STDP4028AB
STDP4028AB
    MEGACHIPS(兆芯)
    164-LFBGA,CSPBGA
    IC DISPLAYPORT CONVERT LFBGA164
STDP4028AB 数据手册
STDP4028 DisplayPort transmitter Datasheet Rev A MegaChips’ Proprietary Information MegaChips reserves the right to make any change herein at any time without prior notice. MegaChips does not assume any responsibility or liability arising out of application or use of any product or service described herein except as explicitly agreed upon. MegaChips’ Proprietary Information Page 1 of 43 STDP4028 Features • • • • Enhanced DisplayPort® (DP) transmitter – DP 1.1a compliant – Embedded DisplayPort (eDP) compliant – 1, 2, or 4 lanes Higher bandwidth “Turbo mode” (3.24 Gbps) per lane, supports: – 1920 x 1080 (FHD) 120 Hz/10-bit color video standard timings and 7.1 Ch audio – 2560 x 1600 (WQXGA), 2560 x 2048 (QSXGA) 60 Hz/10-bit color graphics and 7.1 Ch audio Interface compatibility with wide range of display controller ICs – LVTTL (60 wide) and LVDS (quad bus) video interface – 8-Ch I2S and SPDIF audio interface Robust AUX channel – Link service, maintenance – I2C-over-AUX (MCCS, DDC) – IR, full duplex UART protocol HDCP repeater capability – Acts as downstream transmitter • Spread spectrum on DisplayPort, LVDS, and TTL interfaces for EMI reduction • Supports deep color and color format conversion – RGB/YUV (4:4:4) – 10-bit color – YUV (4:2:2/4:2:0) – 12-bit color – RGB (4:4:4) to YUV (4:4:4) conversion and vice-versa • Low power operation; 18 mW standby • I2C to AUX bridge for EDID, MCCS pass through • Supports HBR/“Turbo” speed over HBR/RBRrated long cables (15 m and more) • Package – 164 LFBGA (12 x 12 mm / 0.8 mm) • Power supply voltages – 3.3 V I/O; 1.2 V core Applications • Configurable through I2C host interface • Supports HDCP 1.3 with on-chip keys QLVDS/ TTL (60) Video • • Digital TV, docking station, STB, game console, etc. LVDS/TTL Receiver DisplayPort Transmitter I2S/SPDIF Audio I2S/SPDIF Receiver I2C Host Interface C4028-DAT-01p Crystal Oscillator GPIO I2C Master MegaChips’ Proprietary Information Page 2 of 43 DP Output STDP4028 Contents 1. Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2. Application overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 3. Feature attributes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 4. BGA footprint and pin lists . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 5. 6. 4.1 Ball grid array diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 4.2 Full pin list sorted by pin number . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .11 Connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 5.1 Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 5.2 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 5.3 General purpose input/output (GPIO) pins . . . . . . . . . . . . . . . . . . . . . . . . 25 Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 6.1 7. Marking field template and descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 7.1 Absolute maximum ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 7.2 Maximum speed of operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 7.3 DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 7.4 AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 7.4.1 Digital video input port DC characteristics . . . . . . . . . . . . . . . . . . . . . . . 31 7.4.2 LVDS video input DC/AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . 32 7.4.3 Digital audio input I2S timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 7.4.4 DisplayPort transmitter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 7.4.5 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 7.4.6 SPI interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 39 8. Ordering information . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41 9. Revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42 C4028-DAT-01p MegaChips’ Proprietary Information Page 3 of 43 STDP4028 List of Tables Table 1. Table 2. Table 3. Table 4. Table 5. Table 6. Table 7. Table 8. Table 9. Table 10. Table 11. Table 12. Table 13. Table 14. Table 15. Table 16. Table 17. Table 18. Table 19. Table 20. Table 21. Key to BGA diagrams . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Pin list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 DisplayPort transmitter outputs. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Reference clocks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Digital video inputs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Multi-function - digital audio output, general purpose input/output, bootstrap pins. . . . . . . 20 Multi-function and system interface connections . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 No connects . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 22 System power and ground . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Bootstrap configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Field descriptors . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Absolute maximum ratings . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28 DC characteristics. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 Digital video input port DC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 LVDS video input DC/AC characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 32 Digital audio input I2S timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 DisplayPort transmitter characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 I2C interface timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 37 SPI interface timing, VDD = 3.3V . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 39 Order codes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 41 Document revision history . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42 C4028-DAT-01p MegaChips’ Proprietary Information Page 4 of 43 STDP4028 List of Figures Figure 1. Figure 2. Figure 3. Figure 4. Figure 5. Figure 6. Figure 7. Figure 8. Figure 9. Figure 10. Figure 11. Figure 12. System interface block diagram . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Pin diagram. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 26 Marking template . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Digital video input timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 31 LVDS single-ended waveform . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 Receiver strobe positions LVDS input . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 33 Receiver margins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 34 Digital audio I2S input timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 35 I2C Timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 38 SPI output or serial interface SPI ROM input timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 39 SPI input or serial interface SPI ROM output timing . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 40 C4028-DAT-01p MegaChips’ Proprietary Information Page 5 of 43 STDP4028 1. Description The STDP4028 is a DisplayPort transmitter IC for the secure transmission of high-bandwidth, uncompressed digital audio-video signals targeted for applications such as DTV, LCD monitor, docking station, STB and other types of consumer audio-video systems. STDP4028 is VESA DP 1.1a and eDP compliant device, implementing a single link DisplayPort output port comprising four main lanes, auxiliary channel, and HPD. In addition to the standard HBR (2.7 Gbps) and RBR (1.62 Gbps) speeds, this device supports “turbo” speed of 3.24 Gbps per lane with a total link bandwidth of 12.96 Gbps. The higher bandwidth provides unique benefits to users over other commercial DP transmitters for embedded applications by offering additional margin to support higher color depth, resolution, and refresh rate. For example, STDP4028 supports FHD non-reduced blanking video (1080p 30-bit color per pixel) at 120 Hz, plus 7.1 Ch audio in two-box TV applications. The high-speed auxiliary channel in STDP4028 acts as a bidirectional communication link, supporting application-specific protocols such as MCCS, DDC, UART, IR, as