NAU8810YG
NAU8810YG
    NUVOTON(新唐)
    TQFN20
    带两线接口控制的差分/单声道音频编解码器
NAU8810YG 数据手册
NAU8810 Differential/Mono Audio Codec with 2-wire Interface Control Interface emPowerAudio™ 1. GENERAL DESCRIPTION The NAU8810 a cost effective low power wideband Monophonic audio CODEC. It is suitable for a wide range of audio applications, including voice telephony. Supported functions include a 5-band Graphic Equalizer, Automatic Level Control (ALC) with noise gate, PGA, standard I2S or PCM audio interface, optional PCM time slot assignment, and a full fractional-N on-chip PLL. This device includes one differential microphone input, and multiple variable gain control stages in the audio paths. Both a Mono headset/line-level output and a high power differential BTL speaker driver output are provided. The analog input path includes a PGA enabling dynamic range optimization of a wide range of input sources with programmable gain from -12dB to +35.25dB. In addition to a digital high pass filter to remove DC offset voltages, the ADC also features programmable voice band digital filtering. Audio data is communicated via the audio interface that supports multiple I2S and PCM data formats. The DAC converter path includes filtering, and mixing, programmable-gain amplifiers, and soft muting. The 2-Wire digital control interface has an independent supply voltage to enable easy integration into multiple supply voltage systems. The NAU88U10 operates at supply voltages from 2.5V to 3.6V, and the digital core can operate at a voltage as low as 1.71V to conserve power. The NAU8810 is specified for operation from -40C to +85C, and is available with automotive AEC-Q100 qualification. Please refer to ordering information for AEC-Q100 compliance part number. 2. FEATURES 24-bit signal processing linear Audio CODEC  Audio DAC: 93dB SNR and -84dB THD  Audio ADC: 91dB SNR and -79dB THD  Support variable sample rates from 8 - 48kHz Analog I/O  Integrated programmable Microphone Amplifier  Integrated BTL Speaker Driver 1 W (8Ω / 5V)  Earphone / Speaker / Line-Output Mixing / Routing  Integrated Headset Driver 40mW (16Ω / 3.3V)  Low Noise bias supply voltage for microphone  On-chip full fractional-N PLL Interfaces  I2S digital interface PCM time slot assignment  2-Wire serial control Interface (I2C style; /Write capable) emPowerAudio™ Datasheet Revision 2.8 Page 1 of 102 March 1, 2017 NAU8810 Low Power, Low Voltage  Analog Supply: 2.5V to 3.6V  Digital Supply: 1.71V to 3.6V  Nominal Operating Voltage: 3.3V Additional features  5-band Graphic Equalizer  Programmable ALC  ADC Notch Filter  Programmable High Pass Filter  Digital ADC/DAC Passthrough  Mono data output on both channels  Automotive AEC-Q100 grade 3 & TS16949 qualification, tested to a higher reliability standard  Temperature: –40C to +85C Applications  All types of wired/wireless telephony  Security Systems  Mobile Telephone Hands-free Kits  Residential & Consumer Intercoms MICMIC+ Microphone Interface Input Mixers & Gain Stage ADC ADC Filter Volume Control HPF Notch Filter MOUT DAC Filter Volume Control Limiter DAC Output Mixers SPKOUT+ -1 MICBIAS Microphone Bias Digital Audio Interface I2S PCM Audio I/O emPowerAudio™ Datasheet Revision 2.8 Page 2 of 102 SPKOUT- Control IF 2-wire Digital I/O March 1, 2017 NAU8810 MIC+ MIC- VREF VDDSPK SPKOUT - 20 19 18 17 16 PIN CONFIGURATION 3 13 MOUT VDDD 4 12 SDIO VSSD 5 11 SCLK Metal Paddle (VSSA) 10 VSSA MCLK SPKOUT+ 9 14 BCLK 2 8 VDDA FS VSSSPK 7 15 DACIN 1 6 MICBIAS ADCOUT 3. Figure 1: 20-Pin QFN Package emPowerAudio™ Datasheet Revision 2.8 Page 3 of 102 March 1, 2017 NAU8810 4. PIN DESCRIPTION Pin Name 24-Pin MICBIAS 1 VDDA VSSA Functionality A/D Pin Type Microphone Bias A O 2 Analog Supply A I 3 Analog Ground A O VDDD 4 Digital Supply D I VSSD 5 Digital Ground D O ADCOUT 6 Digital Audio Data Output D O DACIN 7 Digital Audio Data Input D I FS 8 Frame Sync D I/O BCLK 9 Bit Clock D I/O MCLK 10 Master Clock D I SCLK 11 2-Wire Serial Clock D I SDIO 12 2-Wire I/O D O MOUT 13 MONO Output A O SPKOUT+ 14 Speaker Positive Output A O VSSSPK 15 Speaker Ground A O SPKOUT- 16 Speaker Negative Output A O VDDSPK 17 Speaker Supply A I VREF 18 Decoupling internal analog mid supply reference A O MIC- 19 Microphone Negative Input voltage A I MIC+ 20 Microphone Positive Input A I Table 1: Pin Description Notes 1. The 20-QFN package includes a bulk ground connection pad on the underside of the chip. This bulk ground should be thermally tied to the PCB, and electrically tied to the analog ground. 2. Unused analog input pins should be left as no-connection. 3. Any unused digital input pin must be tied high or low as appropriate. emPowerAudio™ Datasheet Revision 2.8 Page 4 of 102 March 1, 2017 emPowerAudio™ Datasheet Revision 2.8 Page 5 of 102 MICBIASEN[4] (0x2F) DIGITAL AUDIO INTERFACE VDDA R R VDDA MICROPHONE BIAS PMICBSTGAIN[6:4] (0x2F) = 000 ALC NOTCH FILTER DAC PLL (Sidetone) BYPASS LIMITER MCLK CONTROL INTERFACE VSSA VREF MICBIAS PMICPGA ADC VDDSPK PMICBSTGAIN[6:4] (0x2F) Σ HPF VSSD PGAGAIN (0x2D) PGAMT[6] (0x2D) PGABST[8] (0x2F) VSSD VREF NMICPGA[1] (0x2C) VSSSPK MIC+ MIC- BYPSPK[1] (0x32) DACSPK[0] (0X32) BYPMOUT[1] (0x38) DACMOUT[0] (0x38) SPKGAIN[5:0] (0x36) SPKMOUT[x:0] (0xxx) SPKMXEN[2] (0x03) Σ Σ MOUTMXEN[3] (0x03) SPKBST[2] (0x31) MOUTBST[3] (0x31) 1.5X 1.0X 1.5X 1.0X 1.5X 1.0X SPKOUT- SPKOUT+ MOUT 5. -12 dB to +35.25 dB PGAEN[2] (0x02) NAU8810 BLOCK DIAGRAM SCLK SDIO ADCOUT DACIN FS BCLK Figure 2: NAU88U10 General Block Diagram March 1, 2017 NAU8810 6. Table of Contents 1. GENERAL DESCRIPTION .................................................................................................................................1 2. FEATURES .........................................................................................................................................................1 3. PIN CONFIGURATION .......................................................................................................................................3 4. PIN DESCRIPTION .............................................................................................................................................4 5. BLOCK DIAGRAM..............................................................................................................................................5 6. TABLE OF CONTENTS ......................................................................................................................................6 7. LIST OF FIGURES ..............................................................................................................................................9 8. LIST OF TABLES .............................................................................................................................................11 9. ABSOLUTE MAXIMUM RATINGS ...................................................................................................................12 10. OPERATING CONDITIONS ..............................................................................................................................12 11. ELECTRICAL CHARACTERISTICS.................................................................................................................13 12. FUNCTIONAL DESCRIPTION ..........................................................................................................................17 12.1. INPUT PATH ..............................................................................................................................................17 12.1.1. The differential microphone input (MIC- & MIC+ pins)...................................................................17 12.1.1.1. Positive Microphone Input (MIC+) ...........................................................................................18 12.1.1.2. Negative Microphone Input (MIC-) ...........................................................................................19 12.1.1.3. PGA Gain Control .....................................................................................................................19 12.1.2. PGA Boost / Mixer Stage ..................................................................................................................20 12.2. MICROPHONE BIASING ...........................................................................................................................21 12.3. ADC DIGITAL FILTER BLOCK .................................................................................................................22 12.3.1. Programmable High Pass Filter (HPF) ............................................................................................23 12.3.2. Programmable Notch Filter (NF) ......................................................................................................24 12.3.3. Digital ADC Gain Control ..................................................................................................................24 12.4. PROGRAMMABLE GAIN AMPLIFIER (PGA)...........................................................................................25 12.4.1. Automatic level control (ALC) ..........................................................................................................25 12.4.1.1. Normal Mode .............................................................................................................................28 12.4.1.2. ALC Hold Time (Normal mode Only) .......................................................................................28 12.4.2. Peak Limiter Mode ............................................................................................................................29 12.4.3. Attack Time ........................................................................................................................................30 12.4.4. Decay Times ......................................................................................................................................30 12.4.5. Noise gate (normal mode only) ........................................................................................................30 12.4.6. Zero Crossing ....................................................................................................................................31 12.5. DAC DIGITAL FILTER BLOCK .................................................................................................................32 12.5.4. Hi-Fi DAC De-Emphasis and Gain Control ......................................................................................34 12.5.5. Digital DAC Output Peak Limiter .....................................................................................................34 12.5.6. Volume Boost ....................................................................................................................................34 12.5.7. 5-Band Equalizer ...............................................................................................................................35 12.6. ANALOG OUTPUTS ..................................................................................................................................36 12.6.1. Speaker Mixer Outputs .....................................................................................................................36 12.6.2. Mono Mixer Output ..........................................................................................................................37 12.6.3. Differential Output Configuration ....................................................................................................38 12.6.4. Unused Analog I/O ............................................................................................................................38 12.7. GENERAL PURPOSE CONTROL.............................................................................................................41 12.7.1. Slow Timer Clock ..............................................................................................................................41 emPowerAudio™ Datasheet Revision 2.8 Page 6 of 102 March 1, 2017 NAU8810 12.8. CLOCK GENERATION BLOCK ................................................................................................................41 12.9. CONTROL INTERFACE ............................................................................................................................45 12.9.1. 2-WIRE Serial Control (I2C Style Interface) .....................................................................................45 12.9.1.1. 2-WIRE Protocol Convention ...................................................................................................45 12.9.1.2. 2-WIRE Write Operation ...........................................................................................................46 12.9.1.3. 