NJU9101MLE-TE1
NJU9101MLE-TE1
    NJR(新日本无线)
    WFQFN24_EP
    LOWPOWERANALOGFRONTENDIC
NJU9101MLE-TE1 数据手册
NJU9101 Low Power Analog Front End ■FEATURES ●Supply Voltage ●Low Current Consumption ■GENERAL DESCRIPTION +2.4 to +3.6V 4µA (OPA,OPB), 150µA (ADC) ●Low Noise Amplifier 1.3µVpp typ. (0.1 to 10Hz) ●Low Offset Voltage Amplifier 300µV max. ●RF immunity Amplifier ●Programmable Cell Bias Voltage OPA: 0.3V to 1.7V (7 steps) OPB: 0.25V to 1.75V (50mV step) ●Programmable Gain Pre-Amplifier 1V/V to 8V/V ●High resolution Programmable Gain ADC 1V/V to 8V/V, 16-Bit (NFB), 32sps to 2k sps ●System Calibration for offset & gain drift ●Control external EEPROM as a Master device ●Ambient Operating Temperature -40°C to +85°C 2 ●Interface I C (3-Bit selectable slave address) ●Package EQFN-24-LE (4mm x 4mm) ■APPLICATION NJU9101 is a Low Power Analog Front End IC for use in micro-power sensing applications, especially electrochemical sensors. It provides a complete signal processing solution between sensor and micro-processor as smart-sensor module. NJU9101 has 2 channel low power operational amplifiers. These amplifiers provide potentiostat and trans-impedance-amplifiers to constitute gas sensor systems. The NJU9101 has calibration circuit by using output data of built-in high precision ADC. It is suitable for temperature variation of sensor. NJU9101 operates over voltage range of 2.4V to 3.6V. Total average current consumption can be less than 5µA. ■INL vs Input Voltage (ADC) ●Gas Monitor ●Blood Glucose Meter ●Current Sensing Systems ●Low Power Systems ●Photodiode Sensing Systems ●Portable equipment ■EQUIVALENT CIRCUIT・BLOCK DIAGRAM Ver.1 http://www.njr.com/ -1- NJU9101 ■PIN CONFIGURATION EQFN-24-LE PIN NO. 1 SYMBOL DESCRIPTION Pin Type I C serial clock input Digital Input 2 SCL 2 2 SDA I C serial data input / output (which requires an pull-up resistor) Digital Input / Output 3 EXSCL I C serial clock output for external EEPROM (which requires an pull-up register) Digital Output 4 EXSDA I C serial data input / output for external EEPROM (which requires an pull-up resister) Digital Input / Output 5 AD0 Chip address selection input 0 6 AD1 Chip address selection input 1 7 AD2 Chip address selection input 2 8 TEST TEST terminal (This terminal is used for production test. Connect to VDD) Analog Input 9 VDD Voltage Supply Power Supply 10 VREFA+ Positive voltage reference input for ADC Analog Input 11 VREFIN Voltage reference input for Bias Registor Analog Input 12 BOUT Voltage output for Bch. OpAmp Analog Output 13 BIN- Negative voltage input for Bch. OpAmp Analog Input 14 BIN+ Positive voltage input for Bch. OpAmp Analog Input 15 SWS Switch Source Input 1 Swtich 16 SWD Switch Drain Input 2 Swtich 17 AIN+ Positive voltage input for Ach. OpAmp Analog Input 18 AIN- Negative voltage input for Ach. OpAmp Analog Input 19 AOUT Voltage output for Ach. OpAmp Analog Output 20 AUXIN- Auxiliary positive input Analog Input 21 AUXIN+ Auxiliary negative input Analog Input VREFA- Negative voltage reference input for ADC (connect to GND, is recommended) Analog Input 2 2 22 Ver.1 Select 7 chip address from “000” to “110”. Do not select address “111”, which address is for production test purpose Digital Input Digital Input Digital Input 23 GND GND GND 24 RDYB RDYB output / GPIO Digital Input / Output PAD EXPPAD Exposed PAD on backside (connect to GND) GND http://www.njr.com/ -2- NJU9101 ■MARK INFORMATION NJU9101 MLE (TE1) Part Number Package ■ORDERING INFORMATION PACKAGE PART NUMBER OUTLINE NJU9101MLE EQFN-24-LE Taping Form RoHS O HALOGEN- TERMINAL FREE FINISH O Sn-2Bi MARKING 9101 WEIGHT (mg) 31 MOQ(pcs) 1,000 ■ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL RATINGS UNIT Power Supply Voltage VDD 5 V Analog Input Voltage (1) VIA -0.3 to VDD+0.3 not exceeding 5 V Digital Input Voltage VID -0.3 to 6 V VIS -0.3 to VDD+0.3 not exceeding 5 (1) Switch Input Voltage On State Switch Current ISO Power Dissipation(Ta=25°C) PD Operating Temperature Range Topr -40 to +40 (4) (5) 830 / 2100 (2-layer / 4-layer) -40 to +85 Storage Temperature Range Tstg -40 to +150 (2) V (3) mA mW °C °C (1): The input pins have clamp diodes to the power supply pins. Limit the input current to 10mA or less whenever input signals exceed the power supply rail by 0.3V. (2): Power dissipation is the power that can be consumed by the IC at Ta=25°C, and is the typical measured value based on JEDEC condition. When using the IC over Ta=25°C subtract the value [mW/°C] = PD / Tst max.- 25) per temperature. (3): Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 2Layers FR-4, with Exposed Pad) (4): Mounted on glass epoxy board. (101.5×114.5×1.6mm: based on EIA/JEDEC standard, 4Layers FR-4, with Exposed Pad) (For 4Layers: Applying 99.5×99.5mm inner Cu area and a thermal via hole to a board based on JEDEC standard JESD51-5) ■RECOMMENDED OPERATING CONDITIONS PARAMETER SYMBOL RATINGS UNIT Power Supply Voltage VDD +2.4 to +3.6 V Operating Temperature Range Topr -40 to +85 °C Storage Temperature Range Tstg -40 to +150 °C Ver.1 http://www.njr.com/ -3- NJU9101 ■ELECTRICAL CHARACTERISTICS Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Input Offset Voltage VIO VICM = VDD/2, Rs = 50Ω - - ±300 µV Input Offset Voltage Drift ∆VIO / ∆T - ±1 - µV/°C Input Bias Current IB - 10 - pA OPA, OPB Open Loop Gain AV - 100 - dB Common Mode Rejection Ratio CMR VICM = GND to 2V 65 80 - dB Common Mode Input Voltage Range VICM CMR ≥ 65dB GND - 2 V VOH ISOUECE = 1mA 2.8 2.85 - V VOL ISINK = 1mA Maximum Output Voltage - 0.15 0.2 V Gain Band Width GBW - 30 - kHz Slew Rate SR - 0.01 - V/µs Equivalent Input Noise Voltage en f = 100Hz, RS = 50Ω - 50 - nV/√Hz f = 0.1Hz to 10Hz - 1.3 - µVpp Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V, ADC reference Voltage = External PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT OPA referred to OPB Input Offset Voltage 1 VIO1A-B OPA BIAS = 1V OPB BIAS = 1V - - ±0.6 mV OPA referred to OPB Input Offset Drift 1 ∆VIO1A-B / ∆T OPA BIAS = 1V OPB BIAS = 1V - ±2 - µV/°C OPA referred to OPB Input Offset Voltage 2 VIO2A-B OPA BIAS = 1V OPB BIAS = 0.7V 295 300 305 mV OPA referred to OPB Input Offset Drift 2 ∆VIO2A-B / ∆T OPA BIAS = 1V OPB BIAS = 0.7V - ±5 - µV/°C OPA referred to OPB Input Offset Voltage 3 VIO3A-B OPA BIAS = 1V OPB BIAS = 1.6V -605 -600 -595 mV OPA referred to OPB Input Offset Drift 3 ∆VIO3A-B / ∆T OPA BIAS = 1V OPB BIAS = 1.6V - ±8 - µV/°C MIN. TYP. MAX. UNIT 10 30 Ω ±1 - nA OPA, OPB with BIASRES (Potentiostat) Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V PARAMETER SYMBOL TEST CONDITION RON Analog Switch = ON IDS = -10mA ILOFFD Analog Switch = OFF VSWS=2V/1V, VSWD=1V/2V Analog Switch (ANASW) On State Resistance Off Leakage Current Ver.1 http://www.njr.com/ - -4- NJU9101 Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V, Temperature Input Mode PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Temperature Accuracy (Error) 1 TACC1 Ta = 25°C - ±1 ±5 °C Temperature Accuracy (Error) 2 TACC2 Ta = -40°C to +85°C - ±3 - °C Temperature Resolution TRES - 0.25 - °C Temperature Sensor Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = 3V PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Internal Reference Voltage VIREF ±1% 2.028 2.048 2.068 V Internal Reference Drift ∆VIREF / ∆T Ta = -40°C to +85°C - 30 - ppm/°C Internal Reference Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V, Auxiliary Differential Input Mode PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT PREAMP Gain Error GACCP PREAMP Gain = 1V/1V to 8V/V - ±0.1 - % PREAMP Common Mode Rejection CMRPRE PREAMP Gain = 1V/V AUXIN+ = AUXIN- = GND+0.05 to VDD-1 70 90 - dB PREAMP Common Mode Input Voltage VICMP PREAMP Gain = 1V/V CMRPRE ≥ 70dB GND +0.05 - VCC-1 V PREAMP Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V, Auxiliary Input Mode ADC Chopping = ON, ADC Reference Voltage = External, ADC Gain = 1V/V, ADC Decimation Ratio = “320” PARAMETER SYMBOL Resolution N Noise Free Bit NFB Conversion Time DR Output Noise VnADC Integral Non Linearity INL TEST CONDITION MIN. TYP. MAX. UNIT 16 - - Bit - 16 - Bit See p.22 “ADC Conversion Time” - - - SPS VREFA+ = 3V - 13.9 - µVrms ADC Ver.1 (6) No missing code - ±1 - LSB Gain Error ADC Gain = 1V/1V to 8V/1V - ±0.1 - % Offset Error AUXIN+ = AUXIN- = VDD/2 - ±1 - LSB Differential Input Voltage Range VIDADC VREF = |(VREFA+)-(VREFA-)| - ±VREF - V ADC Common Mode Rejection CMRADC AUXIN+ = AUXIN- = GND to VDD 80 90 - dB ADC Common Mode Input Voltage Range VICADC CMRADC ≥ 80dB GND - VDD V http://www.njr.com/ -5- NJU9101 (6) This Parameter is not production tested, please refer Typical Characteristics. Unless otherwise specified, all limits ensured for Ta = 25°C, VDD = VREFIN = VREFA+ = 3V PARAMETER SYMBOL TEST CONDITION MIN. TYP. MAX. UNIT Power Supply / OSC Ver.1 Voltage Range VDD 2.4 - 3.6 V Bias Resistance RBIAS - 1.5 - MΩ Supply Current 1 IDD1 All Circuit Block Off - 0.5 1 µA Supply Current 2 IDD2 OPA、OPB - 4 5.5 µA Supply Current 3 IDD3 Internal Reference Voltage (2.048V) - 31 40 µA Supply Current 4 IDD4 PREAMP - 55 75 µA Supply Current 5 IDD5 ADC - 150 200 µA OSC Frequency fOSC ±10% 276 307 338 kHz http://www.njr.com/ -6- NJU9101 2 ■CHARACTERISTICS OF I/O STAGES FOR I C-BUS Compatible (SDA, SCL) 2 I C BUS Load Conditions STANDARD MODE: Pull up resistance 4kΩ (Connected to VDD), Load capacitance 200pF (Connected to GND) FASE MODE: Pull up resistance 4kΩ (Connected to VDD), Load capacitance 50pF (Connected to GND) Standard Mode Fast Mode PARAMETER SYM BOL MIN. TYP. MAX. MIN. TYP. MAX. Low Level Input Voltage VIL 0.0 - 0.3VDD 0.0 - 1.5 V V High Level Input Voltage VIH 0.7VDD - 5.5 2.7 - 5.5 Low Level Output Voltage (3mA at SDA pin) VOL 0 - 0.4 0 - 0.4 Input current each I/O pin with an input voltage between 0.1VDD and 0.9VDD max. Ii -10 - 10 -10 - 10 UNIT V µA 2 ■CHARACTERISTICS OF BUS LINES (SDA, SCL) FOR I C-BUS Compatible Devices 2 I C BUS Load Conditions STANDARD MODE: Pull up resistance 4kΩ (Connected to VDD), Load capacitance 200pF (Connected to GND) FASE MODE: Pull up resistance 4kΩ (Connected to VDD), Load capacitance 50pF (Connected to GND) Standard Mode Fast Mode PARAMETER SYM BOL MIN. TYP. MAX. MIN. TYP. MAX. SCL clock frequency fSCL 10 - 100 10 - 400 kHz Hold time (repeated) START condition tHD:STA 4.0 - - 0.6 - - µs Low period of the SCL clock tLOW 4.7 - - 1.3 - - µs UNIT High period of the SCL clock tHIGH 4.0 - - 0.6 - - µs Set-up time for a repeated START condition tSU:STA 4.7 - - 0.6 - - µs Data hold time tHD:DAT 0 - - 0 - - µs Data set-up time tSU:DAT 250 - - 100 - - ns Rise time of both SDA and SCL signals tr - - 1000 - - 300 ns Fall time of both SDA and SCL signals tf - - 300 - - 300 ns Set-up time for STOP condition tSU:STO 4.0 - - 0.6 - - µs Bus free time between a STOP and START condition tBUF 4.7 - - 1.3 - - µs Capacitive load for each bus line Cb - - 400 - - 400 pF Noise margin at the Low Level VnL 0.5 - - 0.5 - - V Noise margin at the High Level VnH 1 - - 1 - - V Cb: Total capacitance of one bus line in pF. 2 ■TIMING ON THE I C BUS (SDA, SCL) Ver.1 http://www.njr.com/ -7- NJU9101 2 ■CHARACTERISTICS OF I/O STAGES FOR EEPROM I C-BUS (EXSDA, EXSCL) 2 I C BUS Load Conditions Pull up resistance 4kΩ (Connected to VDD), Load capacitance 50pF (Connected to GND) PARAMETER SYMBOL MIN. TYP. MAX. UNIT Low Level Input Voltage VIL 0.0 - 0.3VDD V High Level Input Voltage VIH 0.7VDD - - V Low Level Output Voltage (3mA at SDA pin) VOL 0 - 0.4 Input current each I/O pin with an input voltage between 0.1VDD and 0.9VDD max. Ii -10 - 10 V µA ■CHARACTERISTICS OF BUS LINES (EXSDA, EXSCL) 2 I C BUS Load Conditions Pull up resistance 4kΩ (Connected to VDD), Load capacitance 50pF (Connected to GND) PARAMETER SYMBOL MIN. TYP. MAX. UNIT EXSCL clock frequency fSCL 92 102.3 112.7 kHz Hold time (repeat) START condition tHD:STA 7.2 6.5 5.9 µs Low period of the EXSCL clock tLOW 7.2 6.5 5.9 µs High period of the EXSCL clock tHIGH 3.6 3.3 3.0 µs Set-up time for a repeated START condition tSU:STA 7.2 6.5 5.9 µs Data hold time (EXSDA input) tHD:DAT 0 - - µs Data hold time (EXSDA output) tHD:DAT 7.2 6.5 5.9 µs Data Set-up time (EXSDA input) tSU:DAT 0 - - µs Data Set-up time (EXSDA output) tSU:DAT 7.2 6.5 5.9 µs Rise time of both SDA and SCL signals tr - - 300 ns Fall time of SDA and SCL signals tf - - 300 ns Set-up time for STOP condition tSU:STO 7.2 6.5 5.9 µs Bus free time between a STOP and START condition tBUF 7.2 6.5 5.9 µs Capacitive load for each bus line Cb - - 400 pF Noise margin at the Low level VnL 0.5 - - V Noise margin at the High level VnH 1 - - V Cb: total capacitance of one bus line in pF. ■TIMING ON THE EEPROM I2C BUS (EXSDA, EXSCL) Ver.1 http://www.njr.com/ -8- NJU9101 ■REGISTER DESCRIPTION 2 NJU9101 has register (list shown below) which can access it through I C bus. It can control the external EEPROM address corresponding to each register address from NJU9101. BIT REGISTER EEPROM REGISTER ADDRESS ADDRESS NAME D7 D6 0x00 - CTRL - RST 0x01 - STATUS - - 0x02 - AMPDATA0 AMPDATA [15:8] 0x03 - AMPDATA1 AMPDATA [7:0] 0x04 - AUXDATA0 AUXDATA [15:8] 0x05 - AUXDATA1 AUXDATA [7:0] 0x06 - TMPDATA0 TMPDATA [9:2] 0x07 - TMPDATA1 0x08 - ID 0x09 - ROMADR0 0x0A - ROMADR1 TMPDATA [1:0] D5 D4 D3 SENSCK [1:0] BOOT CLKRUN - D2 D1 D0 MEAS MEAS_SEL [1:0] RDYB OV CERR OFOV - - - - - MEAS_SC ID [7:0] - - - - - ROMADR [10:8] ROMADR [7:0] 0x0B - ROMDATA 0x0C - ROMCTRL ROMDATA [7:0] 0x0D - TEST 0x0E 0x000 ANAGAIN - 0x0F 0x001 BLKCONN0 - 0x10 0x002 BLKCONN1 0x11 0x003 BLKCONN2 0x12 0x004 BLKCTRL 0x13 0x005 0x14 - - ROMERR ROMBUSY ROMSTOP ROMACT ROMMODE [1:0] TEST [7:0] - - - PRE_GAIN [1:0] - BIASSWA BIASSWB ADC_GAIN [1:0] PRE_BIAS [3:0] OPA_BIAS [2:0] OPB_BIAS [4:0] PREMODE INPSWA ADCCONV - ADCCHOP CLKDIV [1:0] 0x006 SYSPRESET RDYBOE RDYBDAT RDYBMODE [1:0] - - - AMPAUX 0x15 0x007 SCAL1A0 - - - - - - - SCAL1A [8] 0x16 0x008 SCAL1A1 0x17 0x009 SCAL2A0 - - - - - - - SCAL2A [8] 0x18 0x00A SCAL2A1 0x19 0x00B SCAL3A0 - - - SCAL3A [8] 0x1A 0x00C SCAL3A1 0x1B 0x00D SCAL4A0 - - - SCAL4A [8] 0x1C 0x00E SCAL4A1 SCAL4A [7:0] 0x1D 0x00F SCAL1B0 SCAL1B [15:8] 0x1E 0x010 SCAL1B1 SCAL1B [7:0] 0x1F 0x011 SCAL2B0 SCAL2B [15:8] 0x20 0x012 SCAL2B1 SCAL2B [7:0] 0x21 0x013 SCAL3B0 SCAL3B [15:8] 0x22 0x014 SCAL3B1 SCAL3B [7:0] 0x23 0x015 SCAL4B0 SCAL4B [15:8] 0x24 0x016 SCAL4B1 SCAL4B [7:0] 0x25 0x017 OCAL1A0 - - 0x26 0x018 OCAL1A1 Ver.1 INPSWB ANASW BIASSWN PAMPSEL BIASSEL VREFSEL BLKCTRL [7:0] REJ [1:0] OSR [1:0] SCAL1A [7:0] SCAL2A [7:0] - - - - - - - - SCAL3A [7:0] - - - - OCAL1A [9:8] OCAL1A [7:0] http://www.njr.com/ -9- NJU9101 0x27 0x019 OCAL2A0 0x28 0x01A OCAL2A1 0x29 0x01B OCAL3A0 0x2A 0x01C OCAL3A1 0x2B 0x01D OCAL4A0 0x2C 0x01E OCAL4A1 0x2D 0x01F OCAL1B0 0x2E 0x020 OCAL1B1 0x2F 0x021 OCAL2B0 0x30 0x022 OCAL2B1 0x31 0x023 OCAL3B0 0x32 0x024 OCAL3B1 0x33 0x025 OCAL4B0 0x34 0x026 OCAL4B1 OCAL4B [7:0] 0x35 0x027 SCAL1 SCAL1 [7:0] 0x36 0x028 SCAL2 SCAL2 [7:0] 0x37 0x029 SCAL3 SCAL3 [7:0] 0x38 0x02A OCAL1 OCAL1 [7:0] 0x39 0x02B OCAL2 OCAL2 [7:0] 0x3A 0x02C OCAL3 OCAL3 [7:0] 0x3B 0x02D AUXSCAL0 AUX_SCAL [15:8] 0x3C 0x02E AUXSCAL1 AUX_SCAL [7:0] 0x3D 0x02F AUXOCAL0 AUX_OCAL [15:8] 0x3E 0x030 AUXOCAL1 AUX_OCAL [7:0] 0x3F - CHKSUM CHKSUM [7:0] Ver.1 - - - - - - OCAL2A [9:8] - - OCAL3A [9:8] - - OCAL4A [9:8] OCAL2A [7:0] - - - - - - - - OCAL3A [7:0] OCAL4A [7:0] - OCAL1B [14:8] OCAL1B [7:0] - OCAL2B [14:8] OCAL2B [7:0] - OCAL3B [14:8] OCAL3B [7:0] - OCAL4B [14:8] http://www.njr.com/ - 10 - NJU9101 ■EVERY REGISTER DESCRIPTION CTRL Register Register Address: 0x00, EEPROM Address: CTRL BIT [7] [6] BIT NAME - RST SENSCK [1:0] MEAS MEAS_SEL [1:0] MEAS_SC R /W - WS RW RW RW RW RESET - - 0x0 0 0x0 0 BIT [5] [4] BIT NAME [3] [2] [1] [0] FUNCTION Write Software Reset. When read this bit, always return “0”. [6] RST 0: 1: No effect Reset Change offset voltage of OPB to check sensor diagnostic. [5:4] [3] SENSCK MEAS 00: 01: 10: 11: OFF (No change) Plus Offset (Change Offset Voltage ≈ +5.0mV) Minus Offset (Change Offset Voltage ≈ -5.0mV) Reserve Measurement Switch When write “1”, ADC conversion starts. When read this bit, returns “1” in case of under conversion, “0” in case of idle condition. When select “Single Conversion” mode, this bit is set to “0” automatically after conversion completion. When select “Continuous Conversion” mode and write “0”, ADC conversion stop and return to an idol state. 0: 1: Measurement OFF (Operating condition of this chip follows “BLKCTRL” condition) Measurement ON Measurement Mode Selection. [2:1] MEAS_SEL 00: 01: 10: 11: Temperature sensor input mode Amplifier input mode Auxiliary input mode Reserve Measurement Mode for ADC [0] Ver.1 MEAS_SC 0: 1: Single Conversion Continuous Conversion http://www.njr.com/ - 11 - NJU9101 STATUS Register Register Address: 0x01, EEPROM Address: STATUS BIT [7] [6] [5] [4] [3] [2] [1] [0] BIT NAME - - BOOT CLKRUN RDYB OV CERR OFOV R /W - - R R R R R R RESET - - 1 - 1 0 0 0 BIT [5] BIT NAME BOOT FUNCTION Booting flag for IC. NJU9101 reads initial register value from external EEPROM as booting. This bit returns “1” until the reading of the initial register value is completed from start. 0: 1: Completion of booting Under booting System Clock Condition. [4] CLKRUN 0: 1: System Clock is sleeping System Clock is operating Data Ready Flag. When conversion data is updated, this bit is cleared to “0”. When either “AMPDATA0”, “AUXDATA0”, or “TMPDATA” is read, this bit is set to “1”. [3] RDYB 0: 1: [2] OV Overflow flag in sensitivity calibration of ADC output data. When over flow is occurred in sensitivity calibration of ADC conversion data, this bit is set to “1”. When this bit is “1”, ADC output data (“AMPDATA” or “AUXDATA”) is set to 0x7FFF (positive over flow) or 0x8000 (negative over flow). When either “AMPDATA0”, “AUXDATA0”, or “TMPDATA” is read, this bit is cleared to “0”. 0: 1: [1] CERR OFOV No overflow in calibration coefficient calculation Overflow in calibration coefficient calculation (Output data is invalid) Overflow flag in offset calibration of ADC output data. When over flow is occurred in offset calibration of ADC conversion data, this bit is set to “1”. In case of “1”, ADC output data is invalid value. When either “AMPDATA0”, “AUXDATA0” or “TMPDATA” is read, this bit is cleared to “0”. 