HEF4541B
Programmable timer
Rev. 6 — 25 November 2021
Product data sheet
1. General description
The HEF4541B is a programmable timer. It consists of a 16-stage binary counter, an integrated
oscillator to be used with external timing components, an automatic power-on reset and output
control logic. The external components RTC and CTC determines the frequency of the oscillator
within the frequency range 1 Hz to 100 kHz. An external clock signal at input RS can replace the
oscillator. The timer advances on the positive-going transition of RS. A LOW on the auto reset input
(AR) and a LOW on the master reset input (MR) enables the internal power-on reset. A HIGH level
at input MR resets the counter independent on all other inputs. Resetting, disables the oscillator to
provide no active power dissipation.
A HIGH at input AR turns off the power-on reset to provide a low quiescent power dissipation of the
8 10 13
16
timer. The 16-stage counter divides the oscillator frequency by 2 , 2 , 2 or 2 depending on the
state of the address inputs (A0, A1). The divided oscillator frequency is available at output O. The
phase input (PH) features a complementary output signal. When the mode select input (MODE) is
n
LOW the timer is a single transition timer and when HIGH the timer is a 2 frequency divider.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually
ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Wide supply voltage range from 3.0 V to 15.0 V
CMOS low power dissipation
High noise immunity
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Complies with JEDEC standard JESD 13-B
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
HEF4541BT
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
HEF4541B
Nexperia
Programmable timer
4. Functional diagram
AR
MR
PH
5
6
RS
CTC
RTC
3
2
1
A0
12
CP
POWER-ON
RESET
CD
A1
MODE
13
10
CONTROL INPUTS
8
OUTPUT
STAGE
BINARY
COUNTER
O
9
001aai581
Fig. 1.
Functional diagram
CTC
RTC
28 COUNTER
CP
RESET
RS
28
28 COUNTER
CP
RESET 22 25 28
A0
MUX
A1
AR
POWER-ON
RESET
LATCH
MR
MODE
PH
O
001aai583
Fig. 2.
Logic diagram
HEF4541B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 14
HEF4541B
Nexperia
Programmable timer
5. Pinning information
5.1. Pinning
HEF4541B
RTC
1
14 VDD
CTC
2
13 A1
RS
3
12 A0
n.c.
4
11 n.c.
AR
5
10 MODE
MR
6
9
PH
VSS
7
8
O
001aai582
Fig. 3.
Pin configuration for SOT108-1 (SO14)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
RTC
1
external resistor connection
CTC
2
external capacitor connection
RS
3
external resistor connection (RS) or external clock input
n.c.
4, 11
not connected
AR
5
auto reset input (active low)
MR
6
master reset input
VSS
7
ground (0 V)
O
8
timer output
PH
9
phase input
MODE
10
mode select input
A0, A1
12, 13
address inputs
VDD
14
supply voltage
HEF4541B
Product data sheet
3 / 14
HEF4541B
Nexperia
Programmable timer
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
MODE
Input
AR
MR
PH
MODE
H
L
X
X
auto reset disabled
L
L
X
X
auto reset enabled[1]
X
H
X
X
master reset active
X
L
X
H
normal operation selected division to output
X
L
X
L
single-cycle mode[2]
X
L
L
X
output initially LOW after reset
X
L
H
X
output initially HIGH, after reset
[1]
[2]
For correct power-on reset, the supply voltage should be above 8.5 V. For VDD < 8.5 V, disable the auto reset and connect AR to VDD.
n-1
The timer is initialized on a reset pulse and the output changes state after 2 counts and remains in that state (latched). A master
reset or a LOW to HIGH transition on the MODE input, resets this latch.
Table 4. Frequency selection table
A0
A1
Number of
counter stages n
L
L
13
8192
L
H
10
1024
H
L
8
256
H
H
16
65536
7. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
VDD
supply voltage
-0.5
+18
V
IIK
input clamping current
±10
mA
VI
input voltage
IOK
output clamping current
VO < -0.5 V or VO > VDD + 0.5 V
-0.5
VDD + 0.5
±10
mA
II/O
input/output current
O output
±10
mA
Tstg
storage temperature
-65
+150
°C
Tamb
ambient temperature
-40
+125
°C
Ptot
total power dissipation
500
mW
P
power dissipation
100
mW
[1]
Conditions
VI < -0.5 V or VI > VDD + 0.5 V
Tamb = -40 °C to +125 °C
[1]
V
For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C.