2-WIRE Operation ....................................................................................................................46 12.10. DIGITAL AUDIO INTERFACES.................................................................................................................47 12.10.1. Right Justified audio data ................................................................................................................48 12.10.2. Left Justified audio data ...................................................................................................................49 12.10.3. I2S audio data ....................................................................................................................................50 12.10.4. PCM audio data .................................................................................................................................51 12.10.5. PCM Time Slot audio data ................................................................................................................52 12.10.6. Companding ......................................................................................................................................53 12.11. POWER SUPPLY ......................................................................................................................................54 12.11.1. Power-On Reset ................................................................................................................................54 12.11.2. Power Related Software Considerations ........................................................................................54 12.11.3. Software Reset ..................................................................................................................................55 12.11.4. Power Up/Down Sequencing ............................................................................................................55 12.11.5. Reference Impedance (REFIMP) and Analog Bias .........................................................................57 12.11.6. Power Saving .....................................................................................................................................57 12.11.7. Estimated Supply Currents ..............................................................................................................57 13. REGISTER DESCRIPTION ...............................................................................................................................59 13.1. SOFTWARE RESET ..................................................................................................................................61 13.2. POWER MANAGEMENT REGISTERS .....................................................................................................61 13.2.1. Power Management 1 .......................................................................................................................61 13.2.2. Power Management 2 .......................................................................................................................62 13.2.3. Power Management 3 .......................................................................................................................62 13.3. AUDIO CONTROL REGISTERS ...............................................................................................................62 13.3.1. Audio Interface Control ....................................................................................................................62 13.3.2. Audio Interface Companding Control..............................................................................................63 13.3.3. Clock Control Register .....................................................................................................................64 13.3.4. Audio Sample Rate Control Register...............................................................................................65 13.3.5. DAC Control Register .......................................................................................................................65 13.3.6. DAC Gain Control Register ..............................................................................................................66 13.3.7. ADC Control Register .......................................................................................................................66 13.3.8. ADC Gain Control Register ..............................................................................................................67 13.4. 5-BAND EQUALIZER CONTROL REGISTERS ........................................................................................68 13.5. DIGITAL TO ANALOG CONVERTER (DAC) LIMITER REGISTERS .......................................................69 13.6. NOTCH FILTER REGISTERS ...................................................................................................................70 13.7. AUTOMATIC LEVEL CONTROL REGISTER ...........................................................................................71 13.7.1. ALC1 REGISTER ...............................................................................................................................71 13.7.2. ALC2 REGISTER ...............................................................................................................................72 13.7.3. ALC3 REGISTER ...............................................................................................................................73 13.8. NOISE GAIN CONTROL REGISTER ........................................................................................................74 13.9. PHASE LOCK LOOP (PLL) REGISTERS .................................................................................................75 13.9.1. PLL Control Registers ......................................................................................................................75 13.9.2. Phase Lock Loop Control (PLL) Registers .....................................................................................75 13.10. INPUT, OUTPUT, AND MIXERS CONTROL REGISTER .........................................................................76 emPowerAudio™ Datasheet Revision 2.8 Page 7 of 102 March 1, 2017 NAU8810 13.10.1. Attenuation Control Register ...........................................................................................................76 13.10.2. Input Signal Control Register ...........................................................................................................76 13.10.3. PGA Gain Control Register ..............................................................................................................77 13.10.4. ADC Boost Control Registers ..........................................................................................................78 13.10.5. Output Register .................................................................................................................................78 13.10.6. Speaker Mixer Control Register .......................................................................................................79 13.10.7. Speaker Gain Control Register ........................................................................................................79 13.10.8. MONO Mixer Control Register ..........................................................................................................80 13.10.9. Power Management 4 .......................................................................................................................80 13.11. PCM TIME SLOT CONTROL & ADCOUT IMPEDANCE OPTION CONTROL .........................................81 13.11.1. PCM1 TIMESLOT CONTROL REGISTER .........................................................................................81 13.11.2. PCM2 TIMESLOT CONTROL REGISTER .........................................................................................81 13.12. REGISTER ID ............................................................................................................................................82 13.12.1. Device revision register ....................................................................................................................82 13.12.2. 2-WIRE ID Register ............................................................................................................................82 13.12.3. Additional ID ......................................................................................................................................82 13.13. Reserved ...................................................................................................................................................82 13.14. OUTPUT Driver Control Register ............................................................................................................83 13.15. AUTOMATIC LEVEL CONTROL ENHANCED REGISTER ......................................................................84 13.15.1. ALC1 Enhanced Register .................................................................................................................84 13.15.2. ALC Enhanced 2 Register ................................................................................................................84 13.16. MISC CONTROL REGISTER ....................................................................................................................85 13.17. Output Tie-Off REGISTER ........................................................................................................................86 13.18. AGC PEAK-TO-PEAK OUT REGISTER ...................................................................................................86 13.19. AGC PEAK OUT REGISTER.....................................................................................................................86 13.20. AUTOMUTE CONTROL AND STATUS REGISTER ................................................................................87 13.21. Output Tie-off Direct Manual Control REGISTER ..................................................................................87 14. CONTROL INTERFACE TIMING DIAGRAM ....................................................................................................88 14.1. 2-WIRE TIMING DIAGRAM........................................................................................................................88 15. AUDIO INTERFACE TIMING DIAGRAM ..........................................................................................................89 15.1. AUDIO INTERFACE IN SLAVE MODE ......................................................................................................89 15.2. AUDIO INTERFACE IN MASTER MODE ..................................................................................................89 15.3. PCM AUDIO INTERFACE IN SLAVE MODE (PCM Audo Data) ................................................................90 15.4. PCM AUDIO INTERFACE IN MASTER MODE (PCM Audo Data) ............................................................90 15.5. PCM AUDIO INTERFACE IN SLAVE MODE (PCM Time Slot Mode ) .......................................................91 91 15.6. PCM AUDIO INTERFACE IN MASTER MODE (PCM Time Slot Mode ) ...................................................91 15.7. System Clock (MCLK) Timing Diagram ......................................................................................................92 15.8. µ-LAW ENCODE DECODE CHARACTERISTICS ....................................................................................93 15.9. A-LAW ENCODE DECODE CHARACTERISTICS....................................................................................94 15.10. µ-LAW / A-LAW CODES FOR ZERO AND FULL SCALE ........................................................................95 15.11. µ-LAW / A-LAW OUTPUT CODES (DIGITAL MW)...................................................................................95 16. DIGITAL FILTER CHARACTERISTICS ...........................................................................................................96 17. TYPICAL APPLICATION ..................................................................................................................................98 18. PACKAGE SPECIFICATION ............................................................................................................................99 19. ORDERING INFORMATION ...........................................................................................................................100 20. VERSION HISTORY .......................................................................................................................................101 emPowerAudio™ Datasheet Revision 2.8 Page 8 of 102 March 1, 2017 NAU8810 7. List of Figures Figure 1: 20-Pin QFN Package .....................................................................................................................................3 Figure 2: NAU88U10 General Block Diagram ...............................................................................................................5 Figure 3: Input PGA Circuit Block Diagram .................................................................................................................18 Figure 4: Boost Stage Block Diagram .........................................................................................................................20 Figure 5: Microphone Bias Schematic .........................................................................................................................21 Figure 6: ADC Digital Filter Path Block Diagram .........................................................................................................22 Figure 7: ALC Block Diagram ......................................................................................................................................25 Figure 8: ALC Response Graph ..................................................................................................................................26 Figure 9: ALC Normal Mode Operation .......................................................................................................................28 Figure 10: ALC Hold Time ...........................................................................................................................................29 Figure 11: ALC Limiter Mode Operations ....................................................................................................................29 Figure 12: ALC Operation with Noise Gate disabled ...................................................................................................30 Figure 13: ALC Operation with Noise Gate Enabled ...................................................................................................31 Figure 14: DAC Digital Filter Path ...............................................................................................................................32 Figure 15: DAC Digital Limiter Control ........................................................................................................................34 Figure 16: Speaker and MONO Analogue Outputs [To Update ? output from Auxilliary Amplifier] .............................36 Figure 17: Tie-off Options for the Speaker and MONO output Pins ............................................................................39 Figure 18: PLL and Clock Select Circuit ......................................................................................................................41 Figure 19: Valid START Condition ..............................................................................................................................45 Figure 20: Valid Acknowledge .....................................................................................................................................45 Figure 21: Valid STOP Condition ................................................................................................................................45 Figure 22: Slave Address Byte, Control Address Byte, and Data Byte .......................................................................46 Figure 23: Byte Write Sequence .................................................................................................................................46 Figure 24: 2-Wire Read Sequence ..............................................................................................................................47 Figure 25: Right Justified Audio Interface (Normal Mode) ...........................................................................................48 Figure 26: Right Justified Audio Interface (Special mode) ..........................................................................................49 Figure 27: Left Justified Audio Interface (Normal