NAU88L25B
Ultra-Low Power Audio CODEC for Headphone/Headsets Application
With 124dB Class G Headphone Drive and Advanced Headset Features
Description
The NAU88L25B® is an Ultra-Low-Power High-Performance Audio CODEC Ground-Referenced Headphone
Amplifier with Advanced Headset Detection. The single-chip solution with microphone and ground detection and
switching capabilities is designed for smartphones, tablets, Personal Computers (PCs), and other portable devices
that support both analog and digital audio functions. The NAU88L25B is a cost-optimized solution for audio jack
applications that benefit from enhanced audio quality and more integrated detection and suppression functions.
Additionally, when used in combination with the Nuvoton NuMicro® NUC123, an ARM® Cortex MO-based
microprocessor, the NAU88L25B Audio CODEC provides an easy-to-implement design solution for USB
headphones.
The highly-integrated NAU88L25B features one I2S/PCM Interface, one digital mixer, two high-quality audio
Digital-to-Analog Converters (DACs), one high-quality audio Analog-to-Digital Converter (ADC), one monophonic
differential analog microphone input, two analog single-ended microphone inputs, and one stereophonic Class G
headphone amplifier with automatic headset detection. After automatically detecting which type of headset is in
use—Stereo headphone, Nokia-type headsets, or Apple-type headsets—the NAU88L25B switches internal
connections to support the appropriate format.
The advanced on-chip Digital Signal Processing (DSP) engine includes a Dynamic Range Compressor (DRC), and
Programmable Bi-Quad Filters for various types of filters to optimize audio quality and eliminate undesirable
frequency components.The NAU88L25B Audio CODEC provides comprehensive headset detection features that
support jack insertion/ejection, microphone detection, distinct key / short key / long key / key release detection and
Crosstalk detection/suppression. The chip also provides an integrated Frequency Locked Loop (FLL) to support
various clocks.
The NAU88L25 operates with analog supply voltages from 1.6V to 1.8V, while the digital core can operate from
1.1V to 1.98V to conserve power. The NAU88L25 is specified for operation from -40°C to +85°C, and is available
in QFN 32 or CSP package with 0.4mm pitch.
Features
DAC with auto attenuate : 124dB SNR;
without auto mute: 113dB SNR, (A-weighted)
@ 0dB gain, 1.8V and -89dB THDN @
20mW and RL= 32Ω, DAC playback to
headphone output mode
ADC : 101dB SNR (A-weighted) @ 0dB MIC
gain, 1.8V, Fs = 48kHz and -91dB THD ,
1.8V, MIC gain 0dB, OSR 128x
One Digital I2S/PCM I/O port
Programmable Biquad filter
One Headset Mic: One Differential Analog
Mic input, Line-input or two single-ended Mic
input
One Class G Stereo Headphone
Amplifier(28mW @ 32Ω, 1% THD+N)
NAU88L25B Product Brief Rev 1.0
Page 1 of 16
Sampling rate from 8K to 192 KHz
Autonomous Headset Microphone & Ground
Detection and Switching
Jack Insertion and Ejection Detection
Distinct Keys Detection
Package : 32 Pin QFN package, and 42 Balls
WLCSP with 0.4mm Pitch
Applications
Ultra-Portable Laptop
Mobile Device
Wireless or USB Headphone
Smart Remote Controller
Gaming Controller
Aug 19, 2016
Block Diagram
The NAU88L25B Audio CODEC is available in a QFN 32-Lead package and, in a WLCSP 42-Ball package, as shown in
Figure 1 and Figure 2, respectively.
