W681308DG
W681308DG
    NUVOTON(新唐)
    LQFP48
    W681308DG
W681308DG 数据手册
W681308 XXXX PRODUCT DESCRIPTION W681308 USB AUDIO CONTROLLER Data Sheet Revision 1.2 W681308 XXXX PRODUCT DESCRIPTION TABLE OF CONTENT 1. GENERAL DESCRIPTION ............................................................................................................................................... 6 2. FEATURES....................................................................................................................................................................... 6 3. PIN CONFIGURATION..................................................................................................................................................... 8 4. PIN DESCRIPTION .......................................................................................................................................................... 9 5. BLOCK DIAGRAM.......................................................................................................................................................... 11 6. MEMORY MAP............................................................................................................................................................... 12 7. 8. 6.1 PROGRAM MEMORY MAP ........................................................................................................................................... 12 6.2 DATA MEMORY MAP .................................................................................................................................................. 12 REGISTERS ................................................................................................................................................................... 13 7.1 MCU CLOCK RATE SELECT REGISTER ....................................................................................................................... 13 7.2 INTERRUPT CONTROL REGISTERS .............................................................................................................................. 13 7.3 KEYPAD IO, LCD, UART AND GPIO CONTROL REGISTERS ......................................................................................... 13 7.4 GAIN STAGE AND MIXER CONTROL REGISTERS............................................................................................................ 14 7.5 PCM CONTROL REGISTERS....................................................................................................................................... 14 7.6 CODEC CONTROL REGISTERS .................................................................................................................................. 14 7.7 SPI CONTROL REGISTERS ......................................................................................................................................... 15 7.8 W2S CONTROL REGISTERS ....................................................................................................................................... 15 7.9 RING TONE (PWM) CONTROL REGISTERS .................................................................................................................. 16 7.10 FULL/HALF DUPLEX ACOUSTIC ECHO CANCELLATION (AEC) CONTROL REGISTERS ........................................................ 16 7.11 USB CONTROLLER REGISTERS .................................................................................................................................. 18 MICROCONTROLLER ................................................................................................................................................... 21 8.1 FEATURES................................................................................................................................................................ 21 8.2 MEMORY ORGANIZATION ........................................................................................................................................... 21 8.2.1 Program Memory ............................................................................................................................................... 21 8.2.2 Data Memory ..................................................................................................................................................... 21 8.2.3 Special Function Registers (SFR) ..................................................................................................................... 22 8.3 POWER MANAGEMENT............................................................................................................................................... 22 8.4 RESET CONDITIONS .................................................................................................................................................. 23 8.4.1 External Reset ................................................................................................................................................... 23 8.4.2 Watchdog Reset ................................................................................................................................................ 23 8.5 INTERRUPTS ............................................................................................................................................................. 23 8.6 PROGRAMMING TIMERS AND COUNTERS ..................................................................................................................... 24 8.6.1 Timers/Counters 0 and 1 ................................................................................................................................... 24 8.6.2 Timer/Counter 2................................................................................................................................................. 25 2 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 8.6.3 Watchdog Timer ................................................................................................................................................ 25 8.7 SERIAL PORT (UART)............................................................................................................................................... 28 8.8 OTP ROM .............................................................................................................................................................. 28 9. CLOCK CONTROL AND RESET ................................................................................................................................... 29 9.1 CLOCK CONTROL ...................................................................................................................................................... 29 9.1.1 Overview............................................................................................................................................................ 29 9.1.2 Clock Generation ............................................................................................................................................... 29 9.1.3 Control Register................................................................................................................................................. 30 10. INTERRUPT CONTROL ............................................................................................................................................ 31 10.1 OVERVIEW ............................................................................................................................................................... 31 10.2 FUNCTIONALITY ........................................................................................................................................................ 31 10.3 INTERRUPT CONTROL REGISTERS .............................................................................................................................. 32 11. INTERFACE LOGIC................................................................................................................................................... 33 11.1 SOFTWARE KEYPAD SCANNER ................................................................................................................................... 33 11.2 GPIO S ................................................................................................................................................................... 34 11.3 LCD CONTROL ......................................................................................................................................................... 35 11.4 UART I/O CONTROL ................................................................................................................................................. 35 12. PCM INTERFACE , GAIN STAGE AND MIXER ........................................................................................................ 36 12.1 PCM INTERFACE ...................................................................................................................................................... 36 12.2 GAIN STAGE ............................................................................................................................................................. 36 12.3 MIXER ..................................................................................................................................................................... 37 12.4 CONNECTION CASE EXAMPLE .................................................................................................................................... 37 12.5 MIXER CASE EXAMPLES WITH REGISTER SETTING ....................................................................................................... 39 12.6 I2S REGISTER SETTING EXAMPLE .............................................................................................................................. 42 13. AUDIO CODEC INTERFACE..................................................................................................................................... 43 13.1 OVERVIEW ............................................................................................................................................................... 43 13.2 AUDIO CODEC SIGNAL PATH .................................................................................................................................... 43 13.3 MICROPHONE INTERFACE AND AUXILIARY INTERFACE ................................................................................................... 44 14. SERIAL PERIPHERAL INTERFACE.......................................................................................................................... 47 14.1 OVERVIEW ............................................................................................................................................................... 47 14.2 DATA AND SIGNAL FORMAT OF SPI............................................................................................................................ 47 14.3 FSM OF SPI ............................................................................................................................................................ 47 14.4 FIFO AND RAM OF SPI ............................................................................................................................................ 48 14.5 INTERRUPT SOURCES ................................................................................................................................................ 48 15. NUVOTON 2-WIRE SERIAL BUS.............................................................................................................................. 49 3 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 15.1 16. OVERVIEW ............................................................................................................................................................... 49 ICE FUNCTION BY JTAG STD. IEEE 1149.1............................................................................................................ 49 16.1 OVERVIEW ............................................................................................................................................................... 49 16.2 SCAN CHAINS AND JTAG INTERFACE.......................................................................................................................... 49 16.3 PIN DESCRIPTION ..................................................................................................................................................... 