NAU8401YG
NAU8401YG
    NUVOTON(新唐)
    WFQFN32_EP
    NAU8401YG
NAU8401YG 数据手册
NAU8401 24-bit Stereo Audio DAC with Speaker Driver emPowerAudio™ Description The NAU8401 is a low power, high quality audio output system for portable applications. In addition to precision 24-bit stereo DACs, this device integrates a broad range of additional functions to simplify implementation of complete audio systems. The NAU8401 includes drivers for speaker, headphone, and stereo line outputs, and integrates mixing of the DAC outputs with analog input signals. Advanced on-chip digital signal processing includes a 5-band equalizer, a 3-D audio enhancer, and a digital limiter/dynamic range compressor function for the playback path. The digital interface can operate as either a master or a slave. Additionally, an internal fractional-N PLL is available to generate accurate audio sample rate clocks for the DAC derived from any available system clock from 8MHz through 33MHz. The NAU8401 operates with analog supply voltages from 2.5V to 3.6V, while the digital core can operate as low as 1.7V to reduce power. The loudspeaker BTL output pair and two auxiliary line outputs can use a 5V supply to increase output power capability, enabling the NAU8401 to drive 1 Watt into an external speaker. Internal control registers enable flexible power conserving modes, shutting down sub-sections of the chip under software control. The NAU8401 is specified for operation from -40°C to +85°C. AEC-Q100 & TS16949 compliant device is available upon request. Key Features  DAC: 94dB SNR and -84dB THD (“A” weighted)  Integrated BTL speaker driver: 1W into 8Ω  Integrated head-phone driver: 40mW into 16Ω  Integrated line inputs and line outputs  On-chip high resolution fractional-N PLL  Integrated DSP with specific functions:  5-band equalizer  3-D audio enhancement  Automatic level control  Audio level limiter/dynamic range compressor  Standard audio interfaces: PCM and I2S  Serial control interfaces with read/write capability  Supports audio sample rates from 8kHz to 48kHz Applications  Personal Navigation Devices  Personal Media Players  Personal Navigation Devices  Portable Game Players  Portable TVs Datasheet Rev 2.5 Page 1 of 69 March, 2014 NAU8401 NAU8401YG Headphones/ Line drivers LINPUT RINPUT AUXOUT2 5-Band Stereo Equalizer Limiter/ Dynamic Range Compressor 3D Audio Effects AUXOUT1 LDAC LHP Output Mixer RDAC RHP BTL Speaker Digital Audio Interface GPIO PLL I2S LSPKOUT Serial Control Interface PCM 2-wire RSPKOUT SPI PRGREF VDDA LHP RHP VSSA VREF VDDSPK LSPKOUT 32 32 31 31 30 30 29 29 28 28 27 27 26 26 25 25 Pinout n/c 1 24 24 VSSSPK n/c 2 23 23 RSPKOUT GPIO2 3 22 22 AUXOUT2 n/c 4 21 21 AUXOUT1 n/c 5 20 20 RINPUT GPIO3 6 19 19 LINPUT FS 7 18 18 MODE BCLK 8 17 17 SDIO 15 16 14 VDDB SCLK 13 CSB/GPIO1 12 11 MCLK VSSD 10 DACIN VDDC 9 n/c NAU8401YG 32-lead QFN RoHS Part Number Dimension Package Package Material NAU8401YG 5 x 5 mm 32-QFN Pb-Free Datasheet Rev 2.5 Page 2 of 69 March, 2014 NAU8401 Pin Descriptions Pin # Name Type Functionality 1 2 3 4 5 6 n/c n/c GPIO2 n/c n/c GPIO3 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 FS BCLK n/c DACIN MCLK VSSD VDDC VDDB CSB/GPIO1 SCLK SDIO MODE LINPUT RINPUT AUXOUT1 AUXOUT2 RSPKOUT VSSSPK Digital Input Digital Input Supply Supply Supply Digital I/O Digital Input Digital I/O Digital Input Analog Input Analog Input Analog Output Analog Output Analog Output Supply 25 26 LSPKOUT VDDSPK Analog Output Supply 27 28 29 30 31 32 33 VREF VSSA RHP LHP VDDA PRGREF GPAD Reference Supply Analog Output Analog Output Supply Analog Output Bulk Ground Pad Digital Input Digital Output Digital I/O Digital I/O Not internally connected Not internally connected General purpose I/O. Can be used for jack detect. Not internally connected Not internally connected General Purpose I/O. Can be used for jack detect. In 4-wire mode, must be used as output to read register data. Digital Audio DAC and ADC Frame Sync Digital Audio Bit Clock Not internally connected Digital Audio DAC Data Input Master Clock Input Digital Ground Digital Core Supply Digital Buffer (Input/Output) Supply 3-Wire MPU Chip Select or General Purpose I/O 3-Wire MPU Clock Input / 2-Wire MPU Clock Input 3-Wire MPU Data Input / 2-Wire MPU Data I/O Control Interface Mode Selection Pin Left Analog Input Right Analog Input Headphone Ground / Mono Mixed Output / Line Output Headphone Ground / Line Output BTL Speaker Positive Output or Right high current output Speaker Ground (ground pin for RSPKOUT, LSPKOUT, AUXOUT2 and AUXTOUT1 output drivers) BTL Speaker Negative Output or Left high current output Speaker Supply (power supply pin for RSPKOUT, LSPKOUT, AUXOUT2 and AUXTOUT1 output drivers) Decoupling for Midrail Reference Voltage Analog Ground Headphone Positive Output / Line Output Right Headphone Negative Output / Line Output Left Analog Power Supply Programmable buffered DC voltage output Electrical and Thermal pad on underside of device Notes 1. The 32-QFN package includes a bulk ground connection pad on the underside of the device. This bulk ground should be thermally tied to the PCB as much as possible, and electrically tied to the analog ground (VSSA, pin 28). 2. Unused analog input pins should be left as no-connection. 3. Unused digital input pins should be tied to ground. 4. Pins designated as "n/c" (Not Internally Connected) should be left as no-connection Datasheet Rev 2.5 Page 3 of 69 March, 2014 NAU8401 n/c 1 n/c 2 n/c 4 n/c 5 LINPUT n/c 19 9 VDDB 14 VDDC VSSD 13 12 VDDA 31 VSSA 28 VDDSPK 26 VSSSPK 24 Normal -6dB PLL LDAC -1.0X AUX1 MIXER RDAC GPIO3 FS 6 AUDIO INTERFACE (PCM/IIS) 8 MCLK SCLK SDIO MODE GPIO2 -1.0X +1.5X AUXOUT2 22 Limiter 5 Band EQ 3D 10 30 LHP RMAIN MIXER 11 RDAC CSB/GPIO1 Σ LMIX AUXOUT1 21 LMAIN MIXER 7 BCLK DACIN Σ LDAC +1.5X 15 Σ CONTROL LOGIC & REGISTERS 16 RMIX 29 LMIX LDAC Σ 17 18 CONTROL INTERFACE (2-, 3- and 4-wire) 27 VDDA -1.0X AUX2 MIXER Σ +1.5X R 27 VREF Programmable Voltage 32 PRGREF RMIX 20 LSPKOUT 25 -1.0X +1.5X R RSPKOUT 23 RSPK SUBMIXER RINPUT Figure 1: NAU8401 Block Diagram Datasheet Rev 2.5 RHP Page 4 of 69 March, 2014 NAU8401 Table of Contents 1 2 3 GENERAL DESCRIPTION .............................................................................................................................10 POWER SUPPLY .............................................................................................................................................12 INPUT PATH DETAILED DESCRIPTION ....................................................................................................13 3.1 3.2 4 Analog Input Impedance and Variable Gain Stage Topology .....................................................................13 Programmable Reference Voltage Controls ...............................................................................................14 DAC DIGITAL BLOCK ..................................................................................................................................15 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5 DAC Soft Mute ...........................................................................................................................................15 DAC AutoMute ...........................................................................................................................................15 DAC Sampling / Oversampling Rate, Polarity Control, Digital Passthrough ...............................................15 DAC Digital Volume Control and Update Bit Functionality .........................................................................16 DAC Automatic Output Peak Limiter / Volume Boost .................................................................................16 5-Band Equalizer ........................................................................................................................................17 3D Stereo Enhancement ............................................................................................................................18 DAC Output A-law and µ-law Expansion ...................................................................................................19 8-bit Word Length .......................................................................................................................................19 ANALOG OUTPUTS .......................................................................................................................................20 5.1 5.2 5.3 5.4 5.5 5.6 6 Main Mixers (LMAIN MIX and RMAIN MIX)................................................................................................20 Auxiliary Mixers (AUX1 MIXER and AUX2 MIXER) ....................................................................................21 Right Speaker Submixer ............................................................................................................................21 Headphone Outputs (LHP and RHP) .........................................................................................................22 Speaker Outputs ........................................................................................................................................23 Auxiliary Outputs ........................................................................................................................................24 MISCELLANEOUS FUNCTIONS ..................................................................................................................24 6.1 6.2 6.3 7 Slow Timer Clock .......................................................................................................................................24 General Purpose Inputs and Outputs (GPIO1, GPIO2, GPIO3) and Jack Detection ..................................25 Automated Features Linked to Jack Detection ...........................................................................................25 CLOCK SELECTION AND GENERATION ..................................................................................................26 7.1 7.2 8 Phase Locked Loop (PLL) General Description .........................................................................................27 CSB/GPIO1 as PLL output .........................................................................................................................28 CONTROL INTERFACES ...............................................................................................................................29 8.1 8.2 8.3 8.4 8.5 8.6 8.7 8.8 8.9 8.10 8.11 9 Software Reset ...........................................................................................................................................29 Selection of Control Mode ..........................................................................................................................29 2 2-Wire-Serial Control Mode (I C Style Interface) ........................................................................................29 2-Wire Protocol Convention........................................................................................................................30 2-Wire Write Operation ...............................................................................................................................31 2-Wire Read Operation ..............................................................................................................................32 SPI Control Interface Modes ......................................................................................................................33 SPI 3-Wire Write Operation ........................................................................................................................33 SPI 4-Wire 24-bit Write and 32-bit Read Operation...................................................................................33 SPI 4-Wire Write Operation ......................................................................................................................34 SPI 4-Wire Read Operation ........................................................................................................................35 DIGITAL AUDIO INTERFACES ...................................................................................................................36 9.1 9.2 9.3 9.4 Right-Justified Audio Data ..........................................................................................................................36 Left-Justified Audio Data ............................................................................................................................37 2 I S Audio Data ............................................................................................................................................37 PCM A Audio Data .....................................................................................................................................38 Datasheet Rev 2.5 Page 5 of 69 March, 2014 NAU8401 9.5 9.6 9.7 9.8 10 PCM B Audio Data .....................................................................................................................................38 PCM Time Slot Audio Data.........................................................................................................................39 