74LVT16374ADGG,518
74LVT16374ADGG,518
    NEXPERIA(安世)
    TFSOP48
    IC FF D-TYPE DUAL 8BIT 48TSSOP
74LVT16374ADGG,518 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia 74LVT16374A; 74LVTH16374A 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state Rev. 10 — 2 April 2012 Product data sheet 1. General description The 74LVT16374A; 74LVTH16374A are high performance BiCMOS products designed for VCC operation at 3.3 V. This device is a 16-bit edge-triggered D-type flip-flop featuring non-inverting 3-state outputs. The device can be used as two 8-bit flip-flops or one 16-bit flip-flop. On the positive transition of the clock (nCP), the nQn outputs of the flip-flop take on the logic levels set up at the nDn inputs. 2. Features and benefits             16-bit edge-triggered flip-flop 3-state buffers Output capability: +64 mA and 32 mA TTL input and output switching levels Input and output interface capability to systems at 5 V supply Bus-hold data inputs eliminate the need for external pull-up resistors to hold unused inputs Live insertion and extraction permitted Power-up reset Power-up 3-state No bus current loading when output is tied to 5 V bus Latch-up protection:  JESD78B Class II exceeds 500 mA ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVT16374ADL 40 C to +85 C SSOP48 plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 74LVT16374ADGG 40 C to +85 C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74LVT16374AEV 40 C to +85 C VFBGA56 plastic very thin fine-pitch ball grid array package; 56 balls; body 4.5  7  0.65 mm SOT702-1 74LVTH16374ABX 40 C to +125 C HXQFN60 plastic compatible thermal enhanced extremely thin quad flat package; no leads; 60 terminals; body 4  6  0.5 mm SOT1134-2 74LVTH16374ADGG 4. Functional diagram 47 46 44 43 41 40 38 37 1 1OE 48 1CP 24 2OE 25 2CP 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 48 1CP 1 1OE 1D0 1D1 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 1D2 1D3 2 3 5 6 8 9 11 12 1D4 1D5 36 35 33 32 30 29 27 26 1D6 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 25 2D0 2D1 2CP 2D2 24 2D3 2OE 2D4 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 2D5 2D6 13 14 16 17 19 20 22 23 2D7 47 EN1 C3 EN2 C4 3D 44 5 43 6 41 8 40 9 38 11 37 12 36 4D 74LVT_LVTH16374A Product data sheet 2 13 35 14 33 16 32 17 30 19 29 20 27 22 26 23 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 001aaa254 Pin numbers are shown for SSOP48 and TSSOP48 packages only. Logic symbol 2 3 001aac369 Fig 1. 1 46 Pin numbers are shown for SSOP48 and TSSOP48 packages only. Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 2 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state nD0 nD1 D nD2 D CP Q CP nD3 D Q CP nD4 D Q CP nD5 D Q nD6 D CP Q CP nD7 D Q CP D Q CP Q nCP nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 001aac371 Fig 3. Logic diagram 5. Pinning information 5.1 Pinning 74LVT16374A 74LVTH16374A 1OE 1 48 1CP 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2CP ball A1 index area 1 2 3 4 5 6 A B C D E F G H J K 001aak264 Transparent top view 001aak263 Fig 4. Pin configuration for SOT370-1 (SSOP48) and SOT362-1 (TSSOP48) 74LVT_LVTH16374A Product data sheet 74LVT16374A 74LVTH16374A Fig 5. Pin configuration for SOT702-1 (VFBGA56) All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 3 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state terminal 1 index area D1 A32 A1 D5 A31 A30 B20 A29 B19 A28 B18 A27 D4 D8 A26 A2 A25 B17 B1 A3 A24 B16 B2 A4 A23 B15 B3 A5 A22 74LVT16374A 74LVTH16374A B4 A6 