP), as well as from the right mixer MIXIN_R for stereo-to-mono conversion. Similarly the right mxer accepts inputs from AUX_R_AMP and from either or both of the microphone PGAs (MIC_1_AMP and MIC_2_AMP), as well as from the left mixer MIXIN_L for stereo-to-mono conversion. Input channel selection is determined by MIXIN_L_MIX_SELECT and MIXIN_R_MIX_SELECT. The mixers can be muted using the MIXIN_L_AMP_MUTE_EN and MIXIN_R_AMP_MUTE_EN controls. The currently active gain settings are stored in MIXIN_L_AMP_GAIN_STATUS and MIXIN_R_AMP_GAIN_STATUS registers. 14.7 Stereo audio ADC DA7212 includes a low power 24-bit high quality stereo audio ADC that supports sampling rates from 8 kHz to 96 kHz. The sample rate is specified using the SR register. The stereo ADC can be enabled and disabled on either channel using ADC_L_EN and ADC_R_EN, thereby providing the opportunity to save power during mono operation. The ADC channels offer a configurable digital gain from 83.25 dB to +12 dB in 0.75 dB steps after the digital conversion. Individual gain settings can be programmed via controls ADC_L_DIGITAL_GAIN and ADC_R_DIGITAL_GAIN. The currently active gain settings are stored in ADC_L_GAIN_STATUS and ADC_R_GAIN_STATUS registers. Muting, and the ramping of digital gain changes, can be controlled using the dedicated ADC_L_CTRL and ADC_R_CTRL registers. If the ramping is enabled using the control bits ADC_L_RAMP_EN and ADC_R_RAMP EN, the rate of the ramping is controlled using GAIN_RAMP_RATE. To enable saturation-free signals with maximum signal to noise ratios, the input levels of the ADC are adjusted with second level PGAs that are enabled with controls MIXIN_L_AMP_EN and MIXIN_R_AMP_EN. The signal routing and mix are configured using the MIXIN_L_SELECT and MIXIN_R_SELECT registers. On the dedicated MIXIN_L_CTRL and MIXIN_R_CTRL registers, settings such as gain changes at zero-cross (for smooth volume changes), ramping of gain changes at signal zero cross ramping of gain changes, and mute can be configured. If the ramping is enabled using the control bits MIXIN_L_AMP_RAMP_EN and MIXIN_R_AMP_RAMP_EN, the speed of the ramp can be configured on GAIN_RAMP_RATE. 14.8 Automatic Level Control (ALC) For improved sound recordings of signals with a large volume range, the DA7212 offers a fullyconfigurable automatic recording level control (ALC) for microphone inputs. This is enabled via the ALC_L_EN and ALC_R_EN controls, and can be enabled independently on either left or right channel. It is recommended that the ALC is only enabled in stereo as this applies the same gain to both channels and so protects the pan of stereo signals. The ALC monitors the digital signal after the ADC and adjusts the microphones’ analogue and digital gain to maintain a constant recording level, whatever the analogue input signal level. Operation of ALC is illustrated in Figure 9. When the input signal volume is high, the ALC system will reduce the overall gain until the output volume is below the specified maximum value. When the input signal volume is low, the ALC will increase the gain until the output volume increases above the specified minimum value. If the output signal is within the desired signal level (between the specified minimum and maximum levels), the ALC does nothing. The maximum and the minimum thresholds that trigger a gain change of the ALC are programmed by the ALC_THRESHOLD_MAX and ALC_THRESHOLD_MIN controls. Datasheet CFR0011-120-00 Rev 4 Revision 3a 36 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec ALC Input ALC MAX level ALC Gain ALC MIN level Release time ALC Output Attack time Figure 9: Principle of Operation of the ALC The total gain is made up of an analogue gain, which is applied to the microphone PGAs, and a digital gain, which is implemented in the filtering stage. The ALC block monitors and controls the gain of the microphone PGAs and the ADC. Note that although the ALC is controlling the gain, it does not modify any of the registers MIC_1_AMP_GAIN, MIC_2_AMP_GAIN, ADC_L_DIGITAL_GAIN and ADC_R_DIGITAL_GAIN. These registers are ignored while the ALC is in operation. The minimum and maximum levels of digital gain that can be applied by the ALC are controlled using ALC_ATTEN_MAX and ALC_GAIN_MAX. Similarly the minimum and maximum levels of analogue gain are controlled by ALC_ANA_GAIN_MIN and ALC_ANA_GAIN_MAX.The rates at which the gain is changed are defined by the attack and decay rates in register ALC_CTRL2. When attacking, the gain decreases with ALC_ATTACK rate. When decaying, the gain increases with ALC_RELEASE rate. The hold-time is defined by ALC_HOLD in the ALC_CTRL3 register. This controls the length of time that the system maintains the current gain level before starting to decay. This prevents unwanted changes in the recording level when there is a short-lived ‘spike’ in input volume, for example when recording speech. Typically the attack rate should be much faster than the decay rate, as it is necessary to reduce rapidly increasing waveforms as quickly as possible, whereas fast release times will result in the signal appearing to ‘pump’. The ALC also has an anti-clipping function that applies a very fast attack rate when the input signal is close to full-range. This prevents clipping of the signal by reducing the signal gain at a faster rate than would normally be applied. The anti-clip function is enabled using ALC_ANTICLIP_EN, and the threshold above which it is activated is set in the range 1/128 full-scale to full-scale using ALC_ANTICLIP_LEVEL. A recording Noise-Gate feature is provided to avoid increasing the gain of the channel when there is no signal, or when only a noise signal is present. Boosting a signal on which only noise is present is known as ‘noise pumping’. The Noise-Gate prevents this. Whenever the level of the input signal drops below the noise threshold configured in ALC_NOISE, the channel gain remains constant. Datasheet CFR0011-120-00 Rev 4 Revision 3a 37 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec max input signal min time gain level atk rate dcy rate atk hld dcy time Figure 10: Attack, Delay and Hold parameters 14.9 Beep Generator and Controller The DA7212 has two sine wave generators (SWG). Each SWG can generate an audio frequency from 10Hz to 12 kHz with a 12.288 MHz system clock (or from 10Hz to 11.02 kHz with a 11.288 MHz system clock). The output frequency of each SWG can be specified with a 10Hz step size using the FREQ1_L and FREQ1_U registers for SWG 1, and FREQ2_L and FREQ2_U for SWG 2. For all Output Frequency calculations, FREQ[15:8] = FREQn_U FREQ[7:0] = FREQn_L For sample rates (SR) = 8/12/16/24/32/48/96 kHz, FREQ = (2^16 * (fHz/12)) -1 For sample rates (SR) = 11.025/22.05/44.4/88.2 kHz, FREQ = (2^16 * (fHz/11.025)) -1 The SWGs have a programmable gain that can be set in 3 dB steps from 0 dB to 45 dB using the GAIN register field. The gain setting applies equally to both SWGs. The beep generator generates beeps that can be a single tone from either SWG (register SWG_SEL = 1 or SWG_SEL = 2), or a mix of two tones from the two SWGs (register SWG_SEL = 0 or SWG_SEL = 3). The beep generator can also output standard DTMF keypad values (listed in Table 4) by asserting the DTMF_EN register bit. Note that output from