ISD1964SYI01
ISD1964SYI01
    NUVOTON(新唐)
    SOIC28
    IC VOICE REC/PLAY 128SEC 28-SOIC
ISD1964SYI01 数据手册
ISD1900 ISD ChipCorder® ISD1900 Series Datasheet The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. Nuvoton is providing this document only for reference purposes of Audio Product Line based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Mar 31, 2020 Page 1 of 32 Rev 1.0 ISD1900 TABLE OF CONTENTS 1. GENERAL DESCRIPTION .................................................................................... 4 2. FEATURES............................................................................................................ 4 2.1. Address Mode .............................................................................................. 5 2.2. Direct Mode .................................................................................................. 5 3. BLOCK DIAGRAM ................................................................................................. 6 4. PIN CONFIGURATION .......................................................................................... 7 5. PIN DESCRIPTION ............................................................................................... 9 6. FUNCTIONAL DESCRIPTION ............................................................................ 12 6.1. Address Mode ............................................................................................ 12 6.1.1 Record (REC ¯¯¯¯) Operation......................................................................... 14 6.1.2 Edge-triggered Playback (PlayE ¯¯¯¯¯) Operation ........................................... 15 6.1.3 Level-triggered Playback (¯¯¯¯¯) PlayL Operation ........................................... 16 6.1.4 Playback (Supersedes Record) Operation .............................................. 17 6.1.5 XCLK Feature ......................................................................................... 18 6.2. Direct Mode ................................................................................................ 18 6.3. Other Operations ........................................................................................ 22 6.3.1 Rosc Operation ....................................................................................... 22 6.3.2 LED Operation ........................................................................................ 22 6.3.3 Feed-Through mode Operation ............................................................... 22 6.3.4 Power-On Playback Operation ................................................................ 22 6.3.5 Automatic Single Message Playback ...................................................... 23 6.3.6 Power is interrupted Abruptly .................................................................. 23 7. ABSOLUTE MAXIMUM RATINGS [1] ................................................................... 24 7.1. Operating Conditions ................................................................................. 24 8. ELECTRICAL CHARACTERISTICS .................................................................... 25 8.1. DC Parameters .......................................................................................... 25 8.2. AC Parameters........................................................................................... 26 9. TYPICAL APPLICATION CIRCUIT...................................................................... 27 10. PACKAGING ....................................................................................................... 29 10.1. 28-Lead 300-Mil Plastic Small Outline Integrated Circuit (SOIC) ............... 29 11. ORDERING INFORMATION ............................................................................... 30 12. VERSION HISTORY............................................................................................ 31 Mar 31, 2020 Page 2 of 32 Rev 1.0 ISD1900 Important Notice ........................................................................................................ 