Mode) .............................................................................................49 Figure 28: Left Justified Audio Interface (Special mode) .............................................................................................50 Figure 29: I2S Audio Interface (Normal Mode) ............................................................................................................50 Figure 30: I2S Audio Interface (Special mode)............................................................................................................51 Figure 31: PCM Mode Audio Interface (Normal Mode) ...............................................................................................51 Figure 32: PCM Mode Audio Interface (Special mode) ...............................................................................................52 Figure 33: PCM Time Slot Mode (Time slot = 0) (Normal Mode) ................................................................................52 Figure 34: PCM Time Slot Mode (Time slot = 0) (Special mode) ................................................................................53 Figure 35: The Programmable ADCOUT Pin ..............................................................................................................81 Figure 36: 2-Wire Timing Diagram ..............................................................................................................................88 Figure 37: Audio Interface Slave Mode Timing Diagram .............................................................................................89 emPowerAudio™ Datasheet Revision 2.8 Page 9 of 102 March 1, 2017 NAU8810 Figure 38: Audio Interface in Master Mode Timing Diagram .......................................................................................89 Figure 39: PCM Audio Interface Slave Mode Timing Diagram ....................................................................................90 Figure 40: PCM Audio Interface Slave Mode Timing Diagram ....................................................................................90 Figure 41: PCM Audio Interface Slave Mode (PCM Time Slot Mode )Timing Diagram ..............................................91 Figure 42: PCM Audio Interface Master Mode (PCM Time Slot Mode )Timing Diagram .............................................91 Figure 43: MCLK Timing Diagram ...............................................................................................................................92 Figure 44: DAC Filter Frequency Response................................................................................................................97 Figure 45: ADC Filter Frequency Response................................................................................................................97 Figure 46: DAC Filter Ripple .......................................................................................................................................97 Figure 47: ADC Filter Ripple .......................................................................................................................................97 Figure 48: Application Diagram For 20-Pin QFN .........................................................................................................98 emPowerAudio™ Datasheet Revision 2.8 Page 10 of 102 March 1, 2017 NAU8810 8. List of Tables Table 1: Pin Description ................................................................................................................................................4 Table 2: Register associated with Input PGA Control .................................................................................................18 Table 3: Microphone Non-Inverting Input Impedances .................................................................................................19 Table 4: Microphone Inverting Input Impedances .......................................................................................................19 Table 5: Registers associated with ALC and Input PGA Gain Control ........................................................................20 Table 6: Registers associated with PGA Boost Stage Control ....................................................................................20 Table 7: Register associated with Microphone Bias ....................................................................................................21 Table 8: Microphone Bias Voltage Control ..................................................................................................................22 Table 9: Register associated with ADC .......................................................................................................................23 Table 10: High Pass Filter Cut-off Frequencies (HPFAM=1) .......................................................................................23 Table 11: Registers associated with Notch Filter Function ..........................................................................................24 Table 12: Equations to Calculate Notch Filter Coefficients..........................................................................................24 Table 13: Register associated with ADC Gain ............................................................................................................24 Table 14: Registers associated with ALC Control .......................................................................................................27 Table 15: ALC Maximum and Minimum Gain Values ..................................................................................................27 Table 16: Registers associated with DAC Gain Control ..............................................................................................32 Table 17: Registers associated with Equalizer Control ...............................................................................................35 Table 18: Speaker Output Controls .............................................................................................................................37 Table 19: MONO Output Controls ...............................................................................................................................37 Table 20: General Purpose Control .............................................................................................................................41 Table 21: Registers associated with PLL ....................................................................................................................42 Table 22: Registers associated with PLL ....................................................................................................................43 Table 23: PLL Frequency Examples ...........................................................................................................................44 Table 24: Standard Interface modes ...........................................................................................................................48 Table 25: Audio Interface Control Registers................................................................................................................48 Table 26: Companding Control ...................................................................................................................................53 Table 27: Power up sequence.....................................................................................................................................56 Table 28: Power down Sequence ...............................................................................................................................57 Table 29: Registers associated with Power Saving .....................................................................................................57 Table 30: VDDA 3.3V Supply Current .........................................................................................................................58 Table 31: 2-WireTiming Parameters ...........................................................................................................................88 Table 32: Audio Interface Timing Parameters .............................................................................................................92 Table 33: MCLK Timing Parameter .............................................................................................................................92 emPowerAudio™ Datasheet Revision 2.8 Page 11 of 102 March 1, 2017 NAU8810 9. ABSOLUTE MAXIMUM RATINGS CONDITION MIN MAX Units VDDD, VDDA supply voltages -0.3 +3.63 V VDDSPK supply voltage (MOUTBST=0, SPKBST=0) -0.3 +3.63 V VDDSPK supply voltage (MOUTBST=1, SPKBST=1) -0.3 +5.50 V Core Digital Input Voltage range VSSD – 0.3 VDDD + 0.30 V Analog Input Voltage range VSSA – 0.3 VDDA + 0.30 V Industrial operating temperature -40 +85 0 C Storage temperature range -65 +150 0 C CAUTION: Do not operate at or near the maximum ratings listed for extended period. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 10. OPERATING CONDITIONS Condition Symbol Min Value Analogue supplies range VDDA Digital supply range Speaker supply (MOUTBST=0, SPKBST=0) Speaker supply (MOUTBST=1, SPKBST=1) Ground Typical Value Max Value Units 2.501 3.60 V VDDD 1.71 3.60 V VDDSPK 2.50 3.60 V VDDSPK 2.50 5.50 V VSSD, VSSA, VSSSPK 0 V Note 1. VDDA must be ≥ VDDD. emPowerAudio™ Datasheet Revision 2.8 Page 12 of 102 March 1, 2017 NAU8810 11. ELECTRICAL CHARACTERISTICS VDDD = 1.8V, VDDA = VDDSPK = 3.3V (VDDSPK = 1.5*VDDA when Boost), TA = +25oC, 1kHz signal, fs = 48kHz, 24-bit audio data unless otherwise stated. PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Analogue to Digital Converter (ADC) Full scale input signal 1 Signal to Noise Ratio 2 Total Harmonic Distortion 3 VINFS PGABST = 0dB PGAGAIN = 0dB SNR Gain = 0dB, A-weighted THD Input = -1dBFS, Gain = 0dB 87 1.0 0 VRMS dBV 91 dB -79 -65 dB Digital to Analogue Converter (DAC) to MONO output (all data measured with 10kΩ / 50pF load) Full Scale output signal MOUTBST=0 1.0x (VREF) MOUTBST=1 1.5 x VREF 1 Signal to Noise Ratio 2 SNR A-weighted (ADC/DAC oversampling rate of 128) Total Harmonic Distortion 3 THD RL = 10 KΩ; -1.0dBfs 90 Programmable input PGA gain Guaranteed monotonic PGABST = 0 Programmable Boost PGA gain Positive Microphone Input resistance RMIC+ Input Capacitance CMIC dB VRMS dBV 35.25 dB dB 0 dB 20 Mute Attenuation RAUX -70 0.75 PGABST = 1 PGA equivalent output noise dB 1 0 -12 Programmable Gain Step Size Auxiliary Input resistance 93 -84 Microphone Inputs (MICN & MICP) and MIC Input Programmable Gain Amplifier (PGA) PGABST = 0dB Full-scale Input Signal Level 1 VINFS PGAGAIN = 0dB VRMS 100 dB 0 to 20kHz, Gain set to 35.25dB 110 µV PGA Gain = 35.25dB 1.6 kΩ PGA Gain = 0dB 47 kΩ PGA Gain = -12dB 75 kΩ PMICPGA = 1 94 kΩ 10 pF Speaker Output PGA Programmable Gain Programmable Gain Step Size emPowerAudio™ Datasheet Revision 2.8 -57 Guaranteed monotonic Page 13 of 102 6 1 March 1, 2017 dB dB NAU8810 VDDD = 1.8V, VDDA = VDDSPK = 3.3V (VDDSPK = 1.5*VDDA when Boost), TA = +25oC, 1kHz signal, fs = 48kHz, 24-bit audio data unless otherwise stated. PARAMETER SYMBOL TEST CONDITIONS BTL Speaker Output (SPKOUT+, SPKOUT- with 8Ω bridge tied load) SPKBST = 0 VDDSPK = VDDA 7 Full scale output SPKBST = 1 VDDSPK = 1.5 * VDDA Output Power PO Signal to Noise Ratio SNR PSRR UNIT VDDA / 3.3 VRMS (VDDA / 3.3) * 1.5 90 dB VDDSPK = 1.5*VDDA RL = 8Ω 90 dB -63 dB -56 dB -60 dB -61 dB PO =1W -34 dB VDDSPK = 3V, SPKBST = 0 50 dB VDDSPK = 1.5*VDDA, SPKBST = 1 50 dB VDDA / 3.3 VRMS 90 dB -84 dB -85 dB (MICBIASV = 0) 0.9* VDD A V (MICBIASV = 1) 0.65* VDD A V VDDSPK=3.3V PO =360mW RL = 8Ω VDDSPK = 1.5*VDDA PO =800mW Power Supply Rejection Ratio (50Hz - 22kHz) MAX VDDSPK = 3.3V RL = 8Ω PO =400mW THD TYP Output power is very closely correlated with THD; see below PO =180mW Total Harmonic Distortion MIN Headphone’ output (SPKOUTP, SPKOUTN with resistive load to ground) Full scale output 7 Signal to Noise Ratio SNR A-weighted Po = 20mW Total Harmonic Distortion THD Po = 20mW RL=16 Ω RL=32 Ω VDDSPK=3.3V Microphone Bias Bias Voltage VMICBIAS Bias Current Source IMICBIAS Output Noise Voltage VN 3 mA MICBIASM = 0 (1kHz to 20kHz) 14 nV/√Hz MICBIASM = 1 (1kHz to 20kHz) 4 nV/√Hz Automatic Level Control (ALC)/Limiter – ADC only Target Record Level -28.5 Programmable Gain -6 dB 35.25 0.75 dB dB 0 / 2.67 / …/ 43691 ms -12 Programmable Gain Step Size Gain Hold Time 4, 6 Guaranteed Monotonic tHOLD MCLK=12.288MHz ™ emPowerAudio Datasheet Revision 2.8 Page 14 of 102 March 1, 2017 NAU8810 (time doubles with each step) emPowerAudio™ Datasheet Revision 2.8 Page 15 of 102 March 1, 2017 NAU8810 VDDD = 1.8V, VDDA = VDDSPK = 3.3V (VDDSPK = 1.5*VDDA when Boost), TA = +25oC, 1kHz signal, fs = 48kHz, 24-bit audio data unless otherwise stated. PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNIT Automatic Level Control (ALC)/Limiter – ADC only Gain Ramp-Up (Decay) Time 5, 6 Gain Ramp-Down (Attack) 5, 6 Time tDCY tATK ALC Mode ALCM=0 MCLK=12.288MHz 3.3 / 6.6 / 13.1 / … / 3360 (time doubles every step) ms Limiter Mode ALCM=1 MCLK=12.288MHz 0.73 / 1.45 / 2.91 / … / 744 (time doubles every step) ms ALC Mode ALCM=0 MCLK=12.288MHz 0.83 / 1.66 / 3.33 / … / 852 (time doubles every step) ms Limiter Mode ALCM=1 MCLK=12.288MHz 0.18 / 0.36 / 0.73 / … / 186 (time doubles every step) ms Digital Input / Output 0.7 × VDDD Input HIGH Level VIH Input LOW Level VIL Output HIGH Level VOH IOL = 1mA Output LOW Level VOL IOH = -1mA V 0.3 × VDDD 0.9 × VDDD V 0.1 x VDDD Notes 1. Full Scale is relative to VDDA (FS = VDDA/3.3.). 2. Signal-to-noise ratio (dB) - SNR is a measure of the difference in level between the full-scale output and the output with no signal applied. (No Auto-zero or Automute function is employed in achieving these results). 3. THD+N (dB) - THD+N are a ratio, of the RMS values, of (Noise + Distortion)/Signal. 4. Hold Time is the length of time between a signal detected being too quiet and beginning to ramp up the gain. It does not apply to ramping down the gain when the signal is too loud, which happens without a delay. 5. Ramp-up and Ramp-Down times are defined as the time to change the PGA gain by 6dB of its gain range. 