the beep generator is mixed into the DAI to DAC path. This means that if the source path for DAC_L or DAC_R is selected to be ADC_L or ADC_R (registers 0x2A[5:4] and 0x2A[1:0]), the beep generator is omitted from the signal path. Datasheet CFR0011-120-00 Rev 4 Revision 3a 38 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 25: DTMF Keypad frequencies Frequency 1 (Hz) 1209 1336 1477 1633 Frequency 2 (Hz) 697 770 852 941 1 2 3 A 4 5 6 B 7 8 9 C * 0 # D The beep tone On and Off periods are specified using the BEEP_ON_PER and BEEP_OFF_PER register fields. Beep-On and Beep-Off periods can be configured in 10ms steps from 10ms to 200ms, and in 50ms steps from 250ms to 2000ms. The Beep-On period can also be configured as continuous. The number of beep cycles is configured using the BEEP_CYCLES register field. The tone generator is started by asserting the START_STOPN register bit, and is halted by clearing it. If START_STOPN is cleared, beep generation terminates on completion of the current beep-cycle, or at the next zero-cross if in continuous mode. The START_STOPN register bit is cleared automatically once the programmed number of beeps has completed. In continuous-beep mode (BEEP_CYCLES = 6 or 7, or BEEP_ON_PER = 63), the tone generator is switched off by clearing START_STOPN. 14.10 Output Signal Chain The DA7212 has two audio outputs. These are a stereo Class-G headphone driver, and a mono Class-AB speaker driver. Two output mixers allow mixing of signals from the DACs and the analogue bypass paths, with output going to any or all of the three output PGAs. These output paths are illustrated in Figure 11. Datasheet CFR0011-120-00 Rev 4 Revision 3a 39 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec from AUX_L_AMP -57dB to +6dB in 1dB steps HP_L_AMP from MIXIN_L HP_L from DAC_L HP_R HP_R_AMP -57dB to +6dB in 1dB steps LINE_AMP SP_P from DAC_R SP_N -48dB to +15dB in 1dB steps from MIXIN_R from AUX_R_AMP Figure 11: Analogue output signal paths and gain ranges 14.11 Stereo Audio DAC The integrated stereo DAC is suitable for high quality audio playback by MP3 players and by portable multi media players of all kinds. The left and right channels of the DAC can be individually enabled using controls DAC_L_EN and DAC_R_EN. Each channel includes individual gain settings that are controllable in 0.75 dB steps from 78 dB to 12 dB using DAC_L_DIGITAL_GAIN and DAC_R_DIGITAL_GAIN. The currently active gain settings are stored in DAC_L_GAIN_STATUS and DAC_R_GAIN_STATUS registers. On the dedicated DAC_L_CTRL and DAC_R_CTRL registers, settings such as mute and ramping of gain changes can be configured. If ramping is enabled using the control bits DAC_L_RAMP_EN or DAC_R_RAMP_EN, the rate of the ramping can be controlled using GAIN_RAMP_RATE. A digital high-pass filter for each DAC channel is implemented with a 3 dB cut-off frequency controlled by DAC_AUDIO_HPF_CORNER. The high-pass filter is enabled by control DAC_HPF_EN. After Reset, the high pass filters for both channels are enabled by default. 14.12 Output Mixer For playback, the output mixer amplifier is enabled using MIXOUT_L_AMP_EN and MIXOUT_R_AMP_EN. The audio signal can be mixed from all sources, and can be output simultaneously to both headphones and speakers. The mixing takes place only after asserting the control MIXOUT_L_MIX_EN and MIXOUT_R_MIX_EN. The output mixer is configured using register MIXOUT_L_SELECT and MIXOUT_R_SELECT. This Datasheet CFR0011-120-00 Rev 4 Revision 3a 40 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec output-mixer control is independent of the input path, so recording of one audio signal while listening to another signal such as FM Radio or an MP3 file is possible. The playback sound can be mixed with background signals or with inverted background microphone signals (side tone) to enable a basic headphone environmental noise reduction, or to compensate for unwanted damping of environmental sound while listening with sealed headphones. Playback signals coming from the AUX or microphone input channels can be individually inverted before being mixed out to the left and right channel (see MIXOUT_L_SELECT and MIXOUT_R_SELECT registers). A stereo to mono conversion can be implemented by using either the input or the output mixer. This allows direct feeding of high power speaker amplifiers and other mono devices with the complete audio content. 14.13 Headphone Amplifier The headphone Class G amplifiers offer 'true ground' technology, which allows cost and space optimisation by removing the need for bulky headphone-coupling capacitors. This also enhances the bass performance, which is typically reduced by conventional AC-coupling. In comparison to alternative approaches like ‘phantom ground’, ‘true ground’ technology generates real ground-centred output signals, which provide common GND as required for Mini-USB connectors and CEA 936 A-compliant interfaces. An embedded offset compensation circuit suppresses click and pop noise during start-up and dynamic supply voltage adjustments. Integrated short circuit protection enables a ‘resistors free’ connection to a standard audio jack, to achieve a maximum output power of up to 67 mW per channel (referenced to VDD_A). Headphone load impedance is typically 16 Ω, but the paths can also be used as volume controlled lineout signals for external speaker amplifiers and audio devices. The headphone Class G amplifiers are supplied from the positive VDD_A rail via a capacitive charge pump that generates the negative rail required for ‘true ground’ mode. For improved power efficiency, the headphone headphone supply voltage levels are dynamically adjusted between ±VDD_A and ±VDD_A/2 to match the levels of the left and right headphone signals. The headphone amplifiers are enabled with controls HP_L_AMP_EN and HP_R_AMP_EN. For optimum pop and click performance when switching the amplifier On and Off, the headphone amplifier provides a high impedance mode that can be enabled via HP_L_AMP_OE / HP_R_AMP_OE. Balance is controlled by programming the left and right gains separately. The gain of each headphone channel can be programmed independently in steps of 1.0 dB from +6 dB down to – 57 dB using controls HP_L_AMP_GAIN / HP_R_AMP_GAIN. Settings such as mute, gain changes at signal zero cross (for smooth volume changes), and the ramping of gain changes are controlled using the dedicated HP_L_CTRL and HP_R_CTRL registers. If the ramping is enabled using the control bits HP_L_AMP_RAMP_EN and HP_R_AMP_RAMP_EN, the rate of the ramping is controlled using GAIN_RAMP_RATE. For smooth volume changes, the gain update can be synchronised to audio signal zero-crossings using HP_L_AMP_ZC_EN and HP_R_AMP_ZC_EN. If no zero crossing is detected within approximately 85ms, the gain change is applied unconditionally. The left and right channels are synchronised independently. 