32 Mar 31, 2020 Page 3 of 32 Rev 1.0 ISD1900 1. GENERAL DESCRIPTION Nuvoton’s ISD1900 ChipCorder® Series is a single-chip multiple-message record/playback device with dual operating modes and wide operating voltage ranging from 2.4V to 5.5V. The sampling frequency can be selected from 4 to 12 kHz via an external resistor, which also determines the duration. The device is designed for mostly standalone applications, and of course, it can be manipulated by a microcontroller, if necessary. The two operating modes are Address Mode and Direct Mode. While in Address Mode, both record and playback operations are manipulated according to the start address and end address specified through the start address and end address pins. In Direct Mode, the device can configure the memory up to as many as eight similar duration messages, pending upon the fixed message configuration settings. With the record or playback feature being pre-selected, each message can be randomly accessed via its message control pin. The device has a selectable differential microphone input with AGC feature or singleended analog input, AnaIn, under feed-through mode. The audio output is either a differential Class-D PWM direct-drive or a single-ended voltage output (AUX out), depending on the derivative selected. 2. FEATURES The ISD1900 is a multiple messages record/playback device with two operational modes: Address Mode and Direct Mode. • Supply voltage: 2.4V to 5.5V. • External resistor, Rosc, selects sampling frequency and duration. Sampling 12 kHz 8 kHz 6.4 kHz 5.3 kHz 4 kHz Frequency Rosc 53.3 KΩ 80 KΩ 100 KΩ 120 KΩ 160 KΩ ISD1916 10.6 sec 16 sec 20 sec 24 sec 32 sec ISD1932 21.3 sec 32 sec 40 sec 48 sec 64 sec ISD1964 42.6 sec 64 sec 80 sec 96 sec 128 sec Mic+/Mic-: differential microphone inputs. AGC: automatic gain control for microphone preamp circuit. FT ¯¯: feed-through the AnaIn signal to the speaker outputs while AnaIn is converted from MIC+. When both FT ¯¯ and recording are active, device will record AnaIn signal into memory with AnaIn signal output to speaker simultaneously. SP+/SP-: Class-D PWM differential speaker drivers or single-ended voltage output, depending on the derivative selected. ¯¯¯¯: LED LED is on during recording. • • • • • • Mar 31, 2020 Page 4 of 32 Rev 1.0 ISD1900 • •   Automatically power down after each operation cycle. Playback takes precedence over the recording operation. Temperature option: -40°C to +85°C (Industrial) Packaging: available in SOIC only 2.1. ADDRESS MODE • While in Address Mode, flexible message duration is defined by start address and end address. • Utilize four start address pins (S0, S1, S2 & S3) and four end address pins (E0, E1, E2 & E3) to specify the message duration. • ¯¯¯¯: REC Level-hold or Edge-trigger (toggle on-off) recording from start to end addresses. • ¯¯¯¯¯: PlayE Edge-trigger playback from start to end address and stops at EOM marker, if EOM is prior to end address. Toggle on-off. • ¯¯¯¯¯: PlayL Level-hold playback from start to end address. Also, if constantly Low, device will loop playback from start to end address. 2.2. DIRECT MODE • While Direct Mode is active, utilizing the configuration pins, FMC1, FMC2 & FMC3, to define up to eight similar duration messages for random access. • The control pins are: M1 ¯¯ ~ M8 ¯¯ (message activation) and ¯¯/P R (record or playback selection). • The record or playback operation is pre-defined by the ¯¯/P R pin. • Each message can be randomly accessed via its message control pin (M1 ¯¯ ~ M8 ¯¯ ) and the desired operation is facilitated accordingly. Mar 31, 2020 Page 5 of 32 Rev 1.0 ISD1900 3. BLOCK DIAGRAM Figure 3-1 Block Diagram Mar 31, 2020 Page 6 of 32 Rev 1.0 ISD1900 4. PIN CONFIGURATION VSSD 1 28 VCCD S0 / M1 2 27 Addr / Drct S1 / M2 3 26 FT S2 / M3 4 25 XCLK / FMC3 S3 / M4 5 24 REC / R/P PlayL / FMC1 6 23 PlayE / FMC2 E0 / M5 7 22 LED VSSA 8 21 VCCA E1 / M6 9 20 Rosc E2 / M7 10 19 Mic-_NC E3 / M8 11 18 Mic+_AnaIn VSSP2 12 17 AGC SP- 13 16 VSSP1 VCCP 14 15 SP+ ISD1900 Figure 4-1 Pin Configuration VSSD 1 28 S0 2 27 VCCD Addr S1 3 26 FT S2 4 25 XCLK S3 5 24 REC PlayL 6 23 PlayE E0 7 22 LED VSSA 8 21 VCCA E1 9 20 Rosc E2 10 19 Mic-_NC E3 11 18 Mic+_AnaIn VSSP2 12 17 AGC SP- 13 16 VSSP1 VCCP 14 15 SP+ ISD1900 VCC Figure 4-2 Pin Configuration – Address Mode Mar 31, 2020 Page 7 of 32 Rev 1.0 ISD1900 VSSD 1 28 VCCD M1 2 27 Drct M2 3 26 FT M3 4 25 FMC3 M4 5 24 R/P FMC1 6 23 FMC2 M5 7 22 LED VSSA 8 21 VCCA M6 9 20 Rosc M7 10 19 Mic-_NC M8 11 18 Mic+_AnaIn VSSP2 12 17 AGC SP- 13 16 VSSP1 VCCP 14 15 SP+ ISD1900 Figure 4-3 Pin Configuration – Direct Mode Mar 31, 2020 Page 8 of 32 Rev 1.0 ISD1900 5. PIN DESCRIPTION PIN NAME VSSD