6. All hold, ramp-up and ramp-down times scale proportionally with MCLK (specified for MCLK = 12.288MHz) 7. The maximum output voltage can be limited by the speaker power supply. If MOUTBST or SPKBST is, set then VDDSPK should be 1.5xVDDA to prevent clipping taking place in the output stage (when PGA gains are set to 0dB). emPowerAudio™ Datasheet Revision 2.8 Page 16 of 102 V March 1, 2017 V NAU8810 12. FUNCTIONAL DESCRIPTION The NAU8810 a Mono Audio CODEC with very robust ADC and DAC capabilities. The device provides one differential microphone input pair (MIC- & MIC+ pins) supported by a two-stage amplification path for amplification by as much as 55.25dB. Additionally, the MIC+ pin can be used independently from the MIC- pin enabling two independent mixing inputs for some applications. The device also has an internal configurable biasing circuit for biasing the microphone, which reduces external components. The PGA output has programmable ADC gain. An advanced Sigma Delta ADC and DAC are used along with digital decimation and interpolation filters to give high quality audio at sample rates from 8 KHz to 48 KHz. The Digital Filter blocks include ADC high pass filters, a Notch Filter, and a 5-band equalizer. The device has two output mixers, one for the Mono output, and the other for the speaker output. The NAU88U10 has a 2-Wire read/write serial control interface for device control. Audio data is supported in many commonly used industry formats as either I2S or PCM formatted data. Additionally, the PCM mode supports time slotting for added design flexibility, such as in creation of multichannel systems using a shared audio data bus. The NAU88U10 can operate as a master or slave audio device. It can operate with sample rates ranging from 8 kHz to 48 kHz, depending on the values of MCLK and it is prescaler. The NAU88U10 includes a PLL block, where it takes the external clock (MCLK pin) to generate other clocks for the audio data transfer such as Bit clock (BCLK), Frame Sync (FS), and I2S clocks. The power control registers help save power by controlling the major individual functional blocks of the NAU88U10. 12.1. INPUT PATH The NAU88U10 microphone inputs are maintained at a DC bias at approximately a half of the VDDA supply voltage. Connections to these inputs should be AC-coupled by means of DC blocking capacitors suitable for the device application. 12.1.1. The differential microphone input (MIC- & MIC+ pins) The NAU88U10 features a low-noise, high common mode rejection ratio (CMRR), differential microphone inputs (MIC- & MIC+ pins) which are connected to a PGA Gain stage. The differential input structure is essential in noisy digital systems where amplification of low-amplitude analog signals is required in products such as notebooks and PDAs. When properly employed, the differential input architecture offers an improved powersupply rejection ratio (PSRR) and higher ground noise immunity. emPowerAudio™ Datasheet Revision 2.8 Page 17 of 102 March 1, 2017 NAU8810 PGAGAIN[5:0] (0x2D) NMICPGA[1] (0x2C) NMICPGA[1] (0x2C) R MIC- R PGAGAIN[5:0] (0x2D) PMICPGA[0] (0x2C) MIC+ To PGA Boost R -12 dB to +35.25 dB VREF PGAGAIN[5:0] (0x2D) Figure 3: Input PGA Circuit Block Diagram Bit(s) Addr Parameter Programmable Range PMICPGA[0] 0x2C Positive Microphone to PGA 0 = Input PGA Positive terminal to VREF 1 = Input PGA Positive terminal to MICP NMICPGA[1] 0x2C Negative Microphone to PGA 0 = MICN not connected to input PGA 1 = MICN to input PGA Negative terminal. Table 2: Register associated with Input PGA Control 12.1.1.1. Positive Microphone Input (MIC+) The positive microphone input (MIC+) can be used as part of the differential input. It connects to the positive terminal of the PGA gain amplifier by setting PMICPGA[0] address (0x2C) to HIGH or can be connected to VREF by setting PMICPGA[0] address (0x2C) to LOW. In single ended applications where the MIC+ input is used without using MIC-, the PGA gain values will be valid only if the MIC- pin is terminated to a low impedance signal point. This termination should normally be an AC coupled path to signal ground. The non-inverting input impedance is constant regardless of the gain value. The following table gives the nominal input impedance for both inputs. Impedance for specific gain values not listed in this table can be estimated through interpolation between listed values. emPowerAudio™ Datasheet Revision 2.8 Page 18 of 102 March 1, 2017 NAU8810 MIC+ to non-inverting PGA input Nominal Input Impedance MIC- to inverting PGA input Nominal Input Impedance Gain (dB) Impedance (kΩ) Gain (dB) Impedance (kΩ) -12 -9 -6 -3 0 3 6 9 12 18 30 35.25 94 94 94 94 94 94 94 94 94 94 94 94 -12 -9 -6 -3 0 3 6 9 12 18 30 35.25 75 69 63 55 47 39 31 25 19 11 2.9 1.6 Table 3: Microphone Non-Inverting Input Impedances 12.1.1.2. Table 4: Microphone Inverting Input Impedances Negative Microphone Input (MIC-) The negative microphone input (MIC-) may be used as either a differential input in conjunction with MIC+, or as a single ended input. This input connects to the negative terminal of the PGA gain amplifier by setting NMICPGA[1] address (0x2C) to HIGH. When the MIC- is used as a single ended input, MIC+ should be connected to VREF by setting PMICPGA[0] address (0x2C) bit to LOW, or MIC+ may be used as an independent input. When the associated control bit is set logic = 1, the MIC- pin is connected to a resistor of approximately 30kΩ which is tied to VREF. The purpose of the tie to VREF is to reduce any pop or click sound by keeping the DC level of the MIC- pin close to VREF at all times. It is important for a system designer to know that the MIC-input impedance varies as a function of the selected PGA gain. This is normal and expected for a difference amplifier type topology. The above table gives the nominal resistive impedance values for this input over the possible gain range. Impedance for specific gain values not listed in this table can be estimated through interpolation between listed values. 12.1.1.3. PGA Gain Control The PGA amplification is common to both microphone input pins MIC-, MIC+, and enabled by PGAEN[2] address (0x02). It has a range of -12dB to +35.25dB in 0.75dB steps, controlled by PGAGAIN[5:0] address (0x2D). Input PGA gain will not be used when ALC is enabled using ALCEN[8] address (0x20). Addr Bit 8 Bit 7 Bit 6 0x2D 0 PGAZC PGAMT 0x20 ALCEN 0 0 emPowerAudio™ Datasheet Revision 2.8 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 PGAGAIN[5:0] ALCMXGAIN[2:0] Page 19 of 102 Default 0x010 ALCMNGAIN[2:0] 0x038 March 1, 2017 NAU8810 Table 5: Registers associated with ALC and Input PGA Gain Control 12.1.2. PGA Boost / Mixer Stage The boost stage has two inputs connected to the PGA Boost Mixer. Both inputs can be individually connected or disconnected from the PGA Boost Mixer. The boost stage can be enabled by setting BSTEN[4] address (0x02) to HIGH. The following figure shows the PGA Boost stage. PGABST[8] PGAMT[6] (0x2F) (0x2D) Output from PGA Gain To ADC PMICBSTGAIN[6:4] (0x2F) MIC+ Pin Figure 4: Boost Stage Block Diagram The signal from the PGA stage to the PGA Boost Mixer is disconnected or muted by setting PGAMT[6] address (0x2D) to HIGH. In this path, the PGA boost can be a fixed value of +20dB or 0dB, controlled by the PGABST[8] address (0x2F) bit. The signal from MIC+ pin to the PGA Boost Mixer is disconnected by setting ‘000’ binary value to PMICBSTGAIN[6:4] address (0x2F) and any other combination connects the path. Bit(s) Addr Parameter Programmable Range BSTEN[4] 0x02 Enable PGA Boost Block 0 = Boost stage OFF 1 = Boost stage ON PGAMT[6] 0x2D Mute control for input PGA 0=Input PGA not muted 1=Input PGA muted PMICBSTGAIN[6:4] 0x2F Boost MIC+ signal Range: -12dB to +6dB @ 3dB increment PGABST[8] 0x2F Boost PGA stage 0 = PGA output has +0dB 1 = PGA output has +20dB Table 6: Registers associated with PGA Boost Stage Control emPowerAudio™ Datasheet Revision 2.8 Page 20 of 102 March 1, 2017 NAU8810 12.2. MICROPHONE BIASING MICBIASM[0] (0x28) VREF MICBIAS R R MICBIASV[1:0] (0x2C) Figure 5: Microphone Bias Schematic The MICBIAS pin is a low-noise microphone bias source for an external microphone, and it can provide a maximum of 3mA of bias current. This DC bias voltage either is suitable for powering traditional ECM (electret) type microphones, or for MEMS types microphones with an independent power supply pin. Seven different bias voltages are available for optimum system performance, depending on the specific application. The microphone bias pin normally requires an external filtering capacitor as shown on the schematic in the Application section. The output bias can be enabled by setting MICBIASEN[4] address (0x01) to HIGH. It has various voltage values selected by a combination of bits MICBIASM[4] address (0x3A) and MICBIASV[8:7] address (0x2C). The low-noise feature results in greatly reduced noise in the external MICBIAS voltage by placing an internal resistor of approximately 200-ohms in series with the output pin. This creates a low pass filter in conjunction with the external microphone-bias filter capacitor, but without any other additional external components. Bit(s) Addr Parameter MICBIASEN[4] 0x01 MICBIASM[4] (0x3A) Microphone bias mode selection MICBIASV[8:7] (0x2C) Microphone bias voltage selection Microphone bias enable Programmable Range 0 = Disable 1 = Enable 0 = Disable 1 = Enable Table 7: Register associated with Microphone Bias Below are the unloaded values when MICBIASM[4] is set to 1 and 0. When loaded, the series resistor will cause the voltage to drop, depending on the load current. emPowerAudio™ Datasheet Revision 2.8 Page 21 of 102 March 1, 2017 NAU8810 Microphone Bias Voltage Control MICBIASV[8:7] MICBIASM[4] = 0 MICBIASM[4]= 1 0 0 0.9* VDDA 0.85* VDDA 0 1 0.65* VDDA 0.60* VDDA 1 0 0.75* VDDA 0.70* VDDA 1 1 0.50* VDDA 0.50* VDDA Table 8: Microphone Bias Voltage Control 12.3. ADC DIGITAL FILTER BLOCK ADC Digital Filters ADC Digital Decimator Digital Filter / Gain 5-Band Equalizer High Pass Filter Notch Filter Digital Audio Interface Figure 6: ADC Digital Filter Path Block Diagram The ADC digital filter block performs a 24-bit signal processing. The block consists of an oversampled analog sigma-delta modulator, digital decimator, digital filter, 5-band graphic equalizer, high pass filter, and a notch filter. For digital decimator and 5-band graphic equalizer details, refer to “Output Signal Path”. The oversampled analog sigma-delta modulator provides a bit stream to the decimation stages and filter. The ADC coding scheme is in twos-complement format, and the full-scale input level is proportional to VDDA. With a 3.3V supply voltage, the full-scale level is 1.0VRMS and any voltage greater than full scale may overload the ADC and cause distortion. The ADC is enabled by setting ADCEN[0] address (0x02) bit. Polarity and oversampling rate of the ADC output signal can be changed by ADCPL[0] address (0x0E) and ADCOS[3] address (0x0E) respectively. emPowerAudio™ Datasheet Revision 2.8 Page 22 of 102 March 1, 2017 NAU8810 Bit(s) Addr Parameter Programmable Range ADCPL[0] 0x0E ADCOS[3] 0x0E HPFEN[8] 0x0E HPFAM[7] 0x0E Audio or Application Mode 0 = Audio (1st order, fc ~ 3.7 kHz) 1 = Application (2nd order, fc =HPF) HPF[6:4] 0x0E High Pass Filter frequencies 82 Hz to 612 Hz depending on the sample rate ADCEN[0] 0x02 Enable ADC 0 = Disable 1 = Enable SMPLR[3:1] 0x07 Sample rate 8k Hz to 48 kHz 0 = Normal 1 = Inverted ADC Polarity 0=64x (Lowest power) 1=128x (best SNR at typical condition) ADC Over Sample Rate High Pass Filter Enable 0 = Disable 1 = Enable Table 9: Register associated with ADC 12.3.1. Programmable High Pass Filter (HPF) The high pass filter (HPF) has two different operational modes set by bit HPFAM[7] at address (0x0E). In Audio Mode (HPFAM=0), the filter is first order, with a cut-off frequency of 3.7Hz. In Application mode (HPFAM=1), the filter is second order, with a cut-off frequency selectable via the HPF[2:0] register bits. Cut-off frequency of the HPF depends on sample frequency selected by SMPLR[3:1] address (0x07). The HPF is enabled by setting HPFEN[8] address (0x0E) to HIGH. Table below shows the cut-off frequencies with different sampling rates. HPF[2:0] 8 SMPLR=101/100 11.025 12 fs (kHz) SMPLR=011/010 16 22.05 24 SMPLR=001/000 32 44.1 48 000 82 113 122 82 113 122 82 113 122 001 102 141 153 102 141 153 102 141 153 010 131 180 156 131 180 156 131 180 156 011 163 225 245 163 225 245 163 225 245 100 204 281 306 204 281 306 204 281 306 101 261 360 392 261 360 392 261 360 392 110 327 450 490 327 450 490 327 450 490 111 408 563 612 408 563 612 408 563 612 Table 10: High Pass Filter Cut-off Frequencies (HPFAM=1) emPowerAudio™ Datasheet Revision 2.8 Page 23 of 102 March 1, 2017 NAU8810 12.3.2. Programmable Notch Filter (NF) The NAU88U10 has a programmable notch filter which passes all frequencies except those in a stop band centered on a given center frequency. The filter gives lower distortion and flattens response. The notch filter is enabled by setting NFCEN[7] address (0x1B) to HIGH. The variable center frequency is programmed by setting two’s complement values to NFCA0[6:0] address (0x1C), NFCA0[13:7] address (0x1B) and NFCA1[6:0] address (0x1E), NFCA1[13:7] address (0x1D) registers. The coefficients are updated in the circuit when the NFCU[8] bit is set HIGH in a write to any of the registers NF1-NF4 address (0x1B, 0x1C, 0x1D, 0x1E). Addr Bit 8 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Default 0x1B NFCU NFCEN NFCA0[13:7] 0x000 0x1C NFCU 0 NFCA0[6:0] 0x000 0x1D NFCU 0 NFCA1[13:7] 0x000 0x1E NFCU 0 NFCA1[6:0] 0x000 Table 11: Registers associated with Notch Filter Function A0 Coefficient A1  2  fb 1  tan   2 fs   2  fb 1  tan   2 fs           1  A0   2  fc   x cos   fs   Notation Register Value (DEC) fc = center frequency (Hz) fb = -3dB bandwidth (Hz) fs = sample frequency (Hz) NFCA0 = -A0 x 213 NFCA1 = -A1 x 212 (then convert to 2’s complement) Table 12: Equations to Calculate Notch Filter Coefficients 12.3.3. Digital ADC Gain Control The digital ADC can be muted by setting “0000 0000” to ADCGAIN[7:0] address (0x0F). Any other combination digitally attenuates the ADC output signal in the range -127dB to 0dB in 0.5dB increments]. Addr Name Bit 8 0x0F ADCG 0 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 ADCGAIN Bit 1 Bit 0 Default 0x0FF Table 13: Register associated with ADC Gain emPowerAudio™ Datasheet Revision 2.8 Page 24 of 102 March 1, 2017 NAU8810 12.4. PROGRAMMABLE GAIN AMPLIFIER (PGA) NAU88U10 has a programmable gain amplifier (PGA) which controls the gain under program control, or automatically supporting either of these two features:  Automatic level control (ALC) or  Input peak limiter The Automatic Level Control (ALC) seeks to control the PGA gain in response to the amplitude of the input signal such that the PGA output maintains a relatively constant level. The peak limiter simply prevents the output signal from exceeding a specified level. 12.4.1. Automatic level control (ALC) The ALC seeks to control the PGA gain such that the PGA output maintains a constant envelope. This helps to prevent clipping at the input of the sigma delta ADC while maximizing the full dynamic range of the ADC. The ALC monitors the output of the ADC, and adjusts the PGA gain as required. The ADC output is fed into a peak detector, which updates the measured peak value whenever the absolute value of the input signal is higher than the current measured peak. The measured peak gradually decays to zero unless a new peak is detected, allowing for an accurate measurement of the signal envelope. Based on a comparison between the measured peak value and the target value, the ALC block adjusts the gain control, which is fed back to the PGA. Rate Convert/ Decimator Input Pin PGA ADC Sinc Filter Digital Decimator Digital Filter ALC Figure 7: ALC Block Diagram The ALC is enabled by setting ALCEN[8] address (0x20) bit to HIGH. The ALC has two functional modes, which is set by ALCM[8] address (0x22).  