49 16.4 RESET BEHAVIOR ..................................................................................................................................................... 50 17. RING TONE (PWM) GENERATOR............................................................................................................................ 50 17.1 18. OVERVIEW ............................................................................................................................................................... 50 FULL/HALF DUPLEX ACOUSTIC ECHO CANCELLATION(AEC) ............................................................................ 51 18.1 19. FUNCTION CONTROL REGISTERS ................................................................................................................................ 51 USB DEVICE CONTROLLER AND TRANSCEIVER ................................................................................................. 52 19.1 OVERVIEW ............................................................................................................................................................... 52 19.2 FUNCTIONAL DESCRIPTION ........................................................................................................................................ 52 19.2.1 Endpoints ...................................................................................................................................................... 53 19.2.2 Descriptor RAM ............................................................................................................................................. 54 20. ELECTRICAL CHARACTERISTICS .......................................................................................................................... 55 20.1 ABSOLUTE MAXIMUM RATINGS ................................................................................................................................... 55 20.2 RECOMMENDED OPERATING CONDITIONS ................................................................................................................... 55 20.3 DC CHARACTERISTICS .............................................................................................................................................. 56 20.4 ANALOG TRANSMISSION CHARACTERISTICS ................................................................................................................. 56 20.5 ANALOG DISTORTION AND NOISE PARAMETERS ........................................................................................................... 57 20.5.1 8kHz sampling............................................................................................................................................... 57 20.5.2 16kHz sampling............................................................................................................................................. 57 20.5.3 48kHz sampling............................................................................................................................................. 58 20.6 PROGRAMMABLE OUTPUT LINEAR REGULATOR ............................................................................................................ 58 20.7 USB PHY ELECTRONIC CHARACTERISTICS ( 25°C, DVDD= 3.3V, VDDL =1.8V) ......................................................... 59 20.8 USB PLL ELECTRONIC CHARACTERISTICS.................................................................................................................. 60 21. 21.1 TYPICAL APPLICATION REFERENCE CIRCUIT ..................................................................................................... 61 USB VOIP SPEAKER PHONE APPLICATION ................................................................................................................... 61 22. PACKAGE DIMENSIONS .......................................................................................................................................... 62 23. ORDERING INFORMATION ...................................................................................................................................... 63 24. REVISION HISTORY ................................................................................................................................................. 64 4 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION LIST OF TABLES Table 1 Pin Description .......................................................................................................................................................... 10 Table 2 W681308 MCU SFR location..................................................................................................................................... 22 Table 3 Interrupt Priority Structure.......................................................................................................................................... 23 Table 4 Timer Mode/Control TMOD/TCON SFR .................................................................................................................... 24 Table 5 Timer 2 Mode/Control TMOD/TCON SFR ................................................................................................................. 25 Table 6 Time-Out Values For Watchdog Timer ...................................................................................................................... 26 Table 7 Watchdog Control WDCON SFR............................................................................................................................... 26 Table 8 Watchdog Control Bits ............................................................................................................................................... 27 Table 9 Watchdog Timer Timeout Control.............................................................................................................................. 27 Table 10 Serial Control SCON SFR ....................................................................................................................................... 28 Table 11 JTAG Pin Description .............................................................................................................................................. 49 Table 12 W681308 USB Endpoint Definitions ........................................................................................................................ 53 Table 13 USB Descriptor RAM Definitions ............................................................................................................................. 54 LIST OF FIGURES Figure 1 Pin diagram ................................................................................................................................................................ 8 Figure 2 W681308 Function Block Diagram ........................................................................................................................... 11 Figure 3 Interrupt Structure .................................................................................................................................................... 31 Figure 4 Keypad Scanning Application Circuit........................................................................................................................ 33 Figure 5 PCM Interface, Gain Stage and Mixer Location ....................................................................................................... 36 Figure 6 Mixer Connection Case Examples ........................................................................................................................... 37 Figure 7 Mixer Examples with Registers Setting .................................................................................................................... 39 Figure 8 W681308 CODEC Signal Path Control .................................................................................................................... 43 Figure 9 Microphone Voltage Gain Mode ............................................................................................................................... 45 Figure 10 Microphone Current Gain Mode ............................................................................................................................. 45 Figure 11 Microphone Auxiliary Input Mode ........................................................................................................................... 46 Figure 12 SPI Block Diagram ................................................................................................................................................. 47 Figure 13 Ring Tone Generator Block .................................................................................................................................... 50 Figure 14 Signal flow through Acoustic Echo Cancellation in the speech processor.............................................................. 51 Figure 15 USB Function Block Diagram ................................................................................................................................. 52 Figure 16 W681308 Reference Design Application Circuit..................................................................................................... 61 5 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 1. General Description W681308 USB Audio Controller from Nuvoton integrates fast 8051 Microcontroller Unit (MCU), Universal Serial Bus (USB) 2.0 Full Speed compliant controller with PHY, 16bit high quality Analog to Digital Converter / Digital to Analog Converter (ADC/DAC) with 8/16/48 KHz wide band sampling rates, speaker phone and echo cancellation, 8 KB One Time Programmable (OTP) program memory and 1 KB data memory in a single 48 pin Low-profile Quad Flat Package (LQFP). MCU includes Joint Test Access Group (JTAG) In-Circuit Emulation(ICE) interface and can handle customer programs such as keypad scan, LCD control, caller list download, and USB and CODEC control among other features. W681308 provides highest integration and low BOM cost solution with 8051-based development platform for USB Audio peripherals and USB VoIP devices such as Skype® , other IM and SIP-based application. With Nuvoton’s market proven CODEC product experience, W681308 is designed to provide high audio quality in VoIP and audio devices applications and deliver USB Audio/VoIP solution with the shortest time to market, time to volume and time to profit 2. Features 8 Bit Turbo MCU ƒ Embedded 12/24/48 MHz Turbo 8051 MCU with 4 Clocks per machine Cycle ƒ 1 KB system RAM, 8 KB OTP ROM ƒ 256 byte internal RAM (8051) ƒ Power on Reset circuit ƒ Software Idle mode ƒ In Circuit Emulation (ICE) through JTAG Interface ƒ High Quality 16 bit Mono Audio Linear CODEC ƒ Built-in 8/16/48 KHz sampling rate wideband mono audio CODEC and true 16-bit resolution ADC/DAC with internal 24-bit audio processing for both record and playback ƒ Analog microphone(MIC) amplifier and speaker driver with internal programmable gain stage ƒ 82 dB Receive SNR @ 8 Ohm load USB 2.0 Full speed (FS) Interface with integrated PHY ƒ USB 2.0 FS compliant device controller and PHY with 12 Mbps communication speed ƒ Support 6 USB endpoints configuration: Control, ISO IN/OUT, Bulk IN/OUT and Interrupt IN ƒ 512-Byte RAM-based USB descriptor for multiple USB device support through 8051 MCU ƒ Less than 500uA supply current in suspend mode ƒ ƒ ƒ ƒ Fully integrated cap-less microphone amplifier with microphone bias Dual earphone / speaker driver and buzzer Integrated DAC switch for earphone or speaker phone Integrated Acoustic Echo Cancellation (AEC) ƒ Support both half-duplex AEC and 32ms full duplex AEC ƒ Built-in digital Auto Gain Control (AGC) with microphone input for speaker phone application Integrated keypad control pins and GPIO ƒ Suitable for VoIP application ƒ Volume up and down ƒ Dial / hang up ƒ Microphone and speaker phone mute ƒ LED indicators 6 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION ƒ ƒ ƒ ƒ Number pad control User programmable keys Keypad scanning LCD Module interface control UART ƒ Programmable UART port for serial data application PCM Interface ƒ Master linear PCM interface to external PCM device such as Nuvoton’s ProX CODEC/SLIC SPI interface ƒ Works in master mode to control Liquid Crystal Display (LCD) Module or other SPI slave devices ƒ Support Winbond serial flash device with SPI interface W2S 2 Wire interface ƒ Support 2 wire interface for EEPROM three