Control Interface Timing .............................................................................................................................40 Audio Interface Timing: ..............................................................................................................................42 APPLICATION INFORMATION....................................................................................................................43 10.1 10.2 10.3 10.4 11 12 APPENDIX A: DIGITAL FILTER CHARACTERISTICS ............................................................................49 APPENDIX B: COMPANDING TABLES .....................................................................................................52 12.1 12.2 13 14 15 16 Typical Application Schematic ....................................................................................................................43 Recommended power up and power down sequences ..............................................................................44 Power Consumption ...................................................................................................................................47 Supply Currents of Specific Blocks .............................................................................................................48 µ-Law / A-Law Codes for Zero and Full Scale ............................................................................................52 µ-Law / A-Law Output Codes (Digital mW).................................................................................................52 APPENDIX C: DETAILS OF REGISTER OPERATION ..............................................................................53 APPENDIX D: REGISTER OVERVIEW .......................................................................................................66 PACKAGE DIMENSIONS ..............................................................................................................................67 ORDERING INFORMATION .........................................................................................................................68 Datasheet Rev 2.5 Page 6 of 69 March, 2014 NAU8401 Electrical Characteristics Conditions: VDDC = 1.8V, VDDA = VDDB = VDDSPK = 3.3V, MCLK = 12.288MHz, TA = +25°C, 1kHz signal, fs = 48kHz, 24-bit audio data, unless otherwise stated. Parameter Symbol Comments/Conditions Digital to Analog Converter (DAC) driving RHP / LHP with 10kΩ / 50pF load Full scale output 1 Signal-to-noise ratio SNR A-weighted Total harmonic distortion 2 THD+N RL = 10kΩ; full-scale signal Channel separation 1kHz signal Power supply rejection ratio PSRR (50Hz - 22kHz) Speaker Output (RSPKOUT / LSPKOUT with 8Ω bridge-tied-load) Full scale output 3 SPKBST = 1 VDDSPK = VDDA SPKBST = 0 VDDSPK = VDDA * 1.5 Total harmonic distortion 2 THD+N Po = 320mW, VDDSPK=3.3V Po = 400mW, VDDSPK = 3.3V Po = 860mW, VDDSPK = 5.0V Po = 1000mW, VDDSPK = 5.0V Signal-to-noise ratio SNR VDDSPK = 3.3V Power supply rejection ratio PSRR (50Hz - 22kHz) Maximum programmable gain Minimum programmable gain Programmable gain step size Guaranteed monotonic Mute attenuation 1kHz full scale signal Headphone Output (RHP / LHP with 32Ω load) 0dB full scale output voltage Signal-to-noise ratio SNR A-weighted Total harmonic distortion 2 THD+N RL = 16Ω, Po = 20mW, VDDA = 3.3V RL = 32Ω, Po = 20mW, VDDA = 3.3V Maximum programmable gain Minimum programmable gain Programmable gain step size Guaranteed monotonic Mute attenuation 1kHz full scale signal AUXOUT1 / AUXOUT2 with 10kΩ / 50pF load Full scale output 3 AUX1BST = 1 AUX2BST = 1 VDDSPK = VDDA AUX1BST = 0 AUX2BST = 0 VDDSPK = VDDA * 1.5 Signal-to-noise ratio SNR Total harmonic distortion 2 THD+N Channel separation 1kHz signal Power supply rejection ratio PSRR (50Hz - 22kHz) Datasheet Rev 2.5 Page 7 of 69 Min 88 Typ Max Units VDDA / 3.3 94 -84 99 53 Vrms dB dB dB dB VDDA / 3.3 Vrms (VDDA / 3.3) * 1.5 Vrms -64 dB -60 dB -60 dB -34 dB 91 81 dB dB +6 -57 1 85 dB dB dB dB VDDA / 3.3 92 80 Vrms dB dB 85 dB +6 -57 1 85 dB dB dB dB VDDA / 3.3 Vrms (VDDA / 3.3) * 1.5 Vrms 87 -83 99 53 dB dB dB dB March, 2014 NAU8401 Electrical Characteristics, cont’d. Conditions: VDDC = 1.8V, VDDA = VDDB = VDDSPK = 3.3V, MCLK = 12.288MHz, TA = +25°C, 1kHz signal, fs = 48kHz, 24-bit audio data, unless otherwise stated. Parameter Symbol Line Level Analog Inputs (LINPUT, RINPUT) Full scale input signal 1 Input resistance Comments/Conditions Min Typ Gain = 0dB Vrms dBV 20 40 159 10 kΩ kΩ kΩ pF 0.50, 0.60,0.65, 0.70, 0.75, 0.85, or 0.90 3 14 VDDA VDDA mA nV/√Hz Input capacitance Output current Output noise voltage Digital Input/Output Input HIGH level IPRGREF Vn See Figure 3 1kHz to 20kHz VIL 0.7 * VDDB Input LOW level VIH Output HIGH level VOH ILoad = 1mA Output LOW level VOL ILoad = -1mA 3. V 0.3 * VDDB Input capacitance Notes 1. 2. Units 1.0 0 Aux direct-to-out path, only Input gain = +6.0dB Input gain = 0.0dB Input gain = -12dB PRGREF programmable reference voltage Output voltage VPRGREF Max 0.9 * VDDB V 0.1 * VDDB 10 Full Scale is relative to the magnitude of VDDA and can be calculated as FS = VDDA/3.3. Distortion is measured in the standard way as the combined quantity of distortion products plus noise. The signal level for distortion measurements is at 3dB below full scale, unless otherwise noted. With default register settings, VDDSPK should be 1.5xVDDA (but not exceeding maximum recommended operating voltage) to optimize available dynamic range in the AUXOUT1 and AUXOUT2 line output stages. Output DC bias level is optimized for VDDSPK = 5.0Vdc (boost mode) and VDDA = 3.3Vdc. Datasheet Rev 2.5 Page 8 of 69 V March, 2014 V pF NAU8401 Absolute Maximum Ratings Condition Min Max Units VDDB, VDDC, VDDA supply voltages -0.3 +3.61 V VDDSPK supply voltage (default register configuration) -0.3 +5.80 V VDDSPK supply voltage (optional low voltage configuration) -0.3 +3.61 V Core Digital Input Voltage range VSSD – 0.3 VDDC + 0.30 V Buffer Digital Input Voltage range VSSD – 0.3 VDDB + 0.30 V Analog Input Voltage range VSSA – 0.3 VDDA + 0.30 V Industrial operating temperature -40 +85 °C Storage temperature range -65 +150 °C CAUTION: Do not operate at or near the maximum ratings listed for extended periods of time. Exposure to such conditions may adversely influence product reliability and result in failures not covered by warranty. Operating Conditions Condition Symbol Min Digital supply range (Core) VDDC Digital supply range (Buffer) Analog supply range Speaker supply required: SPKBST=AUX1BST=AUX2BST = 0 Speaker supply if any: SPKBST, AUX1BST, or AUX2BST = 1 Ground Max Units 1.65 3.60 V VDDB 1.65 3.60 V VDDA 2.50 3.60 V VDDSPK 2.50 5.50 V VDDSPK 2.50 3.60 V VSSD VSSA VSSSPK Typical 0 V 1. VDDA must be ≥ VDDC. 2. VDDB must be ≥ VDDC. Datasheet Rev 2.5 Page 9 of 69 March, 2014 NAU8401 1 General Description The NAU8401 is a stereo device with identical left and right channels that share common support elements. Additionally, the right channel auxiliary output path includes a dedicated submixer that supports mixing the right auxiliary input directly into the right speaker output driver. This enables the right speaker channel to output audio that is not present on any other output. 1.1.1 Analog Inputs The left and right analog inputs have available analog input gain conditioning of -15dB through +6dB in 3dB steps. These inputs include individual muting functions with excellent channel isolation and off-isolation, and are suitable for full quality, high bandwidth signals. 1.1.2 Analog Outputs There are six high current analog audio outputs. These are very flexible outputs that can be used individually or in stereo pairs for a wide range of end uses. However, these outputs are optimized for specific functions and are described in this section using the functional names that are applicable to those optimized functions. Each output receives its signal source from built-in analog output mixers. These mixers enable a wide range of signal combinations, including muting of all sources. Additionally, each output has a programmable gain function, output mute function, and output disable function. The RHP and LHP headphone outputs are optimized for driving a stereo pair of headphones, and are powered from the main analog voltage supply rail, VDDA. These outputs may be coupled using traditional DC blocking series capacitors. Alternatively, these may be configured in a no-capacitor DC coupled design using a virtual ground at ½ VDDA provided by an AUXOUT analog output operating in the non-boost output mode. The AUXOUT1 and AUXOUT2 analog outputs are powered from the VDDSPK supply rail and VSSSPK ground return path. The supply rail may be the same as VDDA, or may be a separate voltage up to 5.5Vdc. This higher voltage enables these outputs to have an increased output voltage range and greater output power capability. The RSPKOUT and LSPKOUT loudspeaker outputs are powered from the VDDSPK power supply rail and VSSGND ground return path. LSPKOUT receives its audio signal via an additional submixer. This submixer supports combining a traditional alert sound (from the RINPUT input) with the right channel headphone output mixer signal. This submixer also provides the signal invert function that is necessary for the normal BTL (Bridge Tied Load) configuration used to drive a high power external loudspeaker. Alternatively, each loudspeaker output may be used individually as a separate high current analog output driver. Datasheet Rev 2.5 Page 10 of 69 March, 2014 NAU8401 1.1.3 DAC and Digital Signal Processing Each left and right channel has an independent high quality DAC associated with it. These are high performance, 24-bit delta-sigma converters that are suitable for a very wide range of applications. The DAC functions are each individually supported by powerful analog mixing and routing. The DAC blocks are also supported by advanced digital signal processing subsystems that enable a very wide range of programmable signal conditioning and signal optimizing functions. All digital processing is with 24-bit precision, as to minimize processing artifacts and maximize the audio dynamic range supported by the NAU8401. The DACs are supported by a programmable limiter/DRC (Dynamic Range Compressor). This is useful to optimize the output level for various applications and for use with small loudspeakers. This is an optional feature that may be programmed to limit the maximum output level and/or boost an output level that is too small. Digital signal processing is also provided for a 3D Audio Enhancement function, and for a 5-Band Equalizer. These features are optional, and are programmable over wide ranges. This pair of digital processing features may be applied jointly to the DAC audio path, or be jointly disabled from the DAC audio path. 1.1.4 Programmable Voltage Reference The filtered Vref pin is buffered and scaled to create a low-noise programmable DC output voltage. This output may be used for a wide range of purposes, such as providing a DC bias for other amplifiers and components in the system. 1.1.5 Digital Interfaces Command and control of the device is accomplished using a 2-wire/3-wire/4-wire serial control interface. This is a simple, but highly flexible interface that is compatible with many commonly used command and control serial data protocols and host drivers. Digital audio input/output data streams are transferred to and from the device separately from command and control. The digital audio data interface supports either I2S or PCM audio data protocols, and is compatible with commonly used industry standard devices that follow either of these two serial data formats. 1.1.6 Clock Requirements The clocking signals required for the audio signal processing, audio data I/O, and control logic may be provided externally, or by optional operation of a built-in PLL (Phase Locked Loop). An external master clock (MCLK) signal must be active for analog audio logic paths to align with control register updates, and is required as the reference clock input for the PLL, if the PLL is used. The PLL is provided as a low cost, zero external component count optional method to generate required clocks in almost any system. The PLL is a fractional-N divider type design, which enables generating accurate desired audio sample rates derived from a very wide range of commonly available system clocks. The frequency of the system clock provided as the PLL reference frequency may be any stable frequency in the range between 8MHz and 33MHz. Because the fractional-N multiplication factor is a very high precision 24-bit value, any desired sample rate supported by the NAU8401 can be generated with very high accuracy, typically limited by the accuracy of the external reference frequency. Reference clocks and sample rates outside of these ranges are also possible, but may involve performance tradeoffs and increased design verification. Datasheet Rev 2.5 Page 11 of 69 March, 2014 NAU8401 2 Power Supply This device has been designed to operate reliably using a wide range of power supply conditions and poweron/power-off sequences. There are no special requirements for the sequence or rate at which the various power supply pins change. Any supply can rise or fall at any time without harm to the device. However, pops and clicks may result from some sequences. Optimum handling of hardware and software power-on and power-off sequencing is described in more detail in the Applications section of this document. 