Normal mode (ALCM = LOW)  Peak Limiter mode (ALCM = HIGH) emPowerAudio™ Datasheet Revision 2.8 Page 25 of 102 March 1, 2017 NAU8810 When the ALC is disabled, the input PGA remains at the last controlled value of the ALC. An input gain update must be made by writing to the PGAGAIN[5:0] address (0x2D). A digital peak detector monitors the input signal amplitude and compares it to a register defined threshold level ALCSL[3:0] address (0x21). Output Level Blue Green Red Input < noise gate threshold Original Input signal (linear line from zero to maximum) PGA gain value over time (inverse to signal in target range) Output signal (held to a constant value in target range) ALC operation range Target ALCSL -6dB Gain (Attenuation) Clipped at ALCMNGAIN -12dB +33 dB PGA Gain 0 dB -12 dB ALCNEN = 1 ALCNTH = -39dB MIC Boost Gain = 0dB ALCSL = -6dB ALCMNGAIN = -12dB ALCMXGAIN = +35.25dB -39dB -39dB -6dB +6dB Input Level Figure 8: ALC Response Graph The registers listed in the following section allow configuration of ALC operation with respect to:  ALC target level  Gain increment and decrement rates  Minimum and maximum PGA gain values for ALC operating range  Hold time before gain increments in response to input signal  Inhibition of gain increment during noise inputs  Limiter mode operation emPowerAudio™ Datasheet Revision 2.8 Page 26 of 102 March 1, 2017 NAU8810 Bit(s) Addr ALCMNGAIN[2:0] Parameter Programmable Range Minimum Gain of PGA Range: -12dB to +30dB @ 6dB increment Maximum Gain of PGA Range: -6.75dB to +35.25dB @ 6dB increment ALCEN[8] Enable ALC function 0 = Disable 1 = Enable ALCSL[3:0] ALC Target Range: -28.5dB to -6dB @ 1.5dB increment ALC Hold Time Range: 0ms to 1s, time doubles with every step) ALCZC[8] ALC Zero Crossing 0 = Disable 1 = Enable ALCATK[3:0] ALC Attack time ALCM=0 - Range: 125us to 128ms ALCM=1 - Range: 31us to 32ms (time doubles with every step) ALC Decay time ALCM=0 - Range: 500us to 512ms ALCM=1 - Range: 125us to 128ms (Both ALC time doubles with every step) ALC Select 0 = ALC mode 1 = Limiter mode ALCMXGAIN[2:0] ALCHT[3:0] 0x20 0x21 0x22 ALCDCY[3:0] ALCM[8] Table 14: Registers associated with ALC Control The operating range of the ALC is set by ALCMXGAIN[5:3] address (0x20) and ALCMNGAIN[2:0] address (0x20) bits such that the PGA gain generated by the ALC is between the programmed minimum and maximum levels. When the ALC is enabled, the PGA gain is disabled. In Normal mode, the ALCMXGAIN bits set the maximum level for the PGA in the ALC mode but in the Limiter mode ALCMXGAIN has no effect because the maximum level is set by the initial PGA gain setting upon enabling of the ALC. ALCMAXGAIN Maximum Gain (dB) ALCMINGAIN Minimum Gain (dB) 111 110 35.25 29.25 000 001 -12 -6 ALC Max Gain Range 35.25dB to -6dB @ 6dB increments 001 000 -0.75 -6.75 ALC Min Gain Range -12dB to 30dB @ 6dB increments 110 111 24 30 Table 15: ALC Maximum and Minimum Gain Values emPowerAudio™ Datasheet Revision 2.8 Page 27 of 102 March 1, 2017 NAU8810 12.4.1.1. Normal Mode Normal mode is selected when ALCM[8] address (0x22) is set LOW and the ALC is enabled by setting ALCEN[8] address (0x20) HIGH. This block adjusts the PGA gain setting up and down in response to the input level. A peak detector circuit measures the envelope of the input signal and compares it to the target level set by ALCSL[3:0] address (0x21). The ALC increases the gain when the measured envelope is greater than the target and decreases the gain when the measured envelope is less than - 1.5dB. The following waveform illustrates the behavior of the ALC. PGA Input PGA Output PGA Gain Figure 9: ALC Normal Mode Operation 12.4.1.2. ALC Hold Time (Normal mode Only) The hold parameter ALCHT[3:0] configures the time between detection of the input signal envelope being outside of the target range and the actual gain increase. Input signals with different characteristics (e.g., voice vs. music) may require different settings for this parameter for optimal performance. Increasing the ALC hold time prevents the ALC from reacting too quickly to brief periods of silence such as those that may appear in music recordings; having a shorter hold time, on the other hand, may be useful in voice applications where a faster reaction time helps to adjust the volume setting for speakers with different volumes. The waveform below shows the operation of the ALCHT parameter. emPowerAudio™ Datasheet Revision 2.8 Page 28 of 102 March 1, 2017 NAU8810 PGA Input PGA Output PGA Gain Hold Delay Change Figure 10: ALC Hold Time 12.4.2. Peak Limiter Mode Peak Limiter mode is selected when ALCM[8] address (0x22) is set to HIGH and the ALC is enabled by setting ALCEN[8] address (0x20). In limiter mode, the PGA gain is constrained to be less than or equal to the gain setting at the time the limiter mode is enabled. In addition, attack and decay times are faster in limiter mode than in normal mode as indicated by the different lookup tables for these parameters for limiter mode. The following waveform illustrates the behavior of the ALC in Limiter mode in response to changes in various ALC parameters. PGA Input PGA Output PGA Gain Limiter Enabled Figure 11: ALC Limiter Mode Operations When the input signal exceeds 87.5% of full scale, the ALC block ramps down the PGA gain at the maximum attack rate (ALCATK=0000), regardless of the mode and attack rate settings until the ADC output level has been reduced below this threshold. This minimizes ADC clipping, if there is a sudden increase in the input signal level. emPowerAudio™ Datasheet Revision 2.8 Page 29 of 102 March 1, 2017 NAU8810 12.4.3. Attack Time When the absolute value of the ADC output exceeds the level set by the ALC threshold, ALCSL[3:0] address (0x21), attack mode is initiated at a rate controlled by the attack rate register ALCATK[3:0] address (0x22). The peak detector in the ALC block loads the ADC output value when the absolute value of the ADC output exceeds the current measured peak; otherwise, the peak decays towards zero, until a new peak has been identified. This sequence is continuously running. If the peak is ever below the target threshold, then there is no gain decrease at the next attack timer time; if it is ever above the target-1.5dB, then there is no gain increase at the next decay timer time. 12.4.4. Decay Times The decay time ALCDCY[6:4] address (0x22) is the time constant used when the gain is increasing. In limiter mode, the time constants are faster than in ALC mode. 12.4.5. Noise gate (normal mode only) A noise gate may be used to limit the ALC gain when there is no input signal, or a signal less than the noise gate threshold. This noise from excess input gain, when there is no useful signal to amplify. The noise gate is enabled by setting ALCNEN[3] address (0x23) to HIGH. It does not remove noise from the signal. The noise gate threshold ALCNTH[2:0] address (0x23) is set to a desired level so when there is no signal or a very quiet signal (pause), which is composed mostly of noise, the ALC holds the gain constant instead of amplifying the signal towards the target threshold. The noise gate only operates in conjunction with the ALC and ONLY in Normal mode. The noise gate flag is asserted when (Signal at ADC – PGA gain – MIC Boost gain) < ALCNTH (ALC Noise Gate Threshold) (dB) Levels at the extremes of the range may cause inappropriate operation, so care should be taken when setting up the function. PGA Input PGA Output PGA Gain Figure 12: ALC Operation with Noise Gate disabled emPowerAudio™ Datasheet Revision 2.8 Page 30 of 102 March 1, 2017 NAU8810 PGA Input Noise Gate Threshold PGA Output PGA Gain Figure 13: ALC Operation with Noise Gate Enabled 12.4.6. Zero Crossing The PGA gain comes from either the ALC block when the ALC is enabled, or directly from the PGA gain register setting when the ALC is disabled. Zero crossing detection may be enabled to force PGA gain changes to occur only at an input zero crossing events. Enabling zero crossing detection limits clicks and pops that will occur if the gain changes while the input signal is at a voltage that is significantly higher or lower than zero. There are two zero crossing detection enables:  Register ALCZC[8] address (0x21) – is only relevant when the ALC is enabled.  Register PGAZC[7] address (0x2D) – is only relevant when the ALC is disabled. If the zero crossing function is enabled (using either register) and SCLKEN[0] address (0x07) is asserted, the zero cross timeout function may take effect. If the zero crossing flag does not change polarity within 0.25 seconds of a PGA gain update (either via ALC update or PGA gain register update), then the gain will update automatically. This backup system prevents the gain from locking up if the input signal has a small swing and/or a DC offset that prevents the zero crossing flag from triggering. emPowerAudio™ Datasheet Revision 2.8 Page 31 of 102 March 1, 2017 NAU8810 12.5. DAC DIGITAL FILTER BLOCK DAC Digital Filters Digital Audio Interface Digital Gain Digital Peak Limiter 5-Band Equalizer Digital Filters Interpolation Sigma Delta Modulator DAC Figure 14: DAC Digital Filter Path The DAC digital block uses 24-bit signal processing to generate analog audio using data from the audio data bus or from the ADC output. This block consists of a sigma-delta modulator, 5-band graphic equalizer, high pass filter, digital gain/filters, de-emphasis, and analog mixers. The DAC coding scheme is in twos complement format and the full-scale output level is proportional to VDDA. With a 3.3V supply voltage, the full-scale output level is 1.0VRMS. The DAC is enabled by setting DACEN[0] address (0x03) bit HIGH. Bit(s) Addr Parameter Programmable Range DACEN[0] 0x03 DAC enable 0 = Disable 1 = Enable ADDAP[0] 0x05 Pass-through of ADC output data into DAC input 0 = Disable 1 = Enable DACPL[0] DAC Polarity 0 = No Inversion 1 = DAC Output Inverted AUTOMT[2] Auto Mute 0 = Disable 1 = Enable DEEMP[5:4] Sample Rate 32 kHz, 44.1 kHz, and 48 kHz DACMT[6] Soft Mute 0 = Disable 1 = Enable DAC Volume Control Range: -127dB to 0dB @ 0.5dB increment, 00 hex is Muted DAC Limiter Attack Range: 68us to 139ms DAC Limiter Decay Range: 544us to 1.1s DAC Limiter Enable 0 = Disable 1 = Enable DAC Limiter Volume Boost Range: 0dB to +12dB @ 1dB increment DAC Limiter Threshold Range: -6dB to -1bB @ 1dB increment 0x0A DACGAIN[7:0] 0x0B DACLIMATK[3:0] DACLIMDCY[7:4] 0x18 DACLIMEN[8] DACLIMBST[3:0] 0x19 DACLIMTHL[6:4] Table 16: Registers associated with DAC Gain Control emPowerAudio™ Datasheet Revision 2.8 Page 32 of 102 March 1, 2017 NAU8810 12.5.1. DAC Soft Mute The NAU88U10 also has a Soft Mute function, which smoothly attenuates the volume of the digital signal to zero. When un-muted, the gain will ramp back up to the register determined digital gain setting. This feature provides a tool that is useful to enable/disable DAC output without introducing pop and click sounds. To output any DAC signal, Soft Mute must be disabled by setting the DACMT[6] address (0x0A) bit to LOW. 12.5.2. DAC Auto Mute The output of the DAC can also be muted by the analog Auto Mute function. The Auto Mute function is enabled by setting AUTOMT[2] address (0x0A) to HIGH and applied to the DAC output when there are 1024 or more consecutive zeros at its input. If at any time there is a non-zero DAC input sample value, the DAC will be unmuted, and the 1024 count will be reinitialized to zero. 12.5.3. DAC Sampling / Oversampling rate, Polarity, DAC Volume control and Digital Passthrough The sampling rate of the DAC is determined entirely by the frequency of its input clock and the oversampling rate setting. The oversampling rate of the DAC can be changed to 64x or 128x. In the 128x oversampling mode, audio performance is improved at slightly higher power consumption. Because the additional supply current is only 1mA, in most applications, the 128x oversampling is preferred for maximum audio performance. The polarity of the DAC output signal can be changed as a feature, and this can useful in management of the audio phase. This feature can help minimize audio processing that may be otherwise required as the data are passed to other stages in the system. The effective output audio volume of the DAC can be changed using the digital volume control feature. This processes the output of the DAC to scale the output by the amount indicated in the volume register setting. Included is a “digital mute” value, which will completely mute the signal output of the DAC. The digital volume setting can range from 0dB through -127dB in 0.5dB steps. Digital audio pass-through allows the output of the ADC to be directly sent to the DAC as the input signal to the DAC for DAC output. In this mode of operation, the external digital audio signal for the DAC will be ignored. The pass-through function is useful for many test and application purposes, and the DAC output may be utilized in any way that is normally supported for the DAC analog output signals. emPowerAudio™ Datasheet Revision 2.8 Page 33 of 102 March 1, 2017 NAU8810 12.5.4. Hi-Fi DAC De-Emphasis and Gain Control The NAU88U10 has Hi-Fi DAC gain control for signal conditioning. The level of attenuation for an eight-bit code X is given by: for 1 ≤ X ≤ 255; 0.5 × (X-255) dB MUTE for X = 0 It includes on-chip digital de-emphasis and is available for sample rates of 32 kHz, 44.1 kHz, and 48 kHz. The digital de-emphasis can be enabled by setting DEEMP[5:4] address (0x0A) bits depending on the input sample rate. The de-emphasis feature is included to accommodate audio recordings that utilize 50/15 s pre-emphasis equalization as a means of noise reduction. 12.5.5. Digital DAC Output Peak Limiter Output Peak-Limiters optimize the dynamic range by ensuring the signal will not exceed a certain threshold, while maximizing the RMS of the resulted audio signal, and minimizing audible distortions. NAU88U10 has a digital output limiter function. The operation of this is shown in figure below. In this diagram, the upper graph shows the envelope of the input/output signals and the lower graph shows the gain characteristic. The limiter has a programmable threshold, DACLIMTHL[6:4] address (0x19), which ranges from -1dB to -6dB in 1dB increments. The digital peak limiter seeks to keep the envelope of the output signal within the target threshold +/- 0.5dB. The attack and decay rates programmed in registers DACLIMATK[3:0] address (0x18) and DACLIMDCY[7:4] address (0x18) specify how fast the digital peak limiter decrease and increase the gain, respectively, in response to the envelope of the output signal falling outside of this range. In normal operation LIMBST=000 signals below this threshold are unaffected by the limiter. DAC Input Data Threshold -1dB DAC Output Signal 0dB Digital Gain -0.5dB -1dB Figure 15: DAC Digital Limiter Control 12.5.6. Volume Boost emPowerAudio™ Datasheet Revision 2.8 Page 34 of 102 March 1, 2017 NAU8810 The limiter has programmable upper gain, which boosts signals below the threshold to compress the dynamic range of the signal and increase its perceived loudness. This operates as an ALC function with limited boost capability. The volume boost is from 0dB to +12dB in 1dB steps, controlled by the DACLIMBST[3:0] register bits. The output limiter volume boost can also be used as a stand-alone digital gain boost when the limiter is disabled. 