well as, the dedicated DisplayPort link training and device management functions. The STDP4028 supports RGB and YUV video color formats with color depth of 12 (YUV 4:2:2 only), 10, and 8 bits. This device offers LVDS and LVTTL input interface configurable to map a wide range of display controller products. The Quad LVDS interface supports video signals up to 400 MHz pixel rate with flexible channel and lane swapping options. The 60-bit LVTTL input ports on STDP4028 can be mapped to transfer video data either in two pixels per clock or single pixel per clock of a chosen color depth. The STDP4028 also supports both compressed and uncompressed audio formats. This device comprises four I2S audio inputs, supporting up to 8 channels LPCM audio and a single wire SPDIF input for encoded audio. The STDP4028 features HDCP 1.3 content protection scheme with an embedded key option for secure transmission of digital audio-video content. In addition, it supports the HDCP repeater function and, thus acts as a downstream transmitter suitable for two-box TV and HDMI/DVI to DP converter applications.The STDP4028 is configurable from an external host through the I2C host interface. This IC also includes general-purpose inputs/outputs for controlling system components. The STDP4028 features a color space converter (RGB to YUV and YUV to RGB) for flexible interface with external video processing devices. C4028-DAT-01p MegaChips’ Proprietary Information Page 6 of 43 STDP4028 2. Application overview The STDP4028 is designed as DisplayPort transmitter device for transferring high bandwidth video and audio in PC and CE applications. Typical audio-video source system has a graphics or video processing device that acts as system master (host). The host controller configures STDP4028 through an I2C host interface. The host and STDP4028 also use interrupt mechanism whenever the slave needs attention. The STDP4028 may require an external SPI Flash to store firmware for supporting custom specific applications. The audio and video signal from the host controller is converted in to DisplayPort streams through STDP4028 and transfer to an external display system over standard DisplayPort cable. The I2C to AUX bypass channel handles the I2C traffic between STDP4028 and host controller as shown in the figure below. Figure 1. System interface block diagram DP EDID SPI Flash Flash I 2C I2C I2C slave INTR Host Controller TTL( 60 bit) HS, VS, CLK, DE STDP4028 Main Link AUX CH HPD_in I2S/SPDIF C4028-DAT-01p MegaChips’ Proprietary Information Page 7 of 43 DP Connector I2C Master DP Connector SPI DP Rx DP Rx STDP4028 3. Feature attributes • Video – Up to 2560 x 2048-60 Hz, 2560 x 1600-60 Hz, FHD 120 Hz at 10-bits per color – 8/10/12 bits per color option – RGB/YUV color format • Audio – 8-Ch I2S; word length up to 64 x Fs; bit depth up to 24 bits, sample rate up to 192 kHz – SPDIF; 2-Ch LPCM, AC3, DTS, bit depth up to 24 bits, sample rate up to 192 kHz • Input interface – Video: TTL 60/48 bits wide; QLVDS 8/10 bits per color – Audio: I2S 8-Ch, SPDIF x1 • Output interface – DP 1.1a (4 lanes, AUX, HPD); supported link speed 3.24 Gbps, 2.7 Gbps, 1.62 Gbps • Spread spectrum – Supported on DP output and LVDS/TTL inputs • AUX capabilities – UART, I2C-over-AUX (MCCS, DDC, etc.) IR • HDCP – On-chip keys, HDCP repeater • Color format conversion – RGB 4:4:4 to YUV 4:4:4 and vice-versa • System configuration – I2C host interface for control by an external system microprocessor • Package – 164 LFBGA (12 x 12 mm), 1 mm thickness, 0.8 pitch • Power – Standby power 18 mW • ESD – 2 KV HBM, 200 V MM, 750 V CDM C4028-DAT-01p MegaChips’ Proprietary Information Page 8 of 43 STDP4028 4. BGA footprint and pin lists 4.1 Ball grid array diagram The ball grid array (BGA) diagrams give the allocation of pins to the package, shown from the top looking down using the PCB footprint. Some signal names in BGA diagrams have been abbreviated. Refer toTable 2: Pin list on page 11 for full signal names sorted by pin number. Table 1. Key to BGA diagrams Function Type