ISD15D00YYI
ISD15D00YYI
    NUVOTON(新唐)
    QFN-32-EP(5x5)
    ISD15D00YYI
ISD15D00YYI 数据手册
ISD15D00 DATASHEET ISD15D00 Digital ChipCorder with Digital Audio Interface -1- Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET TABLE OF CONTENTS 1 GENERAL DESCRIPTION .............................................................................................................. 3 2 FEATURES ...................................................................................................................................... 3 3 BLOCK DIAGRAM ........................................................................................................................... 5 4 PINOUT CONFIGURATION ............................................................................................................ 6 4.1 QFN-32 .................................................................................................................................................... 6 5 PIN DESCRIPTION .......................................................................................................................... 7 6 ELECTRICAL CHARACTERISTICS .............................................................................................. 10 6.1 ABSOLUTE MAXIMUM RATINGS ............................................................................................................. 10 6.2 OPERATING CONDITIONS ........................................................................................................................ 10 6.3 DC PARAMETERS ................................................................................................................................... 12 6.4 AC PARAMETERS ................................................................................................................................... 13 6.4.1 Internal Oscillator ......................................................................................................................... 13 6.4.2 Inputs ............................................................................................................................................. 13 6.4.3 Outputs ........................................................................................................................................... 15 6.4.4 SPI Timing ..................................................................................................................................... 18 6.4.5 I2S Timing ...................................................................................................................................... 19 7 APPLICATION DIAGRAM .............................................................................................................. 21 8 PACKAGE SPECIFICATION ......................................................................................................... 23 8.1 9 10 QFN-32 (5X5 MM^2, THICKNESS 0.8MM ,PITCH 0.5 MM) .................................................................. 23 ORDERING INFORMATION .......................................................................................................... 24 REVISION HISTORY.................................................................................................................. 25 -2- Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 1 GENERAL DESCRIPTION ® The ISD15D00 is a digital ChipCorder featuring digital compression, comprehensive memory management, and integrated analog/digital audio signal paths. The ISD15D00 utilizes serial flash 2 memory to provide non-volatile audio playback for a two-chip solution. The ISD15D00 provides an I S digital audio interface, faster digital programming, higher sampling frequency, and a signal path with SNR 80dB. 2 2 The ISD15D00 can take digital audio data via I S or SPI interface. When I S input is selected, it will replace the analog audio inputs and will support sample rates of 32, 44.1 or 48 kHz depending upon clock configuration. When SPI interface is chosen, the sample rate of the audio data sent must be one of the ISD15D00 supported sample rates. The ISD15D00 has inbuilt analog audio