14.14 Speaker Amplifier The differential lineout channel can be used to directly drive mini speakers with a nominal impedance ≥ 8 Ω. For highest efficiency and speaker output power, a direct supply from the battery is supported via a separate supply pin. This amplifier offers individually programmable volume control in 1.0 dB steps from +15 dB to 48 dB using LINE_AMP_GAIN. On the dedicated LINE_CTRL register, settings such as mute, tri-state output mode and ramping of gain changes can be configured. If ramping is enabled via control bit LINE_AMP_RAMP_EN, the rate of the ramping can be configured on GAIN_RAMP_RATE. The differential speaker amplifier can be used to drive mini-speakers with an impedance of 8 Ω or Datasheet CFR0011-120-00 Rev 4 Revision 3a 41 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec higher. A direct supply from the battery is provided by the VDD_SP pin. This allows maximum speaker power, and a wide operating range from 5.0 V down to 1.0 V. The mono lineout/speaker amplifier is enabled by asserting LINE_AMP_EN. Gain can be set in the range -48 dB to +15 dB in 1 dB steps using the LINE_AMP_GAIN control. The speaker amplifier can be muted by asserting LINE_AMP_MUTE_EN. Smooth updates to line/speaker amplifer gain can be made by asserting LINE_AMP_RAMP_EN. When LINE_AMP_RAMP_EN is asserted, gain updates are made by ramping sequentially through all intermediate gain values. 14.15 Charge Pump Control The charge pump is enabled by asserting CP_EN in the CP_CTRL (0x47) register. Once enabled, the charge pump can be controlled manually or automatically. When under manual control (CP_MCHANGE = 00), the output voltage level is directly determined by CP_MOD. The amount of charge stored, and therefore the voltage generated, by the charge pump is controlled by the charge pump controller (CP_CTRL register). As the power consumed by devices such as amplifiers is proportional to Voltage2, significant power savings are available by matching the charge pump’s output with the system’s power requirement. Under automatic control, there are three modes of operation that are determined by the CP_MCHANGE setting. All four modes (one manual and three automatic) are described in Table 5. Table 26: Charge pump output voltage control Charge Pump Tracking Mode Charge Pump Output Voltage Details 00 Manual The charge pump’s output voltage is determined by the settings of CP_MOD. 01 Voltage level depends on the programmed gain setting 10 Voltage level depends on the DAC signal envelope CP_MCHANGE 11 Voltage level depends on the signal magnitude and the programmed gain setting The charge pump controller monitors the PGA volume settings, and generates the minimum voltage that is high enough to drive a full-scale signal at the current gain level. The charge pump controller monitors the DAC signal, and generates a voltage that is high enough to drive a full-scale output at the current DAC signal volume level The charge pump monitors both the programmed volume settings and the actual signal size, and generates the appropriate output voltage. This is the most power-efficient mode of operation. When CP_MCHANGE is set to 10 (tracking DAC signal size, described in Table 26) or CP_MCHANGE is set to 11 (tracking the output signal size), the charge pump switches its supply between the VDD_A rail and the VDD_A/2 rail depending on its power requirements. When low output voltages are needed, the charge pump saves power by using the the lower-voltage VDD_A/2 rail. The switching point between using the VDD_A rail and the VDD_A/2 rail is determined by the CP_THRESH_VDD2 register setting. The switching points determined by CP_THRESH_VDD2 vary between the two CP_MCHANGE modes, and are summarised in Table 27 and Table 28. Datasheet CFR0011-120-00 Rev 4 Revision 3a 42 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Note 17 When the charge pump output voltage is controlled manually (CP_MCHANGE = 00) or when it is tracking the PGA gain settings (CP_MCHANGE = 01), the charge pump always takes its supply from VDD_A Table 27: CP_THRESH_VDD2 Settings in DAC_VOL mode (CP_MCHANGE = 10) CP_THRESH_VDD2 Setting Approximate Switching Point 0x01 -30 dBFS Do not use. Very power-inefficient as nearly always VDD/1 0x03 -24 dBFS Not recommended. Very power-inefficient as nearly always VDD/1 0x07 -18 dBFS Good to use but not power efficient 0x0E -12 dBFS Good to use 0x10 -10 dBFS Recommended setting 0x3F – 0x13 Notes Not recommended Note 18 Full Scale (FS) = 1.6 * VDD_A Table 28: CP_THRESH_VDD2 Settings in Signal Size mode (CP_MCHANGE = 11) CP_THRESH_VDD2 Setting Approximate Switching Point Notes 0x00 Never Not recommended. Always VDD/1 mode 0x01 Never Not recommended. Always VDD/1 mode 0x02 -32 dBFS Not recommended. Very power-inefficient as nearly always VDD/1 0x03 -24 dBFS Good to use 0x04 -20 dBFS Good to use 0x05 -17 dBFS Good to use 0x06 -15 dBFS Recommended setting 0x07 -13 dBFS Good to use 0x08 -12 dBFS Good to use 0x09 -11 dBFS Good to use 0x0A -10 dBFS Good to use 0x0B -9 dBFS Not recommended. VDD/2 begins to clip 0x0C Never Not recommended. Always VDD/2 mode 0x0D Never Not recommended. Always VDD/2 mode 0x0E Never Not recommended. Always VDD/2 mode 0x0F Never Not recommended. Always VDD/2 mode Note 19 Full Scale (FS) = 1.6 * VDD_A Datasheet CFR0011-120-00 Rev 4 Revision 3a 43 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.16 Charge pump clock control The charge pump on DA7212 requires two clocks (cp_clk and cp_clk2). The cp_clk2 clock runs at a slower frequency than cp_clk. It is cp_clk that actually clocks the charge pump. To prevent the clocks stopping in an unknown state, there are always two pulses on cp_clk for every one pulse of cp_clk2. This is illustrated in Figure 12. clk cp_clk cp_clk2 Figure 12: Input (clk) and Output Clocks (cp_clk and cp_clk2) at CP_FCONTROL = 010 When CP_ANALOGUE_LVL = 00 (‘No feedback’ – see Section 14.17 for more details), the charge pump’s nominal clock rate cp_clk is controlled by CP_FCONTROL, providing a range from 1 MHz (CP_FCONTROL = 000) down to 63 kHz (CP_FCONTROL = 100). With the slower clock rates, quiescent power consumption is lower but the trade-off is a reduced load current, and slower changes to the voltage. Section 14.17 describes how quiescent power and load current can be varied according to demand. 14.17 Boosting the charge pump using demand feedback control When CP_ANALOGUE_LVL = 00, the clock frequency for the charge pump is under direct control of the registers as described in Section 0. When CP_ANALOGUE_LVL = 01 or 10 (11 is reserved and is not used), the demands on the charge pump output are tracked, and the clock frequency is boosted when necessary to give the required output current. This gives the benefit of a very low (or even zero) quiescent current when the charge pump is not required combined with a maximum output when that is required. 14.17.1 Tracking the demands on the charge pump output There are three points at which the demands on the charge pump can be tracked. These tracking points are determined by CP_MCHANGE. 14.17.1.1 CP_MCHANGE = 00 (manual mode) If CP_MCHANGE = 00, the voltage level is controlled by the CP_MOD setting. 14.17.1.2 CP_MCHANGE = 01 (tracking the PGA gain setting) If CP_MCHANGE = 01, it is the PGA gain setting that is tracked, and which provides the feedback to boost the clock frequency when necessary. 14.17.1.3 CP_MCHANGE = 10 (tracking the DAC signal setting) If CP_MCHANGE = 01, it is the size of the DAC signal that is tracked, and which provides the feedback to boost the clock frequency when necessary. 