MCDP2850BC
MCDP2850BC
    MEGACHIPS(兆芯)
    LFBGA64
    ICDISPLAYPORTCONVERTERHDMI
MCDP2850BC 数据手册
MCDP28x0 DisplayPort1.2a to HDMI2.0 Level Shifter/Protocol Converter [LSPCON] Datasheet Rev B MegaChips’ Proprietary Information MegaChips reserves the right to make any change herein at any time without prior notice. MegaChips does not assume any responsibility or liability arising out of application or use of any product or service described herein except as explicitly agreed upon. MegaChips’ Proprietary Information Page 1 of 33 MCDP28x0 – All other 3D formats forwarded as is Features • • • • • • DisplayPort® (DP) ver. 1.2a receiver – Link rate HBR2/HBR/RBR – 1, 2, or 4 lanes configuration – AUX CH 1 Mbps, HPD out – Supports eDP ASSR scrambler operation HDMI ver. 2.0 transmitter – Max data rate up to 6.0 Gbps/ch – Deep color up to 16 bits per color – 3D video timings, CEC, HPD in – Supports High Dynamic Range (HDR) – Supports scrambling for the higher data rate Level shifter operation (up to 3.4Gbps/ch) – AC-coupled HDMI1.4b to DC-coupled HDMI1.4b – PHY analog repeater (re-driver or re-timer) – 3.3 V DDC/AUX CH signaling support with auto detect – 3.3 V DDC to 5V DDC buffering – I2C-over-AUX to 5V DDC translation – DP HPD_OUT matched to HDMI HPD_IN Protocol converter operation (up to 6.0 Gbps/ch) – DP SST-to-HDMI format conversion – Video and audio forwarding – Pixel encoding format conversion from YCbCr444 to YCbCr420 – Horizontal expansion of VESA CVT to CEA-861 timings – Meta data handing Level shifter – Protocol converter mode switching – Via sideband communication (AUX CH/ DDC) Max video resolution and color depth – 4Kp60Hz, RGB/YCbCr444, 8bpc – 4Kp60Hz, YCbCr420, up to 16bpc – 4Kp30Hz, RGB/YCbCr444, up to 16bpc • YCbCr420 support – YCbCr444-to-420 conversion, up to 16 bpc – YCbCr420 pass through, up to 16 bpc • Stereoscopic 3D forwarding – Conversion from frame sequential over DP to stacked top-bottom 3D over HDMI C28x0-DAT-01p • Audio forwarding – 2-ch, 768 kHz 24bps HBR audio – Up to 8-ch, 192 kHz, 24bps LPCM audio, AC3, DTS • Secure communication – Intel secure communication protocol compliant with LSPCON spec • HDCP content protection – Embedded HDCP keys – HDCP2.2 transmitter – HDCP1.x repeater • Metadata handling – HDMI TX DVI/HDMI mode setting (DPCD register) – YCbCr444-420 conversion (DPCD register) – IEC60958 BYTE3 channel status overwrite – CEA861F INFOFRAME generation – CEA861-3 HDR and Mastering InfoFrame • SCDC read request handling – Polling enabled for HDMI sinks not supporting read request • AUX to I2C bridge for EDID/MCCS pass through • CEC tunneling over AUX CH • Device configuration options – SPI flash for firmware binary image storage required – AUX CH, I2C host interface (optional) • EMI reduction support – Spread spectrum for DP input – Scrambler for DP input and HDMI2.0a output • Low power operation – 412 mW in protocol converter mode – 100 mW in Level shifter mode – 0.1 mW in connected standby mode • ESD specification – +/-6.5 KV HBM, 500 V CDM • Package – 64 LFBGA (7 x 7 mm) • Power supply voltages – 3.3 V I/O; 1.2 V core MegaChips’ Proprietary Information Page 2 of 33 MCDP28x0 Applications • PC notebook/ tablet motherboard • DP/USB Type-C docking station, dongle Figure 1. MCDP28x0 internal block diagram HPD Out 3.3V Tol HPD 5V SAFE (3.3V IO) From OCM To OCM HPD 5V SAFE (3.3V IO) I2C bypass path AUX, AC 3.3V I2C DC 3.3V DP++ Input 1.2V AC, 5.4Gbps XTAL TCLK RESETN CONFIG GPIO C28x0-DAT-01p AUX/I2C Detector I2C Level Shifter To / From OCM Protocol converter path AUX to I2C Converter HDMI Transmitter Protocol converter path DP to HDMI AV Format Converter HDCP RX/ TX/Repeater HDMI DDC HDMI 2.0 Output DC, 3.3V, 6Gbps UART Clock Generation Reset 5V Tol 5V Tol Analog repeater path DP Dual Mode Receiver HPD In UART_RX UART_TX VDD12_ON OCM V186 CEC I2C Slave SPI Controller GPIO VDD12_ON CEC MegaChips’ Proprietary Information – Strictly Confidential Page 3 of 33 SCL SDA SPI_CLK SPI_DI SPI_DO SPI_CSN MCDP28x0 Contents 1. Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 2. Application overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 3. 4. 5. 6. 2.1 Motherboard-down topology . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 2.2 Adaptor topology . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 BGA footprint and pin lists . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 3.1 Ball grid array diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 3.2 Signal mapping sorted by ball (pin) number . . . . . . . . . . . . . . . . . . . . . . . 12 Connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 4.1 Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 4.2 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 4.3 RESETN connection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Package specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 5.1 Package drawing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 5.2 LFBGA 7 x 7 dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 5.3 Marking field template and descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 5.4 Classification reflow profile . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Electrical specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 6.1 Absolute maximum ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 6.2 Power Connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 6.3 DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 6.4 AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 6.4.1 DisplayPort receiver . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 6.4.2 HDMI transmitter I/O specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 6.4.3 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 6.4.4 SPI interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 7. Ordering information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 8. Revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 C28x0-DAT-01p MegaChips’ Proprietary Information Page 4 of 33 MCDP28x0 List of Tables Table 1. Table 2. Table 3. Table 4. Table 5. Table 6. Table 7. Table 8. Table 9. Table 10. Table 11. Table 12. Table 13. Table 14. Table 15. Table 16. Table 17. Table 18. Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 DisplayPort receiver pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 HDMI output pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 System interface pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Power and ground pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Field descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 Absolute maximum ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 DC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 IO DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Maximum speed of operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 DisplayPort receiver characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 HDMI transmitter I/O specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 HDMI transmitter AC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 SPI interface timing, VDD = 3.3 V. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Order codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 Document revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 C28x0-DAT-01p MegaChips’ Proprietary Information Page 5 of 33 MCDP28x0 List of Figures Figure 1. Figure 2. Figure 3. Figure 4. Figure 5. Figure 6. Figure 7. Figure 8. Figure 9. MCDP28x0 internal block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 MCDP2800 motherboard-down use case. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 MCDP2850 adaptor (dongle) use case . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 MCDP28x0 BGA diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 RESETN Connection to MCDP28x0. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 MCDP28x0 package drawing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 MCDP28x0 package dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Marking template . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 I2C timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29 C28x0-DAT-01p MegaChips’ Proprietary Information Page 6 of 33 MCDP28x0 1. Description The MCDP28x0 is a power-optimized DisplayPort1.2a-to-HDMI 2.0 converter device targeted for desktop/mobile PC motherboard-down applications and for DP or USB type-C adaptor (dongle, docking station) applications. This device functions as a level shifter as well as an active protocol converter. In level shifter mode, the device functions as a PHY repeater with optional jitter removal capability. This operating mode provides a low-power means of using an AC-coupled TMDS signal from a dual mode DP (DP++) source to be repeated to the HDMI output. The maximum TMDS character clock frequency in this mode is limited to 340 Mchar/s (per HDMI1.4b specification). In Protocol Converter (PCON) mode, MCDP28x0 functions as a DP branch device receiving AC coupled DisplayPort stream and converting it to HDMI output. The maximum TMDS character clock frequency supported in this mode is up to 600 Mchar/s (as per the HDMI2.0a specification). The MCDP28x0 operates with two power supply voltages: 1.2 V and 3.3 V. It consumes: • 100 mW in PHY analog repeater mode • 412 mW in protocol converter mode • 0.1 mW in connected standby mode (1.2 V power rail disabled) The MCDP28x0 has a DisplayPort1.2a dual-mode receiver and HDMI 2.0a transmitter. The upstream main link can receive DP input at HBR2 rate over 4 lanes and AC-coupled TMDS signal up to 340Mchar/s. It supports DP SST stream on its main link and Manchester-coded AUX signaling or native 3.3 I2C signaling as the side band channel with the DP++ source. The downstream HDMI TX port is HDMI 2.0 specification compliant. The MCDP28x0 is capable of supporting Ultra High-Definition video formats, resolutions as high as 4096 x 2160@60 Hz. It supports RGB/YCbCr video color formats with a color depth of 16 bpc (or 48 bits per pixel) as long as it fits within the DP1.2 and HDMI2.0a link rate. In addition, this device also supports pixel encoding conversion from YCbCr444 to YCbCr420 and YcbCr420 pass-through from a DP input to an HDMI output. High Dynamic Range (HDR) with deep color up to 12bpc at 4Kp60Hz is supported through the conversion of YCbCr444 CVT timing over DP link with horizontal expansion to YCbCr420 CEA timing on the HDMI