B14 A21 B5 B13 A7 A20 B6 B12 B7 B11 A8 A19 A9 A18 GND(1) A10 D6 D2 A11 B8 A12 B10 B9 A13 A14 A15 D7 A17 A16 D3 001aak265 Transparent top view (1) This is not a supply pin, the substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad however if it is soldered the solder land should remain floating or be connected to GND. Fig 6. Pin configuration SOT1134-2 (HXQFN60) 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 4 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description SOT370-1 and SOT362-1 SOT702-1 SOT1134-2 1OE, 2OE 1, 24 A1, K1 A30, A13 output enable input (active LOW) 1CP, 2CP 48, 25 A6, K6 A29, A14 clock input 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 B2, B1, C2, C1, D2, D1, E2, E1 B20, A31, D5, D1, A2, data output B2, B3, A5 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 F1, F2, G1, G2, H1, H2, J1, J2 A6, B5, B6, A9, D2, D6, A12, B8 GND 4, 10, 15, 21, 28, 34, 39, B3, D3, G3, J3, J4, 45 G4, D4, B4 A32, A3, A8, A11, A16, ground (0 V) A19, A24, A27 data output VCC 7, 18, 31, 42 C3, H3, H4, C4 A1, A10, A17, A26 supply voltage 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 B5, B6, C5, C6, D5, D6, E5, E6 B18, A28, D8, D4, A25, B16, B15, A22 data input 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 F6, F5, G6, G5, H6, H5, J6, J5 A21, B13, B12, A18, D3, D7, A15, B10 data input n.c. - A2, A3, A4, A5, A4, A7, A20, A23, B1, B4, B7, B9, B11, B14, B17, B19 not connected K2, K3, K4, K5 6. Functional description Table 3. Function table[1] Operating mode Input nOE nCP nDn Load and read register L  L Hold Disable outputs [1] Internal register Output l L L  h H H L NC X NC NC H NC X NC Z H  nDn nDn Z nQ0 to nQ7 H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW clock transition; L = LOW voltage level; l = LOW voltage level one set-up time prior to the HIGH-to-LOW clock transition; NC = no change; X = don’t care; Z = high-impedance OFF-state;  = LOW-to-HIGH clock transition. 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 5 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +4.6 V [1] 0.5 +7.0 V [1] 0.5 +7.0 V 50 - mA VI input voltage VO output voltage output in OFF-state or HIGH-state IIK input clamping current VI < 0 V IOK output clamping current VO < 0 V 50 - mA IO output current output in LOW-state - 128 mA output in HIGH-state 64 - mA 65 +150 C [2] - 150 C (T)SSOP48 package [3] - 500 mW VFBGA56 and HXQFN60 package [4] - 1000 mW storage temperature Tstg Tj junction temperature Ptot total power dissipation Tamb = 40 C to +85 C [1] The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. [2] The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. [3] Above 60 C the value of Ptot derates linearly with 5.5 mW/K. [4] Above 70 C the value of Ptot derates linearly with 1.8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Typ Max Unit VCC supply voltage Conditions 2.7 - 3.6 V VI input voltage 0 - 5.5 V VIH HIGH-level input voltage 2.0 - - V VIL LOW-level input voltage - - 0.8 V IOH HIGH-level output current 32 - - mA IOL LOW-level output current none - - 32 mA current duty cycle  50 %; fi  1 kHz - - 64 mA in free-air 40 - +85 C - - 10 ns/V Tamb ambient temperature t/V input transition rise and fall rate outputs enabled 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 6 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit VCC = 2.7 V; IIK = 18 mA 1.2 0.85 Tamb = 40 C to +85 C VIK input clamping voltage VOH HIGH-level output voltage IOH = 100 A; VCC = 2.7 V to 3.6 V VOL - V VCC  0.2 VCC - V IOH = 8 mA; VCC = 2.7 V 2.4 2.5 - V IOH = 32 mA; VCC = 3.0 V 2.0 2.3 - V IOL = 100 A - 0.07 0.2 V IOL = 24 mA - 0.3 0.5 V IOL = 16 mA - 0.25 0.4 V IOL = 32 mA - 0.3 0.5 V - 0.4 0.55 V - 0.1 0.55 V - 0.1 1 A - 0.4 10 A VCC = 0 V or 3.6 V; VI = 5.5 V - 0.4 10 A VCC = 3.6 V; VI = VCC - 0.1 1 A VCC = 3.6 V; VI = 0 V 5 0.4 - A LOW-level output voltage VCC = 2.7 V VCC = 3.0 V IOL = 64 mA VOL(pu) power-up LOW-level output voltage VCC = 3.6 V; IO = 1 mA; VI = VCC or GND II input leakage current control pins [2] VCC = 3.6 V; VI = VCC or GND VCC = 0 V or 3.6 V; VI = 5.5 V input data pins [3] IOFF power-off leakage current VCC = 0 V; VI or VO = 0 V to 4.5 V - 0.1 100 A IBHL bus hold LOW current VCC = 3 V; VI = 0.8 V 75 135 - A IBHH bus hold HIGH current VCC = 3 V; VI = 2.0 V IBHLO bus hold LOW overdrive current input data pins; VI = 0 V to 3.6 V; VCC = 3.6 V [4] IBHHO bus hold HIGH overdrive current input data pins; VI = 0 V to 3.6 V; VCC = 3.6 V [4] ILO output leakage current output in HIGH-state when VO > VCC; VO = 5.5 V; VCC = 3.0 V IO(pu/pd) power-up/power-down output current VCC  1.2 V; VO = 0.5 V to VCC; VI = GND or VCC; nOE = don’t care IOZ OFF-state output current VCC = 3.6 V; VI = VIH or VIL ICC supply current [5] 75 A 500 - - A - - 500 A - 50 125 A - 1 100 A output HIGH: VO = 3.0 V - 0.5 5 A 5 0.5 - A - 0.07 0.12 mA VCC = 3.6 V; VI = GND or VCC; IO = 0 A outputs LOW outputs disabled Product data sheet 135 output LOW: VO = 0.5 V outputs HIGH 74LVT_LVTH16374A - All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 [6] - 4.0 6.0 mA - 0.07 0.12 mA © NXP B.V. 2012. All rights reserved. 7 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit - 0.1 0.2 mA ICC additional supply current CI input capacitance input pins; VI = 0 V or 3.0 V - 3 - pF CO output capacitance output pins nQn; outputs disabled; VO = 0 V or VCC - 9 - pF per input pin; VCC = 3.0 V to 3.6 V; one input at VCC  0.6 V, other inputs at VCC or GND [7] [1] Typical values are measured at VCC = 3.3 V and at Tamb = 25 C. [2] For valid test results, data must not be loaded into the flips-flops (or latches) after applying power. [3] Unused pins at VCC or GND. [4] This is the bus hold overdrive current required to force the input to the opposite logic state. [5] This parameter is valid for any VCC between 0 V and 1.2 V with a transition time of up to 10 ms. From VCC = 1.2 V to VCC = 3.3 V  0.3 V a transition time of 100 s is permitted. This parameter is valid for Tamb = 25 C only. [6] ICC is measured with outputs pulled to VCC or GND. [7] This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C fmax maximum frequency nCP; VCC = 3.3 V  0.3 V; see Figure 7 150 - - MHz tPLH LOW to HIGH propagation delay VCC = 3.3 V  0.3 V 1.5 2.9 5.0 ns VCC = 2.7 V - - 5.6 ns VCC = 3.3 V  0.3 V 1.5 3.0 5.0 ns VCC = 2.7 V - - 5.6 ns VCC = 3.3 V  0.3 V 1.5 3.2 4.8 ns VCC = 2.7 V - - 6.0 ns VCC = 3.3 V  0.3 V 1.5 3.0 4.6 ns VCC = 2.7 V - - 5.2 ns VCC = 3.3 V  0.3 V 1.5 3.9 5.4 ns VCC = 2.7 V - - 6.0 ns VCC = 3.3 V  0.3 V 1.5 3.4 4.6 ns VCC = 2.7 V - - 5.0 ns tPHL tPZH tPZL tPHZ tPLZ HIGH to LOW propagation delay nCP to nQn; see Figure 7 nCP to nQn; see Figure 7 OFF-state to HIGH propagation delay nOE to nQn; see Figure 8 OFF-state to LOW propagation delay nOE to nQn; see Figure 8 HIGH to OFF-state propagation delay LOW to OFF-state propagation delay 74LVT_LVTH16374A Product data sheet nOE to nQn; see Figure 8 nOE to nQn; see Figure 8 All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 8 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 