0: 1: Ver.1 ADC conversion data is valid ADC conversion data is over flow (set 0x7FFF or 0x8000) Overflow flag in calibration coefficient data. When over flow is occurred in setting of calibration coefficient data, this bit is set to “1”. In case of “1”, ADC output data is invalid value. When either “AMPDATA0”, “AUXDATA0” or “TMPDATA” is read, this bit is cleared to “0”. 0: 1: [0] New ADC data is ready New ADC data is not ready No overflow in offset calibration data Overflow in offset calibration data (Output data is invalid) http://www.njr.com/ - 12 - NJU9101 AMPDATA0 / AMPDATA1 Register BIT [7] [6] Register Address: 0x02 / 0x03, EEPROM Address: - AMPDATA0 AMPDATA1 Register Address: 0x02 Register Address: 0x03 [5] [4] [3] [2] [1] [0] [7] [6] BIT NAME AMPDATA [15:0] R /W R RESET - BIT BIT NAME AMPDATA0 [7:0] + AMPDATA1 [7:0] AMPDATA[15:0] [7] [6] AUXDATA0 AUXDATA1 Register Address: 0x04 Register Address: 0x05 [5] [4] [3] [2] [1] [0] [7] [6] R /W R RESET - BIT BIT NAME AUXDATA0 [7:0] + AUXDATA1 [7:0] AUXDATA[15:0] [5] [4] [3] [2] [0] [1] [0] ADC output data register for Auxiliary input mode. Signed 16-Bit data. Register Address: 0x06 / 0x07, EEPROM Address: - TMPDATA0 TMPDATA1 Register Address: 0x06 Register Address: 0x07 [5] [1] FUNCTION TMPDATA0 / TMPDATA1 Register [6] [2] Register Address: 0x04 / 0x05, EEPROM Address: - AUXDATA [15:0] [7] [3] ADC output data register for amplifier input mode. Singed 16-Bit data. BIT NAME BIT [4] FUNCTION AUXDATA0 / AUXDATA1 Register BIT [5] [4] [3] [2] [1] [0] [7] [6] [5] [4] [3] [2] [1] [0] BIT NAME TMPDATA [9:0] - - - - - - R /W R/W - - - - - - RESET - - - - - - - ビット TMPDATA0 [7:0] + TMPDATA1 [7:6] Ver.1 ビット名 TMPDATA[9:0] 機能 ADC output data register for Temperature sensor input mode. Signed 8.2 fixed point format. (-45°C to +127.75°C) Temperature calibration calculation is executed by value of TEMPDATA. When calibration is executed by using external temperature sensor, write data which getting from external temperature sensor to this register. http://www.njr.com/ - 13 - NJU9101 ID Register Register Address: 0x08, EEPROM Address: ID BIT [7] [6] [5] [4] BIT NAME [3] [2] [1] [0] ID [7:0] R /W R RESET 0x55 BIT BIT NAME [7:0] ID FUNCTION Fixed value “0x55” is stored as a chip identification code in this register. ROMADR0 / ROMADR1 Register Register Address: 0x09 / 0x0A, EEPROM Address: ROMADR0 ROMADR1 Register Address: 0x09 Register Address: 0x0A BIT [7] [6] [5] [4] [3] BIT NAME - - - - - ROMADR [10:0] R /W - - - - - RW RESET - - - - - 0x0 ビット ビット名 ROMADR0 [2:0] + ROMADR1 [7:0] ROMADR[10:0] [2] [1] [0] [7] [6] [5] [4] [3] [2] [1] [0] 機能 This is EEPROM address selection register that read/write from/to EEPROM. *Be sure to set ROMADR0[4:3] = “00” to control EEPROM. ROMDATA Register Register Address: 0x0B, EEPROM Address: ROMDATA BIT [7] [6] [5] [4] [3] BIT NAME ROMDATA [7:0] R /W RW RESET 0x00 BIT [7:0] BIT NAME FUNCTION ROMDATA In read mode, return a reading data from EEPROM. In write mode, set a writing data to EEPROM. [2] [1] [0] *Be sure to set ROMADR0[4:3] = “00” to control EEPROM. Ver.1 http://www.njr.com/ - 14 - NJU9101 ROMCCTL Register Register Address: 0x0C, EEPROM Address: ROMCCTL BIT [7] [6] [5] [4] [3] [2] BIT NAME - - ROMERR ROMBUSY ROMSTOP ROMACT [1] [0] ROMMODE [1:0] R /W - - RC R WS WS W RESET - - - - 0x0 0x0 0x0 BIT BIT NAME FUNCTION 2 [5] ROMERR When I C bus communication error occurs during accessing to external EEPROM, this bit is set to “1”. It is communication error in the following cases, 1) When NJU9101 outputs address, data, acknowledge data, it receives the EXSDA data different from the EXSDA data which outputs. 2) NJU9101 receives NACK response in the timing which it is expected to receive ACK response. And, It is cleared to “0” when this bit is written in “1”. 0: 1: I2C communication is not error I2C communication is error This bit shows accessing status to external EEOPROM. [4] [3] ROMBUSY ROMSTOP 0: 1: When write “1” to “ROMSTOP” bit, stop accessing to external EEPROM. “ROMBUSY” bit is cleared to “0” immediately. When it stops accessing during writing to external EEPROM, ROM data is not guaranteed. In the read mode, this bit always returns “0”. 1: [2] ROMACT Completion of the access Under accsessing stop accessing to external EEPROM When write “1” to ROMACT bit, start accessing to external EEPROM with following “ROMMODE[1:0]” data. In write “0” case, it is not started accessing. And, to start accessing to external EEPROM, it is necessary that it is not accessing timing to external EEPROM (“ROMBUSY” bit = “0”), and system clock is during operation (“CLKRUN” bit = “1”). In the read mode, this bit always returns “0”. 1: start accessing to external EEPROM Write operation for external EEPROM. In the read mode, this bit returns “0”. 00: [1:0] ROMMODE 01: 10: 11: Read one byte data from external EEPROM (address ROMADR[10:0]), and, store this one byte data to ROMDATA[7:0] bit register in NJU9101. Write ROMDATA[7:0] bit data to register in external EEPROM which is assigned by ROMADR[10:0] address. Load external EEPROM data to Host-register (ex. MPU) Store Host-register setting (ex. MPU) into external EEPROM data. *Be sure to set ROMADR0[4:3] = “00” to control EEPROM. Ver.1 http://www.njr.com/ - 15 - NJU9101 Register Address: 0x0D, EEPROM Address: − TEST Register TEST BIT [7] [6] [5] [4] BIT NAME [3] [2] [1] [0] TEST [7:0] R /W RW RESET 0x00 *This register if for production test purpose. Do not write data to this register. ANAGAIN Register Register Address: 0x0E, EEPROM Address: 0x000 ANAGAIN BIT [7] [6] [5] [4] [3] [2] [1] [0] BIT NAME - - - - PRE_GAIN [1:0] ADC_GAIN [1:0] R /W - - - - RW RW RESET - - - - 0x0 0x0 BIT BIT NAME FUNCTION Pre-amplifier gain selection [3:2] PRE_GAIN 00: 01: 10: 11: 1 V/V 2 V/V 4 V/V 8 V/V Programmable-gain-amplifier in ADC selection [1:0] Ver.1 ADC_GAIN 00: 01: 10: 11: 1 V/V 2 V/V 4 V/V 8 V/V http://www.njr.com/ - 16 - NJU9101 BLKCONN0 Register Register Address: 0x0F, EEPROM Address: 0x001 BLKCONN0 BIT [7] [6] [5] [4] BIT NAME - - BIASSWA BIASSWB PRE_BIAS [3:0] R /W - - RW RW RW RESET - - 0x0 0x0 0x0 BIT BIT NAME [3] [2] [1] [0] FUNCTION This is Switch for connecting “BIASRES” and “OPA positive input” [5] BIASSWA 00: 01: Open “BIASRES” and “OPA positive input” Connect “BIASRES” and “OPA positive input” This is Switch for connecting “BIASRES” and “OPB positive input” [4] BIASSWB 00: 01: Open “BIASRES” and “OPB positive input” Connect “BIASRES” and “OPB positive input” Negative input bias level for PREAMP (From 0.3V to 1.7V are 100mV steps) This bias level is set by “BIASRES” Circuit Block. [3:0] Ver.1 PRE_BIAS VREFIN = 3V or at INTVREF(2.048V) as follows 0000: GND 0001: 0.3V 0010: 0.4V 0011: 0.5V : : 1101: 1.5V 1110: 1.6V 1111: 1.7V http://www.njr.com/ - 17 - NJU9101 BLKCONN1 Register Register Address: 0x10, EEPROM Address: 0x002 BLKCONN1 BIT [7] [6] [5] [4] [3] [2] BIT NAME OPA_BIAS [2:0] OPB_BIAS [4:0] R /W RW RW RESET 0x0 0x0 BIT BIT NAME [1] [0] FUNCTION Bias Level for OPA, This bias level is set by “BIASRES” Block. [7:5] OPA_BIAS VREFIN = 3V or at INTVREF(2.048V) as follows 000: GND 001: 0.3V 010: 0.5V 011: 0.7V 100: 1.0V 101: 1.3V 110: 1.5V 111: 1.7V Bias Level for OPB (From 0.25V to 1.75V are 50mV steps). [4:0] Ver.1 OPB_BIAS VREFIN = 3V or at INTVREF(2.048V) as follows 00000: GND 00001: 0.25V 00010: 0.3V 00011: 0.35V : 11101: 1.65V 11110: 1.7V 11111: 1.75V http://www.njr.com/ - 18 - NJU9101 BLKCONN2 Register Register Address: 0x11, EEPROM Address: 0x003 BLKCONN2 BIT [7] [6] [5] [4] [3] [2] [1] [0] BIT NAME PREMODE INPSWA INPSWB ANASW BIASSWN PAMPSEL BIASSEL VREFSEL R /W RW RW RW RW RW RW RW RW RESET 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 BIT BIT NAME FUNCTION Select PREAMP mode [7] PREMODE 0: 1: Non-Inverted Amplifier mode Instrumentation Amplifier mode OPA positive input connection [6] INPSWA 0: 1: GND AINP Positive input is connected to GND. Positive input is connected to AINP Pin. OPB positive input connection [5] INPSWB 0: 1: GND BINP Positive input is connected to GND. Positive input is connected to BINP Pin. Build in Analog Switch Status [4] ANASW 0: 1: Switch OFF Switch ON On Resistance is 10Ω typ. Absolute Maximum Input Current is ±50mA. Select switch for PREAMP / ADC Negative Input at AMP / AUX input mode. [3] BIASSWN 0: 1: OPB Output / AUXINBIASRES This is selectable bias level set by “PRE-BIAS”. Enable / Disable PREAMP for signal path. [2] PAMPSEL 0: 1: Disable (Bypass PREAMP) Enable Reference Voltage selection for Bias Register [1] BIASSEL 0: 1: Internal Reference (2.048V) External Reference Reference Voltage selection for ADC [0] Ver.1 VREFSEL 0: 1: Internal Reference (2.048V) External Reference http://www.njr.com/ - 19 - NJU9101 BLKCTRL Register Register Address: 0x12, EEPROM Address: 0x004 BLKCNT BIT [7] [6] BIT NAME [5] [4] [3] [1] [0] BLKCTRL [7:0] R /W RW RESET 0x00 BIT [2] BIT NAME FUNCTION Circuit Block Powered down selection. When ADC is in the idle state, circuit block which this bit is set to “0” is automatically powered down. The circuit block which this bit is set to “1” is kept powered on state even in case of ADC idle state. When all bits are “0”, NJU9101 goes “power down mode” except for Digital block. [7:0] Ver.1 BLKCTRL [7]: [6]: [5]: [4]: [3]: [2]: [1]: [0]: BIASRES