TX output. This device offers secure reception and transmission of high bandwidth digital audio and video content with HDCP 1.x content protection for the upstream DP interface and HDCP2.2 for the downstream HDMI interface. It also operates as an HDCP1.x repeater between the source and the sink. In addition, it conforms to the secure communication protocol specified in the Intel “LSPCON Security Requirements C28x0-DAT-01p MegaChips’ Proprietary Information Page 7 of 33 MCDP28x0 Architecture Specification” document. The MCDP28x0 comes with embedded HDCP keys that are stored in encrypted form. The MCDP28x0 uses an external crystal of 27 MHz as a reference clock for its operation and it has a reset input which provides the chip reset during system power up. The device has an on-chip microcontroller with SPI, UART, and I2C interfaces for system level communication and debug. It requires an external SPI flash memory for storing device configuration firmware. The firmware update is done through the DP AUX channel or through UART interface. An 8 Mbit SPI flash memory is recommended for storing the firmware with a backup option as fail-safe during in-system-programming. C28x0-DAT-01p MegaChips’ Proprietary Information Page 8 of 33 MCDP28x0 2. Application overview Two important target applications of MCDP28x0 are: • Mobile PC motherboard application. This is referred as motherboard-down topology and the part number that supports this topology is MCDP2800. • Accessory application (dongle, docking station etc.). This is referred as adaptor topology and the part number for this topology is MCDP2850. 2.1 Motherboard-down topology In a Motherboard-down topology, the MCDP2800 resides next to the source (CPU/GPU) device on a same PCB with relatively short copper tracks connecting directly to the source. These tracks are typically micro stripes with controlled impedance of 100 Ω. In this configuration, the source device is aware of the presence and capabilities of the MCDP2800. The source communicates with MCDP2800 through AUX/DDC interface via I2C-over-AUX or native I2C (3.3V) messaging. In this topology, typically the MCDP2800 operates as a re-driving or re-timing analog repeater for AC-coupled TMDS input for speeds below 3.4Gbps and as a DisplayPort to HDMI protocol converter for speeds above 3.4 Gbps up to 6.0 Gbps. The analog repeater mode saves the active power consumption during low frequency oeprtation. MCDP2800 however is capable of operating as DP to HDMI protocol converter for the entire operating range up to 6 Gbps. The motherboard-down topology supports transmitting both HDCP1.x and HDCP2.2 protected content over the HDMI output. Figure 2. MCDP2800 motherboard-down use case Source SoC 2.2 HDMI Cable MCDP2800   HDMI Sink Adaptor topology In an adaptor topology, the MCDP2850 is part of the source side adaptor or docking station that plugs into the PC/NB via a DP++ connector. In this case, a typical source sends out a DP signal to the adaptor and the adaptor converts it into HDMI 2.0 output for the entire operating frequency range. However, a source which is aware of the presence and capabilities of the MCDP2850 can choose to send an AC- C28x0-DAT-01p MegaChips’ Proprietary Information Page 9 of 33 MCDP28x0 coupled TMDS signal at lower speeds (below 3.4 Gbps) and a DP signal at higher speeds (above 3.4 Gbps) similar to a motherboard-down topology. In the adaptor application, the MCDP2850 dynamically decides whether to use I2C-over-AUX or native I2C messaging at the time of connectivity with the source. MCDP2850 only supports HDCP1.x repeater/transmitter functionality; no HDCP2.2 transmitter function allowed in this topology. Note: In an adaptor topology, signal degradation is higher compared to in a motherboard-down topology due to longer traces and multiple connectors in the path. Figure 3. MCDP2850 adaptor (dongle) use case Dongle Source SoC C28x0-DAT-01p HDMI Cable MCDP2850  MegaChips’ Proprietary Information Page 10 of 33 HDMI Sink MCDP28x0 3. BGA footprint and pin lists 3.1 Ball grid array diagram The ball grid array (BGA) diagrams give the allocation of signals to the balls of the package, shown from the top looking down using the PCB footprint. Some signal names in BGA diagrams have been abbreviated. Refer to the pin list for full signal names sorted by pin number. Figure 4. MCDP28x0 BGA diagram 1 2 3 4 5 6 7 8 DPRX L3N DPRX L3P DPRX L2N DPRX L2P DPRX L1N DPRX L1P DPRX L0N DPRX L0P DPRX HPD_OUT VDD33 RX GND VDD12 RX VDD12 RX GND VDD12 PLL RESETN SPI_CSN SPI_DI GPIO1 VDD33 RX VDD33 AUX R_EXT DPRX AUXP DPRX AUXN VDD33 IO GND GND VDD12 DIG UART_TX TEST VDD33 IO GND I2C_SDA UART_RX VDD12 OSC VDD12 DIG I2C_SCL VDD33 TX VDD12 TX GND A B C SPI_DO SPI_CLK D E F G H HDMITX DDC_SCL SPI_WP HDMITX DDC_SDA HDMI CEC CONFIG1 HDMITX HPD_IN VDD33 TX GND HDMITX CLKN HDMITX CLKP HDMITX CH0N HDMITX CH0P HDMITX CH1N 1 2 3 4 5 HDMI_TX Power 3.3V C28x0-DAT-01p DP_RX GND B C D XT> E d>< VDD12 TX VDD12 ON HDMITX CH1P HDMITX CH2N HDMITX CH2P 6 7 8 Power Return MegaChips’ Proprietary Information Page 11 of 33 C_EXT F SYS_DIGITAL Power 1.2V A SYS_ANALOG 8kV pads G H MCDP28x0 3.2 Signal mapping sorted by ball (pin) number Table 1. Pin list Pin number C28x0-DAT-01p Net