inputs, analog audio line driver, and speaker driver output. The analog audio input, Aux-in, has a fixed gain configured by SPI command. Aux-in can directly feed-through to the analog outputs; it can also mix with the DAC output and then feed-through to the analog outputs. Analog outputs are available in two forms: (1) Aux-out is an analog single-ended voltage output; (2) Class-AB BTL (bridge-tied-load) is an analog differential voltage output. Class-AB BTL delivers 0.7watt output power at VCCSPK = 4.5V. Class-D PWM direct-drive is also available, which delivers 0.9-watt output power at VCCSPK = 4.5V. 2 FEATURES  External Memory: o The ISD15D00 supports the following flash: Manufacturer Family JEDEC ID Winbond 25X 25Q EF 30 1X EF 40 1X 25P 20 20 1X Numonyx 25PX 20 71 1X 25PE 20 80 1X MXIC 25L / 25V C2 20 1X o     The addressing ability of ISD15D00 is up to 128Mbit, which is 64-minute playback time based on 8kHz/4bit ADPCM. o Inbuilt 3V voltage regulator to provide power source to the external flash memory Fast Digital Programming o Programming rate can go up to 1Mbits/second mainly limited by the flash memory write rate. Memory Management o Store pre-recorded audio (Voice Prompts) using high quality digital compression o Use a simple index-based command for playback o Execute pre-programmed macro scripts (Voice Macros) designed to control the configuration of the device and play back Voice Prompts sequences. Sample Rate o Seven sampling frequencies are available for a given master sample rate. For example, the sampling frequencies of 4, 5.3, 6.4, 8, 12.8, 16 and 32kHz are available when the device is clocked at a 32kHz master sample rate. 2 o For I S operation, 32, 44.1 and 48kHz master sample rates are available with playback sampling frequencies scaling accordingly. Compression Algorithms o For Pre-Recorded Voice Prompts  µ-Law: 6, 7 or 8 bits per sample -3- Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET               1 2 Differential µ-Law: 6, 7 or 8 bits per sample PCM: 8, 10 or 12 bits per sample Enhanced ADPCM: 2, 3, 4 or 5 bits per sample Variable-bit-rate optimized compression. This allows best possible compression given a metric of SNR and background noise levels. Oscillator o Internal oscillator with internal reference: 2.048 MHz with ±1% deviation 1 o Internal oscillator with external resistor: 2.048 MHz with ±2% deviation 2 o I S bit clock input Inputs o Aux-in: Analog input with 2-bit gain control configured by SPI command Outputs o PWM: Class-D speaker driver to directly drive an 8Ω speaker or buzzer  Deliver 0.9-watt output power at VCCSPK = 4.5V o Aux-out: an analog single-ended voltage output o Class-AB BTL: an analog differential voltage output  Deliver 0.7-watt output power at VCCSPK = 4.5V  Class-AB BTL can directly drive an 8Ω speaker or buzzer  Class-AB BTL can drive an 8Ω speaker or buzzer via an external amplifier I/Os o SPI interface: MISO, MOSI, SCLK, SSB for commands and digital audio data 2 2 2 2 2 o I S interface: I S_CLK, I S_WS, I S_SDI, I S_SDO for digital audio data o 8 GPIO pins: 2  4 GPIO pins share with I S  4 GPIO pins share with SPI Interface  GPIO pins can trigger Voice Macro for a pushbutton application 8-bit Volume Control set by SPI command for flexible mixing Talarm temperature threshold: 125°C typical Operating Voltage: 2.7 ~ 5.5V Standby Current: 1uA typical Package: o Green QFN-32 Automotive grade: o AEC-Q100 grade 3 operating temperature range -40⁰C to 85⁰C 2 o Tested to a high reliability standard With ±1% precision 80kohm external resistor. Contact Nuvoton sale s representatives for details. -4- Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET BLOCK DIAGRAM AUXIN Av = 0, 3, 6, 9dB AUXIN SUM2 GPIO7 / SDI GPIO5 / WS Digital Signal Path: Digital Filters Resampling Volume Control I2S Interface GPIO4 / SDO DAC PWM Control AUX_MUX GPIO6 / SCK + SPI Interface Memory Management and Command Interpreter Flash Memory Controller Figure 3-1 ISD15D00 Block Diagram -5- Publication Release Date: Aug 5, 2016 Revision 1.2 AUXOUT SPK+ SPK-_MUX SCLK SSB GPIO1 / MISO GPIO0 / MOSI GPIO3 / INTB GPIO2 / RDY/BSYB AUXOUT