block OPB block OPA block OSC block PREAMP block INTVREF(2.048V) block ADC block Temperature Sensor block http://www.njr.com/ - 20 - NJU9101 ADCCONV Register Register Address: 0x13, EEPROM Address: 0x005 ADCCONV BIT [7] [6] BIT NAME - ADCCHOP CLKDIV [1:0] REJ [1:0] OSR [1:0] R /W - RW RW RW RW RESET - 0x0 0x0 0x0 0x0 BIT [6] [5] [4] BIT NAME ADCCHOP [3] [2] [1] [0] FUNCTION ADC CHOP Switch. It’s effective in reducing offset Voltage of PREAMP and ADC. Reduce offset voltage by chopping input signal. When this bit is “1”, conversion time becomes long. (ex. 16.2ms(ADCCHOP=”0”) -> 31.1ms(ADCCHOP=”1”)) 0: 1: CHOP OFF CHOP ON Select operation clock frequency for sigma-delta modulator. fOSC=307.2kHz typ. [5:4] CLKDIV 00: 01: 10: 11: fmod=(1/2) x fOSC fmod=(1/4) x fOSC fmod=(1/8) x fOSC fmod=(1/16) x fOSC Select rejection mode for Sinc3 filter [3:2] REJ [1:0] OSR Ver.1 00: 01: 10: 11: 50/60Hz Rejection 50Hz Rejection 60Hz Rejection Reserved Select Decimation ratio for Sinc3 filter. Total Decimation Ratio is decided by REJ / OSC bits combination. http://www.njr.com/ - 21 - NJU9101 ADC Decimation Ratio REJ [1:0] OSR [1:0] 00 01 10 11 00 768 768 640 - 01 384 384 320 - 10 192 192 160 - 11 96 96 80 - ADC Conversion Time [ms] REJ [1:0] OSR [1:0] 00 01 10 11 00 01 10 11 00 01 10 11 00 01 10 11 00 16.2 16.2 13.7 - 31.3 31.3 26.3 - 5 5 4.2 - 15.3 15.3 12.8 - 01 8.7 8.7 7.5 - 16.3 16.3 13.8 - 2.5 2.5 2.1 - 7.8 7.8 6.5 - 10 5.0 5.0 4.3 - 8.8 8.8 7.6 - 1.3 1.3 1.0 - 4.0 4.0 3.4 - 11 3.1 3.1 2.8 - 5.1 5.1 4.5 - 0.6 0.6 0.5 - 2.1 2.1 1.8 - State Single Conversion CHOP: OFF Continuous Conversion CHOP: ON CHOP: OFF CHOP: ON Conversion Time vs Resolution (ADC) CHOP: ON CHOP: OFF ADC Conversion Time 1V/V 2V/V 4 V/V 8 V/V 1 V/V 2 V/V 4 V/V 8 V/V 26.3ms 16 / (16) 16 / (16) 16 / (16) 16 / (16) 16 / (16) 16 / (16) 15.6 / (16) 15.3 / (16) ADC Gain ADC Gain 13.8ms 16 / (16) 16 / (16) 15.2 / (16) 16 / (16) 16 / (16) 16 / (16) 15 / (16) 14.8 / (16) 7.6ms 15 / (16) 14.7 / (16) 14.5 / (16) 14 / (16) 15 / (16) 14.7 / (16) 14.1 / (16) 13.5 / (16) 4.5ms 14 / (16) 14 / (16) 13.5 / (16) 12 / (14.7) 14 / (16) 14 / (16) 13.6 / (16) 12 / (14.7) Noise Free Bit / (Effective Number of Bits), Unit: bit Ver.1 http://www.njr.com/ - 22 - NJU9101 SYSPRESET Register Register Address: 0x14, EEPROM Address: 0x006 SYSPRESET BIT [7] [6] BIT NAME RDYBOE RDYBDAT R /W RW RESET 0x0 BIT [5] [4] [3] [2] [1] [0] RDYBMODE [1:0] - - - AMPAUX RW RW - - - RW - 0x1 - - - 0x0 BIT NAME FUNCTION RDYB terminal direction of GPIO mode [7] RDYBOE [6] RDYBDAT 0: 1: RDYB terminal is input mode RDYB terminal is Output mode Return RDYB terminal level in input mode. Store RDYB terminal level in Output mode. Select function of RDYB terminal [5:4] RDYBMODE 00: 01: 10: 11: RDYB terminal outputs “RDYB” bit in STATUS register. RDYB terminal outputs “RDYB” bit in STATUS register. with open-drain circuit style. RDYB terminal is used as GPIO. Output condition is set by “RDYBDAT” and “RDYBOE”. Reserved Select Calibration channel coefficient assignment. [0] AMPAUX 0: 1: Ver.1 AMPDATA uses SCAL/OCAL calibration coefficient. AUXDATA uses AUX_SCAL / AUX_OCAL calibration coefficient. AMPDATA uses AUX_SCAL / AUX_OCAL calibration coefficient. AUXDATA uses SCAL/OCAL calibration coefficient. http://www.njr.com/ - 23 - NJU9101 SCALxA0 / SCALxA1 Register Register Address: 0x15 to 0x1C, EEPROM Address: 0x007 to 0x00E SCALxA0 (x=1 to 4) SCALxA1 (x=1 to 4) Register Address: 0x15, 0x17, 0x19, 0x1B EEPROM Address: 0x007, 0x009, 0x00B, 0x00D Register Address: 0x16, 0x18, 0x1A, 0x1C EEPROM Address: 0x008, 0x00A, 0x00C, 0x00E BIT [7] [6] [5] [4] [3] [2] [1] BIT NAME - - - - - - - SCALxA [8:0] R /W - - - - - - - RW RESET - - - - - - - - BIT BIT NAME SCALxA0 [0] + SCALxA1 [7:0] SCALxA [8:0] (x=1 to 4) [7] [5] [4] [3] [2] [1] [0] ST 1 order Gain Calibration parameter for AMPDATA. This parameter is signal 9-Bit data. Register Address: 0x1D to 0x24, EEPROM Address: 0x00F to 0x016 SCALxB0 (x=1 to 4) SCALxB1 (x=1 to 4) Register Address: 0x1D, 0x1F, 0x21, 0x23 EEPROM Address: 0x00F, 0x011, 0x013, 0x15 Register Address: 0x1E, 0x20, 0x22, 0x24 EEPROM Address: 0x010, 0x012, 0x014, 0x016 [7] [6] [5] [4] [3] [2] [1] [0] [7] BIT NAME SCALxB [15:0] R /W RW RESET - Ver.1 [6] FUNCTION SCALxB0 / SCALxB1 Register BIT [0] BIT BIT NAME SCALxB0 [7:0] + SCALxB1 [7:0] SCALxB [15:0] (x=1 to 4) [6] [5] [4] [3] [2] [1] [0] FUNCTION Zero-order Gain Calibration parameter for AMPDATA. This parameter is unsigned 16-Bit data. http://www.njr.com/ - 24 - NJU9101 OCALxA0 / OCALxA1 Register Register Address: 0x25 to 0x2C, EEPROM Address: 0x017 to 0x01E OCALxA0 (x=1 to 4) OCALxA1 (x=1 to 4) Register Address: 0x25 to 0x28 EEPROM Address: 0x017 to 0x01A Register Address: 0x29 to 0x2C EEPROM Address: 0x01B to 0x01E BIT [7] [6] [5] [4] [3] [2] BIT NAME - - - - - - OCALxA [9:0] R /W - - - - - - RW RESET - - - - - - - BIT BIT NAME OCALxA0 [1:0] + OCALxA1 [7:0] OCALxA [9:0] (x=1 to 4) [1] [0] [7] [6] [5] [4] [3] [2] [1] [0] FUNCTION ST 1 order Offset Calibration parameter for AMPDATA. This parameter is signed 10-Bit data. OCALxB0 / OCALxB1 Register Register Address: 0x2D to 0x34, EEPROM Address: 0x01F to 0x026 OCALxB0 (x=1 to 4) OCALxB1 (x=1 to 4) Register Address: 0x2D, 0x2F, 0x31, 0x33 EEPROM Address: 0x01F, 0x021, 0x023, 0x025 Register Address: 0x2E, 0x30, 0x32, 0x34 EEPROM Address: 0x020, 0x022, 0x024, 0x026 BIT [7] BIT NAME - [6] [5] [4] OCALxB [14:0] R /W - RW RESET - - BIT BIT NAME OCALxB0 [6:0] + OCALxB1 [7:0] OCALxB [14:0] (x=1 to 4) [3] [2] [1] [0] [7] [6] [5] [4] [3] [2] [1] [0] FUNCTION Zero-order Offset Calibration parameter for AMPDATA. This parameter is signed 15-Bit data. SCALx Register Register Address: 0x35 to 0x37, EEPROM Address: 0x027 to 0x029 SCALx (x=1 to 3) BIT [7] [6] [5] [4] [3] BIT NAME SCALx [7:0] R /W RW RESET - BIT BIT NAME [7:0] SCALx (x=1 to 3) Ver.1 [2] [1] [0] FUNCTION Threshold Temperature for AMPDATA Sensitivity Calibration. Signed 8.0 fixed point format. (-45°C to +127°C) -45°C ≤ SCAL1 < SCAL2 < SCAL3 ≤ +127°C http://www.njr.com/ - 25 - NJU9101 OCALx Register Register Address: 0x38 to 0x3A, EEPROM Address: 0x02A to 0x02C OCALx (x=1 to 3) BIT [7] [6] [5] [4] [3] BIT NAME OCALx [7:0] R /W RW RESET - BIT BIT NAME [7:0] OCALx (x=1 to 3) [7] [6] Register Address: 0x3B / 0x3C, EEPROM Address: 0x02D / 0x02E AUX_SCAL0 AUX_SCAL1 Register Address: 0x3B EEPROM Address: 0x02D Register Address: 0x3C EEPROM Address: 0x02E [5] [4] [3] [2] [1] [0] [7] [6] AUXSCAL [15:0] R /W RW RESET - BIT BIT NAME AUX_SCAL0 [7:0] + AUX_SCAL1 [7:0] AUXSCAL [15:0] [6] [4] [3] [2] AUX_OCAL0 AUX_OCAL1 Register Address: 0x3E EEPROM Address: 0x030 [4] [3] [2] [1] [0] [7] [6] AUXOCAL [15:0] R /W RW RESET - BIT BIT NAME AUX_OCAL0 [7:0] + AUX_OCAL1 [7:0] AUXOCAL [15:0] [0] Register Address: 0x3D / 0x3E, EEPROM Address: 0x02F / 0x030 Register Address: 0x3D EEPROM Address: 0x02F [5] [1] Sensitivity Calibration for AUXDATA. (Auxiliary calibration does not have temperature coefficient). BIT NAME Ver.1 [5] FUNCTION AUX_OCAL0 / AUX_OCAL1 Register [7] [0] Threshold Temperature for AMPDATA Offset Calibration. Signed 8.0 fixed point format. (-45°C to +127°C) -45°C ≤ OCAL1 < OCAL2 < OCAL3 ≤ +127°C BIT NAME BIT [1] FUNCTION AUX_SCAL0 / AUX_SCAL1 Register BIT [2] [5] [4] [3] [2] [1] [0] FUNCTION Offset Calibration for AUXDATA. (Auxiliary calibration does not have temperature coefficient.) http://www.njr.com/ - 26 - NJU9101 CHKSUM Register Register Address: 0x3F, EEPROM Address: CHKSUM BIT [7] [6] [5] [4] [3] BIT NAME CHKSUM [7:0] R /W R RESET - BIT [7:0] Ver.1 [2] [1] [0] BIT NAME FUNCTION CHKSUM Check Sum value of register set value is showed which is read from external EEPROM. Check Sum value is updated in following cases, when start up, when finish reading saved data from in external EEPROM, and when finish roading setting data to host-register from external EEPROM. Check Sum result value is finally showed as 1’s complement. This result is summed unsigned data of each address byte (0x000 to 0x030) in external EEPROM. http://www.njr.com/ - 27 - NJU9101 ■TYPICAL CHARACTERISTICS Ver.1 http://www.njr.com/ - 28 - NJU9101 Ver.1 http://www.njr.com/ - 29 - NJU9101 Ver.1 http://www.njr.com/ - 30 - NJU9101 Ver.1 http://www.njr.com/ - 31 - NJU9101 Ver.1 http://www.njr.com/ - 32 - NJU9101 Ver.1 http://www.njr.com/ - 33 - ■ Application Manual NJU9101 ■APPLICATION NOTE / GLOSSARY NJU9101 consists of the following circuit block. CIRCUIT BLOCK NAME SYMBOL 2 Low Current Operational Amplifier “OPA”、“OPB” Bias Level Setting Register “BIASRES” 10Ω Analog Switch “ANASW” Variable Gain Pre-Amplifier “PREAMP” Temperature Sensor “TempSensor” Internal Reference “INTVREF (2.048V)” 16-Bit sigma delta ADC “16-Bit ADC” Digital Control & Calibration “Control&Calibration” 2 2 “I C” I C Bus Compatible Control NJU9101 is suitable for many kinds of low power analog signal applications by using these circuit blocks. 