S0/M1 ¯¯ PIN # 1 2 I/ O I I FUNCTION Digital Ground: Ground path for digital circuits. S0[1] : In Address Mode, Start Address Bit 0. M1 ¯¯ : When Direct Mode is active, low active operation on 1st Message. Internal pull-up & debounce existed. S1/M2 ¯¯ 3 I S1[1] : In Address Mode, Start Address Bit 1. M2 ¯¯ : When Direct Mode is active, low active operation on 2nd Message. Internal pull-up & debounce existed. S2/M3 ¯¯ 4 I S2[1] : In Address Mode, Start Address Bit 2. M3 ¯¯ : When Direct Mode is active, low active operation on 3rd Message. Internal pull-up & debounce existed. S3/M4 ¯¯ 5 I S3[1] : In Address Mode, Start Address Bit 3. M4 ¯¯ : When Direct Mode is active, low active operation on 4th Message. Internal pull-up & debounce existed. ¯¯¯¯¯ PlayL /FMC1 6 E0/M5 ¯¯ 7 VSSA E1/M6 ¯¯ I ¯¯¯¯¯: PlayL In Address Mode, low active input, Level-hold playback start to end addresses, debounce & internal pull-up existed. Holding ¯¯¯¯¯ PlayL Low constantly will perform looping playback function from start to end addresses with insignificant dead time between messages regardless of sampling frequencies. FMC1: When Direct Mode is active, FMC1, together with FMC2 & FMC3, setup various fixed-message configurations. 8 9 I I I E0[1] : In Address Mode, End Address Bit 0. M5 ¯¯ : When Direct Mode is active, low active operation on 5th Message. Internal pull-up & debounce existed. Analog Ground: Ground path for analog circuits. E1[1] : In Address Mode, End Address Bit 1. M6 ¯¯ : When Direct Mode is active, low active operation on 6th Message. Internal pull-up & debounce existed. E2/M7 ¯¯ 10 I E2[1] : In Address Mode, End Address Bit 2. M7 ¯¯ : When Direct Mode is active, low active operation on 7th Message. Internal pull-up & debounce existed. E3/M8 ¯¯ 11 I E3[1] : In Address Mode, End Address Bit 3. Mar 31, 2020 Page 9 of 32 Rev 1.0 ISD1900 PIN NAME PIN # I/ O VSSP2 SP- 12 13 I O VCCP SP+ 14 15 I O VSSP1 AGC 16 17 I I MIC+ / AnaIn 18 I MIC- / NC 19 I Rosc 20 I VCCA ¯¯¯¯ LED 21 22 I O ¯¯¯¯¯ PlayE /FMC2 23 I Mar 31, 2020 FUNCTION M8 ¯¯ : When Direct Mode is active, low active operation on 8th Message. Internal pull-up & debounce existed. Ground: Ground for negative PWM speaker driver. SP-: Negative signal of the differential Class-D PWM speaker outputs. This output, together with the SP+, is used to drive an 8Ω speaker directly. Speaker Power Supply: Power supply for PWM speaker drivers. Depending on the derivative selected, it could be: SP+: Positive signal of the differential Class-D PWM speaker outputs. This output, together with the SP-, is used to drive an 8Ω speaker directly. Or, AUX out: single-ended voltage output. Ground: Ground for positive PWM speaker driver. Automatic Gain Control (AGC): The AGC adjusts the gain of the preamplifier dynamically to compensate for the wide range of microphone input levels. The AGC allows the full range of signals to be recorded with minimal distortion. The AGC is designed to operate with a nominal capacitor of 4.7 µF connected to this pin. Connecting this pin to ground (VSSA) provides maximum gain to the preamplifier circuitry. Conversely, connecting this pin to the power supply (VCCA) provides minimum gain to the preamplifier circuitry. MIC+: Non-inverting input of the differential microphone signal. AnaIn: When FT ¯¯ is selected, the MIC+ input is configured to a single-ended input with 1Vp-p maximum input amplitude and feed-through to the speaker outputs. MIC-: Inverting input of the differential microphone signal. While FT ¯¯ is enabled, MIC- pin is disabled and must be floated. Oscillator Resistor: Connect an external resistor from this pin to VSSA to select the internal sampling frequency. Analog Power Supply: Power supply for analog circuits. LED output: During recording, this output is Low. Also, ¯¯¯¯ LED pulses Low momentarily at the end of playback. ¯¯¯¯¯: PlayE In Address Mode, low active input, edge-trigger playback from start to end addresses & toggle on-off. Debounce & internal pull-up existed. FMC2: When Direct Mode is active, FMC2, together with FMC1 & FMC3, setup various fixed-message configurations. Page 10 of 32 Rev 1.0 ISD1900 PIN NAME ¯¯¯¯/ REC ¯¯/P R PIN # 24 I/ O I FUNCTION ¯¯¯¯: REC In Address Mode, level-hold (after 1 sec holding) or edgetrigger (toggle on-off), low active, recording from start to end addresses. Debounce & internal pull-up existed. ¯¯/P