NJM2580
SINGLE SUPPLY WIDE BAND 3ch VIDEO AMPLIFIER
Q GENERAL DESCRIPTION
The NJM2580 is a wide band 3ch video amplifier,
operated on a single supply voltage. It is suitable for Y, Pb,
and Pr signal because frequency range is 50MHz.
The NJM2580 is suitable for Set Top Box, AV amplifier,
and other high quality AV systems.
Q PACKAGE OUTLINE
Q FEATURES
O Operating Voltage
4.5 to 5.5V
O Wide frequency range
0dB at 50MHz typ.
O Internal 6dB Amplifier
O Internal 75Ω Driver Circuit (2-system drive)
O Power Save Circuit
O Bipolar Technology
O Package Outline
DIP14, DMP14, SSOP14
NJM2580D
NJM2580M
NJM2580V
Q BLOCK DIAGRAM
VIN1
1
14
V+ 1
75Ω
Driver
6dB
AMP
BIAS
GND1
2
13
VOUT1
VIN2
3
12
V+ 2
6dB
AMP
75Ω
Driver
BIAS
GND2
4
11
VOUT2
VIN3
5
10
V+ 3
6dB
AMP
75Ω
Driver
CLAMP
Ver.6
GND3
6
Power Save
7
REF
9
VOUT3
8
VSAG
-1-
NJM2580
(Ta=25°C)
Q ABSOLUTE MAXIMUM RATINGS
PARAMETERS
Supply Voltage
Power Dissipation
Operating Temperature Range
Storage Temperature Range
SYMBOL
V+
RATINGS
12.0
(DIP) 620
(DMP) 430
(SSOP)520 *
-40 to +85
-40 to +150
PD
Topr
Tstg
UNIT
V
mW
°C
°C
(Note) At on a board of EIA/JEDEC specification. (114.3 x 76.2 x 1.6mm Two layers, FR-4)
Q ELECTRICAL CHARACTERISTICS
PARAMETER
Operating Current
Operating Current
(Power Save)
SYMBOL
ICC
Isave
( V+=5.0V, RL=150Ω, Ta=25°C)
TEST CONDITION
No signal
No signal, Power Save
BIAS input
Vin=1kHz,Sin signal, THD=1%,
CLAMP input
Vin=1MHz, 1.0Vp-p Sin signal
MIN.
TYP.
23.0
MAX.
33.0
UNIT
mA
1.2
mA
2.4
3.0
Vp-p
2.2
2.4
Vp-p
6.4
50
-40
0.3
0.3
65
6.8
-50
dB
MHz
dB
dB
dB
deg
dB
Maximum Output Voltage1
Vom1
Maximum Output Voltage2
Vom2
Voltage Gain
Band Width
Frequency Characteristic
Cross talk 1
Cross talk 2
Differential Gain
Differential Phase
S/N
Power Save Switch Change
Voltage H Level
Voltage L Level
Gv
f
Gf
CTB1
CTB2
DG
DP
SNv
Vin=50MHz / 1MHz, 1.0Vp-p, Sin signal
Vin=4.43MHz, 1.0Vp-p, Sin signal
Vin=50MHz, 1.0Vp-p, Sin signal
Vin=1.0Vpp 10step Video signal
Vin=1.0Vpp, 100% White Video signal
6.0
VthPH
IC Operating
2.0
V+
V
VthPL
IC Waiting
V
Q MODE SWITCH FUNCTION
PIN
Power Save
MODE
H
L
OPEN
NOTES
Power Save: OFF
Power Save: ON (Mute)
-2-
NJM2580
Q EQUIVALENT CIRCUIT (V+=5V)
PIN No.
NAME
INSIDE EQUIVALENT CIRCUIT
V+
1
3
VIN1
VIN2
VIN1
VOLTAGE
V+
20KΩ
270Ω
2.60V
VIN2
V+
V+
5
100Ω
VIN3
100Ω
1.70V
VIN3
V+
13
11
VOUT1
VOUT2
VOUT1
2.55V
5.5KΩ
VOUT2
V+
9
VOUT3
V+
VOUT3
V+
1.35V
750Ω
5.5KΩ
-3-
NJM2580
PIN No.
