WAU8822YG
WAU8822YG
    NUVOTON(新唐)
    QFN32
    WAU8822YG
WAU8822YG 数据手册
WAU8822 24-bit Stereo Audio Codec with Speaker Driver emPowerAudio™ Description The WAU8822 is a low power, high quality CODEC for portable applications. In addition to precision 24-bit stereo ADCs and DACs, this device integrates a broad range of additional functions to simplify implementation of complete audio system solutions. The WAU8822 includes drivers for speaker, headphone, and differential or stereo line outputs, and integrates preamps for stereo differential microphones, significantly reducing external components. Advanced on-chip digital signal processing includes a 5-band equalizer, a 3-D audio enhancer, a mixed-signal automatic level control for the microphone or line input through the ADC, and a digital limiter function for the playback path. Additional digital filtering options are available in the ADC path, to simplify implementation of specific application requirements such as „wind noise reduction‟. The digital interface can operate as either a master or a slave. Additionally, an internal fractional PLL is available to generate accurate audio sample rate clocks for the CODEC derived from a wide range of commonly available system clock frequencies such as 12MHz and 13MHz. The WAU8822 operates with analog supply voltages from 2.5V to 3.6V, while the digital core can operate at 1.65V to conserve power. The loudspeaker BTL output pair and two auxiliary line outputs can operate using a 5V supply to increase output power capability, enabling the WAU8822 to drive 1 Watt into an external speaker. Internal register controls enable flexible power saving modes by powering down sub-sections of the chip under software control. The WAU8822 is specified for operation from -40°C to +85°C, and is available with full automotive AEC-/Q100 & TS16949 qualification. It is packaged in a cost-effective, space-saving 32-lead QFN package.  Standard audio interfaces: PCM and I2S  Serial control interfaces with read/write capability  Supports audio sample rates from 8kHz to 48kHz Key Features  DAC: 94dB SNR and -84dB THD (“A” weighted)  ADC: 90dB SNR and -80dB THD (“A” weighted)  Integrated BTL speaker driver: 1W into 8Ω  Integrated head-phone driver: 40mW into 16Ω  Integrated programmable microphone amplifier  Integrated line input and line output  On-chip PLL  Integrated DSP with specific functions:  5-band equalizer  3-D audio enhancement  Automatic level control  Audio level limiter  Multiple filtering options Applications  Personal Media Players  Smartphones  Personal Navigation Devices  Portable Game Players  Camcorders  Digital Still Cameras  Portable TVs  Stereo Bluetooth Headsets Headphones/ Line drivers LAUXIN AUXOUT2 RAUXIN ADC Filter LLIN LADC RLIN LMICN LMICP Stereo Microphone Interface Input Mixer RADC DAC Filter Volume Control AUXOUT1 LDAC Volume Control High Pass & Notch Filters Limiter LHP RDAC 5-band EQ Output Mixer RHP BTL Speaker 3D RMICN LSPKOUT RMICP RSPKOUT Digital Audio Interface Microphone Bias WAU8822 Data SheetRev 0.86 GPIO PLL I2S PCM Serial Control Interface WAU8822YG Page 1 of 21 September 4, 2008 MICBIAS VDDA LHP RHP VSSA VREF VDDSPK LSPKOUT 31 31 30 30 29 29 28 28 27 27 26 26 25 25 LMICP 1 24 24 VSSSPK LMICN 2 23 23 RSPKOUT LLIN/GPIO2 3 22 22 AUXOUT2 RMICP 4 21 21 AUXOUT1 RMICN 5 20 20 RAUXIN RLIN/GPIO3 6 19 19 LAUXIN FS 7 18 18 MODE BCLK 8 17 17 SDIO 15 16 14 VDDB SCLK 13 CSB/GPIO1 12 MCLK VSSD 11 DACIN VDDC 9 10 ADCOUT WAU8822YG 32-lead QFN RoHS Part Number Dimension Package Package Material WAU8822YG 5 x 5 mm 32-QFN Pb-Free WAU8822 Data Sheet Rev 0.86 emPowerAudio™ 32 32 Pinout Page 2 of 21 September 4, 2008 Pin Descriptions Pin # Name Type 1 2 3 LMICP LMICN LLIN/GPIO2 4 5 6 RMICP RMICN RLIN/GPIO3 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 FS BCLK ADCOUT DACIN MCLK VSSD VDDC VDDB CSB/GPIO1 SCLK SDIO MODE LAUXIN RAUXIN AUXOUT1 AUXOUT2 RSPKOUT VSSSPK Analog Input Analog Input Analog Input / Digital I/O Analog Input Analog Input Analog Input / Digital I/O Digital I/O Digital I/O Digital Output Digital Input Digital Input Supply Supply Supply Digital I/O