74LVC1GU04GW,165
74LVC1GU04GW,165
    NEXPERIA(安世)
    TSSOP5
    IC INVERTER 1CH 1-INP 5TSSOP
74LVC1GU04GW,165 数据手册
74LVC1GU04 Unbuffered inverter Rev. 13 — 12 December 2016 Product data sheet 1. General description The 74LVC1GU04 is a single unbuffered inverter. The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of this device in a mixed 3.3 V and 5 V environment. 2. Features and benefits  Wide supply voltage range from 1.65 V to 5.5 V  High noise immunity  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  24 mA output drive (VCC = 3.0 V)  CMOS low power consumption  Latch-up performance exceeds 250 mA  Input accepts voltages up to 5 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC1GU04GW 40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads; body width 1.25 mm SOT353-1 74LVC1GU04GV 40 C to +125 C SC-74A plastic surface-mounted package; 5 leads SOT753 74LVC1GU04GM 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1.45  0.5 mm SOT886 74LVC1GU04GF 40 C to +125 C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1  1  0.5 mm SOT891 74LVC1GU04GN 40 C to +125 C XSON6 extremely thin small outline package; no leads; SOT1115 6 terminals; body 0.9  1.0  0.35 mm 74LVC1GU04GS 40 C to +125 C XSON6 extremely thin small outline package; no leads; SOT1202 6 terminals; body 1.0  1.0  0.35 mm 74LVC1GU04GX 40 C to +125 C X2SON5 X2SON5: plastic thermal enhanced extremely thin small outline package; no leads; 5 terminals; body 0.8  0.8  0.35 mm SOT1226 74LVC1GU04 Nexperia Unbuffered inverter 4. Marking Table 2. Marking codes Type number Marking[1] 74LVC1GU04GW VD 74LVC1GU04GV VU4 74LVC1GU04GM VD 74LVC1GU04GF VD 74LVC1GU04GN VD 74LVC1GU04GS VD 74LVC1GU04GX VD [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram 9&& ȍ $  $ <   PQD Fig 1.  <  PQD Logic symbol Fig 2. 9&& PQD IEC logic symbol Fig 3. Logic diagram 6. Pinning information 6.1 Pinning /9&*8 /9&*8 QF  $  *1'    QF   9&& $   QF *1'   < 9&& < DDE 7UDQVSDUHQWWRSYLHZ DDE Fig 4. Pin configuration SOT353-1 and SOT753 74LVC1GU04 Product data sheet Fig 5. Pin configuration SOT886 All information provided in this document is subject to legal disclaimers. Rev. 13 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 2 of 20 74LVC1GU04 Nexperia Unbuffered inverter /9&* /9&*8 QF QF   9&& $   QF *1'   <  9&&  <  *1' $ DDI  DDD 7UDQVSDUHQWWRSYLHZ 7UDQVSDUHQWWRSYLHZ Fig 6.  Pin configuration SOT891, SOT1115 and SOT1202 Fig 7. Pin configuration SOT1226 (X2SON5) 6.2 Pin description Table 3. Pin description Symbol Pin Description TSSOP5, SC-74A and X2SON5 XSON6 n.c. 1 1 not connected A 2 2 data input GND 3 3 ground (0 V) Y 4 4 data output n.c. - 5 not connected VCC 5 6 supply voltage 7. Functional description Table 4. Function table[1] Input (A) Output (Y) L H H L [1] H = HIGH voltage level; L = LOW voltage level. 74LVC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 3 of 20 74LVC1GU04 Nexperia Unbuffered inverter 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current Conditions [1] Active mode VO = 0 V to VCC output current supply current IGND ground current Ptot total power dissipation Tstg storage temperature Unit 0.5 +6.5 V - 50 mA 0.5 +6.5 V - 50 mA 0.5 VCC + 0.5 VO > VCC or VO < 0 V output voltage IO Max VI < 0 V VO ICC Min [1][2] Tamb = 40 C to +125 C - 50 mA - +100 mA - 100 mA - 250 mW 65 +150 C [3] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. [3] V