14.17.1.4 CP_MCHANGE = 11 (tracking the output signal magnitude) If CP_MCHANGE = 01, it is the magnitude of the output signal that is tracked, and which provides Datasheet CFR0011-120-00 Rev 4 Revision 3a 44 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec the feedback to boost the clock frequency when necessary. 14.17.2 Specifying clock frequencies when tracking the charge pump output demand CP_FCONTROL specifies the frequency of the charge pump clock. The frequency is fixed and is set manually if CP_MCHANGE = 00 (see section 14.17.1.1). The available frequency settings are 1 MHz (the absolute maximum), and 500, 250, 125 and 63 kHz. If CP_MCHANGE not = 00, the charge pump load is monitored and the clock frequency adjusted accordingly to allow the charge pump to supply the required current. Clock frequency varies depending on the charge pump requirements, and the CP_FCONTROL settings specify the minimum frequency at which the clock will run. The maximum frequency is always 1 MHz. In addition to the CP_FCONTROL settings outlined above, and which specify the minimum clock frequency, there is an extra setting of CP_FCLOCK = 101 which has no minimum frequency. The clock frequency is under the complete control of the tracking and feedback mechanism. The frequency can vary from 0 Hz when there is no load on the charge pump and no component leakage, up to the maximum of 1 MHz. These settings are all summarised in Table 29. 14.17.3 Controlling the boost of the charge pump clock-frequency The manner in which the charge pump clock-frequency is boosted is controlled by CP_ANALOGUE_LVL. If CP_ANALOGUE_LVL = 00, there is no feedback to the clock generator, and the frequency remains fixed at the frequency specified by CP_FCONTROL. 14.17.3.1 CP_ANALOGUE_LVL = 01 If CP_ANALOGUE_LVL = 01, the clock frequency is boosted from the base frequency specified in CP_FCONTROL by the insertion of extra clock pulses in to the clock signal as and when required. When no extra pulses are being inserted, the clock frequency remains fixed at the value specified by CP_FCONTROL. The extra clock pulses are inserted in to the clock signal as needed as long as the clock frequency does not exceed its maximum of 1 MHz. These settings are all summarised in Table 29. . 14.17.3.2 CP_ANALOGUE_LVL = 10 If CP_ANALOGUE_LVL = 10, instead of boosting the clock frequency by inserting extra clock pulses as described in section 14.17.3.1, the clock is restarted. By restarting the clock before the next pulse is due, the frequency is effectively increased. The clock frequency can be increased from the minimum frequency specified in CP_FCONTROL, up to the maximum frequency of 1 MHz. These settings are all summarised in Table 29. . Datasheet CFR0011-120-00 Rev 4 Revision 3a 45 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Table 29: Charge pump current load control CP_ANALOGUE_LVL (0x47[1:0]) 000 001 010 CP_FCONTROL (0x96[2:0]) 011 100 101 110 111 00 No current boost 01 Variable current boost 10 Variable current boost 11 1 MHz 1 MHz 1 MHz Reserved 500 kHz From 500 kHz to1MHz depending on demand Note 20 From 500 kHz to1MHz depending on demand Note 20 Reserved 250 kHz From 250 kHz to1MHz depending on demand Note 20 From 250 kHz to1MHz depending on demand Note 20 Reserved 125 kHz From 125 kHz to1MHz depending on demand Note 20 From 125 kHz to1MHz depending on demand Note 20 Reserved 63 kHz From 63 kHz to1MHz depending on demand Note 20 From 63 kHz to1MHz depending on demand Note 20 Reserved Reserved 0 Hz to 1MHz depending on demand Note 20 0 Hz to 1MHz depending on demand Note 20 Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved Note 20 Power demand is determined bythe PGA gain level if CP_MCHANGE = 01, by the DAC signal level if CP_MCHANGE = 10 , or by the output signal level If CP_MCHANGE = 11 14.18 Other Charge Pump Controls When a higher charge pump output voltage is needed, the charge pump increases its output as the fastest rate possible given the controls and settings in that currently in place. Once the higher output voltage is no longer needed, the charge pump controller waits for a period determined by the CP_TAU_DELAY setting before reducing the output voltage. For best performance Dialog recommend setting CP_TAU_DELAY to 16ms or greater. The charge pump limiter is controlled by CP_ON_OFF. The limiter restricts the current flow to the charge pump’s capacitors at start-up. CP_SMALL_SWITCH_FREQ_EN enables a low-load, low-power switching mode. If CP_SMALL_SWITCH_FREQ_EN is enabled and CP_FCONTROL is set to a value between 000 and 100, any feedback from the analogue level detector results in a switch from low-power to full-power. Full-power is maintained for one CP_TAU_DELAY period after the pulse. Any subsequent pulses restart the CP_TAU_DELAY period. If CP_FCONTROL = 101, the first feedback from the analogue level detector primes the change to full-power mode. If another pulse occurs within 32 clock cycles of the first feedback from the analogue level detector, full power is enabled for one CP_TAU_DELAY period. 14.19 Digital Signal Processing Engine The digital signal processing engine includes a configurable audio processor that offers flexible routing and extensive audio enhancement and effects. Linear phase FIR filters perform the DAC Datasheet CFR0011-120-00 Rev 4 Revision 3a 46 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec interpolation and decimation for the required sample rates. Configurable high-pass filtering (optionally enabled on both ADC and DAC) removes any signal DC offset and can help to filter out wind noise. A 5-band playback equaliser can be configured to suit the users listening preferences. 14.20 Variable High Pass Audio Filter (DC Cut) Any DC offset from the input path is removed via IIR filters (typically 5 MHz, you must follow the procedure below. Write F0 = 8b Write F1 = 01 Write F0 = 00 Setup PLL and clocking 14.29 Mixed Sample Rates In DA7212 there is only one Sample Rate register and therefore, by default, this controls the sample rate of both the ADC and the DAC Some applications require the ADC and the DAC to run at different sample rates. A special mode (24-48 Mode) is available by asserting 24_48_MODE at register address 0x84[0]. Asserting this bit sets the ADC to run at 24kHz and the DAC to run at 48kHz. In this mode all the functionality of the ADC and the DAC is available. The DAI will continue to run at 48kHz, and every ADC sample will be repeated across two WCLK frames. 