SPK+_MUX De-Compression FCLK FCSB FDI FDO 3 SPK- ISD15D00 DATASHEET VMID VSSA VCCA AUXOUT 32 31 30 29 28 27 26 I2S_WS / GPIO5 2 XTALIN AUXIN 25 24 VCCFS 23 VCCF 22 FCSB I2S_SDO / GPIO4 3 VSSD 4 21 FDI ISD15D00 VCCD 5 20 FCLK 19 FDO VREG 6 18 RESET MISO / GPIO1 7 12 VCCSPK SPK+ 13 14 15 VCCSPK 11 SPK- 10 VSSSPK 9 MOSI / GPIO0 SCLK 8 17 GPIO2 / RDY/BSYB 16 GPIO3 / INTB I2S_SCK / GPIO6 1 NC QFN-32 I2S_SDI / GPIO7 4.1 PINOUT CONFIGURATION SSB 4 Figure 4-1 ISD15D00 QFN-32 Pin Configuration. -6- Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 5 PIN DESCRIPTION Pin Number QFN-32 Pin Name I/O Function 32 GPIO7 / 2 I S_SDI I/O A GPIO pin. By default this pin is a pull-high input. 2 Can be configured as Serial Data Input of the I S interface. 1 GPIO6 / 2 I S_SCK I/O A GPIO pin. By default this pin is a pull-high input. Can be configured as Clock input in slave mode or clock output in master mode. This pin can be configured as an external clock buffer 2 if I S is not used. 2 GPIO5 / 2 I S_WS I/O A GPIO pin. By default this pin is a pull-high input. Can be configured as Word Select (WS) input in slave mode or WS output in master mode. 3 GPIO4 / 2 I S_SDO I/O A GPIO pin. By default this pin is a pull-high input. 2 Can be configured as Serial Data Output of the I S Interface. 4 VSSD I Digital Ground. 5 VCCD I Digital power supply. 6 VREG O A 1.8V regulator to supply the internal logic. A minimum 1uF capacitor with low ESR 0.2W - 16 - Typ Max Units 65 dB -40 dB 80 % Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET CLASS-AB BTL OUTPUT Conditions: VCCD = 3.3V, VCCA = VCCSPK = 5V, MCLK = 16.384MHz, TA = +25°C, 1kHz signal Parameter Symbol Comments/Conditions Min Typ Max Units Speaker CLASS-AB BTL Output (SPK_PLUS / SPK_MINUS with 8Ω bridge-tied-load) Full scale output Gain paths all at 0dB VCCA / 3.3 gain Vrms Signal-to-noise ratio 2 Total harmonic distortion Efficiency dB dB % SNR THD EAB A-weighted A-weighted 8Ω bridge-tied-load Pout > 0.7W 90 -60 50 Conditions: VCCD = 3.3V, VCCA = VCCSPK = 3.3V, MCLK = 16.384MHz, TA = +25°C, 1kHz signal Parameter Symbol Comments/Conditions Min Typ Max Units Speaker CLASS-AB BTL Output (SPK_PLUS / SPK_MINUS with 8Ω bridge-tied-load) Full scale output Gain paths all at 0dB VCCA / 3.3 gain Vrms Signal-to-noise ratio 2 Total harmonic distortion Efficiency dB dB % SNR THD EAB A-weighted A-weighted 8Ω bridge-tied-load Pout > 0.4W 84 -60 50 Notes 1. 2. 3. Full Scale is relative to the magnitude of VCCA and can be calculated as FS = VCCA/3.3. Distortion is measured in the standard way as the combined quantity of distortion products plus noise. The signal level for distortion measurements is at 3dB below full scale, unless otherwise noted. SNR measured with a -100dbFS signal at input. - 17 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 6.4.4 SPI Timing TSSBHI SSB TSSBS TSSBH TSCK TRISE TFALL SCLK TSCKH TSCKL MOSI TMOS TMOH TZMID TMIZD MISO TMID TCRBD TRBCD RDY/BSYB Figure 6-2 SPI Timing SYMBOL DESCRIPTION MIN TYP MAX UNIT TSCK SCLK Cycle Time 60 --- --- ns TSCKH SCLK High Pulse Width 25 --- --- ns TSCKL SCLK Low Pulse Width 25 --- --- ns TRISE Rise Time for All Digital Signals --- --- 10 ns TFALL Fall Time for All Digital Signals --- --- 10 ns st TSSBS SSB Falling Edge to 1 SCLK Falling Edge Setup Time 30 --- --- ns TSSBH Last SCLK Rising Edge to SSB Rising Edge Hold Time 30ns --- 50us --- TSSBHI SSB High Time between SSB Lows 20 --- --- ns TMOS MOSI to SCLK Rising Edge Setup Time 15 --- --- ns TMOH SCLK Rising Edge to MOSI Hold Time 15 --- --- ns TZMID Delay Time from SSB Falling Edge to MISO Active -- -- 12 ns TMIZD Delay Time from SSB Rising Edge to MISO Tri-state -- -- 12 ns - 18 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET SYMBOL MIN TYP MAX Delay Time from SCLK Falling Edge to MISO --- --- 12 ns TCRBD Delay Time from SCLK Rising Edge to RDY/BSYB Falling Edge -- -- 12 ns TRBCD Delay Time from RDY/BSYB Rising Edge to SCLK Falling Edge 0 -- -- ns TMID 6.4.5 DESCRIPTION UNIT 2 I S Timing TSCK TRISE TFALL IS_SCK TWSH TSCKH TWSH TSCKL TWSS TWSS IS_WS TSDIS TSDIH IS_SDI MSB LSB MSB TSDOD IS_SDO MSB LSB MSB 2 Figure 6-3 I S