1. Signal channel selection for Measurement 1.1 Temperature Sensor Measurement Write below code to measure Temperature. No. Ver.1 REGISTER ADDRESS CONTENS 1 Select Temperature Input Mode 2 Select ADC Conversion Mode (Exp. Single Conversion) 0x00 3 Start AD Conversion 4 Check completion of the AD conversion ( “MEAS” bit = “0”) 5 Acquire AD conversion data. (TMPDATA) 0x06 0x07 http://www.njr.com/ REGISTER NAME BIT NAME BIT VALUE MEAS_SEL [2:1] 00 MEAS_SC [0] 0 CTRL TMPDATA0 TMPDATA1 1 MEAS [3] TMPDATA [9:0] - - 34 - ■ Application Manual NJU9101 1.2 System Example 1 (Potentiostat Measurement) Write below code to constitute “potentiostat” and “trans-impedance-amplifier” No. Ver.1 CONTENS REGISTER ADDRESS REGISTER NAME 0x0F BLKCONN0 0x11 BLKCONN2 BIT NAME BIT VALUE BIASSWA [5] 1 BIASSWB [4] 1 BIASSWN [3] 1 OPA_BIAS [7:5] OPB_BIAS [4:0] BLKCTRL [7:0] 1 Connect the switch “BIASRES” and “OPA” 2 Connect the switch “BIASRES” and “OPB” 3 Select output of BIASRES 4 Bias level for “trance-impedance-amplifier” (GND to 1.7V) 5 Bias level for “potentiostat” (GND to 1.75V) 6 Powered on BIASRES, OPA, OPB, OSC 0x12 BLKCTRL 7 Enable PREAMP 0x11 BLKCONN2 PAMPSEL [2] 1 8 Select Amp Input Mode MEAS_SEL [2:1] 01 9 Set Measurement Mode for ADC (ex.: Single conversion) MEAS_SC [0] 0 10 Start measurement 11 Check completion of the AD conversion ( “MEAS” bit = “0”) 12 Acquire AD conversion data (AMPDATA) 0x10 0x00 0x02 0x03 http://www.njr.com/ BLKCONN1 any CTRL AMPDATA0 AMPDATA1 0xF0 1 MEAS [3] AMPDATA [15:0] - - 35 - NJU9101 ■ Application Manual 1.3 System Example 2 (Differential Input) Write below code to constitute “Differential Amplifier Input” by using OPA/OPB. No. Ver.1 CONTENTS REGISTER ADDRESS REGISTER NAME 0x0F BLKCONN0 0x11 BLKCONN2 1 Open OPA input switch 2 Open OPB input switch 3 Select OPA sensor signal input 4 Select OPB sensor signal input 5 Select OPB output 6 Powered on OPA, OPB, OSC 0x12 7 Enable PREAMP 0x11 8 Select Amp Input Mode 9 Set Measurement Mode for ADC (ex.: Single conversion) 0x00 10 Start measurement 11 Check completion of the AD conversion ( “MEAS” bit = “0”) 12 Acquire AD conversion data (AMPDATA) 0x02 0x03 BIT NAME BIT VALUE BIASSWA [5] 0 BIASSWB [4] 0 INPSWA [6] 1 INPSWB [5] 1 BIASSWN [3] 0 BLKCTRL BLKCTRL [7:0] 0x70 BLKCONN2 PAMPSEL [2] 1 MEAS_SEL [2:1] 01 MEAS_SC [0] 0 CTRL AMPDATA0 AMPDATA1 http://www.njr.com/ 1 MEAS [3] AMPDATA [15:0] - - 36 - NJU9101 ■ Application Manual 1.4 System Example 3 (Single Input (Non-Inverting)) Write below code to constitute “Single Amplifier Input” by using OPA/OPB. No. Ver.1 CONTENTS REGISTER ADDRESS REGISTER NAME 0x0F BLKCONN0 0x11 BLKCONN2 1 Open OPA input switch 2 Close OPB input switch 3 Select OPA sensor signal input 4 Connect OPB positive input to GND 5 Select BIASRES output 6 Powered on BIASRES, OPA, OPB, OSC 0x12 7 Enable PREAMP 0x11 8 Select Amp Input Mode 9 Set Measurement Mode for ADC (ex.: Single conversion) Start measurement 11 Check completion of the AD conversion ( “MEAS” bit = “0”) 12 Acquire AD conversion data (AMPDATA) 0x02 0x03 BIT VALUE BIASSWA [5] 0 BIASSWB [4] 1 INPSWA [6] 1 INPSWB [5] 0 BIASSWN [3] 1 BLKCTRL BLKCTRL [7:0] 0xF0 BLKCONN2 PAMPSEL [2] 1 MEAS_SEL [2:1] 01 MEAS_SC [0] 0 0x00 10 BIT NAME CTRL AMPDATA0 AMPDATA1 http://www.njr.com/ 1 MEAS [3] AMPDATA [15:0] - - 37 - NJU9101 ■ Application Manual 1.5 Auxiliary (external Input) Measurement Write below code to constitute “Differential Amplifier Input” by using PREAMP. No. Ver.1 CONTENTS REGISTER ADDRESS REGISTER NAME 0x11 BLKCONN2 BIT NAME BIT VALUE BIASSWN [3] 1 PAMPSEL [2] 1 1 Select AUXIN input 2 Enable PREAMP 3 Select Auxiliary input mode MEAS_SEL [2:1] 10 4 Set Measurement Mode for ADC (ex.: Single conversion) MEAS_SC [0] 0 5 Start measurement 6 Check completion of the AD conversion ( “MEAS” bit = “0”) MEAS [3] 7 Acquire AD conversion data (AUXDATA) AUXDATA [15:0] 0x00 0x04 0x05 CTRL AUXDATA0 AUXDATA1 http://www.njr.com/ 1 - - 38 - ■ Application Manual NJU9101 2. Potentiostat & Ttans-impedance-amp circuit block Potentiostat consists of “OPB”, “Variable Bias Resister (BIASRES)”. “Reference Electrode (RE)” bias voltage is set by “Variable Bias Resister (BIASRES)” using command in “OPB_BIAS” bits. “Trans-impedance-amp(OPA)” connected to the “Working Electrode (WE)” is used to provide an output voltage that is proportional to the cell current. Bias Voltage of OPA is also set by BIASRES using command in “OPA_BIAS” bits. OPA gain is set by external resister (RTIA). And, please connect RL between WE and negative input of OPA. Shorting FET Function NJU9101 has Internal Analog Switch (ANASW). This switch can connect between WE and RE of Chemical Sensor Cell. This Switch is switched on/off by “ANASW” bit. In discrete system, depletion FET (ex. J177) is usually used as shorting FET. But, this switch “ANASW” in NJU9101 is enhancement FET (not depletion FET). Therefore, this switch “ANASW” is effective only during powered on. This means that “ANASW” can’t turn on during powered off. ON resistance of this switch “ANASW” is 10Ω typ. This is to get a quick stabilized time after powered on. Maximum Allowed Current (mA) 3. Junction Temperature (°C) 4. Regarding Sensor Diagnostic Function NJU9101 has Sensor Diagnostic Function using “SENSCK” bits. When “SENSCK” mode turns ON (“1”), Offset Voltage of “OPA” changes around ±5mV. To switch “SENSCK” bits to “0””1””0”, you can get as below waveforms. * This is one of way to Sensor Diagnostic that we propose only. Sensor Condition AOUT Voltage SENSCK OFF SENSCK ON ALL connected 1V 0.6V WE opened 1V 1V CE opened 1V 1V RE opened 0V 0V BOUT Condition Waveform1 Waveform2 Waveform3 ONOFFON Ver.1 Waveform1 Waveform2 Waveform3 All connected WE or CE opened RE opened http://www.njr.com/ - 39 - ■ Application Manual NJU9101 5. Variable Bias Register (BIASRES) “Variable Bias Resister (BIASRES)” for “OPA”, “OPB”, and “PREAMP” are shown in below. The Bias Voltage for these amplifiers are given by resister ladder ratio (total resister = 1.5MΩ). These resister ladder ratio are set by “OPA_BIAS”, “OPB_BIAS”, “PRE_BIAS” registers. Setting Name of these register (ex. 0.5V @ VREFIN=3V) is in VREFIN=3V condition. If VREFIN is not 3V (ex. VREFIN=2.5V), the selected Voltage is shifted as follow. If register setting is “1.5V @ VREFIN=3V”  Actual Voltage is 1.5V * (2.5V/3.0V) = 1.25V And, when “BIASSEL = 0”, BIASSEL_SW is turned on and fixed voltage “INTVREF (2.048V)” is given to the resister ladder shown in figure below. VREFIN=3V TOTAL 1.5MΩ 475k 24k BIASSEL_SW INTVREF 2.048V 150k 1.75 25k 1.7 200k 1.55 25k 1.5 25k 1.45 25k 1.4 1.1 BIN+ 25k 1.05 OPB BOUT 25k 100mVsteps 1.0 25k 0.95 25k BIN- PREAMP 0.9 500k OUTN INN 0.6 25k 50mVsteps 0.55 25k 0.5 25k 0.45 OUTP 0.3 25k INP 0.25 125k GND/0.3/0.5/1.0/1.5/1.7V OPA AIN+ AIN- RTIA AOUT RL Ver.1 http://www.njr.com/ - 40 - ■ Application Manual 6. NJU9101 PREAMP Gain Calculation “Non-Inverted Amplifier” or “Instrumentation Amplifier” is selected by “PREMODE” bit. “Pre-Amplifier-Gain” is selected by “PRE_GAIN” bits. Input Voltage range of INP&INM is “0V” ~ “VDD-1V”. Output Voltage range of OUTP&OUTN is “0.05V” ~ “VDD-0.05V”. * Please design not to exceed Input & Output Voltage range. 6.1. PREMODE = 0 (Non-Inverted Amplifier) INP OUTP R2 V OUTP   V INP   V OUTN   V INN  R1 GAIN  OUTN INN 6.2. R2  V INP  INN  R1 V OUTP  OUTN  R2 1 V INP  INN  R1 Gain PRE_GAIN R1 R2 1 V/V 00 320kΩ 0Ω 2 V/V 01 160kΩ 160kΩ 4 V/V 10 80kΩ 240kΩ 8 V/V 11 40kΩ 280kΩ PREMODE = 1 (Instrumentation Amplifier) INP OUTP V OUTP   V INP   R2  V INP  INN  R1 R2 V OUTN   V INN   R1 R2 OUTN INN Ver.1 GAIN  R2  V INN  INP  R1 V OUTP  OUTN  R2  1 2  V INP  INN  R1 Gain PRE_GAIN R1 R2 1 V/V 00 320kΩ 0Ω 2 V/V 01 160kΩ 80kΩ 4 V/V 10 80kΩ 120kΩ 8 V/V 11 40kΩ 140kΩ http://www.njr.com/ - 41 - ■ Application Manual NJU9101 7. Low Power Management NJU9101 is intended for use in portable devices, so the power consumption is as low as possible in order to ensure a long battery life. Following usage assumption of NJU9101 is in a portable gas detector. And its power consumption is summarized in below. The total power consumption for NJU9101 is below @3V average over time, this excludes any current drawn from any pin, please consider another device’s consumption. < Condition > ~ The system is used about 8 hours a day, and 16 hours a day it is in Standby mode. ~ Basically, Only “OPB” and “BIASRES” block are turned On in Standby mode. ~ Potentiostat Measurement is once per second. ~ Aux Data Measurement is one per minutes. ~ Temperature Measurement is one per minutes. ~ ADC conversion time uses approximately 16.6ms. (OSR=”01”, REJ=”10”, ADCCHOP=”1”) 3-Lead Potentiostat Aux Data Temperature Total Current Potentiostat Measurement Measurement Measurement Consumption 0.5µA 10.5µA 215.5µA 160.5µA 250.5µA 16 (h) 8 (h) 480 (s) 8 (s) 8 (s) 66.6% 33.3% 0.556% 0.009% 0.009% Average Current 0.33µA 3.5µA 1.2µA 0.01µA 0.02µA ANASW ON OFF OFF OFF OFF BIASRES OFF ON ON ON ON OPA OFF ON ON ON ON OPB OFF ON ON ON ON PREAMP OFF OFF ON OFF ON ON Standby Current Consumption Time On a Day Ver.1 ADC OFF OFF ON ON Temp. sensor OFF OFF OFF OFF ON I2C & Logic ON ON ON ON ON http://www.njr.com/ 5.01µA - 42 - ■ Application Manual 8. NJU9101 2 I C-BUS Interface 2 NJU9101 has 2 types of I C bus, one bus communicates to host device such as MCU, the other bus communicates to 2 external EEPROM which is to retain the IC configurations, calibration parameters, .etc. These 2 types of I C bus operate 2 2 independently. NJU9101 operates for host interface as I C slave device, and operates for EEPROM interface as I C Master Device. 