VREF
Charge Pump
ADC Effect
ADC
MIC1-
Volume
DRC
BiQuad
MICBIAS
GND
Switch
Mixers
Sidetone
DAC Effect
DAC
HPL(JKTIP)
Volume
DRC
BiQuad
DAC
HPR(JKR1)
ADC
FLL
I2S/PCM
I2C Slave
& Registers
Headset Detection
Jack Insertion / Ejection
MIC Detection
Button Detection
Speaker Impedance
Crosstalk Suppression
Auto MIC/GND Swap
SCLK
SDIO
CPIO1/CSB
IRQ
FS
DACIN
ADCOUT
Jack Detection
MCLK
JKDET
Digital Audio
Effects
BCLK
JKR2
VSSMIC
JKSLV
CPOUTP
VSSCP
CPOUTN)x2)
CPCB
CPCA
BIAS
MIC1+
MICBIAS
VDDMIC
VSSA
VDDA(2)
VSSD
VDDB
VDDC
Figure 1: NAU88L25B Block Diagram for 32-Lead QFN Package
VREF
Charge Pump
ADC
ADC Effect
Digital Audio
Effects
Volume
DRC
BiQuad
Mixers
Sidetone
MIC1-
Volume
DRC
BiQuad
DAC
ADC
FLL
I2S/PCM
I2C Slave
& Registers
GPIO4
SCLK
SDIO
IFSEL
CPIO1/CSB
IRQ
GND
Switch
DAC
BCLK
FS
DACIN
ADCOUT
JKDET1
JKDET2
MICBIAS
DAC Effect
MCLK
JKR2
JKR2FB
VSSMIC
JKSLV
JKSLVFB
CPOUTP(x2)
VSSCP
CPOUTN)x2)
CPCB
CPCA
BIAS
MIC1+
MICBIAS
VDDMIC
VSSA
VDDA(2)
VSSD
VDDB
VDDC
Figure 2: NAU88L25B Block Diagram for 42-Ball WLCSP Package
Jack Detection
Page 2 of 16
HPL(JKTIP)
HPR(JKR1)
Headset Detection
• Jack Insertion / Ejection
• MIC Detection
• Button Detection
• Speaker Impedance
• Crosstalk Suppression
• Auto MIC/GND Swap
Aug 19, 2016
Pin Diagram
Figure 3 and 4 shows the pin diagram of QFN 32-Lead and WLCSP 42 ball package respectively.
Figure 3: NAU88L25B Pin Diagram for 32-Lead QFN Package
VDDA
DACIN
BCLK
GPIO2/JKDET
JKSLV
VSSMIC
JKR2
MIC+
MIC-
32
25
1
24
ADCOUT
MICBIAS
FS
VDDMIC
VDDC
VREF
VSSD
Top View
VSSA
VDDB
VDDA
MCLK
CPOUTP
SCLK
VSSCP
8
17
9
16
GPIO1/CSB
IRQ
CPOUTN
Page 3 of 16
JKR1(HPR)
JKTIP(HPL)
CPCA
CPCB
CPOUTN
SDIO
Aug 19, 2016
Figure 4: NAU88L25B Pin Diagram for 42-Ball WLCSP Package
6
5
4
3
2
1
JKSLVFB
BCLK
DACIN
A
JKSLV
JK
DET1
ADC
OUT
FS
B
MIC+
VDD
MIC
JK
DET2
NC
VDDC
C
VREF
VSSA
MIC
DET
NC
IFSEL
VSSD
D
VDDA
VSSCP
NC
GPIO4
VDDB
MCLK
E
CP
OUTP
CP
OUTP
CPCA
HPR
GPIO1
SCLK
F
CP
OUTN
CPCB
HPL
CP
OUTN
IRQ
SDIO
G
JKR2
JKR2FB
VDDA
MIC-
MIC
BIAS
VSSA
Bottom View
Page 4 of 16
Aug 19, 2016
Pin Descriptions
Pin Descriptions for the NAU88L25B are shown in Table 1 and Table 2 by package type.