format page modes USB 5V voltage supply ƒ Built-in linear regulator on chip supports 3.3V to 1.8V conversion for digital core power ƒ USB 5V to 3.3V supply power using external transistors Package ƒ 48-pin LQFP package 7mmx7mmx1mm Application ƒ USB audio peripheral box/ USB sound card ƒ USB microphone / USB mono headset ƒ Wired and Wireless USB VoIP phone with LCD ƒ USB VoIP ATA and Gateway ƒ PSTN and USB VoIP dual phone ƒ General USB MCU and audio application 7 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION JTAG GPIO15/KX0 GPIO16/KX1 GPIO17/KX2 GPIO18/KX3 GPIO19/KX4 GPIO20/KY0 GPIO21/KY1 GPIO22/KY2 GPIO23/KY3 GPIO24/KY4 REGL 47 46 45 44 43 42 41 40 39 38 37 Pin Configuration 48 3. GPIO14/UARTT(nTRST) 1 36 VREF1 GPIO13/UARTR(TMS) 2 35 VREF2 DGND 3 34 MCP XTALO 4 33 MCO XTALI 5 32 RGND VDDL 6 31 AGND DVDD 7 30 SPP DN 8 29 EARP DP 9 28 AVDD 10 27 EARN GPIO3/LED 11 26 SPN GPIO0(TCK) 12 25 AGND DGND W681308 48 Pin LQFP 21 22 23 24 GPIO4/PCMR GPIO5/PCMT GPIO1(TDI) GPIO2(TDO) VPP GPIO12/CSL 20 17 GPIO8/SDO GPIO6/BCLK 16 GPIO9/SDI 19 15 GPIO10/SCLK GPIO7/FS 14 GPIO11/CS 18 13 Figure 1 Pin diagram 8 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 4. Pin Description Please refer to Design Guide for product design details. Pin Name State in Reset 1 Pull-H UART TX data / JTAG TAP controller reset input /GPIO 14 D I/O 2 mA 2 Pull-H UART Rx data / JTAG TMS input / GPIO 13 D I/O 2 mA UARTT /nTRST Driver Pin No /GPIO 14 Functionality Pin Type Strength UARTR /TMS /GPIO 13 DGND 3 Digital ground supply voltage D P — XTALO 4 Crystal clock output A O — XTALI 5 Crystal clock input A I — VDDL 6 Logic supply voltage D P — DVDD 7 Digital supply voltage D P — DN 8 USB D- connection A I/O — DP 9 USB D+ connection A I/O — DGND 10 Digital ground supply voltage D P — LED/GPIO 3 11 Pull-H LED connection / GPIO 3 D I/O 16 mA TCK/GPIO 0 12 Pull-H JTAG Clock with internal pull up / GPIO 0 D I/O 16 mA CS/GPIO 11 13 Pull-H Chip select (used for SPI flash or normal SPI) /GPIO 11 D I/O 2 mA SCLK/GPIO 10 14 Pull-L Serial port bit clock ( For SPI flash or normal SPI) /GPIO 10 D I/O 2 mA SDI/GPIO 9 15 Pull-L Serial port data in (SPI flash/ SPI) /GPIO 9 D I/O 2 mA SDO/GPIO 8 16 Pull-H Serial port data out (SPI flash/ SPI) /GPIO 8 D I/O 2 mA CSL/GPIO 12 17 Pull-H LCD, LCM chip select /GPIO 12 D I/O 2 mA FS/GPIO 7 18 Pull-L PCM Frame Sync output /GPIO 7 D I/O 2 mA BCLK/GPIO 6 19 Pull-L PCM Bit Clock output or input / GPIO 6 D I/O 2 mA PCMR/GPIO 4 20 Pull-L Serial PCM Receive data input / GPIO 4 D I/O 2 mA PCMT/GPIO 5 21 Pull-L Serial PCM Transmit data output / GPIO 5 D I/O 2 mA TDI/GPIO 1 22 Pull-H JTAG Data Input / GPIO 1 D I/O 2 mA 9 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Pin Name Pin No State in Reset TDO/GPIO 2 23 Pull-L Functionality Pin Type Driver Strength JTAG Data Output / GPIO 2 D I/O 2 mA A P — VPP 24 Reset signal for digital core. Tie this pin to 6.75V for programming the OTP ROM AGND 25 Analog ground supply voltage A P — SPN 26 Speaker1 negative connection A O — EARN 27 Speaker2 negative connection A O — AVDD 28 Analog supply voltage A P — EARP 29 Speaker2 positive connection A O — SPP 30 Speaker1 positive connection A O — AGND 31 Analog ground supply voltage A P — RGND 32 Low noise ADC and DAC reference A P — MCO 33 The microphone amplifier output A G — MCP 34 Microphone positive connection A O — VREF2 35 Voltage reference A O — VREF1 36 Voltage reference A O — REGL 37 Linear regulator base control output A O — KY4/GPIO 24 38 Pull-H Keypad row Y4 connection /GPIO 24 D I/O 2 mA KY3/GPIO 23 39 Pull-H Keypad row Y3 connection /GPIO 23 D I/O 2 mA KY2/GPIO 22 40 Pull-H Keypad row Y2 connection /GPIO 22 D I/O 2 mA KY1/GPIO 21 41 Pull-H Keypad row Y1 connection /GPIO 21 D I/O 2 mA KY0/GPIO 20 42 Pull-H Keypad row Y0 connection /GPIO 20 D I/O 2 mA KX4/GPIO 19 43 Pull-L Keypad column X4 connection /GPIO 19 D I/O 2 mA KX3/GPIO 18 44 Pull-L Keypad column X3 connection /GPIO 18 D I/O 2 mA KX2/GPIO 17 45 Pull-L Keypad column X2 connection /GPIO 17 D I/O 2 mA KX1/GPIO 16 46 Pull-L Keypad column X1 connection /GPIO 16 D I/O 2 mA KX0/GPIO 15 47 Pull-L Keypad column X0 connection /GPIO 15 D I/O 2 mA JTAG 48 Pull-L Tie to DGND for normal operation. Tie to DVDD to enable JTAG function. D I 2 mA Table 1 Pin Description NOTE: All GPIO pins modes are controlled by register settings. 10 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 5. Block Diagram Figure 2 W681308 Function Block Diagram There are 4 major function block groups in the USB Audio Controller: ƒ Turbo 8051 MCU, registers, OTP/RAM memory and peripheral ports ƒ 16-bit audio quality CODEC with AEC/AGC ƒ USB 2.0 FS interface with SIE, Full Speed PHY and 6 end points ƒ SPI / UART / I2C / PCM / I2S and GPIO interfaces. 11 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 6. Memory Map 6.1 Program Memory map Memory is mapped into program memory and data memory. Program memory is mapped from 0x0000 to 0x1FFF (8 KB), it is used by internal OTP. 6.2 Data Memory map Data memory address Size (Byte) Function Total Available 0x1440 ~ 0x1443 4 4 Interrupt Control Registers 0x144A ~ 0x145F 22 20 Keypad IO, LCD, UART and GPIO Control Registers 0x1460 ~ 0x146F 16 16 Gain stage and Mixer Control Registers 0x1470 ~ 0x1474 16 5 PCM Control Registers 0x1480 ~ 0x148A 16 11 CODEC Control Registers 0x14A0 ~ 0x14AF 16 15 SPI Control Registers 0x14B0 ~ 0x14BA 16 11 W2S Control Registers 0x14C0 ~ 0x14C5 16 5 Ring Tone(PWM) Control Registers 0x1600 ~ 0x167F 128 120 Full/Half Duplex AEC Control Registers 0x1680 ~ 0x16FF 128 16 AGC Control Registers 0x1800 ~ 0x19FF 512 57 USB Control Registers 0x2000 ~ 0x23FF 1024 1024 USB RAM Based Descriptor Field 0x2800 ~ 0x2FFF 2048 2048 Full Duplex AEC RAM 0x3000 ~ 0x33FF 1024 1024 System RAM 12 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 7. Registers The registers are mapped by function. 7.1 MCU Clock Rate Select Register Address 0x1440 7.2 Name MCU Rate Select Mode R/W Value At Reset 0x00 Function MCU system clock rate selection Interrupt Control Registers Address Name Mode Value At Reset Function 0x1441 Interrupt Source R/W 0x00 Enable / Disable Interrupt source 0x1442 Interrupt Enable R/W 0x00 Enable / Disable Interrupt function 0x1443 Interrupt Priority R/W 0x00 Set Interrupt priority 7.3 Keypad IO, LCD, UART and GPIO Control Registers Address Name Mode Value At Reset Function 0x144A~ 0x144B GPIO [14:0] Pull Up/Down Control R/W 0x00 Enable/Disable GPIO [14:0] Pull Up/Down 0x144C~ 0x144F Keypad I/O (GPIO [24:15]) and GPIO [14:0] Pull Up/Down Selection R/W 0x00 Select Pull Up/Down for Keypad I/O (GPIO [24:15]) and GPIO [14:0] 0x1450~ 0x1453 Keypad I/O(GPIO [24:15]) and GPIO [14:0] Status R/W 0x00 Indicate Keypad I/O(GPIO [24:15]) and GPIO [14:0] pin status 0x1454~ 0x1457 Keypad I/O(GPIO [24:15]) and GPIO [14:0 Direction Control R/W 0x00 Select Keypad I/O(GPIO [24:15]) and GPIO [14:0] Input/Output Direction 0x1458~ 0x145B Keypad I/O(GPIO [24:15]) and GPIO [14:0] Interrupt control R/W 0x00 Enable/Disable Keypad I/O(GPIO [24:15]) and GPIO [14:0] Interrupt 0x145E LCD Control R/W 0x00 Enable/Disable LCD data, clock and chip selection control. 0x145F UART I/O Control R/W 0x00 Enable/Disable UART I/O control. 13 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 7.4 Gain Stage and Mixer Control Registers Address Name Mode Value At Reset Function Enable/Disable Gain Stage for Side tone Gain, CODEC to AEC Gain, AEC to CODEC Gain, AEC to Mixer Gain, Mixer to AEC Gain and USB in/USB out Gain. Select Mixer mode for USB, CODEC and PCM. Set Audio Gain Index Register Value (Side tone Gain, CODEC to AEC Gain, AEC to CODEC Gain, AEC to Mixer Gain, Mixer to AEC Gain, USB in and USB out Gain) 0x1460 Gain Stage and Mixer Control R/W 0x00 0x1461~ 0x1467 Gain Stage Index R/W 0x00 R 0x00 Enable/Disable MCU to monitor USB ISO In/Out data R/W 0x00 Enable/Disable MCU write data to USB and CODEC Mode Value At Reset R/W 0x00 Enable/Disable PCM Interface and Bit Clock / Frame Sync selection R/W 0x00 Set Frame Sync pulse length 0x1468~ 0x146B 0x146C~ 0x146F 7.5 MCU Record MCU Play PCM Control Registers Address Name 0x1470 PCM Control 0x1472 PCM Frame Length 7.6 Sync Function CODEC Control Registers Address Name Mode Value At Reset Function 0x1480 CODEC control R/W 0x00 Enable/Disable CODEC, Select Sampling Rate and High Pass Frequency 0x1481 Dither Control R/W 0x00 Enable/Disable Dither Function 0x1482~ 0x1483 0x1484~ 0x1485 CODEC ADC Digital Gain CODEC DAC Digital Gain R/W 0x04 0x00 Set Digital ADC Path Gain R/W 0x04 0x00 Set Digital DAC Path Gain 0x1488 CODEC MIC Control R/W 0x00 Set microphone bias voltage and bias resistor reference 0x1489 CODEC MIC Control R/W 0x00 Select MIC interface mode and Set microphone gain R/W 0x00 Attenuate speaker phone/ earphone speaker and Set speaker gain R/W 0x00 Enable/Disable CODEC Analog Block 0x148A 0x148B CODEC Speaker Control CODEC Analog Control 14 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 7.7 SPI Control Registers Address Name SPI Clock and Interface SPI Command Interface Control 0x14A0 0x14A1 Mode Value At Reset R/W 0x00 R/W 0x00 Function Enable/Disable SPI interface and Select SPI bit clock rate Set SPI interface command length, R/W and other control 0x14A2 SPI Data Length RW 0x00 Set SPI interface data field length 0x14A3 SPI Interrupt Control R/W 0x00 Enable/Disable SPI interface interrupt 0x14A4~ 0x14A8 SPI Command Byte Control SPI Clock Format Control RW 0x00 Set SPI interface command byte 1 to 5 RW 0x00 Set SPI interface clock format 0x14AB 0x14AC SPI FIFO Data RW 0x00 Read/write data from SPI interface FIFO 0x14AD SPI Byte Count R 0x00 Current SPI interface FIFO counter value 0x14AE SPI Write Count R/W 0x00 MCU current Write point for SPI interface FIFO 0x14AF SPI Read Count R/W 0x00 MCU current Read point for SPI interface FIFO 7.8 W2S Control Registers Address Name Mode Value At Reset Function 0x14B0 W2S Enable R/W 0x00 Enable/Disable W2S bus controller 0x14B1 EEPROM control R/W 0x00 Set different page mode and page size of EEPROM 0x14B2~ 0x14B3 W2S Clock R/W 0x00 Set W2S bit clock rate 0x14B4 W2S R/W FIFO R/W 0x00 Read/Write W2S compatible device 0x14B5 W2S R/W Operation Control R/W 0x00 Set W2S Read/Write and FIFO control 0x14B6 W2S Status R/W 0x00 Indicate W2S FIFO space and ACK signal status 0x14B7 FIFO Read Pointer R/W 0x00 Indicate W2S FIFO read pointer 0x14B8 FIFO Write Pointer R/W 0x00 Indicate W2S FIFO write pointer 0x14B9 ACK Failure Detect R/W 0x00 0x14BA W2S Miscellaneous Control R/W 0x00 Set ACK failure detect and indicate failure data pointer in FIFO Indicate status for SCL_in, finite state machine state and interrupt signal status 15 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 7.9 Ring Tone (PWM) Control Registers Address Name Mode Value At Reset Function 0x14C0 PWM Clock R/W 0x00 Enable/Disable PWM Operation Clock 0x14C2 PWM Tone1 Control R/W 0x00 Set Tone 1 Volume 0x14C3 PWM Tone1 Frequency R/W 0x00 Set Tone 1 Frequency 0x14C4 PWM Tone2 Control R/W 0x00 Set Tone 2 Volume 0x14C5 PWM Tone2 Frequency R/W 0x00 Set Tone 2 Frequency 7.10 Full/Half Duplex Acoustic Echo Cancellation (AEC) Control Registers Address Name Mode Value At Reset Function 0x1600 AEC Configuration R/W 0x96 Set AEC Configuration parameters 0x1601 AEC Reset Control R/W 0x08 Set AEC power down and reset function 0x1602 AEC Mode Control R/W 0x03 Set AEC Full/Half duplex mode and Noise suppressor R/W 0x09 Set time constant for long term power estimation of double talk R/W 0x0B Set time constant for short term power estimation of double talk R/W 0x0020 Set hangover time window of double talk detection algorithm R/W 0x19A8 Set deviation power threshold of double talk R/W 0x0000 Set power threshold for long term power estimation of double talk R/W 0x1010 Set power threshold for short term power estimation of double talk R 0x0F Set AEC Divergence threshold R/W 0x09 Set time constant for long term power estimation of Voice Detect R/W 0x0B Set time constant for short term power estimation of Voice Detect R/W 0x0009 Set hangover time window of Voice Detect detection algorithm 0x1605 0x1606 0x1607~ 0x1608 0x1609~ 0x160A 0x160B~ 0x161C 0X160D~ 0x160E 0X160F 0x1610 0x1611 0x1612~ 0x1613 Double Talk Long Term Power Time Constant Double Talk Short Term Power Time Constant Double Talk Hangover Time Double Talk Deviation Threshold Double Talk Long Term Power Threshold Double Talk Short Term Power Threshold AEC Divergence Threshold Voice Detect Long Term Power Time Constant Voice Detect Short Term Power Time Constant Voice Detect Hangover Time 16 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Mode Value