Timing SYMBOL DESCRIPTION MIN TYP MAX UNIT TSCK IS_SCK Cycle Time 60 --- --- ns TSCKH IS_SCK High Pulse Width 25 --- --- ns TSCKL IS_SCK Low Pulse Width 25 --- --- ns TRISE Rise Time for All Digital Signals --- --- 10 ns TFALL Fall Time for All Digital Signals --- --- 10 ns - 19 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET SYMBOL DESCRIPTION MIN TYP MAX UNIT TWSS WS to IS_SCK Rising Edge Setup Time 20 --- --- ns TWSH IS_SCK Rising Edge to IS_WS Hold Time 20 --- --- ns TSDIS IS_SDI to IS_SCK Rising Edge Setup Time 15 --- --- ns TSDIH IS_SCK Rising Edge to IS_SDI Hold Time 15 --- --- ns TSDOD Delay Time from IS_SCLK Falling Edge to IS_SDO --- --- 12 ns - 20 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 7 APPLICATION DIAGRAM VCCD CSB VCC DO HOLDB WPB CLK GND DIO 0.1 uF Flash VSSD 4 21 22 20 19 FDI FCSB FCLK FDO 32 1 2 3 I2S_SDI / GPIO7 I2S_SCK / GPIO6 I2S_WS / GPIO5 I2S_SDO / GPIO4 VCCD VCCD VREG ISD15D00 10K  10K VCCD 5 24 V CCFS 23 V CCF 1uF 7 8 VCCD 9 10  10K 16 data flow control 17 18 high pulse of 50ms MISO / GPIO1 SCLK SSB MOSI / GPIO0 INTB / GPIO3 RDY/BSYB / GPIO2 RESET 220pF 0.1uF 30 5.6 K  : Ground for SPK; 1uF VCCSPK VCCSPK 11 VCCSPK 15 0.1 uF VSSSPK 13 SPK+ 12 VCCA VCCD VCCSPK1uH 0 XTALIN 25 VCCA VCCA 27 VSSA 28 AUXOUT 26 4.7 uF 0.1 uF 0.1uF 100  4.7K 200 pF Figure 7-1 ISD15D00 Application Diagram – VCCF is regulated internally from VCCFS - 21 - 47 uF 1uH SPK- 14 AUXIN 29 V MID : Analog ground; 6 10K  5.6 K : Digital ground; 0.1 uF Publication Release Date: Aug 5, 2016 Revision 1.2 0 ISD15D00 DATASHEET VCCD VCCFS CSB VCC DO HOLDB WPB 0.1 uF CLK DIO GND Flash VSSD 4 21 22 20 19 FDI FCSB FCLK FDO 32 1 2 3 I2S_SDI / GPIO7 I2S_SCK / GPIO6 I2S_WS / GPIO5 I2S_SDO / GPIO4 VCCD VCCD VREG 6 ISD15D00 10K  10K  VCCD 5 24 V CCFS 23 V CCF 1uF 7 8 VCCD 9 10 10K  16 data flow control 17 18 high pulse of 50ms MISO / GPIO1 SCLK SSB MOSI / GPIO0 INTB / GPIO3 RDY/BSYB / GPIO2 RESET 220pF 30 5.6 K  VCCA VCCD VCCSPK1uH SPK- 14 1uH 0 47 uF 0 XTALIN 25 VCCA VCCA 27 AUXIN 29 V MID 0.1 uF SPK+ 12 VSSA 28 0.1uF : Ground for SPK; 1uF VCCSPK 13 10K  5.6 K : Analog ground; VCCSPK 11 VCCSPK 15 VSSSPK : Digital ground; 0.1 uF AUXOUT 26 4.7 uF 0.1 uF 0.1uF 100  4.7K 200 pF Figure 7-2 ISD15D00 Application Diagram – VCCF is tied to VCCFS The above application examples are for references only. It makes no representation or warranty that such applications shall be suitable for the use specified. Each design has to be optimized in its own system for the best performance on voice quality, current consumption, functionalities and etc. - 22 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 8 8.1 PACKAGE SPECIFICATION QFN-32 (5X5 MM^2, THICKNESS 0.8MM ,PITCH 0.5 MM) 32 25 1 24 8 17 9 16 25 32 24 1 17 8 16 9 - 23 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 9 ORDERING INFORMATION I15D00 YYI Lead-Free Package Type Y: QFN-32 Y: Green (RoHS Compliant) I: Industrial -40 C to 85C - 24 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET 10 REVISION HISTORY Version Date Description 0.23 Aug 3, 2009 Initially released as the Preliminary Datasheet. 0.26 Aug 17, 2009 Update application diagram. 0.27 Sep 28, 2009 Update the list of supported Flash Memory. 0.29 Nov 18, 2009 Update:  Block Diagram.  Electrical Characteristics. 0.34 Dec 7, 2009 Add QFN-32 Package. 0.35 Feb 8, 2010 Update block diagram. 0.40 July 1, 2010 Update crystal configuration. 0.50 Aug 12, 2010 Update PWM spec. 0.60 Mar 31, 2011 Class-AB output delivers 0.7-watt at 4.5V. 0.63 Apr 13, 2011 Update package information. 0.64 Aug 09,2011 AEC_Q100 standard. 1.0 Aug 23, 2013 Add internal oscillator characteristics. 