14.30 I2C Control Interface The DA7212 is completely software-controlled from the host by registers. The DA7212 provides an I2C compliant serial control interface to access these registers. Data is shifted into or out of the DA7212 under the control of the host processor, which also provides the serial clock. The 7-bit I2C slave address is 0x1A so that the 8-bit address for writing is 0x34 and for reading is 0x35. The I2C clock is supplied by the SCL line and the bi directional I2C data is carried by the SDA line. The I2C interface is open-drain supporting multiple devices on a single line. The bus lines have to be pulled HIGH by external pull-up resistors (1 kΩ to 20 kΩ range). The attached devices only drive the bus lines LOW by connecting them to ground. This means that two devices cannot conflict if they drive the bus simultaneously. In standard/fast mode the highest frequency of the bus is 1 MHz. The exact frequency can be determined by the application and does not have any relation to the DA7212 internal clock signals. DA7212 will follow the host clock speed within the described limitations and does not initiate any clock arbitration or slow down. In high-speed mode the maximum frequency of the bus can be increased up to 3.4 MHz. This mode is supported if the SCL line is driven with a push-pull stage from the host and if the host enables an external 3mA pull-up at the SDA pin to decrease the rise time of the data. In this mode the SDA line on DA7212 is able to sink up to 12mA. In all other respects the high speed mode behaves as the standard/fast mode. Communication on the I2C bus always takes place between two devices, one acting as the master and the other as the slave. The DA7212 will only operate as a SLAVE. The I2C interface has direct access to the whole register map of the DA7212. Datasheet CFR0011-120-00 Rev 4 Revision 3a 57 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec VDD_IO Host Processor SCL SDA VDD_IO SCL SDA Codec SCL SDA Peripheral Device Figure 20: Schematic of the I2C control interface bus 14.31 Details of the I2C Control interface protocol All data is transmitted across the I2C bus in groups of 8 bits. To send a bit the SDA line is driven to the intended state while the SDA is LOW (a LOW on SDA indicates a zero bit). Once the SDA has settled, the SCL line is brought HIGH and then LOW. This pulse on SCL clocks the SDA bit into the receiver’s shift register. A two byte serial protocol is used containing one byte for address and one byte for data. Data and address transfer is transmitted MSB first for both read and write operations. All transmission begins with the START condition from the master while the bus is in the IDLE state (the bus is free). It is initiated by a high to low transition on the SDA line while the SCL is in the high state (a STOP condition is indicated by a low to high transition on the SDA line while the SCL line is in the high state). SCL SDA Figure 21 Timing of I2C START and STOP Conditions The I2C bus is monitored by DA7212 for a valid SLAVE address whenever the interface is enabled. It responds with an Acknowledge immediately when it receives its own slave address. The Acknowledge is done by pulling the SDA line low during the following clock cycle (white blocks marked with ‘A’ in Figure 22 to Figure 25). The protocol for a register write from master to slave consists of a start condition, a slave address with read/write bit and the 8-bit register address followed by 8 bits of data terminated by a STOP condition (the DA7212 responds to all bytes with Acknowledge). This is illustrated in Figure 22. Datasheet CFR0011-120-00 Rev 4 Revision 3a 58 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec S SLAVE addr 7-bits W A REG addr 1-bit A 8-bits Master to Slave DATA P A 8-bits Slave to Master S = START condition P = STOP condition A = Acknowledge (low) W = Write (low) Figure 22: I2C Byte write (SDA signal) When the host reads data from a register it first has to write-access DA7212 with the target register address and then read access DA7212 with a repeated START, or alternatively a second START condition. After receiving the data the host sends a Not Acknowledge (NAK) and terminates the transmission with a STOP condition: S SLAVEaddr W A 7-bits 1-bit S SLAVEaddr W A 7-bits 1-bit REG addr A Sr SLAVEaddr R 8-bits 7-bits REG addr A P 7-bits * DATA A P 8-bits S SLAVEaddr R 8-bits Master to Slave A 1-bit A 1-bit * DATA A P 8-bits Slave to Master S = START condition Sr = Repeated START condition P = STOP condition A = Acknowledge (low) * A = Not Acknowledge (NAK) W = Write (low) R = Read (high) Figure 23: Examples of the I2C Byte Read (SDA line) Consecutive (Page Mode) read-out mode (CIF_I2C_WRITE_MODE (0x1D [0]) = 0) is initiated from the master by sending an Acknowledge instead of Not Acknowledge (NAK) after receipt of the data word. The I2C control block then increments the address pointer to the next I2C address and sends the data to the master. This enables an unlimited read of data bytes until the master sends a NAK directly after the receipt of data, followed by a subsequent STOP condition. If a non-existent I2C address is read out, the DA7212 will return code zero. S SLAVEaddr W A 7-bits 1 bit S SLAVEaddr W A 7-bits REG addr A Sr SLAVEaddr R A 8-bits REG addr 7-bits Master to Slave S = START condition Sr = Repeat START condition P = STOP condition 8-bits S SLAVEaddr R A A P 7-bits 8-bits 1-bit 1-bit DATA 1-bit A DATA A 8-bits DATA * DATA A P 8-bits A 8-bits DATA * A P 8-bits Slave to Master A = Acknowledge (low) * A = Not Acknowledge (NAK) W = Write (low) R = Read (high) Figure 24: Examples of I2C Page Read (SDA line) Note 1 The slave address after the Repeated START condition must be the same as the previous slave address Consecutive write-mode (CIF_I2C_WRITE_MODE (0x1D [0]) = 0) is supported if the Master sends several data bytes following a slave register address. The I2C control block then increments the address pointer to the next I2C address, stores the received data and sends an Acknowledge until the master sends the STOP condition. Datasheet CFR0011-120-00 Rev 4 Revision 3a 59 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec S SLAVEaddr W A 7-bits 1 bit REGadr 8-bits A DATA 8-bits Master to Slave A DATA 1-bit 8-bits A DATA 8-bits A ………. A P Repeated writes Slave to Master S = START condition Sr = Repeat START condition P = STOP condition A = Acknowledge (low) * A = Not Acknowledge (NAK) W = Write (low) R = Read (high) Figure 25: I2C Page Write (SDA Line) An alternative repeated-write mode that uses non-consecutive slave register addresses is available using the CIF_I2C_WRITE_MODE register. In this Repeat Mode (CIF_I2C_WRITE_MODE (0x1D [0]) = 1), the slave can be configured to support a host’s repeated write operations into several nonconsecutive registers. Data is stored at the previously received register address. If a new START or STOP condition occurs within a message, the bus returns to IDLE mode. This is illustrated in Figure 26 Datasheet CFR0011-120-00 Rev 4 Revision 3a 60 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec S SLAVEaddr W A 7-bits 1 bit REG addr A 8-bits Master to Slave DATA 8-bits A REG addr 1-bit 8-bits A DATA 8-bits A ………. A P Repeated writes Slave to Master S = START condition Sr = Repeat START condition P = STOP condition A = Acknowledge (low) * A = Not Acknowledge (NAK) W = Write (low) R = Read (high) Figure 26: I2C Repeated Write (SDA Line) Note 2 Note that in Page Mode (CIF_I2C_WRITE_MODE = 0), both Page Mode reads and writes using auto-incremented addresses, and Repeat Mode reads and writes using non auto-incremented addresses, are supported. In Repeat Mode (CIF_I2C_WRITE_MODE = 1) however, only Repeat Mode reads and writes are supported. 