74ABT16245BDGG,518
74ABT16245BDGG,518
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    IC TXRX NON-INVERT 5.5V 48TSSOP
74ABT16245BDGG,518 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74ABT16245B 16-bit bus transceiver; 3-state Rev. 4 — 19 August 2014 Product data sheet 1. General description The 74ABT16245B high-performance BiCMOS device combines low static and dynamic power dissipation with high speed and high output drive. The 74ABT16245B device is a dual octal transceiver featuring non-inverting 3-state bus compatible outputs in both send and receive directions. The control function implementation minimizes external timing requirements. The device features two output enable (1OE, 2OE) inputs for easy cascading and two direction (1DIR, 2DIR) inputs for direction control. 2. Features and benefits         16-bit bidirectional bus interface Multiple VCC and GND pins minimize switching noise Power-up 3-state 3-state buffers Output capability: +64 mA / 32 mA Live insertion/extraction permitted Latch-up performance: JESD 78 Class II ESD protection:  HBM JESD22-A114E exceeds 2000 V  CDM JESD22-C101C exceeds 1000 V 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74ABT16245BDL 40 C to +85 C SSOP48 plastic shrink small outline package; 48 leads; body SOT370-1 width 7.5 mm 74ABT16245BDGG 40 C to +85 C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 4. Functional diagram ',5 ',5 2( 2( $ $ % $ % $ % $ % $ % $ % $ % $ % $ % $ % $ % $ % $ % % $ $ % % DDD Fig 1. Logic symbol 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 2 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 2( ',5 * (1>%$@ (1>$%@ * (1>%$@ (1>$%@ 2( ',5 $ %   $ % $ % $ % $ % $ % $ % $ % $ %   $ % $ % $ % $ % $ % $ % $ % DDD Fig 2. IEC logic symbol 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 3 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 5. Pinning information 5.1 Pinning $%7% ',5   2( %   $ %   $ *1'   *1' %   $ %   $ 9&&  %   9&&  $ %   $ *1'   *1' %   $ %   $ %   $ %   $ *1'   *1' %   $ %   $ 9&&  %   9&&  $ %   $ *1'   *1' %   $ %   $ ',5   2( DDD Fig 3. Pin configuration SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1DIR, 2DIR 1, 24 direction control input 1B0 to 1B7 2, 3, 5, 6, 8, 9, 11, 12 data input/output 2B0 to 2B7 13, 14, 16, 17, 19, 20, 22, 23 data input/output GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 1OE, 2OE 48, 25 output enable input (active LOW) 1A0 to 1A7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 2A0 to 2A7 36, 35, 33, 32, 30, 29, 27, 26 data input/output 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 4 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 6. Functional description Table 3. Function table[1] Inputs Outputs nOE nDIR nAn nBn L L nAn = nBn inputs L H inputs nBn = nAn H X Z Z [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7.0 V [1] 1.2 +7.0 V [1] 0.5 +5.5 V VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current VI < 0 V 18 - mA IOK output clamping current VO < 0 V 50 - mA IO output current output in LOW-state - 128 mA output in HIGH-state 64 - mA - 150 C 65 +150 C Tj junction temperature Tstg storage temperature [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. 