1.1 Jun 13, 2014 Update current consumption characteristic data 1.2 Aug 3, 2016 Add Absolute Maximum Ratings. Add Talarm temperature threshold typical value. - 25 - Publication Release Date: Aug 5, 2016 Revision 1.2 ISD15D00 DATASHEET Nuvoton products are not designed, intended, authorized or warranted for use as components in systems or equipment intended for surgical implantation, atomic energy control instruments, airplane or spaceship instruments, transportation instruments, traffic signal instruments, combustion control instruments, or for other applications intended to support or sustain life. Furthermore, Nuvoton products are not intended for applications wherein failure of Nuvoton products could result or lead to a situation wherein personal injury, death or severe property or environmental damage could occur. Nuvoton customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nuvoton for any damages resulting from such improper use or sales. The contents of this document are provided only as a guide for the applications of Nuvoton products. Nuvoton makes no representation or warranties with respect to the accuracy or completeness of the contents of this publication and reserves the right to discontinue or make changes to specifications and product descriptions at any time without notice. No license, whether express or implied, to any intellectual property or other right of Nuvoton or others is granted by this publication. Except as set forth in Nuvoton's Standard Terms and Conditions of Sale, Nuvoton assumes no liability whatsoever and disclaims any express or implied warranty of merchantability, fitness for a particular purpose or infringement of any Intellectual property. The contents of this document are provided “AS IS”, and Nuvoton assumes no liability whatsoever and disclaims any express or implied warranty of merchantability, fitness for a particular purpose or infringement of any Intellectual property. In no event, shall Nuvoton be liable for any damages whatsoever (including, without limitation, damages for loss of profits, business interruption, loss of information) arising out of the use of or inability to use the contents of this documents, even if Nuvoton has been advised of the possibility of such damages. Application examples and alternative uses of any integrated circuit contained in this publication are for illustration only and Nuvoton makes no representation or warranty that such applications shall be suitable for the use specified. The 100-year retention and 100K record cycle projections are based upon accelerated reliability tests, as published in the Nuvoton Reliability Report, and are neither warranted nor guaranteed by Nuvoton. This datasheet and any future addendum to this datasheet is(are) the complete and controlling ISD ® ChipCorder® product specifications. In the event any inconsistencies exist between the information in this and other product documentation, or in the event that other product documentation contains information in addition to the information in this, the information contained herein supersedes and governs such other information in its entirety. This datasheet is subject to change without notice. Copyright© 2005, Nuvoton Technology Corporation. All rights reserved. ChipCorder ® and ISD® are trademarks of Nuvoton Technology Corporation. All other trademarks are properties of their respective owners. Headquarters Nuvoton Technology Corporation America Nuvoton Technology (Shanghai) Ltd. No. 4, Creation Rd. III Science-Based Industrial Park, Hsinchu, Taiwan TEL: 886-3-5770066 FAX: 886-3-5665577 http://www.Nuvoton.com.tw/ 2727 North First Street, San Jose, CA 95134, U.S.A. TEL: 1-408-9436666 FAX: 1-408-5441797 http://www.Nuvoton-usa.com/ 27F, 299 Yan An W. Rd. Shanghai, 200336 China TEL: 86-21-62365999 FAX: 86-21-62356998 Taipei Office Nuvoton Technology Corporation Japan Nuvoton Technology (H.K.) Ltd. 9F, No. 480, Pueiguang Rd. Neihu District Taipei, 114 Taiwan TEL: 886-2-81777168 FAX: 886-2-87153579 7F Daini-ueno BLDG. 3-7-18 Shinyokohama Kohokuku, Yokohama, 222-0033 TEL: 81-45-4781881 FAX: 81-45-4781800 Unit 9-15, 22F, Millennium City, No. 378 Kwun Tong Rd., Kowloon, Hong Kong TEL: 852-27513100 FAX: 852-27552064 Please note that all data and specifications are subject to change without notice. All the trademarks of products and companies mentioned in this datasheet belong to their respective owners. - 26 - Publication Release Date: Aug 5, 2016 Revision 1.2
ISD15D00YYI 价格&库存
很抱歉,暂时无法提供与“ISD15D00YYI”相匹配的价格&库存,您可以联系我们找货
ISD15D00YYI
    • 1+35.01360
    • 200+13.55400
    • 500+13.07880
    • 1000+12.84120