2 2 One I C-bus which connects to host device is SCL/SDA, and the other I C-bus which connects to external EEPROM is EXSCL/EXSDA. 2 Communicate I C bus I/O Host Device (e.g.: MPU) SCL Input SDA Input / Open-Drain Output EXSCL Open-Drain Output EXSDA Input / Open-Drain Output External EEPROM uP (I2C Master) SCL Master / Slave NJU9101:Master Serial EEPROM 16kbits (I2C Slave) SDA EXSCL AD0 AD1 NJU9101:Slave EXSDA I2C Master Interface (EEPROM Bridge) I2C Slave Interface AD2 10 (address) 8 (data) Host Register ADC 2 8.1. I C Slave Interface 2 This interface is used for the Host that accesses to registers in NJU9101. NJU9101 is a I C Slave device for the host MCU. The operation of which conversion trigger, conversion data reading, access external EEPROM, .etc. are executed through reading and writing of registers in NJU9101. Registers in NJU9101 are register address 0x00 ~ 0x3F and each address has 8 bits width register. Ver.1 http://www.njr.com/ - 43 - NJU9101 ■ Application Manual 2 ● I C Protocol 2 7bit-I C Slave address consists of a fixed four-bit ‘0x9(b1001)’ and chip address pin ‘AD2’, ‘AD1’, ‘AD1’. In case of write operation, transmit the writing data in following, ‘Slave address’ + ‘Write bit (0)’ + ‘Write Register address’ + ‘Write data’. When more than 2 bites of write data are transmitted, register address are increment automatically, and write the date into corresponding registers. When register address is over 0x3F, return to address 0x00 and lap around. In case of read operation, transmit the data in following, ‘Slave address’ + ‘Write bit (0)’ + ‘Read Register address’ and then transmit ‘repeat start’ command. When more than 2 bites of read data are read, register address are increment automatically, and read the date into corresponding address. When register address is over 0x3F, return to address 0x00 and lap around. Write 4 3 1 S I2C Slave Addr[3:0] AD2 AD1 AD0 W S I2C Slave Addr[3:0] AD2 AD1 AD0 W 2 A 0 A 0 6 8 0 Register Addr[5:0] 0 Register Addr[5:0] A Write Data Byte A Write Data Byte A P Sequential Write 4 3 1 2 6 8 8 A Register Addr 4 Read 3 1 S I2C Slave Addr[3:0] AD2 AD1 AD0 W S I2C Slave Addr[3:0] AD2 AD1 AD0 W 4 Sequential Read 3 2 A 0 A 0 1 6 4 0 Register Addr[5:0] 0 Register Addr[5:0] 2 3 Sr I2C Slave Addr[3:0] AD2 AD1 AD0 R A Sr I2C Slave Addr[3:0] AD2 AD1 AD0 R 4 A Write Data Byte Register Addr+1 A 6 8 Write Data Byte A P Register Addr+N 8 A Read Data Byte A Read Data Byte 3 A P 8 Register Addr 8 A Read Data Byte Register Addr+1 A Read Data Byte Register Addr+N SDA Direction Master = Output / Slave = Input Master = Input / Slave = Output S: Start Condition Sr: Repeat Start Condition P: Stop Condition A: Ack A: Nack R: Read W: Write 2 ● I C external EEPROM Interface 2 I C external EEPROM of 16k-Bit (2kByte) can be connected as a external storage device for NJU9101. ‘Microchip 2 24LC16B’ is used as a standard External EEPROM. Other I C Serial EEPROM with communication compatible can be used. Some areas in external EEPROM are used as preset area for configuration data of NJU9101. The remaining areas in external EEPROM can be used for any uses. NJU9101 supports 4-operations for external EEPROM from host-interface (MCU). · Read data from arbitrary address area in external EEPROM. · Write data to arbitrary address area in external EEPROM. · Load the all data from external EEPROM to host register (MCU). · Store register data in host register (MCU) to external EEPROM. See also, “EVERY REGISTER DESCRIPTION : ROMCTRL” to control the external EEPROM. Ver.1 http://www.njr.com/ - 44 - A P NJU9101 ■ Application manual 2 ● External EEPROM operating flow & External EEPROM I C bus timing Flow chart of access to external EEPROM is shown in below. When access to external EEPROM, system clock has to be operating and ‘ROMBUSY’ bit has to be ‘0’. And it can also access to external EEPROM under ADC conversion (Except for reading the initial register value just after reset release.). RESET idle Start access to EEPROM Read 'ROMBUSY' bit no ROMBUSY=0? yes EEPROM Accessible state ROMBUSY=0 Start access to EEPROM 1 byte Read no 1 byte Write Load register setting Store register setting Set 'ROMADR' register address Set 'ROMADR' register address Set 'ROMDATA'register Write ROMMODE=10 ROMACT=1 Write ROMMODE=11 ROMACT=1 Write ROMMODE=00 ROMACT=1 Write ROMMODE=01 ROMACT=1 Read 'ROMBUSY'bit Read 'ROMBUSY'bit Read 'ROMBUSY' bit Read 'ROMBUSY' bit ROMBUSY=0? yes Read 'ROMDATA' register no no ROMBUSY=0? ROMBUSY=0? no ROMBUSY=0? yes yes Load Complete Store Complete yes Write Complete External EEPROM requires about 5ms of write time internally after write operation. During this period, NJU9101 cannot read/write from/to external EEPROM and external EEPROM returns ‘NACK’ for address byte. When NJU9101 starts to access to external EEPROM, NJU9101 does polling until receive ‘ACK’, and wait for completion of writing time in external EEPROM. When NJU9101 is not connected with external EEPROM, address byte of NJU9101 always receives ‘NACK’. Therefore, External EEPROM Control block in NJU9101 cannot stop polling. In such case, stop accessing to external EEPROM quickly by writing “1” to “ROMSTOP” bit, or it can break out of the polling by generating communication error (“ROMERR”=”1”) with fixed “0” for EXSDA terminal. 2 I C-bus of external EEPROM uses 3-system clock every 1 bit transfer, therefore maximum translate is fin/3[bps]. Ver.1 http://www.njr.com/ - 45 - NJU9101 ■ Application Manual ● ∆Σ ADC control ∆Σ ADC conversion flow is shown in below. RESET Wait Clock start CLKRUN=0 MEAS=0 ROMBUSY=0 Load data from EEPROM CLKRUN=1 MEAS=0 ROMBUSY=1 BLKCNT[4] = 0 Idle with clock stop CLKRUN=0 MEAS=0 ROMBUSY=0 BLKCNT[4] = 1 BLKCNT[4] (OSC Power) BLKCNT[4] = 0 BLKCNT[4] = 1 Wait Clock start Idle CLKRUN=1 MEAS=0 ROMBUSY=0 Write MEAS = 1 Write MEAS = 1 Wait Clock start CLKRUN=0 MEAS=1 MEAS_SC = 1 MEAS_SC MEAS_SC = 0 Continuoua Conversion CLKRUN=1 MEAS=1 MEAS_SC = 1 Conplete Conversion (RDYB=0) Complete Conversion MEAS=0 RDYB=0 BLKCNT[4] (OSC Power) BLKCNT[4] = 0 Ver.1 MEAS_SC = 0 Single Conversion CLKRUN=1 MEAS=1 Write MEAS = 0 BLKCNT[4] = 0 MEAS_SC BLKCNT[4] (OSC Power) BLKCNT[4] = 1 BLKCNT[4] = 1 http://www.njr.com/ - 46 - NJU9101 ■ Application Manual ● Start-Up 2 After power-on reset or release I C reset, start internal clock (OSC) and load data from external EEPROM to NJU9101’s register. During loading, ‘ROMBUSY’ shows ‘1’. After finish loading to NJU9101’s register, NJU9101 becomes idle state or idle state with clock stop which are following BLKCNT [4] setting. ● Idle State “Idle state” means in the state which is not conversion state. In the idle state, ‘BLKCNT [4](OSC power down)’bit changes the powered-on/off of system clock. During stopping the system clock, NJU9101 is idle state with clock stop, and it cannot write the data of NJU9101 register except ‘CTRL’ and ‘BLKCNT’ register. This means that “Please write ‘BLKCNT[4]’=’1’, when change the data of NJU9101 register”. ● Conversion When write ‘MEAS’ bit = ‘1’, conversion starts with following NJU9101 register setting. First, Wake up time of modulator Twu is required after conversion started. TWU = 20 / fmod [sec] Tadc is the time which is divided ‘decimation rate (set in OSR / REJ bit) by fmod (normal modulation clock frequency of ΔΣ modulator ≈ 153.6 kHz). Tadc = Decimation rate / fmod [sec] Standard timing of ADC conversion is defined as Tadc. And, after completion of conversion, it requires around 70 cycle of system clock (70 / fOSC) to do data corrective calculation. This calculation time is defined as Tcal. Tcal = 70 / fOSC ≈ 230µ [sec] ● Single Conversion Conversion time of ‘Single conversion’ is ‘ Twu + 3 * Tadc + ‘Tcal ’. The settling time of ADC requires ‘ 3 * Tadc ’. After complete data correction, data register is updated, and RDYB bit is asserted. Start Conversion Modulator+Sinc3 Filter Tadc Tadc Tadc Tcal Data correction MEAS RDYB Conversion Data AMPDATA Ver.1 http://www.njr.com/ - 47 - NJU9101 ■ Application Manual ● Single Conversion + Chopping Operation Conversion time of ‘Single Conversion + Chopping Operation’ is ‘ Twu + 6 * Tadc + Tcal ’. The settling time of ADC requires ‘ 6 * Tadc ’. After complete data correction, data register is updated, and ‘RDYB’ bit is asserted. And then, ‘MEAS’ bit turns to ‘0’, become idle state again. Chopping operation can cancel offset voltage into ADC by swapping differential positive - negative input. Start Conversion non-inverted input conversion Tadc Modulator+Sinc3 Filter Tadc inverted input conversion Tadc Tadc Tadc Tadc Tcal Data Correction MEAS RDYB AMPDATA Converiosn Data ● Continuous Conversion The first conversion time of ‘Continuous Conversion’ is ‘ Twu + 3 * Tadc + Tcal ’. The settling time of ADC requires Tadc. After complete the first conversion data correction, data register is updated, and RDYB bit is asserted. And after that, data register is updated and RDYB bit is asserted every Tadc. Conversion rate after the first conversion is 1/Tadc [sps]. This