Table 1 Pin Descriptions for 32-Lead QFN
Pin #
Name
Type
Functionality
1
VDDA
Supply
Analog Supply
2
MICBIAS
Analog Output
Microphone Bias Output
3
VDDMIC
Supply
Microphone Supply
4
VREF
Analog I/O
Internal DAC & ADC Voltage Reference Decoupling I/O
5
VSSA
Ground
Analog Supply Ground
6
VDDA
Supply
Analog Supply
7
CPOUTP
Analog I/O
Charge Pump Positive Voltage
8
VSSCP
Ground
Charge Pump Supply Ground
9
CPOUTN
Analog I/O
Charge Pump Negative Voltage
10
CPCB
Analog I/O
Charge Pump Switching Capacitor Node B
11
CPCA
Analog I/O
Charge Pump Switching Capacitor Node A
12
JKTIP(HPL)
Analog Output
Jack Tip; Headphone Left Channel Output
13
JKR1(HPR)
Analog Output
Jack Ring 1; Headphone Right Channel Output
14
CPOUTN
Analog I/O
15
IRQ
Digital Output
Programmable Interrupt Output
16
GPIO1
Digital I/O
General Purpose I/O/I2C Address
17
SDIO
Digital I/O
Serial Data for I2C
18
SCLK
Digital Input
Serial Data Clock for I2C
19
MCLK
Digital Input
CODEC Master Clock Input
VDDB
Supply
Digital IO Supply
21
VSSD
Ground
Digital IO Ground
22
VDDC
Supply
Digital Core Supply
23
FS
Digital I/O
Frame Sync Input or Output for I2S or PCM Data
24
ADCOUT
Digital Output
Serial Audio Data Output for I2S or PCM Data
25
DACIN
Digital Input
Serial Audio Data Input for I2S or PCM Data
26
BCLK
Digital I/O
Serial Data Bit Clock Input or Output for I2S or PCM Data
27
JKDET
Analog Input
Jack Detect Input
28
JKSLV
Analog I/O
Jack Sleeve; Headset Jack Pin 4
29
VSSMIC
Ground
30
JKR2
Analog I/O
Jack Ring 2; Headset Jack Pin 3
31
MIC+
Analog Input
PGA MIC+ Analog Input
32
MIC-
Analog Input
PGA MIC- Analog Input
Page 5 of 16
Aug 19, 2016
Table 2 Pin Descriptions 42-Ball WLCSP
Pin #
Name
Type
Functionality
A1
DACIN
Digital Input
A2
BCLK
Digital I/O
A3
JKSLVFB
Analog I
Jack Sleeve Feedback Sense Input
A4
VSSA
Ground
A5
JKR2FB
Analog I
JackRing 2 Feedback Sense Input
A6
JKR2
Analog I/O
JackRing 2 Jack Terminal
B1
FS
Digital I/O
B2
ADCOUT
Digital Output
B3
JKDET1
Analog Input
Jack Detect Input
B4
JKSLV
Analog I/O
Jack Sleeve Jack Terminal
B5
MIC-
Analog Input
B6
VDDA
Supply
Analog Supply
C1
VDDC
Supply
Digital Core Supply
C2
NC
No Connect
This pin should remain not connected
C3
JKDET2
Analog Input
Jack Detect Input
C4
VDDMIC
Supply
Microphone Supply
C5
MIC+
Analog Input
C6
MICBIAS
Analog Output
D1
VSSD
Ground
D2
IFSEL
Digital Input
I2C/SPI Interface selection
D3
NC
No Connect
D4
MICDET
Analog I/O
Microphone Signal and SAR ADC Input
D5
VSSA
Ground
D6
VREF
Analog I/O
E1
MCLK
Digital Input
E2
VDDB
Supply
Digital IO Supply
E3
GPIO4
Digital Output
Serial Data Output for SPI Data
E4
NC
No Connect
This pin should remain NOT CONNECTED
E5
VSSCP
Ground
E6
VDDA
Supply
Analog Supply
F1
SCLK
Digital Input
F2
GPIO1
Digital I/O
General Purpose Input Output/I2C Address
F3
JKR1(HPR)
Analog Output
F4
CPCA
Analog I/O
F5
CPOUTP
Analog I/O
F6
CPOUTP
Analog I/O
G1
SDIO
Digital I/O
Serial Data for I2C
Page 6 of 16
Aug 19, 2016
Pin #
Name
Type
Functionality
G2
IRQ
Digital Output
G3
CPOUTN
Analog I/O
G4
JKTIP(HPL)
Analog Output
Jack Tip; Headphone left channel output
G5
CPCB
Analog I/O
G6
CPOUTN
Analog I/O
Note: Analog I/O supply is VDDA; Digital I/O supply is VDDB.