8. Recommended operating conditions Table 5. Operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter Min Max Unit VCC supply voltage 4.5 5.5 V VI input voltage 0 VCC V VIH HIGH-level input voltage 2.0 - V VIL LOW-level input voltage - 0.8 V IOH HIGH-level output current 32 - mA IOL LOW-level output current - 64 mA t/V input transition rise and fall rate - 10 ns/V Tamb ambient temperature 40 +85 C 74ABT16245B Product data sheet Conditions in free air All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 5 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 9. Static characteristics Table 6. Static characteristics Symbol Parameter 25 C Conditions 40 C to +85 C Unit Min Typ Max Min Max VIK input clamping voltage VCC = 4.5 V; IIK = 18 mA 1.2 0.9 - 1.2 - V VOH HIGH-level output voltage VCC = 4.5 V; IOH = 3 mA 2.5 2.9 - 2.5 - V VCC = 5.0 V; IOH = 3 mA 3.0 3.4 - 3.0 - V VCC = 4.5 V; IOH = 32 mA 2.0 2.4 - 2.0 - V VI = VIL or VIH VOL LOW-level output voltage VCC = 4.5 V; IOL = 64 mA; VI = VIL or VIH - 0.42 0.55 - 0.55 V II input leakage current control pins; VCC = 5.5 V; VI = VCC or GND - 0.01 1.0 - 1.0 A IOFF power-off leakage current VCC = 0 V; VI or VO  4.5 V - 5.0 100 - 100 A IO(pu/pd) power-up/power-down VCC = 2.0 V; VO = 0.5 V; output current VI = GND or VCC; nOE = HIGH - 5.0 50 - 50 A IOZ OFF-state output current output HIGH-state at VO = 5.5 V - 0.1 10 - 10 A output LOW-state at VO = 0 V - 0.1 10 - 10 A - 5.0 50 - 50 A 50 92 180 50 180 mA outputs HIGH-state - 0.30 0.7 - 0.7 mA outputs LOW-state - 10 19 - 19 mA outputs 3-state - 0.30 0.7 - 0.7 mA outputs enabled; one data input at 3.4 V and other inputs at VCC or GND - 400 700 - 700 A outputs disabled; one data input at 3.4 V and other inputs at VCC or GND - 100 250 - 250 A control pins; outputs disabled; one enable input at 3.4 V and other inputs at VCC or GND - 400 700 - 700 A VCC = 5.5 V; VI = VIL or VIH ILO output leakage current HIGH-state; VO = 5.5 V; VCC = 5.5 V; VI = GND or VCC IO output current VCC = 5.5 V; VO = 2.5 V ICC supply current VCC = 5.5 V; VI = GND or VCC ICC additional supply current [1] per input pin; VCC = 5.5 V [2] [3][4] CI input capacitance VI = 0 V or VCC - 4 - - - pF CI/O input/output capacitance outputs disabled; VO = 0 V or VCC - 7 - - - pF [1] This parameter is valid for any VCC between 0 V and 2.1 V, with a transition time of up to 10 ms. From VCC = 2.1 V to VCC = 5 V  10 %, a transition time of up to 100 s is permitted. [2] Not more than one output should be tested at a time, and the duration of the test should not exceed one second. [3] This is the increase in supply current for each input at 3.4 V. [4] This data sheet limit may vary among suppliers. 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 6 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V. For test circuit, see Figure 6. Symbol Parameter 25 C; VCC = 5.0 V Conditions 40 C to +85 C; VCC = 5.0 V  0.5 V Unit Min Typ Max Min Max tPLH LOW to HIGH propagation delay nAn to nBn; see Figure 4 1.0 2.0 3.2 1.0 3.5 ns tPHL HIGH to LOW propagation delay nAn to nBn; see Figure 4 1.0 2.3 3.5 1.0 4.0 ns tPZH OFF-state to HIGH propagation delay nOE to nAn or nBn; see Figure 5 1.0 3.0 4.4 1.0 5.1 ns tPZL OFF-state to LOW propagation delay nOE to nAn or nBn; see Figure 5 1.7 4.0 5.2 1.7 6.1 ns tPHZ HIGH to OFF-state propagation delay nOE to nAn or nBn; see Figure 5 1.7 3.5 4.9 1.7 5.4 ns tPLZ LOW to OFF-state propagation delay nOE to nAn or nBn; see Figure 5 1.5 3.2 4.4 1.5 5.0 ns 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 7 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 11. Waveforms 9, Q$QQ%Q LQSXW  *1' 90 W 3+/ W 3/+ 92+ Q%QQ$Q RXWSXW  92/ 90 PQD VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Fig 4. Input (nAn) to output (nBn) propagation delay times 9, 90 Q2(LQSXW *1' W3=/ W3/= 9 90 Q$QQ%QRXWSXW 92/9 92/ W3=+ W3+= 92+ 90 Q$QQ%QRXWSXW 92+9 9 DDD VM = 1.5 V VOL and VOH are typical voltage output levels that occur with the output load. Fig 5. 