At Reset Function R/W 0x1998 Set deviation power threshold of Voice Detect R/W 0x1998 Set power threshold for long term power estimation of Voice Detect R/W 0x0BA8 Set Low power threshold for short term power estimation of Voice Detect R/W 0x1038 Set high power threshold for short term power estimation of Voice Detect R/W 0x0000 Set average power threshold for short term power estimation of Voice Detect Power Cut Off Control R/W 0x1998 Set zero reference bias for power cut off estimation AGC Threshold R/W 0x2000 Set maximum output power of AGC AGC Noise Threshold R/W 0x0320 Set AGC calculated input power with time constant AGC Gain from AEC R/W 0x02 Set maximum gain for post echo cancellation signal R/W 0xBB Set delay time constant for long term gain estimation R/W 0x09 Set delay time constant for short term gain estimation R/W 0x00 Enable/Disable soft clip(SC) function R/W 0x00 R/W 0x00 R/W 0x1000 R/W 0x07 R/W 0x07 R/W 0x77 R/W 0x1CA8 R/W 0x77 R/W 0x1CA8 R/W 0xBB R/W 0xBB Address Name 0x1614~ 0x1615 Voice Detect Deviation Threshold Voice Detect Long Term Power Threshold Voice Detect Short Term Power Low Threshold Voice Detect Short Term Power High Threshold Voice Detect Short Term Power Average Threshold 0x1616~ 0x1617 0x1618~ 0x1619 0X161A~ 0X161B 0X161C~ 0X161D 0X161E~ 0X161F 0x1620~ 0x1621 0x1622~ 0x1623 0x1624 0x1625 0x1626 0x1628 0x1629 0x162A 0x162B~ 0x162C 0x162D 0x162E 0x1630 0x16310x1632 0x1633 0x1634~ 0x1635 0x1638 0x1639 AGC Gain Time constant AGC Gain Time constant Soft Clip Control Soft Clip Normal Gain Index Soft Clip Low Gain Index Soft Clip Threshold Soft Clip Power Time Constant Soft Clip Gain Time Constant Acoustic Suppression 1 Time Constant Acoustic Suppression 1 attenuation Acoustic Suppression 2 Time Constant Acoustic Suppression 2 attenuation Noise Suppressor Control Noise Suppressor Gain Time Constant Set gain index of voice detect for soft clip module at normal gain mode Set gain index of voice detect for soft clip module at low gain mode 17 Set threshold level to select soft clip gain mode Set time constant for short term power calculation of voice detect soft clip Set time constant to smooth gain mode change of soft clip Set time constant of acoustic suppression (AS1) for convergence towards target Set maximum attenuation value for acoustic suppression (AS1) algorithm Set time constant of acoustic suppression (AS2) for convergence towards target Set maximum attenuation value for acoustic suppression (AS2) algorithm Set noise suppressor gain index and short term power time constant Set time constant for rise and fall of noise suppressor gain index Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Address Name Mode Value At Reset Function R/W 0x03E8 Set threshold level for active noise suppressor R 0x0000 R 0x0000 R 0x0000 R 0x0000 R 0x0000 R 0x0000 0x1640~ 0x1641 0x1642~ 0x1643 0x1644~ 0x1645 0x1648~ 0x1649 0x164A~0x 164B 0x164C~0x 164D Noise Suppressor Active Power Threshold Short Term Power voice detector Long Term Power Voice Detector Voice Detector Power Deviation Short Term Power Double Talk Long Term Power Double Talk Double Talk Power Deviation 0x1680 AGC Control R/W 0x00 Enable / Disable AGC and Set max gain control 0x1681 AGC Initial Gain Control R/W 0x00 Enable/Disable AGC initial gain setting 0x1682 AGC Gain Time R/W 0x00 Set decreasing and increasing gain time for AGC 0x1683 AGC Peak Release Time R/W 0x00 Set release time for AGC peak voice level 0x1684 AGC Gain Monitor R 0x00 Indicate AGC gain status R 0x00 Indicate AGC gain status at increasing, target or decreasing region. R 0x0000 Indicate AGC Short Term Power estimation R/W 0x0000 Set AGC target region threshold R/W 0x0000 Set AGC Noise low threshold level R/W 0x0000 Set AGC Noise high threshold level 0x163A~ 0X163B 0x1685 0x1687~ 0x1689 0x168A~0x 168B 0x168C~0x 168D 0x168E~0x 168F 7.11 AGC Gain Region Monitor AGC Short Term Power AGC Target Threshold AGC Noise Low Threshold AGC Noise High Threshold Indicate Short Term Power calculated by the voice detector (VD). Indicate Long Term Power calculated by the voice detector (VD). Indicate Power Deviation estimated by the voice detector (VD). Indicate Short Term Power calculated by double-talk detector (DT). Indicate Long Term Power calculated by double-talk detector (DT). Indicate Power Deviation estimated by the double-talk detector (DT). USB Controller Registers Address Name Mode Value At Reset 0x1800 USB Enable R/W 0x00 Enable/Disable USB 1.1 function control 0x1801~ 0x1803 USB Interrupt Register A R/W 0x00 Set USB endpoints interrupt enable, status and clear. 0x1804 ~ 0x1806 USB Interrupt Register B R/W 0x00 Set USB endpoints interrupt enable, status and clear. 18 Function Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Address Name Mode Value At Reset 0x1807 ~ 0x1809 USB Interrupt Register C R/W 0x00 Set USB Audio Class interrupt enable, status and clear. 0x1810 Endpoint 0 – Control In/Out R/W 0x00 Set USB Control in/out Endpoint control Function 0x1811 Control In Data R/W 0x00 Control in Endpoint Data. Internal FIFO has 1 byte for Control In transmission. If the 3rd Token byte is not equal to 0x01 or 0x03 (HID set report application), this byte will be transmitted instead of Control-IN FIFO and InterruptIN FIFO content. 0x1828 ~ 0x182F Control Out Data R 0x00 Control Out Endpoint receiving data. 0x1830 Endpoint 1 and 2 – ISO In/Out R/W 0x00 Set ISO In/Out Endpoint control register. 0x1831 Sampling Frequency R 0x00 Indicate ISO Sampling Frequency 0x18320x1833 Record Volume R 0x00 Indicate Current Record Volume 0x18340x1835 Play Volume R 0x00 Indicate Current Play Volume 0x1836 HID Control Out Information R 0x00 Indicate First Packet and Valid Length 0x1837 Max Volume R 0x00 Indicate Audio Path Max Volume Gain 0x1838 HID Token Information R/W 0x00 Set HID Token 3rd byte 0x1839 HID Descriptor Length R/W 0x00 This register value must be equal to the USB descriptor with respect to the HID return length 0x1840 ~ 0x1847 ISO SYNC Speed R/W 0x00 Set ISO SYNC speed tuning parameter register. 0x1848 Endpoint 3 – Bulk In Control Register R/W 0x00 Set Bulk In Endpoint control register 0x1849 Bulk In Data W 0x00 Set Bulk In transmission data register except final data. 0x184A Bulk In Final Data W 0x00 Set Bulk In transmission final data register. 0x184B Bulk In FIFO Empty Flag R 0x00 Indicate Bulk In transmission data FIFO empty flag. 0x1850 Endpoint 4 – Bulk Out Control Register R/W 0x00 Set Bulk Out Endpoint control register 19 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Address Name Mode Value At Reset 0x1851 Bulk Out FIFO Length R 0x00 Indicate Bulk Out Endpoint receiving data FIFO length. 0x1852 Bulk Out Data R 0x00 Bulk Out Endpoint receiving data FIFO. 0x1858 Endpoint 5 – Interrupt In Control Register R/W 0x00 Set Interrupt In Endpoint control register 0x1859 USB Interrupt Data Length R/W 0x00 Interrupt In Endpoint transmission data length 0x1880 USB ISO MCU Enable R/W 0x00 Enable ISO IN/OUT FIFO access by MCU 0x1881 USB ISO IN FIFO Depth R 0x00 ISO OUT FIFO depth indication 0x1882 USB ISO OUT FIFO Depth R 0x00 ISO IN FIFO depth indication 0x1883~ 0x1884 USB ISO IN DATA R/W 0x00 ISO IN data sample will be written by MCU 0x1885~ 0x1886 USB ISO OUT DATA R 0x00 ISO IN data sample will be read by MCU 0x20000x21FF USB Descriptor RAM data filed R/W 0x00 USB Descriptor 0x22000x223F HID Control-IN data field R/W 0x00 HID Control-IN data field 0x22400x227F HID Interrupt-IN data field R/W 0x00 HID Interrupt-IN data field 0x23000x233F HID Control-OUT data field R/W 0x00 HID Control-OUT data field 20 Function Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 8. 8.1 Microcontroller Features ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ 8.2 8.2.1 8-bit Turbo 8051 Microcontroller with 12/24/48 MHz speed 256 bytes of on chip internal data RAM and 1K bytes external data RAM Instruction set compatible with Nuvoton Turbo 8051 Three 8-bit I/O ports Three 16-bit timers One Full-duplex serial port On-Chip debugger via JTAG (Joint Test Access Group) port 7 interrupt sources with two level priorities Programmable Watchdog Timer Two 16-bit data pointers On Chip 8 KB OTP (One time programmable) memory Memory Organization Program Memory On-chip 8k OTP Memory: All instructions are fetched for execution from this memory area. The MOVC instruction can also access this memory region. 8.2.2 Data Memory The MCU can access 1K bytes of external Data Memory. This memory region is accessed by the MOVX instruction. Additionally it has 256 bytes on chip RAM which can be accessed either by direct addressing or by indirect addressing. Some Special Function Registers (SFRs) can only be accessed by direct addressing. FF 1FFF Indirect RAM Addressing SFRs Direct Addressing only 8K Byte OPT Internal ROM 80 7F Direct&Indirect Addressing 00 33 F F 3000 21 1K Byte RAM 0000 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Special Function Registers (SFR) 8.2.3 Address Byte 0 F8 EIP F0 B E8 EIE E0 ACC D8 WDCON D0 PSW C8 T2CON Byte 1 Byte 2 T2MOD RCAP2L Byte 3 Byte 4 Byte 5 RCAP2H TL2 TH2 PMR STATUS C0 Byte 6 Byte 7 TA B8 IP SADEN B0 P3 A8 IE SADDR A0 P2 XRAMAH 98 SCON SBUF 90 P1 88 TCON TMOD TL0 TL1 TH0 TH1 CKCON 80 P0 SP DPL DPH DPL1 DPH1 DPS PCON Table 2 W681308 MCU SFR location 8.3 Power Management The W681308 has IDLE mode operation features that manage and save power consumption of the device. Enable IDLE mode The user can set the device into idle mode by writing 1 to the PCON bit of SFR. The instruction that sets the idle bit is the last instruction that will be executed before the device goes into Idle Mode. In the Idle mode, the clock to the MCU is halted but not to the Interrupt, Timer, Watchdog timer, and Serial ports blocks. This forces the MCU state to be frozen; the Program counter, the Stack Pointer, the Program Status Word, the Accumulator and the other registers hold their contents. The ALE and PSEN pins are held high during the idle state. The port pins hold the logical states they had at the time Idle was activated. The Idle mode can be terminated in two ways: ƒ Activation of any enabled interrupt Since the interrupt controller is still active, the activation of any enabled interrupt can wake up the processor. This will automatically clear the Idle bit, terminate the Idle mode, and the Interrupt Service Routine (ISR) will be executed. After the ISR, execution of the program will continue from the instruction which put the device into idle mode. 22 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION ƒ Activation of reset The Idle mode can also be exited by activating the reset. The device can be put into reset either by applying a high on the external RST pin, a Power on reset condition or a Watchdog timer reset. The external reset pin has to be held high for at least two machine cycles i.e. 8 clock periods to be recognized as a valid reset. In the reset condition the program counter is reset to 0000h and all the SFRs are set to the reset condition. Since the clock is already running there is no delay and execution starts immediately. In Idle mode, the Watchdog timer continues to run, and if enabled, a time-out will cause a watchdog timer interrupt which will wake up the device. The software must reset the Watchdog timer in order to preempt the reset which will occur after 512 clock periods of the time-out. When the W681308 is exiting from an idle mode with a reset, the instruction following the one which put the device into idle mode is not executed. So there is no danger of unexpected writes. 8.4 Reset Conditions There are two ways to put device into reset state: external reset and watchdog reset. 