Digital Input Digital I/O Digital Input Analog Input Analog Input Analog Output Analog Output Analog Output Supply 25 26 LSPKOUT VDDSPK Analog Output Supply 27 28 29 30 31 32 VREF VSSA RHP LHP VDDA MICBIAS Reference Supply Analog Output Analog Output Supply Analog Output WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Functionality Left MICP Input (common mode) Left MICN Input Left Line Input / alternate Left MICP Input / GPIO2 Right MICP Input (common mode) Right MICN Input Right Line Input/ alternate Right MICP Input / Digital Output In 4-wire mode: Must be used for GPIO3 Digital Audio DAC and ADC Frame Sync Digital Audio Bit Clock Digital Audio ADC Data Output Digital Audio DAC Data Input Master Clock Input Digital Ground Digital Core Supply Digital Buffer (Input/Output) Supply 3-Wire MPU Chip Select or GPIO1 multifunction input/output 3-Wire MPU Clock Input / 2-Wire MPU Clock Input 3-Wire MPU Data Input / 2-Wire MPU Data I/O Control Interface Mode Selection Pin Left Auxiliary Input Right Auxiliary Input Headphone Ground / Mono Mixed Output / Line Output Headphone Ground / Line Output BTL Speaker Positive Output or Right high current output Speaker Ground (ground pin for RSPKOUT, LSPKOUT, AUXOUT2 and AUXTOUT1 output drivers) BTL Speaker Negative Output or Left high current output Speaker Supply (power supply pin for RSPKOUT, LSPKOUT, AUXOUT2 and AUXTOUT1 output drivers) Decoupling for Midrail Reference Voltage Analog Ground Headphone Positive Output / Line Output Right Headphone Negative Output / Line Output Left Analog Power Supply Microphone Bias Page 3 of 21 September 4, 2008 Figure 1: WAU8822 Block Diagram WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 4 of 21 September 4, 2008 MICBIAS VREF RAUXIN RLIN RMICP RMICN LLIN LMICP LMICN LAUXIN 32 27 20 6 4 5 3 1 2 19 PLL MICROPHONE BIAS R R VDDA + - + Σ LADC MIX/BOOST 12 VSSD BCLK 8 31 VDDA 9 FS ADCOUT 7 28 VSSA DACIN 10 RADC Notch Filter ALC HPF RADC AUDIO INTERFACE (PCM/IIS) RADC MIX/BOOST Σ ALC Control 13 14 - VDDC VDDB 11 MCLK RINMIX RDAC Limiter LDAC SCLK 16 SDIO 17 18 CSB/ MODE GPIO1 15 CONTROL INTERFACE (2-, 3- and 4-wire) 24 VSSSPK 5 Band EQ 3D LINMIX 26 VDDSPK RMIX Σ RMAIN MIXER LMAIN MIXER Σ LMIX LDAC LINMIX RMIX LMIX RDAC LDAC RINMIX Σ Σ Σ RSPK SUBMIXER AUX2 MIXER AUX1 MIXER -6dB Normal -1.0X +1.5X -1.0X +1.5X -1.0X +1.5X -1.0X +1.5X 23 25 29 30 22 21 RSPKOUT LSPKOUT RHP LHP AUXOUT2 AUXOUT1 Electrical Characteristics Conditions: VDDC = 1.8V, VDDA = VDDB = VCCSPK = 3.3V, MCLK = 12.88MHz, TA = +25°C, 1kHz signal, fs = 48kHz, 24-bit audio data, 64X oversampling rate, unless otherwise stated. Parameter Symbol Analog to Digital Converter (ADC) Full scale input signal 1 Comments/Conditions PGABST = 0dB PGAGAIN = 0dB Signal-to-noise ratio SNR Gain = 0dB, A-weighted Total harmonic distortion 2 THD+N Input = -3dB FS input Channel separation 1kHz input signal Digital to Analog Converter (DAC) driving RHP / LHP with 10kΩ / 50pF load Full-scale output Output boost disabled PGA gains = 0dB AUX1BST = 1 AUX2BST = 1 Output boost enabled PGA gains = 0dB AUX1BST = 0 AUX2BST = 0 Signal-to-noise ratio SNR A-weighted Total harmonic distortion 2 THD+N RL = 10kΩ; full-scale signal Channel separation 1kHz input signal Output Mixers Maximum PGA gain into mixer Minimum PGA gain into mixer PGA gain step into mixer Guaranteed monotonic Speaker Output (RSPKOUT / LSPKOUT with 8Ω bridge-tied-load) Full scale output 4 SPKBST = 1 Min Typ VINFS tbd Max 1.0 0 90 -80 103 tbd VDDA / 3.3 Units Vrms dBV dB dB dB Vrms Vrms 1.5 * (VDDA / 3.3) 88 94 -84 96 tbd dB dB dB +6 -15 3 dB dB dB VCCSPK / 3.3 Vrms (VCCSPK / 3.3) * 1.5 Vrms Po = 200mW, VDDSPK=3.3V Po = 320mW, VDDSPK = 3.3V Po = 500mW, VDDSPK = 5V Po = 860mW, VDDSPK = 5V VDDSPK = 3.3V *63 dB -64 dB -60 dB -61 dB 91 dB VDDSPK=5V 90 dB 81 dB VDDSPK = 5V (boost) 72 dB Analog Outputs (RHP / LHP; RSPKOUT / LSPKOUT) Maximum programmable gain Minimum programmable gain Programmable gain step size Guaranteed monotonic Mute attenuation 1kHz full scale signal +6 -57 1 85 dB dB dB dB SPKBST = 0 Total harmonic distortion 2 Signal-to-noise ratio Power supply rejection ratio (50Hz - 22kHz) WAU8822 