R ( When Direct Mode is active): • When ¯¯ R /P is set to Low, level-hold record operation is selected. When ¯¯/P R is set to High, edge-trigger & toggle on-off playback operation is selected. ¯¯¯¯¯/FMC3 XCLK 25 I External Clock: In Address Mode, low active and level-hold input. As ¯¯¯¯¯ XCLK activated, Rosc pin accepts external clock input signal, provided resistor at Rosc must be removed. Connecting this pin to High enables device running on internal clock via Rosc resistor. If not used, ¯¯¯¯¯ XCLK must be at high level. When Direct Mode is active, FMC3, together with FMC1 & FMC2, setup various fixed-message configurations. FT ¯¯ 26 I Addr/¯¯¯¯ Drct 27 I Feed-Through: Low active input, Level-hold, debounce & Internal pull-up required. When FT ¯¯ is selected, the MIC+ input is configured to a single-ended input with 1Vp-p maximum input amplitude and feed-through to the speaker outputs. Level-hold input. Addr: When set to High, the device operates under Address Mode. Level-hold input. ¯¯¯¯: Drct When set to Low, the device operates under Direct Mode. The device reconfigures its pin definitions to fit various fixedmessage configurations utilizing FMC1 , FMC2 & FMC3 pins as below table. FMC3 FMC2 FMC1 # of fixed messages 0 0 0 1 0 0 1 2 0 1 0 3 0 1 1 4 1 0 0 5 1 0 1 6 1 1 0 7 1 1 1 8 VCCD 28 I Digital Power Supply: Power supply for digital circuits. [1] Notes: : Address bits S0, S1, S2, S3, E0, E1, E2 & E3 are used to access the memory location. Mar 31, 2020 Page 11 of 32 Rev 1.0 ISD1900 6. FUNCTIONAL DESCRIPTION There are two operational modes: Address Mode and Direct Mode. After a new condition is selected on Addr/¯¯¯¯, Drct the power must be cycled to enable it. 6.1. ADDRESS MODE The start address pins (S0, S1, S2 & S3) and end address pins (E0, E1, E2 & E3) are used to access the memory location and they can divide the memory into a maximum of 16 slots. They are defined as follows: E3 ) E2 ) E1 ) E0 ) Row # 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 8 16 24 32 40 48 56 64 72 80 88 96 104 112 120 ( E0 ) Row # S3 ( ( E3 ) S3 0 0 0 0 0 0 0 0 1 1 1 1 Mar 31, 2020 S2 ( ( E2 ) S2 0 0 0 0 1 1 1 1 0 0 0 0 S1 ( ( E1 ) S1 0 0 1 1 0 0 1 1 0 0 1 1 S0 S0 ( 0 0 1 16 0 32 1 48 0 64 1 80 0 96 1 112 0 128 1 144 0 160 1 176 Page 12 of 32 I1916 Duration [s] 0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 I1932 Duration [s] 0 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 Rev 1.0 ISD1900 1 1 1 1 ( E3 ) S3 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 0 0 1 1 ( E2 ) S2 0 0 0 0 1 1 1 1 0 0 0 0 1 1 1 1 ( E1 ) S1 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 0 1 0 1 192 208 232 240 24.0 26.0 28.0 30.0 ( E0 ) Row # 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 32 64 96 128 160 192 224 256 288 320 352 384 416 464 480 I1964 Duration [s] 0 4.0 8.0 12.0 16.0 20.0 24.0 28.0 32.0 36.0 40.0 44.0 48.0 52.0 56.0 60.0 S0 Below is an example: Given sampling rate set to 6.4 kHz, using the ISD1916 to record four messages: three messages of 2.5 seconds and one message of 12.5 seconds, then the memory can be assigned as follows: S3, S2, S1, S0 E3, E2, E1, E0 Message seconds) 1 (2.5 0 0 0 0 0 0 0 1 Message seconds) 2 (2.5 0 0 1 0 0 0 1 1 Message seconds) 3 (2.5 0 1 0 0 0 1 0 1 Message seconds) 4 (12.5 0 1 1 0 1 1 1 1 Mar 31, 2020 Page 13 of 32 Rev 1.0 ISD1900 6.1.1 Record (REC ¯¯¯¯) Operation • Low active input: o level-hold for level-trigger or o falling edge for edge-trigger with debounce required. • For 8kHz sampling frequency, if ¯¯¯¯ REC is held at Low for a period equal to 1 sec or more, then level recording is activated. However, if ¯¯¯¯ REC is pulsed Low for less than 1 sec, then edge-trigger recording is initiated. • For 6.4kHz sampling frequency, if ¯¯¯¯ REC is held at Low for a period equal to 1.25 sec or more, then level recording is activated. However, if ¯¯¯¯ REC is pulsed Low for less than 1.25 sec, then edge-trigger recording is initiated. • Recording begins from the start address to end address and ¯¯¯¯ LED is on. • Recording ceases whenever:  ¯¯¯¯ REC returns to High in level-hold mode or  a subsequent low-pulse appears while in edge-trigger mode or  when end address is reached. o Then an EOM marker is written at the end of message. And ¯¯¯¯ LED is off. o Then the device will automatically power down. • This pin has an internal pull-up device. • Once ¯¯¯¯ REC is active, input