HEF4541B
Product data sheet
4 / 14
HEF4541B
Nexperia
Programmable timer
8. Recommended operating conditions
Table 6. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
-40
+125
°C
Δt/ΔV
input transition rise and fall rate
VDD = 5 V
3.75
μs/V
VDD = 10 V
0.5
μs/V
VDD = 15 V
0.08
μs/V
9. Static characteristics
Table 7. Static characteristics
VSS = 0 V; VI = VSS or VDD; unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
Conditions
VDD
Tamb = -40 °C
Tamb = 25 °C
Tamb = 85 °C
Tamb = 125 °C Unit
Min
Max
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
0.05
V
CTC, RTC;
HIGH-level
output current
VO = 2.5 V
5V
-1.4
-1.2
-0.95
-0.95 mA
VO = 4.6 V
5V
-0.5
-0.4
-0.3
-0.3
VO = 9.5 V
10 V
-1.4
-1.2
-0.95
-0.95 mA
VO = 13.5 V 15 V
-4.8
-4.0
-3.2
-3.2
mA
VO = 2.5 V
5V
-1.7
-1.4
-1.1
-1.1
mA
VO = 4.6 V
5V
-0.64
-0.5
-0.36
-0.36 mA
VO = 9.5 V
10 V
-1.6
-1.3
-0.9
-0.9
mA
VO = 13.5 V 15 V
-4.2
-3.4
-2.4
-2.4
mA
HIGH-level
input voltage
|IO| < 1 μA
LOW-level
input voltage
|IO| < 1 μA
HIGH-level
|IO| < 1 μA
output voltage
LOW-level
|IO| < 1 μA
output voltage
mA
O;
HEF4541B
Product data sheet
5 / 14
HEF4541B
Nexperia
Programmable timer
Symbol Parameter
IOL
Conditions
CTC, RTC;
LOW-level
output current
VO = 0.4 V
VDD
Tamb = -40 °C
Tamb = 25 °C
Tamb = 85 °C
Tamb = 125 °C Unit
Min
Max
Min
Max
Min
Max
Min
Max
5V
0.33
0.27
0.20
0.20
mA
VO = 0.5 V
10 V
1.0
0.85
0.68
0.68
mA
VO = 1.5 V
15 V
3.2
2.7
2.3
2.3
mA
VO = 0.4 V
5V
0.64
0.5
0.36
0.36
mA
VO = 0.5 V
10 V
1.6
1.3
0.9
0.9
mA
VO = 1.5 V
15 V
4.2
3.2
2.4
2.4
mA
O;
II
input leakage
current
15 V
±0.1
±0.1
±1.0
±1.0
μA
IDD
supply current IO = 0 A
5V
5
5
150
150
μA
10 V
10
10
300
300
μA
15 V
600
μA
7.5
pF
CI
input
capacitance
Table 8. Reset characteristics
VSS = 0 V; VI = VSS or VDD; see Table 12 for test conditions; unless otherwise specified.
VDD
Min
Max
Min
Max
Min
Max
IDD
5V
80
230
230
μA
10 V
750
250 600
700
700
μA
15 V
1.6
0.5
1.3
1.5
1.5
mA
8.5
5
VDD
supply
current
supply
voltage
HEF4541B
Product data sheet
supply current
for power-on
reset enable;
AR = MR = 0 V;
other inputs at
0 V or VDD
supply voltage
for automatic
reset initialization;
AR = MR = 0 V;
other inputs at
0 V or VDD
Tamb = -40 °C
Tamb = +25 °C Tamb = +85 °C Tamb = +125 °C Unit
Symbol Parameter Conditions
Min Typ Max
V
6 / 14
HEF4541B
Nexperia
Programmable timer
10. Dynamic characteristics
Table 9. Dynamic characteristics
VSS = 0 V; Tamb = 25 °C unless otherwise specified. For test circuit, see Fig. 5.