8.4.1 External Reset The device continuously samples the RST pin at state C4 of every machine cycle. Therefore the RST pin must be held for at least 2 machine cycles to ensure detection of a valid RST high. The reset circuitry then synchronously applies the internal reset signal. Thus the reset is synchronous operation and requires the clock to be running to cause an external reset. Once the device is in reset condition, it will remain so long as RST is 1. Even after RST is deactivated, the device will continue to be in reset state for up to two machine cycles, and then begin program execution from 0000h. 8.4.2 Watchdog Reset The Watchdog timer is a free-running timer with programmable time-out intervals. The user can clear the watchdog timer at any time, causing it to restart the count. When the time-out interval is reached an interrupt flag is set. If the Watchdog reset is enabled and the watchdog timer is not cleared, then 512 clocks from the flag being set, the watchdog timer will generate a reset. This places the device into the reset condition. The reset condition is maintained by hardware for two machine cycles. Once the reset is removed the device will begin execution from 0000h. 8.5 Interrupts The W681308 MCU has three priority levels interrupt structure with 7 interrupt sources. Each of the interrupt sources has an individual priority bit, flag, interrupt vector and enable bit. Additionally, all the interrupts can be globally enabled or disabled. Source Flag Priority Vector address External Interrupt 0 IE0 1 (highest) 0003h Timer 0 Overflow TF0 2 000Bh External Interrupt 1 IE1 3 0013h Timer 1 Overflow TF1 4 001Bh RI + TI 5 0023h Timer 2 Overflow TF2 + EXF2 6 002Bh Watchdog Timer WDIF 7 (lowest) 0063h Serial Port Table 3 Interrupt Priority Structure 23 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 8.6 Programming Timers and Counters The MCU of W681308 has three 16-bit programmable timers/counters and one programmable Watchdog timer. The Watchdog timer is operationally quite different from the other three timers. 8.6.1 Timers/Counters 0 and 1 Timer 0 (TM0) and Timer 1 (TM1) are 16-bit Timer/Counters and are nearly identical. Each of these Timers/Counters has two 8 bit registers which form the 16 bit counting register. For Timer/Counter 0 they are TH0, the upper 8 bits register, and TL0, the lower 8 bit register. Similarly Timer/Counter 1 has two 8 bit registers, TH1 and TL1. The two timers can be configured to operate either as timers to count machine cycles or as counters counting external inputs. In Timer mode, the timer counts clock cycles. The timer clock can be programmed to be thought of as 1/12 of the system clock or 1/4 of the system clock. In Counter mode, the register is incremented on the falling edge of the corresponding external input pins, T0 for Timer 0 and T1 for Timer 1. The T0 and T1 inputs are sampled in every machine cycle at C4. If the sampled value is high in one machine cycle and low in the next, then a valid high to low transition on the pin is recognized and the count register is incremented. Since it takes two machine cycles to recognize a negative transition on the pin, the minimum period at which counting will take place is double of the machine cycle. In either the Timer or Counter mode, the count register will be updated at C3. Therefore, in the Timer mode, the recognized negative transition on pin T0 and T1 can cause the count register value to be updated only in the machine cycle following the one in which the negative edge was detected. The Timer or Counter function is selected by the C/T bit in the TMOD Special Function Register. Each Timer/Counter has one selection bit for its own. Bit 2 of TMOD selects the function for Timer/Counter 0 and bit 6 of TMOD selects the function for Timer/Counter 1. 89H Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TMOD GATE C/T M1 M0 GATE C/T M1 M0 88H Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 TCON TF1 TR1 TF0 TR0 IE1 IT1 IE0 IT0 Table 4 Timer Mode/Control TMOD/TCON SFR 24 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 8.6.2 Timer/Counter 2 Timer/Counter 2 is a 16 bit up/down counter which is configured by the T2MOD register and controlled by the T2CON register. Timer/Counter 2 is equipped with a capture/reload capability. As with the Timer 0 and Timer 1 counters, they provide wide selection and control of the clock and selection of the operating modes. The clock source for Timer/ Counter 2 can be selected for the crystal oscillator, which is divided by 12 or 4 ( C/T2 = 0). The clock is then enabled when TR2 is a 1, and disabled when TR2 is a 0. C9H Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 T2MOD - - - - T2CR - - DCEN T2CON TF2 EXF2 RCLK TCLK EXEN2 TR2 C/T2 CP/RL2 Table 5 Timer 2 Mode/Control TMOD/TCON SFR 8.6.3 Watchdog Timer The Watchdog timer is a free-running timer that can be programmed by the user to serve as a system supervisor, a timebase generator or an event timer. It is basically a set of dividers that divide the system clock. The divider output is selectable and determines the time-out interval. When the time-out occurs the flag WDIF is set, which can cause an interrupt if enabled, and a system reset can also be caused if it is enabled. The interrupt will occur if the individual interrupt enable and the global enable are set. The interrupt and reset functions are independent of each other and may be used separately or together depending on the software employed. Fosc 12/24/ 48MHz 0 WD1,WD 0 22 WDIF EWD(EIE.4 ) 00 23 24 01 10 25 WTRF Time-out 11 512 clock delay Reset Watchdog PWT(WDCON. Interru pt 26 27 Enable Watchdog timer reset EWT(WDCON.1) Res et When used as a simple timer, the reset and interrupt functions are disabled. The timer will set the WDIF flag each time the timer completes the selected time interval. The WDIF flag is polled to detect a time-out and the RWT allows software to restart the timer. The Watchdog timer can also be used as a very long timer. The interrupt feature is enabled in this case. Every time the time-out occurs an interrupt will occur if the global interrupt enable EA is set. 25 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION The main use of the Watchdog timer is as a system monitor. This is important in real-time control applications. In case of some power glitches or electro-magnetic interference, the processor may begin to execute errant code. If this is left unchecked the entire system may crash. Using the watchdog timer interrupt during software development will allow the user to select ideal watchdog reset locations. The code is first written without the watchdog interrupt or reset. Then the watchdog interrupt is enabled to identify code locations where interrupt occurs. The user can now insert instructions to reset the watchdog timer which will allow the code to run without any watchdog timer interrupts. Now the watchdog timer reset is enabled and the watchdog interrupt may be disabled. If any errant code is executed now, then the reset watchdog timer instructions will not be executed at the required instants and watchdog reset will occur. Number of Clocks Time@12MHz Time@24MHz Time@48MHz 2 8388608 699.05 ms 349.53 ms 174.76 ms 1 225 33554462 2796.20 ms 1398.10 ms 699.05 ms 1 0 226 67108864 5592.41 ms 2796.20 ms 1398.10 ms 1 1 228 268435456 22369.62 ms 11184.81 ms 5592.41 ms WD1 WD0 0 0 0 Watchdog Interval 23 Table 6 Time-Out Values For Watchdog Timer The Watchdog timer will be disabled by a power-on/fail reset. The Watchdog timer reset does not disable the watchdog timer, but will restart it. NOTE: In general, software should restart the timer to put it into a known state. D8H Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 WDCON - POR - - WDIF WTRF EWT RWT External Reset 0 x 0 x 0 x x 0 Table 7 Watchdog Control WDCON SFR Control Bit Name Function POR Power-on Reset Flag WDIF Watchdog Timer Interrupt Flag This bit is set by hardware to indicate that the time-out period has elapsed and invoke watch dog timer interrupt if enabled(EWDI=1). This bit must be cleared by software. WTRF Watchdog Timer Reset Flag Hardware will set this bit when the watchdog timer causes a reset. Software can read it but must clear it manually. A power-fail reset will also clear the bit. This bit helps software in determining the cause of a reset. If EWT = 0, the watchdog timer will have no affect on this bit. Hardware will set this flag on a power up condition. This flag can be read or written by software. A write by software is the only way to clear this bit once it is set. 26 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Control Bit Name Function EWT Enable Watchdog timer Reset Setting this bit will enable the Watchdog timer Reset function. RWT Reset Watchdog Timer This bit helps in putting the watchdog timer into a know state. It also helps in resetting the watchdog timer before a time-out occurs. Failing to set the EWT before time-out will cause an interrupt, if EWDI (EIE.4) is set, and 512 clocks after that a watchdog timer reset will be generated if EWT is set. This bit is self-clearing. Table 8 Watchdog Control Bits WTRF is set to a 1 on a Watchdog timer reset, set to 0 on power on/down resets. WTRF is not altered by an external reset. POR is set to 1 by a power-on reset. EWT is cleared to 0 on a Power-on reset and unaffected by other resets. To prevent software from accidentally enabling or disabling the watch dog reset function, the bit of WDCON requires Time Access (TA) procedure to write. Example: mov TA, #0AAH mov TA, #055H clr WDIF WD1, WD0 are Time-out bits for Watchdog Timer located at CKCON.7 and CKCON.6. These bits determine the time-out period of the watchdog timer. The reset time-out period is 512 clocks longer than the watchdog time-out. WD1 WD0 Interrupt time-out Reset time-out 0 0 223 223 + 512 0 1 225 225 + 512 1 0 226 226 + 512 1 1 228 228 + 512 Table 9 Watchdog Timer Timeout Control 27 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 8.7 Serial Port (UART) The MCU serial port is a full-duplex port, and the MCU provides additional features, such as Frame Error Detection and Automatic Address Recognition. The serial port is capable of synchronous and asynchronous communication. In synchronous mode, the MCU generates the clock and operates in half-duplex mode. In asynchronous mode, the serial port can simultaneously transmit and receive data. The transmit register and the receive buffer are both addressed as SBUF, but any write to SBUF writes to the transmit register while any read from SBUF reads from the receive buffer. The serial port can operate in four modes: MOD 0, MOD 1, MOD 2 and MOD 3. 98H Bit 7 SCON SM0/FE Bit 6 SM1 Bit 5 SM2 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 REN TB8 RB8 TI RI Table 10 Serial Control SCON SFR 8.8 OTP ROM The W681308 internal OTP ROM is designed to store all application firmware. ƒ 8kB One-Time Programmable Logic Device The OTP programming is done by the injection of hot electrons which are generated by avalanche impact ionization in the bit cell. User can enter JTAG mode to program 8k OTP ROM through JTAG interface pins and signal of PCMT pin will go high simultaneously. The signal of pin PCMT can be used to control external hardware device to apply 6.75V or 3.3V to programming voltage pin VPP. The cells are initialized by ultraviolet light through internal photoemission from the floating gate. ƒ Enable OTP Read Protection You can write zero to bit 7 of OTP address 0x1fff to turn on the read protection feature. 28 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 9. 9.1 9.1.1 Clock Control and Reset Clock Control Overview Each register in the 12/24/48 MHz USB Audio Controller is reset synchronously. The Reset and Clock Control function ensures that the system reset signal is correctly generated. The system reset signal is also used to ensure that bi-directional signals are all set to input during initialization. 9.1.2 Clock Generation The crystal oscillator circuit and the external attachment of a 12 MHz quartz crystal or ceramic resonator is shown below. The Rf is used to DC bias the internal amplifier to operate in the linear region. The R1, C1, and C2 are chosen so as not to overdrive the crystal and to suppress oscillation at higher harmonics. Rf = 1MΩ, R1=270Ω, C1 and C2 are to be 33pf each. XTAL_IN Rf XTAL_OUT R1 C2 External Crystal C1 The PLL block diagram is shown below. The PLL uses the output of the crystal oscillator as its reference clock and generate a 48 MHz clock. 29 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 9.1.3 Control Register MCU Rate Select Address Access Mode Value At Reset 0x1440 R/W 0x00 Bit 7 Bit 6 MCU Rate Select [7:6] MCU Rate Select [7:6] Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Reserved Reserved Reserved Reserved Reserved Reserved MCU Clock Rate select (default = 00 ) 00 = 12 MHz , Use for CODEC/AEC/USB Controller 01 = 24 MHz 10 = 48 MHz , Use for MCU/USB PHY/Peripherals 11 = Reserved 30 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 10. 10.1 Interrupt Control Overview The W681308 generates internal events, these interrupt events are triggered by the interrupt control logic. The MCU supports two priority levels of interrupts with 6 interrupt sources. 