2.1.1 Power-On Reset The NAU8401 does not have an external reset pin. The device reset function is automatically generated internally when power supplies are too low for reliable operation. The internal reset is generated any time that either VDDA or VDDC is lower than is required for reliable maintenance of internal logic conditions. The reset threshold voltage for VDDA and VDDC is approximately 0.5Vdc. If both VDDA and VDDC are being reduced at the same time, the threshold voltage may be slightly lower. Note that these are much lower voltages than are required for normal operation of the chip. These values are mentioned here as general guidance as to overall system design. If either VDDA or VDDC is below its respective threshold voltage, an internal reset condition is asserted. During this time, all registers and controls are set to the hardware determined initial conditions. Software access during this time will be ignored, and any expected actions from software activity will be invalid. When both VDDA and VDDC reach a value above their respective thresholds, an internal reset pulse is generated which extends the reset condition for an additional time. The duration of this extended reset time is approximately 50 microseconds, but not longer than 100 microseconds. The reset condition remains asserted during this time. If either VDDA or VDDC at any time becomes lower than its respective threshold voltage, a new reset condition will result. The reset condition will continue until both VDDA and VDDC again higher than their respective thresholds. After VDDA and VDDC are again both greater than their respective threshold voltage, a new reset pulse will be generated, which again will extend the reset condition for not longer than an additional 100 microseconds. 2.1.2 Power Related Software Considerations There is no direct way for software to determine that the device is actively held in a reset condition. If there is a possibility that software could be accessing the device sooner than 100 microseconds after the VDDA and VDDC supplies are valid, the reset condition can be determined indirectly. This is accomplished by writing a value to any register other than register 0x00, with that value being different than the power-on reset initial values. The optimum choice of register for this purpose may be dependent on the system design, and it is recommended the system engineer choose the register and register test bit for this purpose. After writing the value, software will then read back the same register. When the register test bit reads back as the new value, instead of the power-on reset initial value, software can reliably determine that the reset condition has ended. Although it is not required, it is strongly recommended that a Software Reset command should be issued after power-on and after the power-on reset condition is ended. This will help insure reliable operation under every power sequencing condition that could occur. If there is any possibility that VDDA or VDDC could be unreliable during system operation, software may be designed to monitor whether a power-on reset condition has happened. This can be accomplished by writing a test bit to a register that is different from the power-on initial conditions. This test bit should be a bit that is never used for any other reason, and does not affect desired operation in any way. Then, software at any time can read this bit to determine if a power-on reset condition has occurred. If this bit ever reads back other than the test value, then software can reliably know that a power-on reset event has occurred. Software can subsequently re-initialize the device and the system as required by the system design. 2.1.3 Software Reset All chip registers can be reset to power-on default conditions by writing any value to register 0, using any of the control modes. Writing valid data to any other register disables the reset, but all registers need to have the correct operating data written. See the applications section on powering NAU8401 up for information on avoiding pops and clicks after a software reset. Datasheet Rev 2.5 Page 12 of 69 March, 2014 NAU8401 3 Input Path Detailed Description The NAU8401 provides two analog inputs that are buffered, scaled, optionally muted, and then made available to the output mixers. The output mixers enable a wide range of possible routing of these inputs to the analog output pins, as well as mixing with the output signal from the DAC subsystem. These inputs are maintained at a DC bias at approximately ½ of the AVDD supply voltage. Connections to these inputs should be AC-coupled by means of DC blocking capacitors suitable for the device application. If not used, these input pins should not be left not-connected and muted in the software register controls. The RINPUT signal may additionally be routed to the Right Speaker Submixer in the analog output section. This path enables a sound to be output from the LSPKOUT speaker output, but without being audible anywhere else in the system. One purpose of this path is to support a traditional “beep” sound, such as from a microprocessor toggle bit. This is a historical application scenario which is now uncommon. These inputs are affected by the following registers: LMAIN MIXER or RMAIN MIXER if used (see output mixer section) RSPK SUBMIXER if used (see Right Speaker Submixer section) 3.1 Analog Input Impedance and Variable Gain Stage Topology Each analog input pin is supported by the circuit shown here as a simplified schematic. The gain value changes affect input impedance as detailed in this section. If a path is in the “not selected” condition, then the input impedance will be in a high impedance condition and the input signal will be muted. If an external input pin is not used anywhere in the system, it will be coupled to a DC tie-off of approximately 30kΩ coupled to VREF. The unused input tie-off function is explained in more detail in the Application Information section of this document. Gain Value Adjustment “Not Selected” Switch R Input R To Next Stage VREF -15 dB to +6.0 dB Figure 2: Variable Gain Stage Simplified Schematic The input impedance presented to these inputs depends on the input routing choices and gain values. The nominal resistive input impedances presented to signal pins that are directly routed to an output mixer are listed in the following table. The RINPUT signal may also be connected to the Right Speaker Submixer. If both RINPUT signal paths are connected, then the RINPUT input impedance will be the parallel combination of the two paths. Inputs LINPUT & RINPUT to bypass amp Or RINPUT to RSPK SUBMIXER amp Gain (dB) -15 -12 -9 -6 -3 0 3 6 Impedance (kΩ) 225 159 113 80 57 40 28 20 Table 1: Analog Input and RSPK SUBMIXER Input Impedances Datasheet Rev 2.5 Page 13 of 69 March, 2014 NAU8401 3.2 Programmable Reference Voltage Controls The PRGREF pin provides a low-noise DC bias voltage as may be required for other elements in the audio subsystem. This built-in feature can typically provide up to 3mA of bias current. This DC bias voltage is also suitable for powering either traditional ECM (electret) type microphones, or for MEMS types microphones with an independent power supply pin. Seven different bias voltages are available for optimum system performance, depending on the specific application. The bias pin normally requires an external filtering capacitor as shown on the schematic in the Application section. The programmable voltage bias function is controlled by the following registers: R1 Power control for PRGREF feature (enabled when bit 4 = 1) R44 Optional low-noise mode and different bias voltage levels (enabled when bit 0 = 1) R44 Primary PRGREF voltage selection The low-noise feature results in greatly reduced noise in the external PRGREF voltage by placing a resistor of approximately 200-ohms in series with the output pin. This creates a low pass filter in conjunction with the external reference voltage filter capacitor, but without any additional external components. The low noise feature is enabled when the mode control bit 0 in register R40 is set (level = 1) VREF Register 40, bit 0 PRGREFM Register 1, bit 4 PRGREFEN MICBIAS R R Register 44, bits 7-8 PRGREFV Register 44, Bits 7-8 00 Register 44, Bit 0 0 Output DC Bias Voltage 0.90 * VDDA 01 0 0.65 * VDDA 10 0 0.75 * VDDA 11 0 0.50 * VDDA 00 1 0.85 * VDDA 01 1 0.60 * VDDA 10 1 0.70 * VDDA 11 1 0.50 * VDDA Figure 3: Programmable Reference Bias Generator Datasheet Rev 2.5 Page 14 of 69 March, 2014 NAU8401 4 DAC Digital Block DAC Digital Filters Digital Audio Interface Digital Gain 5-Band Equalizer 3D Digital Peak Limiter ΣΔ DAC Digital Filter The DAC digital block uses 24-bit signal processing to generate analog audio with a 16-bit digital sample stream input. This block consists of a sigma-delta modulator, digital decimator/filter, and optional 5-band graphic equalizer/3D effects block, and a dynamic range compressor/limiter. The DAC coding scheme is in twos complement format and the full-scale output level is proportional to VDDA. With a 3.3V supply voltage, the full-scale output level is 1.0VRMS. Registers that affect the DAC operation are: R3 Power management enable/disable left/right DAC R7 Sample rate indication bits (affect filter frequency scaling) R10 Softmute, Automute, oversampling options, polarity controls for left/right DAC R11 Left channel DAC digital volume value; update bit feature R12 Right channel DAC digital volume value; update bit feature 4.1 DAC Soft Mute Both DACs are initialized with the SoftMute function disabled, which is a shared single control bit. Softmute automatically ramps the DAC digital volume down to zero volume when enabled, and automatically ramps the DAC digital volume up to the register specified volume level for each DAC when disabled. This feature provides a tool that is useful for using the DACs without introducing pop and click sounds. 4.2 DAC AutoMute The analog output of both DACs can be automatically muted in a no signal condition. Both DACs share a single control bit for this function. When automute is enabled, the analog output of the DAC will be muted any time there are 1024 consecutive audio sample values with a zero value. If at any time there is a non-zero sample value, the DAC will be un-muted, and the 1024 count will be reinitialized to zero. 4.3 DAC Sampling / Oversampling Rate, Polarity Control, Digital Passthrough The sampling rate of the DAC is determined entirely by the frequency of its input clock and the oversampling rate setting. The oversampling rate of the DAC can be changed to 128X for improved audio performance at slightly higher power consumption. Because the additional supply current is only 1mA, in most applications the 128X oversampling is preferred for maximum audio performance. The polarity of either DAC output signal can be changed independently on either DAC analog output as a feature sometimes useful in management of the audio phase. This feature can help minimize any audio processing that may be otherwise required as the data are passed to other stages in the system. Datasheet Rev 2.5 Page 15 of 69 March, 2014 NAU8401 4.4 DAC Digital Volume Control and Update Bit Functionality The effective output audio volume of each DAC can be changed using the digital volume control feature. This processes the output of the DAC to scale the output by the amount indicated in the volume register setting. Included is a “digital mute” value which will completely mute the signal output of the DAC. The digital volume setting can range from 0dB through -127dB in 0.5dB steps. Important: The R11 and R12 update bits are write-only bits. The primary intended purpose of the update bit is to enable simultaneous changes to both the left and right DAC volume values, even though these values must be written sequentially. When there is a write operation to either R11 or R12 volume settings, but the update bit is not set (value = 0), the new volume setting is stored as pending for the future, but does not go into effect. When there is a write operation to either R11 or R12 and the update bit is set (value = 1), then the new value in the register being written is immediately put into effect, and any pending value in the other DAC volume register is put into effect at the same time. 4.5 DAC Automatic Output Peak Limiter / Volume Boost Both DACs are supported by a digital output volume limiter/boost feature which can be useful to keep output levels within a desired range without any host/processor intervention. Settings are shared by both DAC channels. Registers that manage the peak limiter and volume boost functionality are: R24 Limiter enable/disable, limiter attack rate, boost decay rate R25 Limiter upper limit, limiter boost value The operation of the peak limiter is shown in the following figure. The upper signal graphs show the time varying level of the input and output signals, and the lower graph shows the gain characteristic of the limiter. When the