conversion is continued until written ‘MEAS = 0’. Start Conversion A Tadc Modulator+Sinc3 Filter Tadc B Tadc C Tadc Tadc Tcal Data Correction Tadc Tcal Tcal MEAS RDYB Conversion Data A AMPDATA Conversion Data B Conversion Data C ● Continuous Conversion + Chopping Operation The first conversion time of ‘Continuous Conversion + Chopping Operation’ is ‘Twu + 6 * Tadc + Tcal’. The settling time of ADC requires ‘6 * Tadc’. After complete data correction, data register is updated, and RDYB bit is asserted. And after that, data register is updated and RDYB bit is asserted every ‘3 * Tadc’. Conversion rate after the first conversion is ‘1/(3 * Tadc)’ [sps]. This conversion is continued until written ‘MEAS = 0’. Start Conversion A Modulator+Sinc3 Filter Tadc Tadc Tadc Tadc Tadc B Tadc Tadc Tadc Tadc Tcal Data Correction Tadc Tadc Tcal MEAS RDYB Conversion Data A AMPDATA Ver.1 http://www.njr.com/ Conversion Data B - 48 - NJU9101 ■ Application Manual ● Conversion at ‘Idle state with Clock Stop’ In case of ‘Idle state with Clock Stop (BLKCNT[4]=0)’, it is necessary an additional time (≈450us) to wake up the clock circuit after start conversion trigger. When ‘Single Conversion’ is set, it turns ‘Idle state with Clock Stop (BLKCNT [4] = 0)’ automatically after complete the conversion. Start Conversion Tadc Modulator+Sinc3 Filter Tadc Tadc Tcal Data Correction MEAS RDYB Wake Up time of Clock Cicuit CLKRUN Conversion Data AMPDATA ● Power-Down Control Power down control signal of each circuit block in NJU9101 is controlled by following registers value ‘MEAS’, ‘MEAS_SEL’, ‘VREFSEL’, ‘PAMPSEL’, and ‘BLKCNT[7:0]’. BIASRES circuit block power down Block BIASRES BLKCNT [7] Power Condition 0 PWR DOWN 1 OPERATE OPA circuit block power down Block OPA MEAS MEAS_SEL [1:0] BLKCNT [5] 0 - 0 1 00 / 10 0 1 01 0 - - 1 MEAS MEAS_SEL [1:0] BLKCNT [6] 0 - 0 1 00 / 10 0 1 01 0 - - 1 Power Condition PWR DOWN OPERATE OPB circuit block power down Block OPB Ver.1 Power Condition PWR DOWN OPERATE http://www.njr.com/ - 49 - NJU9101 ■ Application Manual OSC circuit block power down Block OSC BLKCNT [4] BLKCNT [1] OSC ADC Power Condition 0 0 0 PWR DOWN 1 0 0 - 1 - - - 1 MEAS OPERATE PREAMP circuit block power down Block PREAMP MEAS MEAS_SEL [1:0] PAMPSEL BLKCNT [3] Power Condition 0 - - 0 PWR DOWN 1 00 - - OPERATE 1 01 / 10 0 0 PWR DOWN 1 01 / 10 1 0 - - - 1 MEAS_SEL [1:0] BIASSEL VREFSEL BLKCNT [2] Power Condition 0 - 1 - 0 PWR DOWN 1 00 1 - 0 1 01 / 10 1 0 0 1 01 / 10 1 1 0 - - 1 - 1 - - 0 - - OPERATE 2.048V INTVREF circuit block power down Block INTVREF MEAS OPERATE PWR DOWN OPERATE ADC circuit block power down Block ADC MEAS BLKCNT [1] Power Condition 0 0 PWR DOWN 1 0 - 1 OPERATE Temperature Sensor circuit power down Block Temp. Sensor Ver.1 MEAS_SEL [1:0] BLKCNT [0] Power Condition 0 - 0 PWR DOWN 1 00 0 OPERATE 1 01 / 10 0 PWR DOWN - - 1 OPERATE MEAS http://www.njr.com/ - 50 - NJU9101 ■ Application Manual ● Data Processing nd Analog Input is modulated to PDM signal by 2 Order ΔΣ modulator. And then, this PDM signal changes to PCM signal by Sinc3 Digital Filter. Sinc3 Digital Output data is stored to AMPDATA / AUXDATA / TMPDATA register after data calibration. ● ∆Σ Modulator Normal modulation clock frequency of ΔΣ (Sigma Delta) modulator (fmod) is 153.6 kHz. This frequency (fmod) is the over-sampling clock of the ADC which is divided OSC system clock (fOSC) with setting of ‘CLKDIV’ bit. Modulated ratio of this modulator is 66.7%. When +1.5Vpp of differential signal is input, modulated output goes to +1Vpp. ● Sinc3 Digital Filter rd Digital Filter in NJU9101 is 3 Order Sinc-Filter that has 768 of maximum decimation ratio. This decimation ratio can be set by ‘OSR’ and ‘REJ’ bit. ■ Sinc3 filter frequency example 1 (CHOPPING OFF setting example) Conversion Time = 7.5ms (Single conversion) Decimation Ratio=320 (OSR=01, REJ=10, CLKDIV=00, ADCCHOP=0) ■ Sinc3 filter frequency example 2 (CHOPPING ON setting example) Conversion Time = 13.8ms (Single conversion) Decimation Ratio = 320 (OSR=01, REJ=10, CLKDIV=00, ADCCHOP=1) Ver.1 http://www.njr.com/ - 51 - NJU9101 ■ Application Manual ■ Sinc3 filter frequency example 3 (50 / 60Hz Reduction setting example) Conversion Time = 61.6ms (Single Conversion) Decimation Ratio = 768 (OSR=00, REJ=00, CLKDIV=10, ADCCHOP=0) ■ Sinc3 filter frequency example 4 (Fastest Conversion Time setting example) Conversion Time = 2.8ms (Single Conversion) Decimation Ratio = 80 (OSR=11, REJ=10, CLKDIV=00, ADCCHOP=0) Ver.1 http://www.njr.com/ - 52 - NJU9101 ■ Application Manual ● Data Calibration nd Analog Input is modulated to PDM signal by 2 Order ΔΣ modulator. And then, this PDM signal is changed to signed 19 bit PCM signal (ADCDATA) by Sinc3 Digital Filter. The full-scale range of ADCDATA is -262144 ~ +26143 (0x40000 ~ 0x3FFFF). ADCDATA is stored to AMPDATA / AUXDATA / TMPDATA register after data calibration. Vin Delta-Sigma Modulator PRE AMP PRE_GAIN Digital Filter 19 ADCDATA AMPDATA Calibration Circuit 16 AUXDATA Calibration Circuit 16 TMPDATA Calibration Circuit 10 AMPDATA ADC_GAIN AUXDATA TMPDATA Regarding calculation of ADCDATA, Voltage GAIN of PREAMP (Gpre) and Conversion GAIN of ADC (Gadc) are defined as below, Gain of PREAMP Gain of ADC PAMPSEL PRE_GAIN Gpre ADC_GAIN Gadc 0 XX 1 00 1 1 00 1 01 2 1 01 2 10 4 1 10 4 11 8 1 11 8 When it is assumed that “Vref” :Reference Voltage selected by “VREFSEL”bit. “Vin” :Differential Input Voltage of PREAMP Digital Filter Output (ADCDATA) is output as below, when ADCDATA range is limited as signed 19 bit range (min:-262144(0x40000), max:+262143(0x3FFFF). ADCDATA = 262144 × 𝐺௣௥௘ × 𝐺௔ௗ௖ × Ver.1 http://www.njr.com/ 2 𝑉௜௡ × 3 𝑉௥௘௙ - 53 - NJU9101 ■ Application Manual ● AMPDATA Calibration AMPDATA Calibration has temperature calibration of offset and Sensitivity for ADCDATA. And then, calibrated data is stored to AMPDATA[15:0] register. AMPDATA calibration path is shown in below. OFOV PRE AMP Delta-Sigma Modulator SCAL (SCALx/-45) Digital Filter 8 10 OCAL (OCALx/-45) TMPDATA 8 10 19 ADCDATA + OC (Offset Coefficient) - OV 19 A + SC (Sensitivity Coefficient) 17 10 D0 Divide A/B 19 Limit 16 AMPDATA B 18 + - CERR 10 + 10 OCALA (OCALxA) X 20 + 10 CERR 9 X + OCALB (OCALxB) SCALA (SCALxA) 19 16 + + SCALB (SCALxB) 8 Sensor Coefficients Table Calibration coefficients for offset are set for four temperature areas. For these temperature areas, 0-order coefficient (offset st value: OCALxB at OCALx[C]) and 1 -order coefficient (temperature slope: OCALxA) are set. These temperature area are set by OCALx[C] (-45C ≤ OCAL1 < OCAL2 < OCAL3 ≤ 127C). These coefficients are automatically selected by TEMPDATA value. Offset Calibration coefficient “OC” is signed 17-bits factor and calculated as below Condition Calculation -45 ≤ TEMPDATA [9:2] ˂ OCAL1 OC = [ {TEMPDATA – (-45 x 4) } x OCAL1A ] + (OCAL1B x 4) OCAL1 ≤ TEMPDATA [9:2] ˂ OCAL2 OC = [ {TEMPDATA – (OCAL1 x 4) } x OCAL2A ] + (OCAL2B x 4) OCAL2 ≤ TEMPDATA [9:2] ˂ OCAL3 OC = [ {TEMPDATA – (OCAL2 x 4) } x OCAL3A ] + (OCAL3B x 4) OCAL3 ≤ TEMPDATA [9:2] OC = [ {TEMPDATA – (OCAL3 x 4) } x OCAL4A ] + (OCAL4B x 4) * When ”OC” value exceeds signed 17-bits range (-65536 ~ +65535 (0x10000 ~ 0x0FFFF)), “CERR” bit is set as error flag of offset calibration coefficient. In this situation, AMPDATA is not correct value. And then, ADCDATA and offset coefficient “OC” are summed. Converted DATA “D0” is calculated as below, D0 = ADCDATA + (OC x 4) * When ”D0” value exceeds signed 19-bits range (-262144 ~ +262143 (0x40000 ~ 0x3FFFF)), “OFOV” bit is set as error flag. In this situation, AMPDATA is not correct value. Calibration coefficients for sensitivity are set for four temperature areas. For these temperature areas, 0-order coefficient st (sensitivity value: SCALxB at SCALx[C]) and 1 -order coefficient (temperature slope: SCALxA) are set. These temperature area are set by SCALx[C] (-45C ≤ SCAL1 < SCAL2 < SCAL3 ≤ 127C). These coefficients are automatically selected by TEMPDATA value. Sensitivity Calibration coefficient “SC” is unsigned 18-bits factor and calculated as below. Ver.1 http://www.njr.com/ - 54 - ■ Application Manual NJU9101 Condition Caluculation -45 ≤ TEMPDATA [9:2] ˂ SCAL1 SC = [ {TEMPDATA – (-45 x 4) } x SCAL1A ] + (SCAL1B x 4) SCAL1 ≤ TEMPDATA [9:2] ˂ SCAL2 SC = [ {TEMPDATA – (SCAL1 x 4) } x SCAL2A ] + (SCAL2B x 4) SCAL2 ≤ TEMPDATA [9:2] ˂ SCAL3 SC = [ {TEMPDATA – (SCAL2 x 4) } x SCAL3A ] + (SCAL3B x 4) SCAL3 ≤ TEMPDATA [9:2] SC = [ {TEMPDATA – (SCAL3 x 4) } + (SCAL4B x 4) * When ”SC” value exceeds the range of 8192 ~ 262143 (0x2000 ~ 0x3FFFF), “CERR” bit is set as error flag of sensitivity calibration coefficient. In this situation, AMPDATA is not correct value. And when “SC” value is regarded as signed 2.16 fixed point, this data range is equivalent to 4.0 ~ 0.125. For Sensitivity calculation, offset conversion data “D0” is divided by “SC”. This result (quotient) is rounded to integer, and then, AMPDATA is decided. 