DisplayPort input SIG Reference clocks SIG System controls SIG Multi-function and system interface connections SIG I2S/SPDIF audio output SIG LVDS/TTL Output_Even-0 SIG LVDS/TTL Output_Even-1 SIG LVDS/TTL Output_Odd-0 SIG LVDS/TTL Output_Odd-1 SIG Analog power VCC/VDD Analog ground VSS/GND System power VCC/VDD System ground VSS/GND No connect/Do not connect NC/DNC No ball C4028-DAT-01p MegaChips’ Proprietary Information Page 9 of 43 Key STDP4028 The STDP4028 is available in a 164-pin LFBGA package. Figure 2. Pin diagram C4028-DAT-01p MegaChips’ Proprietary Information Page 10 of 43 STDP4028 4.2 Full pin list sorted by pin number Table 2. Pin list Pin number A1 PVSS3 A2 VSS_RPLL A3 VDD_RPLL A7 DPTX_ML_L1N A8 DPTX_ML_L2N A12 AUX_UART_RX_GPIO_22 A13 I2C_SDA_GPIO_25 A14 PVSS3 B1 UART_RX_GPIO_14 B2 NC B3 NC B4 TX_XTAL B6 DPTX_ML_L0N B7 DPTX_ML_L1P B8 DPTX_ML_L2P B9 DPTX_ML_L3N B11 DPTX_VDDA_1V2 B12 AUX_UART_TX_BOOT4_GPIO_21 B13 I2C_SCL_GPIO_24 B14 AUX_I2C_SDA_GPIO_16 C1 I2S_BCLK_GPIO_7 C2 UART_TX_BOOT1_GPIO_13 C3 VBUFC_RPLL C4 TX_TCLK C5 VSSA_TX C6 DPTX_ML_L0P C7, C8 C4028-DAT-01p Net name DPTX_VDDA_1V2 C9 DPTX_ML_L3P C10 DPTX_AUXN C11 DPTX_REXT C12 DPTX_HDP_IN_GPIO_23 C13 AUX_I2C_SCL_GPIO_15 C14 SPI_DO MegaChips’ Proprietary Information Page 11 of 43 STDP4028 Table 2. Pin list (continued) Pin number D2 I2S_0_GPIO_8 D3 I2S_3_GPIO_11 D4 GPIO_1_BOOT2 D5 VDD33_TX D6 VDDA_3V3 D7, D8 DPTX_VSSA D9 DPTX_VDDA_1V2 D10 DPTX_AUXP D11 NC D12 IRQ_BOOT7_GPIO_12 D13 SPI_DI E3 CLK_OUT_GPIO_5_BOOT0 E4 I2S_WCLK_GPIO_4 E5 PWM0_GPIO_0_BOOT3 E6 RESETn E7, E8 PVDD1 E9, E10 DPTX_VSSA E11 NC E12 SPI_CLK F2 AVSS_OUT_LVRX F3 TESTMODE0 F4 I2S_2_GPIO_10 F5 I2S_1_GPIO_9 F6, F7, F8, F9 PVSS3 F10 SPI_CSn F11 GPIO_3_BOOT6 F12 NC F13 AVSS_OUT_LVRX G1 E1_LVRX_CH0N G2 E1_LVRX_CH0P G3 TESTMODE1 G4 IR_IN_GPIO_6 G5 PVDD22 G6, G7, G8, G9 G10 C4028-DAT-01p Net name PVSS3 GPIO_2_BOOT5 MegaChips’ Proprietary Information Page 12 of 43 STDP4028 Table 2. Pin list (continued) Pin number G11 PVDD21 G12 NC G13 O1_LVRX_CH4N G14 O1_LVRX_CH4P H1 E1_LVRX_CH1N H2 E1_LVRX_CH1P H3 AVDD_OUT_LVRX_33 H4 E1_LVRX_CH5P H5 AVSS_OUT_LVRX H6, H7, H8, H9 PVSS3 H10 AVSS_OUT_LVRX H11 O1_LVRX_CH5P H12 AVDD_OUT_LVRX_33 H13 O1_LVRX_CH3N H14 O1_LVRX_CH3P J2 E1_LVRX_CH2N J3 E1_LVRX_CH2P J4 E1_LVRX_CH6N J5 E1_LVRX_CH5N J6, J7, J8, J9 C4028-DAT-01p Net name PVSS3 J10 O1_LVRX_CH5N J11 O1_LVRX_CH6P J12 O1_LVRX_CLKN J13 O1_LVRX_CLKP K3 E1_LVRX_CLKN K4 E1_LVRX_CLKP K5 E1_LVRX_CH6P K6 PVDD1 K7 AVSS_LVRX K8 AVSS_OUT_LVRX K9 PVDD1 K10 O1_LVRX_CH6N K11 O1_LVRX_CH2P K12 O1_LVRX_CH2N L2 E1_LVRX_CH3N MegaChips’ Proprietary Information Page 13 of 43 STDP4028 Table 2. Pin list (continued) Pin number C4028-DAT-01p Net name L3 E1_LVRX_CH3P L4 E0_LVRX_CH6P L5 E0_LVRX_CLKP L6 E0_LVRX_CH5P L7 AVDD_LVRX_12 L8 AVDD_OUT_LVRX_33 L9 O0_LVRX_CH5P L10 O0_LVRX_CH2P L11 O0_LVRX_CH6N L12 O1_LVRX_CH1N L13 O1_LVRX_CH1P M1 E1_LVRX_CH4N M2 E1_LVRX_CH4P M3 E0_LVRX_CH6N M4 E0_LVRX_CH2P M5 E0_LVRX_CLKN M6 E0_LVRX_CH3P M7 E0_LVRX_CH5N M8 O0_LVRX_CH5N M9 O0_LVRX_CH1P M10 O0_LVRX_CH2N M11 O0_LVRX_CLKP M12 O0_LVRX_CH6P M13 O1_LVRX_CH0N M14 O1_LVRX_CH0P N1 AVDD_OUT_LVRX_33 N2 E0_LVRX_CH0P N3 E0_LVRX_CH1P N4 E0_LVRX_CH2N N6 E0_LVRX_CH3N N7 E0_LVRX_CH4P N8 O0_LVRX_CH0P N9 O0_LVRX_CH1N N11 O0_LVRX_CLKN N12 O0_LVRX_CH3P MegaChips’ Proprietary Information Page 14 of 43 STDP4028 Table 2. Pin list (continued) Pin number C4028-DAT-01p Net name N13 O0_LVRX_CH4P N14 AVDD_OUT_LVRX_33 P1 AVSS_OUT_LVRX P2 E0_LVRX_CH0N P3 E0_LVRX_CH1N P7 E0_LVRX_CH4N P8 O0_LVRX_CH0N P12 O0_LVRX_CH3N P13 O0_LVRX_CH4N P14 AVSS_OUT_LVRX MegaChips’ Proprietary Information Page 15 of 43 STDP4028 5. Connections 5.1 Pin list I/O Legend: I = Input; O = Output; P = Power; G = Ground Note: Some pins can have multiple functionalities, which are configured under register control. The alternate functionality for each pin is listed in the Description column. Table 3. DisplayPort transmitter outputs Pin Assignment I/O Description B6 DPTX_ML_L0N O Negative output of DPTX Main Link Lane0 C6 DPTX_ML_L0P O Positive output of DPTX Main Link Lane0 A7 DPTX_ML_L1N O