signal level exceeds the limiter threshold value by 0.5dB or greater, the DAC digital signal level will be attenuated at a rate set by the limiter attack rate value. When the input signal level is less than the boost lower limit by 0.5dB or greater, the DAC digital volume will be increased at a rate set by the boost decay rate value. The default boost gain value is limited not to exceed 0dB (zero attenuation). DAC Input Signal Envelope DAC Output Signal Envelope Threshold -1dB 0dB -0.5dB -1dB Digital Gain Figure 4: DAC Digital Limiter Control The limiter may optionally be set to automatically boost the DAC digital signal level when the signal is more than 0.5dB below the limiter threshold. This can be useful in applications in which it is desirable to compress the signal dynamic range. This is accomplished by setting the limiter boost register bits to a value greater than zero. If the limiter is disabled, this boost value will be applied to the DAC digital output signal separate from other gain affecting values. Datasheet Rev 2.5 Page 16 of 69 March, 2014 NAU8401 4.6 5-Band Equalizer The NAU8401 includes a 5-band graphic equalizer with low distortion, low noise, and wide dynamic range. The equalizer is applied to both left and right channels. The equalizer is grouped with the 3D Stereo Enhancement signal processing function. These functions are applied to the DAC output signals, only, and do not affect the LINPUT and RINPUT analog input signals. Registers that affect operation of the 5-Band Equalizer are: R18 R18 R19 R20 R21 R22 Enable / Disable Equalizer function Band 1 gain control and cut-off frequency Band 2 gain control, center cut-off frequency, and bandwidth Band 3 gain control, center cut-off frequency, and bandwidth Band 4 gain control, center cut-off frequency, and bandwidth Band 5 gain control and cut-off frequency Each of the five equalizer bands is independently adjustable for maximum system flexibility, and each offers up to 12dB of boost and 12dB of cut with 1dB resolution. The high and the low bands are shelving filters (highpass and low-pass, respectively), and the middle three bands are peaking filters. Details of the register value settings are described below. Response curve examples are provided in the Appendix of this document. Register Value 00 01 10 11 1 (High Pass) Register 18 Bits 5 & 6 EQ1CF 80Hz 105Hz 135Hz 175Hz 2 (Band Pass) Register 19 Bits 5 & 6 EQ2CF 230Hz 300Hz 385Hz 500Hz Equalizer Band 3 (Band Pass) Register 20 Bits 5 & 6 EQ3CF 650Hz 850Hz 1.1kHz 1.4kHz 4 (Band Pass) Register 21 Bits 5 & 6 EQ4CF 1.8kHz 2.4kHz 3.2kHz 4.1kHz 5 (Low Pass) Register 22 Bits 5 & 6 EQ5CF 5.3kHz 6.9kHz 9.0kHz 11.7kHz Table 2: Equalizer Center/Cutoff Frequencies Register Value Binary Hex 00000 00h 00001 01h 00010 02h ---01100 0Ch 01101 17h ---11000 18h 11001 to 11111 19h to 1Fh Gain Registers +12db +11dB +10dB Increments 1dB per step 0dB -11dB Increments 1dB per step -12dB Reserved Bits 0 to 4 in registers 18 (EQ1GC) 19 (EQ2GC) 20 (EQ3GC) 21 (EQ4GC) 22 (EQ5GC) Table 3: Equalizer Gains Datasheet Rev 2.5 Page 17 of 69 March, 2014 NAU8401 4.7 3D Stereo Enhancement NAU8401 includes digital circuitry to provide flexible 3D enhancement to increase the perceived separation between the right and left channels, and has multiple options for optimum acoustic performance. The equalizer is grouped with the 3D Stereo Enhancement signal processing function. Both functions may be assigned jointly to support the DAC audio output path, or may be jointly disabled from the DAC audio output path. Registers that affect operation of 3D Stereo Enhancement are: R18 Enable / Disable 3D enhancement function R41 3D Audio depth enhancement setting The amount of 3D enhancement applied can be programmed from the default 0% (no 3D effect) to 100% in register 41, bits 0 to 3 (DEPTH3D), as shown in the following table. Note: 3D enhancement uses increased gain to achieve its effect, so that the source signal may need to be attenuated by up to 6dB to avoid clipping distortion. Register 41 Bits 0 to 3 3DDEPTH 3D Effect 0000 0001 0% 6.7%dB 0010 13.4%dB --- Increments 6.67% for each binary step in the input word 1110 1111 93.3% 100% Table 4: 3D Enhancement Depth Datasheet Rev 2.5 Page 18 of 69 March, 2014 NAU8401 4.8 DAC Output A-law and µ -law Expansion Companding (compression | expansion) is used in digital communication systems to optimize signal-to-noise ratios with reduced data bit rates, using non-linear algorithms. NAU8401 supports the two main telecommunications expansion standards on the DAC path receive side: A-law and µ-law. The A-law algorithm is primarily used in European communication systems and the µ -law algorithm is primarily used by North America, Japan, and Australia. On the sending side of a telecommunications system, audio is converted from a linear dynamic range of approximately 13 bits (µ -law) or 12 bits (A-law) into a compressed 8-bit format using non-linear quantization. The compressed signal is an 8bit word containing sign (1-bit), exponent (3-bits) and mantissa (4-bits). The DAC can then convert the compressed back into the original 13-bit or 12-bit linear audio format. The register affecting companding operation is: R5 Enable 8-bit mode, enable DAC expansion Following are the data compression equations set in the ITU-T G.711 standard and implemented in the NAU8401: 4.8.1 µ law F(x) = ln( 1 + µ|x|) / ln( 1 + µ) -1 ≤ x ≤ 1 with µ=255 for the U.S. and Japan 4.8.2 A-law with A=87.6 for Europe The companded signal is an 8-bit word consisting of a sign bit, three bits for the exponent, and four bits for the mantissa. When companding is enabled, the PCM interface must be set to an 8-bit word length. When in 8-bit mode, the Register 4 word length control (WLEN) is ignored. Companding Mode No Companding (default) DAC A-law μ-law Bit 4 0 1 1 Register 5 Bit3 Bit 2 0 0 Bit 1 0 1 0 Table 5: Companding Control 4.9 8-bit Word Length Writing a 1 to register 5, bit 5 (CMB8), will cause the PCM interface to use 8-bit word length for data transfer, overriding the word length configuration setting in WLEN (register 4, bits 5 and 6.). Datasheet Rev 2.5 Page 19 of 69 March, 2014 NAU8401 5 Analog Outputs The NAU8401 features six different analog outputs. These are highly flexible and may be used individually or in pairs for many purposes. However, they are grouped in pairs and named for their most commonly used stereo application end uses. The following sections detail key features and functions of each type of output. Included is a description of the associated output mixers. These mixers are separate internal functional blocks that are important toward understanding all aspects of the analog output section. Important: For analog outputs depopping purpose, when powering up speakers, headphone, AUXOUTs, certain delays are generated after enabling sequence. However, the delays are created by MCLK and sample rate register. For correct operation, sending I2S signal no earlier than 250ms after speaker or headphone enabled and MCLK appearing. 5.1 Main Mixers (LMAIN MIX and RMAIN MIX) Each left and right channel is supported by an independent main mixer. This mixer combines signals from a various available signal sources internal to the device. Each mixer may also be selectively enabled/disabled as part of the power management features. The outputs of these mixers are the only signal source for the headphone outputs, and the primary signal source for the loudspeaker outputs. Each mixer can accept either or both the left and right digital to analog (DAC) outputs. Normally, the left and right DAC is mixed into the associated left and right main output mix. This additional capability to mix opposite DAC channels enables switching the left and right DAC outputs to the opposite channel, or mixing together the left and right DAC signals – all without any processor or host intervention and processing overhead. Each mixer also can also combine signals directly from the respective left or right line input (LINPUT and RINPUT). Each of these analog input paths may be muted, or have an applied selectable gain between -15dB and +6dB in 3dB steps. Registers that affect operation of the Main Mixers are: R3 R49 R50 R51 R50 R51 Power control for the left and right main mixer left and right DAC cross-mixing source selection options left DAC to left main mixer source selection option right DAC to right main mixer source selection option left mixer source select, and gain settings right mixer source select, and gain settings Datasheet Rev 2.5 Page 20 of 69 March, 2014 NAU8401 5.2 Auxiliary Mixers (AUX1 MIXER and AUX2 MIXER) Each auxiliary analog output channel is supported by an independent mixer dedicated to the auxiliary output function. This mixer combines signals from a various available signal sources internal to the device. Each mixer may also be selectively enabled/disabled as part of the power management features. Unlike the main mixers, the auxiliary mixers are not identical and combine different signal sets internal to the device. These mixers in conjunction with the auxiliary outputs greatly increase the overall capabilities and flexibility of the NAU8401. The AUX1 mixer combines together any or all of the following: Left Main Mixer output Right Main Mixer output Left DAC output Right DAC output The AUX2 mixer combines together any or all of the following: Left Main Mixer output Left DAC output Output from AUX1 mixer stage Registers that affect operation of the Auxiliary Mixers are: R1 Power control for the left and right auxiliary mixer R56 Signal source selection for the AUX2 mixer R57 Signal source selection for the AUX1 mixer 5.3 Right Speaker Submixer The right speaker submixer serves two important functions. One is to optionally invert the output from the Right Main Mixer as an optional signal source for the right channel loudspeaker output driver. This inversion is normal and necessary in typical applications using the loudspeaker drivers. The other function of the right speaker submixer is to mix the RINPUT input signal directly into the right channel speaker output driver. This enables the RINPUT signal to be output on the right loudspeaker channel, but not be mixed to any other output. The traditional purpose of this path is to support an old-style beep sound, such as traditionally generated by a microprocessor output toggle bit. On the NAU8401, this traditional function is supported by a full quality signal path that may be used for any purpose. The volume for this path has a selectable gain from -15dB through +6dB in 3dB step increments. There is no separate power management control feature for the Right Speaker Submixer. The register that affects the Right Speaker Submixer is: R43 Input mute controls, volume for RINPUT path Datasheet Rev 2.5 Page 21 of 69 March, 2014 NAU8401 5.4 Headphone Outputs (LHP and RHP) These are high quality, high current output drivers intended for driving low impedance loads such as headphones, but also suitable for a wide range of audio output applications. The only signal source for each of these outputs is from the associated left and right Main Mixer. Power for this section is provided from the VDDA pin. Each driver may be selectively enabled/disabled as part of the power management features. Each output can be individually muted, or controlled over a gain range of -57dB through +6dB in 3dB steps. Gain changes for the two headphone outputs can be coordinated through use of an update bit feature as part of the register controls. Additionally, clicks that could result from gain changes can be suppressed using an optional zero crossing feature. Registers that affect the headphone outputs are: R2 Power management control for the left and right headphone amplifier R52 Volume, mute, update, and zero crossing controls for left headphone driver R53 Volume, mute, update, and zero crossing controls for right headphone driver Important: The R52 and R53 update bits are write-only bits. The primary intended purpose of the update bit is to enable simultaneous changes to both the left and right headphone output volume values, even though these two register values must be written sequentially. When there is a write operation to either R52 or R53 volume settings, but the update bit is not set (value = 0), the new volume setting is stored as pending for the future, but does not go into effect. When there is a write operation to either R52 or R53 and the update bit is set (value = 1), then the new value in the register being written is immediately put into effect, and any pending value in the other headphone output volume register is put into effect at the same time. Zero-Crossing controls are implemented to suppress clicking sounds that may occur when volume setting changes take place while an audio input signal is active. When the zero crossing function is enabled (logic = 1), any volume change for the affected channel will not take place until the audio input signal passes through the zero point in its peak-to-peak swing. This prevents any instantaneous voltage change to the audio signal caused by volume setting changes. If the zero crossing function is disabled (logic = 0), volume changes take place instantly on condition of the Update Bit, but without regard to the instantaneous voltage