10. Symbol Parameter tsu Min Typ[1] Max Unit 2.0 0.7 - ns 2.0 - - ns 0.8 0 - ns 0.1 - - ns VCC = 3.3 V  0.3 V 1.5 0.6 - ns VCC = 2.7 V 1.5 - - ns VCC = 3.3 V  0.3 V 3.0 1.6 - ns VCC = 2.7 V 3.0 - - ns Conditions set-up time nDn to nCP; HIGH or LOW; see Figure 9 [2] VCC = 3.3 V  0.3 V VCC = 2.7 V hold time th nDn to nCP; HIGH or LOW; see Figure 9 [3] VCC = 3.3 V  0.3 V VCC = 2.7 V pulse width tW [4] nCP HIGH; see Figure 7 nCP LOW; see Figure 7 [1] All typical values are at VCC = 3.3 V and Tamb = 25 C. [2] tsu is the same as tsu(H) and tsu(L). [3] th is the same as th(H) and th(L). [4] tW is the same as tW(H) and tW(L). 11. Waveforms 1/fmax VI nCP input VM VM GND tW t PHL t PLH VOH VM nQn output 001aaa256 VOL Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Propagation delay clock input to output, clock pulse width and maximum clock frequency Table 8. Measurement points Input Output VM VM VX VY 1.5 V 1.5 V VOL + 0.3 V VOH  0.3 V 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 9 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state VI nOE input VM GND tPZL tPLZ 3.0 V VM nYn output VX VOL t PZH t PHZ VOH nYn output VY VM 0V 001aae464 Measurements points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Enable and disable times VI VM nCP input GND t su t su th th VI VM nDn input GND VOH VM nQn output VOL 001aaa257 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Remark: The shaded areas indicate when the input is permitted to change for predictable output performance. Fig 9. Data set-up and hold times 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 10 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI PULSE GENERATOR RL VO DUT RT CL RL 001aae235 Test data is given in Table 9. Definitions test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = Test voltage for switching times. Fig 10. Test circuit for measuring switching times Table 9. Test data Input Load VEXT VI fi tW tr, tf CL RL tPHZ, tPZH tPLZ, tPZL tPLH, tPHL 2.7 V  10 MHz 500 ns  2.5 ns 50 pF 500  GND 6V open 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 11 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 12. Package outline SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm SOT370-1 D E A X c y HE v M A Z 25 48 Q A2 A1 A (A 3) θ pin 1 index Lp L 24 1 detail X w M bp e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2.8 0.4 0.2 2.35 2.20 0.25 0.3 0.2 0.22 0.13 16.00 15.75 7.6 7.4 0.635 10.4 10.1 1.4 1.0 0.6 1.2 1.0 0.25 0.18 0.1 0.85 0.40 8o o 0 Note 1. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT370-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-118 Fig 11. Package outline SOT370-1 (SSOP48) 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 12 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 E D A X c HE y v M A Z 48 25 Q A2 (A 3) A1 pin 1 index A θ Lp L 1 detail X 24 w M bp e 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 12.6 12.4 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.8 0.4 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT362-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig 12. Package outline SOT362-1 (TSSOP48) 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 13 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state VFBGA56: plastic very thin fine-pitch ball grid array package; 56 balls; body 4.5 x 7 x 0.65 mm B D SOT702-1 A ball A1 index area A E A2 A1 detail X e1 1/2 C ∅v M C A B ∅w M C b e y1 C e y K J H e G F e2 E D 1/2 e C X B A ball A1 index area 1 2 3 4 5 6 DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 b D E e e1 e2 v w y y1 mm 1 0.3 0.2 0.7 0.6 0.45 0.35 4.6 4.4 7.1 6.9 0.65 3.25 5.85 0.15 0.08 0.08 0.1 OUTLINE VERSION SOT702-1 REFERENCES IEC JEDEC JEITA 0 2.5 5 mm scale EUROPEAN PROJECTION ISSUE DATE 02-08-08 03-07-01 MO-225 Fig 13. Package outline SOT702-1 (VFBGA56) 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 14 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state HXQFN60: plastic compatible thermal enhanced extremely thin quad flat package; no leads; 60 terminals; body 4 x 6 x 0.5 mm A B D SOT1134-2 terminal 1 index area A A2 E A1 detail X e2 b e1 L1 L A11 B10 A17 A10 eR eT y y1 C D3 D7 A16 B8 C eT 1/2 e D2 D6 C A B C eR e C A B C v w v w e B11 B7 Eh e3 e4 1/2 e B17 B1 A1 terminal 1 index area A26 D5 D1 A32 B20 B18 A27 Dh D8 D4 eT eR X K eT eR 0 5 mm Dimensions Unit mm A A1 A2 b max 0.50 0.08 0.42 0.28 nom 0.05 0.40 0.23 min 0.02 0.38 0.18 D Dh E Eh e e1 e2 e3 e4 eR 4.1 4.0 3.9 1.95 1.85 1.75 6.1 6.0 5.9 3.95 3.85 3.75 0.5 1.0 2.5 3.0 4.5 0.5 eT K L L1 v w 0.25 0.28 0.195 0.49 0.20 0.23 0.145 0.1 0.15 0.18 0.095 y 0.05 0.08 y1 0.1 sot1134-2_po References Outline version IEC JEDEC JEITA SOT1134-2 --- --- --- European projection Issue date 11-08-15 Fig 14. Package outline SOT1134-2 (HXQFN60) 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 15 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description BiCMOS Bipolar Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date 74LVT_LVTH16374A v.10 20120402 Modifications: 74LVT_LVTH16374A v.9 Modifications: • Change notice Supersedes Product data sheet - 74LVT_LVTH16374A v.9 For type number 74LVTH16374ABX the sot code has changed to SOT1134-2. 20111122 • Data sheet status Product data sheet - 74LVT_LVTH16374A v.8 Legal pages updated. 74LVT_LVTH16374A v.8 20110620 Product data sheet - 74LVT_LVTH16374A v.7 74LVT_LVTH16374A v.7 20100322 Product data sheet - 74LVT_LVTH16374A v.6 74LVT_LVTH16374A v.6 20100118 product data sheet - 74LVT16374A v.5 74LVT16374A v.5 20040916 product data sheet - 74LVT16374A v.4 74LVT16374A v.4 20021101 product specification - 74LVT16374A v.3 74LVT16374A v.3 19991018 product specification - 74LVT16374A v.2 74LVT16374A v.2 19980219 product specification - - 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 16 of 19 74LVT16374A; 74LVTH16374A NXP Semiconductors 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. NXP Semiconductors takes no responsibility for the content in this document if provided by an information source outside of NXP Semiconductors. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74LVT_LVTH16374A Product data sheet Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors and its suppliers accept no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 17 of 19 NXP Semiconductors 74LVT16374A; 74LVTH16374A 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com 74LVT_LVTH16374A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 2 April 2012 © NXP B.V. 2012. All rights reserved. 18 of 19 NXP Semiconductors 74LVT16374A; 74LVTH16374A 3.3 V 16-bit edge-triggered D-type flip-flop; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2012. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 2 April 2012 Document identifier: 74LVT_LVTH16374A
74LVT16374ADGG,518 价格&库存
很抱歉,暂时无法提供与“74LVT16374ADGG,518”相匹配的价格&库存,您可以联系我们找货
74LVT16374ADGG,518
  • 2000+2.883882000+0.37360
  • 4000+2.804454000+0.36331
  • 6000+2.764646000+0.35816
  • 10000+2.7205710000+0.35245
  • 14000+2.6948014000+0.34911
  • 20000+2.6700420000+0.34590