12.5.7. 5-Band Equalizer NAU88U10 features 5-band graphic equalizer with low distortion, low noise, and wide dynamic range, and is an ideal choice for Hi-Fi applications. All five bands are fully parametric with independently adjustable bandwidth that displays exceptional tonal qualities. Each of the five bands offers +/- 12dB of boost and cut with 1dB resolution. The five bands are divided in to three sections Low, Mid and High bands. The High and the Low bands are shelving filters and the mid three are peak filters. The equalizer can be applied to the ADC or DAC path under control of the EQM[8] address (0x12) register bit. Bit(s) Address EQM[8] EQ1CF[6:5] Parameter Programmable Range Equalizer Enable Band 1 Cut-off Frequency Range: 80 Hz to 175 Hz EQ1GC[4:0] Band 1 Gain Control Range: -12 dB to +12 dB @ 1.0dB increment EQ2BW[8] Band 2 Equalizer Bandwidth Narrow or Wide Band 2 Centre Frequency Range: 230 Hz to 500 Hz EQ2GC[4:0] Band 2 Gain Control Range: -12 dB to +12 dB @ 1.0dB increment EQ2BW[8] Band 3 Equalizer Bandwidth Narrow or Wide Band 3 Centre Frequency Range: 650 Hz to 1.4 kHz EQ3GC[4:0] Band 3 Gain Control Range: -12 dB to +12 dB @ 1.0dB increment EQ4BW[8] Band 4 Equalizer Bandwidth Narrow or Wide Band 4 Centre Frequency Range: 1.8 kHz to 4.1 kHz Band 4 Gain Control Range: -12 dB to +12 dB @ 1.0dB increment Band 5 Cut-off Frequency Range: 5.3 kHz to 11.7 kHz Band 5 Gain Control Range: -12 dB to +12 dB @ 1.0dB increment EQ2CF[6:5] EQ3CF[6:5] EQ4CF[6:5] 0x12 0x13 0x14 0x15 EQ4GC[4:0] EQ5CF[6:5] 0x16 EQ5GC[4:0] Table 17: Registers associated with Equalizer Control emPowerAudio™ Datasheet Revision 2.8 Page 35 of 102 March 1, 2017 NAU8810 12.6. ANALOG OUTPUTS The NAU88U10 features two different types of outputs, a single-ended or differential Mono output (MOUT) and a differential speaker outputs (SPKOUT+ and SPKOUT-). The speaker amplifiers designed to drive a load differentially; a configuration referred to as Bridge-Tied Load (BTL). MOUTBST[3] (0x31) Output from Auxiliary Amplifier VDDSPK MOUTMXEN[3] (0x03) DACOUT[0] (0x38) DAC Output MOUT MONO MIXER MOUTBST GAIN 0 1.0x 1 1.5x DC output 1.0 x VREF 1.5 x VREF -10dB or +0dB SIDETONE Output from PGA Boost VSSSPK VDDSPK Zero Cross Detection SPEAKER MIXER -1 SPKOUTSPKBST GAIN 0 1.0x 1 1.5x DC output 1.0 x VREF 1.5 x VREF SPKOUT+ -10dB or 0dB SPKMXEN[2] (0x03) SPKVOL[5:0] (0x36) Zero Cross Detection Buffer SPKBST[2] (0x31) VSSSPK Figure 16: Speaker and MONO Analogue Outputs [To Update ? output from Auxiliary Amplifier] Important: For analog outputs depopping purpose, when powering up speakers, headphone, AUXOUTs, certain delays are generated after enabling sequence. However, the delays are created by MCLK and sample rate register. For correct operation, sending I2S signal no earlier than 250ms after speaker or headphone enabled and MCLK appearing 12.6.1. Speaker Mixer Outputs The speaker amplifiers are designed to drive a load differentially; a configuration referred to as Bridge-Tied Load (BTL). The differential speaker outputs can drive a single 8Ω speaker or two headphone loads of 16Ω or higher, including differential line output applications. Driving the load differentially doubles the output voltage. The output of the speaker can be manipulated by changing attenuation and the volume (loudness of the output signal). The output stage is powered by the speaker supply, VDDSPK, which are capable of driving up to 1.5VRMS signals (equivalent to 3VRMS into a BTL speaker). The speaker outputs can be controlled and can be muted individually. The output pins are at reference DC level when the output is muted. emPowerAudio™ Datasheet Revision 2.8 Page 36 of 102 March 1, 2017 NAU8810 Bit(s) Addr Parameter Programmable Range SPKMXEN[2] 0x03 Speaker Mixer enable 0 – Disabled 1 – Enabled PSPKEN[5] 0x03 Speaker positive terminal enable 0 – Disabled 1 – Enabled NSPKEN[6] 0x03 Speaker negative terminal enable 0 – Disabled 1 – Enabled SPKATT[1] 0x28 Speaker output attenuation 0 - 0dB 1 - -10dB SPKBST[2] 0x31 Speaker output Boost 0 – (1.0x VREF) Boost 1- (1.5 x VREF) Boost SPKGAIN[5:0] 0x36 Speaker output Volume Range: -57dB to +6dB @ 6dB increment SPKMT[6] 0x36 Speaker output Mute 0 – Speaker Enabled 1 – Speaker Muted Table 18: Speaker Output Controls 12.6.2. Mono Mixer Output The single ended output can drive headphone loads of 16Ω or 32Ω or a line output. The MOUT can be manipulated by changing attenuation and the volume (loudness of the output signal). The output stage is powered by the speaker supply, VDDSPK, which are capable of driving up to 1.5VRMS signals. The Mono output can be enabled for signal output or muted. The output pins are at reference DC level when the output is muted. Bit(s) Addr Parameter Programmable Range MOUTMXEN[3] 0x03 MONO mixer enable 0 – Disabled 1 – Enabled MOUTEN[7] 0x03 MONO output enable 0 – Disabled 1 – Enabled MOUTATT[2] 0x28 MONO output attenuation 0 - 0dB 1 - -10dB MOUTBST[3] 0x31 MONO output boost 0 – (1.0x VREF) Boost 1 - (1.5 x VREF) Boost MOUTMXMT[6] 0x38 MONO Output Mixer Mute 0 – MONO Mixer Normal Mode 1 – MONO Mixer Muted MOUTMT[4] 0x45 MONO Output Mute 0 – MONO Output Normal Mode 1 – MONO Output Muted Table 19: MONO Output Controls emPowerAudio™ Datasheet Revision 2.8 Page 37 of 102 March 1, 2017 NAU8810 12.6.3. Differential Output Configuration The NAU88U10 features two different types of outputs, a single-ended or differential Mono output (MOUT) and a differential speaker output (SPKOUT+ and SPKOUT-). The speaker amplifiers are designed to drive a load differentially as Bridge-Tied Load (BTL). Three differential output options can be configured from the three output pins: MOUT, SPKOUT+ and SPKOUT. To enable differential outputs, three registers need to be configured accordingly: SPK2MOUT=1 (0x45[5]), AOUTMP=1 (0x31[0]) and 0x4F=0x100. - Option 1: Two differential outputs by using pair of MOUT and SPKOUT-, SPKOUT+ and SPKOUT- for driving both headphone/earpiece and Speaker. Register setting: MOUTEN=1, NSPKEN=1, and PSPKEN =1 - Option 2: One differential output by using MOUT and SPKOUT- for driving headphone/earpiece. Register setting: MOUTEN=1, NSPKEN=1, and PSPKEN =0 - Option 3: One differential output by using SPKOUT+ and SPKOUT- for driving speaker. Register setting: MOUTEN=0, NSPKEN=1 and PSPKEN =1 12.6.4. Unused Analog I/O emPowerAudio™ Datasheet Revision 2.8 Page 38 of 102 March 1, 2017 NAU8810 SMOUT[3] (0x4F) MIC- MOUTBST[3] = 1 (0x31) 30k 1K NMICPGA[1] (0x2C) MIC+ MOUT 30K 40k PMICPGA[0] (0x2C) MOUTBST[3] = 0 (0x31) SPSPK[4] (0x4F) 1.0 x VREF 1K VREF SPKOUT+ SNSPK[5] (0x4F) SBUFH[7] (0x4F) DCBUFEN[8] (0x01) SPKBST[2] = 0 (0x31) SBUFL[6] (0x4F) IOBUFEN[2] (0x01) SPKBST[2] = 1 (0x31) 30K 1K SPKOUT- 1.5 x VREF 30K AOUTIMP[0] (0x31) R R Figure 17: Tie-off Options for the Speaker and MONO output Pins In audio and voice systems, any time there is a sudden change in voltage to an audio signal, an audible pop or click sound may be the result. Systems that change inputs and output configurations dynamically, or which are required to manage low power operation, need special attention to possible pop and click situations. The NAU88U10 includes many features, which may be used to greatly reduce or eliminate pop and click sounds. The most common cause of a pop or click signal is a sudden change to an input or output voltage. This may happen either in a DC coupled system, or in an AC coupled system. The strategy to control pops and clicks is similar for both a DC coupled system and an AC coupled system. The case of the AC coupled system is the most common and the more difficult situation, and therefore, the AC coupled case will be the focus for this information section. When an input or output pin is being used, the DC level of that pin will be very close to half of the VDDA voltage that is present on the VREF pin. The only exception is that when outputs are operated in the 5-Volt mode known as the 1.5x boost condition, then the DC level for those outputs will be equal to 1.5xVREF. In all cases, any input or output capacitors will become charged to the emPowerAudio™ Datasheet Revision 2.8 Page 39 of 102 March 1, 2017 NAU8810 operating voltage of the used input or output pin. The goal to reduce pops and clicks is to insure that the charge voltage on these capacitors does not change suddenly at any time. When an input or output is in a not-used operating condition, it is desirable to keep the DC voltage on that pin at the same voltage level as the DC level of the used operating condition. This is accomplished using special internal DC voltage sources that are at the required DC values. When an input or output is in the not-used condition, it is connected to the correct internal DC voltage as not to have a pop or click. This type of connection is known as a “tie-off” condition. Two internal DC voltage sources are provided for making tie-off connections. One DC level is equal to the VREF voltage value, and the other DC level is equal to 1.5x the VREF value. All inputs are always tied off to the VREF voltage value. Outputs will automatically be tied to either the VREF voltage value or to the 1.5xVREF value, depending on the value of the “boost” control bit for that output. That is to say, when an output is set to the 1.5x gain condition, then that same output will automatically use the 1.5xVREF value for tie-off in the not-used condition. The input pull-ups are connected to IOBUFEN[2] address (0x01) buffer with a voltage source (VREF). The output pull-ups can be connected two different buffers depending on the voltage source. IOBUFEN[2] address (0x01) buffer is enabled if the voltage source is (VREF) and DCBUFEN[8] address (0x01) buffer is enabled if the voltage source is (1.5 x VREF). IOBUFEN[2] address (0x01) buffer is shared between input and output pins. To conserve power, these internal voltage buffers may be enabled/disabled using control register settings. To better manage pops and clicks, there is a choice of impedance of the tie-off connection for unused outputs. The nominal values for this choice are 1kΩ and 30kΩ. The low impedance value will better maintain the desired DC level in the case when there is some leakage on the output capacitor or some DC resistance to ground at the NAU88U10 output pin. A tradeoff in using the low-impedance value is primarily that output capacitors could change more suddenly during power-on and power-off changes. Automatic internal logic determines whether an input or output pin is in the used or un-used condition. This logic function is always active. An output is determined to be in the un-used condition when it is in the disabled unpowered condition, as determined by the power management registers. An input is determined to be in the unused condition when all internal switches connected to that input are in the “open” condition. emPowerAudio™ Datasheet Revision 2.8 Page 40 of 102 March 1, 2017 NAU8810 12.7. GENERAL PURPOSE CONTROL 12.7.1. Slow Timer Clock Addr D8 D7 D6 D5 D4 0x07 0 0 0 0 0 D3 D2 D1 D0 Default SCLKEN 0x000 SMPLR[2:0] Table 20: General Purpose Control An internal Slow Timer Clock is supplied to automatically control features that happen over a relatively long period of time, or time-spans. This enables the NAU88U10 to implement long time-span features without any host/processor management or intervention. The Slow Timer Clock supports automatic time out for the zero-crossing hold off PGA volume changes. If this feature is required, the Slow Timer Clock must be enabled. The Slow Timer Clock is initialized in the disabled state. The Slow Timer Clock rate is derived from MCLK using an integer divider that is compensated for the sample rate as indicated by the register address (0x07). If the sample rate register value precisely matches the actual sample rate, then the internal Slow Timer Clock rate will be a constant value of 128ms. If the actual sample rate is, for example, 44.1kHz and the sample rate selected in register 0x07 is 48kHz, the rate of the Slow Timer Clock will be approximately 10% slower in direct proportion of the actual vs. indicated sample rate. This scale of difference should not be important in relation to the dedicated end uses of the Slow Timer Clock. 