on FT ¯¯, Addr/¯¯¯¯, Drct S0, S1, S2, S3, E0, E1, E2 or E3 is illegal. Addr/Drct TASet TAHold REC TDeb LED TStop1 Mic+/or AnaIn TErs End Address Figure 6-1 Record–Level (REC ¯¯¯¯) function till end address Mar 31, 2020 Page 14 of 32 Rev 1.0 ISD1900 Addr/Drct TAHold TASet REC Start TDeb TASet TAHold Start Stop TSettle1 TDeb TDeb LED TErs Mic+/or AnaIn TStop1 TErs End Address Figure 6-2 Record–Level (¯¯¯¯ REC ) function with start and stop actions Addr/Drct Start REC Start Stop TDeb TDeb TAHold TASet TAHold TASet TSettle1 TDeb LED Mic+/or AnaIn TErs TErs TStop1 End Address Figure 6-3 Record–Edge (¯¯¯¯ REC ) function with on-off 6.1.2 Edge-triggered Playback (PlayE ¯¯¯¯¯) Operation • Low active input, edge-trigger, toggle on-off, debounce required. • Playback begins from the start address to end address or EOM, whichever occurrs first. • At the end of message, ¯¯¯¯ LED pulses Low momentarily. o Then device will automatically power down. • During playback, a subsequent trigger terminates the playback operation. If EOM marker is not encountered, then ¯¯¯¯ LED will not pulses Low momentarily. • This pin has an internal pull-up device. • Once ¯¯¯¯¯ PlayE is active, input on ¯¯¯¯¯, PlayL ¯¯¯¯, REC FT ¯¯, Addr/¯¯¯¯, Drct S0, S1, S2, S3, E0, E1, E2 or E3 is banned. Mar 31, 2020 Page 15 of 32 Rev 1.0 ISD1900 Addr/Drct TASet TAHold TASet Start PlayE Stop TDeb TDeb TAHold Start TSettle2 TEOM TDeb LED End of Message Sp+ Sp- Figure 6-4 Playback–Edge (¯¯¯¯¯ PlayE) function 6.1.3 Level-triggered Playback (PlayL ¯¯¯¯¯) Operation • Low active input, Level-hold, debounce required. • Once active, playback begins from the start address and stops whenever ¯¯¯¯¯ PlayL returns to High. When an EOM is encountered, ¯¯¯¯ LED pulses Low momentarily. o Then device will automatically power down. • This pin has an internal pull-up device. • Once ¯¯¯¯¯ PlayL is active, input on ¯¯¯¯¯, PlayE ¯¯¯¯, REC FT ¯¯, Addr/¯¯¯¯, Drct S0, S1, S2, S3, E0, E1, E2 or E3 is prohibited. Addr/Drct TASet PlayL Start TDeb LED TASet TAHold Start Stop TDeb TAHold TSettle2 TEOM TDeb Part of Message Sp+ Sp- End of Message Figure 6-5 Playback–Level (¯¯¯¯¯ PlayL ) function • Holding ¯¯¯¯¯ PlayL Low constantly will perform looping playback function, without power down, from start address to end address. Mar 31, 2020 Page 16 of 32 Rev 1.0 ISD1900 Addr/Drct TASet TAHold PlayL TDeb TEOM TEOM LED Sp+ Sp- Figure 6-6 Looping playback function via ¯¯¯¯¯ PlayL 6.1.4 Playback (Supersedes Record) Operation • Playback takes precedence over the Recording operation. • If either ¯¯¯¯¯ PlayE or ¯¯¯¯¯ PlayL is activated during a recording cycle, the recording immediately ceases with an EOM marker attached, and without power down, playback of the just-recorded message performs accordingly. Then device powers down. Addr/Drct TAHold TASet REC TEOM TDeb LED Mic+/or AnaIn TErs TSettle1 TSettle3 PlayE TDeb SP+ SP- Figure 6-7 An example of Playback supersedes Record Mar 31, 2020 Page 17 of 32 Rev 1.0 ISD1900 6.1.5 XCLK Feature • When precision sampling frequency is required, external clock mode can be activated by setting ¯¯¯¯¯ XCLK to Low. Under such condition, the resistor at Rosc pin must be removed and the external clock signal must be applied to the Rosc pin. These conditions must be satisfied prior to any operations. • However, when internal clock is used, ¯¯¯¯¯ XCLK must be linked to High. • The external clock frequencies required for various sampling frequencies are listed in below table. Sampling Freq 12 8 6.4 5.3 4 [kHz] ¯¯¯¯¯ XCLK [MHz] 3.072 2.048 1.638 1.356 1.024 6.2. DIRECT MODE • The Direct Mode is selected by the ¯¯¯¯ Drct pin. Once chosen, the supply voltage must be reset to allow the device to construct itself to the appropriate configuration by re-defining the function on the related control pins. Also, the mode change is only allowed while the device is in power down state and is inhibited when an operation is in progress. • Once Direct Mode is activated, FMC1, FMC2 & FMC3 are utilized to select various (1 to 8) fixed message configurations [1]. Pending upon the arrangement on FMC1, FMC2 & FMC3, each divided message has approximate equal length of duration, which is related to the number of rows assigned as in tables below. • The record or playback operation is pre-defined by the ¯¯/P R pin. Setting this pin to Low allows record operation while setting