𝐷0 × 2ଵସ AMPDATA = Round ቆ ቇ 𝑆𝐶 * When AMPDATA value exceeds signed 16-bits range (-32768 ~ +32767 (0x8000 ~ 0x7FFF)), “OV” bit is set as error flag. In this situation, ADCDATA value is limited to min: -32768(0x8000) or max: +32767(0x7FFF), and then stored to AMPDATA register. Calibration Range Register Set Resolution ±1.0 conv. 14-Bit conv. ±1.0 conv. 14-Bit conv. Offset coef. th OCALxB ±1.0 ±8192 1 / (2^14) 0.5LSB st OCALxA ±0.03125 / °C ±256LSB / °C 1 / (2 to 14) / °C 0.5LSB / °C th SCALxB x0.125 to x4.0 - 61ppm - st SCALxA ±15625ppm / °C - 61ppm / °C - 0 1 Sens coef. 0 1 Offset Offset Area 1 Offset Area 2 Offset Area 3 1.0 OCAL4B OCAL1B -45 OCAL4A OCAL1A OCAL3B 0.0 Offset Area 4 OCAL1 OCAL3A OCAL2 TMPDATA[degree] OCAL3 127 OCAL2A OCAL2B -1.0 1/Gain=Sensitivity Gain Area 1 Gain Area 2 4.0 SCAL2B 1.0 SCAL1B -45 Gain Area 3 SCAL4B Gain Area 4 SCAL4A SCAL2A SCAL3B SCAL3A SCAL1A TMPDATA[degree] SCAL1 SCAL2 SCAL3 127 0.125 Ver.1 http://www.njr.com/ - 55 - NJU9101 ■ Application Manual ● AUXDATA Calibration AUXDATA Calibration has offset and Sensitivity calibration for ADCDATA. And then, calibrated data is stored to AUXDATA[15:0] register. AUXDATA calibration path is shown in below. 16 AUX_SCAL PRE AMP Delta-Sigma Modulator Digital Filter 19 ADCDATA 17 /4 OV OFOV 33 + AUX_OCAL 16 17 X D1 16 17 /2 16 Limit AUXDATA - Conversion Data “D1” after offset calibration is calculated as below. (Low order 2-bit of ADCDATA are rounded down) 𝐴𝐷𝐶𝐷𝐴𝑇𝐴 D1 = Truncate( ) − AUX_OCAL 4 * When “D1” value exceeds signed 17-bits range (-65536 ~ +65535 (0x10000 ~ 0x0FFFF)), “OFOV” bit is set as error flag. In this situation, AUXDATA value is not correct value. For sensitivity calibration, it is multiplied conversion data “D1” by “AUX_SCAL” coefficient. This result (product) is divided by 2^16, and is rounded to integer. And then, AMPDATA is decided. 𝐷1 × 𝐴𝑈𝑋_𝑆𝐶𝐴𝐿 AUXDATA = Round( ) 2ଵ଺ * When AUXDATA value exceeds signed 16-bits range (-32768 ~ +32767 (0x8000 ~ 0x7FFF)), “OV” bit is set as error flag. In this situation, ADCDATA value is limited to min: -32768(0x8000) or max: +32767(0x7FFF), and then stored to AUXDATA register. Calibration Range Register ±1.0 conv. 14-Bit conv. Set Resolution ±1.0 conv. 14-Bit conv. Offset calibration coef. AUX_OCAL ±0.5 ±4096 1 / (2^17) 0.125LSB Sensitivity calibration coef. AUX_SCAL x0.0 to x2.0 - 30.5ppm / °C - ● TMPDATA Calibration TMPDATA data conversion are converted ADCDATA to temperature code. In TMPDATA conversion, fixed setting of these bits “VREFSEL”, “ADC_GAIN”, PRE_GAIN” are used. TMPDATA is converted to signed 10-bits data shown as 0.25C/LSB. The data range of TMPDATA is -45.00C ~ +127.75C (0x34C ~ 0x1FF). When converted value exceeds this range, “OV” bit is set as error flag. In this situation, ADCDATA value is limited to min: -45.00C (0x34C) or max: +127.75C (0x1FF), and then stored to TMPDATA register. Ver.1 http://www.njr.com/ - 56 - NJU9101 ■EVALUATION BOARD・PCB LAYOUT (Note) Install the decoupling capacitor in the proximity of the NJU9101. Ver.1 http://www.njr.com/ - 57 - NJU9101 ■PACKAGE OUTLINE EQFN-24-LE S A 0.10 M 0.7±0.05 0.075 0. 10 M 4.00±0.05 S B 4.00±0.05 S S 0.01 +0.010 -0.008 0.05 S 2.5 +0.06 -0.04 A 1pin C 8 0. B 3. R0 0.40±0.05 8 Ver.1 0.5 2.5 +0.06 -0.04 0.23 +0.06 -0.04 http://www.njr.com/ 0.05 M S AB - 58 - NJU9101 ■SOLDER FOOT PRINT EQFN-24-LE Ver.1 http://www.njr.com/ - 59 - NJU9101 ■PACKING SPECIFICATION EQFN Emboss Taping (TE1) EQFN18-E7 EQFN24-LK EQFN24-LE Remark A 2.25±0.05 4.35±0.05 4.35±0.05 Bottom size Bottom size 4.35±0.05 4.35±0.05 1.5 +0.1/-0 1.5 +0.1/-0 0.5±0.1 1.0±0.1 1.0±0.1 E 1.75±0.1 1.75±0.1 1.75±0.1 F 3.5±0.05 5.5±0.05 5.5±0.05 P0 4.0±0.1 4.0±0.1 4.0±0.1 P0 φ D0 T P1 4.0±0.1 8.0±0.1 8.0±0.1 P2 2.0±0.05 2.0±0.05 2.0±0.05 T 0.25±0.05 0.3±0.05 0.3±0.05 T2 1.0±0.07 1.3±0.07 1.3±0.07 K0 0.65±0.05 - - W 8.0±0.2 12.0±0.3 12.0±0.3 W1 5.5 9.5 9.5 Symbol EQFN18-E7 EQFN24-LK EQFN24-LE A Ø 180 +0/-1.5 Ø 180 +0/-1.5 B Ø 60 +1/-0 Ø 60 +1/-0 D0 Ø 13±0.2 Ø 13±0.2 D1 Ø 21±0.8 Ø 21 ± 0.8 E 2.0±0.5 2.0±0.5 W 9.0 +0.3/-0 13.0 +1.0/-0 B W1 F D1 P2 K0 P1 Thickness 0.1MAX φ D1 A T2 W1 Unit: mm E B C A 2.25±0.05 1.5 +0.1/-0 W B D0 Pull out direction E Symbol D W1 1.2 1.2 Contents 3,000pcs 1,000pcs Unit: mm W Seal area by a cover tape Empty Occupancy 160mm and more Empty cover tape 100mm and more Pull out direction 1 reel and more TE1 Label Put in the outer box Label Ver.1 http://www.njr.com/ - 60 - NJU9101 ■RECOMMENDED MOUNTING METHOD *Recommended reflow soldering procedure f 260℃ e 230℃ 220℃ d 180℃ 150℃ Room Temp. a a:Temperature ramping rate b:Pre-heating temperature time c:Temperature ramp rate d:220℃ or higher time e:230℃ or higher time f:Peak temperature g:Temperature ramping rate b c g : 1 to 4℃/s : 150 to 180℃ : 60 to 120s : 1 to 4℃/s : Shorter than 60s : Shorter than 40s : Lower than 260℃ : 1 to 6℃/s The temperature indicates at the surface of mold package. Ver.1 http://www.njr.com/ - 61 - NJU9101 [ CAUTION ] 1. New JRC strives to produce reliable and high quality semiconductors. New JRC's semiconductors are intended for specific applications and require proper maintenance and handling. To enhance the performance and service of New JRC's semiconductors, the devices, machinery or equipment into which they are integrated should undergo preventative maintenance and inspection at regularly scheduled intervals. Failure to properly maintain equipment and machinery incorporating these products can result in catastrophic system failures 2. The specifications on this datasheet are only given for information without any guarantee as regards either mistakes or omissions. The application circuits in this datasheet are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. All other trademarks mentioned herein are property of their respective companies. 3. To ensure the highest levels of reliability, New JRC products must always be properly handled. The introduction of external contaminants (e.g. dust, oil or cosmetics) can result in failures of semiconductor products. 4. New JRC offers a variety of semiconductor products intended for particular applications. It is important that you select the proper component for your intended application. You may contact New JRC's Sale's Office if you are uncertain about the products listed in this catalog. 5. Special care is required in designing devices, machinery or equipment which demand high levels of reliability. This is particularly important when designing critical components or systems whose failure can foreseeably result in situations that could adversely affect health or safety. In designing such critical devices, equipment or machinery, careful consideration should be given to amongst other things, their safety design, fail-safe design, back-up and redundancy systems, and diffusion design. 6. The products listed in the catalog may not be appropriate for use in certain equipment where reliability is critical or where the products may be subjected to extreme conditions. You should consult our sales office before using the products in any of the following types of equipment. Aerospace Equipment Equipment Used in the Deep sea Power Generator Control Equipment (Nuclear, Steam, Hydraulic) Life Maintenance Medical Equipment Fire Alarm/Intruder Detector Vehicle Control Equipment (airplane, railroad, ship, etc.) Various Safety devices 7. New JRC's products have been designed and tested to function within controlled environmental conditions. Do not use products under conditions that deviate from methods or applications specified in this catalog. Failure to employ New JRC products in the proper applications can lead to deterioration, destruction or failure of the products. New JRC shall not be responsible for any bodily injury, fires or accident, property damage or any consequential damages resulting from misuse or misapplication of its products. Products are sold without warranty of any kind, either express or implied, including but not limited to any implied warranty of merchantability or fitness for a particular purpose. 8. Warning for handling Gallium and Arsenic(GaAs) Products (Applying to GaAs MMIC, Photo Reflector). This Products uses Gallium(Ga) and Arsenic(As) which are specified as poisonous chemicals by law. For the prevention of a hazard, do not burn, destroy, or process chemically to make them as gas or power. When the product is disposed, please follow the related regulation and do not mix this with general industrial waste or household waste. 9. The product specifications and descriptions listed in this catalog are subject to change at any time, without notice. Ver.1 http://www.njr.com/ - 62 -
NJU9101MLE-TE1
物料型号:NJU9101
器件简介: NJU9101是一款用于微功耗传感应用的低功耗模拟前端集成电路,尤其适用于电化学传感器。它提供了传感器和微处理器之间的完整信号处理解决方案,可作为智能传感器模块使用。
引脚分配: - SCL和SDA为I2C通信接口 - EXSCL和EXSDA用于外部EEPROM的I2C通信 - ADO、AD1、AD2用于选择芯片地址 - TEST用于生产测试 - VDD为电源供应 - VREFA+和VREFIN用于模拟信号参考电压输入 - AIN+和AIN-为操作放大器A的输入 - AOUT为操作放大器A的输出 - 其他引脚包括地、电源、模拟和数字输入输出等
参数特性: - 供电电压范围:+2.4到+3.6V - 工作温度范围:-40°C到+85°C - 具有两个低功耗运算放大器,提供potentiostat和trans-impedance放大器以构成气体传感器系统 - 可编程单元偏置电压和可编程增益前置放大器 - 高分辨率可编程增益ADC,16位,32sps到2ksps
功能详解: - 系统校准以补偿偏移和增益漂移 - 作为外部EEPROM的主机设备进行控制 - 具有多种应用,如气体监测器、血糖计、电流感测系统、低功耗系统、光电二极管感测系统和便携设备
应用信息: NJU9101适用于多种低功耗模拟信号应用,包括但不限于气体监测、血液葡萄糖测量、电流感测、低功耗系统和便携设备。
封装信息: - 封装类型:EQFN-24-LE (4mm x 4mm) - 引脚数量:24 - 封装特点:小尺寸、低高度、热增强型
NJU9101MLE-TE1 价格&库存
很抱歉,暂时无法提供与“NJU9101MLE-TE1”相匹配的价格&库存,您可以联系我们找货