Page 7 of 16
Aug 19, 2016
Electrical Characteristics
Absolute Maximum Ratings
Table 3 provides the absolute maximum ratings for the NAU88L25B Audio CODEC.
CAUTION: Do not operate at or near maximum ratings extended periods. Stresses above those listed in Table 3 may cause
permanent damage to the device. Exposure to conditions beyond these ratings may adversely affect the life and reliability of
the device and result in failures not covered by warranty.
Table 3 Absolute Maximum Ratings
Parameter
Min
Max
Units
Junction Temperature, TJ
-40
+150
°C
Storage Temperature
-65
+150
°C
Analog Supply Range
-0.3
2.2
V
Digital I/O Supply Range
-0.3
6.0
V
Digital Supply Range
-0.3
2.2
V
Input Voltage Digital Range
DGND - 0.3
VDD + 0.3
V
Input Voltage Analog Range
AGND - 0.3
VDD + 0.3
V
Headphone Supply Range
-0.3
2.2
V
Microphone Bias Supply Voltage
-0.3
6.0
V
Operating Conditions
Table 4 provides the recommended operating conditions for the NAU88L25B.
Table 4 Operating Conditions
Condition
Symbol
Min
Typical
Max
Units
Analog Supply Range
VDDA
1.6
1.8
2.0
V
VDDC
1.1
1.2
1.98
V
Digital Supply Range for FLL
Operation and for Fs> 48 KHz
VDDC
1.61
1.8
1.98
V
VDDB
1.6
1.8
3.6
V
VDDA
1.6
1.8
2.0
V
VDDMIC
2.5
4.2
5.0
V
Temperature Range
TA
-40
+85
°C
QFN Package
Junction to Ambient
ƞ˚ja
33.1
°C/W
Junction to Case
ƞ˚jc
3.1
°C/W
Page 8 of 16
Aug 19, 2016
Shutdown and Standby Current
Table 5 provides Shutdown and Standby currents.
Table 5 Shutdown and Standby Current
Parameter
Shutdown Current
Standby Current
Symbol
ISD
IDD
Conditions
Typical
Limit
VDDA in Shutdown Mode
0.2
1
VDDA When VDDC=1.2 V
17.2
VDDB
0.2
1
VDDC
2
10
VDDMIC
0.2
1
MCLK off, Jack Insertion, IRQ enabled
5
Units
µA
µA
ADC Characteristics
Table 6 provides the ADC electrical characteristics for the NAU88L25B Audio CODEC.
Conditions: VDDA = VDDB = VDDC = 1.8 V; VDDMIC= 4.2 V. RL(Headphone) = 32 Ω, f = 1 kHz, MCLK=12.88 MHz,
unless otherwise specified. Limits apply for TA = 25° C.