name A1 DPRX_L3N A2 DPRX_L3P A3 DPRX_L2N A4 DPRX_L2P A5 DPRX_L1N A6 DPRX_L1P A7 DPRX_L0N A8 DPRX_L0P B1 DPRX_HPD_OUT B2 VDD33_RX B3 GND B4 VDD12_RX B5 VDD12_RX B6 GND B7 VDD12_PLL B8 RESETN C1 SPI_CSN C2 SPI_DI C3 GPIO1 C4 VDD33_RX C5 VDD33_AUX C6 R_EXT C7 DPRX_AUXP C8 DPRX_AUXN D1 SPI_DO D2 SPI_CLK D3 VDD33_IO D4 GND D5 GND D6 VDD12_DIG D7 UART_TX D8 TEST E1 HDMITX_DDC_SCL E2 SPI_WP MegaChips’ Proprietary Information Page 12 of 33 MCDP28x0 Table 1. Pin list (continued) Pin number C28x0-DAT-01p Net name E3 VDD33_IO E4 GND E5 GND E6 I2C_SDA E7 UART_RX E8 XTAL F1 HDMITX_DDC_SDA F2 HDMI_CEC F3 CONFIG1 F4 VDD12_OSC F5 VDD12_DIG F6 I2C_SCL F7 C_EXT F8 TCLK G1 HDMITX_HPD_IN G2 VDD33_TX G3 GND G4 VDD33_TX G5 VDD12_TX G6 GND G7 VDD12_TX G8 VDD12_ON H1 HDMITX_CLKN H2 HDMITX_CLKP H3 HDMITX_CH0N H4 HDMITX_CH0P H5 HDMITX_CH1N H6 HDMITX_CH1P H7 HDMITX_CH2N H8 HDMITX_CH2P MegaChips’ Proprietary Information Page 13 of 33 MCDP28x0 4. Connections 4.1 Pin list I/O Legend: I = Input; O = Output; P = Power; G = Ground; IO = Bi-direction; AI = Analog input Table 2. DisplayPort receiver pins Pin A1 A2 A3 A4 A5 A6 A7 A8 Assignment DPRX_L3N DPRX_L3P DPRX_L2N DPRX_L2P DPRX_L1N DPRX_L1P DPRX_L0N DPRX_L0P C28x0-DAT-01p I/O I I I I I I I I VDD Domain Description 1.2 V DisplayPort receiver main link Lane 3 negative analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 3 positive analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 2 negative analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 2 positive analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 1 negative analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 1 positive analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 0 negative analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. 1.2 V DisplayPort receiver main link Lane 0 positive analog input. AC-coupled internal pull up to VDD12_RX through 50 Ω resistor. MegaChips’ Proprietary Information Page 14 of 33 MCDP28x0 Pin C7 Assignment DPRX_AUXP I/O IO VDD Domain Description 3.3 V DisplayPort receiver auxiliary channel positive analog input/output. Common mode voltage = 3.3 V AC-coupled internal pull up to VDD33_AUX through 50 Ω resistor. Also functions as DDC_SCL. C8 DPRX_AUXN IO 3.3V DisplayPort receiver auxiliary channel negative analog input/output. Common mode voltage = 3.3 V AC-coupled internal pull up to VDD33_AUX through 50 Ω resistor. Also functions as DDC_SDA. B1 DPRX_HPD_OUT O 3.3 V To the upstream HPD signal pin (DP source), to be externally pulled down (100K ohm recommended) as per DP1.2a spec. C6 R_EXT IO 1.2 V Termination calibration reference resistor; 249 Ω 1% resistor should be connected from this pin to VDD12_RX (1.2 V analog power supply). 3.3V General purpose IO. Connects to DP upstream connector pin 13 in Adaptor topology. Optional in Motherboard-down topology. Default POR state is INPUT use weak pull-down when not used. F3 CONFIG1 IO Table 3. HDMI output pins Pin Assignment I/O VDD Domain Description H1 HDMITX_CLKN O 3.3 V HDMI transmitter CLOCK_N to TX connector H2 HDMITX_CLKP O 3.3 V HDMI transmitter CLOCK_P to TX connector H3 HDMITX_CH0N O 3.3 V HDMI transmitter DATA0_N to TX connector H4 HDMITX_CH0P O 3.3 V HDMI transmitter DATA0_P to TX connector H5 HDMITX_CH1N O 3.3 V HDMI transmitter DATA1_N to TX connector H6 HDMITX_CH1P O 3.3 V HDMI transmitter DATA1_P to TX connector H7 HDMITX_CH2N O 3.3 V HDMI transmitter DATA2_N to TX connector H8 HDMITX_CH2P O 3.3 V HDMI transmitter DATA2_P to TX connector C28x0-DAT-01p MegaChips’ Proprietary Information Page 15 of 33 MCDP28x0 Pin Assignment I/O VDD Domain Description E1 HDMITX_DDC_SCL O 3.3 V, 5 V Tol HDMI TX DDC I2C master SCL. 3.3 V logic level, 5 V tolerant. Open drain, external 2.2 K pull up to +5 V. F1 HDMITX_DDC_SDA IO 3.3 V, 5 V Tol HDMI TX DDC I2C master SDA. 3.3 V logic level, 5 V tolerant. Open drain, external 2.2 K pull up to +5 V. F2 HDMI_CEC IO 3.3 V CEC input. 3.3 V open drain IO. Connect to HDMI CEC pin, to be externally pulled up to 3.3 V (27K Ohm recommended) as per HDMI1.4b spec. G1 HDMITX_HPD_IN I 3.3 V, 5 V Tol 3.3 V logic level, 5 V tolerant input from HDMI connector. To be externally pulled down via resistor. (47K Ohm recommended) Table 4. System interface pins Pin Assignment I/O VDD Domain Reset State Description B8 RESETN I 3.3 V Input Power-ON chip reset (active low) input signal Connects to 3.3V VDD through 2.2K +/-10% resistor E8 XTAL IO 1.2 V NA Connect to 27 MHz crystal oscillator with 22 pF to VDD12_OSC F8 TCLK IO 1.2 V NA Connect to 27 MHz crystal oscillator with 22 pF to VDD12_OSC F7 C_EXT O 3.3V NA Capacitor for filtering internal 2.5V LDOR. Connect to GND through 2.2uF capacitor. Output 1.2 V power control signal to control external 1.2 V power as shown in Figure 4. Reset State definition assumes 3.3 V Rail is ramped up to full voltage. G8 C28x0-DAT-01p VDD12_ON O 3.3 V MegaChips’ Proprietary Information Page 16 of 33 MCDP28x0 Pin Assignment I/O D8 TEST IO E6 F6 I2C_SDA I2C_SCL IO I VDD Reset State Description 3.3 V NA Test select. Tie to GND for mission mode 3.3 V Input, Internal PU Host I2C interface data line. External pull-up required for I2C operation. Leave NC when not used. 3.3 V Input, Internal PU Host I2C interface