10.2 Functionality The External Interrupts INT0 and INT1 can be either edge triggered or level triggered, The Interface and Support logic generate the following interrupts: ƒ ƒ ƒ ƒ ƒ ƒ NFS interrupt Keypad-Wakeup Interrupt GPIO interrupt SPI interrupt W2S interrupt USB interrupt Three registers control the generation of interrupts in the W681308, the interrupt source register, the interrupt enable register and the interrupt priority register. Each interrupt has a corresponding bit in these three registers. The interrupt source register is set when an interrupt event occurs and is cleared by MCU. When the MCU writes to interrupt source, any bit that is set to 1 cause the corresponding bit of interrupt source to be cleared, bits set to 0 are not affected (write “one” to clear). An Interrupt is generated when (interrupt source) & (interrupt enable) =1 for any of the interrupt sources. For each bit; if interrupt priority = 0, the interrupt is issued to INT0, if interrupt priority = 1, the interrupt is issued to INT1. Interrupt Source & Interrupt Enable Interrupt Priority & INT0 & INT1 Figure 3 Interrupt Structure 31 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 10.3 Interrupt Control Registers Address Access Mode Value At Reset 0x1441 ~ 0x1443 R/W 0x00 Address Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 0x1441 USB Interrupt W2S Interrupt SPI Interrupt GPIO Interrupt KeypadWakeup Interrupt Bit 2 Bit 1 NFS Interrupt Reserved Bit 0 Reserved NOTE: The NFS interrupt occurs for every 8 CODEC frames. Interrupt Source Register (0x1441) Interrupt Enable Register (0x1442) Interrupt Priority Register (0x1443) Read: 1 = Interrupt 0 = No Interrupt Write: 1 = Clear 1 = Enable 0 = Disable 0 = INT0 1 = INT1 32 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 11. Interface Logic The W681308 Interface logic consists of: ƒ Keypad Scanner Interface ƒ Input/Output GPIO Ports ƒ LCD/LCM interface ƒ UART interface ƒ JTAG Interface ƒ PCM Interface ƒ SPI for Serial Data Flash ƒ W2S Interface Keypad scanner, GPIO, LCD/LCM and UART interfaces are covered in this section. Software Keypad Scanner 11.1 The keypads consist of a number of buttons, connected in a row/column arrangement as shown in Figure 4 The default pin KX[4:0] is pull-L and pin KY[4:0] is pull-H, User can follow below steps to scan the keypad by software: 1. 2. 3. Program KX[4:0] pin to output direction and output data 0. Program KY[4:0] pins to input direction. While key is pressed, MCU will be informed by GPIO interrupt then to check KX[4:0] and KY[4:0] status. KX[4:0] keep output data 0, then to read KY[4:0] status by register 0x1451[4:0], By reading KY[4:0] status, MCU can know which bit equal 0, allowing it to determine which row is pressed. Change pin KY[4:0] from input direction to output direction and output data 1. Change pin KX[4:0] from output direction to input direction then to read KX[4:0] status by register 0x1450[4:0]. By reading KX[4:0] status, MCU can know which bit equal 1, allowing it to determine which column is pressed. MCU knows which row and column are pressed, so it can determine which key is pressed. 4. 5. S1 S2 S3 S4 S5 S6 S7 S8 S9 S10 S11 S12 S13 S14 S15 S16 S17 S18 S19 S20 S21 S22 S23 S24 S25 KY[0] KY[1] KY[2] KY[3] KY[4] KX[0] KX[1] KX[2] KX[3] KX[4] Figure 4 Keypad Scanning Application Circuit 33 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 11.2 GPIO s W681308 has 25 GPIO pins that are mainly used for keypad scanner, LCM controller, SPI, W2S, PCM interface, UART port, JTAG interface and GPIO s. NOTE: The pin function for LED, CS, SCLK, SDI, SDO and CSL will act as different functions according to the setting of LCD_ENB (0x145E), SPI_ENB (0x14A0), RDY_ENB(0x14AB) and W2S_ENB(0x14B0). Address Name Values 0x145E[3] LCD_ENB 0 1 1 0 0 0 0x14A0[7] SPI_ENB 0 0 1 1 1 0 0x14AB[5] RDY_ENB 0 0 0 0 1 0 0x14B0[7] W2S_ENB 0 0 0 0 0 1 Functions Pin Number Pin Name GPIO 0x145E[2:0] for LCD driver Control SPI for LCD driver SPI for data flash ISD15000 W2S 11 LED GPIO 3 GPIO 03 GPIO 3 GPIO 3 SPI_RDY GPIO 3 13 CS GPIO 11 GPIO 11 SPI_CS SPI_CS SPI_CS GPIO 11 14 SCLK GPIO 10 LCD_CKN (0x145E[B1]) SPI_CLK SPI_CLK SPI_CLK W2S_SCL 15 SDI GPIO 9 GPIO 09 GPIO 9 SPI_SDI SPI_SDI GPIO 9 16 SDO GPIO 8 SPI_DO SPI_SDO SPI_SDO W2S_SDA 17 CSL GPIO 12 Pull High GPIO 12 GPIO 12 GPIO 12 LCD_TX (0x145E[B0]) LCD_CSN (0x145E[B2]) 34 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 11.3 LCD Control Address Access Mode Value At Reset 0x145E R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Reserved Reserved Reserved Reserved LCD_ENB LCD_CSN LCD_CKN LCD_TX LCD Write Out Data LCD Write Out Clock LCD Write Out Chip Select Enable (active low) LCD I/O Enable Control : 1 = Enable, 0 = Disable Set this bit to enable LCD control interface : Pin 17 CSL = LCD_CSN Pin 14 SCLK = LCD_CKN Pin 16 SDO = LCD_TX LCD_TX LCD_CKN LCD_CSN LCD_ENB 11.4 UART I/O Control Address Access Mode Value At Reset 0x145F R/W 0x00 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 UART IO ENB Reserved Reserved Reserved Reserved Reserved Reserved Reserved UART IO ENB UART I/O Enable Control, 1 = Enable, 0 = Disable 35 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 12. 12.1 PCM Interface , Gain Stage and Mixer PCM Interface The PCM module is a 16-bit parallel/serial data transfer interface. It transfers the 16 bits data from Gain-Stage/Mixer to single bit Output, and transfers the one bit signal data of Input pin to 16 bits data buffer to the Gain-Stage / Mixer. In normal operation, the FS and BCLK are generated from the analog PLL module. PCM Interface specification: ƒ Master Mode Only ƒ Support TX / RX path mute ƒ 8 PCM Bit Clock frequency : 128K, 256K, 512K, 768K, 1M, 1.536M, 2M, 4M Hz. ƒ 3 frequency selection of the PCM Frame Sync (FS) : 8K, 16K and 48K Hz. ƒ 16 bit length selection of the PCM Frame Sync (FS) : 1~ 16 bits. ƒ 4 selection of PCM FS/DATA location + 1 half bit clock delay. ƒ PCM_FS & PCM_BCLK inverse mode for I2S interface. 12.2 Gain stage There are 6 programmable gain stages for transmit and receive path. These gain stages are implemented to provide a range of +24 dB to –31.5 dB with 0.5 dB per step. The Figure 5 is shown the location of these digital gain stages. There are 2 side tone paths to select from: One before AEC block, one after AEC block. Side tone gain stage is from -0.5dB to -31.5dB with 0.5dB step. Figure 5 PCM Interface, Gain Stage and Mixer Location 36 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 12.3 Mixer The mixer provides flexible connections among CODEC block, PCM interface and USB block. We will describe each connection case of mixer modes and how to configure them below. 12.4 Connection Case Example Figure 6 Mixer Connection Case Examples Case 0: Link CODEC and USB Case 1: Link CODEC and PCM 37 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Case 2: Link PCM and USB Case 3: Link All 12.5 38 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Mixer Case Examples with Register Setting Figure 7 Mixer Examples with Registers Setting Case 0: Default Register Setting: 0x1460 = 0x80 (Enable Gain Stage, Link CODEC_USB) 0x1470 = 0x00 (Disable PCM) Case 1: Record Conversation Register Setting: 0x1460 = 0x83 (Enable Gain Stage, Link All) 0x1470 = 0x80 (Enable PCM) 0x1474 = 0x02 (Mute PCM_RX) 39 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Case 2: Record Greeting Register Setting: 0x1460 = 0x80 (Enable Gain Stage, Link CODEC_USB) 0x1470 = 0x80 (Enable PCM) 0x1474 = 0x02 (Mute PCM_RX) Case 3: Record Message Register Setting: 0x1460 = 0xF0 (Enable Gain Stage, Link CODEC_USB, Record_USB) 0x1470 = 0x80 (Enable PCM) 0x1474 = 0x02 (Mute PCM_RX) 40 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Case 4: Play conversation 1 Register Setting: 0x1460 = 0x83 (Enable Gain Stage, Link All) 0x1470 = 0x80 (Enable PCM) 0x1474 = 0x04 (Mute PCM_TX) Case 5: Play Conversation 2 Register Setting: 0x1460 = 0x83 0x1470 = 0x80 0x1474 = 0x04 0x1464 = 0x40 0x1467 = 0x40 (Enable Gain Stage, Link All) (Enable PCM) (Mute PCM_TX) (Mute CODEC A/D IN) (Mute USB ISO OUT) 41 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION Case 6: Pro-X FXS Register Setting: 0x1460 = 0x81 (Enable Gain Stage, Link PCM_USB) 0x1470 = 0x80 (Enable PCM) 0x1465 = 0x40 (Mute CODEC D/A OUT) 12.6 I2S Register Setting Example The following example will generate I2S interface format from the W681308 PCM interface. I2S for 48KHz Sampling Rate(SR) with 16bits LPCM : 0x1470 = 85 101 = BCLK Rate Select. SR x 32 bits = 48K x 32 = 1.536MHz ( L, 0x1470 [2:0] R channels are 16 bits format) 00 = FST Location, Frame Sync is occurred before the MSB of the 0x1470 [4:3] PCM data. 1 = Enable PCM Interface 0x1470 [7] F0 = For long frame 0x1472 40 = PCM bit clock inverse enable 0x1474 42 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 13. 13.1 Audio Codec Interface Overview The audio CODEC interface allows the USB Audio Controller Device to be connected to one or more of the following: ƒ ƒ ƒ ƒ 16 bit internal linear PCM CODEC and Echo Cancellation block. 8/16/48 KHz CODEC sampling rate An I2S interface to and from the on chip linear CODEC. A PCM interface to connect to a external Nuvoton ProX SLIC/CODEC The audio data is flowing between USB interface and CODEC through 2 segmented FIFOs that allow MCU processing of audio data. 13.2 Audio CODEC Signal Path Figure 8 W681308 CODEC Signal Path Control Transmit Path Operation The microphone is biased through pins MCP by an internal programmable voltage reference and programmable resistor. The microphone ac signal is gained up by the input amplifier and filtered to prevent aliasing at the input of the sigma delta ADC. The sigma delta ADC converts the signal in a 2 bit digital representation, which is decimated and low pass filtered to the base band sampling rate of 8kHz to 48kHz. A high pass filter can be enabled in the transmit path. 43 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION The signal from the digital receive input is filtered through the acoustic echo cancellation filter and subtracted from the high pass filter output. The acoustic echo cancellation is only active in speaker phone operation with 8 kHz sampling. The result is then passed to the AGC with programmable time, release time and enable signal. The output of the AGC can be passed either to the PCM interface, the USB/MCU or both (recording a conversation). Receive Path Operation The PCM input can be obtained through a multiplexer from the PCM interface or the USB FIFO/MCU. The digital signal can then be gained or attenuated through a programmable digital gain stage. Then, the side tone from the transmit side is added through a programmable side tone gain stage. The side tone is disabled when the speakerphone is active. The digital signal is then passed through a high pass filter with programmable enable. The output of the high pass filter goes through the interpolation smoothing filter, which produces a 4 bit binary to 15 bit thermometer digital representation for the sigma delta DAC. The output of the DAC goes through an analog smoothing filter. The output of the smoothing filter can be hooked up to the speaker phone speaker driver, the earphone speaker driver or both. A programmable attenuation switch is used to switch between the earphone driver and the speaker phone driver. At power up of the analog section, the slow ramp on pin VREF1 is used to control the ramp up of the speaker and earphone driver in order to avoid ‘POP’ sounds. During operation, the user should lower the volume of the speaker using the software volume control settings, before switching the speaker and earphone driver in order to reduce the ‘POP’ sounds.; Alternatively, a buzzer can be used on the speakerphone driver outputs, using a 200Hz- 32 kHz PWM signal. However, the speakerphone can not be used in that case. Digital CODEC The digital CODEC filter chain is so designed that it can handle 48K, 16K and 8K rate through its rate change filters. 