NJW1504V-TE1
NJW1504V-TE1
    NJR(新日本无线)
    LSSOP16
    IC PLL SYNTH W/I2C BUS 16-SSOP
NJW1504V-TE1 数据手册
NJW1504/1508 PLL Synthesizer with I2C Bus for TV Tuner n DESCRIPTION The NJW1504/1508 are a PLL frequency synthesizer especially designed for TV and VCR tuning systems and consists of PLL circuit and a prescaler which operates up to 1.0GHz, built into one chip. The NJW1504/1508 are controlled through an I2C-bus. n PACKAGE OUTLINE n FEATURES • Operating Voltage 5V • Low Operating Current : 15mA typ. @Vcc=5V NJW1504V/NJW1508V • Prescaler accepts frequencies up to 1GHz on chip • Reference Signal : NJW1504: Reference Signal Oscillator with peripheral of Xtal on chip NJW1508: Buffer Amplifier for External Reference Signal on chip • 34V max. tuning voltage output • Package Outline: SSOP16 n BLOCK DIAGRAM BAND SW 4bit 1/8 HF IN VCC1 5V GND VCC3 BS0-BS3 I2C Receive Bus r 4bit Latch ADRS SDA SCL 15bit Latch Programmable Divider 15bit PreAMP CP 8bit Latch VCC2 OSCOUT AMPOUT Phase OUT AMP Phase Comp. 1/1024 1/512 (1/640) Ref. Divider X’tal OSC XTAL (Note) Purchase of I2C components of New Japan RadioCo.,Ltd or one of its sublicensed Associated Companies conveys a license under the Philips I2C Patent Rights to use these components in an I2C system, provided that the system conforms to the I2C standard specification as definedby by Philips. -1- NJW1504/1508 n ABSOLUTE MAXIMUM RATINGS Parameter Symbol Supply Voltage (Vcc1, 3) Vcc1, Vcc3 Supply Voltage (Vcc2) Vcc2 Input Voltage (except I2C bus) Vi 2 Output Voltage (except I C bus) Vo I2C bus Input Voltage Power Dissipation Operating Temperature Range Storage Temperature Range Viiic PD Topr Tstg Ratings -0.3 to +6.5 -0.3 to +36 -0.3 to Vcc+0.3 -0.3 to Vcc+0.3 (TA=25°C) Unit V V V V -0.3 to 6.5 300 -20 to +85 -40 to +125 V mW °C °C n RECOMMENDED OPERATING CONDITION Parameter Condition Symbol Operating Voltage Vcc1, Vcc3 Vcc1, Vcc3 Operating Voltage Vcc2 Vcc2 X’tal Operating Range fxtal HF Input Frequency Input= -20dBm fhf Clock Frequency fSCL Bus Free Time tBUF Data Hold Time tHDSTA SCL Low Hold Time tLOW SCL High Hold Time tHIGH Set-up Time Refer to I2C bus Timing Chart tSUSTA Data Hold Time tHDDAT Data Set-up Time tSUDAT Rise Time tR Fall Time tF Data Set-up Time tSUSTO Min. 4.5 0 3.15 80 0 4.7 2 4.7 2 2 0 250 4 Typ. 5 4 - Max. 5.5 34 4.05 1000 100 1000 300 - (T A=25°C) Unit V V MHz MHz KHz uS uS uS uS uS uS nS nS nS uS SDA t BUF SCL t t HIG H t LOW t t SU;DAT HD;STA t R t HD;DAT t F t SU;STA I2C bus Timing Chart VIH min(0.7 Vcc1) and VILmax(0.3 Vcc1) -2- HD;STA t S U;STO NJW1504/1508 n ELECTRICAL CHARACTERISTICS Parameter Condition Operating Current 1 fHF =100MHz Operating Current 2 AMPOUT: Low Level AMP Input Current Phase OUT: High Imp (2.5V) ANP OUT: Low Level AMP Output Current AMPOUT Input=5V AMP Gain f=1KHz Phase Comparator Current Source Output Current Phase Comparator Current Sink Output Current Band Switch “L” Output Current BS0=BS1=0.3V “H” Output Current BS0=BS1=4.7V “L” Output Current BS2=BS3=0.3V “H” Output Current BS2=BS3=4.7V I2C bus “H” Input Current SCL, SDA Terminal “L” Input Current SCL, SDA Terminal “H” Input Voltage Range SCL, SDA Terminal “L” Input Voltage Range SCL, SDA Terminal ACK Sink Current ACK Output, SDA=0.4V (Vcc1,3=5V,Vcc2=34V,TA=25°C) Symbol Min. Typ. Max. Unit ICC 12 15 21 mA ICC 2 1.6 mA IIN (-50) 0.1 (50) nA IOUT - - -2 mA AV 40 50 60 dB Isourse 190 280 400 uA Isink -400 -280 -190 uA IOBS0-1L IOBS0-1H IOBS2-3L IOBS2-3H -2.0 11.0 -2.0 5.5 -1 15.0 -1.0 7.5 0 0 - mA mA mA mA IIN H IINL VIH VIL VACK -5 -5 3.5 0 3 0 0 - 5 5 5.3 1.5 - uA uA V V mA -3- NJW1504/1508 n TEST CIRCUIT 34V