Table 6 ADC Electrical Characteristics
Parameter
ADC Total
Harmonic Distortion
+ Noise
Signal-to-Noise
Ratio
Symbol
THD+N
SNR
Conditions
Typical
Limit
Units
MIC Input, MIC_GAIN = 0 dB,
VIN = 0.8 Vrms, f = 1 KHz,
fs = 48 KHz, Mono Differential Input
-91
dB
MIC Input, MIC_GAIN = 30 dB,
Volume = 0 dB, VIN = 28.5 Vrms,
fs = 1 k, Digital Gain = 0 dB,
-80
dB
Reference = VOUT(0dBFS),
A-Weighted, MIC Input,
MIC Gain = 0 dB,fs = 8 KHz,
101
dB
Reference = VOUT(0 dB FS),
MIC Gain = 6 dB,fs = 8 KHz,
98
dB
Power Supply
Rejection Ratio
PSRR
VRIPPLE = 200 mVPP applied to VDDA,
fRIPPLE = 217 Hz, Input Referred,
MIC_GAIN = 0 dB Differential Input
78
dB
Common Mode
Rejection Ratio
CMRR
Differential Input 100 Vrms,
PGA Gain = 20 dB, frequency sweep
from 20 Hz to 20 KHz
64
dB
ADC Full Scale
Input Level
FSADC
VDDA= 1.8 V
1
VRMS
12
KOhm
Minimum Input
Impedance
Page 9 of 16
Aug 19, 2016
Parameter
Symbol
Conditions
Typical
Limit
Units
Frequency
Response
f = 20 Hz ~ 20 KHz
+/-0.02
dB
Power
Consumption
No Load, No Signal, ADC on,
PGA on; fs = 44.1 kHz
5.4
mW
Headphone Amplifier Characteristics
Table 7 provides the headphone amplifier electrical characteristics for the NAU88L25B.
Table 7 Headphone Amplifier Electrical Characteristics
Parameter
Symbol
Output Power
32-Lead QFN
Package
PO
Output Power
42-Ball WLCSP
Package
Total Harmonic
Distortion + Noise
Signal to Noise
Ratio
THD+N
SNR
Conditions
Typical
Limit
Units
Stereo RL = 16 Ω, DAC Input,
CPVDD = 1.8 V, f = 1 kHz, 22 kHz BW,
THD+N = 1% w. Headset Switch
35
mW
Stereo RL = 32 Ω, DAC Input,
THD+N = 1%, w. Headset Switch
28
mW
Stereo RL = 16Ω, DAC Input,
39.5
mW
CPVDD= 1.8 V, f = 1 kHz, 22 kHz BW,
30.5
mW
RL = 32 Ω, f=1 kHz, PO = 20 mW,
w. Headset Switch
-89
dB
VOUT = 1 VRMS, DAC Input,
DAC_Gain = 0 dB, HP_Gain = 0 dB,
Digital Zero Input, f = 1 kHz,
A-Weighted, w. Headset Switch
113
dB
VOUT = 1 VRMS, DAC Input, DAC_Gain
= 0 dB, HP_Gain = 0 dB, Digital Zero
Input, f = 1 kHz, A-Weighted, Auto
Mute Enabled, w. Headset Switch
124
dB
Page 10 of 16
Aug 19, 2016
Parameter
Symbol
Conditions
Typical
Limit
Units
fRIPPLE = 217 Hz, VRIPPLE = 200
mVP_P Input Referred,
HP_GAIN = 0 dB
DAC Input, DAC_Gain = 0 dB Ripple
Applied to VDDA
81
dB
Left Channel to Right Channel, -1 dB
FS, Gain = 0 dB, f = 1 kHz, MIC/GND
Switching Off without HCS
88
dB
Switching On with HCS (QFN)
91
dB
Switching On with HCS (WLCSP)
98
dB
Interchannel Level
Mismatch
Headphone Right and Left Channel
Difference with 0 dB FS Input Sweep
+/- 0.1
dB
Frequency
Response
F = 20 Hz ~ 20 KHz
+/-0.005
dB
Output Noise
fS=48 kHz, OSRDAC = 128,
A-Weighted
2.2
µVRMS
BW= 400 Hz to 500 KHz
-86
dB
HP_Gain = 0 dB, DAC_Gain= 0 dB,
DAC Input
0.1
Power Consunption
No Load, No Signal, Amp on
fS = 48 kHz, Stereo DAC On, Amp On,
POUT = 0 mW. RL = 32 Ω
5.7
mW
Pop-and-Click
Noise
Into or out of DAC to Headphone
Shutdown, Headphone Impedance &
Crosstalk Detection Disabled
.1
mVrms
ON Resistance between JKR2 and
GND or JKSLV and GND (QFN)
.09
Ohm
GND or JKSLV and GND (WLCSP)
0.075
Ohm
Power Supply
Rejection Ratio
Channel Crosstalk
PSRR
XTALK
eOS
Out-of-Band Noise
Level
Output Offset
Voltage
VOS
Ground Switch ON
Resistance
Page 11 of 16
±0.5
mV
Aug 19, 2016
Digital I/O Characteristics
Table 8 provides the headphone amplifier electrical characteristics for the NAU88L25B.