Negative output of DPTX Main Link Lane1 B7 DPTX_ML_L1P O Positive output of DPTX Main Link Lane1 A8 DPTX_ML_L2N O Negative output of DPTX Main Link Lane2 B8 DPTX_ML_L2P O Positive output of DPTX Main Link Lane2 B9 DPTX_ML_L3N O Negative output of DPTX Main Link Lane3 C9 DPTX_ML_L3P O Positive output of DPTX Main Link Lane3 C10 DPTX_AUXN I/O Negative input/output of DPTX Aux Channel D10 DPTX_AUXP I/O Positive input/output of DPTX Aux Channel C12 DPTX_HPD_IN/GPIO_23 I/O C11 DPTX_REXT I DisplayPort Receiver Hot Plug Detect Input General Purpose Schmitt Trigger Input / Tristate Output 26 [5V Tolerant] Termination calibration reference resistor; 240 ohm 1% resistor should be connected from this pin to 1.2 V analog power supply. Table 4. Reference clocks Pin Assignment I/O Description B4 TX_XTAL I/O Crystal Oscillator Input. Connect to external crystal. C4 TX_TCLK I/O Reference Clock (TCLK) from a 27 MHz Crystal or TTL Oscillator. Connect to external crystal or oscillator. C3 VBUFC_RPLL O Analog Test Pin for Internal Clocks. No connect. C4028-DAT-01p MegaChips’ Proprietary Information Page 16 of 43 STDP4028 Table 5. Digital video inputs Pin Assignment I/O Description K4 E1_LVRX_CLKP I Positive input of LVDS RX E1 Clock Channel TTL Even Red Channel Data 4 K3 E1_LVRX_CLKN I Negative input of LVDS RX E1 Clock Channel TTL Even Red Channel Data 7 Positive input of LVDS RX E1 Channel 0 G2 E1_LVRX_CH0P I TTL VSYNC Negative input of LVDS RX E1 Channel 0 G1 E1_LVRX_CH0N I TTL HSYNC Positive input of LVDS RX E1 Channel 1 H2 E1_LVRX_CH1P I TTL Even Red Channel Data 1 Negative input of LVDS RX E1 Channel 1 H1 E1_LVRX_CH1N I TTL Even Red Channel Data 0 Positive input of LVDS RX E1 Channel 2 J3 E1_LVRX_CH2P I TTL DE Negative input of LVDS RX E1 Channel 2 J2 E1_LVRX_CH2N I TTL Even Red Channel Data 9 Positive input of LVDS RX E1 Channel 3 L3 E1_LVRX_CH3P I TTL Even Red Channel Data 6 Negative input of LVDS RX E1 Channel 3 L2 E1_LVRX_CH3N I TTL Even Red Channel Data 5 Positive input of LVDS RX E1 Channel 4 M2 E1_LVRX_CH4P I TTL Even Red Channel Data 2 Negative input of LVDS RX E1 Channel 4 M1 E1_LVRX_CH4N I TTL Even Red Channel Data 3 J5 E1_LVRX_CH5N I TTL Even Red Channel Data 8 H4 E1_LVRX_CH5P I TTL Even Blue Channel Data 0 K5 E1_LVRX_CH6P I TTL Odd Red Channel Data 0 J4 E1_LVRX_CH6N I TTL Even Blue Channel Data 1 I Negative input of LVDS RX O1 Clock Channel J12 O1_LVRX_CLKN TTL Odd Blue Channel Data 8 J13 O1_LVRX_CLKP I Positive input of LVDS RX O1 Clock Channel TTL Odd Blue Channel Data 7 C4028-DAT-01p MegaChips’ Proprietary Information Page 17 of 43 STDP4028 Table 5. Digital video inputs Pin Assignment I/O M14 O1_LVRX_CH0P I Description Positive input of LVDS RX O1 Channel 0 TTL Odd Green Channel Data 6 Negative input of LVDS RX O1 Channel 0 M13 O1_LVRX_CH0N I TTL Odd Green Channel Data 5 Positive input of LVDS RX O1 Channel 1 L13 O1_LVRX_CH1P I TTL Odd Green Channel Data 3 Negative input of LVDS RX O1 Channel 1 L12 O1_LVRX_CH1N I TTL Odd Blue Channel Data 0 Positive input of LVDS RX O1 Channel 2 K11 O1_LVRX_CH2P I TTL Odd Green Channel Data 4 Negative input of LVDS RX O1 Channel 2 K12 O1_LVRX_CH2N I TTL Odd Green Channel Data 2 Positive input of LVDS RX O1 Channel 3 H14 O1_LVRX_CH3P I TTL Odd Blue Channel Data 4 Negative input of LVDS RX O1 Channel 3 H13 O1_LVRX_CH3N I TTL Odd Blue Channel Data 5 Positive input of LVDS RX O1 Channel 4 G14 O1_LVRX_CH4P I TTL Odd Blue Channel Data 2 Negative input of LVDS RX O1 Channel 4 G13 O1_LVRX_CH4N I TTL Odd Blue Channel Data 3 J10 O1_LVRX_CH5N I TTL Odd Green Channel Data 8 H11 O1_LVRX_CH5P I TTL Odd Blue Channel Data 6 K10 O1_LVRX_CH6N I TTL Odd Green Channel Data 9 J11 O1_LVRX_CH6P I TTL Odd Blue Channel Data 9 I Negative input of LVDS RX E0 Clock Channel M5 E0_LVRX_CLKN TTL Even Green Channel Data 2 L5 E0_LVRX_CLKP I Positive input of LVDS RX E0 Clock Channel TTL Even Green Channel Data 3 Negative input of LVDS RX E0 Channel 0 P2 E0_LVRX_CH0N I TTL Even Green Channel Data 0 Positive input of LVDS RX E0 Channel 0 N2 E0_LVRX_CH0P I TTL Even Green Channel Data 1 Negative