it to High enables playback operation. • Each message can be randomly accessed via its message control pin (M1 ¯¯ ~ M8 ¯¯ ) and the desired operations are facilitated accordingly. Non-configured pins are automatically disabled and must be floated. Mar 31, 2020 Page 18 of 32 Rev 1.0 ISD1900 Notes: [1] : Number of fixed message arrangement with respect to FMC1, FMC2 & FMC3. FMC2 FMC1 # of fixed FMC3 messages [1] 0 0 0 1 0 0 1 2 0 1 0 3 0 1 1 4 1 0 0 5 1 0 1 6 1 1 0 7 1 1 1 8 [2] : Number of memory row arrangement with respect to different number of fixed messages for ISD1916 (128 Rows). The nonconfigured Message control pins (Mx) will be disabled. # of Msg M1 M2 M3 M4 M5 M6 M7 M8 1 128 2 64 64 3 44 42 42 4 32 32 32 32 5 26 26 26 26 24 6 23 21 21 21 21 21 7 20 18 18 18 18 18 18 8 16 16 16 16 16 16 16 16 for ISD1932 (256 Rows) # of Msg M1 M2 1 256 2 128 128 3 86 85 4 64 64 5 52 51 6 43 43 7 37 37 8 32 32 Mar 31, 2020 M3 M4 M5 M6 M7 M8 85 64 51 43 37 32 64 51 43 37 32 51 42 36 32 42 36 32 36 32 32 Page 19 of 32 Rev 1.0 ISD1900 for ISD1964 (512 Rows) # of Msg M1 M2 M3 1 512 2 256 256 3 172 170 170 4 128 128 128 5 103 103 102 6 86 86 85 7 74 73 73 8 64 64 64 [3] M5 M6 M7 M8 128 102 85 73 64 102 85 73 64 85 73 64 73 64 64 : The durations for various fixed message configurations on I1916 device at 8 kHz sampling frequency are shown in below table. # of Msg M1 M2 M3 M4 M5 M6 M7 M8 1 16 2 8 8 3 5.5 5.25 5.25 4 4.0 4.0 4.0 4.0 5 3.25 3.25 3.25 3.25 3.0 6 2.87 2.62 2.62 2.62 2.62 2.62 5 5 5 5 5 5 7 2.50 2.25 2.25 2.25 2.25 2.25 2.25 8 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 for ISD1932 (256 Rows) # of Msg M1 M2 1 32 2 16 16 3 10.75 10.625 4 8.0 8.0 5 6.5 6.375 6 5.375 5.375 7 4.625 4.625 8 4.0 4.0 Mar 31, 2020 M4 M3 M4 10.625 8.0 6.375 5.375 4.625 4.0 8.0 6.375 5.375 4.625 4.0 Page 20 of 32 M5 M6 6.375 5.25 5.25 4.5 4.5 4.0 4.0 M7 4.5 4.0 M8 4.0 Rev 1.0 ISD1900 for ISD1964 (512 Rows) # of Msg M1 M2 1 64 2 32 32 3 21.5 21.25 4 16.0 16.0 5 12.875 12.875 6 10.75 10.75 7 9.25 9.125 8 8.0 8.0 M3 M4 21.25 16.0 12.75 10.625 9.125 8.0 16.0 12.75 10.625 9.125 8.0 M5 M6 M7 M8 12.75 10.625 10.625 9.125 9.125 9.125 8.0 8.0 8.0 8.0 Example of four Fixed-Message Configuration: Addr/Drct FM3 FM2 FM1 TFSet R/P Stop M1 ~ M4 TDeb TDeb LED Mic+/or AnaIn Start TSettle1 Start TDeb TStop1 TErs TErs End of Duration Figure 6-8 Record Operation under FMC mode Addr/Drct FM3 FM2 FM1 R/P TFSet Start Stop Start M1 ~ M4 TEOM LED TDeb TDeb TSettle2 TDeb End of Message Sp+ Sp- Figure 6-9 Playback Operation under FMC mode Mar 31, 2020 Page 21 of 32 Rev 1.0 ISD1900 6.3. OTHER OPERATIONS 6.3.1 Rosc Operation • When the ROSC varies from 53.3 KΩ to 160 KΩ, the sampling frequency changes from 12 to 4 kHz accordingly. • When ROSC resistor value is changed during playback, the tone of a recorded message will alter either faster or slower. • If the ground side of ROSC resistor is floated or tied to VCC, then the current operation will be freezed. • The operation will resume when the resistor is connected back to ground. 6.3.2 LED Operation • ¯¯¯¯ LED turns on during recording. Also, ¯¯¯¯ LED pulses Low at the end of message. The Low period must be sufficiently greater than debounce time. 6.3.3 Feed-Through mode Operation • As FT ¯¯ is held Low, the Mic+ pin will be reconfigured as AnaIn input, and the AnaIn signal will be transmitted to the speaker outputs. Under this mode, Micpin is not used (must be floated). • After FT ¯¯ is enabled, If ¯¯¯¯ REC is triggered, then AnaIn signal will be recorded into memory while the Feed-Through path remains on. • If FT ¯¯ is already enabled, activating either ¯¯¯¯¯ PlayE or ¯¯¯¯¯ PlayL will first disable the FT path and then play the recorded message. Once playback completes, FT path will be resumed. • During an operation, activating the FT ¯¯ pin is not allowed. 