level of the affected audio input signal. Datasheet Rev 2.5 Page 22 of 69 March, 2014 NAU8401 5.5 Speaker Outputs These are high current outputs suitable for driving low impedance loads, such as an 8-ohm loudspeaker. Both outputs may be used separately for a wide range of applications, however, the intended application is to use both outputs together in a BTL (Bridge-Tied-Load, and also, Balanced-Transformer-Less) configuration. In most applications, this configuration requires an additional signal inversion, which is a feature supported in the right speaker submixer block. This inversion is normal and necessary when the two speaker outputs are used together in a BTL (Bridge-TiedLoad, and also, Balanced-Transformer-Less) configuration. In this physical configuration, the RSPKOUT signal is connected to one pole of the loudspeaker, and the LSPKOUT signal is connected to the other pole of the loudspeaker. Mathematically, this creates within the loudspeaker a signal equal to (Left-Right). The desired mathematical operation for a stereo signal is to drive the speaker with (Left+Right). This is accomplished by implementing an additional inversion to the right channel signal. For most applications, best performance will be achieved when care is taken to insure that all gain and filter settings in both the left and right channel paths to the loudspeaker drivers are identical. Power for the loudspeaker outputs is supplied via the VDDSPK pin, and ground is independently provided as the VSSPK pin. This power option enables an operating voltage as high as 5Vdc and helps in a system design to prevent high current outputs from creating noise on other supply voltage rails or system grounds. VSSPK must be connected at some point in the system to VSSA, but provision of the VSSPK as a separate high current ground pin facilitates managing the flow of current to prevent “ground bounce” and other ground noise related problems. Each loudspeaker output may be selectively enabled/disabled as part of the power management features. Registers that affect the loudspeaker outputs are: R3 Power management control of LSPKOUT and RSPKOUT driver outputs R3 Speaker bias control (BIASGEN) set logic = 1 for maximum power and VDDSPK > 3.60Vdc R48 Driver distortion mode control R49 Disable boost control for speaker outputs for VDDSPK 3.3V or lower R54 Volume (gain), mute, update bit, and zero crossing control for left speaker driver R55 Volume (gain), mute, update bit, and zero crossing control for right speaker driver Important: The R49 boost control option is set in the power-on reset condition for high voltage operation of VDDSPK. If VDDSPK is greater than 3.6Vdc, the R49 boost control bits should be remain at the power-on default settings. This insures reliable operation of the part, proper DC biasing, and optimum scaling of the signal to enable the output to achieve full scale output when VDDSPK is greater than VDDA. In the boost mode, the gain of the output stage is increased by a factor of 1.5 times the normal gain value. Important: The R54 and R55 update bits are write-only bits. The primary intended purpose of the update bit is to enable simultaneous changes to both the left and right headphone output volume values, even though these two register values must be written sequentially. When there is a write operation to either R54 or R55 volume settings, but the update bit is not set (value = 0), the new volume setting is stored as pending for the future, but does not go into effect. When there is a write operation to either R54 or R55 and the update bit is set (value = 1), then the new value in the register being written is immediately put into effect, and any pending value in the other headphone output volume register is put into effect at the same time. Zero-Crossing controls are implemented to suppress clicking sounds that may occur when volume setting changes take place while an audio input signal is active. When the zero crossing function is enabled (logic = 1), any volume change for the affected channel will not take place until the audio input signal passes through the zero point in its peak-to-peak swing. This prevents any instantaneous voltage change to the audio signal caused by volume setting changes. If the zero crossing function is disabled (logic = 0), volume changes take place instantly on condition of the Update Bit, but without regard to the instantaneous voltage level of the affected audio input signal. The loudspeaker drivers may optionally be operated in an ultralow distortion mode. This mode may require additional external passive components to insure stable operation in some system configurations. No external components are required in normal mode speaker driver operation. Distortion performance in normal operation is excellent, and already suitable for almost every application. Datasheet Rev 2.5 Page 23 of 69 March, 2014 NAU8401 5.6 Auxiliary Outputs These are high current outputs suitable for driving low impedance loads such as headphones or line level loads. Power for these outputs is supplied via the VDDSPK pin, and ground is also independently provided as the VSSPK pin. This power option enables an operating voltage as high as 5Vdc and helps in a system design to prevent high current outputs from creating noise on other supply voltage rails or system grounds. VSSPK must be connected at some point in the system to VSSA, but provision of the VSSPK as a separate high current ground pin facilitates managing the flow of current to prevent “ground bounce” and other ground noise related problems. Each auxiliary output driver may be selectively enabled/disabled as part of the power management features. Registers that affect the auxiliary outputs are: R3 Power management control of AUXOUT1 and AUXOUT2 outputs R3 Speaker bias control (BIASGEN) set logic = 1 for maximum power and VDDSPK > 3.60Vdc R49 Disable boost control for AUXOUT1 and AUXOUT2 for VDDSPK 3.3Vdc or lower R56 Mute, gain control, and input selection controls for AUXOUT2 R57 Mute, gain control, and input selection controls for AUXOUT1 Important: The R49 boost control option is set in the power-on reset condition for high voltage operation of VDDSPK. If VDDSPK is greater than 3.6Vdc, the R49 boost control bits should be remain at the power-on default settings. This insures reliable operation of the part, proper DC biasing, and optimum scaling of the signal to enable the output to achieve full scale output when VDDSPK is greater than VDDA. In the boost mode, the gain of the output stage is increased by a factor of 1.5 times the normal gain value. An optional alternative function for these outputs is to provide a virtual ground for an external headphone device. This is for eliminating output capacitors for the headphone amplifier circuit in applications where this type of design is appropriate. In this type of application, the AUXOUT output is typically operated in the muted condition. In the muted condition, and with the output configured in the non-boost mode (also requiring that VDDSPK < 3.61Vdc), the AUXOUT output DC level will remain at the internal VREF level. This the same internal DC level as used by the headphone outputs. Because these DC levels are nominally the same, DC current flowing through the headphone in this mode of operation is minimized. Depending on the application, one or both of the auxiliary outputs may be used in this fashion. 6 Miscellaneous Functions 6.1 Slow Timer Clock An internal Slow Timer Clock is supplied to automatically control features that happen over a relatively periods of time, or time-spans. This enables the NAU8401 to implement long time-span features without any host/processor management or intervention. Two features are supported by the Slow Timer Clock. These are an optional automatic time out for the zerocrossing holdoff of PGA volume changes, and timing for debouncing of the mechanical jack detection feature. If either feature is required, the Slow Timer Clock must be enabled. The Slow Timer Clock is initialized in the disabled state. The Slow Timer Clock is controlled by only the following register: R7 Sample rate indication select, and Slow Timer Clock enable The Slow Timer Clock rate is derived from MCLK using an integer divider that is compensated for the sample rate as indicated by the R7 sample rate register. If the sample rate register value precisely matches the actual sample rate, then the internal Slow Timer Clock rate will be a constant value of 128ms. If the actual sample rate is, for example, 44.1kHz and the sample rate selected in R7 is 48kHz, the rate of the Slow Timer Clock will be approximately 10% slower in direct proportion of the actual vs. indicated sample rate. This scale of difference should not be important in relation to the dedicated end uses of the Slow Timer Clock. Datasheet Rev 2.5 Page 24 of 69 March, 2014 NAU8401 6.2 General Purpose Inputs and Outputs (GPIO1, GPIO2, GPIO3) and Jack Detection Three pins are provided in the NAU8401 that may be used for limited logic input/output functions. GPIO1 has multiple possible functions, and may be either a logic input or logic output. GPIO2 or GPIO3 may be used as logic inputs dedicated to the purpose of jack detection. GPIO3 is used as a logic output in 4-wire SPI mode, and GPIO2 does not have any logic output capability. Only one GPIO can be selected for jack detection. If a GPIO is selected for the jack detection feature, the Slow Timer Clock must be enabled. The jack detection function is automatically “debounced” such that momentary changes to the logic value of this input pin are ignored. The Slow Timer Clock is necessary for the debouncing feature. Registers that control the GPIO functionality are: R8 GPIO functional selection options R9 Jack Detection feature input selection and functional options If a GPIO is selected for the jack detection function, the required Slow Timer Clock determines the duration of the time windows for the input logic debouncing function. Because the logic level changes happen asynchronously to the Slow Timer Clock, there is inherently some variability in the timing for the jack detection function. A continuous and persistent logic change on the GPIO pin used for jack detection will result in a valid internal output signal within 2.5 to 3.5 periods of the Slow Timer Clock. Any logic change of shorter duration will be ignored. The threshold voltage for a jack detection logic-low level is no higher than 1.0Vdc. The threshold voltage for a jack detection logic-high level is no lower than 1.7Vdc. These levels will be reduced as the VDDC core logic voltage pin is reduced below 1.9Vdc. 6.3 Automated Features Linked to Jack Detection Some functionality can be automatically controlled by the jack detection logic. This feature can be used to enable the internal analog amplifier bias voltage generator, and/or enable analog output drivers automatically as a result of detecting a logic change at a GPIO pin assigned to the purpose of jack detection. This eliminates any requirement for the host/processor to perform these functions. The internal analog amplifier bias generator creates the VREF voltage reference and bias voltage used by the analog amplifiers. The ability to control it is a power management feature. This is implemented as a logical “OR” function of either the debounced internal jack detection signal, or the ABIASEN control bit in Register 1. The bias generator will be powered if either of these control signals is enabled (value = 1). Power management control of four different outputs is also optionally and selectively subject to control linked with the jack detection signal. The four outputs that can be controlled this way are the headphone driver signal pair, loudspeaker driver signal pair, AUXOUT1, and AUXOUT2. Register settings determine which outputs may be enabled, and whether they are enabled by a logic 1 or logic 0 value. Output control is a logical “AND” operation of the jack detection controls, and of the register control bits that normally control the outputs. Both controls must be in the “ON” condition for a given output to be enabled. Registers that affect these functions are: R9 GPIO pin selection for jack detect function, jack detection enable, VREF jack enable R13 bit mapped selection of which outputs are to be enabled when jack detect is in a logic 1 state R13 bit mapped selection of which outputs are to be enabled when jack detect is in a logic 0 state Datasheet Rev 2.5 Page 25 of 69 March, 2014 NAU8401 7 Clock Selection and Generation The NAU8401 has two basic clock modes that support the DAC data converters. It can accept external clocks in the slave mode, or in the master mode, it can generate the required clocks from an external reference frequency using an internal PLL (Phase Locked Loop). The internal PLL is a fractional type scaling PLL, and therefore, a very wide range of external reference frequencies can be used to create accurate audio sample rates. Separate from this DAC clock subsystem, audio data are clocked to and from the NAU8401 by means of the control logic described in the Digital Audio Interfaces section. The audio bit rate and audio sample rate for this data flow are managed by the Frame Sync (FS) and Bit Clock (BCLK) pins in the Digital Audio