For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 and X2SON5 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature t/V input transition rise and fall rate 74LVC1GU04 Product data sheet Conditions Active mode Min Typ Max Unit 1.65 - 5.5 V 0 - 5.5 V 0 - VCC V 40 - +125 C VCC = 1.65 V to 2.7 V 0 - 20 ns/V VCC = 2.7 V to 5.5 V 0 - 10 ns/V All information provided in this document is subject to legal disclaimers. Rev. 13 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 4 of 20 74LVC1GU04 Nexperia Unbuffered inverter 10. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C VIH HIGH-level input voltage VCC = 1.65 V to 5.5 V 0.75  VCC - VIL LOW-level input voltage VCC = 1.65 V to 5.5 V - - VOH HIGH-level output voltage VI = VIH or VIL VCC 0.1 - - V IO = 4 mA; VCC = 1.65 V 1.2 - - V IO = 8 mA; VCC = 2.3 V 1.9 - - V IO = 12 mA; VCC = 2.7 V 2.2 - - V IO = 24 mA; VCC = 3.0 V 2.3 - - V IO = 32 mA; VCC = 4.5 V 3.8 - - V IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.45 V IO = 100 A; VCC = 1.65 V to 5.5 V VOL LOW-level output voltage - V 0.25  VCC V VI = VIH or VIL IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - 0.1 1 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - 0.1 4 A CI input capacitance VCC = 3.3 V; VI = GND to VCC - 6 - pF - V Tamb = 40 C to +125 C VIH HIGH-level input voltage VCC = 1.65 V to 5.5 V 0.8  VCC - VIL LOW-level input voltage VCC = 1.65 V to 5.5 V - - VOH HIGH-level output voltage VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 5.5 V 74LVC1GU04 Product data sheet 0.2  VCC V VCC 0.1 - - V IO = 4 mA; VCC = 1.65 V 0.95 - - V IO = 8 mA; VCC = 2.3 V 1.7 - - V IO = 12 mA; VCC = 2.7 V 1.9 - - V IO = 24 mA; VCC = 3.0 V 2.0 - - V IO = 32 mA; VCC = 4.5 V 3.4 - - V All information provided in this document is subject to legal disclaimers. Rev. 13 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 5 of 20 74LVC1GU04 Nexperia Unbuffered inverter Table 7. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Min Typ[1] Max Unit IO = 100 A; VCC = 1.65 V to 5.5 V - - 0.1 V IO = 4 mA; VCC = 1.65 V - - 0.7 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.6 V IO = 24 mA; VCC = 3.0 V - - 0.80 V Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage - - 0.80 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IO = 32 mA; VCC = 4.5 V - 0.1 1 A ICC supply current VI = 5.5 V or GND; IO = 0 A; VCC = 1.65 V to 5.5 V - - 4 A [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 C. 11. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 11. Symbol Parameter 40 C to +85 C Conditions propagation delay A to Y; see Figure 8 tpd [1] Max Min Max 0.3 1.7 5.0 0.3 6.5 ns VCC = 2.3 V to 2.7 V 0.3 1.3 4.0 0.3 5.5 ns VCC = 2.7 V 0.5 1.7 5.0 0.5 6.5 ns VCC = 3.0 V to 3.6 V 0.5 1.6 3.7 0.5 5.0 ns 0.5 1.3 3.0 0.5 4.0 ns - 14.9 - - - pF VCC = 4.5 V to 5.5 V power dissipation capacitance Typ[1] [2] VCC = 1.65 V to 1.95 V CPD 40 C to +125 C Unit Min [3] VI = GND to VCC; VCC = 3.3 V Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. [2] tpd is the same as tPLH and tPHL. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74LVC1GU04 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 13 — 12 December 2016 © Nexperia B.V. 2017. All rights reserved 6 of 20 74LVC1GU04 Nexperia Unbuffered inverter 12. Waveforms 9, 90 $LQSXW *1' W 3+/ W 3/+ 92+ 90
74LVC1GU04GW,165 价格&库存
很抱歉,暂时无法提供与“74LVC1GU04GW,165”相匹配的价格&库存,您可以联系我们找货
74LVC1GU04GW,165