6.3.4 Power-On Playback Operation • If ¯¯¯¯¯ PlayE is kept at Low during power turns on, the device plays message once, then powers down. • If ¯¯¯¯¯ PlayL is held at Low during power turns on and constantly maintained at Low, the device will play the message repeatedly, with insignificant dead time between messages regardless of sampling frequencies. This status will sustain unless power is turned off or ¯¯¯¯¯ PlayL somehow returns to High. Mar 31, 2020 Page 22 of 32 Rev 1.0 ISD1900 6.3.5 Automatic Single Message Playback • If ¯¯¯¯ LED is connected to ¯¯¯¯¯, PlayE once ¯¯¯¯¯ PlayE is triggered, the device plays message repeatedly without power down between the looping playback. However, if ¯¯¯¯¯ PlayE is triggered again during playback, then playback will stop. 6.3.6 Power is interrupted Abruptly • During the device is in operation, it is strongly recommended that the supply power cannot be interrupted. Otherwise, it may cause the device to become malfunctioning. Mar 31, 2020 Page 23 of 32 Rev 1.0 ISD1900 7. ABSOLUTE MAXIMUM RATINGS [1] ABSOLUTE MAXIMUM RATINGS CONDITION VALUE Junction temperature 150°C Storage temperature range -65°C to +150°C Voltage applied to any pins (VSS – 0.3V) to (VCC + 0.3V) Voltage applied to Input pins (current limited to +/20 mA) (VSS – 1.0V) to (VCC + 1.0V) Voltage applied to output pins (current limited to +/-20 mA) (VSS – 1.0V) to (VCC + 1.0V) VCC – VSS -0.3V to +7.0V [1] Stresses above those listed may cause permanent damage to the device. Exposure to the absolute maximum ratings may affect device reliability and performance. Functional operation is not implied at these conditions. 7.1. OPERATING CONDITIONS OPERATING CONDITIONS CONDITION Operating temperature range Operating voltage (VCC) VALUE 0°C to +50°C [1] +2.4V to +5.5V Ground voltage (VSS) [2] 0V [1] V CC [2] = VCCA = VCCD VSS = VSSA = VSSD Mar 31, 2020 Page 24 of 32 Rev 1.0 ISD1900 8. ELECTRICAL CHARACTERISTICS 8.1. DC PARAMETERS PARAMETER Input Low Voltage Input High Voltage Output Low Voltage Output High Voltage Standby Current Record Current Playback Current SYMBO MIN[2] TYP[1] MAX[2] UNITS CONDITIONS L VIL 0.3xVc V c VIH 0.7xVc V c VOL 0.3xVc V IOL = 4.0 mA[3] c VOH 0.7xVc V IOH = -1.6 mA[3] c ISTBY 1 10 µA [4] [5] IREC 20 30 mA VCC = 5.5V [4] [5] IPLAY 20 30 mA VCC = 5.5V, no load [4] [5] Pull-up device for ¯¯¯¯ REC , ¯¯¯¯¯ PlayE , ¯¯¯¯¯ PlayL , FT ¯¯ & M1 ¯¯ ~ M8 ¯¯ pins RPU1 600 kΩ MIC+ Input Resistance MIC- Input Resistance AnaIn Input Resistance MIC Differential Input AnaIn Input Gain from MIC to SP+/- RMICP RMICN RANAIN VIN1 VIN2 AMSP 18 18 42 KΩ KΩ KΩ mV V dB Gain from AnaIn to SP+/Output Load Impedance Speaker Output Power AASP Speaker Output Voltage Total Harmonic Distortion RSPK Pout 15 300 1 40 6 0 dB Ω 8 VOUT1 670 313 117 49 VDD mW mW mW mW V THD 1 % Peak-to-peak Peak-to-peak VIN = 15~300 mVp-p, AGC = 4.7 µF, VCC = 2.4V~5.5V VCC = 2.4V~5.5V Speaker load VDD = 5.5 V VDD = 4.4 V VDD= 3 V VDD= 2.4 V 1Vp-p, 1 kHz sine wave at AnaIn. RSPK =8Ω RSPK = 8Ω Speaker, Typical buzzer 15 mV p-p 1 kHz sine wave, Cmessage weighted Notes: [1] Typical values @ VCC = 5.5V, TA = 25° and sampling frequency (Fs) at 8 kHz, unless stated. [2] Not all specifications are 100 percent tested. All Min/Max limits are guaranteed by Nuvoton via design, electrical testing and/or characterization. [3] LED output during recording. [4] V CCA, VCCD and VCCP are connected together. Also, VSSA, VSSD, VSSP1 and VSSP2 are linked together. [5] All required control pins must be at appropriate status. External components are biased under a separated power supply. Mar 31, 2020 Page 25 of 32 Rev 1.0 ISD1900 8.2. AC PARAMETERS CHARACTERISTIC [1] Sampling Frequency Record / Playback Duration (ISD1916) Record / Playback Duration (ISD1932) Record / Playback Duration (ISD1964) Debounce Time Address Setup Time Address Hold Time Erase Time FMC Setup Time Record Settle Time Play Settle Time Delay from Record to Play Record Stop Time LED Pulse Low Time SYMBOL MIN[2] TYP MAX[2] UNITS Fs 4 12 kHz TREC / 10.6 32 sec TPLAY TREC / 21.3 64 sec TPLAY TREC / 42.6 128 sec TPLAY TDeb 225k/Fs msec TASet 30 nsec TAhold 225k/Fs msec TErs 1.25MRN msec TFset 30 nsec TSettle1 32k/Fs msec TSettle2 256k/Fs msec TSettle3 128k/Fs msec TStop1 TEOM 30 256k/Fs nsec msec CONDITIONS [3] [3] [3] [3] [3] [4] [3] [4] MRN = message row # [3] [4] [3] [4] [3] [4] [3] [4] Notes: [1] Conditions are VCC = 5.5V, TA = 25°C and sampling frequency (FS) at 8kHz, unless specified. [2] Not all specifications are 100 percent tested. All Min/Max limits are guaranteed by Nuvoton via design, electrical testing and/or characterization. [3] When different FS is applied, the value will change accordingly. Also, stability of internal oscillator may vary as much as +10% over the operating temperature and voltage ranges. [4] k = 1000. Mar 31, 2020 Page 26 of 32 Rev 1.0 ISD1900 9. TYPICAL APPLICATION CIRCUIT The following typical application