Symbol Parameter
tpd
propagation
delay
Conditions
10
RS to O; 2
see Fig. 4
13
RS to O; 2
see Fig. 4
tW
pulse width
fclk(max)
fosc
16
selected;
selected;
selected;
Typ[1]
Max
Unit
[2] 348 ns + (0.55 ns/pF)CL
375
750
ns
10 V
139 ns + (0.23 ns/pF)CL
150
300
ns
15 V
102 ns + (0.16 ns/pF)CL
110
220
ns
5V
398 ns + (0.55 ns/pF)CL
425
850
ns
10 V
154 ns + (0.23 ns/pF)CL
165
330
ns
15 V
112 ns + (0.16 ns/pF)CL
120
240
ns
5V
483 ns + (0.55 ns/pF)CL
510
1020
ns
10 V
179 ns + (0.23 ns/pF)CL
190
380
ns
15 V
127 ns + (0.16 ns/pF)CL
135
270
ns
5V
548 ns + (0.55 ns/pF)CL
575
1150
ns
10 V
199 ns + (0.23 ns/pF)CL
210
420
ns
15 V
142 ns + (0.16 ns/pF)CL
150
300
ns
5V
RS LOW; MR HIGH;
see Fig. 4
maximum
clock
frequency
RS; see Fig. 4
oscillator
frequency
Rt = 5 kΩ; Ct = 1 nF;
RS = 10 kΩ; see Fig. 6
Rt = 56 kΩ; Ct = 1 nF;
RS = 120 kΩ; see Fig. 6
[1]
[2]
[3]
Min
5V
RS to O; 2 selected;
see Fig. 4
RS to O; 2
see Fig. 4
Extrapolation formula
VDD
8
60
30
ns
10 V
[3]
30
15
ns
15 V
24
12
ns
5V
8
16
MHz
10 V
15
30
MHz
15 V
18
36
MHz
5V
90
kHz
10 V
90
kHz
15 V
90
kHz
5V
8
kHz
10 V
8
kHz
15 V
8
kHz
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
tpd is the same as tPHL and tPLH.
tW is the same as tWL(min) and tWH(min).
Table 10. Dynamic power dissipation
PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C.
Symbol
Parameter
VDD
Typical formula[1]
PD
dynamic power dissipation
Per package
2
5V
PD = 1300 × fi + (fo × CL × VDD ) μW
10 V
PD = 5300 × fi + (fo × CL × VDD ) μW
15 V
PD = 12000 × fi + (fo × CL × VDD ) μW
2
2
Total, using the on-chip oscillator
2
PD = 1300 × fosc + foCLVDD + 2CTCVDD fosc + 10VDD μW
10 V
PD = 5300 × fosc + foCLVDD + 2CTCVDD fosc + 100VDD μW
15 V
[1]
2
5V
2
2
2
2
PD = 12000 × fosc + foCLVDD + 2CTCVDD fosc + 400VDD μW
fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V;
fosc = oscillator frequency in MHz; CTC = timing capacitance in pF.
HEF4541B
Product data sheet
7 / 14
HEF4541B
Nexperia
Programmable timer
10.1. Waveforms and test circuit
(1)
1/fclk(max)
VI
VM
RS input
VSS
VOH
tWH(min)
tPLH
tWL(min)
tPHL
VM
O output
VOL
VI
MR input
VSS
tWH(min)
aaa-003391
VOL and VOH are typical output voltage levels that occur with the output load.
Measurement points are given in Table 11.
n
(1) 2 pulses as selected by address inputs (A0, A1).
Fig. 4.
Propagation delay clock (RS) to output (O), clock pulse width and maximum clock frequency
Table 11. Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
VDD
G
VI
VO
DUT
CL
RT
001aag182
Test data is given in Table 12.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance.
RT = Termination resistance should be equal to output impedance of Zo of the pulse generator.
Fig. 5.
Test circuit for measuring switching times
Table 12. Test data
Supply
Input
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
≤ 20 ns
50 pF
HEF4541B
Product data sheet
Load
8 / 14
HEF4541B
Nexperia
Programmable timer
11. Application information
RC oscillator timing component limitations
RTCCTC determines the oscillator frequency, provided RTC
很抱歉,暂时无法提供与“HEF4541BT,653”相匹配的价格&库存,您可以联系我们找货
