NJW1504/1508
PLL Synthesizer with I2C Bus for TV Tuner
n DESCRIPTION
The NJW1504/1508 are a PLL frequency synthesizer especially
designed for TV and VCR tuning systems and consists of PLL circuit
and a prescaler which operates up to 1.0GHz, built into one chip.
The NJW1504/1508 are controlled through an I2C-bus.
n PACKAGE OUTLINE
n FEATURES
• Operating Voltage 5V
• Low Operating Current : 15mA typ. @Vcc=5V
NJW1504V/NJW1508V
• Prescaler accepts frequencies up to 1GHz on chip
• Reference Signal :
NJW1504: Reference Signal Oscillator with peripheral of Xtal on chip
NJW1508: Buffer Amplifier for External Reference Signal on chip
• 34V max. tuning voltage output
• Package Outline: SSOP16
n BLOCK DIAGRAM
BAND SW
4bit
1/8
HF IN
VCC1
5V GND
VCC3
BS0-BS3
I2C
Receive
Bus
r
4bit
Latch
ADRS
SDA
SCL
15bit
Latch
Programmable
Divider 15bit
PreAMP
CP
8bit
Latch
VCC2
OSCOUT
AMPOUT
Phase
OUT
AMP
Phase
Comp.
1/1024
1/512
(1/640)
Ref.
Divider
X’tal
OSC
XTAL
(Note)
Purchase of I2C components of New Japan RadioCo.,Ltd or one of its sublicensed Associated Companies conveys a license
under the Philips I2C Patent Rights to use these components in an I2C system, provided that the system conforms to the I2C
standard specification as definedby by Philips.
-1-
NJW1504/1508
n ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Supply Voltage (Vcc1, 3)
Vcc1, Vcc3
Supply Voltage (Vcc2)
Vcc2
Input Voltage (except I2C bus)
Vi
2
Output Voltage (except I C bus)
Vo
I2C bus Input Voltage
Power Dissipation
Operating Temperature Range
Storage Temperature Range
Viiic
PD
Topr
Tstg
Ratings
-0.3 to +6.5
-0.3 to +36
-0.3 to Vcc+0.3
-0.3 to Vcc+0.3
(TA=25°C)
Unit
V
V
V
V
-0.3 to 6.5
300
-20 to +85
-40 to +125
V
mW
°C
°C
n RECOMMENDED OPERATING CONDITION
Parameter
Condition
Symbol
Operating Voltage
Vcc1, Vcc3
Vcc1, Vcc3
Operating Voltage
Vcc2
Vcc2
X’tal Operating Range
fxtal
HF Input Frequency
Input= -20dBm
fhf
Clock Frequency
fSCL
Bus Free Time
tBUF
Data Hold Time
tHDSTA
SCL Low Hold Time
tLOW
SCL High Hold Time
tHIGH
Set-up Time
Refer to I2C bus Timing Chart
tSUSTA
Data Hold Time
tHDDAT
Data Set-up Time
tSUDAT
Rise Time
tR
Fall Time
tF
Data Set-up Time
tSUSTO
Min.
4.5
80
2
4.7
2
2
4
Typ.
5
4
Max.
5.5
34
4.05
1000
100
1000
300
(T A=25°C)
Unit
V
V
MHz
MHz
KHz
uS
uS
uS
uS
uS
uS
nS
nS
nS
uS
SDA
t BUF
SCL
t
t HIG H
t LOW
t
t SU;DAT
HD;STA
t
R
t HD;DAT
t
F
t SU;STA
VIH min(0.7 Vcc1) and VILmax(0.3 Vcc1)
-2-
HD;STA
t S U;STO
NJW1504/1508
n ELECTRICAL CHARACTERISTICS
Parameter
Condition
Operating Current 1
fHF =100MHz
Operating Current 2
AMPOUT: Low Level
AMP Input Current
Phase OUT: High Imp (2.5V)
ANP OUT: Low Level
AMP Output Current
AMPOUT Input=5V
AMP Gain
f=1KHz
Phase Comparator
Current Source
Output Current
Phase Comparator
Current Sink
Output Current
Band Switch
“L” Output Current
BS0=BS1=0.3V
“H” Output Current
BS0=BS1=4.7V
“L” Output Current
BS2=BS3=0.3V
“H” Output Current
BS2=BS3=4.7V
I2C bus
“H” Input Current
SCL, SDA Terminal
“L” Input Current
SCL, SDA Terminal
“H” Input Voltage Range
SCL, SDA Terminal
“L” Input Voltage Range
SCL, SDA Terminal
ACK Sink Current
ACK Output, SDA=0.4V
(Vcc1,3=5V,Vcc2=34V,TA=25°C)
Symbol Min.
Typ.
Max.
Unit
ICC
12
15
21
mA
ICC 2
1.6
mA
IIN
(-50)
0.1
(50)
nA
IOUT
-2
mA
AV
40
50
60
dB
Isourse
190
280
400
uA
Isink
-400
-280
-190
uA
IOBS0-1L
IOBS0-1H
IOBS2-3L
IOBS2-3H
-2.0
11.0
-2.0
5.5
-1
15.0
-1.0
7.5
mA
mA
mA
mA
IIN H
IINL
VIH
VIL
VACK
-5
-5
3.5
5
5.3
1.5
uA
uA
V
V
mA
-3-
NJW1504/1508
n TEST CIRCUIT
34V
VS3
5V
SDA
5V
2mV
VS2
1kHz
2.5V
SCL
270
OSC OUT
18p
100
316k
4MHz
SCL
OSC OUT
VCC2
AMP OUT
CP
BS3
BS2
BS1
BS0
9
VCC3
10
SDA
11
VCC1
12
ADRS
13
GND
14
XTAL
15
HF
16
1
2
3
4
5
6
7
8
1n
50
SG
5V
-20dBm
VS1
4.7V or 0.3V
COUNTER
-4-
NJW1504/1508
n I2C bus Protocols
The input information, which consists of chip address and next two or four byte data, is received by I2C bus
receiver. The allowable I2C bus protocols are as follows.