examples on ISD1900 series are for references only. They make no representation or warranty that such applications shall be suitable for the use specified. It’s customer’s obligation to verify the design in its own system for the functionalities, voice quality, current consumption, and etc. In addition, the below notes apply to the following application examples: • The suggested values are for references only. Depending on system requirements, they can be adjusted for functionalities, voice quality and degree of performance. It is important to have a separate path for each ground and power back to the related terminals to minimize the noise. Besides, the power supplies should be decoupled as close to the device as possible. Also, it is crucial to follow good audio design practices in layout and power supply decoupling. See recommendations in Application Notes from our websites. Example #1: Operations via start and end address under Address Mode. To switches or address I/Os VCC 4.7 k Ω∗ 4.7µ F* 4.7 k Ω∗ REC Addr PLAYE LED PLAYL XCLK S3 S2 S1 S0 E3 E2 E1 E0 Mar 31, 2020 Rosc* Vcc VCCA VCCD VCCP VCCD 0.1µ F Gnd 10 µ F* VSSD ISD1900 Mic+_AnaIn Mic- VCCA VCCA 0.1µ F 10 µ F* VSSA VCCP FT 4.7 µ F* 4.7 k Ω∗ D1 VCCD 0.1 µ F* 0.1 µ F* 1 KΩ VSSP1 VCCP 0.1µ F 10 µ F* 10 µ F* 0.1µ F VSSP2 AGC SP+/AUX Rosc SP-/NC Page 27 of 32 Speaker Rev 1.0 ISD1900 Example #2: Fixed Message Configuration Operations under Direct Mode. VCC 1 kΩ R/P LED M1 M2 Drct FMC3 M3 FMC2 M4 FMC1 VCCD M5 M6 VCC M8 Vcc Gnd VCCA VCCD VCCP VCCD 0.1µ F 10 µ F* VSSD M7 4.7 k Ω∗ D1 ISD1900 VCCA VCCA 0.1µ F 10 µ F VSSA 4.7µ F* 4.7 k Ω∗ FT 0.1 µ F* VCCP Mic+_AnaIn 0.1 µ F* 4.7 µ F* 4.7 kΩ∗ VCCP 0.1µ F VSSP1 MicAGC Rosc* Rosc 10 µ F* 10 µ F* 0.1µ F VSSP2 SP+/AUX Speaker SP-/NC Good Audio Design Practices Nuvoton’s ChipCorder are very high-quality single-chip voice recording and playback devices. To ensure the highest quality voice reproduction, it is important that good audio design practices on layout and power supply decoupling are followed. See Application Information links below for details. Good Audio Design Practices (apin11.pdf) Single-Chip Board Layout Diagrams (apin12.pdf) It is strongly recommended that before any design or layout project starts, the designer should contact Nuvoton Sales Rep for the most update technical information and layout advice. Mar 31, 2020 Page 28 of 32 Rev 1.0 ISD1900 10. PACKAGING 10.1. 28-LEAD 300-MIL PLASTIC SMALL OUTLINE INTEGRATED CIRCUIT (SOIC) 28 27 26 25 24 23 22 21 20 19 18 17 16 15 1 2 3 4 5 6 7 8 9 10 11 12 13 14 A G C B D E H F Plastic Small Outline Integrated Circuit (SOIC) Dimensions INCHES MILLIMETERS Min Nom Max Min Nom Max A 0.701 0.706 0.711 17.81 17.93 18.06 B 0.097 0.101 0.104 2.46 2.56 2.64 C 0.292 0.296 0.299 7.42 7.52 7.59 D 0.005 0.009 0.0115 0.127 0.22 0.29 E 0.014 0.016 0.019 0.35 0.41 0.48 F 0.050 1.27 G 0.400 0.406 0.410 10.16 10.31 10.41 H 0.024 0.032 0.040 0.61 0.81 1.02 Note: Lead coplanarity to be within 0.004 inches. Mar 31, 2020 Page 29 of 32 Rev 1.0 ISD1900 11. ORDERING INFORMATION Product Number Descriptor Key I19 xxxxxxxx Product Name: I = ISD Output Type: Blank = PWM 01 = AUX out Tape & Reel: Blank = None R = Tape & Reel Product Series: 19 = 1900 Duration: 16 : 10.6 – 32 secs 32 : 21.3 – 64 secs 64 : 42.6 – 128 secs Temperature: I = Industrial (-40°C to +85°C) Package Type: S = Small Outline Integrated Circuit (SOIC) Package Lead-Free: Y = Lead-Free When ordering ISD1900 devices, please refer to the above ordering scheme. Contact the local Nuvoton Sales Representatives for any questions and the availability. For the latest product information, please contact the Nuvoton Sales/Rep or access Nuvoton’s worldwide web site at http://www.nuvoton.com Mar 31, 2020 Page 30 of 32 Rev 1.0 ISD1900 12. VERSION HISTORY VERSION DATE 0 Aug 11, 2007 Initial revision 0.1 Oct 10, 2007 Update block diagram 0.2 Oct 16, 2007 Update description 0.3 July 23, 2008 Generalize for different derivatives. 0.4 Aug 15, 2008 Update timing and application diagrams. 0.41 Aug 21, 2008 Add description of AGC. 0.51 Jan 5, 2009 Rename Norm/Mode ¯¯¯¯ to Addr/¯¯¯¯. Drct 1.0 Apr 1, 2020 Update Document Format Mar 31, 2020 DESCRIPTION Page 31 of 32 Rev 1.0 ISD1900 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Mar 31, 2020 Page 32 of 32 Rev 1.0
ISD1964SYI01 价格&库存
很抱歉,暂时无法提供与“ISD1964SYI01”相匹配的价格&库存,您可以联系我们找货