14.32 Digital Audio Interface (DAI) DA7212 provides one Digital Audio Interface (DAI) to input DAC data or to output ADC data. It is enabled by asserting DAI_EN. The DSP provides flexible routing options allowing each interface to be connected to different signal paths as desired in each application. The DAI consists of a four-wire serial interface, with bit clock (BCLK), word clock (WCLK), data-in (DATIN) and data-out (DATOUT) pins. Both master and slave clock modes are supported by the DA7212. Master mode is enabled setting register DAI_CLK_EN (0x28[7]) = 1. In master mode, the bit clock and word clock signals are outputs from the codec. In slave mode these are inputs to the codec. BCLK WCLK DA7212 Codec DATIN Processor DATOUT Figure 27: Master Mode (DAI_CLK_EN = 1) Datasheet CFR0011-120-00 Rev 4 Revision 3a 61 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec BCLK WCLK DA7212 Codec DATIN Processor DATOUT Figure 28: Slave Mode (DAI_CLK_EN = 0) The internal serialized DAI data is 24 bits wide. Serial data that is not 24 bits wide is either shortened or zero-filled at input to, or at output from, the DAI’s internal 24-bit data width. The serial data word length can be configured to be 16, 20, 24 or 32 bits wide using the DAI_WORD_LENGTH register bits. Four different data formats are supported by the digital audio interface. The data format is determined by the setting of the DAI_FORMAT register bits. ● ● ● ● I2S mode Left Justified mode Right Justified mode DSP mode Time division multiplexing (TDM) is available in any of these modes to support the case where multiple devices are communicating simultaneously on the same bus. TDM is enabled by asserting the DAI_TDM_MODE_EN bit. Datasheet CFR0011-120-00 Rev 4 Revision 3a 62 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.33 I2S Mode In I2S mode (DAI_FORMAT = 0), the MSB of the left channel is valid on the second rising edge of the bit clock after the falling edge of the word clock. The MSB of the right channel is valid on the second rising edge of the bit clock after the rising edge of the word clock, and the MSB of the left channel is valid on the second rising edge of the bit clock after the falling edge of the word clock. WCLK WCLK 1 = RIGHT CHANNEL DATA WCLK 0 = LEFT CHANNEL DATA BCLK DATIN/DATOUT msb Right Channel lsb msb Left Channel lsb msb Figure 29: I2S Mode 14.34 Left Justified Mode In left-justified mode (DAI_FORMAT = 1), the MSB of the right channel is valid on the rising edge of the bit clock following the falling edge of the word clock. The MSB of the left channel is valid on the rising edge of the bit clock following the rising edge of the word clock. WCLK WCLK 1 = LEFT CHANNEL DATA WCLK 0 = RIGHT CHANNEL DATA BCLK DATIN/DATOUT msb Left Channel lsb msb Right Channel lsb msb Figure 30: Left Justified Mode 14.35 Right Justified Mode In right-justified mode (DAI_FORMAT = 2), the LSB of the left channel is valid on the rising edge of the bit clock preceding the falling edge of word clock. The LSB of the right channel is valid on the rising edge of the bit clock preceding the rising edge of the word clock. WCLK WCLK 1 = LEFT CHANNEL DATA WCLK 0 = RIGHT CHANNEL DATA BCLK DATIN/DATOUT lsb msb Left Channel lsb msb Right Channel lsb Figure 31: Right Justified Mode Datasheet CFR0011-120-00 Rev 4 Revision 3a 63 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.36 DSP Mode In DSP mode (DAI_FORMAT = 3), the rising edge of the word clock starts the data transfer with the left channel data first and immediately followed by the right channel data. Each data bit is valid on the falling edge of the bit clock. WCLK The falling edge of WCLK can occur anywhere in this area BCLK DATIN/DATOUT msb Left Channel lsb msb WCLK Right Channel lsb msb The falling edge of WCLK can occur anywhere in this area BCLK DATIN/DATOUT msb Left Channel lsb msb Right Channel lsb msb Offset Figure 32: DSP Mode Datasheet CFR0011-120-00 Rev 4 Revision 3a 64 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.37 Time Division Multiplexing (TDM) Mode Time Division Multiplexing (TDM) allows multiple devices to communicate on the same bus without conflicting. TDM mode (DAI_TDM_MODE_EN = 1) is an extension of the DSP and the Left Justified formats (see page 63). DA7212 Codec ADC Data Out DAC Data In Word Clock Bit Clock Processor DA7212 Codec Figure 33: TDM Example (slave mode) WCLK WCLK 1 = LEFT CHANNEL DATA WCLK 0 = RIGHT CHANNEL DATA BCLK DATIN/DATOUT msb Left Channel WCLK lsb msb Right Channel WCLK 1 = LEFT CHANNEL DATA lsb msb WCLK 0 = RIGHT CHANNEL DATA BCLK DATIN/DATOUT msb Left Channel lsb msb Right Channel lsb msb Offset Figure 34: TDM Mode (left justified mode) Datasheet CFR0011-120-00 Rev 4 Revision 3a 65 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec A time offset is specified from the normal ‘start of frame’ condition using register bit DAI_OFFSET. Since a different offset may be defined for each device on the bus, they may both communicate without collisions. In the Left-Justified TDM example illustrated in Figure 34, the left channel data is valid DAI_OFFSET clock cycles after the rising edge of the word clock, and the right channel data is valid the same DAI_OFFSET number of clock cycles after the falling edge of the word clock. In DSP TDM mode (not illustrated), the left channel data is valid after the same DAI_OFFSET clock cycles from the rising edge of the word clock, but the right channel data is valid immediately after the left channel data. The serial data pin must be tri-stated whenever the output is not valid. Mono mode is supported in the TDM mode by asserting DAI_MONO_MODE_EN. If DAI_MONO_MODE_EN is asserted, only the data from the Digital Audio Interface left channel is transmitted. 14.37.1 Configuration of the Digital Audio Interface The data format is configured using register DAI_FORMAT. The offset applied in TDM mode is configured using register DAI_OFFSET. The word length is configured using register DAI_WORD_LENGTH. The digital audio interface is enabled using register DAI_EN and the frame length is configured using DAI_BCLKS_PER_WCLK. When using the digital audio interface in slave mode (DAI_CLK_EN = 0), if the WCLK input is not from the same clock source as the MCLK input, then the SRM PLL mode must be enabled to maintain synchronization. 14.38 Pop-Free and Click-Free Start-up using the System Controllers DA7212 has two System Controllers that provide pop-free and click-free start-up under most conditions. 14.38.1 Level 1 System Controller (SCL1) The Level 1 System Controller (SCL1) is automatically activated whenever a sub-system’s enable bit is asserted. SCL1 ensures that the desired component parts are sequenced in the correct order to provide click-free and pop-free start-up. The following example using the left DAC illustrates SCL1 in operation. 