Data Sheet Rev 0.86 emPowerAudio™ THD+N SNR PSRR Page 5 of 21 September 4, 2008 Electrical Characteristics, cont’d. Conditions: VDDC = 1.8V, VDDA = VDDB = VCCSPK = 3.3V, MCLK = 12.288MHz, TA = +25°C, 1kHz signal, fs = 48kHz, 24-bit audio data, unless otherwise stated. Parameter Symbol Headphone Output (RHP / LHP with 32Ω load) 0dB full scale output voltage Signal-to-noise ratio SNR Total harmonic distortion 2 THD+N AUXOUT1 / AUXOUT2 with 10kΩ / 50pF load Full scale output Signal-to-noise ratio Total harmonic distortion 2 Channel separation Power supply rejection ratio (50Hz - 22kHz) Comments/Conditions Min Typ Max Units AVDD / 3.3 92 80 Vrms dB dB 85 dB AUX1BST = 0 AUX2BST = 0 VDDSPK / 3.3 Vrms AUX1BST = 1 AUX2BST = 1 (VDDSPK / 3.3) * 1.5 Vrms 87 -83 99 53 dB dB dB dB 56 dB A-weighted RL = 16Ω, Po = 20mW, VDDA = 3.3V RL = 32Ω, Po = 20mW, VDDA = 3.3V SNR THD+N 1kHz signal PSRR VDDSPK = 5V (boost) Microphone Inputs (LMICP, LMICN, RMICP, RMICN, LLIN, RLIN) and Programmable Gain Amplifier (PGA) Full scale input signal 1 PGABST = 0dB 1.0 Vrms PGAGAIN = 0dB 0 dBV Programmable gain -12 35.25 dB Programmable gain step size Guaranteed Monotonic 0.75 dB Mute Attenuation 120 dB Input resistance Inverting Input PGA Gain = 35.25dB 1.6 kΩ PGA Gain = 0dB 47 kΩ PGA Gain = -12dB 75 kΩ 94 kΩ Non-inverting Input Input capacitance 10 pF PGA equivalent input noise 0 to 20kHz, Gain set to 120 µV 35.25dB Input Boost Mixer Gain boost Boost disabled 0 dB Boost enabled 20 dB Gain range LLIN / RLIN or -12 6 dB LAUXIN / RAUXIN to boost/mixer Gain step size to boost/mixer 3 dB Auxiliary Analog Inputs (LAUXIN, RAUXIN) Full scale input signal 1 Gain = 0dB 1.0 Vrms 0 dBV Input resistance Aux direct-to-out path, only Input gain = +6.0dB 20 kΩ Input gain = 0.0dB 40 kΩ Input gain = -12dB 159 kΩ Input capacitance 10 pF WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 6 of 21 September 4, 2008 Electrical Characteristics, cont’d. Conditions: VDDC = 1.8V, VDDA = VDDB = VCCSPK = 3.3V, MCLK = 12.88MHz, TA = +25°C, 1kHz signal, fs = 48kHz, 24-bit audio data, unless otherwise stated. Parameter Symbol Comments/Conditions Automatic Level Control (ALC) & Limiter: ADC path only Target record level Programmable gain Gain hold time 3 tHOLD Doubles every gain step, with 16 steps total Gain ramp-up (decay) 3 tDCY ALC Mode ALC = 0 Limiter Mode ALC = 1 Gain ramp-down (attack) 3 tATK ALC Mode ALC = 0 Limiter Mode ALC = 1 Mute Attenuation Microphone Bias Bias voltage VMICBIAS See Figure 3 Bias current source Output noise voltage Digital Input/Output Input HIGH level IMICBIAS Vn 1kHz to 20kHz VIL Min Typ Max -22.5 -1.5 -12 35.25 0 / 2.67 / 5.33 / … / 43691 dBFS dB ms 4 / 8 / 16 / … / 4096 ms 1 / 2 / 4 / … / 1024 ms 1 / 2 / 4 / … / 1024 ms 0.25 / 0.5 / 1 / … / 128 ms 120 dB 0.50, 0.60,0.65, 0.70, 0.75, 0.85, or 0.90 3 14 VDDA VDDA mA nV/√Hz 0.7 * VDDC Input LOW level VIH Output HIGH level VOH ILoad = 1mA Output LOW level VOL ILoad = -1mA V 0.3 * VDDC Input capacitance Units 0.9 * VDDC V V 0.1 * VDDC 10 V pF Notes 1. Full Scale is relative to the magnitude of VDDA and can be calculated as FS = VDDA/3.3. 2. Distortion is measured in the standard way as the combined quantity of distortion products plus noise. The signal level for distortion measurements is at 3dB below full scale, unless otherwise noted. 3. Time values scale proportionally with MCLK. Complete descriptions and definitions for these values are contained in the detailed descriptions of the ALC functionality. 4. With default register settings, SPKVDD should be 1.5xVDDA (but not exceeding maximum recommended operating voltage) to optimize available dynamic range in the AUXOUT1, AUXOU2, RSPKOUT, and LSPKOUT outputs stages. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 7 of 21 September 4, 2008 Absolute Maximum Ratings Condition Min Max Units VDDB, VDDC, VDDA supply voltages -0.3 +3.90 V VDDSPK supply voltage (default register configuration) -0.3 +5.80 V VDDSPK supply voltage (optional low voltage configuration) -0.3 +3.90 V Core Digital Input Voltage range VSSD – 0.3 VDDC + 0.30 V Buffer Digital Input Voltage range VSSD – 0.3 VDDB + 0.30 V Analog Input Voltage range VSSA – 0.3 VDDA + 0.30 V Industrial operating temperature -40 +85 °C Storage temperature range -65 +150 °C CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. Operating Conditions Condition Symbol Min Digital supply range (Core) VDDC Digital supply range (Buffer) Analog supply range Typical Max Units 1.65 3.60 V VDDB 1.65 3.60 V VDDA 2.50 3.60 V Speaker supply (SPKBST=0) VDDSPK 2.50 5.50 V Speaker supply (SPKBST=1) VDDSPK 2.50 5.50 V Ground VSSD VSSA VSSSPK 0 V 1. VDDA must be ≥ VDDC. 2. VDDB must be ≥ VDDC. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 8 of 21 September 4, 2008 1 General Description The WAU8822 is a stereo device with identical left and right channels that share common support elements. Additionally, the right channel auxiliary output path includes a dedicated submixer that supports mixing the right auxiliary input directly into the right speaker output driver. This enables the right speaker channel to output audio that is not present on any other output. 1.1.1 Analog Inputs All inputs, except for the wide range programmable amplifier (PGA), have available analog input gain conditioning of -15dB through +6dB in 3dB steps. All inputs also have individual muting functions with excellent channel isolation and off-isolation from all outputs. All inputs are suitable for full quality, high bandwidth signals. Each of the left-right stereo channels includes a low noise differential PGA amplifier, programmable for high-gain input. This may be used for a microphone level through line level source. Gain may be set from +35.25db through -12dB at the analog difference-amplifier type programmable amplifier input stage. A separate additional 20dB analog gain is available on this input path, between the PGA output and ADC mixer input. The output of the ADC mixer may be routed to the ADC and/or analog bypass to the analog output sections. Each channel also has a line level input. This input may be routed to the input PGA, and/or directly to the ADC input mixer. Each channel has a separate additional auxiliary input. This is a line level input which may be routed the ADC input mixer and/or directly to the analog output mixers. 1.1.2 Analog Outputs There are six high current analog audio outputs. These are very flexible outputs that can be used individually or in stereo pairs for a wide range of end uses. However, these outputs are optimized for specific functions and are described in this section using the functional names that are applicable to those optimized functions. Each output receives its signal source from built-in analog output mixers. These mixers enable a wide range of signal combinations, including muting of all sources. Additionally, each output has a programmable gain function, output mute function, and output disable function. The RHP and LHP headphone outputs are optimized for driving a stereo pair of headphones, and are powered from the main analog voltage supply rail, VDDA. These outputs may be coupled using traditional DC blocking series capacitors. Alternatively, these may be configured in a no-capacitor DC coupled design using a virtual ground at ½ VDDA provided by an AUXOUT analog output. The AUXOUT1 and AUXOUT2 analog outputs are powered from the VDDSPK supply rail and VSSSPK ground return path. The supply rail may be the same as VDDA, or may be a separate voltage up to 5.5Vdc. This higher voltage enables these outputs to have an increased output voltage range and greater output power capability. The RSPKOUT and LSPKOUT loudspeaker outputs are powered from the VDDSPK power supply rail and VSSGND ground return path. LSPKOUT receives its audio signal via an additional submixer. This submixer supports combining a traditional alert sound (from the RAUXIN input) with the right channel headphone output mixer signal. This submixer also provides the signal invert function that is necessary for the normal BTL (Bridge Tied Load) configuration used to drive a high power external loudspeaker. Alternatively, each loudspeaker output may be used individually as a separate high current analog output driver. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 9 of 21 September 4, 2008 1.1.3 ADC, DAC, and Digital Signal Processing Each left and right channel has an independent high quality ADC and DAC associated with it. These are high performance, 24-bit delta-sigma converters that are suitable for a very wide range of applications. The ADC and DAC functions are each individually supported by powerful analog mixing and routing. The ADC output may be routed to the digital output path and/or to the input of the DAC in a digital passthrough mode. The ADC and DAC blocks are also supported by advanced digital signal processing subsystems that enable a very wide range of programmable signal conditioning and signal optimizing functions. All digital processing is with 24-bit precision, as to minimize processing artifacts and maximize the audio dynamic range supported by the WAU8822. The ADCs are supported by a wide range, mixed-mode Automatic Level Control (ALC), a high pass filter, and a notch filter. All of these features are optional and highly programmable. The high pass filter function is intended for DC-blocking or low frequency noise reduction, such as to reduce unwanted ambient noise or “wind noise” on a microphone input. The notch filter may be programmed to greatly reduce a specific frequency band or frequency, such as a 50Hz, 60Hz, or 217Hz unwanted noise. The DACs are supported by a programmable limiter/DRC (Dynamic Range Compressor). This is useful to optimize the output level for various applications and for use with small loudspeakers. This is an optional feature that may be programmed to limit the maximum output level and/or boost an output level that is too small. Digital signal processing is also provided for a 3D Audio Enhancement function, and for a 5-Band Equalizer. These features are optional, and are programmable over wide ranges. This pair of digital processing features may be applied jointly to either the ADC audio path or to the DAC audio path, but not to both paths simultaneously. 1.1.4 Voltage Reference and Microphone Bias Built-in power management includes a high stability voltage reference. This is used as an internal reference, and to generate a high quality, programmable microphone bias supply voltage that is well isolated from the supply rails. This microphone bias supply is suitable for both conventional electret (ECM) type microphone, and to power the newer MEMS all-silicon type microphones. 1.1.5 Digital Interfaces Command and control of the device is accomplished using a 2-wire/3-wire/4-wire serial control interface. This is a simple, but highly flexible interface that is compatible with many commonly used command and control serial data protocols and host drivers. Digital audio input/output data streams are transferred to and from the device separately from command and control. The digital audio data interface supports either I2S or PCM audio data protocols, and is compatible with commonly used industry standard devices that follow either of these two serial data formats. 1.1.6 Clock Requirements The clocking signals required for the audio signal processing, audio data I/O, and control logic may be provided externally, or by optional operation of a built-in PLL (Phase Locked Loop). An external master clock (MCLK) signal must be active for analog audio logic paths to align with control register updates, and is required as the reference clock input for the PLL, if the PLL is used. The PLL is provided as a low cost, zero external component count optional method to generate required clocks in almost any system. The PLL is a fractional-N divider type design, which enables generating accurate desired audio sample rates derived from a very wide range of commonly available system clocks. The frequency of the system clock provided as the PLL reference frequency may be any stable frequency in the range between 8MHz and 33MHz. Because the fractional-N multiplication factor is a very high precision 24-bit value, any desired sample rate supported by the WAU8822 can be generated with very high accuracy, typically limited by the accuracy of the external reference frequency. Reference clocks and sample rates outside of these ranges are also possible, but may involve performance tradeoffs and increased design verification. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 10 of 21 September 4, 2008 2 Application Information 2.1 Typical Application Schematic 11 8 7 10 9 16 17 15 18 WAU8822 VDDSPK VDDB VDDC VDDA MCLK BCLK FS DACIN ADCOUT VDDSPK SCLK SDIO CSB/GPIO1 MODE Analog Inputs: No Connection if “not used” C16 1uF C15 1uF R4 1200 ohm 28 VSSSPK VSSD 24 12 C14 1uF ECM “electret” type Mic R3 1200 ohm R2 1000 ohm R1 1000 ohm C10 4.7uF 6 RLIN/GPIO3 19 LAUXIN 20 RAUXIN 1 5 C12 1uF ECM “electret” type Mic LLIN/GPIO2 C13 1uF 4 C11 1uF 32 C1 4.7uF C2 4.7uF C3 4.7uF C4 4.7uF 21 C5 1uF R9 3 2 VDDB 14 13 31 26 VSSA AUXOUT1 VSS Jack Switch Detection Example VDDC VSS R5 220K ohm VDDB VDDA vss AUXOUT2 optional R8 22 C6 1uF Left Headphone “tip” on 3.5mm Stereo connector C7 220uF LHP 30 + R7 vss LMICN RHP LMICP 29 + optional R6 VSS “sleeve” on 3.5mm Audio connector Right Headphone “ring” on 3.5mm Stereo connector C8 220uF RMICN RSPKOUT RMICP MICBIAS VREF LSPKOUT 23 25 27 C9 4.7uF VSS Figure 2: Schematic with recommended external components for typical application with AC-coupled headphones and stereo electret (ECM) style microphones. Note 1: All non-polar capacitors are assumed to be low ESR type parts, such as with MLC construction or similar. If capacitors are not low ESR, additional 0.1ufd and/or 0.01ufd capacitors may be necessary in parallel with the bulk 4.7ufd capacitors on the supply rails. Note 2: Load resistors to ground on outputs may be helpful in some applications to insure a DC path for the output capacitors to charge/discharge to the desired levels. If the output load is always present and the output load provides a suitable DC path to ground, then the additional load resistors may not be necessary. If needed, such load resistors are typically a high value, but a value dependent upon the application requirements. Note 3: To minimize pops and clicks, large polarized output capacitors should be a low leakage type. Note 4: Depending on the microphone device and PGA gain settings, common mode rejection can be improved by choosing the resistors on each node of the microphone such that the impedance presented to any noise on either microphone wire is equal. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 11 of 21 September 4, 2008 2.2 Power Consumption WAU8822 has flexible power management capability which allows sections not being used to be powered down, to draw minimum current in battery-powered applications. Table – shows typical power consumption in different operating conditions. Mode OFF Sleep Stereo Record Stereo Playback Conditions VREF off, no clocks, VREF maintained @ 75kΩ, no clocks, VREF maintained @ 300kΩ, no clocks, VREF maintained @ 5kΩ, no clocks, 8kHz 8kHz, PLL on 16Ω HP, 44.1kHz, PLL on, sine wave 16Ω HP, 44.1kHz, quiescent 16Ω HP, 44.1kHz, white noise 16Ω HP, 44.1kHz, sine wave 16Ω HP, 44.1kHz, PLL on, sine wave VDDA = 3V mA tbd 0.1 0.0 0.0 0.3 7.9 10.4 24.5 4.4 7.2 22.0 24.5 VDDC = 1.8V mA tbd 0.001 0.001 0.001 0.001 1.7 2.9 8.2 6.2 6.5 6.8 8.2 VDDB = 3V mA tbd 0.0003 0.0003 0.0003 0.0003 0.005 0.07 0.07 0.005 0.005 0.005 0.07 Total Power mW tbd 0.15 0.045 0.025 0.78 26.7 36.6 88.5 24.4 33.3 78.3 88.5 Table 1: Typical Power Consumption in Various Application Modes. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 12 of 21 September 4, 2008 2.3 Supply Currents of Specific Blocks WAU8822 can be programmed to enable/disable various analog blocks individually, and the current to some of the major blocks can be reduced with minimum impact on performance. The table below shows the change in current consumed with different register settings. Sample rate settings will vary current consumption of VDDC supply, which draws consumes approximately 4mA @ 1.8V and fs = 48kHz. Lower sampling rates draw lower current. Register Dec Hex Function Bit REFIMP[1:0] 1 01 Power Management 1 IOBUFEN[2] ABIASEN[3] MICBIASEN[4] PLLEN[5] AUX2MXEN[6] AUX1MXEN[7] DCBUFEN[8] LADCEN[0] RADCEN[1] 2 02 Power Management 2 