clock line. External pull-up required for I2C operation. Leave NC when not used. General purpose input/output. Applicable for CONFIG2 if needed. Default POR state is INPUT; use weak pull-down when not used. Domain C3 GPIO1 IO 3.3 V Input, Internal PU C1 SPI_CSN O 3.3 V Input, Internal PU Serial peripheral interface chip select Input, Internal PD Serial peripheral interface data input Input, Internal PD Serial peripheral interface data output 3.3 V C2 SPI_DI I 3.3 V D1 SPI_DO O D2 SPI_CLK O 3.3 V Input, Internal PD Serial peripheral interface clock E2 SPI_WP O 3.3 V Input, Internal PD Serial peripheral interface write protect D7 UART_TX O 3.3 V Input, Internal PU Universal asynchronous serial Tx output. Leave NC when not used. C28x0-DAT-01p MegaChips’ Proprietary Information Page 17 of 33 MCDP28x0 Pin Assignment I/O E7 UART_RX I VDD Domain 3.3 V Reset State Description Input, Internal PU Universal asynchronous serial Rx input. Leave NC when not used. Table 5. Power and ground pins Pin Assignment Voltage Level Description B2, C4 VDD33_RX L3.3 V DisplayPort RX analog power B4, B5 VDD12_RX 1.2 V DisplayPort RX analog power C5 VDD33_AUX 3.3 V DisplayPort AUX analog power B7 VDD12_PLL 1.2 V PLL analog power F4 VDD12_OSC 1,2 V Oscillator circuit power G2, G4 VDD33_TX 3.3 V HDMI TX analog power G5, G7 VDD12_TX 1.2 V HDMI TX analog power D6, F5 VDD12_DIG 1.2 V Core and 1.2V IO power D3, E3 VDD33_IO 3.3 V 3.3V IO power GND Power return for all supplies B3, B6, D4, D5, E4, GND E5, G3, G6 4.2 Bootstrap configuration Other than the normal operating mode (mission mode), the MCDP28x0 is configured in testing and debugging mode during factory testing and chip bring-up. For this purpose, the chip is configured during the boot operation using several bootstrap configurations. DC levels on these bootstrap pins are latched during the de-asserting edge of power-on reset (RESETN goes HIGH). The levels specified below must be adhered to for the normal function of the device. Table 6. Bootstrap configuration Bootstrap signal Internal PU/PD name Pin assignment Function 0: Reserved for ATE test Bootstrap_0 PULL UP UART_TX (D7) 1: Normal operation (mission mode) C28x0-DAT-01p MegaChips’ Proprietary Information Page 18 of 33 MCDP28x0 0: Normal operation (mission mode) Bootstrap_1 PULL DN SPI_WP (E2) 1: OCM debug mode 0: (Default) Internal ROM is enabled and mapped to top 32 K of OCM memory map. OCM boots from IROM. Normal mode (mission mode). Bootstrap_2 PULL DN SPI_CLK (D2) 1: Internal ROM is disabled. External ROM includes the address range reserved for IROM. OCM boots from EXTROM. Debug mode. 0: Default. Reserved (mission mode) Bootstrap_3 PULL DN SPI_DO (D1) 1: Reserved for testing 0: Select external CLK on XTAL pin (used in ATE). Bootstrap_4 Note: 4.3 PULL UP SPI_CSN (C1) 1: (Default) Select crystal and internal oscillator. Normal operation (mission mode). When the pin corresponding to a specific bootstrap is left NC, the pin takes the value of the assigned by the internal PULLUP (Level 1) or PULLDN (Level 0). The internal resistor used is around 50 k Ω. To select a non-default value on a bootstrap, an external PULLUP or PULLDN resistor tied to the opposite direction that overcomes the internal PULLUP or PULLDN needs to be used. RESETN connection The RESETN pin must be pulled up to 3.3 V via a 2.2 kohm +/- 10% resistor as shown below. The chip also supports an active low, external reset pulse to RESETN allowing a system host controller to reset the system. The recommended way to drive RESETN is through an open-drain output. Alternately, if an open-drain output is not available, the series resistor shown in the figure below is required. Figure 5. RESETN Connection to MCDP28x0 3.3V External Reset  Control (optional) System Host 2.2Kohm External Reset  Switch (for debug) External 1.5K to 3Kohm  +/‐1% series resistor Capacitor Value  should not exceed  50pF C28x0-DAT-01p MegaChips’ Proprietary Information Page 19 of 33 MCDP28x0 RESETN MCDP28x0 5. Package specifications Package type: LFBGA (7 x 7 x 1.4 mm, 64 F8 x 8 Pitch 0.8 Ball 0.4) 5.1 Package drawing Figure 6. MCDP28x0 package drawing C28x0-DAT-01p MegaChips’ Proprietary Information Page 20 of 33 MCDP28x0 5.2 LFBGA 7 x 7 dimensions Figure 7. MCDP28x0 package dimensions DIMENSIONS DATABOOK (mm) REF. MIN. TYP. A A1 DRAWING (mm) MAX. MIN. TYP. 1.4 0.25 A2 0.25 0.29 A4 0.30 MAX. NOTES 1.24 (1) 0.35 0.24 0.28 0.32 0.60 0.57 0.585 0.60 b 0.35 0.40 0.45 0.35 0.40 0.45 D 6.95 7.00 7.05 6.95 7.00 7.05 7.05 6.95 7.00 D1 E 5.60 6.95 7.00 (2) 5.60 E1 5.60 5.60 e 0.80 0.80 Z 0.70 7.05 0.70 ddd 0.08 0.08 eee 0.09 0.09 (4) fff 0.05 0.05 (5) NOTES: (1) - LFBGA stands for Low profile Fine Pitch Ball Grid Array. - Thin profile: 1.00mm < A ” 1.20mm / Fine pitch: e < 1.00mm pitch. - The total profile height (Dim A) is measured from the seating plane to the top of the component - The maximum total package height is calculated by the following methodology: A Max = A1 Typ + A2 Typ + A4 Typ +¥ (A1² + A2² + A4² tolerance values) (2) – The typical ball diameter before mounting is 0.40mm. (3) – LFBGA with 0.40mm pitch is not yet registered into JEDEC Publications. (4) - The tolerance of position that controls the location of the pattern