j
NJM2568
Video Amplifier with 75 ohms Driver
■GENERAL DESCRIPTION
■PACKAGE OUTLINE
THE NJM2568 is a video amplifier with 75 ohms drivers, which
includes LPF and BPF of both Y and C system.
THE NJM2568 can compose the output circuit of digital video
items with a little external components. It is suitable for portable
items.
NJM2568V
■FEATURES
●Operating Voltage V 1=4.5 to 5.3V,V 2=2.7 to 5.3V
●Operating Current 9.5mAtyp.V =4.8V
7.3mAtyp.V =3.0V
●Internal LPF,BPF
●Internal Clamp Discharge
●Bipolar Technology
●Package Outline SSOP14
■BLOCK DIAGRAM
12
11
10
COMP.
3
3v
Vreg
4.8v
Blank
LEVEL
CLAMP
GCA
6±3dB
-6dB
2
CLAMP
LPF
ATT
-6dB
+18dB
75ΩDriver
1
8
Blank
LEVEL
4
9
DISC.
5
6
BIAS
14
GCA
6±3dB
-6dB
ATT
7
BPF
13
PowerSave
1.CLAMP REF
2.YIN
3.GCA CTLY/MUTE
4.CLAMP
5.DIS CTL
6.GND
7.GND
8.VSAG
9.VOUT
10.V 1
11.V 1
12.V 2
13.GCA CTLC/POWER SAVE
14.CIN
-1-
j
NJM2568
■ABSOLUTE MAXIMUM RATINGS
PARAMETERS
SYMBOL
Supply Voltage
V
Power Dissipation
PD
Operating Temperature Range
Topr
Storage Temperature Range
Tstg
RATINGS
7.0
300
-20 to +85
-40 to +125
(Ta=25°C)
UNIT
V
mW
°C
°C
■ELECTRICAL CHARACTERISTICS ( Ta=25°C,V 1=4.8V,V 2=3.0V,RL=150Ω)
PARAMETERS
Operating Current 1
Operating Current 1
(Power Save Mode)
Operating Current 2
Operating Current2
(Power Save Mode)
SYMBOL
ICC1
Isave1
Icc2
Isave2
TEST CONDITION
MIN. TYP. MAX. UNIT
9.5
12.5
mA
1.6
2.1
mA
7.3
10.0
mA
0.37
0.9
mA
+6.0
V 1=4.8V,No Signal
V 1=4.8V,Power Save
V 2=3.0V,No Signal
V 2=3.0V,Power Save
(Y Amplifier)
Voltage Gain 1
GvY1
YIN to VOUT,GCACTLY=0.5V
100kHz,0.5Vp-p @Sine Wave
+3.0
+9.0
dB
Voltage Gain 2
GvY2
YIN to VOUT,GCACTLY=2.5V
+13.0 +16.0 +19.0
dB
+3.0
+9.0
dB
+13.0 +16.0 +19.0
dB
(C Amplifier)
Voltage Gain 1
GvC1
Voltage Gain 2
GvC2
CIN to VOUT,GCACTLY=0.5V
4MHz,143mVp-p @Sine Wave
CIN to VOUT,GCACTLC=2.5V
+6.0
(Filter Characteristics)
LPF (YIN)
BPF (CIN)
GfY6M
GfY7.2M
GfY20M
DLY
GfC±1M
GfC±1.6M
GfC500k
GfC20M
DLC
6MHz/100kHz,100mVp-p @Sine Wave
7.2MHz/100kHz,100mVp-p@Sine Wave
20MHz/100kHz,100mVp-p@Sine Wave
Group Delay |GD3MHz-GD6MHz|
±1MHz/4MHz,100mV@Sine Wave
±1.6MHz/4MHz,100mV@Sine Wave
500kHz/4MHz,100mVp-p@Sine Wave
20MHz/4MHz,100mVp-p@Sine Wave
-1.0
-1.5
-1.0
-3.0
60
-25
60
-20
100
-10
-10
90
dB
dB
dB
nsec
dB
dB
dB
dB
nsec
+25
nsec
1.2
Vp-p
0.5
GND
0.5
GND
2.5
0.3
2.5
0.3
V
V
V
V
(YC Delay)
YC Delay
TYC
TYOUT-TCOUT at 4MHz
VOVM
100kHz,Sine Wave,RL=75Ω
(Maximum Output Swing)
V-OUT
(GCA Control Signal)
GCACTLY
GCACTLC
VGC1
VGL1
VGC2
VGL2
GCA Control Voltage
MUTE Voltage
GCA Control Voltage
Power Down Voltage
-2-
j
NJM2568
■TEST CIRCUIT
C IN
V +1
V +2
G C AC TLC
VOUT2
VOUT1
S2
A
B
75Ω 50Ω
47uF
47uF
75Ω
1000pF
1000pF
S4
A
75Ω
1000pF
B
100uF
22uF
0 .1 u F
14
13
12
11
10
9
8
6
7
GND
GND
N JM 2568
1
2
3
4
5
0 .1 u F
1uF
S3
A
B
1M Ω
1000pF
S1
A
75Ω
1uF
20kΩ
B
20kΩ
50Ω
Y IN
G C A C T LY
D IS C .C T L
-3-
NJM2568
MEMO
<注意事項>
このデータブックの掲載内容の正確さには
万全を期しておりますが、掲載内容について
何らかの法的な保証を行うものではありませ
ん。とくに応用回路については、製品の代表
的な応用例を説明するためのものです。また、
工業所有権その他の権利の実施権の許諾を伴
うものではなく、第三者の権利を侵害しない
ことを保証するものでもありません。
很抱歉,暂时无法提供与“NJM2568V-TE2”相匹配的价格&库存,您可以联系我们找货