Table 8 Digital I/O Characteristics
Parameter
Symbol
Comments/Conditions
Max
VDDB = 1.8 V
0.33* VDDB
VDDB = 3.3 V
0.37**VDDB
Input LOW Level
VIL
Input HIGH Level
VIH
Output HIGH Level
VOH
ILoad= 1mA
Output LOW Level
VOL
ILoad= 1mA
Min
VDDB = 1.8 V
0.67* VDDB
VDDB = 3.3 V
0.63* VDDB
VDDB = 1.8 V
0.9* VDDB
VDDB = 3.3 V
0.95* VDDB
V
V
V
VDDB = 1.8 V
0.1* VDDB
VDDB =3.3 V
0.05* VDDB
Page 12 of 16
Units
V
Aug 19, 2016
Ordering Information
Table 9 provides dimensions and packaging information for the NAU88L25B Audio CODECs.
Table 9 Ordering Information
Part Number
Dimension
Package
Package Material
NAU88L25YGB
5 x 5 mm
QFN-32 Lead
Green
NAU88L25VGB
2.552 x 2.915 mm
WLCSP 42-Balls
Green
NAU88L25 = Part Name
L = Low-Power Product
Lead-Free (Green) Packaging:
YG = indicates QFN packaging
VG = indicates WLCSP packaging WLCSP
B = Chip Revision
Page 13 of 16
Aug 19, 2016
Package Information
QFN 32-Lead Package
QFN32L 5X5 mm2, Thickness 0.8 mm (Max) , Pitch 0.5 mm (Saw Type) EP SIZE 3.5 X 3.5 mm.
Figure 5 QFN 32-Lead Package
Page 14 of 16
Aug 19, 2016
WLCSP 42-Ball Package
WLCSP 42-Balls package, 2.552 x 2.915 mm, with 0.4 mm Pitch.
Figure 6 WLCSP 42-Ball Package
Page 15 of 16
Aug 19, 2016
Revision History
Table 10: Revision History
Version
Date
Description
Page(s)
0.1
Nov 20, 2014
NA
Prelimnary Version
0.2
Mar 10, 2015
0.3
Apr 10, 2015
8
Ordering info is added.
0.4
Jun 15, 2015
5, 6
Updated Electrical Characteristics
0.5
July 16, 2015
1
Updated the descriptions
0.6
Sep 28, 2015
1,
2,
7,
8
Updated the descriptions and key features
Updated the block diagram
Changed VIH (input high voltage)
Updated the package information
0.7
Oct 27, 2015
9
1.0
Aug 19, 2016
All
Content format changes, edits for grammar and clarity. Color
removed from graphics.
Updated the pin-out and pin-descriptions
Important Notice
Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or
equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments,
transportation instruments, traffic signal instruments, combustion control instruments, or for other applications
intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure
of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or
environmental damage could occur.
Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to
fully indemnify Nuvoton for any damages resulting from such improper use or sales.
Page 16 of 16
Aug 19, 2016