1. When the left DAC is enabled by assertion of the DAC_L_EN register bit (register 0x69[7] ) a. SCL1 first activates the DAC clocks b. SCL1 then activates the DSP logic c. Next, SCL1 activates the analogue DAC d. Finally, SCL1 ramps up the digital gain In this way, SCL1 helps ensure that the DAC_L start-up is free of pops and clicks. Note 34 Note, however, that if any dependent functions for a sub-system’s activation have not been enabled, SCL1 will not automatically enable them. This allows you greater control over the sequencing of the sub-system, but it also means that any sub-system can potentially be brought up in such a way that audible artefacts such as pops and clicks are introduced. Datasheet CFR0011-120-00 Rev 4 Revision 3a 66 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 14.38.2 Level 2 System Controller (SCL2) Level 2 System Controller (SCL2) is a higher level controller that provides one-touch activation of standard operating modes. Input or output sub-systems can be activated either singly or in combination. All selected sub-systems will start up in the correct order and without pops or clicks when SCL2 is activated. First, the desired input sub-systems must be selected by asserting the relevant fields (bits 1 to 7) of the SYSTEM_MODES_INPUT (0x50) register. Similarly, the desired output sub-systems must be selected by asserting the relevant fields (bits 1 to 7) of the SYSTEM_MODES_OUTPUT (0x51) register. Once the desired sub-systems have been selected, the SCL2 controller is activated by writing ‘1’ to the MODE_SUBMIT register field in either the SYSTEM_MODES_INPUT (0x50) or the SYSTEM_MODES_OUTPUT (0x51) register. It does not matter which of the two MODE_SUBMIT fields is asserted. Both work in the same way, and each will start up both the input and the output sub-systems. When SCL2 is activated by asserting MODE_SUBMIT, all of the register-writes that are required by the selected sub-systems are performed automatically. Each sub-system is brought up in the correct order to avoid pops and clicks, and within each sub-system, the component parts are brought up in the correct pop-free and click-free sequence. Note 35 Note that the MODE_SUBMIT field used to start SCL2 is self-clearing, and is automatically reset to ‘0’ once SCL2 has started SCL1 and SCL2 activity can be monitored using the SCL1_BUSY and SCL2_BUSY bits on the SYSTEM_STATUS (0xE0) register. Note 36 If the DA7212 device is changed from one playback mode to another, or if it is changed from one record mode to another, the initial mode is closed down first before the second mode is activated. This happens automatically. 14.39 Power Supply – Standby Mode DA7212 has an ultra-low power standby mode that can be enabled to save power when the device is not in use. Standby Mode is controlled using the SYSTEM_ACTIVE register. 14.39.1 Entering Standby Mode Standby Mode is activated by writing a ‘0’ to the SYSTEM_ACTIVE register bit. This SYSTEM_ACTIVE register cannot be read when in Standby Mode because the act of reading the bit causes it to be asserted, which causes the Standby Mode to be exited. When entering Standby Mode, it is important that all audio paths are shut down first because the shut down is abrupt and audio artifacts such as pops and click may be heard. No audio functions are possible during Standby Mode, as the reference oscillator and the reference voltages are both shut down. 14.39.2 Exiting Standby Mode Standby Mode can be exited by writing a ‘1’ to the SYSTEM_ACTIVE register bit. Any read or write access to the DA7212 will also cause the SYSTEM_ACTIVE bit to be asserted, but note that the first read or write access may fail because of the time taken to restart the reference Datasheet CFR0011-120-00 Rev 4 Revision 3a 67 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec oscillator. It is recommended that Standby Mode is exited by writing to the the SYSTEM_ACTIVE register rather than relying on the automatic assertion of the register by a read or write access. Read or write accesses to I2C slave addresses other than those used by the DA7212 will not cause Standby Mode to be exited. Datasheet CFR0011-120-00 Rev 4 Revision 3a 68 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 15 Register definitions 15.1 Register map Addr Function 7 6 5 4 3 2 1 0 Reserved Reserved Reserved Reserved PLL_SRM_LOCK PLL_LOCK Status Registers 0x02 STATUS1 Reserved Reserved Reserved Reserved 0x03 PLL_STATUS Reserved Reserved Reserved Reserved 0x04 AUX_L_GAIN_STAT US Reserved Reserved AUX_L_AMP_GAIN_STATUS 0x05 AUX_R_GAIN_STAT US Reserved Reserved AUX_R_AMP_GAIN_STATUS 0x06 MIC_1_GAIN_STAT US Reserved Reserved Reserved Reserved Reserved MIC_1_AMP_GAIN_STATUS 0x07 MIC_2_GAIN_STAT US Reserved Reserved Reserved Reserved Reserved MIC_2_AMP_GAIN_STATUS 0x08 MIXIN_L_GAIN_STA TUS Reserved Reserved Reserved Reserved MIXIN_L_AMP_GAIN_STATUS 0x09 MIXIN_R_GAIN_STA TUS Reserved Reserved Reserved Reserved MIXIN_R_AMP_GAIN_STATUS 0x0A ADC_L_GAIN_STAT US Reserved ADC_L_DIGITAL_GAIN_STATUS 0x0B ADC_R_GAIN_STAT US Reserved ADC_R_DIGITAL_GAIN_STATUS 0x0C DAC_L_GAIN_STAT US Reserved DAC_L_DIGITAL_GAIN_STATUS 0x0D DAC_R_GAIN_STAT US Reserved DAC_R_DIGITAL_GAIN_STATUS 0x0E HP_L_GAIN_STATU S Reserved Datasheet CFR0011-120-00 Rev 4 Reserved PLL_BYPASS_ACTIV PLL_MCLK_STATUS E HP_L_AMP_GAIN_STATUS Revision 3a 69 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 5 4 3 2 Addr Function 7 6 0x0F HP_R_GAIN_STATU S Reserved Reserved HP_R_AMP_GAIN_STATUS 0x10 LINE_GAIN_STATU S Reserved Reserved LINE_AMP_GAIN_STATUS 1 0 Reserved CIF_I2C_WRITE_MOD E System Initialisation Registers 0x1D CIF_CTRL CIF_REG_SOFT_ RESET Reserved 0x21 DIG_ROUTING_DAI Reserved Reserved 0x22 SR Reserved Reserved 0x23 REFERENCES Reserved Reserved 0x24 PLL_FRAC_TOP Reserved Reserved 0x25 PLL_FRAC_BOT 0x26 PLL_INTEGER Reserved 0x27 PLL_CTRL PLL_EN PLL_SRM_EN PLL_32K_MODE PLL_MCLK_SQR_EN 0x28 DAI_CLK_MODE DAI_CLK_EN Reserved Reserved Reserved Reserved Reserved DAI_R_SRC Reserved Reserved Reserved Reserved Reserved Reserved VMID_FAST_DISCH VMID_FAST_CHARG ARGE E DAI_L_SRC SR BIAS_EN Reserved Reserved Reserved Reserved Reserved Reserved PLL_FBDIV_FRAC_TOP PLL_FBDIV_FRAC_BOT PLL_FBDIV_INTEGER PLL_INDIV DAI_WCLK_POL DAI_CLK_POL 0x29 DAI_CTRL DAI_EN DAI_OE DAI_MONO_MODE_ DAI_TDM_MODE_EN EN 0x2A DIG_ROUTING_DAC DAC_R_MONO Reserved DAC_R_SRC DAC_L_MONO Reserved 0x2B ALC_CTRL1 ALC_R_EN Reserved ALC_CALIB_OVERF ALC_AUTO_CALIB_ LOW EN ALC_L_EN ALC_CALIB_MODE DAI_BCLKS_PER_WCLK DAI_WORD_LENGTH DAI_FORMAT DAC_L_SRC ALC_SYNC_MODE ALC_OFFSET_EN Input Gain / Select Filter Registers 0x30 AUX_L_GAIN Reserved Reserved AUX_L_AMP_GAIN 0x31 AUX_R_GAIN Reserved Reserved 0x32 MIXIN_L_SELECT DMIC_L_EN Reserved Reserved MIXIN_L_SEL MIC2_SEL MIC1_SEL AUX_L_SEL 0x33 MIXIN_R_SELECT DMIC_R_EN Reserved Reserved MIXIN_L_SEL MIC1_SEL MIC2_SEL AUX_R_SEL 0x34 MIXIN_L_GAIN Reserved Reserved Datasheet CFR0011-120-00 Rev 4 AUX_R_AMP_GAIN Reserved Reserved Revision 3a 70 of 154 MIXIN_L_AMP_GAIN 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Addr Function 7 6 5 4 0x35 MIXIN_R_GAIN Reserved Reserved Reserved Reserved 0x36 ADC_L_GAIN Reserved ADC_L_DIGITAL_GAIN 0x37 ADC_R_GAIN Reserved ADC_R_DIGITAL_GAIN 0x38 ADC_FILTERS1 ADC_HPF_EN Reserved 0x39 MIC_1_GAIN Reserved Reserved Reserved 0x3A MIC_2_GAIN Reserved Reserved Reserved ADC_AUDIO_HPF_CORNER 3 2 1 0 MIXIN_R_AMP_GAIN ADC_VOICE_EN ADC_VOICE_HPF_CORNER Reserved Reserved MIC_1_AMP_GAIN Reserved Reserved MIC_2_AMP_GAIN Output Gain / Select Filter Registers DAC_SOFTMUTE _EN 0x40 DAC_FILTERS5 DAC_SOFTMUTE_RATE 0x41 DAC_FILTERS2 DAC_EQ_BAND2 DAC_EQ_BAND1 0x42 DAC_FILTERS3 DAC_EQ_BAND4 DAC_EQ_BAND3 0x43 DAC_FILTERS4 DAC_EQ_EN Reserved 0x44 DAC_FILTERS1 DAC_HPF_EN Reserved 0x45 DAC_L_GAIN Reserved DAC_L_DIGITAL_GAIN 0x46 DAC_R_GAIN Reserved DAC_R_DIGITAL_GAIN 0x47 CP_CTRL CP_EN CP_SMALL_SWIT CH_FREQ_EN 0x48 HP_L_GAIN Reserved Reserved HP_L_AMP_GAIN 0x49 HP_R_GAIN Reserved Reserved HP_R_AMP_GAIN 0x4A LINE_GAIN Reserved Reserved LINE_AMP_GAIN 0x4B MIXOUT_L_SELECT Reserved MIXIN_R_INV MIXIN_L_INV AUX_L_INV DAC_L MIXIN_R MIXIN_L AUX_L 