of balls with respect to datums A and B. For each ball there is a cylindrical tolerance zone eee perpendicular to datum C and located on true position with respect to datums A and B as defined by e. The axis perpendicular to datum C of each ball must lie within this tolerance zone. (5) - The tolerance of position that controls the location of the balls within the matrix with respect to each other. For each ball there is a cylindrical tolerance zone fff perpendicular to datum C and located on true position as defined by e. The axis perpendicular to datum C of each ball must lie within this tolerance zone. Each tolerance zone fff in the array is contained entirely in the respective zone eee above The axis of each ball must lie simultaneously in both tolerance zones. (6) - The terminal A1 corner must be identified on the top surface by using a corner chamfer, ink or metallized markings, or other feature of package body or integral heatslug. - A distinguishing feature is allowable on the bottom surface of the package to identify the terminal A1 corner. Exact shape of each corner is optional. 5.3 Marking field template and descriptors The MCDP28x0 marking template is shown below. C28x0-DAT-01p MegaChips’ Proprietary Information Page 21 of 33 MCDP28x0 Figure 8. Marking template Field descriptors are shown below. Table 7.Field descriptors Field Description A Marking MegaChips logo MegaChips B Product code One of the codes below: MCDP2800BB MCDP2850BB MCDP2800BC MCDP2850BC C 2-character diffusion plant code VQ D 3-digit wafer start date “YWW” E 3-character FE sequence code “ABC” F 2-character assembly plant code 99 G 3-character BE sequence code “XYZ” H Optional marking or ES(1) I 3-character country of origin code MYS J 2-digit test plant code 8U K 1-digit assembly year “Y” L 2-digit assembly week “WW” M Ball A1 identifier a DOT 1. Marked ES for Engineering Samples, used for development purposes. 5.4 Classification reflow profile Please refer to the DisplayPort Application Note: Classification reflow profile for SMD devices (C0353APN-06) for reflow diagram and details. C28x0-DAT-01p MegaChips’ Proprietary Information Page 22 of 33 MCDP28x0 6. Electrical specifications 6.1 Absolute maximum ratings Applied conditions greater than those listed under “Absolute maximum ratings” may cause permanent damage to the device. The device should never exceed absolute maximum conditions since it may affect device reliability. Table 8. Absolute maximum ratings Parameter Symbol Min Typ Max Units 3.3 V supply voltages (1,2) VVDD_3.3 -0.3 3.3 3.96 V (1.2) VVDD_1.2 -0.3 1.2 1.44 V 1.2 V supply voltages Input voltage tolerance for 3.3 V, 5 V tolerant I/O pins VIN5tol -0.3 5.5 V Input voltage tolerance for 3.3 V I/O pins VIN3V3 -0.3 3.63 V ESD – Human Body Model (HBM) [JESD22-A114 spec] For all pins VESD +/- 2.0 kV ESD – Human Body Model (HBM) [IEC61000-4 spec] VESD For DP and HDMI connector-facing pins - - +/- 6.5 kV ESD – Charged Device Model (CDM) VESD - - +/- 500 V ILA - - +/- 100 mA Ambient operating temperature TA 0 - 70 C Storage temperature TSTG -40 - 150 C TJ 0 75 125 C JA - - 49.0 C/W JC - - 20.1 C/W TSOL - - 260 C Latch-up (3,4) Operating junction temperature Thermal resistance (Junction to Ambient) Thermal resistance (Junction to Case)(5) Peak IR reflow soldering temperature (5) Note (1): All voltages are measured with respect to GND. Note (2): Absolute maximum voltage ranges are for transient voltage excursions. Note (3): For connector facing pins CONFIG1 and DPRX_HPD_OUT, a series resistor of 100 ohms is recommended. Refer to the MCDP28x0 Layout Guideline appnote. Note (4): JEDEC Class1. Note (5): These are simulated results under the following conditions: Four layer JEDEC PCB, no heat spreader, Air flow = 0 m/s. C28x0-DAT-01p MegaChips’ Proprietary Information Page 23 of 33 MCDP28x0 6.2 Power Connections From 3.3V regulator FB FB 0.1uF FB= FERRITE BEAD 120Ohms@100MHz B2 C5 VDD33_AUX VDD33_RX 0.1uF C4 VDD33_RX VDD33_IO D3 VDD33_IO E3 VDD33_TX G4 C6 REXT VDD33_TX 0.1uF FB G2 0.1uF 1.2V REGULATOR V_IN V_ON 0.01uF V_OUT GND FB 249ohm/1% B4 VDD12_RX B5 F4 FB 0.1uF 22pF MCDP28x0 R1 VDD12ON G8 R2 VDD12_RX G5 VDD12_TX VDD12_TX G7 VDD12_OSC F8 0.1uF TCLK FB E8 22pF 0.1uF XTAL GND B3, B6, D4, D5, E4, E5, G3, G6, D8 CEXT F7 2.2uF VDD12_PLL B7 F5 VDD12_DIG VDD12_DIG D6 0.1uF 0.1uF C28x0-DAT-01p 0.1uF MegaChips’ Proprietary Information Page 24 of 33 FB 0.1uF MCDP28x0 6.3 DC characteristics Table 9. DC characteristics Parameter Symbol Min Typ Max Units 3.3 V supply voltages (analog and digital) VVDD_3.3 3.14 3.3 3.47 V 1.2 V supply voltages (analog and digital) VVDD_1.2 1.14 1.2 1.26 V Protocol converter Mode Measurement condition: Nominal corner, 25°C, Nominal power supply 4k x 2k / 60 Hz 4L HBR2 to HDMI test pattern: ON-OFF dot Moire attributes-based rendering 412 460 mW Analog PHY repeater mode 100 120 mW Sleep State 18 20 mW Connected standby mode 0.1 0.2 mW Power Supply current Measurement conditions: Nominal corner, 25°C, Nominal power supply 4k x 2k @60 MHz 4L HBR to HDMI2.0a VDD (analog and digital) 3.3V VDD (analog and digital) 1.2V Note: mA 30 300 Ripple amplitude for power supplies should be 30 mV or lower with max ripple frequency of up to 30 MHz. Table 