Interface. It is important to understand that the sampling rate for the DAC data converters is not determined by the Digital Audio Interface, and instead, this rate is derived exclusively from the Internal Master Clock (IMCLK). It is therefore a requirement that the Digital Audio Interface and data converters be operated synchronously, and that the FS, BCLK, and IMCLK signals are all derived from a common reference frequency. If these three clocks signals are not synchronous, audio quality will be reduced. The IMCLK is always exactly 256 times the sampling rate of the data converters. IMCLK is output from the Master Clock Prescaler. The prescaler reduces by an integer division factor the input frequency input clock. The source of this input frequency clock is either the external MCLK pin, or the output from the internal PLL Block. Registers that are used to manage and control the clock subsystem are: R1 Power management, enable control for PLL (default = disabled) R6 Master/slave mode, clock scaling, clock selection R7 Sample rate indication (scales DSP coefficients and timing – does NOT affect actual sample rate R8 MUX control and division factor for PLL output on GPIO1 R36 PLL Prescaler, Integer portion of PLL frequency multiplier R37 Highest order bits of 24-bit fraction of PLL frequency multiplier R38 Middle order bits of 24-bit fraction of PLL frequency multiplier R39 Lowest order bits of 24-bit fraction of PLL frequency multiplier In Master Mode, the IMCLK signal is used to generate FS and BCLK signals that are driven onto the FS and BCLK pins and input to the Digital Audio Interface. FS is always IMCLK/256 and the duty cycle of FS is automatically adjusted to be correct for the mode selected in the Digital Audio Interface. The frequency of BCLK may optionally be divided to optimize the bit clock rate for the application scenario. In Slave Mode, there is no connection between IMCLK and the FS and BCLK pins. In this mode, FS and BLCK are strictly input pins, and it is the responsibility of the system designer to insure that FS, BCLK, and IMCLK are synchronous and scaled appropriately for the application. Datasheet Rev 2.5 Page 26 of 69 March, 2014 NAU8401 DAC PLL Prescaler R36[4] Master Clock Prescaler R6[7,6,5] MCLK 0 f1 1 PLL f2=R(f1) f2 fPLL f/4 0 f/N 1 IMCLK = 256fS f/2 Master Clock Select PLL BLOCK R6[8] BCLK Output Scaler f/N f/256 R6[4,3,2] CSB / GPIO1 f/N GPIO1 MUX Control R8[2,1,0] PLL to GPIO1 Output Scaler Master / Slave Select R8[5,4] R6[0] 1 0 FS Digital Audio Interface BCLK Figure 5: PLL and Clock Select Circuit 7.1 Phase Locked Loop (PLL) General Description The PLL may be optionally used to multiply an external input clock reference frequency by a high resolution fractional number. To enable the use of the widest possible range of external reference clocks, the PLL block includes an optional divide-by-two prescaler for the input clock, a fixed divide-by-four scaler on the PLL output, and an additional programmable integer divider that is the Master Clock Prescaler. The high resolution fraction for the PLL is the ratio of the desired PLL oscillator frequency (f 2), and the reference frequency at the PLL input (f1). This can be represented as R = f2/f1, with R in the form of a decimal number: xy.abcdefgh. To program the NAU8401, this value is separated into an integer portion (“xy”), and a fractional portion, “abcdefgh”. The fractional portion of the multiplier is a value that when represented as a 24bit binary number (stored in three 9-bit registers on the NAU8401), very closely matches the exact desired multiplier factor. To keep the PLL within its optimal operating range, the integer portion of the decimal number (“xy”), must be any of the following decimal values: 6, 7, 8, 9, 10, 11, or 12. The input and output dividers outside of the PLL are often helpful to scale frequencies as needed to keep the “xy” value within the required range. Also, the optimum PLL oscillator frequency is in the range between 90MHz and 100MHz, and thus, it is best to keep f 2 within this range. In summary, for any given design, choose:  IMCLK = desired Master Clock = (256)*(desired codec sample rate)  f2 = (4)*(P)(IMCLK), where P is the Master Clock Prescale integer value; optimal f 2: 90MHz< f2 0.546*fs fs -55 Group Delay dB dB 28 1/fs Table 14: DAC Digital Filter Characteristics TERMINOLOGY 1. Stop Band Attenuation (dB) – the degree to which the frequency spectrum is attenuated (outside audio band) 2. Pass-band Ripple – any variation of the frequency response in the pass-band region 3. Note that this delay applies only to the filters and does not include other latencies, such as from the serial data interface Figure 28: DAC Filter Frequency Response Figure 29: DAC Filter Ripple Datasheet Rev 2.5 Page 49 of 69 March, 2014 NAU8401 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 30: EQ Band 1 Gains for Lowest Cut-Off Frequency +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 31: EQ Band 2 Peak Filter Gains for Lowest Cut-Off Frequency with EQ2BW = 0 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k 10k 20k Hz Figure 32: EQ Band 2, EQ2BW = 0 versus EQ2BW = 1 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k Hz Figure 33: EQ Band 3 Peak Filter Gains for Lowest Cut-Off Frequency with EQ3BW = 0 Datasheet Rev 2.5 Page 50 of 69 March, 2014 NAU8401 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k Hz Figure 34: EQ Band 3, EQ3BW = 0 versus EQ3BW = 1 +15 T +10 +5 d B r 0 -5 -10 -15 Figure 35: EQ Band 4 Peak Filter Gains for Lowest Cut-Off Frequencies with EQ4BW = 0 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k 10k 20k 10k 20k Hz Figure 36: EQ Band 4, EQ4BW = 0 versus EQ4BW =1 +15 +10 +5 d B r 0 -5 -10 -15 20 50 100 200 500 1k 2k 5k Hz Figure 37: EQ Band 5 Gains for Lowest Cut-Off Frequency Datasheet Rev 2.5 Page 51 of 69 March, 2014 NAU8401 12 Appendix B: Companding Tables 12.1 µ-Law / A-Law Codes for Zero and Full Scale µ-Law Level A-Law Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) + Full Scale 1 000 0000 1 010 1010 + Zero 1 111 1111 1 101 0101 - Zero 0 111 1111 0 101 0101 - Full Scale 0 000 0000 0 010 1010 Table 15: Companding Codes for Zero and Full-Scale 12.2 µ-Law / A-Law Output Codes (Digital mW) µ-Law Sample A-Law Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) Sign bit (D7) Chord bits (D6,D5,D4) Step bits (D3,D2,D1,D0) 1 0 001 1110 0 011 0100 2 0 000 1011 0 010 0001 3 0 000 1011 0 010 0001 4 0 001 1110 0 011 0100 5 1 001 1110 1 011 0100 6 1 000 1011 1 010 0001 7 1 000 1011 1 010 0001 8 1 001 1110 1 011 0100 Table 16: Companding Output Codes Datasheet Rev 2.5 Page 52 of 69 March, 2014 NAU8401 13 Appendix C: Details of Register Operation Register Function Name Dec Hex 0 00 Bit Description 8 7 6 5 4 3 2 1 0 Any write operation to this register resets all registers to default values Software Reset Power control for internal tie-off buffer used in 1.5X boost conditions 0 = internal buffer unpowered 1 = enabled Power control for AUX1 MIXER supporting AUXOUT1 analog output 0 = unpowered 1 = enabled Power control for AUX2 MIXER supporting AUXOUT2 analog output 0 = unpowered 1 = enabled Power control for internal PLL 0 = unpowered 1 = enabled Power control for refernce voltage bias buffer amplifier (PRGREF output, pin#32) 0 = unpowered and PRGREF pin in high-Z condition 1 = enabled Power control for internal analog bias buffers 0 = unpowered 1 = enabled Power control for internal tie-off buffer used in non-boost mode (-1.0x gain) conditions 0 = internal buffer unpowered 1 = enabled Select impedance of reference string used to establish VREF for internal bias buffers 00 = off (input to internal bias buffer in high-Z floating condition) 01 = 80kΩ nominal impedance at VREF pin 10 = 300kΩ nominal impedance at VREF pin 11 = 3kΩ nominal impedance at VREF pin DCBUFEN AUX1MXEN AUX2MXEN PLLEN 1 01 Power Management 1 PRGREF ABIASEN IOBUFEN REFIMP Default >> 0 0 0 0 0 0 0 0 0 Right Headphone driver enable, RHP analog output, pin#29 0 = RHP pin in high-Z condition 1 = enabled Left Headphone driver enabled, LHP analog output pin#30 0 = LHP pin in high-Z condition 1 = enabled Sleep enable 0 = device in normal operating mode 1 = device in low-power sleep condition RHPEN 2 02 Power Management 2 LHPEN SLEEP Reserved Default >> 3 03 Power Management AUXOUT1EN 3 Datasheet Rev 2.5 0x000 reset value Reserved 0 0 0 0 0 0 0 0 0 0x000 reset value AUXOUT1 analog output power control, pin#21 0 = AUXOUT1 output driver OFF 1 = enabled Page 53 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 AUXOUT2 analog output power control, pin#22 0 = AUXOUT2 output driver OFF 1 = enabled LSPKOUT left speaker driver power control, pin#25 0 = LSPKOUT output driver OFF 1 = enabled RSPKOUT left speaker driver power control, pin#23 0 = RSPKOUT output driver OFF 1 = enabled Bias control for high current output when outputs are in 1.5X boost mode 0 = reduced current operation and reduced max output current 1 = normal operation enabling outputs to deliver full rated output current Right main mixer power control, RMAIN MIXER internal stage 0 = RMAIN MIXER stage OFF 1 = enabled Left main mixer power control, LMAIN MIXER internal stage 0 = LMAIN MIXER stage OFF 1 = enabled Right channel digital-to-analog converter, RDAC, power control 0 = RDAC stage OFF 1 = enabled Left channel digital-to-analog converter, LDAC, power control 0 = LDAC stage OFF 1 = enabled AUXOUT2EN LSPKEN RSPKEN BIASGEN RMIXEN LMIXEN RDACEN LDACEN Default >> 0 0 0 0 0 0 0 0 0 BCLKP LRP WLEN 4 04 Audio Interface AIFMT DACPHS Reserved Reserved Mono operation enable 0 = normal stereo mode of operation (default) 1 = mono mode with audio data in left phase of LRP MONO Default >> Reserved 5 05 Companding CMB8 Datasheet Rev 2.5 0x000 reset value Bit clock phase inversion option for BCLK, pin#8 0 = normal phase 1 = input logic sense inverted Phase control for I2S audio data bus interface 0 = normal phase operation 1 = inverted phase operation PCMA and PCMB left/right word order control 0 = MSB is valid on 2nd rising edge of BCLK after rising edge of FS 1 = MSB is valid on 1st rising edge of BCLK after rising edge of FS Word length (24-bits default) of audio data stream 00 = 16-bit word length 01 = 20-bit word length 10 = 24-bit word length 11 = 32-bit word length Audio interface data format (default setting is I2S) 00 = right justified 01 = left justified 10 = standard I2S format 11 = PCMA or PCMB audio data format option DAC audio data left-right ordering 0 = left DAC data in left phase of LRP 1 = left DAC data in right phase of LRP (left-right reversed) 0 0 1 0 1 0 0 0 0 0x050 reset value Reserved 8-bit word enable for companding mode of operation 0 = normal operation (no companding) 1 = 8-bit operation for companding mode Page 54 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 DACCM DAC companding mode control 00 = off (normal linear operation) 01 = reserved 10 = u-law companding 11 = A-law companding Reserved Reserved Default >> 0 0 0 0 0 0 0 0 0 CLKM MCLKSEL 6 06 Clock control 1 BCLKSEL Reserved Reserved Enables chip master mode to drive FS and BCLK outputs 0 = FS and BCLK are inputs 1 = FS and BCLK are driven as outputs by internally generated clocks CLKIOEN Default >> 7 07 Clock control 2 1 0 1 0 0 0 0 0 0 4-wire control interface enable Reserved Reserved Audio data sample rate indication (48kHz default). Sets up scaling for internal filter coefficients, but does not affect in any way the actual device sample rate. Should be set to value most closely matching the actual sample rate determined by 256fs internal node. 000 = 48kHz 001 = 32kHz 010 = 24kHz 011 = 16kHz 100 = 12kHz 101 = 8kHz 110 = reserved 111 = reserved Slow timer clock enable. Starts internal timer clock derived by dividing master clock. 