13.3 Microphone Interface and Auxiliary Interface W681308 integrates a fully programmable microphone interface. No external components other than the microphone are required to operate the circuit. The microphone interface can operate in three modes: ƒ ƒ ƒ Voltage gain mode Current gain mode Auxiliary input mode For the Current gain mode an internal or external resistor can be selected to determine the gain. The Auxiliary input mode should be used with external resistors. However, an internal gain resistor can be selected. The interface modes above can be selected with register MIC_MODE [2:0] at address 0x1489. ƒ Voltage Gain Mode The basic operation is shown below in Figure 9. The microphone is connected to the pins MCP and RGND. It is important that the negative terminal of the microphone is routed separately to the RGND pin for ‘pseudo differential’ operation, reducing the background noise amplified by the microphone amplifier. This can be enforced in the PCB layout by placing a 0 Ohm resistor or a ferrite bead. The pin MCO is connected to the output of the microphone amplifier and can be used for monitoring the AC level. The voltage gain is set by register MIC_GAIN[7:4] at address 0x1489. This register provides a gain range from 14dB to 38dB. The gain is set by a ratio of internal resistors, providing accurate gain control. The pin MCP also supplies the bias reference for the microphone. The bias consists of a programmable resistor and a programmable voltage reference. The programmable resistor is set by register MIC_RES[7:4] at address 0x1488 and can be set to open and 670 Ohm to 10kOhm. The programmable voltage reference is set by register MIC_BIAS[2:0] at address 0x1488 and can be set from 1.22Volt to 2.74Volt. 44 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION MIC_BIAS[2:0] 0x1488 W681308 Voltage Gain Mode MIC_RES[7:4] 0x1488 0x1489 MIC_MODE=‘000’ MCP + Electret Microphone To ADC MIC_GAIN[7:4] 0x1489 RINT1 RINT2 MIC_GAIN[7:4] 0x1489 MCO 250 Ohm VADC VMCP RGND Rm 0 Ohm Or ferrite RINT 1 RINT 2 = 1+ '000' Figure 9 Microphone Voltage Gain Mode ƒ Current Gain Mode For higher gain configurations, the current gain mode can be used as in Figure 10 below. MIC_BIAS[2:0] 0x1488 Current Gain Mode MIC_RES[7:4] 0x1488 0x1489 MIC_MODE=‘010’or ‘011’ MCP Electret Microphone IS W681308 + IS To ADC - REXT MIC_GAIN[7:4] 0x1489 RINT Rinternal 0x1489 MCO 250 Ohm RGND Rm 0 Ohm Or ferrite VADC IS '011' VADC IS '010 ' = −(REXT + 250) = − RINT REXT > 20 kΩ Figure 10 Microphone Current Gain Mode 45 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION The current gain mode uses the same programmable microphone bias voltage and resistor as the voltage gain mode. The gain is set by either the internal gain resistor or an external resistor, depending on the MIC_MODE setting. Since the current gain mode is using a single resistor, the gain accuracy is limited. However, large gain can be achieved. Note that a 250Ohm ESD protection resistor is connected to the MCO pin. This resistor should be considered when calculating the gain. ƒ Auxiliary Input Mode For non-microphone applications one or more Auxiliary inputs can be connected to the MCP pin as shown in Figure 11 below. The MIC_RES register should be set to open in order to disconnect the microphone bias. For the gain setting it is advised to use external gain resistors only for optimal matching and accuracy. The 250Ohm ESD protection resistor should be considered again when calculating the gain. Note that for this mode the RGND pin is tied to the external supply ground. A clean ground reference should be used for this. MIC_BIAS[2:0] 0x1488 Auxiliary Input Mode MIC_RES[7:4] 0x1488 =‘0100’ Cs1 Rs1 W681308 0x1489 MIC_MODE[2:0]=‘101’ MCP + To ADC Csn + Vsn - MIC_GAIN[7:4] 0x1489 Rsn Rinternal 0x1489 Rext + Vs - MCO VADC REXT + 250 =− VS '101' RS 250 Ohm REXT > 20 kΩ RGND CS = 1 40 ⋅ π⋅ RS Figure 11 Microphone Auxiliary Input Mode 46 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 14. 14.1 Serial Peripheral Interface Overview W681308 built in a serial peripheral interface (SPI) port which is a 4-pin (SCLK, CS, SDI, SDO) SPI Interface. This SPI interface makes W681308 an easy to control 4-pin SPI device including SPI data flash, SPI LCM, Nuvoton Pro-X SLIC CODEC etc. This device has various clock speed and data format by setting relative control registers. The SPI module can be operated at clock rates of up to MCU clock rate. Figure 12 SPI Block Diagram 14.2 Data and Signal Format of SPI There are 5 control bits (CSN_ADD, CSN_MORE, CK_MORE, CP and CI) to decide the SPI control signal format. Register 0x14AB has detail description of the control bits. The packet and page data format is separated to 2 fields: Command field and the Data field. Command field (0 ~ 5 bytes) consists of control instruction/code and access address (TX only). Data field (0 ~ 256 bytes) consists of write and read data of serial data flash (TX/RX). All Command and Data bytes are send MSB first. Command and Data field length can be programmed in CMD_LEN (0x14A1[2:0]) and DATA_LEN (0x14A2[7:0]) register fields. It can be bypassed to write control bit CMD_BYPASS or disable the DATA_ENB. The max command field length is 5 bytes. The max data field length is 256 bytes in unidirectional mode, and 128 bytes in bidirectional mode. Thirteen examples are provided for reference. 14.3 FSM of SPI There are 3 states in the SPI Finite State Machine (FSM) module. The initial state is IDLE when power on. ƒ IDLE After enable the SPI function (write 0x14A0[7] =1), the FSM start to wait for MCU control (write 0x14A1) to change to next state. If the CMD BYPASS flag (0x14A1[5]) is true, the FSM will change to DATA state, then force control logic to shift in/out the data bytes sequentially. If the CMD BYPASS flag ( 0x14A1[5]) is false, the FSM will change to the CMD state, then force control logic to shift out the command bytes sequentially to external SPI device. ƒ Command (CMD) 47 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION After finished shift out the command bytes, the FSM will change to DATA state if the Data_enb ( 0x14A1[4]) is true, or run back to IDLE state if the Data_enb is false. ƒ Data When FSM goes into Data state, the control logic start to shift out write data to external SPI device if SPI_RD (0x14A1[3]) is false, or shift in read data from external SPI device if SPI_RD (0x14A1[3]) is true. In bidirection mode, the control logic will ignore SPI_RD (0x14A1[3]) and start to shift in/out the read/write data from/to external SPI device. After finishing shift out/in the data bytes, the FSM will go back to IDLE state and wait for next transition. IDLE DATA 14.4 CMD FIFO and RAM of SPI The SPI module takes up to 5 bytes Register to write the control command and takes the 256x8 bytes RAM to do the Read/Write access FIFO. In Bidirectional mode, the 256x8 bytes RAM will separate into two 128x8 bytes sections. One (ADDR: 0x00~7F) for keep the transmit data, and the other one (ADDR: 0x80~0xFF) for store the receive data. Once the Bidirectional mode is enabled, the SPI module will automatic put receive data from ADDR: 0x80 instead of the ADDR: 0x00 as in the unidirectional mode. It supports two memory access methods: ƒ FIFO like method MCU always read/write the same register (0x14AC) with hardware control the memory read/write address, and increase the read/write pointer automatically after each read/write. The current write and read pointer can be read at register 0x14AE and 0x14AF. ƒ Direct access method MCU can read/write any byte of the memory after setting the read (0x14AF)/write (0x14AE) pointer first. 14.5 Interrupt Sources The SPI module supports two types of interrupt sources: ƒ TX/RX finish interrupt When TX/RX byte counts (0x14AD) = DATA_LEN. ƒ Middle flag interrupt When TX/RX byte counts (0x14AD) = 16 * INTR_CNT (0x14A3[7:4]). For any other options, refer to the description of the specific registers in W681308 Design Guide. 48 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 15. 15.1 Nuvoton 2-Wire Serial Bus Overview Nuvoton 2-wire serial bus (W2S) is a simple bi-directional 2-wire bus for efficient inter-IC control. This design is for W2S master use only, and governed by the MCU. The W2S is used to both read/write EEPROM and to control various device included I2C interface. The W2S controller is equipped with 35 bytes FIFO performing formatting and de-formatting. The MCU can simply fill up the FIFO contents which consists of target device ID, high/low address (depend on the device format); for reading, just set read enable, for writing, keep writing data to FIFO then set write enable to launch transmission. The W2S controller supports 3 types of page writing, 8, 16 and 32 bytes. The W2S controller is designed to support maximum of 32 bytes per page. The FIFO depth can support 3 header bytes (one device ID, two address) and 32 bytes data. It has various bus speed configurations to support wide range of EEPROM bus speed. 16. 16.1 ICE Function By JTAG STD. IEEE 1149.1 Overview The W681308 MCU on-chip debugger function follows the JTAG standard. It provides 8 sets of breakpoints. There is no watchpoint. There are five JTAG-style scan chains within the 8051 and peripheral logic, which enable embedded ICE logic. The 5 JTAG interface pins TCK (JTAG test clock input), TMS (JTAG test mode select), TDI (JTAG test data input), TDO (JTAG test data output) and nTRST (JTAG TAG controller reset) are needed to enable the operation. The JTAG interface pins are multiplexed with other function pins. 16.2 Scan Chains and JTAG Interface There are five JTAG-style scan chains within the TB51 core and peripheral logic interface. These enable debugging operation and configuration of Embedded-ICE logic. An external pull low signal on nTRST will reset TAP controller or MCU power-on reset will trigger TAP controller reset once. 16.3 Pin Description Table 11 JTAG Pin Description Pin Name Type Function TCK IN JTAG Test clock with internal pull-up. TMS IN JTAG Test-Mode Select with internal pull-up. TDI IN JTAG Test Data Input with internal pull-up. TDI is latched on a rising edge of TCK. TDO OUT JTAG Test Data Output. Data is shifted out on TDO at the rising edge of TCK. TDO output is a tri-state driver with internal weakly pull-low resister. nTRST IN JTAG TAP controller reset input with internal pull-up. 49 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 16.4 Reset Behavior TB51 will start to execute internal code after power on reset. If host JTAG ICE connects with TB51, the host ICE can send command to control the TB51. Reset type Power On Reset Reset by RESET pin or WDT RESET (including set Reset out and Reset in SC0) nTRST Low Functional description 1. Reset MCU 2. Reset JTAG. TAP controller will stay in Test-Logic Reset State. 3. Execution starts from address 0000 after reset. 1. Reset Chip. 2. Do not reset JTAG. TAP controller stays in the original state. 3. If the original TAP controller state is in run mode, chip reset 4. If the original TAP controller state is in Halt mode. No any state changed 1. No effect on MCU. 2. Reset JTAG. TAP controller will stay in Test-Logic Reset state. 17. Ring Tone (PWM) Generator 17.1 Overview The ring tone or PWM can generate dual frequency tones through on chip speaker driver. There are two tone signals can be mixed to the speakerphone driver output. This subsection describes the Ring Tone Generator with the PWM (Pulse Width Modulation) format. Ring tone generator (PWM) specification: ƒ Tone Channel Number = 2 ƒ Tone Volume Step = 32 ƒ Tone Frequency Range = 91Hz~23KHz Frequency = 12 M Hz 16 × N × 32 N = 1 ~ 256 The tone frequency/volume control signal path is shown as Figure 13. Figure 13 Ring Tone Generator Block 50 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 18. FULL/HALF DUPLEX ACOUSTIC ECHO CANCELLATION(AEC) The AEC unit removes the echo signal caused by the speaker and room reflections. 18.1 Function Control Registers Figure 14 illustrates the block diagram of the Full/Half Acoustics Echo Cancellation Figure 14 Signal flow through Acoustic Echo Cancellation in the speech processor 51 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 19. USB Device Controller And Transceiver 19.1 Overview The W681308 includes a full function USB 2.0 Full Speed controller. It supports USB 2.0 FS standard specification and standard USB audio device class and HID device class in Microsoft Windows environment. The USB core embeds one programmable 512x8 Bit RAM to store descriptor. In the setting, the USB core includes five interfaces and 6 endpoints to handle above applications. 