10. IO DC characteristics Parameter Symbol Min Typ Max Units Inputs 3.3 V IO signals, 5 V tolerant open drain type High voltage VIH 2.0 5.5 V Low voltage VIL -0.3 0.8 V Input Hysteresis voltage VHYST 300 High current (VIN = 3.3 V) IIH +/- 10 A Low current (VIN = 0.8 V) IIL +/- 10 A Input capacitance CIN Outputs 3.3 V IO signals, 5 V tolerant open drain type C28x0-DAT-01p MegaChips’ Proprietary Information Page 25 of 33 mV 5 pF MCDP28x0 Low Current (VOL = 0.2 V) IOL 4 mA Tri-state leakage current IOZ 10 A Output Low Voltage (IOL=0.25mA) VOL 0.4 V Output High Voltage(IOH=0.25mA) VOH 2.9 Low Level output Current IOL 0.25 High Level Output Current IOH 0.25 High voltage VIH 2.0 Low voltage VIL Input Hysteresis voltage VHYST High current (VIN = 3.3 V) IIH ±10 A Low current (VIN = 0.8 V) IIL ±10 A Input capacitance CIN 1.0 pF Rout Output Impedance, VOL=0.3V 50 Ω Rout Output Impedance, VDDE3V30.3V 50 Ω Tri-state leakage current IOZ VDD12_ON output V Inputs 3.3 V IO signals, 3.3 V tolerant, TRISTATE V 0.8 300 V mV Outputs 3.3 V IO signals, 3.3 V tolerant, TRISTATE 6.4 ±10 AC characteristics Table 11. Maximum speed of operation Clock domain Max speed of operation Reference Input Clock (TCLK) 27 MHz Reference Internal Clock (RCLK) 324 MHz On-Chip Microcontroller Clock (OCLK) 150 MHz 2-Wire Serial Slave (SLAVE_SCL) 400 kHz 2-Wire Serial Master (MSTRx_SCL) 400 kHz SPI Clock 50 MHz C28x0-DAT-01p MegaChips’ Proprietary Information Page 26 of 33 A MCDP28x0 6.4.1 DisplayPort receiver Table 12. DisplayPort receiver characteristics Parameter Symbol Min Typ Max Units Comments Receiver operating range Differential Input Voltage Range VRX_DIF_PP_RANG E RX Termination Control Range RRX_TERM_RANGE 0.04~1 V 80 ~120 ohm DisplayPort receiver system parameters HBR2 unit interval (5.4Gbps) UIHBR2 185 ps HBR unit interval (2.7Gbps) UIHBR 370 ps RBR unit interval (1.62Gbps) UIRBR 617 ps Link clock down spreading 0 0.5 % Modulation frequency range 0f 30 kHz to 33 kHz DisplayPort receiver TP3 parameters Receiver Eye TP3 RBR TRBR_EYE_TP3 0.25 UI @ 40mV V_diff_pp Receiver Eye TP3_EQ HBR THBR_EYE_TP3EQ 0.4 UI @ 135mV V_diff_pp 0.3 UI @ 70mV V_diff_pp Receiver Eye TP3_EQ HBR2 THBR2_EYE_TP3EQ TSKEW_INTRA_RBR 260 ps 60 ps TSKEW_INTRA_HBR2 50 ps DJ Non-ISI at 1.62 Gbps TRX_DJ_RBR 0.186 UI 1.62Gbps signal @ package pins DJ Non-ISI at 2.7 Gbps TRX_DJ_HBR 0.339 UI 2.7Gbps signal @ package pins DJ at 5.4 Gbps TRX_DJ_HBR2 0.57 UI 5.4 Gbps signal @ package pins TJ at 1.62 Gbps TRX_TJ_RBR 0.78 UI 1.62Gbps signal @ package pins TJ at 2.7 Gbps TRX_TJ_HBR 0.53 UI 2.7Gbps signal @ package pins TJ at 5.4 Gbps TRX_TJ_HBR2 0.7 UI 5.4 Gbps signal @ package pins Lane intra-pair skew tolerance TSKEW_INTRA_HBR C28x0-DAT-01p MegaChips’ Proprietary Information Page 27 of 33 Skew contribution from the cable in addition to the stressed EYE at TP3. MCDP28x0 Parameter Symbol Min Typ Max Units Comments AUX parameters Differential Input Voltage Range VAUX_RX_DIF_RANG 0.14~1 V RX Termination Control Range RAUX_TERM_RANGE 40~60 ohms AUX TX peak-peak Range 0~1 V E VAUX_TX_DIF_PP 7.8125mV/step in 128 steps 6.4.2 HDMI transmitter I/O specifications Table 13. HDMI transmitter I/O specifications Parameters Symbol Min Typ Max Unit Differential output: single ended swing VTX_PP amplitude 0.4 0.5 0.6 V Differential output: Differential swing amplitude VTX_DIF_PP 0.8 1 1.2 V Differential high level output VTX_DIF_HIGH 3.12 3.3 3.49 V Differential low level output VTX_DIF_LOW 3.12 3.49 V Comments Table 14. HDMI transmitter AC characteristics Parameters Symbol Min Typ Max Unit Comments TMDS Character Clock fTX_CHR_CLK 25 600 MHz Programmable Differential Output Voltage VTX_DIF_PP 0 1200 mV In 128 steps TX Edge Rate tTX_ER 75 145 pS 1V VTX_DIF_PP and Premphasis at 0dB in 8 steps TX Pre-Emphasis Level APREMPH 0 6 dB 1V VTX_DIF_PP in 16 steps 100 600 ohms Programmable Termination TTX_J_D102_LF 60 pS TX Jitter 1.65Gbps, < 3.4Gbps for PatternD10.2 TTX_J_D102_MF 35 pS TX Jitter >1.65Gbps, < 3.4Gbps for PatternPRBS7 TTX_J_PRBS7_MF 45 pS TX Termination Control Range RTX_TERM_RANGE TX Jitter 3.4Gbps for PatternD10.2 TTX_J_D102_HF 30 pS TX Jitter >3.4Gbps for PatternPRBS7 TTX_J_PRBS7_HF 35 pS 6.4.3 I2C interface timing Table 15. I2C interface timing Symbol Parameter Conditions Min Typ Max Unit fSCL SCL clock rate Fast mode 0 - 400 kHz tHD-STA Hold time START After this period, the 1st clock starts 1.2 - - s tLOW Low period of clock SCL 1.3 - - s tHIGH High period of clock SCL 1.2 - - s Tsu;STA Set up time for a repeated START 1.2 - - s tHD;DAT Data hold time 0.7 - 0.9(1) s tSU;DAT Data setup time 380 - - ns TBUF Bus free time between STOP and START 1.3 - - s Cb Capacitance load for each bus line - 100 400 pF tr Rise time 220 - 300 ns tf Fall time 60 - 300 ns Vnh Noise margin at high level 0.25VDD - - V Vnl Noise margin at low level 0.2VDD - - Note: For master The maximum tHD;DAT only has to be met if the device does not stretch the low period tLOW of the SCL signal. In the diagram below, S = start, P = stop, Sr = Repeated start, and SP= Repeated stop conditions. Figure 9. I2C timing SDA tf tLOW tSU;DAT tr tf tHD;STA tSP tr tBUF SCL S tHD;STA C28x0-DAT-01p tHD;DAT tHIGH tSU;STA Sr MegaChips’ Proprietary Information Page 29 of 33 