12.8. CLOCK GENERATION BLOCK ADCOS[3] (0x0E) f1 MCLK MCLKSEL[7:5] (0x06) fPLL PLLMCLK[4] (0x24) PLL1 R=f2/f1 f2 IMCLK f/N f/4 ADC f/N f/N DAC f/2 DACOS[3] (0x0A) CLKM[8] (0x06) PLL BLOCK BCLKSEL[4:2] (0x06) … GPIO1 /CSb IMCLK/ N IMCLK/ 256 CLKIOEN[0] (0x06) f/N Digital Audio Interface FS BCLK GPIO1PLL[5:4] (0x08) GPIO1SEL[2:0] (0x08) Figure 18: PLL and Clock Select Circuit emPowerAudio™ Datasheet Revision 2.8 Page 41 of 102 March 1, 2017 NAU8810 The NAU88U10 has two basic clock modes that support the ADC and DAC data converters. It can accept external clocks in the slave mode, or in the master mode, it can generate the required clocks from an external reference frequency using an internal PLL (Phase Locked Loop). The internal PLL is a fractional type scaling PLL, and therefore, a very wide range of external reference frequencies can be used to create accurate audio sample rates. Separate from this ADC and DAC clock subsystem, audio data are clocked to and from the NAU88U10 by means of the control logic described in the Digital Audio Interfaces section. The Frame Sync (FS) and Bit Clock (BCLK) pins in the Digital Audio Interface manage the audio bit rate and audio sample rate for this data flow. It is important to understand that the Digital Audio Interface does not determine the sampling rate for the ADC and DAC data converters, and instead, this rate is derived exclusively from the Internal Master Clock (IMCLK). It is therefore a requirement that the Digital Audio Interface and data converters be operated synchronously, and that the FS, BCLK, and IMCLK signals are all derived from a common reference frequency. If these three clocks signals are not synchronous, audio quality will be reduced. The IMCLK is always exactly 256 times the sampling rate of the data converters. IMCLK is output from the Master Clock Prescaler. The prescaler reduces by an integer division factor the input frequency input clock. The source of this input frequency clock is either the external MCLK pin, or the output from the internal PLL Block. Addr D8 D7 D6 D5 D4 0x01 DCBUFEN 0 PLLEN MICBIASEN 0x06 CLKM 0x07 0 0 0 0 0 0x24 0 0 0 0 PLLMCLK 0x25 0 0 0 MCLKSEL[2:0] D3 D2 D1 ABIASEN IOBUFEN BCLKSEL[2:0] PLLN[3:0] PLLK[23:18] Default REFIMP 0 SMPLR[2:0] D0 CLKIOEN 0x140 SCLKEN 0x000 0x008 0x00C 0x26 PLLK[17:9] 0x093 0x27 PLLK[8:0] 0x0E9 Table 21: Registers associated with PLL In Master Mode, the IMCLK signal is used to generate FS and BCLK signals that are driven onto the FS and BCLK pins and input to the Digital Audio Interface. FS is always IMCLK/256 and the duty cycle of FS is automatically adjusted to be correct for the mode selected in the Digital Audio Interface. The frequency of BCLK may optionally be divided to optimize the bit clock rate for the application scenario. In Slave Mode, there is no connection between IMCLK and the FS and BCLK pins. In this mode, FS and BLCK are strictly input pins, and it is the responsibility of the system designer to insure that FS, BCLK, and IMCLK are synchronous and scaled appropriately for the application. emPowerAudio™ Datasheet Revision 2.8 Page 42 of 102 March 1, 2017 NAU8810 12.8.1. Phase Locked Loop (PLL) General description The PLL may be optionally used to multiply an external input clock reference frequency by a high-resolution fractional number. To enable the use of the widest possible range of external reference clocks, the PLL block includes an optional divide-by-two prescaler for the input clock, a fixed divide-by-four scaler on the PLL output, and an additional programmable integer divider that is the Master Clock Prescaler. The high-resolution fraction for the PLL is the ratio of the desired PLL oscillator frequency (f2), and the reference frequency at the PLL input (f1). This can be represented as R = f2/f1, with R in the form of a decimal number: xy.abcdefgh. To program the NAU88U10, this value is separated into an integer portion (“xy”), and a fractional portion, “abcdefgh”. The fractional portion of the multiplier is a value that when represented as a 24-bit binary number (stored in three 9-bit registers on the NAU88U10), very closely matches the exact desired multiplier factor. To keep the PLL within its optimal operating range, the integer portion of the decimal number (“xy”), must be any of the following decimal values: 6, 7, 8, 9, 10, 11, or 12. The input and output dividers outside of the PLL are often helpful to scale frequencies as needed to keep the “xy” value within the required range. In addition, the optimum PLL oscillator frequency is in the range between 90MHz and 100MHz, and thus, it is best to keep f2 within this range. In summary, for any given design, choose: Equations Description IMCLK = (256) * (desired codec sample rate) IMCLK = desired Master Clock f2 = (4 * P * IMCLK) where P is the Master Clock divider integer value; optimal f2: 90MHz< f2 300 uA 161k/595k < 100 uA 40uA 600uA MICBIASEN[4] 500 uA PLLEN[5] 2.5mA Clocks Applied DCBUFEN[8] 80uA x64 - ADCOS= 0 => 2.0mA x128 – ADCOS= 1 => 3.0mA 400uA ADCEN[0] PGAEN[2] 0x02 BSTEN[4] 200 uA X64 (DACOS=0)=>1.6mA x128(DACOS=1)=>1.7mA 400uA DACEN[0] SPKMXEN[2] MOUTMXEN[3] 0x03 200uA NSPKEN[6] 1mA from VDDSPK + 100uA (VDDA = 5V mode) PSPKEN[5] 1mA from VDDSPK + 100uA (VDDA = 5V mode) MOUTEN[7] 100uA Table 30: VDDA 3.3V Supply Current emPowerAudio™ Datasheet Revision 2.8 Page 58 of 102 March 1, 2017 NAU8810 13. REGISTER DESCRIPTION Register Address Register Bits Register Names DEC HEX 0 0 Default D8 D7 D6 D5 Software Reset D4 D3 D2 D1 D0 RESET (SOFTWARE) 000 POWER MANAGEMENT 1 01 Power Management 1 DCBUFEN 0 0 PLLEN MICBIASEN ABIASEN IOBUFEN 2 02 Power Management 2 0 0 0 0 BSTEN 0 PGAEN 3 03 Power Management 3 0 MOUTEN NSPKEN PSPKEN 0 REFIMP 000 0 ADCEN 000 0 DACEN 000 ADCPHS 0 050 ADDAP 000 CLKIOEN 140 SCLKEN 000 DACPL 000 MOUTMXEN SPKMXEN AUDIO CONTROL 4 04 Audio Interface BCLKP FSP 0 0 5 05 Companding 6 06 Clock Control 1 CLKM 7 07 Clock Control 2 0 0 0 10 0A DAC CTRL 0 0 DACMT 11 0B DAC Volume 0 14 0E ADC CTRL 15 0F ADC Volume HPFEN WLEN[1:0] 0 AIFMT[1:0] 0 DACPHS DACCM[1:0] MCLKSEL[2:0] ADCCM[1:0] BCLKSEL[2:0] 0 0 0 SMPLR[2:0] DEEMP[1:0] DACOS AUTOMT 0 DACGAIN HPFAM HPF[2:0] 0FF ADCOS 0 0 0 ADCPL ADCGAIN 100 0FF EQUALISER 18 0x12 EQ1-Low Cutoff EQM 0 EQ1CF[1:0] EQ1GC[4:0] 12C 19 0x13 EQ2-Peak 1 EQ2BW 0 EQ2CF[1:0] EQ2GC[4:0] 02C 20 0x14 EQ3-Peak 2 EQ3BW 0 EQ3CF[1:0] EQ3GC[4:0] 02C 21 0x15 EQ4-Peak3 EQ4BW 0 EQ4CF[1:0] EQ4GC[4:0] 02C 22 0x16 EQ5-High Cutoff 0 0 EQ5CF[1:0] EQ5GC[4:0] 02C DIGITAL TO ANALOG (DAC) LIMITER 24 18 DAC Limiter 1 DACLIMEN 25 19 DAC Limiter 2 0 DACLIMDCY[3:0] 0 DACLIMTHL[2:0] DACLIMATK[3:0] 032 DACLIMBST[3:0] 000 NOTCH FILTER 27 1B Notch Filter High NFCU NFCEN NFCA0[13:7] 000 28 1C Notch Filter Low NFCU 0 NFCA0[6:0] 000 29 1D Notch Filter High NFCU 0 NFCA1[13:7] 000 30 1E NFCU 0 NFCA1[6:0] 000 Notch Filter Low ALC CONTROL 32 20 ALC CTRL 1 ALCEN 33 21 ALC CTRL 2 ALCZC ALCHT[3:0] ALCSL[3:0] 00B 34 22 ALC CTRL 3 ALCM ALCDCY[3:0] ALCATK[3:0] 032 35 23 Noise Gate 0 0 0 0 0 ALCMXGAIN[2:0] 0 0 ALCMNGAIN[2:0] ALCNEN ALCNTH[2:0] 038 000 PLL CONTROL 36 24 PLL N CTRL 0 0 0 37 25 PLL K 1 0 0 0 38 26 PLL K 2 emPowerAudio™ Datasheet Revision 2.8 0 PLLMCLK PLLN[3:0] PLLK[23:18] 00C PLLK[17:9] Page 59 of 102 008 093 March 1, 2017 NAU8810 Register Address Register Bits Register Names DEC HEX 39 27 Default D8 D7 D6 D5 D4 PLL K 3 D3 D2 D1 D0 PLLK[8:0] 0E9 INPUT, OUTPUT & MIXER CONTROL 40 28 Attenuation CTRL 44 2C Input CTRL 45 2D PGA Gain 47 2F ADC Boost 49 31 50 0 0 MICBIASV 0 0 0 0 MOUTATT SPKATT 0 000 0 0 0 0 0 NMICPGA PMICPGA 003 0 PGAZC PGAMT PGAGAIN[5:0] PGABST 0 Output CTRL 0 0 0 0 32 Mixer CTRL 0 0 0 0 54 36 SPKOUT Volume 0 SPKZC SPKMT 56 38 MONO Mixer Control 0 0 MOUTMT PMICBSTGAIN 010 0 0 0 0 100 0 MOUTBST SPKBST TSEN AOUTIMP 002 0 0 0 BYPSPK DACSPK 001 SPKGAIN[5:0] 0 0 0 039 0 BYPMOUT DACMOUT 001 IBADJ 000 LOW POWER CONTROL 58 3A Power Management 4 LPIPBST LPADC LPSPKD LPDAC MICBIASM TRIMREG PCM TIME SLOT & ADCOUT IMPEDANCE OPTION CONTROL 59 3B Time Slot 60 3C ADCOUT Drive TSLOT[8:0] PCMTSEN TRI PCM8BIT PUDOEN PUDPE 000 PUDPS LOUTR PCMB TSLOT[9:8] 020 REGISTER ID 62 3E Silicon Revision 0 1 1 1 0 1 1 1 1 0EF 63 3F 2-Wire ID 0 0 0 0 1 1 0 1 0 01A 64 40 Additional ID 0 1 1 0 0 1 0 1 0 0CA 65 41 Reserved 1 0 0 1 0 0 1 0 0 124 69 45 High Voltage CTRL 0 0 0 0 MOUTMT 0 HVOPU 0 HVOP 001 70 46 ALC Enhancements 1 ALCTBLSEL ALCPKSEL ALCNGSEL 71 47 ALC Enhancements 2 73 49 Additional IF CTRL 0 75 4B Power/Tie-off CTRL 0 76 4C AGC P2P Detector P2PDET ( ONLY) 000 77 4D AGC Peak Detector PDET ( ONLY) 000 78 4E Control and Status 0 0 AMTCTRL HVDET NSGATE AMUTE DMUTE 0 FTDEC 000 79 4F Output tie-off CTRL MANOUTEN SBUFH SBUFL SNSPK SPSPK SMOUT 0 0 0 000 PKLIMEN emPowerAudio™ Datasheet Revision 2.8 0 0 FSERRVAL[1:0] LPSPKA 0 ALCGAINL ( ONLY) 1 1 FSERFLSH FSERRENA 0 1 0 NFDLY DACINMT 0 Page 60 of 102 000 0 0 1 039 PLLLOCKP DACOS256 000 MANVREFH MANVREFM MANVREFL 000 March 1, 2017 NAU8810 13.1. SOFTWARE RESET Addr D8 D7 D6 D5 0x00 D4 D3 D2 D1 D0 Default 0x000 RESET (SOFTWARE) This is device Reset register. Performing a write instruction to this register with any data will reset all the bits in the register map to default. 13.2. POWER MANAGEMENT REGISTERS 13.2.1. Addr Power Management 1 D8 0x01 DCBUFEN D7 D6 D5 0 0 PLLEN D4 D3 D2 MICBIASEN ABIASEN IOBUFEN D1 D0 Default REFIMP[1:0] 0x000 Name Buffer for DC level shifting Enable PLL enable Microphone Bias Enable Analogue amplifier bias control Unused input/output tie off buffer enable Bit DCBUFEN[8] PLLEN[5] MICBIASEN[4] ABIASEN[3] IOBUFEN[2] 0 Disable Disable Disable Disable Disable 1 Enable (required for 1.5x gain) Enable Enable Enable Enable The DCBUFEN[8] address (0x01) is a dedicated buffer for DC level shifting output stages when in 1.5x gain boost configuration. There are three different reference impedance selections to choose from as follows: VREF REFERENCE IMPEDANCE SELECTION (“R” refers to “R” as shown in Figure3) REFIMP[1] REFIMP[0] Mode emPowerAudio™ Datasheet Revision 2.8 0 0 Disable 0 1 R = 80 k 1 0 R = 300 k 1 1 R = 3 k Page 61 of 102 March 1, 2017 NAU8810 13.2.2. Power Management 2 Addr D8 D7 D6 D5 D4 D3 D2 D1 D0 Default 0x02 0 0 0 0 BSTEN 0 PGAEN 0 ADCEN 0x000 13.2.3. Name Input Boost Enable MIC(+/-) PGA Enable ADC Enable Bit BSTEN[4] PGAEN[2] ADCEN[0] 0 Stage Disable Disable Disable 1 Stage Enable Enable Enable Power Management 3 Addr D8 0x03 0 D7 D6 D5 D4 D3 D2 D1 MOUTEN NSPKEN PSPKEN BIASGEN MOUTMXEN SPKMXEN 0 D0 Default DACEN 0x000 Name MOUT Enable SPKOUTEnable SPKOUT+ Enable Bias Enable MONO Mixer Enable Speaker Mixer Enable DAC Enable Bit MOUTEN[7] NSPKEN[6] PSPKEN[5] BIASGEN[4] MOUTMXEN[3] SPKMXEN[2] DACEN[0] 0 Disable Disable Disable Disable Disable Disable Disable 1 Enable Enable Enable Enable Enable Enable Enable 13.3. AUDIO CONTROL REGISTERS 13.3.1. Audio Interface Control Addr D8 D7 0x04 BCLKP FSP D6 D5 WLEN[1:0] D4 D3 AIFMT[1:0] D2 D1 DACPHS ADCPHS D0 Default 0 0x050 The following table explains the PCM control register bits. Name BCLK Polarity Frame Clock Polarity DAC Data ‘right’ or ‘left’ phases of FRAME clock ADC Data ‘right’ or ‘left’ phases of FRAME clock Bit BCLKP[8] FSP[7] DACPHS[2] ADCPHS[1] 0 Normal Normal DAC data appear in ‘left’ phase of FRAME ADC data appear in ‘left’ phase of FRAME 1 Inverted Inverted DAC data appears in ‘right’ phase of FRAME ADC data appears in ‘right’ phase of FRAME There are three different CODEC modes to choose from as follows: emPowerAudio™ Datasheet Revision 2.8 Page 62 of 102 March 1, 2017 NAU8810 Word Length Selection Audio Data Format Select WLEN[6] WLEN[5] Bits AIFMT[4] AIFMT[3] Format 0 0 16 0 0 Right Justified 0 1 20 0 1 Left Justified 1 0 24 1 0 I2 S 1 1 32 1 1 PCM A 13.3.2. Audio Interface Companding Control Addr D8 D7 D6 D5 D4 0x05 0 0 0 CMB8 D3 DACCM[1:0] D2 D1 ADCCM[1:0] D0 Default ADDAP 0x000 The NAU88U10 provides a Digital Loopback ADDAP[0] address (0x05) bit. Setting ADDAP[0] bit to HIGH enables the loopback so that the ADC data can be fed directly into the DAC input. Companding Mode 8-bit word enable CMB8[5] 0 1 Mode normal operation 8-bit operation emPowerAudio™ Datasheet Revision 2.8 DAC Companding Selection ADC Companding Select DACCM[4] DACCM[3] Mode ADCCM[2] ADCCM[1] Mode 0 0 Disabled 0 0 Disabled 0 1 Reserved 0 1 Reserved 1 0 µ-Law 1 0 µ-Law 1 1 A-Law 1 1 A-Law Page 63 of 102 March 1, 2017 NAU8810 13.3.3. Clock Control Register Addr D8 0x06 CLKM D7 D6 D5 D4 MCLKSEL[2:0] D3 D2 BCLKSEL[2:0] Master Clock Selection MCLKSEL [7] MCLKSEL [6] MCLKSEL [5] 0 0 0 0 0 1 0 1 0 0 1 D1 D0 Default CLKIOEN 0x140 0 Bit Clock Select BCLKSEL [4] BCLKSEL [3] BCLKSEL [2] 0 0 0 0 0 1 2 0 1 0 1 3 0 1 1 8 Mode 1  1.5 Mode 1 (BCLK=MCLK) 2 (BCLK=MCLK/2) 4 1 0 0 4 1 0 0  16 1 0 1 6 1 0 1  32 1 1 0 8 1 1 0 Reserved 1  12 1 1 1 Reserved 1 1 Name Source of Internal Clock FRAME and BCLK Bit CLKM[8] CLKIOEN[0] 0 MCLK (PLL Bypassed) Slave Mode 1 MCLK (PLL Output) Master Mode emPowerAudio™ Datasheet Revision 2.8 Page 64 of 102 March 1, 2017 NAU8810 13.3.4. Audio Sample Rate Control Register Addr D8 D7 D6 D5 D4 0x07 0 0 0 0 0 D3 D2 D1 SMPLR[2:0] D0 Default SCLKEN 0x000 The Audio sample rate configures only the coefficients for the internal digital filters to match the actual sample rate. It does not in any way actually set or change the ADC or DAC audio sample rate. Sample Rate Selection SMPLR[3] SMPLR[2] SMPLR[1] Mode (Hz) 0 0 0 48 k 0 0 1 32 k 0 1 0 24 k 0 1 1 16 k 1 0 0 12 k 1 0 1 8k 1 1 0 Reserved 1 1 1 Reserved NAU88U10 provides a slow clock to be used for the zero cross timeout. Slow Clock Enable Bit 13.3.5. SCLKEN[0] 0 MCLK 1 PLL Output (Period 221 * MCLK) DAC Control Register Addr D8 D7 D6 0x0A 0 0 DACMT D5 D4 DEEMP[1:0] D3 D2 DACOS AUTOMT D1 D0 Default 0 DACPL 0x000 Name Soft Mute Enable Over Sample Rate Auto Mute enable Polarity Invert Bit DACMT[6] DACOS[3] AUTOMT[2] DACPL[0] 0 Disable 64x (Lowest power) Disable Normal 1 Enable 128x (best SNR) Enable DAC Output Inverted emPowerAudio™ Datasheet Revision 2.8 Page 65 of 102 March 1, 2017 NAU8810 De-emphasis 13.3.6. DEEMP[5] DEEMP[4] Mode 0 0 No de-emphasis 0 1 32kHz sample rate 1 0 44.1kHz sample rate 1 1 48kHz sample rate DAC Gain Control Register Addr D8 0x0B 0 D7 D6 D5 D4 D3 D2 D1 D0 Default 0x0FF DACGAIN DAC Gain DACGAIN[7:0] Mode (dB) B7 B6 B5 B4 B3 B2 B1 B0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Digital Mute -127.0 0 0 0 0 0 0 1 0 -126.5 0 0 0 0 0 0 1 1 -126.0 DAC Gain Range -127dB to 0dB @ 0.5 increments 13.3.7. 1 1 1 1 1 1 0 0 -1.5 1 1 1 1 1 1 0 1 -1.0 1 1 1 1 1 1 1 0 -0.5 1 1 1 1 1 1 1 1 0.0 ADC Control Register Addr D8 D7 0x0E HPFEN HPFAM Name High Pass Filter Enable Bit HPFEN[8] 0 1 Disable Enable emPowerAudio™ Datasheet Revision 2.8 D6 D5 D4 HPF[2:0] D3 D2 D1 D0 Default ADCOS 0 0 ADCPL 0x100 Audio or Application Mode Over Sample Rate ADC Polarity HPFAM[7] ADCOS[3] ADCPL[0] 64x (Lowest power) Normal 128x (best SNR) Inverted st Audio (1 order, fc ~ 3.7 Hz) nd Application (2 order, fc = HPF) Page 66 of 102 March 1, 2017 NAU8810 High Pass Filter fs ( kHz) HPF[6] HPF[5] HPF[4] B2 B1 B0 0 0 0 0 0 SMPLR=101 SMPLR=100 SMPLR=011 SMPLR=010 8 11.025 12 0 82 113 1 102 141 1 0 131 0 1 1 1 0 0 1 0 1 1 13.3.8. SMPLR=001 SMPLR=000 16 22.05 24 32 44.1 48 122 82 113 153 102 141 122 82 113 122 153 102 141 153 180 156 131 180 156 131 180 156 163 225 245 204 281 306 163 225 245 163 225 245 204 281 306 204 281 306 1 261 360 392 261 360 392 261 360 392 1 0 327 1 1 408 450 490 327 450 490 327 450 490 563 612 408 563 612 408 563 612 ADC Gain Control Register Addr D8 0x0F 0 D7 D6 D5 D4 D3 D2 D1 D0 Default 0x0FF ADCGAIN ADC Gain ADCGAIN[7:0] Mode (dB) B7 B6 B5 B4 B3 B2 B1 B0 0 0 0 0 0 0 0 0 Unused 0 0 0 0 0 0 0 1 -127.0 0 0 0 0 0 0 1 0 -126.5 0 0 0 0 0 0 1 1 -126.0 ADC Gain Range -127dB to 0dB @ 0.5 increments 1 1 1 1 1 1 0 0 -1.5 1 1 1 1 1 1 0 1 -1.0 1 1 1 1 1 1 1 0 -0.5 1 1 1 1 1 1 1 1 0.0 emPowerAudio™ Datasheet Revision 2.8 Page 67 of 102 March 1, 2017 NAU8810 13.4. 