LPGAEN[2] RPGAEN[3] LBSTEN[4] RBSTEN[5] SLEEP[6] LHPEN[7] RHPEN[8] LDACEN[0] RDACEN[1] 3 58 03 3A Power Management 3 Power Management 4 LMIXEN[2] RMIXEN[3] BIASGEN[4] RSPKEN[5] LSPKEN[6] AUXOUT2EN[7] AUXOUT1EN[8] IBIADJ[1:0] REGVOLT[2:3] MICBIASM[4] LPSPKD[5] LPADC[6] LPIPBST[7] LPDAC[8] VDDA current increase/ Decrease when enabled +100μA for 80kΩ and 300kΩ +260μA for 3kΩ +100μA +600μA +540μA +2.5 mA +1/5mA from VDDC with clocks applied +200μA +200μA +140μA +2.3 mA with 64X OSR +3.3 mA with 128X OSR +2.3 mA with 64X OSR +3.3 mA with 128X OSR +300μA +300μA +650μA +650μA +800μA +800μA +1.6 mA with 64X OSR +1.7 mA with 128X OSR +1.6 mA with 64X OSR +1.7 mA with 128X OSR +250μA +250μA +1.1 mA from VDDSPK +1.1 mA from VDDSPK +225μA +225μA -1.2mA with IBIADJ at 11 -1.1mA with no SNR decrease @ 8kHz -600μA with no SNR decrease @ 8kHz -1.1mA with 1.4dB SNR decrease @ 44.1kHz Table 2: VDDA 3.3V Supply Current in Various Modes WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 13 of 21 September 4, 2008 3 Appendix A: Digital Filter Characteristics Parameter Conditions Min +/- 0.015dB 0 Typ Max Units 0.454 fs ADC Filter Passband -6dB 0.5 Passband Ripple +/-0.015 Stopband Stopband Attenuation fs 0.546 f > 0.546*fs fs -60 Group Delay dB dB 28.25 1/fs -3dB 3.7 Hz -0.5dB 10.4 Hz -0.1dB 21.6 Hz ADC High Pass Filter High Pass Filter Corner Frequency DAC Filter Passband +/- 0.035dB 0 -6dB 0.454 0.5 Passband Ripple Stopband Attenuation fs +/-0.035 Stopband f > 0.546*fs Group Delay fs dB 0.546 fs -55 dB 28 1/fs Table 3: Digital Filter Characteristics TERMINOLOGY 1. Stop Band Attenuation (dB) – the degree to which the frequency spectrum is attenuated (outside audio band) 2. Pass-band Ripple – any variation of the frequency response in the pass-band region 3. Note that this delay applies only to the filters and does not include other latencies, such as from the serial data interface WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 14 of 21 September 4, 2008 Figure 3: DAC Filter Frequency Response Figure 5: ADC Filter Frequency Response Figure 4: DAC Filter Ripple Figure 6: ADC Filter Ripple WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 15 of 21 September 4, 2008 0 -2 d B r -4 -6 10 20 30 Hz Figure 7: ADC Highpass Filter Response, Audio Mode 0 -20 d B -40 r -60 -80 100 300 500 700 900 Hz Figure 8: ADC Highpass Filter Response, HPF enabled, FS = 48kHz 0 -20 d B -40 r -60 -80 100 300 500 700 900 Hz Figure 9: ADC Highpass Filter Response, HPF enabled, FS = 24kHz 0 -20 d B -40 r -60 -80 100 300 500 700 900 Hz Figure 10: ADC Highpass Filter Response, HPF enabled, FS = 12kHz WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 16 of 21 September 4, 2008 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 11: EQ Band 1 Gains for Lowest Cut-Off Frequency +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 12: EQ Band 2 Peak Filter Gains for Lowest Cut-Off Frequency with EQ2BW = 0 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k 10k 20k Hz Figure 13: EQ Band 2, EQ2BW = 0 versus EQ2BW = 1 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k Hz Figure 14: EQ Band 3 Peak Filter Gains for Lowest Cut-Off Frequency with EQ3BW = 0 WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 17 of 21 September 4, 2008 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 15: EQ Band 3, EQ3BW = 0 versus EQ3BW = 1 +15 T +10 +5 d B r 0 -5 -10 -15 Figure 16: EQ Band 4 Peak Filter Gains for Lowest Cut-Off Frequencies with EQ4BW = 0 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k 10k 20k Hz Figure 17: EQ Band 4, EQ4BW = 0 versus EQ4BW =1 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k Hz Figure 18: EQ Band 5 Gains for Lowest Cut-Off Frequency WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 18 of 21 September 4, 2008 4 Appendix D: Register Overview DEC HEX NAME Bit 8 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 00 Software Reset RESET (SOFTWARE) 1 01 Power Management 1 DCBUFEN AUX1MXEN AUX2MXEN PLLEN MICBIASEN ABIASEN IOBUFEN REFIMP 2 02 Power Management 2 RHPEN NHPEN SLEEP RBSTEN LBSTEN RPGAEN LPGAEN RADCEN LADCEN 3 03 Power Management 3 AUXOUT1EN AUXOUT2EN