input of LVDS RX E0 Channel 1 P3 E0_LVRX_CH1N I TTL Even Green Channel Data 6 C4028-DAT-01p MegaChips’ Proprietary Information Page 18 of 43 STDP4028 Table 5. Digital video inputs Pin Assignment I/O N3 E0_LVRX_CH1P I Description Positive input of LVDS RX E0 Channel 1 TTL Even Green Channel Data 7 Negative input of LVDS RX E0 Channel 2 N4 E0_LVRX_CH2N I TTL Even Green Channel Data 4 Positive input of LVDS RX E0 Channel 2 M4 E0_LVRX_CH2P I TTL Even Green Channel Data 5 Negative input of LVDS RX E0 Channel 3 N6 E0_LVRX_CH3N I TTL Even Blue Channel Data 7 Positive input of LVDS RX E0 Channel 3 M6 E0_LVRX_CH3P I TTL Even Blue Channel Data 8 Negative input of LVDS RX E0 Channel 4 P7 E0_LVRX_CH4N I TTL Odd Red Channel Data 1 Positive input of LVDS RX E0 Channel 4 N7 E0_LVRX_CH4P I TTL DCLK M7 E0_LVRX_CH5N I TTL Even Blue Channel Data 6 L6 E0_LVRX_CH5P I TTL Even Blue Channel Data 9 M3 E0_LVRX_CH6N I TTL Even Green Channel Data 9 L4 E0_LVRX_CH6P I TTL Even Green Channel Data 8 N11 O0_LVRX_CLKN I Negative input of LVDS RX O0 Clock Channel TTL Odd Red Channel Data 8 M11 O0_LVRX_CLKP I Positive input of LVDS RX O0 Clock Channel TTL Odd Red Channel Data 7 Negative input of LVDS RX O0 Channel 0 P8 O0_LVRX_CH0N I TTL Odd Green Channel Data 0 Positive input of LVDS RX O0 Channel 0 N8 O0_LVRX_CH0P I TTL Odd Green Channel Data 1 Negative input of LVDS RX O0 Channel 1 N9 O0_LVRX_CH1N I TTL Even Blue Channel Data 4 Positive input of LVDS RX O0 Channel 1 M9 O0_LVRX_CH1P I TTL Even Blue Channel Data 3 Negative input of LVDS RX O0 Channel 2 M10 O0_LVRX_CH2N I TTL Even Blue Channel Data 2 Positive input of LVDS RX O0 Channel 2 L10 O0_LVRX_CH2P I TTL Odd Red Channel Data 2 C4028-DAT-01p MegaChips’ Proprietary Information Page 19 of 43 STDP4028 Table 5. Digital video inputs Pin Assignment I/O P12 O0_LVRX_CH3N I Description Negative input of LVDS RX O0 Channel 3 TTL Odd Red Channel Data 6 Positive input of LVDS RX O0 Channel 3 N12 O0_LVRX_CH3P I TTL Odd Red Channel Data 5 Negative input of LVDS RX O0 Channel 4 P13 O0_LVRX_CH4N I TTL Odd Red Channel Data 4 Positive input of LVDS RX O0 Channel 4 N13 O0_LVRX_CH4P I TTL Odd Blue Channel Data 1 M8 O0_LVRX_CH5N I TTL Even Blue Channel Data 5 L9 O0_LVRX_CH5P I TTL Odd Red Channel Data 9 L11 O0_LVRX_CH6N I TTL Odd Green Channel Data 7 M12 O0_LVRX_CH6P I TTL Odd Red Channel Data 3 Table 6. Multi-function - digital audio output, general purpose input/output, bootstrap pins Pin Assignment I/O E4 I2S_WCLK_GPIO_4 I/O Description I2S_WCLK GPIO_4 I2S_BCLK C1 I2S_BCLK_GPIO_7 I/O GPIO_7 I2S_0 D2 I2S_0_GPIO_8 I/O GPIO_8 I2S_1 F5 I2S_1_GPIO_9 I/O GPIO_9 I2S_2 F4 I2S_2_GPIO_10 I/O GPIO_10 I2S_3 D3 I2S_3_GPIO_11 I/O GPIO_11 Table 7. Multi-function and system interface connections Pin Assignment I/O Description E6 RESETn I/O Reset (active low) signal. Connect to digital 3.3 V with a 2.7 K ohm pull-up resistor. F3 TESTMODE0 I G3 TESTMODE1 I Reserve for testing. Must be connected to system ground (GND) D13 SPI_DI I/O SPI ROM Data Input. C4028-DAT-01p MegaChips’ Proprietary Information Page 20 of 43 STDP4028 Table 7. Multi-function and system interface connections Pin Assignment I/O Description C14 SPI_DO I/O SPI ROM Data Output. E12 SPI_CLK I/O SPI ROM Clock F10 SPI_CSn I/O SPI ROM Chip Select. PWM0 E5 PWM0_GPIO_0_BOOT3 I/O BOOTSTRAP[3] Please refer to Bootstrap configuration table for description General Purpose Schmitt Trigger Input / Tri-state Output 0 [5V Tolerant] General Purpose Schmitt Trigger Input / Tri-state Output 1 [5V Tolerant] D4 GPIO_1_BOOT2 I/O BOOTSTRAP[2] Please refer to Bootstrap configuration table for description General Purpose Schmitt Trigger Input / Tri-state Output 2 [5V Tolerant] G10 GPIO_2_BOOT5 I/O BOOTSTRAP[5] Please refer to Bootstrap configuration table for description BOOTSTRAP[6] Please refer to Bootstrap configuration table for description F11 GPIO_3_BOOT6 I/O General Purpose Schmitt Trigger Input / Tri-state Output 3 [5V Tolerant] CLK_OUT E3 CLK_OUT_GPIO_5_BOOT0 I/O General Purpose Schmitt Trigger Input / Tri-state Output 5 [5V Tolerant] BOOTSTRAP[0] Please