0 = disabled 1 = enabled SMPLR Default >> Reserved 08 GPIO GPIO1PLL Datasheet Rev 2.5 0x140 reset value 4WSPIEN SCLKEN 8 0x000 reset value master clock source selection control 0 = MCLK, pin#11 used as master clock 1 = internal PLL oscillator output used as master clock Scaling of master clock source for internal 256fs rate ( divide by 2 = default) 000 = divide by 1 001 = divide by 1.5 010 = divide by 2 011 = divide by 3 100 = divide by 4 101 = divide by 6 110 = divide by 8 111 = divide by 12 Scaling of output frequency at BCLK pin#8 when chip is in master mode 000 = divide by 1 001 = divide by 2 010 = divide by 4 011 = divide by 8 100 = divide by 16 101 = divide by 32 110 = reserved 111 = reserved 0 0 0 0 0 0 0 0 0 0x000 reset value Reserved Clock divisor applied to PLL clock for output from a GPIO pin 00 = divide by 1 01 = divide by 2 10 = divide by 3 11 = divide by 4 Page 55 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 GPIO1 polarity inversion control 0 = normal logic sense of GPIO signal 1 = inverted logic sense of GPIO signal CSB/GPIO1 function select (input default) 000 = use as input subject to MODE pin#18 input logic level 001 = reserved 010 = Temperature OK status output ( logic 0 = thermal shutdown) 011 = DAC automute condition (logic 1 = one or both DACs automuted) 100 = output divided PLL clock 101 = PLL locked condition (logic 1 = PLL locked) 110 = output set to logic 1 condition 111 = output set to logic 0 condition GPIO1PL GPIO1SEL Default >> 0 0 0 0 0 0 0 0 0 JCKMIDEN JACDEN 9 09 Jack detect 1 JCKDIO Reserved Default >> Reserved 0 0 0 0 0 0 0 0 0 0A Reserved SOFTMT Softmute feature control for DACs 0 = disabled 1 = enabled Reserved Reserved DAC oversampling rate selection (64X default) 0 = 64x oversampling 1 = 128x oversampling DAC automute function enable 0 = disabled 1 = enabled DAC right channel output polarity control 0 = normal polarity 1 = inverted polarity DAC left channel output polarity control 0 = normal polarity 1 = inverted polarity DAC control AUTOMT RDACPL LDACPL Default >> 0 0 0 0 0 0 0 0 0 0B Left DAC volume 12 0C Right DAC volume Datasheet Rev 2.5 DAC left digital volume control (0dB default attenuation value). Expressed as an attenuation value in 0.5dB steps as follows: 0000 0000 = digital mute condition 0000 0001 = -127.0dB (highly attenuated) 0000 0010 = -126.5dB attenuation - all intermediate 0.5 step values through maximum – 1111 1110 = -0.5dB attenuation 1111 1111 = 0.0dB attenuation (no attenuation) LDACGAIN Default >> RDACVU 0x000 reset value DAC volume update bit feature. Write-only bit for synchronized L/R DAC changes If logic = 0 on R11 write, new R11 value stored in temporary register If logic = 1 on R11 write, new R11 and pending R12 values become active LDACVU 11 0x000 reset value Reserved DACOS 10 0x000 reset value Automatically enable internal bias amplifiers on jack detection state as sensed through GPIO pin associated to jack detection function Bit 7 = logic 1: enable bias amplifiers on jack at logic 0 level Bit 8 = logic 1: enable bias amplifiers on jack at logic 1 level Jack detection feature enable 0 = disabled 1 = enable jack detection associated functionality Select jack detect pin (GPIO1 default) 00 = GPIO1 is used for jack detection feature 01 = GPIO2 is used for jack detection feature 10 = GPIO3 is used for jack detection feature 11 = reserved 0 1 1 1 1 1 1 1 1 0x0FF reset value DAC volume update bit feature. Write-only bit for synchronized L/R DAC changes If logic = 0 on R12 write, new R12 value stored in temporary register If logic = 1 on R12 write, new R12 and pending R11 values become active Page 56 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 DAC right digital volume control (0dB default attenuation value). Expressed as an attenuation value in 0.5dB steps as follows: 0000 0000 = digital mute condition 0000 0001 = -127.0dB (highly attenuated) 0000 0010 = -126.5dB attenuation - all intermediate 0.5 step values through maximum volume – 1111 1110 = -0.5dB attenuation 1111 1111 = 0.0dB attenuation (no attenuation) RDACGAIN Default >> 0 1 1 1 1 1 1 1 1 Reserved Outputs drivers that are automatically enabled whenever the designated jack detection input is in the logic = 1 condition, and the jack detection feature is enabled Bit 4 = 1: enable Left and Right Headphone output drivers Bit 5 = 1: enable Left and Right Speaker output drivers Bit 6 = 1: enable AUXOUT2 output driver Bit 7 = 1: enable AUXOUT1 output driver Outputs drivers that are automatically enabled whenever the designated jack detection input is in the logic = 0 condition, and the jack detection feature is enabled Bit 0 = 1: enable Left and Right Headphone output drivers Bit 1 = 1: enable Left and Right Speaker output drivers Bit 2 = 1: enable AUXOUT2 output driver Bit 3 = 1: enable AUXOUT1 output driver JCKDOEN1 13 0D Jack detect 2 JCKDOEN0 Default >> 0x0FF reset value Reserved 0 0 0 0 0 0 0 0 0 0x000 reset value 14 0E Reserved Reserved Reserved 15 0F Reserved Reserved Reserved 16 10 Reserved Reserved Reserved 17 11 Reserved Reserved Reserved Equalizer and 3D audio processing block assignment. 0 = block disabled on digital stream from DAC 1 = block operates on digital stream to DAC (default on reset) EQM Reserved Reserved Equalizer band 1 low pass -3dB cut-off frequency selection 00 = 80Hz 01 = 105Hz (default) 10 = 135Hz 11 = 175Hz EQ Band 1 digital gain control. Expressed as a gain or attenuation in 1dB steps 01100 = 0.0dB default unity gain value EQ1CF 18 12 EQ1 low cutoff 00000 = +12dB 00001 = +11dB - all intermediate 1.0dB step values through minimum gain 11000 = -12dB 11001 and larger values are reserved EQ1GC Default >> 19 13 0x12C reset value EQ2BW Equalizer Band 2 bandwidth selection 0 = narrow band characteristic (default) 1 = wide band characteristic Reserved Reserved EQ2 - peak 1 Datasheet Rev 2.5 1 0 0 1 0 1 1 0 0 Page 57 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 Equalizer Band 2 center frequency selection 00 = 230Hz 01 = 300Hz (default) 10 = 385Hz 11 = 500Hz EQ Band 2 digital gain control. Expressed as a gain or attenuation in 1dB steps 01100 = 0.0dB default unity gain value EQ2CF 00000 = +12dB 00001 = +11dB - all intermediate 1.0dB step values through minimum gain 11000 = -12dB 11001 and larger values are reserved EQ2GC Default >> 0 0 0 1 0 1 1 0 0 EQ3BW Reserved Reserved Equalizer Band 3 center frequency selection 00 = 650Hz 01 = 850Hz (default) 10 = 1.1kHz 11 = 1.4kHz EQ Band 3 digital gain control. Expressed as a gain or attenuation in 1dB steps 01100 = 0.0dB default unity gain value EQ3CF 20 14 EQ3 - peak 2 00000 = +12dB 00001 = +11dB - all intermediate 1.0dB step values through minimum gain 11000 = -12dB 11001 and larger values are reserved EQ3GC Default >> 0 0 0 1 0 1 1 0 0 15 EQ4BW Reserved Reserved Equalizer Band 4 center frequency selection 00 = 1.8kHz 01 = 2.4kHz (default) 10 = 3.2kHz 11 = 4.1kHz EQ Band 4 digital gain control. Expressed as a gain or attenuation in 1dB steps 01100 = 0.0dB default unity gain value EQ4 - peak 3 00000 = +12dB 00001 = +11dB - all intermediate 1.0dB step values through minimum gain 11000 = -12dB 11001 and larger values are reserved EQ4GC Default >> Reserved 22 16 EQ5 - high cutoff Datasheet Rev 2.5 0x02C reset value Equalizer Band 4 bandwidth selection 0 = narrow band characteristic (default) 1 = wide band characteristic EQ4CF 21 0x02C reset value Equalizer Band 3 bandwidth selection 0 = narrow band characteristic (default) 1 = wide band characteristic EQ5CF 0 0 0 1 0 1 1 0 0 0x02C reset value Reserved Equalizer Band 5 high pass -3dB cut-off frequency selection 00 = 5.3kHz 01 = 6.9kHz (default) 10 = 9.0kHz 11 = 11.7kHz Page 58 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 EQ Band 5 digital gain control. Expressed as a gain or attenuation in 1dB steps 01100 = 0.0dB default unity gain value 00000 = +12dB 00001 = +11dB - all intermediate 1.0dB step values through minimum gain 11000 = -12dB 11001 and larger values are reserved EQ5GC Default >> 23 17 0 0 0 1 0 1 1 0 0 Reserved Reserved DAC digital limiter control bit 0 = disabled 1 = enabled DAC limiter decay time. Proportional to actual DAC sample rate. Duration doubles with each binary bit value. Values given here are for 44.1kHz sample rate 0000 = 0.544ms 0001 = 1.09ms 0010 = 2.18ms 0011 = 4.36ms (default) 0100 = 8.72ms 0101 = 17.4ms 0110 = 34.8ms 0111 = 69.6ms 1000 = 139ms 1001 = 278ms 1010 = 566ms 1011 through 1111 = 1130ms DACLIMEN DACLIMDCY 24 18 DAC limiter 1 DAC limiter attack time. Proportional to actual DAC sample rate. Duration doubles with each binary bit value. Values given here are for 44.1kHz sample rate 0000 = 68.0us (microseconds) 0001 = 136us 0010 = 272us (default) 0011 = 544us 0100 = 1.09ms (milliseconds) 0101 = 2.18ms 0110 = 4.36ms 0111 = 8.72ms 1000 = 17.4ms 1001 = 34.8ms 1010 = 69.6ms 1011 through 1111 = 139ms DACLIMATK Default >> 0 0 0 1 1 0 0 1 0 Reserved 19 DAC limiter threshold in relation to full scale output level (0.0dB = full scale) 000 = -1.0dB 001 = -2.0dB 010 = -3.0dB 011 = -4.0dB 100 = -5.0dB 101 through 111 = -6.0dB DAC limiter maximum automatic gain boost in limiter mode. If R24 limiter mode is disabled, specified gain value will be applied in addition to other gain values in the signal path. 0000 = 0.0dB (default) 0001 = +1.0dB - Gain value increases in 1.0dB steps for each binary value – 1100 = +12dB (maximum allowed boost value) 1101 through 1111 = reserved DAC limiter 2 DACLIMBST Default >> 0x032 reset value Reserved DACLIMTHL 25 0x02C reset value Reserved 0 0 0 0 0 0 0 0 0 0x000 reset value 1A Reserved Reserved Reserved 27 1B Reserved Reserved Reserved 28 1C Reserved Reserved Reserved 29 1D Reserved Reserved Reserved 30 1E Reserved Reserved Reserved 31 1F Reserved Reserved Reserved 26 Datasheet Rev 2.5 Page 59 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 32 20 Reserved Reserved Reserved 33 21 Reserved Reserved Reserved 34 22 Reserved Reserved Reserved 35 23 Reserved Reserved Reserved Reserved Reserved Control bit for divide by 2 pre-scale of MCLK path to PLL clock input 0 = MCLK divide by 1 (default) 1 = MCLK divide by 2 Integer portion of PLL input/output frequency ratio divider. Decimal value should be constrained to 6, 7, 8, 9, 10, 11, or 12. Default decimal value is 8. See text for details. PLLMCLK 36 24 PLL N PLLN Default >> 0 0 0 0 0 1 0 0 0 Reserved 37 25 PLL K 1 Reserved High order bits of fractional portion of PLL input/output frequency ratio divider. See text for details. PLLK[23:18] Default >> 0 0 0 0 0 1 1 0 0 26 PLL K 2 Default >> 0 1 0 0 1 0 0 1 1 27 PLL K 3 Default >> 0 1 1 1 0 1 0 0 1 Reserved 40 28 PRGREF Mode Programmable reference optional low noise mode configuration control 0 = normal configuration with low-Z PRGREF output impedance 1 = low noise configuration with 200-ohm PRGREF output impedance 0 0 0 0 0 0 0 0 0 Reserved 41 29 3D control 42 2A Reserved 43 2B RMIXMUT RSUBBYP Datasheet Rev 2.5 3D Stereo Enhancement effect depth control 0000 = 0.0% effect (disabled, default) 0001 = 6.67% effect 0010 = 13.3% effect - effect depth varies by 6.67% per binary bit value – 1110 = 93.3% effect 1111 = 100% effect (maximum effect) 0 0 0 0 0 0 0 0 0 0x000 reset value Reserved Reserved Right Speaker Submixer 0x000 reset value Reserved 3DDEPTH Default >> 0x0E9 reset value Reserved PRGREFM Default >> 0x093 reset value Low order bits of fractional portion of PLL input/output frequency ratio divider. See text for details. PLLK{8:0] 39 0x00C reset value Middle order bits of fractional portion of PLL input/output frequency ratio divider. See text for details. PLLK[17:9] 38 0x008 reset value Reserved Mutes the RMIX speaker signal gain stage output in the right speaker submixer 0 = gain stage output enabled 1 = gain stage output muted Right speaker submixer bypass control 0 = right speaker amplifier directly connected to RMIX speaker signal gain stage 1 = right speaker amplifier connected to submixer output (inverts RMIX for BTL) Page 60 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 RINPUT to Right Speaker Submixer input gain control 000 = -15dB (default) 001 = -12dB 010 = -9.0dB 011 = -6.0dB 100 = -3.0dB 101 = 0.0dB 110 = +3.0dB 111 = +6.0dB RINPUT to Right Speaker Submixer mute control 0 = RINPUT path to submixer is muted 1 = RINPUT path to submixer is enabled RAUXRSUBG RAUXSMUT Default >> 0 0 0 0 0 0 0 0 0 Programmable reference voltage selection control. Values change slightly with R40 PRGREF mode selection control. Open circuit voltage on PRGREF pin#32 is shown as follows as a fraction of the VDDA pin#31 supply voltage. Normal Mode Low Noise Mode 00 = 0.9x 00 = 0.85x 01 = 0.65x 01 = 0.60x 10 = 0.75x 10 = 0.70x 11 = 0.50x 11 = 0.50x PRGREFV 44 2C Input control Reserved Default >> 0x000 reset value Reserved 0 0 0 1 1 0 0 1 1 0x033 reset value 45 2D Reserved Reserved Reserved 46 2E Reserved Reserved Reserved 47 2F Reserved Reserved Reserved 48 30 Reserved Reserved Reserved Reserved Reserved Left DAC output to RMIX right output mixer cross-coupling path control 0 = path disconnected (default) 1 = path connected Right DAC output to LMIX left output mixer cross-coupling path control 0 = path disconnected (default) 1 = path connected AUXOUT1 gain boost control 0 = required setting for greater than 3.6V operation, +1.5x gain (default) 1 = preferred setting for 3.6V and lower operation, -1.0x gain AUXOUT2 gain boost control 0 = required setting for greater than 3.6V operation, +1.5x gain (default) 1 = preferred setting for 3.6V and lower operation, -1.0x gain LSPKOUT and RSPKOUT speaker amplifier gain boost control 0 = required setting for greater than 3.6V operation, +1.5x gain (default) 1 = preferred setting for 3.6V and lower operation, -1.0x gain Thermal shutdown enable protects chip from thermal destruction on overload 0 = disable thermal shutdown (engineering purposes, only) 1 = enable (default) strongly recommended for normal operation Output resistance control option for tie-off of unused or disabled outputs. Unused outputs tie to internal voltage reference for reduced pops and clicks. 