(1) STA CA CB BB STO
(2) STA CA D1 D2 STO
(3) STA CA CB BB D1 D2 STO
(4) STA CA D1 D2 CB BB STO
STA: Start Condition
STO: Stop Condition
CA: Chip Address
CB: Control Byte
BB: Band switch Byte
D1: Divider Byte 1
D2: Divider Byte 2
For suitable circuit operation,5-byte data should have chip address, 2-byte control data, band data, and 2-byte
divider byte. Following chip address. 2-byte data is received. For distinction of each data, first and third data
byte has a function bit. As function bit, divider byte has “1” and control/band data has “0”.
SDA
SCL
1-7
STA
ADDRESS
8
R/W
9
ACK
1 -7
8
DATA
9
9
ACK
ACK
STO
-5-
NJW1504/1508
n Data Format
Parameter
Chip Address
Divider Byte 1
Divider Byte 2
Control Byte
Band switch Byte
Symbol
CA
D1
D2
CB
BB
MSB
1
N7
1
1
N14
N6
CP
N13
N5
T2
N12
N4
T1
N11
N3
T0
BS3
CA1
N10
N2
RD1
BS2
CA0
N9
N1
RD0
BS1
N8
N0
BS0
LSB
A
A
A
A
A
· Data specifications
: don’t care ;0 or 1
CA1, CA0
: Programmable address bits
ADRS Voltage
CA1
CA0
Always valid
0 to 0.1 Vcc1
1
0.4 Vcc1 to 0.6 Vcc1
1
1
0.9 Vcc1 to Vcc1
BS0 to BS3
N0 to N14
: Band switch buffers Control bits, BSn=1 then “ON”
: Control of Programmable divider bits, N14=MSB N0=LSB
Dividing ratio : N=214 ×N14+213× N13+······ +21×N1+N0
Maximum division ratio 32767
Minimum division ratio
256
CP : Charge Pump Current
CP
Charge Pump Current
1
280µA
60µA
T0 to T2
Conditions
Normal, Default
Test
:Test mode bits
T0,T1,T2 :Phase Comparator Output bits
T2
T1
T0
Phase Comparator, Band Switch
Normal Output
1
Phase Comparator (High Impedance)
1
1
Phase Comparator (Sink)
1
1
1
Phase Comparator (Source)
RD1,RD0 : Reference Divider bits
RD1
RD2
Reference Divider
1
1
512
1024
(Note)
Default : Power on reset
-6-
Conditions
Default
Conditions
Normal, Default
Test
Test
Test
NJW1504/1508
n TERMINAL CHARACTERISTICS
Typ.DC
No.
Symbol
Voltage (V)
Equivalent Circuit
Function
High Frequency
Signal Input
1
1
HF
3.2
2
GND
GND
3
VCC1
5
2
Power Supply
4
4
VCC3
Band Switch
Power Supply
5
2
5,6
5
6
BS3
BS2
7
8
BS1
BS0
CP
Band Switch
(Typ: 7.5mA)
7,8
Band Switch
(Typ: 15mA)
9
Charge Pump
Output
-7-
NJW1504/1508
No.
Symbol
Typ.DC
Voltage (V)
10
AMPOUT
11
VCC2
34
12
OSCOUT
4.1
13
SCL
14
SDA
15
ADRS
16
XTAL
3.3
-8-
Equivalent Circuit
11
Function
10
Amplifier Output
Amplifier
Power Supply
12
Reference Oscillator
Output
SCL Input
(I2C bus)
13
SCL Input
(I2C bus)
14
15
16
ADRS Input
(I2C bus)
Crystal Input
NJW1504/1508
n TYPICAL CHARACTERISTICS
TA=25°C
VCC1 Supply Current Curve
XTAL Input Sensitivity Curve
40.0
NJW1508 XTAL:50ome/0.1uF
[dBm]
[mA]
-10
30.0
20.0
Input Level
Supply Current
25.0
15.0
-20
-30
10.0
-40
5.0
0.0
-50
0.0
1.0
2.0
3.0
4.0
VCC1 Supply Voltage
5.0
6.0
7.0
8.0
2.5
3.0
3.5
[V]
BS0-BS1 Output Current Curve
5.0
5.5
VCC1=VCC3=5.0V
25.0
20.0
[mA]
40.0
30.0
15.0
Output Current
[mA]
Output Current
4.5
[MHz]
BS3 Output Current Curve
VCC1=VCC3=5.0V
50.0
4.0
Input Frequency
20.0
10.0
10.0
5.0
0.0
0.0
3.0
3.5
4.0
Output Voltage
4.5
[V]
5.0
3.0
3.5
4.0
Output Voltage
4.5
5.0
[V]
-9-
MEMO
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
很抱歉,暂时无法提供与“NJW1508V-TE1#”相匹配的价格&库存,您可以联系我们找货