LSPKEN RSPKEN BIASGEN RMIXEN LMIXEN RDACEN LDACEN General Audio Controls 4 04 Audio Interface BCLKP LRP WLEN AIFMT DACPHS ADCPHS MONO 5 05 Companding Reserved CMB8 DACCM ADCCM PASSTHRU 6 06 Clock Control 1 CLKM MCLKSEL BCLKSEL Reserved CLKIOEN 7 07 Clock Control 2 4WSPIEN Reserved SMPLR SCLKEN 8 08 GPIO Reserved GPIO1PLL GPIO1PL GPIO1SEL 9 09 Jack Detect 1 JCKMIDEN JCKDEN JCKDIO Reserved 10 0A DAC Control Reserved SOFTMT Reserved DACOS AUTOMT RDACPL LDACPL 11 0B Left DAC Volume LDACVU LDACGAIN 12 0C Right DAC Volume RDACVU RDACGAIN 13 0D Jack Detect 2 Reserved JCKDOEN1 JCKDOEN0 14 0E ADC Control HPFEN HPFAM HPF ADCOS Reserved RADCPL LADCPL 15 F Left ADC Volume LADCVU LADCGAIN 16 10 Right ADC Volume RADCVU RADCGAIN 17 11 Reserved Equalizer 18 12 EQ1-low cutoff EQM Reserved EQ1CF EQ1GC 19 13 EQ2-peak 1 EQ2BW Reserved EQ2CF EQ2GC 20 14 EQ3-peak 2 EQ3BW Reserved EQ3CF EQ3GC 21 15 EQ4-peak3 EQ4BW Reserved EQ4CF EQ4GC 22 16 EQ5-high cutoff Reserved EQ5CF EQ5GC 23 17 Reserved DAC Limiter 24 18 DAC Limiter 1 DACLIMEN DACLIMDCY DACLIMATK 25 19 DAC Limiter 2 Reserved DACLIMTHL DACLIMBST 26 1A Reserved Notch Filter 27 1B Notch Filter 1 NFCU1 NFCEN NFCA0[13:7] 28 1C Notch Filter 2 NFCU2 Reserved NFCA0[6:0] 29 1D Notch Filter 3 NFCU3 Reserved NFCA1[13:7] 30 1E Notch Filter 4 NFCU4 Reserved NFCA1[6:0] 31 1F Reserved ALC and Noise Gate Control 32 20 ALC Control 1 ALCEN Reserved ALCMXGAIN ALCMNGAIN 33 21 ALC Control 2 Reserved ALCHT ALCSL 34 22 ALC Control 3 ALCM ALCDCY ALCATK 35 23 Noise Gate Reserved ALCTBLSEL ALCNEN ALCNTH Phase Locked Loop 36 24 PLL N Reserved PLLMCLK PLLN 37 25 PLL K 1 Reserved PLLK[23:18] 38 26 PLL K 2 PLLK[17:9] 39 27 PLL K 3 PLLK[8:0] 40 28 Mic Bias Mode Reserved MICBIASM Miscellaneous 41 29 3D control Reserved 3DDEPTH 42 2A Reserved 43 2B Right Speaker Submix Reserved RMIXMUT RSUBBYP RAUXRSUBG RAUXSMUT 44 2C Input Control MICBIASV RLINRPGA RMICNRPGA RMICPRPGA Reserved LLINLPGA LMICNLPGA LMICPLPGA 45 2D Left Input PGA Gain LPGAU LPGAZC LPGAMT LPGAGAIN 46 2E Right Input PGA Gain RPGAU RPGAZC RPGAMT RPGAGAIN 47 2F Left ADC Boost LPGABST Reserved LPGABSTGAIN Reserved LAUXBSTGAIN 48 30 Right ADC Boost RPGABST Reserved RPGABSTGAIN SPKSTAGE RAUXBSTGAIN 49 31 Output Control Reserved LDACRMX RDACLMX AUX1BST AUX2BST SPKBST TSEN AOUTIMP 50 32 Left Mixer LAUXMXGAIN LAUXLMX LBYPMXGAIN LBYPLMX LDACLMX 51 33 Right Mixer RAUXMXGAIN RAUXRMX RBYPMXGAIN RBYPRMX RDACRMX 52 34 LHP Volume LHPVU LHPZC LHPMUTE LHPGAIN 53 35 RHP Volume RHPVU RHPZC RHPMUTE RHPGAIN 54 36 LSPKOUT Volume LSPKVU LSPKZC LSPKMUTE LSPKGAIN 55 37 RSPKOUT Volume RSPKVU RSPKZC RSPKMUTE RSPKGAIN 56 38 AUX2 Mixer Reserved AUXOUT2MT Reserved AUX1MIX>2 LADCAUX2 LMIXAUX2 LDACAUX2 57 39 AUX1 Mixer Reserved AUXOUT1MT AUX1HALF LMIXAUX1 LDACAUX1 RADCAUX1 RMIXAUX1 RDACAUX1 58 3A Power Management 4 LPDAC LPIPBST LPADC LPSPKD MICBIASM REGVOLT IBADJ PCM Time Slot and ADCOUT Impedance Option Control 59 3B Left Time Slot LTSLOT[8:0] 60 3C Misc PCMTSEN TRI PCM8BIT PUDEN PUDPE PUDPS Reserved RTSLOT[9] LTSLOT[9] 61 3D Right Time Slot RTSLOT[8:0] Silicon Revision and Device ID 62 3E Device Revision # Reserved REV 63 3F Device ID ID WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 19 of 21 September 4, 2008 Default 000 000 000 050 000 140 000 000 000 000 0FF 0FF 000 100 0FF 0FF 12C 02C 02C 02C 02C 032 000 000 000 000 000 038 00B 032 010 008 00C 093 0E9 000 000 000 033 010 010 100 100 002 001 001 039 039 039 039 001 001 000 000 020 000 xxx xxx 5 Package Dimensions 32-lead Plastic QFN; 5X5mm2, 1.0mm thickness, 0.5mm lead pitch WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 20 of 21 September 4, 2008 6 Ordering Information Nuvoton Part Number Description WAU8822YG Package Material: G = Pb-free Package Package Type: Y = 32-Pin QFN Package Version History VERSION DATE PAGE DESCRIPTION A0.0 February, 2008 NA Preliminary Revision A0.6 May 2008 NA Preliminary Revision A0.86 September 2008 NA Preliminary Revision Table 4: Version History Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. WAU8822 Data Sheet Rev 0.86 emPowerAudio™ Page 21 of 21 September 4, 2008
WAU8822YG 价格&库存
很抱歉,暂时无法提供与“WAU8822YG”相匹配的价格&库存,您可以联系我们找货