refer to Bootstrap configuration table for description Infra-red Receiver Data Input G4 IR_IN_GPIO_6 I/O General Purpose Schmitt Trigger Input / Tri-state Output 6 [5V Tolerant] IRQ D12 IRQ_BOOT7_GPIO_12 I/O BOOTSTRAP[7] Please refer to Bootstrap configuration table for description General Purpose Schmitt Trigger Input / Tri-state Output 12 [5V Tolerant] UART Transmit Data Output. C2 UART_TX_BOOT1_GPIO_1 3 I/O BOOTSTRAP[1] Please refer to Bootstrap configuration table for description General Purpose Schmitt Trigger Input / Tri-state Output 13 [5V Tolerant] C4028-DAT-01p MegaChips’ Proprietary Information Page 21 of 43 STDP4028 Table 7. Multi-function and system interface connections Pin Assignment I/O Description UART Receive Data Input. Pull up with 4.7K ohm resistor. B1 UART_RX_GPIO_14 I/O General Purpose Schmitt Trigger Input / Tri-state Output 14 [5V Tolerant] C13 AUX_I2C_SCL_GPIO_15 I/O I²C Serial Clock for DP AUX channel. This pin, along with AUX_I2C_SDA, creates external serial interface for DP AUX channel. Connect to digital 3.3V with 4.7K ohm resistor. General Purpose Schmitt Trigger Input / Tri-state Output 15 [5V Tolerant] B14 AUX_I2C_SDA_GPIO_16 I/O I²C Data Clock for DP AUX channel. This pin, along with AUX_I2C_SCL, creates external serial interface for DP AUX channel. Connect to digital 3.3V with 4.7K ohm resistor. General Purpose Schmitt Trigger Input / Tri-state Output 16 [5V Tolerant] UART Transmit Data Output for DP AUX channel B12 AUX_UART_TX_BOOT4_GP I/O IO_21 BOOTSTRAP[4] Please refer to Bootstrap configuration table for description General Purpose Schmitt Trigger Input / Tri-state Output 21 [5V Tolerant] UART Receive Data Input for DP AUX channel. Pull up with 4.7K ohm resistor. A12 AUX_UART_RX_GPIO_22 I/O General Purpose Schmitt Trigger Input / Tri-state Output 22 [5V Tolerant] I²C_SCL. Pull up to 3.3V with 4.7K ohm resistor. B13 I2C_SCL_GPIO_24 I/O A13 I2C_SDA_GPIO_25 I/O General Purpose Schmitt Trigger Input / Tri-state Output 24 [5V Tolerant] I²C_SDA. Pull up to 3.3V with 4.7K ohm resistor. General Purpose Schmitt Trigger Input / Tri-state Output 25 [5V Tolerant] Table 8. No connects Pin Assignment I/O F12 NC1 - G12 NC2 - D11 NC3 - E11 NC4 - B2 NC5 - B3 NC6 - Description No connection. C4028-DAT-01p MegaChips’ Proprietary Information Page 22 of 43 STDP4028 Table 9. System power and ground Pin Assignment I/O Description D6 VDDA_3V3 P Analog 3.3V VDD. Connect to analog 3.3V with 0.1µF bypass capacitor to analog ground plane on board. E7, E8, K6, K9 PVDD1 P Digital 1.2V VDD. Connect to digital 1.2V with 0.1µF bypass capacitor. G11 PVDD21 P Digital 3.3V VDD. Connect to digital 3.3V with 0.1µF bypass capacitor. Must be connected at same voltage level. G5 PVDD22 A1, A14, F6, F7, F8, F9, G6, G7, G8, G9, H6, H7, H8, H9, J6, J7, J8, J9 PVSS3 G Digital Ground. Each pin must be connected directly to digital ground plane. B11, C7, C8, D9 DPTX_VDDA_1V2 P DisplayPort Transmitter Analog 1.2V Power Supply. Must be bypassed with a 0.1µF capacitor to analog ground plane on board. D7, D8, E9, E10 DPTX_VSSA G DisplayPort Transmitter VSS. Must be directly connected to analog ground plane on board. D5 VDD33_TX P Analog 3.3V VDD. Connect to analog 3.3V with 0.1µF bypass capacitor to analog ground plane on board. C5 VSSA_TX G Analog ground. Must connect directly to analog ground plane on board H3, H12, L8, N1, N14 AVDD_OUT_LVRX_33 P Analog 3.3V VDD. Connect to analog 3.3V with 0.1µF bypass capacitor to analog ground plane on board. L7 AVDD_LVRX_12 P Analog 1.2V VDD. Connect to analog 1.2V with 0.1µF bypass capacitor to analog ground plane on board. K7 AVSS_LVTX G Analog ground. Must connect directly to analog ground plane on board. F2, F13, H5, H10, K8, P1, P14 AVSS_OUT_LVRX G Analog ground. Must connect directly to analog ground plane on board. A2 VSS_RPLL G Analog Ground for the DDS Reference PLL and Digital Core. Must be directly connected to analog ground plane on board. A3 VDD_RPLL P Analog 1.2V Power Supply for RCLK PLL and Digital Core. Must be bypassed with a 0.1µF capacitor to analog ground plane on board. C4028-DAT-01p MegaChips’ Proprietary Information Page 23 of 43 STDP4028 Note: 5.2 1 PVDD21 and PVDD22 must be connected to same power supply. 