0x4C MIXOUT_R_SELECT Reserved MIXIN_L_INV MIXIN_R_INV AUX_R_INV DAC_R MIXIN_L MIXIN_R AUX_R Reserved Reserved Reserved Reserved DAC_AUDIO_HPF_CORNER Reserved Reserved DAC_EQ_BAND5 DAC_VOICE_EN CP_MCHANGE DAC_VOICE_HPF_CORNER CP_MOD CP_ANALOGUE_LVL System Controller Registers (1) 0x50 SYSTEM_MODES_I NPUT ADC_R ADC_L MIXIN_R MIXIN_L MIC_2 MIC_1 Reserved MODE_SUBMIT 0x51 SYSTEM_MODES_O DAC_R DAC_L HP_R HP_L LINE AUX_R AUX_L MODE_SUBMIT Datasheet CFR0011-120-00 Rev 4 Revision 3a 71 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Addr Function 7 6 5 4 3 2 1 0 UTPUT Control Registers (2) 0x60 AUX_L_CTRL AUX_L_AMP_EN AUX_L_AMP_MUT AUX_L_AMP_RAMP_ AUX_L_AMP_ZC_EN E_EN EN AUX_L_AMP_ZC_SEL Reserved Reserved 0x61 AUX_R_CTRL AUX_R_AMP_EN AUX_R_AMP_MUT AUX_R_AMP_RAMP AUX_R_AMP_ZC_EN E_EN _EN AUX_R_AMP_ZC_SEL Reserved Reserved 0x62 MICBIAS_CTRL MICBIAS2_EN Reserved 0x63 MIC_1_CTRL MIC_1_AMP_EN MIC_1_AMP_MUT E_EN Reserved Reserved MIC_1_AMP_IN_SEL Reserved Reserved 0x64 MIC_2_CTRL MIC_2_AMP_EN MIC_2_AMP_MUT E_EN Reserved Reserved MIC_2_AMP_IN_SEL Reserved Reserved 0x65 MIXIN_L_CTRL MIXIN_L_AMP_E N MIXIN_L_AMP_MU MIXIN_L_AMP_RAM MIXIN_L_AMP_ZC_E TE_EN P_EN N MIXIN_L_MIX_EN Reserved Reserved Reserved 0x66 MIXIN_R_CTRL MIXIN_R_AMP_E MIXIN_R_AMP_M MIXIN_R_AMP_RAM MIXIN_R_AMP_ZC_E N UTE_EN P_EN N MIXIN_R_MIX_EN Reserved Reserved Reserved 0x67 ADC_L_CTRL ADC_L_EN ADC_L_MUTE_EN ADC_L_RAMP_EN Reserved Reserved Reserved Reserved Reserved 0x68 ADC_R_CTRL ADC_R_EN ADC_R_MUTE_EN ADC_R_RAMP_EN Reserved Reserved Reserved Reserved Reserved MICBIAS2_LEVEL MICBIAS1_EN Reserved MICBIAS1_LVL 0x69 DAC_L_CTRL DAC_L_EN DAC_L_MUTE_EN DAC_L_RAMP_EN Reserved Reserved Reserved Reserved Reserved 0x6A DAC_R_CTRL DAC_R_EN DAC_R_MUTE_EN DAC_R_RAMP_EN Reserved Reserved Reserved Reserved Reserved 0x6B HP_L_CTRL HP_L_AMP_EN HP_L_AMP_MUTE HP_L_AMP_RAMP_E HP_L_AMP_ZC_EN _EN N HP_L_AMP_OE HP_L_AMP_MIN_GAI N_EN Reserved Reserved 0x6C HP_R_CTRL HP_R_AMP_EN HP_R_AMP_MUTE HP_R_AMP_RAMP_ _EN EN HP_R_AMP_ZC_EN HP_R_AMP_OE HP_R_AMP_MIN_GAI N_EN Reserved Reserved 0x6D LINE_CTRL LINE_AMP_EN LINE_AMP_MUTE LINE_AMP_RAMP_E _EN N Reserved LINE_AMP_OE LINE_AMP_MIN_GAI N_EN Reserved Reserved 0x6E MIXOUT_L_CTRL MIXOUT_L_AMP_ EN Reserved Reserved MIXOUT_L_SOFTMI X_EN MIXOUT_L_MIX_EN Reserved Reserved Reserved 0x6F MIXOUT_R_CTRL MIXOUT_R_AMP _EN Reserved Reserved MIXOUT_R_SOFTMI MIXOUT_R_MIX_EN X_EN Reserved Reserved Reserved Datasheet CFR0011-120-00 Rev 4 Revision 3a 72 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Addr Function 7 6 5 4 MIXED_SAMPLE_M ODE Reserved Reserved Reserved 3 2 1 0 Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved DMIC_CLK_RATE DMIC_SAMPLEPHA SE DMIC_DATA_SEL Reserved Reserved PC_RESYNC_AUTO PC_FREERUN Mixed Sample Mode Register 0x84 Reserved 24_48_MODE Configuration Registers 0x90 LDO_CTRL LDO_EN Reserved 0x92 GAIN_RAMP_CTRL Reserved Reserved 0x93 MIC_CONFIG Reserved Reserved 0x94 PC_COUNT Reserved Reserved 0x95 CP_VOL_THRESHO LD1 Reserved Reserved 0x96 CP_DELAY 0x97 CP_DETECTOR 0x98 DAI_OFFSET 0x99 DIG_CTRL 0x9A ALC_CTRL2 LDO_LEVEL_SELECT Reserved Reserved Reserved Reserved Reserved CP_THRESH_VDD2 CP_ON_OFF CP_TAU_DELAY Reserved Reserved Reserved Reserved DAC_R_INV Reserved Reserved Reserved CP_FCONTROL Reserved Reserved DAC_L_INV Reserved ALC_RELEASE ALC_CTRL3 ALC_NOISE Reserved Reserved ALC_NOISE 0x9D ALC_TARGET_MIN Reserved Reserved ALC_THRESHOLD_MIN 0x9E ALC_TARGET_MAX Reserved Reserved ALC_THRESHOLD_MAX ALC_GAIN_LIMITS 0XA0 ALC_INTEG_RELEASE ALC_ANTICLIP_CTR ALC_ANTICLIP_E L N 0xA2 ALC_ANTICLIP_LEV EL Reserved 0xA3 ALC_OFFSET_AUT Reserved CFR0011-120-00 Rev 4 ALC_ATTEN_MAX ALC_ANA_GAIN_MAX Reserved Reserved ALC_HOLD ALC_GAIN_MAX 0xA1 Datasheet ALC_INTEG_ATTACK Reserved Reserved ALC_ATTACK 0x9B ALC_ANA_GAIN_LI MITS CPDET_DROP DAI_OFFSET 0x9C 0x9F Reserved GAIN_RAMP_RATE Reserved Reserved Reserved Reserved ALC_ANA_GAIN_MIN Reserved Reserved Reserved Reserved Reserved Reserved ALC_ANTICLIP_LEVEL Reserved Reserved Reserved Revision 3a 73 of 154 Reserved 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Addr Function 7 6 5 4 3 2 1 0 O_M_L 0xA4 ALC_OFFSET_AUT O_U_L Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xA6 ALC_OFFSET_MAN _M_L Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xA7 ALC_OFFSET_MAN _U_L Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xA8 ALC_OFFSET_AUT O_M_R Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xA9 ALC_OFFSET_AUT O_U_R Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xAB ALC_OFFSET_MAN _M_R Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xAC ALC_OFFSET_MAN _U_R Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xAD ALC_CIC_OP_LVL_ CTRL Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xAE ALC_CIC_OP_LVL_ DATA Reserved Reserved Reserved Reserved Reserved Reserved Reserved Reserved 0xAF DAC_NG_SETUP_TI ME Reserved Reserved Reserved Reserved 0xB0 DAC_NG_OFF_THR ESHOLD Reserved Reserved Reserved Reserved Reserved DAC_NG_OFF_THRESHOLD 0xB1 DAC_NG_ON_THRE SHOLD Reserved Reserved Reserved Reserved Reserved DAC_NG_ON_THRESHOLD 0xB2 DAC_NG_CTRL DAC_NG_EN Reserved Reserved Reserved Reserved DAC_NG_RAMPDN_ DAC_NG_RAMPUP_ RATE RATE DAC_NG_SETUP_TIME Reserved Reserved Reserved Tone Generation & Beep Registers 0xB4 TONE_GEN_CFG1 0xB5 TONE_GEN_CFG2 0xB6 TONE_GEN_CYCLE S Datasheet CFR0011-120-00 Rev 4 START_STOPN Reserved Reserved DTMF_EN GAIN Reserved Reserved DTMF_REG Reserved Reserved Reserved Revision 3a 74 of 154 Reserved Reserved SWG_SEL BEEP_CYCLES 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 7 6 5 4 3 Addr Function 0xB7 TONE_GEN_FREQ1 _L FREQ1_L 0xB8 TONE_GEN_FREQ1 _U FREQ1_U 0xB9 TONE_GEN_FREQ2 _L FREQ2_L 0xBA TONE_GEN_FREQ2 _U FREQ2_U 0xBB TONE_GEN_ON_PE R Reserved Reserved BEEP_ON_PER 0xBC TONE_GEN_OFF_P ER Reserved Reserved BEEP_OFF_PER 2 1 0 System Controller Registers (2) 0xE0 SYSTEM_STATUS Reserved Reserved Reserved Reserved Reserved Reserved SC2_BUSY SC1_BUSY 0xFD SYSTEM_ACTIVE Reserved Reserved Reserved Reserved Reserved Reserved Reserved SYSTEM_ACTIVE Datasheet CFR0011-120-00 Rev 4 Revision 3a 75 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec 15.2 Status registers Register address Bit Type Label Default 0x02 STATUS1 7:0 R (reserved) 00000000 Register address Bit Type Label Default 7:4 R (reserved) 0000 R PLL_BYPASS_A CTIVE 3 2 R 0x03 PLL_STATU S 1 0 Datasheet CFR0011-120-00 Rev 4 R R PLL_MCLK_STA TUS PLL_SRM_LOCK PLL_LOCK Description Description 0 Indicates whether the PLL is in bypass mode 0 = not in bypass mode 1 = bypass mode 0 Indicates if the frequency on MCLK is greater than 1 MHz 0 = MCLK frequency 1 MHz or less 1 = MCLK frequency greater than 1 MHz 0 Asserted if the SRM is locked to the reference signal 0 = SRM not locked to reference signal 1 = SRM locked to reference signal 0 Asserted if the PLL is locked to the reference clock 0 = PLL not locked to reference clock 1 = PLL locked to reference clock Revision 3a 76 of 154 19 August 2014 © 2014 Dialog Semiconductor GmbH DA7212 Company confidential Datasheet/Ultra-low power stereo codec Register address 0x04 AUX_L_GAI N_STATUS Bit Type Label Default 7:6 R (reserved) 00 5:0 R AUX_L_AMP_G AIN_STATUS Description Actual AUX_L amplifier gain
DA7212-01UM2 价格&库存
很抱歉,暂时无法提供与“DA7212-01UM2”相匹配的价格&库存,您可以联系我们找货
DA7212-01UM2
    DA7212-01UM2
      DA7212-01UM2