19.2 Functional Description The USB function block diagram is shown below: uC ADDR_SEL Control Endpoint #0 Descriptor RAM 512x8 REG CTRL To USB Transceiver SIE Bulk-IN Endpoint #3 TPRAM 256x8 CTL_IN/INT_IN/BULK_IN Bulk-OUT Endpoint #4 TPRAM 256x8 CTL_OUT/BULK_OUT UCOM Interrupt-IN Endpoint #5 BIST TPRAM 128x16 ISO-OUT Endpoint #2 TPRAM 128x16 PCM ISO-IN Endpoint #1 USB_TST ISO-SYNC Endpoint #6 Figure 15 USB Function Block Diagram The USB module supports all transfer types (Control, Bulk In, Bulk Out, Interrupt In, Isochronous In, Isochronous Out and ISO-SYNC) in USB 1.1 spec and W681308 USB embeds 6 Endpoints include Control Endpoint 0. The default descriptors are stored in the programmable 512x8 Bit RAM. The SIE module is for handle USB series-interface-engine functions. UCOM 52 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION module is a bridge to communicate SIE and all transfer type modules. Register Control module is for handle MCU read/write and data signals of W681308 USB registers. Gain Stage residing out off USB module is required for adjusts gain of PCM data in audio volume control application. USB test module connects many internal signals to test pins for help monitor them from outside. The features of USB interface are: ƒ USB Specification version 2.0 Full Speed(FS) 12Mbps compliant Audio Class Interface and Command support (Volume Control, Mute Control, Sampling Rate selection) ƒ ƒ HID Class Interface and Command support (Set/Get Report) ƒ Programmable pull-up resistor to connect/disconnect 1.5Kohm on D+ bus ƒ Support five interfaces and 6 endpoints: Control, Isochronous IN/OUT, Bulk IN/OUT, and Interrupt IN. ƒ Ping-Pong FIFO control for Bulk IN/Bulk OUT transfer to increase data transmission efficiency. ƒ Provide three bytes Isochronous SYNC to synchronize Isochronous OUT with PC audio data stream and improve voice quality. 19.2.1 Endpoints The definitions of embedded endpoints are: Address Type Direction maximum Packet Size (Bytes) Memory Type 0 Control IN/OUT 64 64x8 TPRAM 1 ISO IN 256 128x16 TPRAM 2 ISO OUT 256 128x16 TPRAM 3 Bulk IN 128 128 x 8 TPRAM 4 Bulk OUT 128 128 x 8 TPRAM 5 Interrupt IN 64 64x8 TPRAM 6* ISO IN 3 Registers Table 12 W681308 USB Endpoint Definitions NOTE: TPRAM - Dual Ports RAM 53 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 19.2.2 Descriptor RAM The referenced descriptors are stored in the 512x8 Bit RAM, programmed by MCU. The address mapping and bank definition of this RAM are shown in 18-2. Address Function Size 0x2000~0x2011 Device Descriptor 18 Bytes 0x2012~0x217F Configuration Descriptor Interface Descriptor Endpoint Descriptor Audio Class Descriptor HID Descriptor 366 Bytes 0x2140~0x214F String Descriptor Index 0 16 Bytes 0x2150~0x215F String Descriptor Index 1 16 Bytes 0x2160~0x216F String Descriptor Index 2 16 Bytes 0x2170~0x217F String Descriptor Index 3 16 Bytes 0x2180~0x21FF Report Descriptor 128 Bytes Table 13 USB Descriptor RAM Definitions 54 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 20. Electrical Characteristics 20.1 Absolute Maximum Ratings CONDITION VALUE UNIT 150 0 C -65 to +150 0 C Lead temperature (soldering – 10 seconds) 300 0 C LQFP-48 Thermal Resistance, typical 76 C/W (VSS - 0.3 ) to (VDD + 0.3 ) V Input current applied to any digital input pin +/- 10 mA ESD (Human Body Model) 2000 V VDD - VSS -0.5 to +3.63 V VDDL - VSS -0.5 to + 1.98 V 0.5 Watt Junction temperature Storage temperature range Voltage applied to any pin Power Dissipation NOTE: Stresses above the value listed may cause permanent damage to the device. Exposure to absolute maximum ratings may affect device reliability. Functional operation is not implied at these conditions. 20.2 Recommended Operating Conditions CONDITION VALUE Commercial operating temperature Industrial operating temperature UNIT 0 to +70 0 C -40 to +85 0 C Supply voltage (VDD) using external regulator +3.13 to +3.47 V Supply voltage (VDDUSB) using internal regulator and external transistors +4.4 to + 5.25 V 0 V Ground voltage (VSS) 55 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 20.3 DC Characteristics SYMBOL PARAMETER MIN TYP MAX UNIT VIL Input Low Voltage -0.3 0.8 V VIH Input High Voltage 2 3.6 V VT Threshold point 1.32 1.41 1.49 V VT+ Schmitt trigger. Low to High threshold point 1.49 1.54 1.58 V VT- Schmitt trigger. high to low threshold point 1.24 1.29 1.34 V Input leakage current @VI=3.3V or 0V ± 10 µA IOZ Tri-state output leakage current @VO=3.3V or 0V ± 10 µA RPU Pull-up resistor 38 54 83 K RPD Pull-down resistor 25 49 110 K VOL Output low voltage @IOL (min) 0.4 V VOH Output high voltage @IOH (min) 2.4 Low level output current @VOL=0.4V 2 mA 2.2 3.7 5.3 mA Low level output current @VOL=0.4V 16 mA 19.6 29.8 39.0 mA High level output current @VOH=2.4V 2 mA 3.2 6.4 10.6 mA High level output current @VOH=2.4V 16 mA 23.1 46.8 77.8 mA II IOL IOH 20.4 Analog Transmission Characteristics AVDD=3.13V – 3.47V; VSS=0V; TA=-40°C to +85°C; All ADC tests using Auxiliary input mode @ 0dB gain PARAMETER SYMBOL CONDITION Full Scale Level TXmaX ADC (single ended) DAC (differential) Absolute Gain GABS Absolute Gain variation with Temperature Absolute Gain variation with Supply Voltage TYP TRANSMIT (ADC) RECEIVE (DAC) UNIT MIN MAX MIN MAX 1.218 2.436 ----- ----- ----- ----- VPK VPK -3dBFS @ 1020 Hz, AVDD =3.3V; TA=+25°C; 0 -0.40 +0.40 -0.40 +0.40 dB GABST TA=0°C to TA=+70°C TA=-40°C to TA=+85°C -3dBFS 0 -0.10 -0.20 +0.10 +0.20 -0.10 -0.20 +0.10 +0.20 dB GABSS AVDD=3.13V – 3.47V; 3dBFS @ 1020 Hz; TA=+25°C 0 -0.10 +0.10 -0.10 +0.10 dB 56 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 20.5 Analog Distortion and Noise Parameters All ADC tests using Auxiliary input mode @ 0dB gain 20.5.1 8kHz sampling AVDD=3.13V – 3.47V; VSS=0V; TA=-40°C to +85°C; 8kHz sampling PARAMETER SYMBOL TRANSMIT (ADC) CONDITION RECEIVE (DAC) MIN TYP MAX MIN TYP MAX UNIT Signal to Noise Ratio SNR Idle channel A-weighted 80 94 -- 80 88 -- dB Total Harmonic Distortion THD3 -3dBFS @ 1020 Hz, 32Ohm speaker load -- -77 -67 -- -77 -67 dB Total Harmonic Distortion THD8 -3dBFS @ 1020 Hz, 8Ohm speaker load -- -77 -67 -- -70 -60 dB Total Harmonic Distortion THD4 -6dBFS @ 1020 Hz, 4Ohm speaker load -- -79 -69 -- -65 -55 dB Frequency Response Power Supply Rejection 20.5.2 Frl -3dB Low pass cut-off PSRRA VDDUSB; 35mVrms DC to 3.4 kHz A-weighted 3.36 70 88 3.36 --- 70 kHz 85 --- dB 16kHz sampling AVDD=3.13V – 3.47V; VSS=0V; TA=-40°C to +85°C; 16kHz sampling PARAMETER SYMBOL TRANSMIT (ADC) CONDITION RECEIVE (DAC) MIN TYP MAX MIN TYP MAX UNIT Signal to Noise Ratio SNR Idle channel A-weighted 80 93 -- 80 86 -- dB Total Harmonic Distortion THD3 -3dBFS @ 1020 Hz, 32Ohm speaker load -- -76 -66 -- -78 -68 dB Total Harmonic Distortion THD8 -3dBFS @ 1020 Hz, 8Ohm speaker load -- -76 -66 -- -70 -60 dB Total Harmonic Distortion THD4 -6dBFS @ 1020 Hz, 4Ohm speaker load -- -79 -69 -- -65 -55 dB Frequency Response Power Supply Rejection Frl PSRRA -3dB Low pass cut-off 6.73 VDDUSB; 35mVrms DC to 6.8 kHz A-weighted 70 57 89 6.73 --- 70 85 Rev1.2 kHz --- dB W681308 XXXX PRODUCT DESCRIPTION 48kHz sampling 20.5.3 AVDD=3.13V – 3.47V; VSS=0V; TA=-40°C to +85°C; 48kHz sampling PARAMETER SYMBOL TRANSMIT (ADC) CONDITION RECEIVE (DAC) MIN TYP MAX MIN TYP MAX UNIT Signal to Noise Ratio SNR Idle channel A-weighted 80 92 -- 80 85 -- dB Total Harmonic Distortion THD3 -3dBFS @ 1020 Hz, 32Ohm speaker load -- -77 -67 -- -76 -66 dB Total Harmonic Distortion THD8 -3dBFS @ 1020 Hz, 8Ohm speaker load -- -77 -67 -- -69 -59 dB Total Harmonic Distortion THD4 -6dBFS @ 1020 Hz, 4Ohm speaker load -- -78 -68 -- -65 -55 dB Frequency Response Power Supply Rejection 20.6 Frl -3dB Low pass cut-off 20.2 VDDUSB; 35mVrms DC to 6.8 kHz A-weighted PSRRA 70 88 20.2 --- 66 76 kHz --- dB Programmable Output Linear Regulator TA=-40°C to +85°C; Using discrete components per application diagram; MIN (2) TYP (1) MAX (2) UNIT Low Power Mode (100mA) High Power Mode (500mA) 4.4 4.75 5 5 5.25 5.25 V V VDD No Load, Normal Operation 3.13 3.3 3.47 V Total Suspend Mode Current ISP Suspend Mode Including USB pull-up and discrete regulator -- 463 -- uA Operating Supply Current IVDD No Load, Normal Operation -- 38 -- mA PARAMETER SYMBOL Recommended USB Supply Voltage VDDUSB Regulated Supply Voltage CONDITION Voltage Drop VDROP0.5 VDDUSB =5V, load=500mA -- 0.006 -- V Voltage Drop VDROP1 VDDUSB =5V, load=1A -- 0.06 -- V NOTE 1: Typical values: TA = 25°C NOTE 2: All min/max limits are guaranteed by Nuvoton via electrical testing or characterization. Not all specifications are 100 percent tested 58 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 20.7 USB PHY Electronic Characteristics ( 25°C, DVDD= 3.3V, VDDL =1.8V) PARAMETER SYMBOL DC Supply Voltage for USB Output Stage MIN. TYP. MAX. UNIT VDD_USB 3.1 3.3 3.5 V USB_DP USB_DN 0 3.5 V Input High VIH 2.0 Input Low VIL Differential Input Sensitivity VDI 0.2 Differential Common-mode Range VCM 0.8 Single-end Receiver threshold VSE 0.8 Output Low VOL Output High VOH 2.8 Output signal cross Voltage VCRV 1.3 Pull-up Resistor RUP 1.3 Driver Output Resistance ZDRV 8 Transceiver Capacitance CIN Driver Rise Time TR Driver Fall Time Input Voltage Range for USB_DP/DN Rise and Fall Time matching VDD_USB Supply Current * (exclude internal pull high resistor) CONDITION V 0.8 V V --- 2.5 V 2.0 V 0.3 V V 1.61 2.0 V 1.9 KΩ 19 Ω 20 pF 4 8 20 ns TF CL = 50pF Rs=25 Ohms CEdge=30pF 4 8 20 ns TLRLF TLRLF = TLR/ TLF 90 100 110 % Standby 100 nA Input Mode 2 mA Output Mode 2 mA IUSB 59 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 20.8 USB PLL Electronic Characteristics PARAMETER SYMBOL CONDITIONS MIN. TYP. MAX. 3.13 3.3 3.47 UNIT Operation Voltage VPLL Input Clock Frequency Range FIN 12 MHz PLL Output Frequency FOUT 48 MHz VCO Frequency FVCO Ouput Duty Cycle V --- 48 --- MHz 46 56 66 % PLL Short-Term Peak To Peak Output Jitter TJITTER 7 ps PLL Lock In Time TREADY 25 us 60 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 21. Typical Application Reference Circuit S1 1 S2 2 S3 3 S4 Mode S5 HangUp S6 4 S7 5 S8 6 S9 Up S10 Down S11 7 S12 8 S13 9 S14 Skype S15 Dial S16 * S17 0 S18 # S19 Left S20 Right USB_5V S22 User S23 Melody S24 Up1 S25 Down1 R1 R2 R3 1M 100K 60K 1uF/10V 2 S21 + C1 PUSHBUTTON Mute Q1 MMBT3906 1 DGND 3 PUSHBUTTON R4 Q2 PZT2222A VDD_3.3V 300K Q3 C2 10nF R5 100K MMBT3904 C3 R6 DGND UARTT 220uF/10V REGL 6 DGND 10nF 7 DN DP C9 USB Connector 100nF 37 19 20 21 22 23 D2 BCLK PCMR PCMT GPIO1 GPIO2 36 VREF1 35 VREF2 34 MCP 33 MCO 1 32 RGND 31 C5 100nF AGND AGND 1 TP1 2 AGND 30 SPP 29 EARP REC1 28 VDD_3.3V 27 EARN 26 SPN 25 MIC1 C6 100nF MICROPHONE REGL KY4 38 39 KY3 KY2 40 41 KY1 KY0 42 18 LED R12 FS SPK1 C10 100nF AGND VDD_3.3V C16 100 LED 100nF SCLK SDO /CSL RS VDD GND SDI PCMT VDD_3.3V KX4 17 100 30pF DGND DGND 43 D1 /CSL 30pF DGND DGND R11 PCMR DGND 44 AGND 16 51pF VDD_3.3V KX3 SPN GPIO0 SDO C15 KX2 GPIO3 15 C14 45 EARN 14 51pF C13 46 47 AVDD DGND 13 C12 LCD Module (Serial Interface) DGND 12 DP SDI 4 DJP1 The shielding of the USB connector can't connect to any GND. 11 GPIO0 EARP BCLK 25 GPIO3 DN FS R10 DGND SPP U1 /CS 25 3 Shielding 10nF R9 RESET DGND 2 RGND AGND DVDD SCLK D+ GND C11 1 W681308_LQFP VDDL /CS D- 9 10 DGND MCO /CS VCC 8 XTALO XTALI AGND SPEAKER C8 33pF VDD_3.3V MCP VPP 5 DGND GPIO2 XTALI AGND 24 4 VREF2 PCMT DGND XTALO VREF1 UARTR GPIO1 C7 UARTT PCMR 3 BCLK 2 FS 1 UARTR DGND 12M USB_5V UARTT /CSL 1M SDO R8 SDI DY1 SCLK 270 33pF KX1 JTAG R7 KX0 48 AGND C4 DGND RECEIVER KY4 KY3 KY2 KY1 KY0 KX3 KX2 KX4 UARTR KX1 KX0 2K AGND PCM interface is for External Audio Device or USB ATA wtih Pro-X AGND VDD_3.3V C17 100nF DGND Figure 16 W681308 Reference Design Application Circuit 21.1 USB VoIP speaker phone application The application diagram illustrated that the W681308 is a SOC with very low BOM system design. Externally it supports a variety interfaces such as keypad, LCM, SLIC, SPI flash/EEPROM, Microphone and speakers directly. External 12M Crystal as well as a 5V to 3.3V linear regulator is required. Ring tone download and playback is through the same Audio DAC path with a switch for ringing and speech. 61 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 22. Package Dimensions W681308DG is in 48 pin Low-profile Quad Flat Package (LQFP). Symbol A A1 A2 b c D E e HD HE L L1 Y θ min 0.002 0.053 0.005 0.004 0.272 0.272 0.014 0.350 0.350 0.018 0’ In inch nom -0.063 0.004 0.055 0.008 0.005 0.276 0.276 0.020 0.354 0.354 0.024 - max 0.006 0.057 0.010 0.008 0.280 0.280 0.025 0.358 0.358 0.030 0.039 0.004 7’ 62 min 0.05 1.35 0.15 0.10 6.90 6.90 0.35 8.90 8.90 0.45 0’ In mm nom 1.60 0.10 1.40 0.20 0.15 7.00 7.00 0.50 9.00 9.00 0.60 - max 0.15 1.45 0.20 0.20 7.10 7.10 0.65 9.10 9.10 0.75 1.00 0.10 7’ Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 23. Ordering Information Nuvoton Part Number Description W681308_ _ Package Material: G = Pb-free Package Product Family Package Type: D = 48-Lead Quad Flat Pack Package (LQFP) When ordering W681308series devices, please refer to the following part numbers: Part Number Temp Range (oC) Package Package Material W681308DG -40 to 85 48-LQFP Pb-Free 63 Rev1.2 W681308 XXXX PRODUCT DESCRIPTION 24. Revision History VERSION DATE PAGE DESCRIPTION V0 9 July, 2007 V1.0 August, 2007 Update Electrical Characteristics V1.1 March, 2008 Update Speaker / Earphone attenuation switch V1.2 March 2009 Format of the datasheet changed Logo update Preliminary Version Important Notice Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. 64 Rev1.2
W681308DG 价格&库存
很抱歉,暂时无法提供与“W681308DG”相匹配的价格&库存,您可以联系我们找货