0 = nominal tie-off impedance value of 1kΩ (default) 1 = nominal tie-off impedance value of 30kΩ LDACRMX RDACLMX AUX1BST 49 31 AUX2BST Output control SPKBST TSEN AOUTIMP Default >> LAUXMXGAIN 50 32 Left mixer LAUXLMX Datasheet Rev 2.5 0 0 0 0 0 0 0 1 0 0x002 reset value Gain value between LINPUT auxiliary input and input to LMAIN left output mixer 000 = -15dB (default) 001 = -12dB 010 = -9.0dB 011 = -6.0dB 100 = -3.0dB 101 = 0.0dB 110 = +3.0dB 111 = +6.0dB LINPUT input to LMAIN left output mixer path control 0 = LINPUT not connected to LMAIN left output mixer (default) 1 = LINPUT connected to LMAIN left output mixer Page 61 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 Reserved Reserved Left DAC output to LMIX left output mixer path control 0 = path disconnected (default) 1 = path connected LDACLMX Default >> 0 0 0 0 0 0 0 0 1 RAUXMXGAIN 51 33 Right mixer 0x001 reset value Gain value between LINPUT auxiliary input and input to LMAIN left output mixer 000 = -15dB (default) 001 = -12dB 010 = -9.0dB 011 = -6.0dB 100 = -3.0dB 101 = 0.0dB 110 = +3.0dB 111 = +6.0dB RINPUT input to RMAIN right output mixer path control 0 = RINPUT not connected to RMAIN right output mixer (default) 1 = RINPUT connected to RMAIN right output mixer RAUXRMX Reserved Reserved Right DAC output to RMIX right output mixer path control 0 = path disconnected (default) 1 = path connected RDACRMX Default >> 0 0 0 0 0 0 0 0 1 LHPVU LHPZC LHPMUTE 52 34 LHP volume 00 0000 = -57dB 00 0001 = -56dB - volume changes in 1.0dB steps per binary bit value – 11 1110 = +5.0dB 11 1111 = +6.0dB LHPGAIN Default >> RHPVU 53 35 RHP volume RHPZC RHPMUTE Datasheet Rev 2.5 0x001 reset value Headphone output volume update bit feature. Write-only bit for synchronized changes of left and right headphone amplifier output settings If logic = 0 on R52 write, new R52 value stored in temporary register If logic = 1 on R52 write, new R52 and pending R53 values become active Left channel input zero cross detection enable 0 = gain changes to left headphone happen immediately (default) 1 = gain changes to left headphone happen pending zero crossing logic Left headphone output mute control 0 = headphone output not muted, normal operation (default) 1 = headphone in muted condition not connected to LMIX output stage Left channel headphone output volume control setting. Setting becomes active when allowed by zero crossing and/or update bit features. 11 1001 = 0.0dB default setting 0 0 0 1 1 1 0 0 1 0x039 reset value Headphone output volume update bit feature. Write-only bit for synchronized changes of left and right headphone amplifier output settings If logic = 0 on R53 write, new R53 value stored in temporary register If logic = 1 on R53 write, new R53 and pending R52 values become active Right channel input zero cross detection enable 0 = gain changes to right headphone happen immediately (default) 1 = gain changes to right headphone happen pending zero crossing logic Right headphone output mute control 0 = headphone output not muted, normal operation (default) 1 = headphone in muted condition not connected to RMIX output stage Page 62 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 Right channel headphone output volume control setting. Setting becomes active when allowed by zero crossing and/or update bit features. 11 1001 = 0.0dB default setting 00 0000 = -57dB 00 0001 = -56dB - volume changes in 1.0dB steps per binary bit value – 11 1110 = +5.0dB 11 1111 = +6.0dB RHPGAIN Default >> 0 0 0 1 1 1 0 0 1 LSPKVU LSPKZC LSPKMUTE 54 36 LSPKOUT volume 00 0000 = -57dB 00 0001 = -56dB - volume changes in 1.0dB steps per binary bit value – 11 1110 = +5.0dB 11 1111 = +6.0dB LSPKGAIN Default >> 0 0 0 1 1 1 0 0 1 RSPKZC RSPKMUTE 37 RSPKOUT volume 00 0000 = -57dB 00 0001 = -56dB - volume changes in 1.0dB steps per binary bit value – 11 1110 = +5.0dB 11 1111 = +6.0dB RSPKGAIN Default >> Reserved AUXOUT2MT 56 38 AUX2 MIXER Reserved AUX1MIX>2 Reserved Datasheet Rev 2.5 0x039 reset value Loudspeaker output volume update bit feature. Write-only bit for synchronized changes of left and right headphone amplifier output settings If logic = 0 on R55 write, new R55 value stored in temporary register If logic = 1 on R55 write, new R55 and pending R54 values become active Right loudspeaker RSPKOUT output zero cross detection enable 0 = gain changes to right loudspeaker happen immediately (default) 1 = gain changes to right loudspeaker happen pending zero crossing logic Right loudspeaker RSPKOUT output mute control 0 = loudspeaker output not muted, normal operation (default) 1 = loudspeaker in muted condition Right loudspeaker output volume control setting. Setting becomes active when allowed by zero crossing and/or update bit features. 11 1001 = 0.0dB default setting RSPKVU 55 0x039 reset value Loudspeaker output volume update bit feature. Write-only bit for synchronized changes of left and right headphone amplifier output settings If logic = 0 on R54 write, new R54 value stored in temporary register If logic = 1 on R54 write, new R54 and pending R55 values become active Left loudspeaker LSPKOUT output zero cross detection enable 0 = gain changes to left loudspeaker happen immediately (default) 1 = gain changes to left loudspeaker happen pending zero crossing logic Right loudspeaker LSPKOUT output mute control 0 = loudspeaker output not muted, normal operation (default) 1 = loudspeaker in muted condition Left loudspeaker output volume control setting. Setting becomes active when allowed by zero crossing and/or update bit features. 11 1001 = 0.0dB default setting 0 0 0 1 1 1 0 0 1 0x039 reset value Reserved AUXOUT2 output mute control 0 = output not muted, normal operation (default) 1 = output in muted condition Reserved AUX1 Mixer output to AUX2 MIXER input path control 0 = path not connected 1 = path connected Reserved Page 63 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 Left LMAIN MIXER output to AUX2 MIXER input path control 0 = path not connected 1 = path connected Left DAC output to AUX2 MIXER input path control 0 = path not connected 1 = path connected LMIXAUX2 LDACAUX2 Default >> 0 0 0 0 0 0 0 0 1 0x001 reset value Reserved AUXOUT1 output mute control 0 = output not muted, normal operation (default) 1 = output in muted condition AUXOUT1 6dB attenuation enable 0 = output signal at normal gain value (default) 1 = output signal attenuated by 6.0dB Left LMAIN MIXER output to AUX1 MIXER input path control 0 = path not connected 1 = path connected Left DAC output to AUX1 MIXER input path control 0 = path not connected 1 = path connected AUXOUT1MT AUX1HALF LMIXAUX1 57 39 AUX1 MIXER LDACAUX1 Reserved Reserved Right RMIX output to AUX1 MIXER input path control 0 = path not connected 1 = path connected Right DAC output to AUX1 MIXER input path control 0 = path not connected 1 = path connected RMIXAUX1 RDACAUX1 Default >> 0 0 0 0 0 0 0 0 1 LPDAC Reduce DAC supply current 50% in low power operating mode 0 = normal supply current operation (default) 1 = 50% reduced supply current mode Reserved Reserved Reduce loudspeaker amplifier supply current 50% in low power operating mode 0 = normal supply current operation (default) 1 = 50% reduced supply current mode Programmable reference voltage output impedance control 0 = low-Z output impedance mode 1 = approx. 200-ohm output impedance mode Regulator voltage control power reduction options 00 = normal 1.80Vdc operation (default) 01 = 1.61Vdc operation 10 = 1.40 Vdc operation 11 = 1.218 Vdc operation Master bias current power reduction options 00 = normal operation (default) 01 = 25% reduced bias current from default 10 = 14% reduced bias current from default 11 = 25% reduced bias current from default LPSPKD PRGREFM 58 Power 3A Management 4 REGVOLT IBADJ Default >> 0 0 0 0 0 0 0 0 0 3B Left time slot Default >> PCMTSEN 0x000 reset value Left channel PCM time slot start count: LSB portion of total number of bit times to wait from frame sync before clocking audio channel data. LSB portion is combined with MSB from R60 to get total number of bit times to wait. LTSLOT[8:0] 59 0x001 reset value 0 0 0 0 0 0 0 0 0 0x000 reset value Time slot function enable for PCM mode. Reserved 60 3C Misc. PCM8BIT 8-bit word length enable Reserved RTSLOT[9] Datasheet Rev 2.5 Right channel PCM time slot start count: MSB portion of total number of bit times to wait from frame sync before clocking audio channel data. MSB is combined with LSB portion from R61 to get total number of bit times to wait. Page 64 of 69 March, 2014 NAU8401 Register Function Name Dec Hex Bit Description 8 7 6 5 4 3 2 1 0 Left channel PCM time slot start count: MSB portion of total number of bit times to wait from frame sync before clocking audio channel data. MSB is combined with LSB portion from R59 to get total number of bit times to wait. LTSLOT[9] Default >> 61 3D Right time slot 3E Device Revision Number 3F 0x000 reset value Reserved REV ID 63 0 0 0 0 0 0 0 0 0 Reserved Default >> 0x020 reset value Right channel PCM time slot start count: LSB portion of total number of bit times to wait from frame sync before clocking audio channel data. LSB portion is combined with MSB from R60 to get total number of bit times to wait. RTSLOT[8:0] Default >> 62 0 0 0 1 0 0 0 0 0 Device Revision Number for readback over control interface = read-only value x x x x x x x x x x x x x x x x x x 7-bit Device ID Number for readback over control interface = read-only value Device ID# Default >> Datasheet Rev 2.5 0 0 0 0 1 1 0 1 0 0x01A reset value (read only) Page 65 of 69 March, 2014 NAU8401 14 Appendix D: Register Overview DEC HEX NAME Bit 8 Bit 7 Bit 6 Bit5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 0 00 Software Reset RESET (SOFTWARE) 1 01 Power Management 1 DCBUFEN AUX1MXEN AUX2MXEN PLLEN PRGREFEN ABIASEN IOBUFEN REFIMP 2 02 Power Management 2 RHPEN NHPEN SLEEP Reserved 3 03 Power Management 3 AUXOUT1EN AUXOUT2EN LSPKEN RSPKEN BIASGEN RMIXEN LMIXEN RDACEN LDACEN General Audio Controls 4 04 Audio Interface BCLKP LRP WLEN AIFMT DACPHS Reserved MONO 5 05 Companding Reserved CMB8 DACCM Reserved Reserved 6 06 Clock Control 1 CLKM MCLKSEL BCLKSEL Reserved CLKIOEN 7 07 Clock Control 2 4WSPIEN Reserved SMPLR SCLKEN 8 08 GPIO Reserved GPIO1PLL GPIO1PL GPIO1SEL 9 09 Jack Detect 1 JCKMIDEN JCKDEN JCKDIO Reserved 10 0A DAC Control Reserved SOFTMT Reserved DACOS AUTOMT RDACPL LDACPL 11 0B Left DAC Volume LDACVU LDACGAIN 12 0C Right DAC Volume RDACVU RDACGAIN 13 0D Jack Detect 2 Reserved JCKDOEN1 JCKDOEN0 14 0E Reserved 15 F Reserved 16 10 Reserved 17 11 Reserved 18 12 EQ1-low cutoff EQM Reserved EQ1CF EQ1GC 19 13 EQ2-peak 1 EQ2BW Reserved EQ2CF EQ2GC 20 14 EQ3-peak 2 EQ3BW Reserved EQ3CF EQ3GC 21 15 EQ4-peak3 EQ4BW Reserved EQ4CF EQ4GC 22 16 EQ5-high cutoff Reserved EQ5CF EQ5GC 23 17 Reserved DAC Limiter 24 18 DAC Limiter 1 DACLIMEN DACLIMDCY DACLIMATK 25 19 DAC Limiter 2 Reserved DACLIMTHL DACLIMBST 26 1A Reserved 27 1B Reserved 28 1C Reserved 29 1D Reserved 30 1E Reserved 31 1F Reserved Reserved 32 20 Reserved 33 21 Reserved 34 22 Reserved 35 23 Reserved Phase Locked Loop 36 24 PLL N Reserved PLLMCLK PLLN 37 25 PLL K 1 Reserved PLLK[23:18] 38 26 PLL K 2 PLLK[17:9] 39 27 PLL K 3 PLLK[8:0] 40 28 ProgRef Mode Reserved PRGREFM Miscellaneous 41 29 3D control Reserved 3DDEPTH 42 2A Reserved 43 2B Right Speaker Submix Reserved RMIXMUT RSUBBYP RAUXRSUBG RAUXSMUT 44 2C Input Control PRGREFV Reserved 45 2D Reserved 46 2E Reserved 47 2F Reserved 48 30 Reserved 49 31 Output Control Reserved LDACRMX RDACLMX AUX1BST AUX2BST SPKBST TSEN AOUTIMP 50 32 Left Mixer LAUXMXGAIN LAUXLMX Reserved Reserved LDACLMX 51 33 Right Mixer RAUXMXGAIN RAUXRMX Reserved Reserved RDACRMX 52 34 LHP Volume LHPVU LHPZC LHPMUTE LHPGAIN 53 35 RHP Volume RHPVU RHPZC RHPMUTE RHPGAIN 54 36 LSPKOUT Volume LSPKVU LSPKZC LSPKMUTE LSPKGAIN 55 37 RSPKOUT Volume RSPKVU RSPKZC RSPKMUTE RSPKGAIN 56 38 AUX2 Mixer Reserved AUXOUT2MT Reserved AUX1MIX>2 Reserved LMIXAUX2 LDACAUX2 57 39 AUX1 Mixer Reserved AUXOUT1MT AUX1HALF LMIXAUX1 LDACAUX1 Reserved RMIXAUX1 RDACAUX1 58 3A Power Management 4 LPDAC LPIPBST Reserved LPSPKD PRGREFM REGVOLT IBADJ PCM Time Slot Controls 59 3B Left Time Slot LTSLOT[8:0] 60 3C Misc PCMTSEN Reserved PCM8BIT Reserved Reserved Reserved Reserved RTSLOT[9] LTSLOT[9] 61 3D Right Time Slot RTSLOT[8:0] Silicon Revision and Device ID 62 3E Device Revision # REV 63 3F Device ID ID Datasheet Rev 2.5 Page 66 of 69 March, 2014 Default 000 000 000 050 000 140 000 000 000 000 0FF 0FF 000 12C 02C 02C 02C 02C 032 000 008 00C 093 0E9 000 000 000 033 002 001 001 039 039 039 039 001 001 000 000 020 000 xxx 01A NAU8401 15 Package Dimensions 32-lead plastic QFN 32L; 5X5mm2, 0.8mm thickness, 0.5mm lead pitch 32 1 24 8 17 9 16 25 32 24 1 17 8 16 Datasheet Rev 2.5 25 9 Page 67 of 69 March, 2014 NAU8401 16 Ordering Information Nuvoton Part Number Description NAU8401YG Package Material: G = Pb-free Package Package Type: Y = 32-Pin QFN Package Version History VERSION DATE PAGE DESCRIPTION A0.0 Dec. 15, 2008 n/a Initial Version V1.0 Feb. 12, 2008 n/a Various minor changes for v1.0 V1.1 March 15, 2010 n/a Updated package information and general update V1.2 April 20, 2010 1, 4 Diagram updated V1.3 July 19, 2010 all Unified appearance, fix R04 erratum, and minor text edits 14 V2.0 January 25, 2011 October 2013 45 8 V2.2 March 2014 7 31 32 42 43 Corrected location of low power mic bias bit from R40 to R58 Included Power Management 2 in Table Corrected 2 wire interface timing diagram Corrected Digital I/O voltage levels from DCVDD to DBVDD Corrected SPKOUT and AUXOUT full scale output Modified 2-wire write figure Modified 2-wire read figure Corrected rising/falling time specification of I2S Modified application circuit V2.3 Nov. 2014 41 Corrected Tsdios setup time V2.4 Jan. 2015 1 Updated AECQ100 description V2.5 March 2016 20 Add Important Notice 27 Revise equation from * to / 48 V2.1 Table 17: Version History Datasheet Rev 2.5 Page 68 of 69 March, 2014 NAU8401 Important Notice Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Datasheet Rev 2.5 Page 69 of 69 March, 2014
NAU8401YG 价格&库存
很抱歉,暂时无法提供与“NAU8401YG”相匹配的价格&库存,您可以联系我们找货