2 Add 47 K pull-down resistor for HPD_IN signal. Bootstrap configuration During hardware reset, on the rising edge of RESETn, logic high or low configuration on Bootstrap pins are latched and stored. 4.7 K pull-up or pull-down resistors must be installed to indicate logic '1' or '0' status on the bootstrap pins. Bootstrap operation is only guaranteed with external pull-up or pull-down resistors. There are eight Bootstrap pins available on STDP4028. Some bootstraps may not be available for normal use. Table 10. Bootstrap configuration Pin # Assignment Function E3 BOOT[0] Set to 1 (Pull High to Vdd) C2 BOOT[1] Set to 0 (Pull Low to GND) D4 BOOT[2] Set to 0 (Pull Low to GND) for normal operation BOOT[3] TTL_LVDS_OUT TTL/LVDS output mode selection 0 = Output is in LVDS format 1 = Output is in TTL format BOOT[4] OCM_BOOT_SEL 0 = OCM boot will be from internal ROM code. (Internal ROM is ‘ON’ and mapped to top 32K of OCM address range) 1 = OCM boot is from external ROM/Flash code (Internal ROM is ‘OFF’ and external ROM/Flash mapped to top 512K of OCM address range) E5 B12 G10 F11 D12 C4028-DAT-01p BOOT[5] WIDE_NARROW_BUS Selects wide or narrow LVDS or TTL bus LVDS 0 = DUAL LVDS 1 = QUAD LVDS TTL 0 = Single 1 = Dual BOOT[6] ASSR_ENABLE Selects whether ASSR is enabled 0 = Disabled 1 = Enabled BOOT[7] I2C_DEV_ID I2C slave Device ID select for RD/WR access. 0: 0xE6, 0xE7 1: 0xE4, 0xE5 MegaChips’ Proprietary Information Page 24 of 43 STDP4028 5.3 General purpose input/output (GPIO) pins The STDP4028 contains 25 general-purpose input/output (GPIO) pins for system configuration purpose. GPIO_0, GPIO_1 are dedicated general-purpose IO pins and the rest have shared functionality. Each GPIO has independent direction control and open drain enable for reading and writing. Note: The GPIO functionality is available only for custom applications. Default settings allow configuration of dedicated GPIO pins (GPIO_0 and GPIO_1) through host interface and the rest of the GPIO configuration requires over-riding the default feature using external firmware. C4028-DAT-01p MegaChips’ Proprietary Information Page 25 of 43 STDP4028 6. Package Package type: 164 LFBGA (12 x 12 mm / ball pitch 0.8 mm) Figure 3. Package specification C4028-DAT-01p MegaChips’ Proprietary Information Page 26 of 43 STDP4028 6.1 Marking field template and descriptors The STDP4028 marking template is shown below. Figure 4. Marking template Field descriptors are shown below. Table 11.Field descriptors Field Description Marking A Standard MegaChips logo M B 2-character version code AB C Product code STDP4028 D 8-character diffusion code 9R”ABCDEF” E 2-character assembly plant code AA F 3-character BE sequence code “XYZ” G 2-character diffusion plant code 9R H 3-character country of origin code TWN I 2-character test plant code AA J 1-digit assembly year “Y” K 2-digit assembly week “WW” L Ball A1 identifier a DOT C4028-DAT-01p MegaChips’ Proprietary Information Page 27 of 43 STDP4028 7. Electrical specification 7.1 Absolute maximum ratings Applied conditions greater than those listed under “Absolute maximum ratings” may cause permanent damage to the device. The device should never exceed absolute maximum conditions since it may affect device reliability. Table 12. Absolute maximum ratings Parameter Symbol Min Typ Max Units VVDD_3.3 -0.3 3.3 3.6 V VVDD_1.2 -0.3 1.2 1.26 V VIN5Vtol -0.3 - 5.5 V Input voltage (non 5V tolerant inputs) (1,2) VIN -0.3 - 3.6 V ESD - Human Body Model (HBM)(4) VESD - - ±2.0 kV VESD - - ±200 V VESD - - ±500 V Latch-up ILA - - ±100 mA Ambient operating temperature TA 0 - 70 °C Storage temperature TSTG -40 - 150 °C Operating junction temperature TJ 0 - 125 °C Thermal resistance (Junction to Ambient)(3) θJA - - 36.6 °C/W Thermal resistance (Junction to Case)(3) θJC - - 18.1 °C/W Peak IR reflow soldering temperature (
STDP4028AB 价格&库存
很抱歉,暂时无法提供与“STDP4028AB”相匹配的价格&库存,您可以联系我们找货