tSU;STO P S MCDP28x0 6.4.4 SPI interface timing Table 16. SPI interface timing, VDD = 3.3 V Symbol Parameter Min Typ Max Units FCLK SPI_CLK output clock frequency 50 MHz TSCKH Serial clock high time 20 ns TSCKL Serial clock low time 20 ns TR_SPI_CLK SPI_CLK rise time @10mA drive 10pF load 2.8 ns TF_SPI_CLK SPI_CLK fall time @10mA drive 10pF load 3.2 ns TMEM_CLK_F Device speed TMEM_CSN_SU Device CSN input setup time requirement 7 ns TMEM_CSN_HLD Device CSN input setup time requirement 7 ns 75 MHz TMEM_DO_PD Device DO out propagation delay 6 ns TMEM_DI_SU Device DI setup time 3 ns TMEM_DI_SU Device DI hold time 5 ns C28x0-DAT-01p MegaChips’ Proprietary Information Page 30 of 33 MCDP28x0 7. Ordering information Table 17. Order codes Part number Description MCDP2800-BBES 64 LFBGA (7 x 7 x 1.4 mm) for motherboard-down application. Engineering samples, for development purpose only. (Rev BB silicon) MCDP2800-BB 64 LFBGA (7 x 7 x 1.4 mm) for motherboard-down application. Mass production parts. Delivered in trays. (Rev BB silicon) MCDP2800-BBT 64 LFBGA (7 x 7 x 1.4 mm) for motherboard-down application. Mass production parts. Delivered in tape and reel. (Rev BB silicon) MCDP2850-BB 64 LFBGA (7 x 7 x 1.4 mm) for dongle application. Delivered in trays. (Rev BB silicon) MCDP2850-BBT 64 LFBGA (7 x 7 x 1.4 mm) for dongle application. Delivered in tape and reel. (Rev BB silicon) MCDP2800-BC 64 LFBGA (7 x 7 x 1.4 mm) for motherboard-down application. Mass production parts. Delivered in trays. (Rev BC silicon) MCDP2800-BCT 64 LFBGA (7 x 7 x 1.4 mm) for motherboard-down application. Mass production parts. Delivered in tape and reel. (Rev BC silicon) MCDP2850-BC 64 LFBGA (7 x 7 x 1.4 mm) for dongle application. Delivered in trays. (Rev BC silicon) MCDP2850-BCT 64 LFBGA (7 x 7 x 1.4 mm) for dongle application. Delivered in tape and reel. (Rev BC silicon) C28x0-DAT-01p MegaChips’ Proprietary Information Page 31 of 33 MCDP28x0 8. Revision history Table 18. Document revision history Date Revision 09-Mar-2016 A Initial version. 07-Apr-2016 B Updated HDMI2.0 to HDMI2.0a throughout the datasheet. Added sub-bullet to Features section. C28x0-DAT-01p Changes MegaChips’ Proprietary Information Page 32 of 33 MCDP28x0 Notice Semiconductor products may possibly experience breakdown or malfunction. Adequate care should be taken with respect to the safety design of equipment in order to prevent the occurrence of human injury, fire or social loss in the event of breakdown or malfunction of semiconductor products The overview of operations and illustration of applications described in this document indicate the conceptual method of use of the semiconductor product and do not guarantee operability in equipment in which the product is actually used. The names of companies and trademarks stated in this document are registered trademarks of the relevant companies. MegaChips Co. provides no guarantees nor grants any implementation rights with respect to industrial property rights, intellectual property rights and other such rights belonging to third parties or/and MegaChips Co. in the use of products and of technical information including information on the overview of operations and the circuit diagrams that are described in this document. The product described in this document may possibly be considered goods or technology regulated by the Foreign Currency and Foreign Trade Control Law. In the event such law applies, export license will be required under said law when exporting the product. This regulation shall be valid in Japan domestic. In the event the intention is to use the product described in this document in applications that require an extremely high standard of reliability such as nuclear systems, aerospace equipment or medical equipment for life support, please contact the sales department of MegaChips Co. in advance. All information contained in this document is subject to change without notice. Copyright ©2016 MegaChips Corporation All rights reserved MegaChips Corporation Head Quarters 1-1-1 Miyahara, Yodogawa-ku Osaka 532-0003, Japan TEL: +81-6-6399-2884 MegaChips Corporation Taiwan Branch RM. B 2F, Worldwide House, No.129, Min Sheng E. Rd., Sec. 3, Taipei 105, Taiwan TEL: +886-2-2547-1297 MegaChips Corporation Tokyo Office 17-6 Ichiban-cho, Chiyoda-ku, Tokyo 102-0082, Japan TEL: +81-3-3512-5080 MegaChips Corporation Tainan Office RM. 2, 8F, No.24, Da Qiao 2 Rd., Yong Kang Dist., Tainan 710, Taiwan TEL: +886-6-302-2898 MegaChips Corporation Makuhari Office 1-3 Nakase Mihama-ku Chiba 261-8501, Japan TEL: +81-43-296-7414 MegaChips Corporation Zhunan Office No.118, Chung-Hua Rd., Chu-Nan, Miao-Li 350, Taiwan TEL: +886-37-666-156 MegaChips Corporation San Jose Office 2033 Gateway Place, Suite 400, San Jose, CA 95110 U.S.A. TEL: +1-408-570-0555 MegaChips Corporation Shenzhen Office Room 6307, Office Tower, Shun Hing Square, 5002 Shen Nan Dong Road, Luohu District, Shenzhen 518000, P. R. China TEL: +86-755-3664-6990 MegaChips Corporation India Branch 17th Floor, Concorde Block UB City, Vittal Mallya Road, Bangalore 560-001, India TEL: +91-80-4041-3999 C28x0-DAT-01p MegaChips’ Proprietary Information Page 33 of 33
MCDP2850BC 价格&库存
很抱歉,暂时无法提供与“MCDP2850BC”相匹配的价格&库存,您可以联系我们找货
