NJM2244D
NJM2244D
    JRC(⽇本无线)
    DIP-8
    IC VIDEO SWITCH 3-IN W/DVR 8-DIP
NJM2244D 数据手册
NJM2244 3-INPUT VIDEO SWITCH WITH 75Ω DRIVER ■ GENERAL DESCRIPTION The NJM2244 is a three input integrated video switch witch selects one video or audio signal from three input signals. It contains driver circuit for 75Ω load and is able to connect to TV monitor. Its operating supply voltage range is 5 to 12v and bandwidth is 10MHz. Crosstalk is 70dB (at 4.43MHZ). NJM2244 contains clamp function and it can be operated while setting DC level fixed in position of the video signal. ■ FEATURES • Operating Voltage 4.75 to 13V • 3 input-1 Output • Internal Driver Circuit for 75Ω Impedance • Muting Function available • Internal Clamp Function • Low power Dissipation 16.5mA • Cross-talk 70dB (at 4.43MHz) • Wide Frequency Range 10MHz (2VP-P Input) • Package Outline DIP8, DMP8, SIP8 • Bipolar Technology ■ APPLICATION • VCR Video Camera AV-TV Video Disc Player ■ PIN CONFIGURATION ■ BLOCK DIAGRAM Pin Connection NJM2244D NJM2244M ■ PACKAGE OUTLINE NJM2244D NJM2244M NJM2244L NJM2244L ■ INPUT CONTROL SIGNAL-OUTPUT SIGNAL SW1 SW2 OUTPUT SIGNAL L L VIN1 H L VIN2 L/H H VIN3 note): Input clamp Voltage is about 2/5 of Supply Voltage Ver.2004-02-17 -1- NJM2244 ■ ABSOLUTE MAXIMUM RATINGS PARAMETER (Ta = 25ºC) SYMBOL RATINGS + UNIT Supply Voltage V 15 V Power Dissipation PD (DIP8) 500 (DMP8) 300 (SIP8) 800 mW mW mW Operating Temperature Range Topr -20 to +75 ºC Storage Temperature Range Tstg -40 to +125 ºC (V+ = 5V, Ta = 25ºC) ■ ELECTRICAL CHARACTERISTICS PARAMETER SYMBOL TEST CONDITION + MIN. TYP. MAX. UNIT 4.75 - 13.0 V Recommended Supply Voltage V Operating Current ICC S1 = S2 = S3 = S4 = S5 = 2 11.5 16.5 22.0 mA Voltage Gain GV Vin = 2.0VP-P, 100kHz, VO / Vi, RL = 150Ω -0.8 -0.3 +0.2 dB Frequency Characteristics Gf Vin = 2.0VP-P, VO (10MHz) / VO (100kHz), RL = 150Ω -1.0 - +1.0 dB Differential Gain DG Vin = 2.0VP-P, staircase, RL = 150Ω - 0.3 - % Differential Phase DP Vin = 2.0VP-P, staircase, RL = 150Ω - 0.3 - deg. Output Offset Voltage Voff S1 = S2 = S3 = 2, S5 = 1 → 2Vo : Voltage change - 0 ±30 mV Crosstalk CT Vin = 2VP-P, 4.43MHz, Vo / Vi - -70 - dB VCH All inside Sw : ON 2.4 - - V VCL All inside Sw : OFF - - 0.8 V Switch Change Voltage (note) Unless specified, tested with three mode below. a) S1 = 1, S2 = S3 = S4 = S5 = 2 b) S2 = S4 = 1, S1 = S3 = S5 = 2 c) S1 = S2 = 2, S3 = S5 = 1, S4 = 1 or 2 ■ APPLICATION Oscillation Prevention on light loading conditions Recommended under circuit -2- Ver.2004-02-17 NJM2244 ■ TEST CIRCUIT DC Voltage Each Terminal Typ. on Test Circuit Ta = 25ºC Terminal Name DC Voltage Ver.2004-02-17 VIN1 2 5 + V SW1 - VIN2 2 5 + V SW2 - VIN3 2 5 + V + V - 2 5 VOUT GND + - V -0.7 -3- NJM2244 ■ EQUIVALENT CIRCUIT PIN NO. PIN FUNCTION 1 PIN NO. PIN FUNCTION VIN1 5 VIN3 (Mute) 2 SW1 6 V 3 VIN2 7 VOUT 4 SW2 8 GND -4- INSIDE EQUIVALENT CIRCUIT INSIDE EQUIVALENT CIRCUIT + Ver.2004-02-17 NJM2244 ■ APPLICATION This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes an unstable pin voltage. This IC requires 0.1uF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp type input at mute mode. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2004-02-17 -5-
NJM2244D
物料型号:NJM2244
器件简介:NJM2244是一款三输入集成视频开关,可以从三个输入信号中选择一个视频或音频信号。它包含用于75欧姆负载的驱动电路,并能连接到电视监视器。其工作电源电压范围为5至12伏,带宽为10MHz,串扰为70dB(在4.43MHz时)。
引脚分配:NJM2244有8个引脚,包括GND、Vout、Vin3、SW2、Vin1、SW1、Vn3(静音)和Vou。
参数特性: - 工作电压:4.75至13V - 3输入1输出 - 内部75欧姆阻抗驱动电路 - 静音功能可用 - 内部钳位功能 - 低功耗:16.5mA - 交叉谈话:70dB(在4.43MHz时) - 宽带宽:10MHz - 封装外形:DIP8, DMP8, SIP8 - 双极型技术
功能详解:NJM2244具有钳位功能,可以在视频信号的DC电平固定位置时操作。它还具有静音功能,并且可以在轻负载条件下防止振荡。
应用信息:适用于VCR、视频摄像机、AV-TV、视频光盘播放器等。
封装信息:NJM2244有三种封装类型,分别是NJM2244D、NJM2244M和NJM2244L。
绝对最大额定值包括供电电压15V,功耗(DIP8)500mW,(DMP8)300mW,(SIP8)800mW,工作温度范围-20至+75℃,存储温度范围-40至+125℃。
电气特性包括推荐供电电压4.75至13.0V,工作电流11.5至22.0mA,电压增益-0.8至+0.2dB,频率特性-1.0至+1.0dB,差分增益0.3%,差分相位0.3度,输出偏置电压0至±30mV,交叉谈话-70dB。
NJM2244D 价格&库存
很抱歉,暂时无法提供与“NJM2244D”相匹配的价格&库存,您可以联系我们找货