VS3 5V SDA 5V 2mV VS2 1kHz 2.5V SCL 270 OSC OUT 18p 100 316k 4MHz SCL OSC OUT VCC2 AMP OUT CP BS3 BS2 BS1 BS0 9 VCC3 10 SDA 11 VCC1 12 ADRS 13 GND 14 XTAL 15 HF 16 1 2 3 4 5 6 7 8 1n 50 SG 5V -20dBm VS1 4.7V or 0.3V COUNTER -4- NJW1504/1508 n I2C bus Protocols The input information, which consists of chip address and next two or four byte data, is received by I2C bus receiver. The allowable I2C bus protocols are as follows. (1) STA CA CB BB STO (2) STA CA D1 D2 STO (3) STA CA CB BB D1 D2 STO (4) STA CA D1 D2 CB BB STO STA: Start Condition STO: Stop Condition CA: Chip Address CB: Control Byte BB: Band switch Byte D1: Divider Byte 1 D2: Divider Byte 2 For suitable circuit operation,5-byte data should have chip address, 2-byte control data, band data, and 2-byte divider byte. Following chip address. 2-byte data is received. For distinction of each data, first and third data byte has a function bit. As function bit, divider byte has “1” and control/band data has “0”. SDA SCL 1-7 STA ADDRESS 8 R/W 9 ACK 1 -7 8 DATA 9 9 ACK ACK STO -5- NJW1504/1508 n Data Format Parameter Chip Address Divider Byte 1 Divider Byte 2 Control Byte Band switch Byte Symbol CA D1 D2 CB BB MSB 1 0 N7 1 × 1 N14 N6 CP × 0 N13 N5 T2 × 0 N12 N4 T1 × 0 N11 N3 T0 BS3 CA1 N10 N2 RD1 BS2 CA0 N9 N1 RD0 BS1 0 N8 N0 × BS0 LSB A A A A A · Data specifications × : don’t care ;0 or 1 CA1, CA0 : Programmable address bits ADRS Voltage CA1 CA0 Always valid 0 1 0 0 0 to 0.1 Vcc1 1 0 0.4 Vcc1 to 0.6 Vcc1 1 1 0.9 Vcc1 to Vcc1 BS0 to BS3 N0 to N14 : Band switch buffers Control bits, BSn=1 then “ON” : Control of Programmable divider bits, N14=MSB N0=LSB Dividing ratio : N=214 ×N14+213× N13+······ +21×N1+N0 Maximum division ratio 32767 Minimum division ratio 256 CP : Charge Pump Current CP Charge Pump Current 1 280µA 0 60µA T0 to T2 Conditions Normal, Default Test :Test mode bits T0,T1,T2 :Phase Comparator Output bits T2 T1 T0 Phase Comparator, Band Switch 0 0 × Normal Output 1 0 1 Phase Comparator (High Impedance) 1 1 0 Phase Comparator (Sink) 1 1 1 Phase Comparator (Source) RD1,RD0 : Reference Divider bits RD1 RD2 Reference Divider × 0 640 1 1 512 0 1 1024 (Note) Default : Power on reset -6- Conditions Default Conditions Normal, Default Test Test Test NJW1504/1508 n TERMINAL CHARACTERISTICS Typ.DC No. Symbol Voltage (V) Equivalent Circuit Function High Frequency Signal Input 1 1 HF 3.2 2 GND 0 3 GND 3 VCC1 5 2 Power Supply 4 4 VCC3 Band Switch Power Supply 5 2 5,6 5 6 BS3 BS2 7 8 BS1 BS0 0 9 CP - 0 Band Switch (Typ: 7.5mA) 7,8 Band Switch (Typ: 15mA) 9 Charge Pump Output -7- NJW1504/1508 No. Symbol Typ.DC Voltage (V) 10 AMPOUT - 11 VCC2 34 12 OSCOUT 4.1 13 SCL - 14 SDA - 15 ADRS - 16 XTAL 3.3 -8- Equivalent Circuit 11 Function 10 Amplifier Output Amplifier Power Supply 12 Reference Oscillator Output SCL Input (I2C bus) 13 SCL Input (I2C bus) 14 15 16 ADRS Input (I2C bus) Crystal Input NJW1504/1508 n TYPICAL CHARACTERISTICS TA=25°C VCC1 Supply Current Curve XTAL Input Sensitivity Curve 40.0 NJW1508 XTAL:50ome/0.1uF 0 35.0 [dBm] [mA] -10 30.0 20.0 Input Level Supply Current 25.0 15.0 -20 -30 10.0 -40 5.0 0.0 -50 0.0 1.0 2.0 3.0 4.0 VCC1 Supply Voltage 5.0 6.0 7.0 8.0 2.5 3.0 3.5 [V] BS0-BS1 Output Current Curve 5.0 5.5 VCC1=VCC3=5.0V 25.0 20.0 [mA] 40.0 30.0 15.0 Output Current [mA] Output Current 4.5 [MHz] BS3 Output Current Curve VCC1=VCC3=5.0V 50.0 4.0 Input Frequency 20.0 10.0 10.0 5.0 0.0 0.0 3.0 3.5 4.0 Output Voltage 4.5 [V] 5.0 3.0 3.5 4.0 Output Voltage 4.5 5.0 [V] -9- MEMO [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights.
NJW1504V-TE1 价格&库存
很抱歉,暂时无法提供与“NJW1504V-TE1”相匹配的价格&库存,您可以联系我们找货