3-state output enable and disable times 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 8 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 12. Test information W: 9,   QHJDWLYH SXOVH 90   9 9, WI WU WU WI  SRVLWLYH SXOVH 9 90  90 90   W: DDL VM = 1.5 V a. Input pulse definition VEXT VCC PULSE GENERATOR VI RL VO DUT CL RT RL 001aac764 Test data is given in Table 8. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. b. Test circuit for 3-state outputs Fig 6. Table 8. Test circuit for measuring switching times Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 3.0 V 1 MHz 500 ns 2.5 ns 50 pF 500  open 7.0 V open 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 9 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 13. Package outline 6623SODVWLFVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F \ +( Y 0 $ =   4 $ $ $ $   ș SLQLQGH[ /S /   GHWDLO; Z 0 ES H   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES PP         '   (   H +( / /S 4 Y Z \ =   ș                    R R F 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 Fig 7. 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Package outline SOT370-1 (SSOP48) 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 10 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F Y +( \ $ =   4 $ $ $ $ SLQLQGH[ ș /S /   GHWDLO; Z ES H  PP  VFDOH 'LPHQVLRQV PPDUHWKHRULJLQDOGLPHQVLRQV 8QLW PD[ QRP PLQ PP $ $ $ $    ES F '  (         H +(      /  /S 4     Y Z     \ = ș  ƒ  ƒ  1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 2XWOLQH YHUVLRQ 627 Fig 8. 5HIHUHQFHV ,(& -('(& -(,7$ VRWBSR (XURSHDQ SURMHFWLRQ ,VVXHGDWH   02 Package outline SOT362-1 (TSSOP48) 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 11 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 14. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ABT16245B v.4 20140819 Product data sheet - 74ABT_H16245B v.3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number 74ABTH16245BDL removed. 74ABT_H16245B v.3 20021213 Product data sheet - 74ABT_H16245B v.2 74ABT_H16245B v.2 19980225 Product data sheet - 74ABT_H16245B v.1 74ABT_H16245B v.1 19961120 Product data sheet - - 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 12 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74ABT16245B Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 13 of 15 74ABT16245B NXP Semiconductors 16-bit bus transceiver; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74ABT16245B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 19 August 2014 © NXP Semiconductors N.V. 2014. All rights reserved. 14 of 15 NXP Semiconductors 74ABT16245B 16-bit bus transceiver; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP Semiconductors N.V. 2014. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 19 August 2014 Document identifier: 74ABT16245B
74ABT16245BDGG,518
1. 物料型号:74ABT16245B 2. 器件简介: - 该器件是双八路收发器,具有非反相的3态总线兼容输出,适用于发送和接收方向。 - 控制功能实现最小化外部定时要求。 - 设备特点包括两个输出使能(1OE, 2OE)输入,便于级联和两个方向(1DIR, 2DIR)输入,用于方向控制。 3. 引脚分配: - 引脚包括数据输入/输出、方向控制输入、电源和地线等。 - 例如,1B0到1B7对应引脚2, 3, 5, 6, 8, 9, 11, 12;GND包括引脚4, 10, 15等。 4. 参数特性: - 供电电压(VCC)范围为-0.5V至+7.0V。 - 输入电压(VI)范围为-1.2V至+7.0V。 - 输出电压(VO)在关闭状态或高状态时的范围为-0.5V至+5.5V。 - 输出电流在低状态时为-128mA,在高状态时为-64mA。 5. 功能详解: - 描述了器件的逻辑符号、引脚配置、功能描述、限制值、推荐操作条件、静态特性、动态特性等。 6. 应用信息: - 设备适用于汽车、工业、计算、消费和可穿戴应用市场。 7. 封装信息: - 提供了两种封装类型:SSOP48和TSSOP48,分别对应不同的引脚数和体宽。
74ABT16245BDGG,518 价格&库存
很抱歉,暂时无法提供与“74ABT16245BDGG,518”相匹配的价格&库存,您可以联系我们找货