NAME
PowerSave
7
30KΩ
Power Save
VOLTAGE
0V
50KΩ
V+
V+
VSAG
1.40V
8
VSAG
14
12
10
V+1
V+2
V+3
5V
2
4
6
GND1
GND2
GND3
0V
750Ω
5.5KΩ
-4-
NJM2580
Q TEST CIRCUIT
47uF
0.1uF
0.1uF
75Ω
75Ω
0.01uF
0.01uF
0.1uF
75Ω
75Ω
75Ω
75Ω
10uF
0.01uF
10uF
100uF
22uF
14
V+1
13
VOUT1
12
V+2
11
VOUT2
10
V+3
9
VOUT3
8
VSA
VIN1
1
GND
2
VIN2
3
GND
4
VIN3
5
GND
6
PowerSave
7
3.3uF
75Ω
0.01uF
50Ω
3.3uF
75Ω
10uF
50Ω
3.3uF
75Ω
50Ω
-5-
NJM2580
Q APPLICATION CIRCUIT 1
5V
47µF
0.1µF
0.01µF
75Ω
0.1µF
470µF
0.01µF
0.1µF
75Ω
75Ω
470µF
100µF
22µF
14
V+1
13
VOUT1
12
V+2
11
VOUT2
10
V+3
9
VOUT3
8
VSAG
VIN1
1
GND
2
VIN2
3
GND
4
VIN3
5
GND
6
PowerSave
7
0.01µF
10µF
0.01uF
75Ω
10µF
0.01µF
75Ω
0.1µF
75Ω
5V
Q APPLICATION CIRCUIT 2
5V
1µF
Y in 1
75Ω
1µF
Y in 2
75Ω
1MΩ
0.01µF
9
8
1MΩ
7
10
Pb in 1
6
11
75Ω
12
CTL
5
NJM2584A
13
1µF
Pb in 2
14
Pr in 1
75Ω
10µF
0.01µF
3
4
12
Pr out
NJM2580
0.1µF
0.01µF
11
Pb out
470µF 75 Ω
0.1µF
5
10
6
9
0.1µF
47µF
1
100µF
7
16
470µF 75 Ω
2
1µF
13
0.01µF
3
75Ω
15
2
0.1µF
4
14
10µF
0.01µF
1µF
1
8
Y out
75 Ω
22µF
1µF
Pr in 2
75Ω
47µF 0.1µF
-6-
NJM2580
Q TYPICAL CHARACTERISTICS
Operating Current vs. Supply Voltage
10
40.0
5.0
35.0
Operating Current Icc(mA)
Voltage Gain Gv(dB)
Voltage Gain vs. Frequency
0.0
-5.0
-10
1ch
2ch
3ch
-15
-20
3
100 10
6
6
1 10
25.0
20.0
15.0
10.0
2.0
6
10 10
30.0
100 10
4.0
1.5
1.0
0.5
8.0
10.0
12.0
14.0
Maximum Output Voltage Swing Vom1(Vpp)
Operating Current at Standby State Isave(mA)
2.0
6.0
12.0
8.0
6.0
4.0
2.0
0.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
Supply Voltage V (V)
Voltage Gain vs. Supply Voltage
1Vpp, 1MHz sinewave signal input
Total Harmonic Distortion=1%, 1kHz
8.0
1ch
2ch
3ch
3ch
7.5
Voltage Gain Gv(dB)
10.0
8.0
6.0
4.0
2.0
0.0
2.0
14.0
1ch
2ch
10.0
Maximum Output Voltage Swing vs. Supply Voltage
(CLAMP Type Input)
Maximum Output Voltage Swing Vom2(Vpp)
12.0
Supply Voltage V+ (V)
12.0
10.0
(BIAS Type Input)
vs. Supply Voltage
4.0
8.0
Frequency (Hz)
0.0
2.0
6.0
7.0
6.5
6.0
5.5
4.0
6.0
8.0
10.0
12.0
14.0
5.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
-7-
NJM2580
Channel Gain Difference vs. Supply Voltage
1Vpp, 50MHz/1MHz
4.0
0.6
1ch
2ch
3ch
3.0
Channel Gain Difference dGv(dB)
Gain Frequency Characteristics Gf(dB)
Gain Frequency Characteristics vs. Supply Voltage
2.0
1.0
0.0
-1.0
-2.0
-3.0
-4.0
2.0
4.0
6.0
8.0
10.0
12.0
0.4
0.2
0.0
-0.2
-0.4
-0.6
2.0
14.0
4.0
Cross Talk 1 vs. Supply Voltage
12.0
14.0
-20.0
IN1OUT2
IN1OUT3
IN2OUT1
IN2OUT3
IN3OUT1
IN3OUT2
IN1OUT2
IN1OUT3
IN2OUT1
IN2OUT3
IN3OUT1
IN3OUT2
-25.0
Cross Talk 2 CTB2(dB)
-45.0
Cross Talk 1 CTB1(dB)
10.0
1Vpp, 50MHz sinewave signal input
-40.0
-50.0
-55.0
-60.0
-65.0
-30.0
-35.0
-40.0
-45.0
4.0
6.0
8.0
10.0
12.0
-50.0
2.0
14.0
4.0
6.0
8.0
10.0
12.0
14.0
Differential Gain vs. Supply Voltage
Differential Phase vs. Supply Voltage
1Vpp, 10step video signal input
10.0
4.0
1ch
2ch
3ch
8.0
1ch
2ch
3ch
3.5
Differential Phase DP(deg)
Differential Gain DG(%)
8.0
Cross Talk 2 vs. Supply Voltage
1Vpp, 4.43MHz sinewave signal input
-70.0
2.0
6.0
6.0
4.0
2.0
3.0
2.5
2.0
1.5
1.0
0.5
0.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
0.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
-8-
NJM2580
Signal to Noise Retio vs. Supply Voltage
PowerSave Switching Voltage VthP(V)
Signal to Noise Retio SNv(dB)
100.0
1ch
2ch
3ch
90.0
80.0
70.0
60.0
50.0
40.0
2.0
PowerSave Switching Voltage vs. Supply Voltage
1.0Vpp, 100% white video signal input
4.0
6.0
8.0
10.0
12.0
14.0
2.0
VthPH
VthPL
1.5
1.0
0.5
0.0
2.0
4.0
6.0
8.0
10.0
12.0
14.0
[CAUTION]
The specifications on this data book are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this data book are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-9-
很抱歉,暂时无法提供与“NJM2580M”相匹配的价格&库存,您可以联系我们找货