5-BAND EQUALIZER CONTROL REGISTERS Address D8 D7 D6 D5 D4 D3 D2 D1 D0 Default 0x12 EQM 0 EQ1CF[1:0] EQ1GC[4:0] 0x12C 0x13 EQ2BW 0 EQ2CF[1:0] EQ2GC[4:0] 0x02C 0x14 EQ3BW 0 EQ3CF[1:0] EQ3GC[4:0] 0x 02C 0x15 EQ4BW 0 EQ4CF[1:0] EQ4GC[4:0] 0x02C 0x16 0 0 EQ5CF[1:0] EQ5GC[4:0] 0x02C Equalizer Gain EQ1GC, EQ2GC, EQ3GC, EQ4GC, EQ5GC [4:0] Mode (dB) B4 B3 B2 B1 B0 0 0 0 0 0 +12 0 0 0 0 1 +11 ::: ::: ::: ::: ::: ::: 0 1 0 1 1 +1 0 1 1 0 0 0 0 1 1 0 1 -1 Equalizer Gain Range -12dB to +12dB @ 1.0 increment ::: ::: ::: ::: ::: ::: 1 0 1 1 1 -11 1 1 0 0 0 -12 1 1 0 0 1 To 1 1 Reserved 1 1 1 Center Frequencies emPowerAudio™ Datasheet Revision 2.8 B1 B0 EQ2CF[6:5] EQ3CF[6:5] EQ4CF[6:5] 0 0 230 650 1.8 k 0 1 300 850 2.4 k 1 0 385 1.1 k 3.2 k 1 1 500 1.4 k 4.1 k Page 68 of 102 March 1, 2017 NAU8810 Cut-off Frequencies EQ5CF[6:5 ] 0 80 5.3 k 1 105 6.9 k 1 0 135 9.0 k 1 1 175 11.7 k B0 0 0 Bandwidth Control Equalizer Path EQ2BW – EQ4BW EQM[8] 0 Narrow bandwidth ADC path 1 Wide bandwidth DAC path Bit 13.5. EQ1CF[6:5] B1 DIGITAL TO ANALOG CONVERTER (DAC) LIMITER REGISTERS Addr D8 D7 0x18 DACLIMEN 0x19 0 D6 D5 D4 D3 DACLIMDCY[3:0] 0 DACLIMTHL[2:0] DAC Limiter Decay time (per 6dB gain change) for 44.1 kHz sampling. Note that these will scale with sample rate D2 D1 D0 Default DACLIMATK[3:0] 0x032 DACLIMBST[3:0] 0x000 DAC Limiter Attack time (per 6dB gain change) for 44.1 kHz sampling. Note that these will scale with sample rate DACLIMDCY[3:0] DACLIMATK[3:0] B3 B2 B1 B0 Decay Time B3 B2 B1 B0 Attack Time 0 0 0 0 544.0 us 0 0 0 0 68 us 0 0 0 1 1.1 ms 0 0 0 1 136 us 0 0 1 0 2.2 ms 0 0 1 0 272 us 0 0 1 1 4.4 ms 0 0 1 1 544 us 0 1 0 0 8.7 ms 0 1 0 0 1.1 ms 0 1 0 1 17.4 ms 0 1 0 1 2.2 ms 0 1 1 0 35.0 ms 0 1 1 0 4.4 ms 0 1 1 1 69.6 ms 0 1 1 1 8.7 ms 1 0 0 0 139.0 ms 1 0 0 0 17.4 ms 1 0 0 1 278.5 ms 1 0 0 1 35 ms 1 0 1 0 557.0 ms 1 0 1 0 69.6 ms 1 0 1 1 1 0 1 1 To 1 1 1.1 s 1 To 1 emPowerAudio™ Datasheet Revision 2.8 1 Page 69 of 102 1 139 ms 1 1 March 1, 2017 NAU8810 DAC Limiter volume Boost (can be used as a standalone volume Boost when DACLIMEN=0) DACLIMBST[3:0] Boost (dB) B3 B2 B1 B0 DAC Limiter Programmable signal threshold level (determines level at which the limiter starts to operate) DACLIMTHL[3:0] B2 B1 B0 Threshold (dB) 0 0 0 -1 0 0 0 0 0 0 0 1 -2 0 0 0 1 +1 0 1 0 -3 0 0 1 0 +2 0 1 1 -4 0 0 1 1 +3 1 0 0 -5 0 1 0 0 +4 1 0 1 0 1 0 1 +5 0 1 1 0 +6 0 1 1 1 +7 1 0 0 0 +8 1 0 0 1 +9 To 1 -6 1 1 1 0 1 0 +10 Bit DAC Digital Limiter DACLIMEN[8] 1 0 1 1 +11 0 Disabled 1 1 0 0 +12 1 Enabled 1 1 0 1 1 1 1 1 Reserved To 13.6. NOTCH FILTER REGISTERS Addr D8 D7 0x1B NFCU NFCEN 0x1C NFCU 0x1D NFCU 0x1E NFCU D6 D5 D4 D3 D2 D1 D0 Default NFCA0[13:7] 0x000 0 NFCA0[6:0] 0x000 0 NFCA1[13:7] 0x000 0 NFCA1[6:0] 0x000 The Notch Filter is enabled by setting NFCEN[7] address (0x1B) bit to HIGH. The coefficients, A0 and A1, should be converted to 2’s complement numbers to determine the register values. A0 and A1 are represented by the register bits NFCA0[13:0] and NFCA1[13:0]. Since there are four register of coefficients, a Notch Filter Update bit is provided so that the coefficients can be updated simultaneously. NFCU[8] is provided in all registers of the Notch Filter coefficients but only one bit needs to be toggled for LOW – HIGH – LOW for an update. If any of the NFCU[8] bits are left HIGH then the Notch Filter coefficients will continuously update. An example of how to calculate is provided in the Notch Filter section. emPowerAudio™ Datasheet Revision 2.8 Page 70 of 102 March 1, 2017 NAU8810 Name A0 A1 Coefficient  2fb 1  tan  2fs  2fb 1  tan  2fs         2f  1  A0  x cos c  fs     Notation Register Value (DEC) fc = center frequency (Hz) fb = -3dB bandwidth (Hz) fs = sample frequency (Hz) NFCA0 = -A0 x 213 NFCA1 = -A1 x 212 (then convert to 2’s complement) 13.7. AUTOMATIC LEVEL CONTROL REGISTER 13.7.1. ALC1 REGISTER Addr D8 D7 D6 0x20 ALCEN 0 0 D5 D4 D3 ALCMXGAIN[2:0] ALCMXGAIN[2:0] B1 B0 0 0 0 0 0 1 0 1 0 1 1 D1 D0 ALCMNGAIN[2:0] Maximum Gain B2 D2 0x038 Minimum Gain ALCMNGAIN[2:0] Mode Mode B2 B1 B0 -6.75dB 0 0 0 -12dB -0.75dB 0 0 1 -6dB 0 +5.25dB 0 1 0 0dB 1 +11.25dB 0 1 1 +6dB 0 0 +17.25dB 1 0 0 +12dB 1 0 1 +23.25dB 1 0 1 +18dB 1 1 0 +29.25dB 1 1 0 +24dB 1 1 1 +35.25dB 1 1 1 +30dB emPowerAudio™ Datasheet Revision 2.8 Default Name ALC Enable Bit ALCEN[8] 0 Disabled (PGA gain set by PGAGAIN register bits) 1 Enabled (ALC controls PGA gain) Page 71 of 102 March 1, 2017 NAU8810 13.7.2. ALC2 REGISTER Addr D8 0x21 ALCZC D7 D6 D5 D4 D3 D2 ALCHT[3:0] D0 Default 0x00B ALCSL[3:0] ALC TARGET – sets signal level at ADC input ALC HOLD TIME before gain is increased. ALCHT[3:0] D1 ALCSL[3:0] B7 B6 B5 B4 ALC Hold Time (sec) B3 B2 B1 B0 ALC Target Level (dB) 0 0 0 0 0 0 0 0 0 -28.5 fs 0 0 0 1 2 ms 0 0 0 1 -27 fs 0 0 1 0 4 ms 0 0 1 0 25.5 fs ALC Target Level Range -28.5dB to -6dB @ 1.5dB increments Time Doubles with every increment 1 0 0 0 256 ms 1 0 1 1 -12 fs 1 0 0 1 512 ms 1 1 0 0 -10.5 fs 1 0 1 0 1 1 0 1 -9 fs 1 1 1 0 -7.5 fs 1 1 1 1 -6 fs To 1 1 1s 1 1 Name ALC Zero Crossing Detect Bit ALCZC[8] 0 Disabled 1 Enabled It is recommended that zero crossing should not be used in conjunction with the ALC or Limiter functions emPowerAudio™ Datasheet Revision 2.8 Page 72 of 102 March 1, 2017 NAU8810 13.7.3. ALC3 REGISTER Addr D8 D7 0x22 ALCM D6 D5 D4 D3 D2 ALCDCY[3:0] D1 D0 Default 0x032 ALCATK[3:0] ALC DECAY TIME ALCDCY[3:0] ALCM = 0 (Normal Mode) ALCM = 1 (Limiter Mode) B3 B2 B1 B0 Per Step Per 6dB 90% of Range Per Step Per 6dB 90% of Range 0 0 0 0 500 us 4 ms 28.78 ms 125 us 1 ms 7.2 ms 0 0 0 1 1 ms 8 ms 57.56 ms 250 us 2 ms 14.4 ms 0 0 1 0 2 ms 16 ms 115 ms 500 us 4 ms 28.8 ms Time doubles with every increment 1 0 0 0 128 ms 1s 7.37 s 32 ms 256 ms 1.8 s 1 0 0 1 256 ms 2s 14.7 s 64 ms 512 ms 3.7 s 1 0 1 0 512 ms 4s 29.5 s 128 ms 1s 7.37 s To 1 1 1 1 ALC ATTACK TIME ALCATK[3:0] ALCM = 0 (Normal Mode) ALCM = 1 (Limiter Mode) 90% of Range Per Step Per 6dB 90% of Range B3 B2 B1 B0 Per Step Per 6dB 0 0 0 0 125 us 1 ms 7.2 ms 31 us 248 us 1.8 ms 0 0 0 1 250 us 2 ms 14.4 ms 62 us 496 us 3.6 ms 0 0 1 0 500 us 4 ms 28.85 ms 124 us 992 us 7.15 ms 1 0 0 0 26.5 ms 256 ms 1.53 s 7.9 ms 63.2 ms 455.8 ms 1 0 0 1 53 ms 512 ms 3.06 s 15.87 ms 127 ms 916 ms 1 0 1 0 128 ms 1s 7.89 s 31.7ms 254 ms 1.83 s 1 1 Time doubles with every increment To 1 1 emPowerAudio™ Datasheet Revision 2.8 Page 73 of 102 March 1, 2017 NAU8810 13.8. NOISE GAIN CONTROL REGISTER Addr D8 D7 D6 D5 D4 D3 0x23 0 0 0 0 0 ALCNEN Noise Gate Enable D2 D1 D0 ALCNTH[2:0] Default 0x000 Noise Gate Threshold Bit ALCNEN[3] 0 Disabled B2 B1 B0 1 Enabled 0 0 0 -39 dB 0 0 1 -45 dB 0 1 0 -51 dB 0 1 1 -57 dB 1 0 0 -63 dB 1 0 1 -69 dB 1 1 0 -75 dB 1 1 1 -81 dB ALCNTH[2:0] Mode emPowerAudio™ Datasheet Revision 2.8 Page 74 of 102 March 1, 2017 NAU8810 13.9. PHASE LOCK LOOP (PLL) REGISTERS 13.9.1. PLL Control Registers Addr D8 D7 D6 D5 D4 0x24 0 0 0 0 PLLMCLK D3 D2 D0 Default 0x008 PLLN[3:0] PLL Integer PLL Clock PLLN[3:0] B3 B2 B1 B0 0 0 0 1 Bit Frequency Ratio PLLMCLK[4] 0 MCLK not divided 1 Divide MCLK by 2 before input PLL Not Valid To 0 1 0 0 0 1 0 1 5 0 1 1 0 6 0 1 1 1 7 1 0 0 0 8 1 0 0 1 9 1 0 1 0 10 1 0 1 1 11 1 1 0 0 12 1 1 0 1 13 1 1 1 0 1 1 1 1 13.9.2. D1 Not Valid Phase Lock Loop Control (PLL) Registers Addr D8 D7 D6 0x25 0 0 0 D5 D4 D3 D2 PLLK[23:18] D1 D0 Default 0x00C 0x26 PLLK[17:9] 0x093 0x27 PLLK[8:0] 0x0E9 Fractional (K) part of PLLK1 – PLLK3 input/output frequency ratio emPowerAudio™ Datasheet Revision 2.8 Page 75 of 102 March 1, 2017 NAU8810 13.10. INPUT, OUTPUT, AND MIXERS CONTROL REGISTER 13.10.1. Attenuation Control Register Addr D8 D7 D6 D5 D4 D3 0x28 0 0 0 0 0 0 D2 D1 MOUTATT SPKATT D0 Default 0 0x000 D0 Default Attenuation Control Attenuation control for bypass path (output of input boost stage) to speaker mixer and MONO mixer input Name MOUTATT[2] Bit 13.10.2. Addr 0x2C SPKATT[1] 0 0 dB 0 dB 1 -10 dB -10 dB Input Signal Control Register D8 D7 MICBIASV D6 D5 D4 D3 D2 0 0 0 0 0 D1 NMICPGA PMICPGA 0x003 MICN to input PGA negative terminal Input PGA amplifier positive terminal to MIC+ or VREF Bit NMICPGA[1] PMICPGA[0] 0 MICN not connected to input PGA Input PGA Positive terminal to VREF 1 MICN to input PGA Negative terminal. Input PGA Positive terminal to MICP through variable resistor Microphone Bias Voltage Control MICBIASV[8:7] Address (0x2C) MICBIASM[4] = 0 Address (0x28) MICBIASM[4] = 1 Address (0x28) 0 0 0.9* VDDA 0.85* VDDA 0 1 0.65* VDDA 0.60* VDDA 1 0 0.75* VDDA 0.70* VDDA 1 1 0.50* VDDA 0.50* VDDA emPowerAudio™ Datasheet Revision 2.8 Page 76 of 102 March 1, 2017 NAU8810 13.10.3. PGA Gain Control Register Addr D8 D7 D6 D5 0x2D 0 PGAZC PGAMT D4 D3 D2 D1 PGAGAIN[5:0] D0 Default 0x010 Programmable Gain Amplifier Gain PGAGAIN[5:0] B5 B4 B3 B2 B1 B0 Gain 0 0 0 0 0 0 -12.00 dB 0 0 0 0 0 1 -11.25 dB 0 0 0 0 1 0 -10.50 dB ::: ::: ::: ::: ::: ::: ::: 0 0 1 1 1 1 -0.75 dB 0 1 0 0 0 0 0 dB 0 1 0 0 0 1 +0.75 dB PGA Gain Range -12dB to +35.25dB @ 0.75 increment ::: ::: ::: ::: ::: ::: ::: 1 1 1 1 0 1 33.75 1 1 1 1 1 0 34.50 1 1 1 1 1 1 35.25 PGA Zero Cross Enable Mute Control for PGA Bit PGAZC[7] PGAMT[6] 0 Update gain when gain register changes Normal Mode st 1 emPowerAudio™ Datasheet Revision 2.8 Update gain on 1 zero cross after gain register write Page 77 of 102 PGA Muted March 1, 2017 NAU8810 13.10.4. ADC Boost Control Registers Addr D8 D7 0x2F PGABST 0 D6 D5 D4 D3 D2 D1 D0 Default 0 0 0 0 0x100 D1 D0 Default PMICBSTGAIN MIC+ pin to the input Boost Stage (NB, when using this path set PMICPGA=0): PMICBSTGAIN[2:0] 13.10.5. Gain (dB) B2 B1 B0 0 0 0 0 0 1 Path Disconnected -12 0 1 0 -9 0 1 1 -6 1 0 0 -3 1 0 1 0 1 1 0 +3 1 1 1 +6 Name Input Boost Bit PGABST[8] 0 PGA output has +0dB gain through input Boost stage 1 PGA output has +20dB gain through input Boost stage Output Register Addr D8 D7 D6 D5 D4 0x31 0 0 0 0 0 D3 D2 MOUTBST SPKBST TSEN AOUTIMP 0x002 MONO Output Boost Stage Speaker Output Boost Stage Thermal Shutdown Analog Output Resistance Bit MOUTBST[3] SPKBST[2] TSEN[1] AOUTIMP[0] 0 (1.0 x VREF) Gain Boost (1.0 x VREF) Gain Boost Disabled ~1kΩ 1 (1.5 x VREF) Gain Boost (1.5 x VREF) Gain Boost Enabled ~30 kΩ emPowerAudio™ Datasheet Revision 2.8 Page 78 of 102 March 1, 2017 NAU8810 13.10.6. Speaker Mixer Control Register Addr D8 D7 D6 D5 D4 D3 D2 0x32 0 0 0 0 0 0 0 13.10.7. D1 D0 Default BYPSPK DACSPK 0x001 Bypass path (output of Boost stage) to Speaker Mixer DAC to Speaker Mixer Bit BYPSPK[1] DACSPK[0] 0 Disconnected Disconnected 1 Connected Connected Speaker Gain Control Register Addr D8 D7 D6 0x36 0 SPKZC SPKMT D5 D4 D3 D2 D1 D0 Default 0x039 SPKGAIN[5:0] Speaker Gain SPKGAIN[5:0] B5 B4 B3 B2 B1 B0 Gain (dB) 0 0 0 0 0 0 -57.0 0 0 0 0 0 1 -56.0 0 0 0 0 1 0 -55.0 ::: ::: ::: ::: ::: ::: ::: 1 1 1 0 0 0 -1.0 1 1 1 0 0 1 0.0 1 1 0 1 0 +1.0 1 Speaker Gain Range -57 dB to +6 dB @ +1 increment ::: ::: ::: ::: ::: ::: ::: 1 1 1 1 0 1 +4.0 1 1 1 1 1 0 +5.0 1 1 1 1 1 1 +6.0 Speaker Gain Control Zero Cross Speaker Output Bit SPKZC[7] SPKMT[6] 0 Change Gain on Zero Cross ONLY Speaker Enabled 1 Change Gain Immediately Speaker Muted emPowerAudio™ Datasheet Revision 2.8 Page 79 of 102 March 1, 2017 NAU8810 13.10.8. MONO Mixer Control Register Addr D8 D7 D6 D5 D4 D3 D2 0x38 0 0 MOUTMXMT 0 0 0 0 D1 D0 Default BYPMOUT DACMOUT 0x001 MOUT Mute Bypass path (output of Boost Stage) to MONO Mixer DAC to MONO Mixer Bit MOUTMXMT[6] BYPMOUT[1] DACMOUT[0] 0 Not Muted Disconnected Disconnected 1 Muted Connected Connected During mute, the MONO output will output VREF that can be used as a DC reference for a headphone out. 13.10.9. Addr Power Management 4 D8 D7 0x3A LPIPBST LPADC B1 D6 D5 LPSPKD D4 D3 LPDAC MICBIASM D2 D1 TRIMREG[3:2] D0 Default 0x000 IBADJ[1:0] Trim Output Regulator (V) Adjust Master Bias of the Analog Portion TRIMREG[3:2] IBADJ[1:0] B0 0 0 1.800 Default Current Consumption 0 1 1.610 25% Current Increase from Default 1 0 1.400 14% Current Decrease from Default 1 1 1.218 25% Current Decrease from Default Trim regulator bits can be used only when VDDD 0.546*fs -60 Group Delay dB 21/fs ADC High Pass Filter High Pass Filter Corner Frequency -3dB 3.7 -0.5dB 10.4 -0.1dB 21.6 Hz DAC Filter +/- 0.035dB 0 0.454*fs Pass band -6dB 0.5*fs Pass band Ripple +/-0.035 Stop band Stop band Attenuation dB 0.546*fs f > 0.546*fs -55 Group Delay dB 29/fs Table 57 Digital Filter Characteristics TERMINOLOGY 1. Stop Band Attenuation (dB) – the degree to which the frequency spectrum is attenuated (outside audio band) 2. Pass-band Ripple – any variation of the frequency response in the pass-band region 3. Note that this delay applies only to the filters and does not include emPowerAudio™ Datasheet Revision 2.8 Page 96 of 102 March 1, 2017 NAU8810 Figure 44: DAC Filter Frequency Response Figure 45: ADC Filter Frequency Response Figure 46: DAC Filter Ripple Figure 47: ADC Filter Ripple emPowerAudio™ Datasheet Revision 2.8 Page 97 of 102 March 1, 2017 NAU8810 17. TYPICAL APPLICATION Figure 48: Application Diagram For 20-Pin QFN Note 1: All non-polar capacitors are assumed to be low ESR type parts, such as with MLC construction or similar. If capacitors are not low ESR, additional 0.1uF and/or 0.01uF capacitors may be necessary in parallel with the bulk 4.7uF capacitors on the supply rails. Note 2: Load resistors to ground on outputs may be helpful in some applications to insure a DC path for the output capacitors to charge/discharge to the desired levels. If the output load is always present and the output load provides a suitable DC path to ground, then the additional load resistors may not be necessary. If needed, such load resistors are typically a high value, but a value dependent upon the application requirements. Note 3: To minimize pops and clicks, large polarized output capacitors should be a low leakage type. Note 4: Depending on the microphone device and PGA gain settings, common mode rejection can be improved by choosing the resistors on each node of the microphone such that the impedance presented to any noise on either microphone wire is equal. emPowerAudio™ Datasheet Revision 2.8 Page 98 of 102 March 1, 2017 NAU8810 18. PACKAGE SPECIFICATION emPowerAudio™ Datasheet Revision 2.8 Page 99 of 102 March 1, 2017 NAU8810 19. ORDERING INFORMATION Nuvoton Part Number Description NAU88U10Y G Package Material: G = Pb-free Package Package Type: Y = 20-Pin QFN Package Feature: U = emPowerAudio™ Datasheet Revision 2.8 AEC-Q100 Page 100 of 102 March 1, 2017 NAU8810 20. VERSION HISTORY VERSION DATE 1.0 September 2010 1.1 October 2010 1.2 1.3 1.4 1.5 January 2011 October 2013 Nov. 7, 2013 Nov. 7, 2013 PAGE Preliminary Revision 95 Updated Applications Diagram 57 Corrected Register 0x38 Register name 73 Improved description of Mic Bias set up 89 Added TMCLKH and TMCLKL parameters to table 85 Corrected 2 wire timing diagram 14 Corrected Digital I/O voltage levels from DCVDD to DBVDD 11 Modify operating condition from VDDA≥VDDC to VDDA≥VDDB. 11 Modify the VDDSPK operating condition 95 Modify Figure 48 (Application Diagram For 20-Pin QFN) Modify Figure 48, replace the VSSA with the symbol of analog 95 12 – 14 1.6 1.7 Jan. 15, 2014 Mar. 27, 2014 DESCRIPTION ground An additional remark of VDDSPK boost mode 43 Modify Figure 23 (Byte Write Sequence) 44 Modify Figure 24 (2-Wire Read Sequence) 11-14, Modified VDDB and VDDC to VDDD 51, 53, Corrected headphone full scale output 54,13,89 Corrected rising/falling time specification of I2S 3 Pin 11 and 12 functionalities are updated. 23 Added more descriptions to figure 8. Nov,2014 85 Corrected Tsdios setup time 2.0 Jan,2015 1 and 98 2.1 May 2015 98 2.2 July 2015 23,65 2.3 Sep,2015 81 Added Reg0x45[5] for SPKMOUT 2.4 Oct, 2015 37 Added 12.6.3 session for differential output configuration 2.5 Feb, 2016 1 Updated AEC-Q100 description 2.6 March 2016 35 Add Important Notice 43 Revise f1 equation from * to / 82 Add Silicon Revision ID All updated part number 1.8 July 2, 2014 1.9 2.7 2.8 June,2016 March, 2017 emPowerAudio™ Datasheet Revision 2.8 Updated AEC-Q100 description note and ordering information Correct a typing error. Modify “contract “ to “contact” Change 3.7KHz to 3.7Hz Page 101 of 102 March 1, 2017 NAU8810 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. emPowerAudio™ Datasheet Revision 2.8 Page 102 of 102 March 1, 2017
